H3C S6820 Switch Series Configuration Examples-Release 630x-6W100
HomeSupportSwitchesS6820 SeriesConfigure & DeployConfiguration ExamplesH3C S6820 Switch Series Configuration Examples-Release 630x-6W100
Table of Contents
Related Documents
67-MPLS OAM Configuration Examples
67-MPLS OAM Configuration Examples 207.99 KB
H3C S6820 Switches
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides MPLS Operation, Administration, and Maintenance (OAM) configuration examples.
MPLS OAM provides the following fault management tools for LSPs, MPLS TE tunnels, and MPLS PWs:
·           MPLS data plane connectivity verification.
·           MPLS data plane and control plane consistency verification.
·           Failure detection and locating.
This document assumes that you have basic knowledge of MPLS OAM.
Example: Configuring BFD for an LSP
As shown in Figure 1, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish LSPs for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
To meet the requirements:
·           Establish LSPs by using LDP.
·           Configure OSPF FRR on the MPLS backbone so LDP can establish a primary LSP and a backup LSP.
·           Configure BFD for the primary LSP. When the primary LSP fails, BFD can quickly detect the failure and notify LDP of the failure, so LDP can immediately switch traffic to the backup LSP.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R6301.
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
Procedures
1.      Configure IP addresses for interfaces:
# On PE 1, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 1.
<PE1> system-view
[PE1] vlan 10
[PE1-vlan10] port hundredgige 1/0/3
[PE1-vlan10] quit
[PE1] interface vlan-interface 10
[PE1-Vlan-interface10] ip address 192.168.10.1 24
[PE1] vlan 12
[PE1-vlan12] port hundredgige 1/0/1
[PE1-vlan12] quit
[PE1-Vlan-interface12] ip address 12.12.12.1 24
[PE1-Vlan-interface12] quit
[PE1] vlan 14
[PE1-vlan14] port hundredgige 1/0/2
[PE1-vlan14] quit
[PE1] interface vlan-interface 14
[PE1-Vlan-interface14] ip address 14.14.14.1 24
[PE1-Vlan-interface14] quit
[PE1] interface loopback 0
[PE1-LoopBack0] quit
# Configure other devices in the same way that PE 1 is configured. (Details not shown.)
2.      Configure OSPF to ensure IP connectivity within the MPLS backbone, and enable OSPF FRR:
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[PE1-ospf-1] fast-reroute lfa
[PE1-ospf-1] quit
# Configure P 1.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] quit
[P1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 34.34.34..0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[PE2-ospf-1] fast-reroute lfa
[PE2-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 34.34.34.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] quit
[P2-ospf-1] quit
# On P 2, set the OSPF cost to 10 for VLAN-interface 14 and VLAN-interface 34. This setting ensures that the backup LSP has a larger OSPF cost than the primary LSP.
[P2] interface vlan-interface 14
[P2-Vlan-interface14] ospf cost 10
[P2-Vlan-interface14] quit
[P2] interface vlan-interface 34
[P2-Vlan-interface34] ospf cost 10
[P2-Vlan-interface34] quit
3.      Configure basic MPLS and MPLS LDP:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface14] mpls enable
[PE1-Vlan-interface14] mpls ldp enable
# Configure P 1.
[P1] mpls lsr-id 2.2.2.2
[P1] mpls ldp
[P1-ldp] quit
[P1] interface vlan-interface 12
[P1-Vlan-interface12] mpls enable
[P1-Vlan-interface12] mpls ldp enable
[P1-Vlan-interface12] quit
[P1] interface vlan-interface 23
[P1-Vlan-interface23] mpls enable
[P1-Vlan-interface23] mpls ldp enable
[P1-Vlan-interface23] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface vlan-interface 23
[PE2-Vlan-interface23] mpls enable
[PE2-Vlan-interface23] mpls ldp enable
[PE2-Vlan-interface23] quit
[PE2] interface vlan-interface 34
[PE2-Vlan-interface34] mpls enable
[PE2-Vlan-interface34] mpls ldp enable
[PE2-Vlan-interface34] quit
# Configure P 2.
[P2] mpls lsr-id 4.4.4.4
[P2] mpls ldp
[P2-ldp] quit
[P2-Vlan-interface14] mpls enable
[P2-Vlan-interface14] mpls ldp enable
[P2-Vlan-interface34] mpls enable
[P2-Vlan-interface34] mpls ldp enable
# Verify that LDP sessions in Operational state have been established on each device. The following shows the output on PE 1.
[PE1] display mpls ldp peer
Total number of peers: 2
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.2:0               Operational   Passive  Off  Off  55/55
4.4.4.4:0               Operational   Passive  Off  Off  6/6
4.      Configure LSP generation policies to establish LSPs to destinations 192.168.10.0/24, 192.168.20.0/24, 1.1.1.1/32, and 3.3.3.3/32:
# On PE 1, create IP prefix list PE1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE1] ip prefix-list PE1 index 10 permit 192.168.10.0 24
[PE1] ip prefix-list PE1 index 20 permit 192.168.20.0 24
[PE1] ip prefix-list PE1 index 30 permit 1.1.1.1 32
[PE1] ip prefix-list PE1 index 40 permit 3.3.3.3 32
[PE1] mpls ldp
[PE1-ldp] lsp-trigger prefix-list PE1
[PE1-ldp] quit
# On P 1, create IP prefix list P1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P1] ip prefix-list P1 index 10 permit 192.168.10.0 24
[P1] ip prefix-list P1 index 20 permit 192.168.20.0 24
[P1] ip prefix-list P1 index 30 permit 1.1.1.1 32
[P1] ip prefix-list P1 index 40 permit 3.3.3.3 32
[P1] mpls ldp
[P1-ldp] lsp-trigger prefix-list P1
[P1-ldp] quit
# On PE 2, create IP prefix list PE2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE2] ip prefix-list PE2 index 10 permit 192.168.10.0 24
[PE2] ip prefix-list PE2 index 20 permit 192.168.20.0 24
[PE2] ip prefix-list PE2 index 30 permit 1.1.1.1 32
[PE2] ip prefix-list PE2 index 40 permit 3.3.3.3 32
[PE2] mpls ldp
[PE2-ldp] lsp-trigger prefix-list PE2
[PE2-ldp] quit
# On P 2, create IP prefix list P2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P2] ip prefix-list P2 index 10 permit 192.168.10.0 24
[P2] ip prefix-list P2 index 20 permit 192.168.20.0 24
[P2] ip prefix-list P2 index 30 permit 1.1.1.1 32
[P2] ip prefix-list P2 index 40 permit 3.3.3.3 32
[P2] mpls ldp
[P2-ldp] lsp-trigger prefix-list P2
[P2-ldp] quit
# Verify that LSPs to destination 192.168.20.0/24 have been established on PE 1. The primary LSP uses VLAN-interface 12 as the outgoing interface and the backup LSP uses VLAN-interface 14 as the outgoing interface.
[PE1]display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
Statistics:
  FECs: 4      Ingress LSPs: 4     Transit LSPs: 4     Egress LSPs: 2
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1279(L)
3.3.3.3/32         -/1150              12.12.12.2      Vlan12
                   1150/1150           12.12.12.2      Vlan12
                   -/1150(B)           12.12.12.2      Vlan14
                   1150/1150(B)        12.12.12.2      Vlan14
192.168.10.0/24    1141/-
                   -/1141(L)
                   -/1141(L)
192.168.20.0/24    -/1133              12.12.12.2      Vlan12
                   1133/1133           12.12.12.2      Vlan12
                   -/1133(B)           14.14.14.4      Vlan14
                   1133/1133(B)        14.14.14.4      Vlan14
5.      Enable BFD for MPLS and use BFD to verify LSP connectivity:
# Configure PE 1.
[PE1] mpls bfd enable
[PE1] mpls bfd 3.3.3.3 32
# Configure PE 2.
[PE2] mpls bfd enable
[PE2] mpls bfd 1.1.1.1 32
1.      Display BFD information for LSPs on PE 1 and PE 2. The following shows the output on PE 1.
[PE1] display mpls bfd
 Total number of sessions: 2, 2 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Destination: 1.1.1.1
   Mask Length: 32
 NHLFE ID: -
 Local Discr: 1026                   Remote Discr: 514
 Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
 Session State: Up                   Session Role: Active
 Template Name: -
 FEC Type: LSP
 FEC Info:
   Destination: 3.3.3.3
   Mask Length: 32
 NHLFE ID: 1028
 Local Discr: 1025                   Remote Discr: -
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
 Session State: Up                   Session Role: Passive
 Template Name: -
2.      Execute the tracert mpls ipv4 command on PE 1. The output shows that the primary LSP is in use.
Before you use the tracert feature, enable sending ICMP time exceeded messages on intermediate devices, and enable sending ICMP destination unreachable messages on the destination device.
[PE1] tracert mpls -a 192.168.10.1 ipv4 192.168.20.0 24
MPLS trace route FEC 192.168.20.0/24
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   12.12.12.2/[1148]
  1     12.12.12.2         2 ms    Transit   23.23.23.3/[1148]
  2     23.23.23.3         2 ms    Egress
3.      Verify that the ping operation from PE 1 to PE 2 will not fail after VLAN-interface 23 on P 1 is shut down during the ping operation:
# Ping PE 2 from PE 1.
[PE1] ping -c 100000 -a 192.168.10.1 192.168.20.1
Ping 192.168.20.1 (192.168.20.1) from 192.168.10.1: 56 data bytes, press CTRL_C
to break
56 bytes from 192.168.20.1: icmp_seq=0 ttl=254 time=2.576 ms
56 bytes from 192.168.20.1: icmp_seq=1 ttl=254 time=1.996 ms
# Shut down VLAN-interface 23 on P 1.
[P1-Vlan-interface23] shutdown
# View the ping command output. The output shows that the communication was interrupted, and then immediately resumed.
to break
56 bytes from 192.168.20.1: icmp_seq=7 ttl=254 time=2.214 ms
Request time out
56 bytes from 192.168.20.1: icmp_seq=9 ttl=254 time=2.659 ms
56 bytes from 192.168.20.1: icmp_seq=10 ttl=254 time=5.049 ms
56 bytes from 192.168.20.1: icmp_seq=11 ttl=254 time=2.098 ms
56 bytes from 192.168.20.1: icmp_seq=12 ttl=254 time=2.225 ms
56 bytes from 192.168.20.1: icmp_seq=13 ttl=254 time=2.187 ms
--- Ping statistics for 192.168.20.1 ---
14 packet(s) transmitted, 13 packet(s) received, 7.1% packet loss
round-trip min/avg/max/std-dev = 1.990/2.455/5.049/0.772 ms
4.      Execute the tracert mpls ipv4 command on PE 1. The output shows that the backup LSP is in use.
  0                                Ingress   14.14.14.4/[1276]
  1     14.14.14.4         2 ms    Transit   34.34.34.3/[1148]
  2     34.34.34.3         2 ms    Egress
Configuration files
·           PE 1:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
 ip address 192.168.10.1 255.255.255.0
interface Vlan-interface12
 ip address 12.12.12.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface14
 ip address 14.14.14.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface HundredGigE1/0/1
 port link-mode bridge
 port access vlan 12
interface HundredGigE1/0/2
 port access vlan 14
interface HundredGigE1/0/3
 port access vlan 10
 mpls bfd 3.3.3.3 32
·           PE 2:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
vlan 23
vlan 30
vlan 34
 mpls lsr-id 3.3.3.3
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
interface Vlan-interface23
 ip address 23.23.23.3 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface30
 ip address 192.168.20.1 255.255.255.0
interface Vlan-interface34
 ip address 34.34.34.3 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 mpls bfd 1.1.1.1 32
·           P 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 12.12.12.2 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 23.23.23.2 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 23
·           P 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 14.14.14.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
 ip address 34.34.34.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 14
Example: Configuring SBFD for an LSP
As shown in Figure 2, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish LSPs for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
·           Configure SBFD for the primary LSP. When the primary LSP fails, SBFD can quickly detect the failure and notify LDP of the failure, so LDP can immediately switch traffic to the backup LSP.
Figure 2 Network diagram
Procedures
# On PE 1, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 2.
<PE1> system-view
[PE1] vlan 10
[PE1-vlan10] quit
[PE1] vlan 12
[PE1-vlan12] quit
[PE1] vlan 14
[PE1-vlan14] quit
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure P 1.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1] quit
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure P 1.
[P1] mpls ldp
[P1-ldp] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
# Configure P 2.
[P2] mpls ldp
[P2-ldp] quit
[PE1] mpls ldp
[PE1-ldp] quit
[P1] mpls ldp
[P1-ldp] quit
[PE2] mpls ldp
[PE2-ldp] quit
[P2] mpls ldp
[P2-ldp] quit
Statistics:
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1279(L)
                   -/1141(L)
                   -/1141(L)
5.      Enable BFD for MPLS and use SBFD to verify LSP connectivity:
# Configure PE 1.
[PE1] sbfd local-discriminator 3000000
[PE1] mpls sbfd 3.3.3.3 32 remote 2000000
# Configure PE 2.
[PE2] sbfd local-discriminator 2000000
[PE2] mpls sbfd 1.1.1.1 32 remote 3000000
1.      Display SBFD information for LSPs on PE 1 and PE 2. The following shows the output on PE 1.
[PE1] display mpls sbfd
 Total number of sessions: 1, 1 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Mask Length: 32
 NHLFE ID: 2
 Local Discr: 513                    Remote Discr: 2000000
 Session State: Up
 Template Name: -
to break
to break
Request time out
Configuration files
·           PE 1:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls ldp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 14
 port access vlan 10
·           PE 2:
ospf 1
 fast-reroute lfa
 area 0.0.0.0
vlan 23
vlan 30
vlan 34
 mpls lsr-id 3.3.3.3
mpls ldp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 mpls bfd 1.1.1.1 32
·           P 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 12
 port access vlan 23
·           P 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls ldp
interface LoopBack0
 ospf cost 10
 mpls enable
 mpls ldp enable
 ospf cost 10
 mpls enable
 mpls ldp enable
 port access vlan 34
 port access vlan 14
Example: Configuring BFD for an MPLS TE tunnel
As shown in Figure 3, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish an MPLS TE tunnel for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
·           Use RSVP-TE to establish an MPLS TE tunnel between Switch A and Switch C.
·           Configure CRLSP backup for the MPLS TE tunnel to simultaneously establish a primary CRLSP (CR-LSP 1) and a backup CRLSP (CR-LSP 2).
·           Configure BFD for the MPLS TE tunnel. When the primary CRLSP fails, BFD can quickly detect the failure and notify RSVP of the failure, so RSVP can immediately switch traffic to the backup CRLSP.
Figure 3 Network diagram
When you configure BFD for an MPLS TE tunnel, follow these restrictions and guidelines:
·           Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
·           OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see Layer 3—IP Routing Configuration Guide.
·           MPLS TE cannot reserve resources and distribute labels for an OSPF virtual link. Make sure no virtual link exists in an OSPF area before you configure MPLS TE.
Procedures
# On Switch A, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 3.
[SwitchA] vlan 10
[SwitchA-vlan10] port hundredgige 1/0/3
[SwitchA-vlan10] quit
[SwitchA-Vlan-interface10] ip address 192.168.10.1 24
[SwitchA] vlan 12
[SwitchA-vlan12] port hundredgige 1/0/1
[SwitchA-vlan12] quit
[SwitchA] interface vlan-interface 12
[SwitchA-Vlan-interface12] ip address 12.12.12.1 24
[SwitchA-Vlan-interface12] quit
[SwitchA] vlan 14
[SwitchA-vlan14] port hundredgige 1/0/2
[SwitchA-vlan14] quit
[SwitchA] interface vlan-interface 14
[SwitchA-Vlan-interface14] ip address 14.14.14.1 24
[SwitchA-Vlan-interface14] quit
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] quit
# Configure other devices in the same way that Switch A is configured. (Details not shown.)
2.      Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
# Configure Switch A.
[SwitchA] mpls lsr-id 1.1.1.1
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA-Vlan-interface12] mpls enable
[SwitchA-Vlan-interface12] mpls te enable
[SwitchA-Vlan-interface12] rsvp enable
[SwitchA-Vlan-interface14] mpls enable
[SwitchA-Vlan-interface14] mpls te enable
[SwitchA-Vlan-interface14] rsvp enable
# Configure Switch B, Switch C, and Switch D in the same way that Switch A is configured. (Details not shown.)
3.      Configure OSPF to ensure IP connectivity within the MPLS backbone, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0:
[SwitchA] ospf
[SwitchA-ospf-1] opaque-capability enable
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] mpls te enable
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure Switch B.
[SwitchB] ospf
[SwitchB-ospf-1] opaque-capability enable
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] mpls te enable
[SwitchB-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] ospf
[SwitchC-ospf-1] opaque-capability enable
[SwitchC ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] mpls te enable
[SwitchC ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[SwitchC ospf-1-area-0.0.0.0] network 34.34.34..0 0.0.0.255
[SwitchC ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[SwitchC ospf-1-area-0.0.0.0] quit
[SwitchC ospf-1] quit
# Configure Switch D.
[SwitchD] ospf
[SwitchD-ospf-1] opaque-capability enable
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 34.34.34.0 0.0.0.255
[SwitchD-ospf-1] quit
4.      Configure an MPLS TE tunnel:
# On Switch A, configure MPLS TE tunnel interface Tunnel 3, and specify the tunnel destination address as the LSR ID of Switch C.
[SwitchA] interface tunnel 3 mode mpls-te
[SwitchA-Tunnel3] ip address 9.1.1.1 255.255.255.0
[SwitchA-Tunnel3] destination 3.3.3.3
# Configure MPLS TE to use RSVP-TE to establish the tunnel, and enable CRLSP hot backup for the tunnel.
[SwitchA-Tunnel3] mpls te signaling rsvp-te
[SwitchA-Tunnel3] mpls te backup hot-standby
[SwitchA-Tunnel3] quit
# Configure explicit paths for the MPLS TE tunnel.
[SwitchA] explicit-path cr-lsp1
[SwitchA-explicit-path-cr-lsp1] nexthop 12.12.12.2
[SwitchA-explicit-path-cr-lsp1] quit
[SwitchA] explicit-path cr-lsp2
[SwitchA-explicit-path-cr-lsp2] nexthop 14.14.14.4
[SwitchA-explicit-path-cr-lsp2]quit
# Set the preference to 1 for CR-LSP 1 and set the preference to 2 for CR-LSP 2.
[SwitchA-Tunnel3] mpls te path preference 1 explicit-path cr-lsp1
[SwitchA-Tunnel3] mpls te path preference 2 explicit-path cr-lsp2
# On Switch C, configure MPLS TE tunnel interface Tunnel 3, and specify the tunnel destination address as the LSR ID of Switch A.
[SwitchC] interface tunnel 3 mode mpls-te
[SwitchC-Tunnel3] ip address 9.3.3.3 255.255.255.0
[SwitchC-Tunnel3] destination 1.1.1.1
[SwitchC-Tunnel3] mpls te signaling rsvp-te
[SwitchC-Tunnel3] mpls te backup hot-standby
[SwitchC-Tunnel3] quit
[SwitchC] explicit-path cr-lsp1
[SwitchC-explicit-path-cr-lsp1] nexthop 23.23.23.2
[SwitchC-explicit-path-cr-lsp1] quit
[SwitchC] explicit-path cr-lsp2
[SwitchC-explicit-path-cr-lsp2] nexthop 34.34.34.4
[SwitchC-explicit-path-cr-lsp2]quit
[SwitchC-Tunnel3] mpls te path preference 1 explicit-path cr-lsp1
[SwitchC-Tunnel3] mpls te path preference 2 explicit-path cr-lsp2
5.      Configure static routing to direct traffic to the MPLS TE tunnel:
# Configure a static route on Switch A to direct the traffic destined for subnet 192.168.20.0/24 to MPLS TE Tunnel 3.
[SwitchA] ip route-static 192.168.20.0 24 tunnel 3 preference 1
# Configure a static route on Switch C to direct the traffic destined for subnet 192.168.10.0/24 to MPLS TE Tunnel 3.
[SwitchC] ip route-static 192.168.10.0 24 tunnel 3 preference 1
6.      Enable BFD for MPLS and use BFD to verify MPLS TE tunnel connectivity:
[SwitchA] mpls bfd enable
[SwitchA-Tunnel3] mpls bfd
[SwitchC] mpls bfd enable
[SwitchC-Tunnel3] mpls bfd
1.      Display MPLS TE tunnel information:
# Execute the display mpls te tunnel-interface command on Switch A. The output shows that the tunnel interface Tunnel 3 is up, the primary and backup CRLSPs have been established, and hot backup is used.
[SwitchA] display mpls te tunnel-interface
Tunnel Name            : Tunnel 3
Tunnel State           : Up (Main CRLSP up, Backup CRLSP up)
Tunnel Attributes      :
  LSP ID               : 37161           Tunnel ID            : 3
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 3.3.3.3
  Signaling            : RSVP-TE         Static CRLSP Name    : -
  Resv Style           : SE
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : CT0             Tunnel Bandwidth     : 0 kbps
  Reserved Bandwidth   : 0 kbps
  Setup Priority       : 7               Holding Priority     : 7
  Affinity Attr/Mask   : 0/0
  Explicit Path        : cr-lsp1
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Disabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : No              Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : Hot Standby     Backup LSP ID        : 37162
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -
# Execute the display rsvp lsp verbose command on Switch A. The output shows detailed information about the primary and backup CRLSPs. The primary CRLSP uses the output interface VLAN-interface 12 and the next hop 12.12.12.2. The backup CRLSP uses the output interface VLAN-interface 14 and the next hop 14.14.14.4.
[SwitchA] display rsvp lsp destination 3.3.3.3 verbose
Tunnel name: Tunnel3
Destination: 3.3.3.3                      Source: 1.1.1.1
Tunnel ID: 3                              LSP ID: 37161
LSR type: Ingress                         Direction: Unidirectional
Setup priority: 7                         Holding priority: 7
In-Label: -                               Out-Label: 1149
In-Interface: -                           Out-Interface: Vlan12
Nexthop: 12.12.12.2                       Exclude-any: 0
Include-Any: 0                            Include-all: 0
Mean rate (CIR): 0 kbps                   Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500                            Class type: CT0
RRO number: 6
  12.12.12.1/32      Flag: 0x00 (No FRR)
  12.12.12.2/32      Flag: 0x00 (No FRR)
  2.2.2.2/32         Flag: 0x20 (No FRR/Node-ID)
  23.23.23.2/32      Flag: 0x00 (No FRR)
  23.23.23.3/32      Flag: 0x00 (No FRR)
  3.3.3.3/32         Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel ID: 3                              LSP ID: 37162
In-Interface: -                           Out-Interface: Vlan14
Nexthop: 14.14.14.4                       Exclude-any: 0
RRO number: 6
  14.14.14.1/32      Flag: 0x00 (No FRR)
  14.14.14.4/32      Flag: 0x00 (No FRR)
  4.4.4.4/32         Flag: 0x20 (No FRR/Node-ID)
  34.34.34.4/32      Flag: 0x00 (No FRR)
  34.34.34.3/32      Flag: 0x00 (No FRR)
2.      Display BFD information for the MPLS TE tunnel on Switch A. The output shows that BFD sessions have been established for the primary and backup CRLSPs and the state of the session is up.
[SwitchA] display mpls bfd te tunnel 3
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 37161
 NHLFE ID: 1029
 Local Discr: 34                     Remote Discr: 33
 Template Name: -
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 37162
 NHLFE ID: 1031
 Local Discr: 33                     Remote Discr: 36
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.4
 Template Name: -
3.      Shut down VLAN-interface 23 on Switch B, and display MPLS TE tunnel information and BFD information:
# Shut down VLAN-interface 23 on Switch B.
[SwitchB] interface vlan-interface 23
[SwitchB-Vlan-interface23] shutdown
# Execute the display mpls te tunnel-interface command on Switch A. The output shows that the primary CRLSP is down and the backup CRLSP is up.
Tunnel State           : Up (Main CRLSP down, Backup CRLSP up)
Tunnel Attributes      :
  LSP ID               : 0               Tunnel ID            : 3
  Ingress LSR ID       : -               Egress LSR ID        : 3.3.3.3
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
# Display BFD information for CR-LSP 2 on Switch A.
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 37162
 NHLFE ID: 1031
 Template Name: -
4.      Bring up VLAN-interface 23 on Switch B and display MPLS TE tunnel information:
# Bring up VLAN-interface 23 on Switch B.
[SwitchB-Vlan-interface23] undo shutdown
# Execute the display mpls te tunnel-interface command on Switch A. The output shows that the primary CRLSP becomes available again.
Tunnel Attributes      :
  LSP ID               : 37177           Tunnel ID            : 3
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
  Backup Type          : Hot Standby     Backup LSP ID        : 37178
Configuration files
·           Switch A:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls te
 nexthop index 1 12.12.12.2 include strict
 nexthop index 1 14.14.14.4 include strict
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 12
 port access vlan 14
 port access vlan 10
interface Tunnel3 mode mpls-te
 mpls bfd
 destination 3.3.3.3
 ip route-static 192.168.20.0 24 Tunnel3 preference 1
·           Switch B:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 12
 port access vlan 23
·           Switch C:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 3.3.3.3
vlan 23
vlan 30
vlan 34
mpls te
 nexthop index 1 23.23.23.2 include strict
 nexthop index 1 34.34.34.4 include strict
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 mpls bfd
 destination 1.1.1.1
 ip route-static 192.168.10.0 24 Tunnel3 preference 1
·           Switch D:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 34
 port access vlan 14
Example: Configuring SBFD for an MPLS TE tunnel
As shown in Figure 4, a company has two branches that are connected to the MPLS backbone. It requires the MPLS backbone to establish an MPLS TE tunnel for communication between the branches, and to provide high availability services for uninterrupted business between the branches.
·           Configure SBFD for the MPLS TE tunnel. When the primary CRLSP fails, SBFD can quickly detect the failure and notify RSVP of the failure, so RSVP can immediately switch traffic to the backup CRLSP.
Figure 4 Network diagram
When you configure SBFD for an MPLS TE tunnel, follow these restrictions and guidelines:
·           OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see OSPF configuration in Layer 3—IP Routing Configuration Guide.
Procedures
# On Switch A, configure IP addresses and masks for interfaces, including the loopback interface, as shown in Figure 4.
[SwitchA] vlan 10
[SwitchA] vlan 12
[SwitchA] vlan 14
[SwitchA] mpls te
[SwitchA-te] quit
[SwitchA] rsvp
[SwitchA-rsvp] quit
[SwitchA] ospf
[SwitchB] ospf
[SwitchC] ospf
[SwitchD] ospf
6.      Enable BFD for MPLS and use SBFD to verify MPLS TE tunnel connectivity:
[SwitchA] sbfd local-discriminator 3000000
[SwitchA-Tunnel3] mpls sbfd remote 2000000
[SwitchC] sbfd local-discriminator 2000000
[SwitchC-Tunnel3] mpls sbfd remote 3000000
Tunnel Attributes      :
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
RRO number: 6
RRO number: 6
2.      Display SBFD information for the MPLS TE tunnel on Switch A. The output shows that SBFD sessions have been established for the primary and backup CRLSPs and the state of the session is up.
[SwitchA] display mpls sbfd te tunnel 3
 FEC Type: TE Tunnel
 FEC Info:
   Source     : 1.1.1.1
   Tunnel ID  : 3
   LSP ID     : 24346
 NHLFE ID: 6
 Session State: Up
 Template Name: -
 FEC Type: TE Tunnel
 FEC Info:
   Source     : 1.1.1.1
   Tunnel ID  : 3
   LSP ID     : 24347
 NHLFE ID: 8
 Local Discr: 514                    Remote Discr: 2000000
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.2
 Session State: Up
 Template Name: -
Tunnel Attributes      :
  Resv Style           : SE
  Tunnel mode          : -
  Explicit Path        : -
  Metric Type          : TE
# Display SBFD information for CR-LSP 2 on Switch A.
 FEC Type: TE Tunnel
 FEC Info:
   Source     : 1.1.1.1
   Tunnel ID  : 3
   LSP ID     : 24347
 NHLFE ID: 8
 Session State: Up
 Template Name: -
Tunnel Attributes      :
  Resv Style           : SE
  Tunnel mode          : -
  Metric Type          : TE
Configuration files
·           Switch A:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 1.1.1.1
vlan 10
vlan 12
vlan 14
mpls te
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 12
 port access vlan 14
 port access vlan 10
 destination 3.3.3.3
·           Switch B:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 2.2.2.2
vlan 12
vlan 23
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 12
 port access vlan 23
·           Switch C:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 3.3.3.3
vlan 23
vlan 30
vlan 34
mpls te
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 34
 port access vlan 23
 port access vlan 30
 destination 1.1.1.1
·           Switch D:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 4.4.4.4
vlan 14
vlan 34
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 port access vlan 34
 port access vlan 14
Related documentation
·           H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Configuration Guide
·           H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Command Reference
