- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
14-MPLS-L3VPN-STD-MIB | 140.71 KB |
mplsL3VpnVrfConfRteMxThrshTime
mplsL3VpnVrfRouteMidThreshExceeded
mplsL3VpnVrfNumVrfRouteMaxThreshExceeded
mplsL3VpnNumVrfRouteMaxThreshCleared
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsL3VpnMIB(11)
Scalar objects
mplsL3VpnConfiguredVrfs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConfiguredVrfs (1.3.6.1.2.1.10.166.11.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of configured VRFs. |
As per the MIB. |
mplsL3VpnActiveVrfs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnActiveVrfs (1.3.6.1.2.1.10.166.11.1.1.2) |
read-only |
Gauge32 |
INTEGER(0..4294967295) |
Number of VRFs in up state. |
As per the MIB. |
mplsL3VpnConnectedInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConnectedInterfaces (1.3.6.1.2.1.10.166.11.1.1.3) |
read-only |
Gauge32 |
Number of interfaces bound to the VRF. |
As per the MIB. |
mplsL3VpnNotificationEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnNotificationEnable (1.3.6.1.2.1.10.166.11.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether MPLS L3VPN notification is enabled. |
As per the MIB. |
mplsL3VpnVrfConfMaxPossRts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfMaxPossRts (1.3.6.1.2.1.10.166.11.1.1.5) |
read-only |
Unsigned32 |
Maximum number of routes that all VRFs on the device can have. |
As per the MIB. This object is not supported. The return value is always 0. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfRteMxThrshTime (1.3.6.1.2.1.10.166.11.1.1.6) |
read-only |
Unsigned32 |
Interval at which the route max threshold notification is regenerated after the maximum route number is exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification is sent. If this value is set to 0, the agent generates only one notification when maximum route number is reached. |
mplsL3VpnIllLblRcvThrsh
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIllLblRcvThrsh (1.3.6.1.2.1.10.166.11.1.1.7) |
read-write |
Unsigned32 |
Number of received incorrect labels. |
Supports only the read operation. This object is not supported. The return value is always 32. |
Tabular objects
mplsL3VpnIfConfTable
About this table
This table specifies MPLS capability and associated VPNs for an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName and mplsL3VpnIfConfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIfConfIndex(1.3.6.1.2.1.10.166.11.1.2.1.1.1) |
not-accessible |
InterfaceIndex |
Integer32(1..2147483647) |
Interface index. |
As per the MIB. |
mplsL3VpnIfVpnClassification(1.3.6.1.2.1.10.166.11.1.2.1.1.2) |
read-create |
INTEGER |
carrierOfCarrier (1), enterprise (2), interProvider (3) |
Interface category. |
Supports only the read operation. |
mplsL3VpnIfVpnRouteDistProtocol (1.3.6.1.2.1.10.166.11.1.2.1.1.3) |
read-create |
BITS |
none (0), bgp (1), ospf (2), rip(3), isis(4), static(5), other (6) |
Route distribution protocol. |
mplsL3VpnIfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.1.1.4) |
read-create |
StorageType |
INTEGER { other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) } |
Storage type of the interface. |
mplsL3VpnIfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.1.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
mplsL3VpnVrfTable
About this table
This table contains VRF configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is mplsL3VpnVrfName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfName (1.3.6.1.2.1.10.166.11.1.2.2.1.1) |
not-accessible |
MplsL3VpnName |
OCTET STRING (0..31) |
VRF name. |
As per the MIB. |
mplsL3VpnVrfVpnId (1.3.6.1.2.1.10.166.11.1.2.2.1.2) |
read-create |
VPNIdOrZero |
OCTET STRING (0 | 7) |
VPN ID. |
As per the MIB. |
mplsL3VpnVrfDescription (1.3.6.1.2.1.10.166.11.1.2.2.1.3) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
VRF description. |
As per the MIB. |
mplsL3VpnVrfRD (1.3.6.1.2.1.10.166.11.1.2.2.1.4) |
read-create |
MplsL3VpnRouteDistinguisher |
OCTET STRING(0..256) |
Configured RD. By default, a get operation obtains the global RD. If no global RD is configured, it obtains the RD for the IPv4 unicast address family. If the IPv4 unicast address family RD is not configured either, "0:0" is displayed. |
As per the MIB. |
mplsL3VpnVrfCreationTime (1.3.6.1.2.1.10.166.11.1.2.2.1.5) |
read-only |
TimeStamp |
TimeTicks |
Time when the VRF entry was created. |
As per the MIB. |
mplsL3VpnVrfOperStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.6) |
read-only |
INTEGER |
up (1), down (2) |
Up/down state. |
As per the MIB. |
mplsL3VpnVrfActiveInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.7) |
read-only |
Gauge32 |
Number of associated interfaces in up state. |
As per the MIB. |
mplsL3VpnVrfAssociatedInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.8) |
read-only |
Unsigned32 |
Number of associated interfaces. |
As per the MIB. |
mplsL3VpnVrfConfMidRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.9) |
read-create |
Unsigned32 |
Mid-level water marker for the number of routes that this VRF supports. |
mplsL3VpnVrfConfHighRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.10) |
read-create |
Unsigned32 |
High-level water marker for the number of routes that the VRF supports. |
mplsL3VpnVrfConfMaxRoutes (1.3.6.1.2.1.10.166.11.1.2.2.1.11) |
read-create |
Unsigned32 |
Maximum number of routes that this VRF is configured to hold. |
mplsL3VpnVrfConfLastChanged (1.3.6.1.2.1.10.166.11.1.2.2.1.12) |
read-only |
TimeStamp |
TimeTicks |
Time when the entry changed most recently. |
As per the MIB. |
mplsL3VpnVrfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.13) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
mplsL3VpnVrfConfAdminStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.14) |
read-create |
INTEGER |
up(1), down(2), testing(3) |
Administrative state of the VRF. |
mplsL3VpnVrfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.2.1.15) |
read-create |
StorageType |
Storage type of the VRF. |
mplsL3VpnVrfRTTable
About this table
This table contains VPN RT information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRTIndex, and mplsL3VpnVrfRTType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRTIndex (1.3.6.1.2.1.10.166.11.1.2.3.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(1..4294967295) |
RT index. |
As per the MIB. |
mplsL3VpnVrfRTType (1.3.6.1.2.1.10.166.11.1.2.3.1.3) |
not-accessible |
MplsL3VpnRtType |
import (1), export (2), or both (3). |
Incoming and outgoing policies. |
As per the MIB. |
mplsL3VpnVrfRT (1.3.6.1.2.1.10.166.11.1.2.3.1.4) |
read-create |
RT character string. |
mplsL3VpnVrfRTDescr (1.3.6.1.2.1.10.166.11.1.2.3.1.5) |
read-create |
SnmpAdminString |
RT description. |
mplsL3VpnVrfRTRowStatus (1.3.6.1.2.1.10.166.11.1.2.3.1.6) |
read-create |
RowStatus |
Row status. |
mplsL3VpnVrfRTStorageType (1.3.6.1.2.1.10.166.11.1.2.3.1.7) |
read-create |
StorageType |
RT storage type. |
mplsL3VpnVrfSecTable
About this table
This table contains MPLS VRF security statistics information about interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfSecIllegalLblVltns (1.3.6.1.2.1.10.166.11.1.2.6.1.1) |
read-only |
Counter32 |
Number of invalid labels that are received. |
As per the MIB. |
mplsL3VpnVrfSecDiscontinuityTime (1.3.6.1.2.1.10.166.11.1.2.6.1.2) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. |
As per the MIB. |
mplsL3VpnVrfPerfTable
About this table
This table contains MPLS L3VPN VRF table performance information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfPerfRoutesAdded (1.3.6.1.2.1.10.166.11.1.3.1.1.1) |
read-only |
Counter32 |
Total number of added IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDeleted (1.3.6.1.2.1.10.166.11.1.3.1.1.2) |
read-only |
Counter32 |
Total number of deleted IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfCurrNumRoutes (1.3.6.1.2.1.10.166.11.1.3.1.1.3) |
read-only |
Gauge32 |
Total number of active IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDropped (1.3.6.1.2.1.10.166.11.1.3.1.1.4) |
read-only |
Counter32 |
Number of discarded routes. |
As per the MIB. |
mplsL3VpnVrfPerfDiscTime (1.3.6.1.2.1.10.166.11.1.3.1.1.5) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. The value of this object is always 0. |
As per the MIB. |
mplsL3VpnVrfRteTable
About this table
This table contains information about routes configured for a VRF.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRteInetCidrDestType, mplsL3VpnVrfRteInetCidrDest, mplsL3VpnVrfRteInetCidrPfxLen, mplsL3VpnVrfRteInetCidrPolicy, mplsL3VpnVrfRteInetCidrNHopType, and mplsL3VpnVrfRteInetCidrNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRteInetCidrDestType (1.3.6.1.2.1.10.166.11.1.4.1.1.1) |
not-accessible |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), dns(16) } |
Destination address type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrDest (1.3.6.1.2.1.10.166.11.1.4.1.1.2) |
not-accessible |
InetAddress |
Destination IP address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPfxLen (1.3.6.1.2.1.10.166.11.1.4.1.1.3) |
not-accessible |
InetAddressPrefixLength |
Unsigned32(0..128) |
Prefix length of the destination address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPolicy (1.3.6.1.2.1.10.166.11.1.4.1.1.4) |
not-accessible |
OBJECT IDENTIFIER |
Additional index that delineates between multiple entries to the same destination. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNHopType (1.3.6.1.2.1.10.166.11.1.4.1.1.5) |
not-accessible |
InetAddressType |
Next hop type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHop (1.3.6.1.2.1.10.166.11.1.4.1.1.6) |
not-accessible |
InetAddress |
Next hop. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrIfIndex (1.3.6.1.2.1.10.166.11.1.4.1.1.7) |
read-create |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Egress interface index. |
mplsL3VpnVrfRteInetCidrType (1.3.6.1.2.1.10.166.11.1.4.1.1.8) |
read-create |
INTEGER |
other(1), reject(2), local(3), remote (4), blackhole(5) |
Route type. |
mplsL3VpnVrfRteInetCidrProto (1.3.6.1.2.1.10.166.11.1.4.1.1.9) |
read-only |
IANAipRouteProtocol |
Routing protocol. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrAge(1.3.6.1.2.1.10.166.11.1.4.1.1.10) |
read-only |
Gauge32 |
Route update time. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHopAS (1.3.6.1.2.1.10.166.11.1.4.1.1.11) |
read-create |
InetAutonomousSystemNumber |
AS number of the next hop. |
mplsL3VpnVrfRteInetCidrMetric1 (1.3.6.1.2.1.10.166.11.1.4.1.1.12) |
read-create |
Integer32 |
Integer32(-1 | 0..2147483647) |
Primary route metric. |
mplsL3VpnVrfRteInetCidrMetric2 (1.3.6.1.2.1.10.166.11.1.4.1.1.13) |
read-create |
Integer32 |
Optional route metric. |
Supports only the read operation. Set the value of this object to -1 if this object is not used. |
mplsL3VpnVrfRteInetCidrMetric3 (1.3.6.1.2.1.10.166.11.1.4.1.1.14) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric4 (1.3.6.1.2.1.10.166.11.1.4.1.1.15) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric5 (1.3.6.1.2.1.10.166.11.1.4.1.1.16) |
read-create |
Integer32 |
mplsL3VpnVrfRteXCPointer (1.3.6.1.2.1.10.166.11.1.4.1.1.17) |
read-create |
MplsIndexType |
mplsXCTable index. |
Supports only the read operation. This object is not supported. The return value is always 00.00.00.00. |
mplsL3VpnVrfRteInetCidrStatus (1.3.6.1.2.1.10.166.11.1.4.1.1.18) |
read-create |
RowStatus |
Row status. |
Notifications
mplsL3VpnVrfUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.11.0.1 |
An interface associated with a VRF comes up. |
Recovery |
ON |
A notification sent when the following conditions exist:
· No interface is associated with this VRF. The value of the ifOperStatus object for the first (and only the first) interface associated with it changes to up(1).
· One interface is associated with this VRF. The value of the ifOperStatus object for the interface changes to up(1).
· Multiple interfaces are associated with this VRF. The value of the ifOperStatus object for all interfaces except for the first one is down(2), and the value of the ifOperStatus object for the first interface changes to up(1).
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn command.
OFF
CLI: Use the undo snmp-agent trap enable l3vpn command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.166.11.1.2.1.1.5 (mplsL3VpnIfConfRowStatus) |
Row status used to create, modify, and delete a row in this table. |
No |
INTEGER |
active(1) |
1.3.6.1.2.1.10.166.11.1.2.2.1.6 (mplsL3VpnVrfOperStatus) |
Operational state of the VPN. |
No |
INTEGER |
up(1) down(2) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
mplsL3VpnVrfDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.2 |
An interface associated with a VRF goes down. |
Error |
Major |
ON |
· One interface is associated with this VRF. The value of the ifOperStatus object for the interface changes from up to down.
· Multiple interfaces are associated with this VRF. The value of the ifOperStatus object for all interfaces except for the first one is up, and the value of the ifOperStatus object for the first interface changes from up to down.
· The last interface whose ifOperStatus value is up disassociates from this VRF.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
active(1) |
No |
INTEGER |
up(1) down(2) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.3 |
The number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold. |
Error |
Warning |
ON |
A notification sent when the number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold. Only one notification is generated when this threshold is exceeded. No more notifications of this type will be generated until the value of mplsL3VpnVrfPerfCurrNumRoutes falls below that of mplsL3VpnVrfConfMidRteThresh.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.166.11.1.3.1.1.3 (mplsL3VpnVrfPerfCurrNumRoutes) |
No |
Gauge32 |
1.3.6.1.2.1.10.166.11.1.2.2.1.9 (mplsL3VpnVrfConfMidRteThresh) |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.4 |
The number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold. |
Error |
Warning |
1.3.6.1.2.1.10.166.11.0.6 |
ON |
A notification sent when the number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold. If mplsL3VpnVrfConfHighRteThresh is set to the same value as mplsL3VpnVrfConfMaxRoutes, this notification is generated when mplsL3VpnVrfConfHighRteThresh is reached.
mplsL3VpnVrfConfRteMxThrshTime defines the interval at which this notification is regenerated after the maximum value has been exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification has been sent. This interval prevents continuous generation of notifications by an agent when routes are continually added to a VRF after it has reached its maximum value. The default value is 0. If this value is set to 0, the agent generates a single notification when the maximum threshold has been reached and does not generate any more notifications until the number of routes falls below the configured threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Gauge32 |
1.3.6.1.2.1.10.166.11.1.2.2.1.10 (mplsL3VpnVrfConfHighRteThresh) |
No |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
The number of routes in a VRF falls below the value of the mplsVrfMaxRouteThreshold object. |
Informational |
ON |
This notification is generated only after the number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by the mplsVrfMaxRouteThreshold object and then falls below this value. The notification informs the operator that the error has been cleared and the operator does not need to check the device.
mplsL3VpnVrfConfRteMxThrshTime defines the interval at which the mplsNumVrfRouteMaxThreshExceeded notification will be regenerated after the maximum value has been exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification has been sent. The generation of this notification will be triggered with the same frequency (assuming that the error condition is cleared). If the error condition is reached and cleared several times during the period of time specified in mplsL3VpnVrfConfRteMxThrshTime, only a single notification will be generated to indicate the first instance of the error condition as well as the first time the error condition is cleared.
This prevents continuous generation of notifications by an agent in the event that routes are continually added to or removed from a VRF after it has reached its maximum value. The default value is 0. If this value is set to 0, the agent sends a notification whenever the maximum threshold has been cleared.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Gauge32 |
No |
Unsigned32 |
Recommended action
