10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10010-MPLS
10-HH3C-VSI-MIB
10-HH3C-VSI-MIB 107.06 KB
HH3C-VSI-MIB
About this MIB
Use this MIB to configure VSI.
MIB file name
hh3c-vsi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVsi(105)
Tabular objects
hh3cVsiScalarGroup
About this table
This table describes the global configuration for VSI.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cVsiNextAvailableVsiIndex (1.3.6.1.4.1.25506.2.105.1.1.1)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Next available VSI entry index.
As per the MIB.
hh3cVsiL2vpnStatus (1.3.6.1.4.1.25506.2.105.1.1.2)
read-write
TruthValue
true(1)
false(2)
Global enabling status of L2VPN.
As per the MIB.
hh3cVsiTable
About this table
Use this table to configure VSI parameters.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cVsiIndex.
Object (OID)
Access
Value range
Implementation
hh3cVsiIndex (1.3.6.1.4.1.25506.2.105.1.2.1.1)
not-accessible
Unsigned32
Index of a VSI.
As per the MIB.
hh3cVsiName (1.3.6.1.4.1.25506.2.105.1.2.1.2)
read-create
OCTET STRING
OCTET STRING (1..31)
Name of a VSI.
Not editable after creation.
hh3cVsiMode (1.3.6.1.4.1.25506.2.105.1.2.1.3)
read-create
INTEGER
default(0),
martini(1),
minm(2)
martiniAndMinm(3),
kompella(4),
kompellaAndMinm(5),
minmpxp(6),
martiniAndMinmpxp(7),
kompellaAndMinmpxp(8),
vxlan(9)
Mode of the VSI.
Supports only default(0) and vxlan(9). The set operation on other variables will be ignored. The default value is default(0).
hh3cVsiId (1.3.6.1.4.1.25506.2.105.1.2.1.5)
read-create
Unsigned32
Default PW ID.
hh3cVsiTransMode (1.3.6.1.4.1.25506.2.105.1.2.1.6)
read-create
INTEGER
vlan(1),
ethernet(2)
Transmit mode of the VSI.
Supports only the read operation. The value is always vlan(1).
hh3cVsiAdminState (1.3.6.1.4.1.25506.2.105.1.2.1.8)
read-create
INTEGER
adminUp(1),
adminDown(2)
Administrative state of the VSI.
Default value: adminUp(1).
hh3cVsiRowStatus (1.3.6.1.4.1.25506.2.105.1.2.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
Active(1) is only used to change the value for hh3cVsiAdminState, hh3cVsiArpSuppression, hh3cVsiFlooding, and hh3cVsiStatistics.
hh3cVsiVxlanID (1.3.6.1.4.1.25506.2.105.1.2.1.11)
read-only
Unsigned32
VXLAN ID.
As per the MIB.
hh3cVsiLocalMacCount (1.3.6.1.4.1.25506.2.105.1.2.1.14)
read-only
Unsigned32
Number of local MAC addresses of the VSI.
This value is 0 if hh3cVsiVxlanID uses an invalid value.
This value cannot be 0 if hh3cVsiVxlanID uses a valid value.
hh3cVsiNvgreID (1.3.6.1.4.1.25506.2.105.1.2.1.17)
read-only
Unsigned32
NVGRE ID
As per the MIB.
hh3cVsiXconnectTable
About this table
Use this table to configure AC-VSI bindings.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cVsiXconnectIfIndex and hh3cVsiXconnectEvcSrvInstId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.105.1.3.1.1)
not-accessible
Unsigned32
Index of an interface.
As per the MIB.
(1.3.6.1.4.1.25506.2.105.1.3.1.2)
not-accessible
Unsigned32
Service instance ID.
As per the MIB.
hh3cVsiXconnectVsiName
(1.3.6.1.4.1.25506.2.105.1.3.1.3)
read-create
OCTET STRING
Name of the VSI.
hh3cVsiXconnectAccessMode
(1.3.6.1.4.1.25506.2.105.1.3.1.4)
read-create
INTEGER
vlan(1),
ethernet(2)
Access mode.
hh3cVsiXconnectHubSpoke
(1.3.6.1.4.1.25506.2.105.1.3.1.5)
read-create
INTEGER
none(1),
hub(2),
spoke(3)
The hub-spoke capability of the service instance.
hh3cVsiXconnectRowStatus
(1.3.6.1.4.1.25506.2.105.1.3.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cVsiPwBindTable
About this table
Use this table to configure PW-VSI bindings.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cVsiIndex and hh3cVsiPwIndex.
Object (OID)
Access
Value range
Implementation
hh3cVsiPwIndex (1.3.6.1.4.1.25506.2.105.1.4.1.1)
not-accessible
Unsigned32
Index of a PW.
As per the MIB.
hh3cVsiPwBindAttributes (1.3.6.1.4.1.25506.2.105.1.4.1.2)
read-create
BITS
noSplitHorizon (0),               hub (1)
PW attribute.
As per the MIB.
hh3cVsiPwBindRowStatus (1.3.6.1.4.1.25506.2.105.1.4.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cVsiFloodMacTable
About this table
This table contains MAC addresses enabled with selective flooding in a VSI.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cVsiIndex and hh3cVsiFloodMac.
Object (OID)
Access
Value range
Implementation
hh3cVsiFloodMac (1.3.6.1.4.1.25506.2.105.1.5.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address.
As per the MIB.
hh3cVsiFloodMacRowStatus (1.3.6.1.4.1.25506.2.105.1.5.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cVsiLocalMacTable
About this table
This table contains information about local MAC addresses of a VSI.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cVsiIndex and hh3cVsiLocalMacAddr.
Object (OID)
Access
Value range
Implementation
hh3cVsiLocalMacAddr (1.3.6.1.4.1.25506.2.105.1.6.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address.
As per the MIB.
hh3cVsiLocalMacIfIndex (1.3.6.1.4.1.25506.2.105.1.6.1.2)
read-only
InterfaceIndex
InterfaceIndex (1..2147483647)
Outgoing interface of the MAC addresses.
As per the MIB.
hh3cVsiLocalMacSrvID (1.3.6.1.4.1.25506.2.105.1.6.1.3)
read-only
Unsigned32
ID of the service instance on the outgoing interface.
As per the MIB.
hh3cVsiPerfTable
About this table
This table contains performance statistics for VSIs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cVsiPerfInOctets (1.3.6.1.4.1.25506.2.105.1.7.1.1)
read-only
Counter64
Counter64 (0..18446744073709551615)
Total number of octets received by the VSI.
As per the MIB.
hh3cVsiPerfInPackets (1.3.6.1.4.1.25506.2.105.1.7.1.2)
read-only
Counter64
Total number of packets received by the VSI.
As per the MIB.
hh3cVsiPerfInErrors (1.3.6.1.4.1.25506.2.105.1.7.1.3)
read-only
Counter64
Number of error packets received by the VSI.
As per the MIB.
hh3cVsiPerfInDiscards (1.3.6.1.4.1.25506.2.105.1.7.1.4)
read-only
Counter64
Number of incoming packets discarded by the VSI.
As per the MIB.
hh3cVsiPerfOutOctets (1.3.6.1.4.1.25506.2.105.1.7.1.5)
read-only
Counter64
Total number of octets sent by the VSI.
As per the MIB.
hh3cVsiPerfOutPackets (1.3.6.1.4.1.25506.2.105.1.7.1.6)
read-only
Counter64
Total number of packets sent by the VSI.
As per the MIB.
hh3cVsiPerfOutErrors (1.3.6.1.4.1.25506.2.105.1.7.1.7)
read-only
Counter64
Number of packets that failed to be sent because of a VSI error.
As per the MIB.
hh3cVsiPerfOutDiscards (1.3.6.1.4.1.25506.2.105.1.7.1.8)
read-only
Counter64
Number of outgoing packets discarded by the VSI because of transmission failure.
As per the MIB.
hh3cVsiPerfInRateOctets (1.3.6.1.4.1.25506.2.105.1.7.1.9)
read-only
Counter64
Number of bytes received per second by the VSI.
As per the MIB.
hh3cVsiPerfInRatePackets (1.3.6.1.4.1.25506.2.105.1.7.1.10)
read-only
Counter64
Number of packets received per second by the VSI.
As per the MIB.
hh3cVsiPerfOutRateOctets (1.3.6.1.4.1.25506.2.105.1.7.1.11)
read-only
Counter64
Number of bytes sent per second by the VSI.
As per the MIB.
hh3cVsiPerfOutRatePackets (1.3.6.1.4.1.25506.2.105.1.7.1.12)
read-only
Counter64
Number of packets sent per second by the VSI.
As per the MIB.
hh3cVsiNextAvailableVsiIfID
About this table
This table contains information about next available VSI interface numbers.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cVsiNextAvailableVsiIfID (1.3.6.1.4.1.25506.2.105.1.8)
read-only
Unsigned32
VSI interface number.
Not supported.
hh3cVsiIfTable
About this table
Use this table to configure VSI interface parameters.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cVsiIfID.
Object (OID)
Access
Value range
Implementation
hh3cVsiIfID (1.3.6.1.4.1.25506.2.105.1.9.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cVsiIfIndex (1.3.6.1.4.1.25506.2.105.1.9.1.2)
read-only
InterfaceIndex
Integer32 (1..2147483647)
VSI interface index.
As per the MIB.
hh3cVsiIfRowStatus (1.3.6.1.4.1.25506.2.105.1.9.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Notifications
hh3cVsiChangeToUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.105.0.1
A VSI came up.
Recovery
Warning
OFF
This notification is generated if a VSI comes up.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn [ vsi-state-change ] command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [ vsi-state-change ] command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.105.1.2.1.2 (hh3cVsiName)
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cVsiChangeToDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.2
A VSI went down.
Failure
Warning
OFF
This notification is generated if a VSI goes down.
Status control
ON
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [vsi-state-change ] command.
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiMacLimitMax
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.3
The number of MAC address entries exceeded the warning threshold for a VSI.
Failure
Warning
OFF
This notification is generated if the number of MAC address entries exceeds the warning threshold for a VSI.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn [ maclimit-vsi ] command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [ maclimit-vsi ] command.
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiMacLimitMaxClear
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.4
The number of MAC address entries dropped below the warning threshold for a VSI.
Recovery
Warning
OFF
This notification is generated if the number of MAC address entries drops below the warning threshold for a VSI.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiLabelResourceNotEnough
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.5
The label resources are insufficient.
Failure
Major
1.3.6.1.4.1.25506.2.105.0.6
(hh3cVsiLabelResourceRestore)
OFF
This notification is generated if label request fails due to lack of label resources.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn label-resource
OFF
CLI: Use the undo snmp-agent trap enable l2vpn label-resource
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
Label resources became sufficient.
Recovery
OFF
This notification is generated if label resources become sufficient.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn label-resource command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn label-resource command.
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiPwNumberMaxExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.7
The PW limit was reached.
Failure
Major
OFF
This notification is generated if the number of PWs reaches the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-limitnum command.
OFF
CLI: Use the undo snmp-agent trap enable pw-limitnum command.
Objects
OID (object name)
Index
Value range
VSI name.
No
OCTET STRING
As per the MIB.
Recommended action
