- H3C S6820 Switch Series Configuration Examples-Release 630x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-FCoE Configuration Examples
- 54-OpenFlow Configuration Examples
- 55-MAC Address Table Configuration Examples
- 56-Static Multicast MAC Address Entry Configuration Examples
- 57-IP Unnumbered Configuration Examples
- 58-MVRP Configuration Examples
- 59-MCE Configuration Examples
- 60-Congestion Avoidance and Queue Scheduling Configuration Examples
- 61-Attack Protection Configuration Examples
- 62-Smart Link Configuration Examples
- 63-RRPP Configuration Examples
- 64-BGP Route Selection Configuration Examples
- 65-IS-IS Route Summarization Configuration Examples
- 66-IRF Configuration Examples
- 67-MPLS OAM Configuration Examples
- 68-MPLS TE Configuration Examples
- 69-NetStream Configuration Examples
- 70-VXLAN Configuration Examples
- 71-DRNI Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 74-S-MLAG Configuration Examples
- 75-MPLS SR Configuration Examples
- 76-Puppet Configuration Examples
| 36-Priority Mapping and Queue Scheduling Configuration Examples | 75.75 KB |
H3C S6820 Switches |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring priority mapping and queue scheduling
Priority configuration for the internal network traffic
Priority configuration for the Internet traffic
Configuring transmission priorities for the internal network traffic
Configuring transmission priorities for the traffic to the Internet
Introduction
This document provides examples for configuring priority mapping and queue scheduling profiles.
This document assumes that you have basic knowledge of priority mapping and queue scheduling profiles.
As shown in Figure 1, the Internet-accessing traffic includes the following types: HTTP, FTP, and Email, with the DSCP values 33, 35, and 27, respectively.
Configure priority mapping and queue scheduling to meet the following requirements:
· Access to the internal server farm—The traffic from the Administration department takes priority over the traffic from the R&D department. When congestion occurs, they are scheduled at a ratio of 2:1.
· Access to the Internet—The traffic from the Administration department takes priority over the traffic from the R&D department. When congestion occurs, the traffic from the Administration department is scheduled preferentially. The traffic from the R&D department is scheduled when no traffic from the Administration department exists. The three types of Internet-accessing traffic are transmitted in the following priority order: HTTP > FTP > Email. When congestion occurs, the three types of traffic are transmitted at a ratio of 2:1:1.
Analysis
To meet the network requirements, you must perform the following tasks:
· For packets from the two departments to be marked with different 802.1p priorities, configure different port priority values for the interfaces connected to the two departments.
· Because the 802.1p priorities are carried in VLAN tags, you must configure HundredGigE 1/0/1 on Switch C to send packets carrying VLAN tags. This example uses the port link type trunk.
· To make the marked 802.1p priority actually affect the packet transmission, configure trusting the 802.1p priorities of received packets on all input interfaces along the transmission path.
· To schedule packets from different queues at the specified ratio when congestion occurs, enable WRR queuing and configure different weights for queues.
· To completely prioritize the traffic from the Administration department when the interface is congested in the outbound direction, perform the following tasks:
¡ Configure SP queuing on the interface.
¡ Assign the traffic from the Administration department to a higher-priority queue.
· To determine the transmission priority based on the upper-layer protocols, configure trusting the DSCP values on the interface, so that the interface can enqueue packets based on the DSCP values.
· To assign packets with DSCP value 33 to a higher-priority queue, modify the DSCP-to-802.1p priority mapping table to map DSCP value 33 to a higher 802.1p priority value than the default. By default, DSCP values 33, 35, 27 are mapped to local precedence values 4, 4, and 3, respectively, based on the DSCP-to-802.1p priority mapping table and the 802.1p-to-local priority mapping table.
Software versions used
This configuration example was created and verified on R6301.
Procedures
1. Configure Switch C:
# Create VLANs 10 and 20.
[SwitchC] vlan 10
[SwitchC-vlan10] quit
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Assign interface HundredGigE 1/0/2 to VLAN 10, and set the port priority to 6 for the interface. This enables the traffic from the Administration department to be marked with 802.1p priority value 6.
[SwitchC] interface hundredgige 1/0/2
[SwitchC-HundredGigE1/0/2] port access vlan 10
[SwitchC-HundredGigE1/0/2] qos priority 6
[SwitchC-HundredGigE1/0/2] quit
# Assign interface HundredGigE 1/0/3 to VLAN 20, and set the port priority to 4 for the interface. This enables the traffic from the R&D department to be marked with 802.1p priority value 4.
[SwitchC] interface hundredgige 1/0/3
[SwitchC-HundredGigE1/0/3] port access vlan 20
[SwitchC-HundredGigE1/0/3] qos priority 4
[SwitchC-HundredGigE1/0/3] quit
# Configure interface HundredGigE 1/0/1 as a trunk port, assign the interface to VLAN 10 and VLAN 20, and remove the interface from VLAN 1.
[SwitchC] interface hundredgige 1/0/1
[SwitchC-HundredGigE1/0/1] port link-type trunk
[SwitchC-HundredGigE1/0/1] port trunk permit vlan 10 20
[SwitchC-HundredGigE1/0/1] undo port trunk permit vlan 1
[SwitchC-HundredGigE1/0/1] quit
2. Configure Switch B:
# Create VLANs 10, 20, 30, and 40.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] quit
[SwitchB] vlan 30
[SwitchB-vlan30] quit
[SwitchB] vlan 40
[SwitchB-vlan40] quit
# Configure interface HundredGigE 1/0/1 as a trunk port.
[SwitchB] interface hundredgige 1/0/1
[SwitchB-HundredGigE1/0/1] port link-type trunk
# Assign interface HundredGigE 1/0/1 to VLANs 10 and 20.
[SwitchB-HundredGigE1/0/1] port trunk permit vlan 10 20
# Remove interface HundredGigE 1/0/1 from VLAN 1.
[SwitchB-HundredGigE1/0/1] undo port trunk permit vlan 1
# Configure HundredGigE 1/0/1 to trust the 802.1p priority of received packets. Based on the 802.1p-to-local priority mapping table, traffic with 802.1p priority 4 is assigned to queue 4, and traffic with 802.1p priority 6 is assigned to queue 6.
[SwitchB-HundredGigE1/0/1] qos trust dot1p
[SwitchB-HundredGigE1/0/1] quit
# Assign interface HundredGigE 1/0/20 to VLAN 30.
[SwitchB] interface hundredgige 1/0/20
[SwitchB-HundredGigE1/0/20] port access vlan 30
# Create VLAN interfaces and configure routing protocols to enable communication between network segments. For more information about these configurations, see H3C S6800[60][61] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Routing Configuration Guide.
# Enable byte-count WRR on interface HundredGigE 1/0/20. By default, byte-count WRR is enabled.
[SwitchB-GigabitEthernet1/0/20] qos wrr byte-count
# Configure the weight of queue 6 as two times that of queue 4. In this example, set the weight value to 4 for queue 6 and 2 for queue 4.
[SwitchB-HundredGigE1/0/20] qos wrr 4 group 1 byte-count 2
[SwitchB-HundredGigE1/0/20] qos wrr 6 group 1 byte-count 4
[SwitchB-HundredGigE1/0/20] quit
# Assign interface HundredGigE 1/0/10 to VLAN 40.
[SwitchB] interface hundredgige 1/0/10
[SwitchB-HundredGigE1/0/10] port access vlan 40
[SwitchB-HundredGigE1/0/10] quit
1. Configure Switch B:
# Enable SP queuing on interface HundredGigE 1/0/10.
[SwitchB-HundredGigE1/0/10] qos sp
2. Configure Switch A:
# Configure interface HundredGigE 1/0/1 to trust the DSCP values of received packets.
[SwitchA] interface hundredgige 1/0/1
[SwitchA-HundredGigE1/0/1] qos trust dscp
# Modify the DSCP-to-802.1p priority mapping table to map DSCP value 33 to 802.1p priority 5 (queue 5).
[SwitchA] qos map-table dscp-dot1p
[SwitchA-maptbl-dscp-dot1p] import 33 export 5
[SwitchA-maptbl-dscp-dot1p] quit
The configuration assigns the three types of packets (HTTP, FTP, and Email) to queues 5, 4, and 3, respectively.
# Enable byte-count WRR on interface HundredGigE 1/0/2. By default, byte-count WRR is enabled.
[SwitchA] interface hundredgige 1/0/2
[SwitchA-HundredGigE1/0/2] qos wrr byte-count
# Set the weights of the three queues at a ratio of 2:1:1 (6, 3, and 3 in this example).
[SwitchA-HundredGigE1/0/2] qos wrr 5 group 1 byte-count 6
[SwitchA-HundredGigE1/0/2] qos wrr 4 group 1 byte-count 3
[SwitchA-HundredGigE1/0/2] qos wrr 3 group 1 byte-count 3
Verify the configuration on any interface on any switch, for example, HundredGigE 1/0/2 on Switch A.
# Verify the WRR configuration.
[SwitchA] display qos queue wrr interface hundredgige 1/0/2
Interface: HundredGigE1/0/2
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Byte count
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 3
4 af4 1 3
5 ef 1 6
6 cs6 1 13
7 cs7 1 15
Configuration files
· Switch A:
import 33 export 5
interface HundredGigE1/0/1
port link-mode bridge
qos trust dscp
interface HundredGigE1/0/2
qos wrr af3 group 1 byte-count 3
qos wrr af4 group 1 byte-count 3
qos wrr ef group 1 byte-count 6
return
· Switch B:
vlan 10
vlan 20
vlan 30
vlan 40
qos trust dot1p
interface HundredGigE1/0/10
port access vlan 40
interface HundredGigE1/0/20
port access vlan 30
qos wrr af4 group 1 byte-count 2
qos wrr cs6 group 1 byte-count 4
return
· Switch C:
vlan 10
vlan 20
port access vlan 10
qos priority 6
interface HundredGigE1/0/3
port access vlan 20
qos priority 4
return
Related documentation
· H3C S6800[60][61] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Configuration Guide
· H3C S6800[60][61] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Command Reference
