- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
07-HH3C-MPLSRSVP-MIB | 72.38 KB |
HH3C-MPLSRSVP-MIB
About this MIB
Use this MIB to notify RSVP traps.
MIB file name
hh3c-mplsrsvp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsRsvp(229)
Scalar objects
hh3cMplsRsvpNbrAddr
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsRsvpNbrAddr (1.3.6.1.4.1.25506.2.229.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..127) |
Address of an RSVP neighbor |
As per the MIB. |
hh3cMplsRsvpFrrMainInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsRsvpFrrMainInfo (1.3.6.1.4.1.25506.2.229.1.1.2) |
OCTET STRING |
Information of a protected tunnel |
As per the MIB. |
hh3cMplsRsvpFrrByPassInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsRsvpFrrByPassInfo (1.3.6.1.4.1.25506.2.229.1.1.3) |
OCTET STRING |
Information of a protection tunnel |
As per the MIB. |
Notifications
hh3cRsvpNeighborLost
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.229.0.1 |
The device was disconnected from an RSVP neighbor, and the hello state of the RSVP neighbor changed from up state to init or idle state. |
Error |
Major |
1.3.6.1.4.1.25506.2.229.0.2 (hh3cMplsRsvpNeighborLostRecovery) |
ON |
This notification is generated when an RSVP hello timer expires, the BFD session is down, or disable RSVP hello.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.229.1.1.1 (1hh3cMplsRsvpNbrAddr) |
RSVP neighbor address |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.2 |
The RSVP neighbor recovered, the device received a hello from the RSVP neighbor, and the hello state of the RSVP neighbor changed from init to up. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when an RSVP neighbor recovers and the device receives hello messages from the RSVP neighbor again.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsRsvpAuthFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.3 |
RSVP authentication failed. The device cannot receive RSVP packets from the RSVP neighbor. |
Error |
Major |
1.3.6.1.4.1.25506.2.229.0.4 (hh3cMplsRsvpAuthFailRecovery) |
ON |
This notification is generated when RSVP authentication fails.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.4 |
The device received correct RSVP authentication packets from the RSVP neighbor. The RSVP authentication failure recovers. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the device receives correct RSVP authentication packets from an authentication-failed RSVP neighbor.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsRsvpFrrProtAval
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.5 |
The main tunnel was bound to the bypass tunnel. The bypass tunnel then can protect the main tunnel. When the main tunnel fails, the bypass tunnel takes over to avoid traffic forwarding failure. |
Error |
Major |
1.3.6.1.4.1.25506.2.229.0.6 (hh3cMplsRsvpFrrProtNotAval) |
ON |
This notification is generated when a main tunnel is bound to a bypass tunnel.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.229.1.1.2 (hh3cMplsRsvpFrrMainInfo ) |
Information of the protected tunnel (main tunnel) |
Yes |
OCTET STRING |
As per the MIB. |
Information of the protection tunnel (bypass tunnel) |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.6 |
The main tunnel was unbound from the bypass tunnel. The bypass tunnel then cannot protect the main tunnel. When the main tunnel fails, traffic forwarding fails. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a main tunnel is unbound from its bypass tunnel.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsRsvpFrrSwitch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.7 |
The main tunnel fails and traffic is switched from the main tunnel to the bypass tunnel. |
Error |
Major |
1.3.6.1.4.1.25506.2.229.0.8 (hh3cMplsRsvpFrrResume) |
ON |
This notification is generated when the main tunnel fails and the bypass tunnel takes over to protect traffic forwarding.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.229.0.8 |
The main tunnel recovers, and traffic is switched back from the bypass tunnel to the main tunnel. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the main tunnel recovers, and traffic is switched back from the bypass tunnel to the main tunnel.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
