H3C S6820 Switch Series Configuration Examples-Release 630x-6W100
HomeSupportSwitchesS6820 SeriesConfigure & DeployConfiguration ExamplesH3C S6820 Switch Series Configuration Examples-Release 630x-6W100
Table of Contents
Related Documents
75-MPLS SR Configuration Examples
75-MPLS SR Configuration Examples 82.67 KB
H3C S6820 Switches
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides MPLS SR configuration examples.
Segment Routing (SR) is a source routing technology. The source node selects a path for the packets, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by the segment identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SR can operate with MPLS. In an MPLS network, SR uses MPLS labels as SIDs to forward packets on an LSP.
This document assumes that you have basic knowledge of MPLS SR.
Example: Configuring MPLS SR over LDP
As shown in Figure 1, configure the devices so the two SR networks can communicate across the LDP network.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Loop1
1.1.1.1/32
Device B
Loop1
2.2.2.2/32
Vlan-Int100
10.0.0.1/24
Vlan-Int100
10.0.0.2/24
Device C
Loop1
3.3.3.3/32
Vlan-Int200
11.0.0.1/24
Vlan-Int100
12.0.0.1/24
Device D
Loop1
4.4.4.4/32
Vlan-Int200
11.0.0.2/24
Vlan-Int100
12.0.0.2/24
Device E
Loop1
5.5.5.5/32
Vlan-Int200
13.0.0.1/24
Vlan-Int200
13.0.0.2/24
Analysis
To enable the two SR networks to communicate across the LDP network, you must perform the following tasks:
·           Configure Device A, Device B, Device C, Device D, and Device E to run IS-IS.
·           Configure Device B, Device C, and Device D to run LDP.
·           Configure Device A, Device B, Device D, and Device E to run MPLS SR.
Software versions used
This configuration example was created and verified on R6301.
Procedures
Configuring Device A
# Configure IP addresses and masks for interfaces. (Details not shown.)
#  Configure IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] quit
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] isis enable 1
[DeviceA-Vlan-interface100] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis enable 1
[DeviceA-LoopBack1] quit
# Set the LSR ID.
[DeviceA] mpls lsr-id 1.1.1.1
# Enable MPLS SR.
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] segment-routing mpls
[DeviceA-isis-1-ipv4] quit
# Configure the SRGB.
[DeviceA-isis-1] segment-routing global-block 16000 16999
# Configure IS-IS prefix SID.
[DeviceA-LoopBack1] isis prefix-sid index 10
Configuring Device B
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] isis enable 1
[DeviceB-Vlan-interface100] quit
[DeviceB] interface vlan-interface 200
[DeviceB-Vlan-interface200] isis enable 1
[DeviceB-Vlan-interface200] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB-LoopBack1] quit
# Set the LSR ID.
[DeviceB] mpls lsr-id 2.2.2.2
# Configure LDP.
[DeviceB] mpls ldp
[DeviceB-ldp] quit
[DeviceB-Vlan-interface200] mpls enable
[DeviceB-Vlan-interface200] mpls ldp enable
# Enable MPLS SR.
[DeviceB] isis 1
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] segment-routing global-block 17000 17999
[DeviceB-LoopBack1] isis prefix-sid index 20
Configuring Device C
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] quit
[DeviceC] interface vlan-interface 100
[DeviceC-Vlan-interface100] isis enable 1
[DeviceC-Vlan-interface100] quit
[DeviceC] interface vlan-interface 200
[DeviceC-Vlan-interface200] isis enable 1
[DeviceC-Vlan-interface200] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC-LoopBack1] quit
# Set the LSR ID.
[DeviceC] mpls lsr-id 3.3.3.3
# Configure LDP.
[DeviceC] mpls ldp
[DeviceC-ldp] quit
[DeviceC-Vlan-interface100] mpls enable
[DeviceC-Vlan-interface100] mpls ldp enable
[DeviceC-Vlan-interface200] mpls enable
[DeviceC-Vlan-interface200] mpls ldp enable
Configuring Device D
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] quit
[DeviceD] interface vlan-interface 100
[DeviceD-Vlan-interface100] isis enable 1
[DeviceD-Vlan-interface100] quit
[DeviceD] interface vlan-interface 200
[DeviceD-Vlan-interface200] isis enable 1
[DeviceD-Vlan-interface200] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] isis enable 1
[DeviceD-LoopBack1] quit
# Set the LSR ID.
[DeviceD] mpls lsr-id 4.4.4.4
# Configure LDP.
[DeviceD] mpls ldp
[DeviceD-ldp] quit
[DeviceD-Vlan-interface1001] mpls enable
[DeviceD-Vlan-interface100] mpls ldp enable
# Enable MPLS SR.
[DeviceD] isis 1
[DeviceD-isis-1] address-family ipv4
[DeviceD-isis-1-ipv4] segment-routing mpls
[DeviceD-isis-1-ipv4] quit
[DeviceD-isis-1] segment-routing global-block 18000 18999
[DeviceD-LoopBack1] isis prefix-sid index 40
Configuring Device E
<DeviceE> system-view
[DeviceE] isis 1
[DeviceE-isis-1] network-entity 00.0000.0000.0005.00
[DeviceE-isis-1] cost-style wide
[DeviceE-isis-1] quit
[DeviceE] interface vlan-interface 200
[DeviceE-Vlan-interface200] isis enable 1
[DeviceE-Vlan-interface200] quit
[DeviceE] interface loopback 1
[DeviceE-LoopBack1] isis enable 1
[DeviceE-LoopBack1] quit
# Set the LSR ID.
[DeviceE] mpls lsr-id 5.5.5.5
# Enable MPLS SR.
[DeviceE] isis 1
[DeviceE-isis-1] address-family ipv4
[DeviceE-isis-1-ipv4] segment-routing mpls
[DeviceE-isis-1-ipv4] quit
[DeviceE-isis-1] segment-routing global-block 19000 19999
[DeviceE-LoopBack1] isis prefix-sid index 50
# Display LDP LSP information on Device B.
[DeviceB] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 5           Ingress: 3           Transit: 3           Egress: 2
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.1/32         24116/-
                   -/24117(L)
2.2.2.2/32         3/-
                   -/24120(L)
3.3.3.3/32         -/3                 11.0.0.2        Vlan200
                   24121/3             11.0.0.2        Vlan200
4.4.4.4/32         -/24119             11.0.0.2        Vlan200
                   24118/24119         11.0.0.2        Vlan200
5.5.5.5/32         -/24118             11.0.0.2        Vlan200
                   24117/24118         11.0.0.2        Vlan200
# Display IS-IS SRLSP information on Device B.
[DeviceB] display mpls lsp protocol isis
FEC                         Proto       In/Out Label    Interface/Out NHLFE
1.1.1.1/32                  ISIS        17010/3         Vlan100
1.1.1.1/32                  ISIS        -/3             Vlan100
2.2.2.2/32                  ISIS        17020/-         -
4.4.4.4/32                  ISIS        17040/24119     Vlan200
4.4.4.4/32                  ISIS        -/24119         Vlan200
5.5.5.5/32                  ISIS        17050/24118     Vlan200
5.5.5.5/32                  ISIS        -/24118         Vlan200
The output shows that the IS-IS SRLSP entries for Device D and Device E are using LDP labels.
Configuration files
·           Device A:
isis 1
 cost-style wide
 address-family ipv4 unicast
 mpls lsr-id 1.1.1.1
vlan 1
vlan 100
interface LoopBack1
 ip address 1.1.1.1 255.255.255.255
 isis enable 1
interface Vlan-interface100
 ip address 10.0.0.1 255.255.255.0
 isis enable 1
interface HundredGigE1/0/1
 port link-mode bridge
 port access vlan 100
 combo enable fiber
·           Device B:
isis 1
 cost-style wide
 mpls lsr-id 2.2.2.2
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 2.2.2.2 255.255.255.255
 isis enable 1
 ip address 10.0.0.2 255.255.255.0
 isis enable 1
interface Vlan-interface200
 ip address 11.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 combo enable fiber
interface HundredGigE1/0/2
 port access vlan 200
 combo enable fiber
·           Device C:
isis 1
 cost-style wide
 mpls lsr-id 3.3.3.3
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 isis enable 1
 ip address 12.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 ip address 11.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 combo enable fiber
 combo enable fiber
·           Device D:
isis 1
 cost-style wide
 mpls lsr-id 4.4.4.4
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 4.4.4.4 255.255.255.255
 isis enable 1
 ip address 12.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 ip address 13.0.0.1 255.255.255.0
 isis enable 1
 combo enable fiber
 combo enable fiber
·           Device E:
isis 1
 cost-style wide
 mpls lsr-id 5.5.5.5
vlan 1
vlan 200
interface LoopBack1
 ip address 5.5.5.5 255.255.255.255
 isis enable 1
 ip address 13.0.0.2 255.255.255.0
 isis enable 1
 combo enable fiber
Related documentation
·           H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Configuration Guide
·           H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series MPLS Command Reference
