10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10010-MPLS
05-HH3C-MPLSCRLSP-MIB
05-HH3C-MPLSCRLSP-MIB 49.19 KB
HH3C-MPLSSCRLSP-MIB
About this MIB
Use this MIB to notify traps about static CRLSPs.
MIB file name
hh3c-mplsscrlsp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(4).mib-2(1).transmission(25506).mplsStdMIB(2).mplsTeCrlspStdMIB(231)
Tabular objects
hh3cMplsScrlspBaseInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsScrlspBaseInfo (1.3.6.1.4.1.25506.2.231.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (1..127)
Static CRLSP basic information
As per the MIB.
hh3cMplsScrlspExtInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsScrlspExtInfo (1.3.6.1.4.1.25506.2.231.1.1.2)
OCTET STRING
Static CRLSP extended information
As per the MIB.
Notifications
hh3cMplsScrlspDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.231.0.1
Static CRLSP down
Error
Major
1.3.6.1.4.1.25506.2.231.0.2 (hh3cMplsScrlspUp)
ON
This notification is generated when a static CRLSP goes down. The MPLS TE tunnel that uses the static CRLSP will fail to forward traffic.
Status control
ON
CLI: Use the snmp-agent trap enable lsm command.
OFF
CLI: Use the undo snmp-agent trap enable lsm command.
Objects
OID (object name)
Index
Value range
Yes
OCTET STRING
As per the MIB.
Yes
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cMplsScrlspUp
Basic information
OID
Event
Severity
Default status
Static CRLSP up
Recovery
N/A
N/A
ON
This notification is generated when a static CRLSP comes up.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index
Value range
Yes
OCTET STRING
As per the MIB.
Yes
OCTET STRING
As per the MIB.
Recommended action
