- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
15-MPLS-LDP-STD-MIB | 133.65 KB |
MPLS-LDP-STD-MIB
About this MIB
LDP is the core of MPLS and defines the messages and processing procedures involved in the label distribution process.
The Label Distribution Protocol (LDP) dynamically distributes FEC-label mapping information between LSRs to establish LSPs. LSPs can be established between two adjacent LSRs or terminate at the egress node of the network, so that all intermediate nodes in the network use label switching.
MPLS-LDP-STD-MIB is a public MIB defined by RFC 3815.
MIB file name
rfc3815-mpls-ldp-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsLdpStdMIB(4)
Scalar objects
mplsLdpLsrId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpLsrId (1.3.6.1.2.1.10.166.4.1.1.1) |
read-only |
Octet string |
Octet string (0..65535) |
LDP LSR ID. |
As per the MIB. |
mplsLdpLsrLoopDetectionCapable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpLsrLoopDetectionCapable (1.3.6.1.2.1.10.166.4.1.1.2) |
read-only |
Integer |
1:none(1) 2:other(2) 3:hopCount(3) 4:pathVector(4) 5:hopCountAndPathVector(5) |
Whether the LSR supports loop detection. |
The value of this object is fixed at hopCountAndPathVector(5). |
mplsLdpEntityLastChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpEntityLastChange (1.3.6.1.2.1.10.166.4.1.2.1) |
read-only |
TimeTicks |
Standard MIB values. |
System time when an entry in the mplsLdpEntityTable table was most recently added, deleted, or modified. |
As per the MIB. |
mplsLdpEntityIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpEntityIndexNext (1.3.6.1.2.1.10.166.4.1.2.2) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Next LDP entity index. |
This object returns 0, which indicates that the network administrator cannot create mplsLdpEntityTable. |
mplsLdpPeerLastChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpPeerLastChange (1.3.6.1.2.1.10.166.4.1.3.1) |
read-only |
TimeStamp |
INTEGER (0..4294967295) |
Time when the entry was edited. |
As per the MIB. |
mplsFecLastChange
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFecLastChange (1.3.6.1.2.1.10.166.4.1.3.8.1) |
read-only |
TimeStamp |
System time when the LDP FEC entry was most recently modified. |
Not supported |
mplsFecIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFecIndexNext (1.3.6.1.2.1.10.166.4.1.3.8.2) |
read-only |
IndexIntegerNextFree |
Gauge32 (1..4294967295) |
Next LDP FEC index. |
This object returns 0, which indicates that the network administrator cannot create mplsFecTable. |
Tabular objects
mplsLdpEntityTable
About this table
This table contains LDP entity information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsLdpEntityLdpId and mplsLdpEntityIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpEntityLdpId (1.3.6.1.2.1.10.166.4.1.2.3.1.1) |
not-accessible |
MplsLdpIdentifier |
OCTET STRING (6,6) |
LDP entity ID. |
As per the MIB. |
mplsLdpEntityIndex (1.3.6.1.2.1.10.166.4.1.2.3.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 (1,4294967295) |
LDP entity index. |
As per the MIB. |
mplsLdpEntityProtocolVersion (1.3.6.1.2.1.10.166.4.1.2.3.1.3) |
read-create |
Unsigned32 |
Unsigned32 (1~65535) |
Version number of the LDP protocol which will be used in the session initialization message. |
As per the MIB. |
mplsLdpEntityAdminStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.4) |
read-create |
INTEGER |
enable(1) disable(2) |
Administrative state of the LDP entity. |
As per the MIB. |
mplsLdpEntityOperStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.5) |
read-only |
INTEGER |
1:unknown(1) 2:enabled(2) 3:disabled(3)
Operational state of the LDP entity. |
As per the MIB. Default: enabled. |
mplsLdpEntityTcpPort (1.3.6.1.2.1.10.166.4.1.2.3.1.6) |
read-create |
Unsigned32 |
Unsigned32 (0..65535) |
TCP port number of the LDP entity. |
As per the MIB. Default: 646. |
mplsLdpEntityUdpDscPort (1.3.6.1.2.1.10.166.4.1.2.3.1.7) |
read-create |
Unsigned32 |
UDP port number of the LDP entity. |
mplsLdpEntityMaxPduLength (1.3.6.1.2.1.10.166.4.1.2.3.1.8) |
read-create |
Unsigned32 |
Unsigned32 (256..65535) |
Maximum PDU length of the LDP entity. |
As per the MIB. Default: 4096. |
mplsLdpEntityKeepAliveHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.9) |
read-create |
Unsigned32 |
Unsigned32 (1..65535) |
Keepalive interval of the LDP entity. |
As per the MIB. Default: 40. |
mplsLdpEntityHelloHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.10) |
read-create |
Unsigned32 |
Hello interval of the LDP entity. |
As per the MIB. Default: 0. If mplsLdpEntityTargetPeer is set to false, the actual default value is 15. If mplsLdpEntityTargetPeer is set to true, the actual default value is 45. |
mplsLdpEntityInitSessionThreshold (1.3.6.1.2.1.10.166.4.1.2.3.1.11) |
read-create |
Integer32 |
Integer32 (0..100) |
LDP entity session initialization threshold. |
As per the MIB. Default: 8. |
mplsLdpEntityLabelDistMethod (1.3.6.1.2.1.10.166.4.1.2.3.1.12) |
read-create |
INTEGER |
downstreamOnDemand(1) downstreamUnsolicited(2) |
LDP entity label distribution method. |
As per the MIB. |
mplsLdpEntityLabelRetentionMode (1.3.6.1.2.1.10.166.4.1.2.3.1.13) |
read-create |
INTEGER |
conservative(1) liberal(2) |
Label retention mode used by the LDP entity. |
As per the MIB. |
mplsLdpEntityPathVectorLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.14) |
read-create |
Integer32 |
Integer32 (0..255) |
LDP entity path vector limit. |
As per the MIB. 0 indicates that loop detection is not enabled. |
mplsLdpEntityHopCountLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.15) |
read-create |
Integer32 |
LDP entity hop limit. |
mplsLdpEntityTransportAddrKind (1.3.6.1.2.1.10.166.4.1.2.3.1.16) |
read-create |
INTEGER |
1:Interface(1) 2:loopback(2)
LDP entity transport address type. |
As per the MIB. Default: loopback(2). |
mplsLdpEntityTargetPeer (1.3.6.1.2.1.10.166.4.1.2.3.1.17) |
read-create |
INTEGER |
true(1) false(2) |
If this LDP entity uses targeted peer, set this to true. |
As per the MIB. Default: false. |
mplsLdpEntityTargetPeerAddrType (1.3.6.1.2.1.10.166.4.1.2.3.1.18) |
read-create |
InetAddressType |
INTEGER unknown (0) , ipv4(1) , ipv6 (2) , ipv4z (3) , ipv6z (4), dns(16) |
Type of the internetwork layer address used for the Extended Discovery. |
As per the MIB. Supports only ipv4. |
mplsLdpEntityTargetPeerAddr (1.3.6.1.2.1.10.166.4.1.2.3.1.19) |
read-create |
OCTET STRING |
OCTET STRING (0..255) |
The value of the internetwork layer address used for the Extended Discovery. |
As per the MIB. |
mplsLdpEntityLabelType (1.3.6.1.2.1.10.166.4.1.2.3.1.20) |
read-create |
INTEGER |
generic(1), atmParameters(2), frameRelayParameters(3) |
LDP entity label type. |
As per the MIB. |
mplsLdpEntityDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.2.3.1.21) |
read-only |
TimeTicks |
System time when any one or more of this entity's counters suffered a discontinuity most recently. |
As per the MIB. |
mplsLdpEntityStorageType (1.3.6.1.2.1.10.166.4.1.2.3.1.22) |
read-create |
INTEGER |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for the LDP entity. |
As per the MIB. |
mplsLdpEntityRowStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.23) |
read-create |
INTEGER |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
mplsLdpEntityStatsTable
About this table
This table contains LDP entity statistics information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpEntityStatsSessionAttempts (1.3.6.1.2.1.10.166.4.1.2.4.1.1) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Session initialization messages sent or received by this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsSessionRejectedNoHelloErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.2) |
read-only |
Counter32 |
Session Rejected (No Hello Error) notifications sent or received by the LDP entity. |
As per the MIB. |
mplsLdpEntityStatsSessionRejectedAdErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.3) |
read-only |
Counter32 |
Session Rejected (Parameters Advertisement Mode Error) notifications sent or received by the LDP entity. |
As per the MIB. |
mplsLdpEntityStatsSessionRejectedMaxPduErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.4) |
read-only |
Counter32 |
Session Rejected (Parameters Max Pdu Length Error) notifications sent or received by the LDP entity. |
As per the MIB. |
mplsLdpEntityStatsSessionRejectedLRErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.5) |
read-only |
Counter32 |
Session Rejected (Parameters Label Range) notifications sent or received by the LDP entity. |
As per the MIB. |
mplsLdpEntityStatsBadLdpIdentifierErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.6) |
read-only |
Counter32 |
Number of Bad LDP Identifier Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsBadPduLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.7) |
read-only |
Counter32 |
Number of Bad PDU Length Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsBadMessageLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.8) |
read-only |
Counter32 |
Number of Bad Message Length Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsBadTlvLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.9) |
read-only |
Counter32 |
Number of Bad TLV Length Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsMalformedTlvValueErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.10) |
read-only |
Counter32 |
Number of Malformed TLV Value Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsKeepAliveTimerExpErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.11) |
read-only |
Counter32 |
Number of Session Keep Alive Timer Expired Fatal Errors detected by the sessions associated with this LDP entity. |
As per the MIB. |
mplsLdpEntityStatsShutdownReceivedNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.12) |
read-only |
Counter32 |
Number of shutdown notifications received by sessions associated with the LDP entity. |
As per the MIB. |
mplsLdpEntityStatsShutdownSentNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.13) |
read-only |
Counter32 |
Number of shutdown notifications sent by sessions associated with the LDP entity. |
As per the MIB. |
mplsLdpPeerTable
About this table
This table contains LDP peer information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is mplsLdpPeerLdpId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpPeerLdpId (1.3.6.1.2.1.10.166.4.1.3.2.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (0..65535) |
LDP ID of the LDP peer. |
As per the MIB. |
mplsLdpPeerLabelDistMethod (1.3.6.1.2.1.10.166.4.1.3.2.1.2) |
read-only |
INTEGER |
downstreamOnDemand(1), |
Label distribution method of the LDP peer. |
As per the MIB. |
mplsLdpPeerPathVectorLimit (1.3.6.1.2.1.10.166.4.1.3.2.1.3) |
read-only |
Integer32 |
Path vector limit information about the LDP peer. |
As per the MIB. |
mplsLdpPeerTransportAddrType (1.3.6.1.2.1.10.166.4.1.3.2.1.4) |
read-only |
INTEGER |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
LDP peer address type. |
As per the MIB. |
mplsLdpPeerTransportAddr (1.3.6.1.2.1.10.166.4.1.3.2.1.5) |
read-only |
OCTET STRING |
OCTET STRING ( 0..255) |
LDP peer address. |
As per the MIB. |
mplsLdpSessionTable
About this table
This table contains LDP session information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpSessionStateLastChange (1.3.6.1.2.1.10.166.4.1.3.3.1.1) |
read-only |
TimeTicks |
Time when the LDP session state changed. |
As per the MIB. |
mplsLdpSessionState (1.3.6.1.2.1.10.166.4.1.3.3.1.2) |
read-only |
INTEGER |
nonexistent(1), initialized(2), openrec(3), opensent(4), operational(5) |
LDP session state. |
As per the MIB. |
mplsLdpSessionRole (1.3.6.1.2.1.10.166.4.1.3.3.1.3) |
read-only |
INTEGER |
unknown(1), active(2), passive(3) |
LDP session role. |
As per the MIB. |
mplsLdpSessionProtocolVersion (1.3.6.1.2.1.10.166.4.1.3.3.1.4) |
read-only |
Unsigned32 |
LDP session protocol version. |
As per the MIB. |
mplsLdpSessionKeepAliveHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.3.1.5) |
read-only |
INTEGER |
INTEGER (0..2147483647) |
Remaining keepalive time. |
As per the MIB. |
mplsLdpSessionKeepAliveTime (1.3.6.1.2.1.10.166.4.1.3.3.1.6) |
read-only |
Unsigned32 |
Keepalive interval. |
As per the MIB. |
mplsLdpSessionMaxPduLength (1.3.6.1.2.1.10.166.4.1.3.3.1.7) |
read-only |
Unsigned32 |
Maximum PDU length. |
As per the MIB. |
mplsLdpSessionDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.3.3.1.8) |
read-only |
TimeTicks |
System time when a counter of the LDP session suffered a discontinuity. |
As per the MIB. |
mplsLdpSessionStatsTable
About this table
This table contains LDP session statistics information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpSessionStatsUnknownMesTypeErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.1) |
read-only |
Counter32 |
Number of unknown messages detected by the LSR during the session. |
As per the MIB. |
mplsLdpSessionStatsUnknownTlvErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.2) |
read-only |
Counter32 |
Number of unknown TLVs detected by the LSR during the session. |
As per the MIB. |
mplsLdpHelloAdjacencyTable
About this table
This table contains LDP hello adjacency information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is mplsLdpHelloAdjacencyIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpHelloAdjacencyIndex (1.3.6.1.2.1.10.166.4.1.3.5.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
LDP hello adjacency index. |
As per the MIB. |
mplsLdpHelloAdjacencyHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.5.1.1.2) |
read-only |
INTEGER |
Time remaining for the hello adjacency. |
As per the MIB. |
mplsLdpHelloAdjacencyHoldTime (1.3.6.1.2.1.10.166.4.1.3.5.1.1.3) |
read-only |
Unsigned32 |
Hold time for the hello adjacency. |
As per the MIB. Default: 0. The actual default value is 15 for the Link Hello mode and 45 for the Targeted Hello mode. |
mplsLdpHelloAdjacencyType (1.3.6.1.2.1.10.166.4.1.3.5.1.1.4) |
read-only |
INTEGER |
link(1), targeted(2) |
LDP hello adjacency type. |
As per the MIB. |
mplsFecTable
About this table
This table contains LDP FEC information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is mplsFecIndex.
Access |
Syntax |
Value range |
Implementation |
mplsFecIndex (1.3.6.1.2.1.10.166.4.1.3.8.3.1.1) |
not-accessible |
Unsigned32 |
LDP FEC index. |
As per the MIB. |
MplsFecType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.2) |
read-create |
INTEGER |
prefix(1), hostAddress(2) |
LDP FEC type. |
As per the MIB. |
mplsFecAddrPrefixLength (1.3.6.1.2.1.10.166.4.1.3.8.3.1.3) |
read-create |
Unsigned32 |
Unsigned32 (0..2040) |
This node will not be defined if the mplsFecType is hostAddress(2). The value for this node is 0 or the IP prefix range defined by mplsFecAddr if the mplsFecType is prefix(1). If the value for this node is 0, it means that the IP prefix matches all IP addresses. |
As per the MIB. |
mplsFecAddrType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.4) |
read-create |
INTEGER |
LDP FEC address type. |
As per the MIB. |
mplsFecAddr (1.3.6.1.2.1.10.166.4.1.3.8.3.1.5) |
read-create |
OCTET STRING |
LDP FEC address. |
As per the MIB. |
mplsFecStorageType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.6) |
read-create |
INTEGER |
LDP FEC storage type. |
As per the MIB. |
mplsFecRowStatus (1.3.6.1.2.1.10.166.4.1.3.8.3.1.7) |
read-create |
INTEGER |
Row status. |
As per the MIB. |
mplsLdpSessionPeerAddrTable
About this table
This table contains LDP session peer address information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is mplsLdpSessionPeerAddrIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsLdpSessionPeerAddrIndex (1.3.6.1.2.1.10.166.4.1.3.11.1.1) |
not-accessible |
Unsigned32 |
Peer address index. |
As per the MIB. |
mplsLdpSessionPeerNextHopAddrType (1.3.6.1.2.1.10.166.4.1.3.11.1.2) |
read-only |
INTEGER |
Next hop address type. |
As per the MIB. |
mplsLdpSessionPeerNextHopAddr (1.3.6.1.2.1.10.166.4.1.3.11.1.3) |
read-only |
OCTET STRING |
Next hop address. |
As per the MIB. |
Notifications
mplsLdpInitSessionThresholdExceeded
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.4.0.1 |
The number of session initialization messages exceeds the limit. |
Error |
Major |
1.3.6.1.2.1.10.166.4.1.2.3.1.11 (mplsLdpEntityInitSessionThreshold) |
ON |
A notification sent when the value of the mplsLdpEntityInitSessionThreshold object is not zero and the number of session initialization messages exceeds the value of the mplsLdpEntityInitSessionThreshold object.
Status control
ON
CLI: Use the snmp-agent trap enable ldp command.
OFF
CLI: Use the undo snmp-agent trap enable ldp command.
Objects
OID (object name) |
Index |
Type |
Value range |
During the session establishment with an LDP peer, if the number of session initialization messages sent by the LDP entity exceeds the maximum value defined by the mplsLdpInitSessionThresholdExceeded object, the LDP entity will send notifications. |
No |
Integer32 |
0..100 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve this issue:
1. Check LDP session initialization message parameters.
2. If the issue persists, contact H3C Support.
mplsLdpSessionUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.4.0.3 |
The session state changes to operational. |
Recovery |
ON |
A notification sent when the value of the mplsLdpSessionState object changes to operational(5).
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.166.4.1.3.3.1.2 (mplsLdpSessionState) |
No |
INTEGER |
nonexistent(1) initialized(2) openrec(3) opensent(4) operational(5)) |
1.3.6.1.2.1.10.166.4.1.3.3.1.8 (mplsLdpSessionDiscontinuityTime) |
Time when the LDP session is up. |
No |
Timeticks |
1.3.6.1.2.1.10.166.4.1.3.4.1.1 (mplsLdpSessionStatsUnknownMesTypeErrors) |
No |
Counter32 |
1.3.6.1.2.1.10.166.4.1.3.4.1.2 (mplsLdpSessionStatsUnknownTlvErrors) |
No |
Counter32 |
Recommended action
No action is required.
mplsLdpSessionDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.4.0.4 |
The session state is not operational. |
Error |
Major |
ON |
A notification sent when the value of the mplsLdpSessionState object is not operational.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Session state. |
No |
INTEGER |
No |
Timeticks |
No |
Counter32 |
No |
Counter32 |
Recommended action
