- H3C S6820 Switch Series Configuration Examples-Release 630x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-FCoE Configuration Examples
- 54-OpenFlow Configuration Examples
- 55-MAC Address Table Configuration Examples
- 56-Static Multicast MAC Address Entry Configuration Examples
- 57-IP Unnumbered Configuration Examples
- 58-MVRP Configuration Examples
- 59-MCE Configuration Examples
- 60-Congestion Avoidance and Queue Scheduling Configuration Examples
- 61-Attack Protection Configuration Examples
- 62-Smart Link Configuration Examples
- 63-RRPP Configuration Examples
- 64-BGP Route Selection Configuration Examples
- 65-IS-IS Route Summarization Configuration Examples
- 66-IRF Configuration Examples
- 67-MPLS OAM Configuration Examples
- 68-MPLS TE Configuration Examples
- 69-NetStream Configuration Examples
- 70-VXLAN Configuration Examples
- 71-DRNI Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 74-S-MLAG Configuration Examples
- 75-MPLS SR Configuration Examples
- 76-Puppet Configuration Examples
| 10-VLAN Tagging Configuration Examples | 580.53 KB |
H3C S6820 Switches |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Configuring devices between PE A and PE B
Example: Configuring one-to-two VLAN mapping
Example: Configuring QoS policies for SVLAN tagging and 802.1p priority marking
Example: Configuring one-to-one and many-to-one VLAN mapping
Example: Configuring two-to-two VLAN mapping
Example: Modifying the CVLAN ID through QoS marking
Introduction
This document provides examples for using VLAN tagging features to extend customer VLANs (CVLANs) across an Ethernet service provider network.
VLAN tagging features enable service providers to separate or aggregate customer traffic in the service provider network. The following are available VLAN tagging operations:
· Adding a layer of service provider VLAN (SVLAN) tag.
· Modifying the SVLAN tag, CVLAN tag, or both.
To add an SVLAN tag, use one of the following VLAN tagging features:
· QinQ—Tags all incoming frames (tagged or untagged) on the customer-side port with the PVID of the port.
· One-to-two VLAN mapping—Adds different SVLANs for traffic with different CVLAN tags.
· Policy-based VLAN manipulation—Uses QoS nest actions in a QoS policy to tag different classes of frames with different SVLAN tags. Traffic classifiers include CVLAN ID, IP address, and MAC address. In addition, you can use QoS priority marking to set the 802.1p priority in SVLAN tags.
To modify VLAN tags, use one of the following VLAN tagging features:
· VLAN mapping—Includes the following features:
¡ One-to-one VLAN mapping—Replaces one VLAN tag with another.
¡ Many-to-one VLAN mapping—Replaces multiple VLAN tags with the same VLAN tag.
¡ Two-to-two VLAN mapping—Replaces the SVLAN ID, CVLAN ID, or both IDs for an incoming double-tagged frame.
· Policy-based VLAN manipulation—Uses a QoS policy to modify the CVLAN or SVLAN ID by using the remark customer-vlan-id or remark service-vlan-id action.
The devices in the service provider network learn MAC addresses of CVLANs into the MAC address table of the SVLAN.
This document assumes that you have basic knowledge of QinQ, VLAN mapping, QoS nesting, and QoS priority and CVLAN marking.
Example: Configuring QinQ
As shown in Figure 1:
· The service provider assigns VLAN 1000 to Company A's VLANs 100 through 150.
· The service provider assigns VLAN 2000 to Company B's VLANs 120 through 200.
Configure QinQ on PE A and PE B to transmit traffic in VLANs 1000 and 2000 for Company A and Company B, respectively.
Software versions used
This configuration example was created and verified on R6301.
When you configure QinQ, follow these restrictions and guidelines:
· You only need to configure QinQ on customer-side ports of PEs.
· The link type of the customer-side port can be access, hybrid, or trunk.
¡ If the link type is access, you must assign the port to the SVLAN.
¡ If the link type is trunk, you must assign the port to the SVLAN, and set the SVLAN ID as the PVID of the port.
¡ If the link type is hybrid, you must assign the port to the SVLAN as an untagged VLAN member, and set the SVLAN ID as the PVID of the port. The settings ensure that the port can forward traffic to the customer site with the SVLAN tag removed.
¡ Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
¡ Configure all the ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1. Create VLANs 1000 and 2000.
<PE_A> system-view
[PE_A] vlan 1000
[PE_A-vlan1000] quit
[PE_A] vlan 2000
[PE_A-vlan2000] quit
2. Configure HundredGigE 1/0/1:
# Configure the port as an access port, and assign the port to VLAN 1000.
[PE_A] interface hundredgige 1/0/1
[PE_A-HundredGigE1/0/1] port access vlan 1000
# Enable QinQ on the port.
[PE_A-HundredGigE1/0/1] qinq enable
[PE_A-HundredGigE1/0/1] quit
3. Configure HundredGigE 1/0/2:
# Configure the port as an access port, and assign the port to VLAN 2000.
[PE_A] interface hundredgige 1/0/2
[PE_A-HundredGigE1/0/2] port access vlan 2000
[PE_A-HundredGigE1/0/2] qinq enable
[PE_A-HundredGigE1/0/2] quit
4. Configure HundredGigE 1/0/3:
# Configure the port as a trunk port.
[PE_A] interface hundredgige 1/0/3
[PE_A-HundredGigE1/0/3] port link-type trunk
# Assign the port to VLANs 1000 and 2000.
[PE_A-HundredGigE1/0/3] port trunk permit vlan 1000 2000
# Remove the port from VLAN 1.
[PE_A-HundredGigE1/0/3] undo port trunk permit vlan 1
[PE_A-HundredGigE1/0/3] quit
Configuring PE B
<PE_B> system-view
[PE_B] vlan 1000
[PE_B-vlan1000] quit
[PE_B] vlan 2000
[PE_B-vlan2000] quit
[PE_B] interface hundredgige 1/0/1
[PE_B-HundredGigE1/0/1] port access vlan 2000
[PE_B-HundredGigE1/0/1] qinq enable
[PE_B-HundredGigE1/0/1] quit
[PE_B] interface hundredgige 1/0/2
[PE_B-HundredGigE1/0/2] port access vlan 1000
[PE_B-HundredGigE1/0/2] qinq enable
[PE_B-HundredGigE1/0/2] quit
[PE_B] interface hundredgige 1/0/3
[PE_B-HundredGigE1/0/3] port link-type trunk
[PE_B-HundredGigE1/0/3] port trunk permit vlan 1000 2000
[PE_B-HundredGigE1/0/3] undo port trunk permit vlan 1
[PE_B-HundredGigE1/0/3] quit
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag. (Details not shown.)
# Verify that each company's PCs can ping each other in the same CVLAN across the service provider network. (Details not shown.)
# Verify that the two companies' PCs cannot communicate at Layer 2 even if their CVLAN IDs are the same. The ARP tables on one company's PCs do not contain entries for MAC addresses of the other company's PCs. (Details not shown.)
Configuration files
· PE A:
vlan 1000
vlan 2000
interface HundredGigE1/0/1
port link-mode bridge
qinq enable
interface HundredGigE1/0/2
qinq enable
interface HundredGigE1/0/3
· PE B:
vlan 1000
vlan 2000
qinq enable
qinq enable
As shown in Figure 2:
· Customer A and Customer B each have two branches that require Layer 2 connectivity over the service provider network.
· Both customers have three types of traffic. For each customer, the service provider assigns one SVLAN by traffic type.
Configure one-to-two VLAN mapping on each customer-side port of PE A and PE B to meet the following requirements:
· The service provider adds an SVLAN tag to packets from customer networks based on the traffic type, as described in Table 1 and Figure 3.
· The SVLAN tag uses the same 802.1p priority as the CVLAN tag.
Table 1 VLAN mapping table
Traffic type |
CVLANs |
SVLAN |
Customer A |
Video |
31 to 40 |
1003 |
Voice |
21 to 30 |
1002 |
Data |
10 to 20 |
1001 |
Customer B |
Storage |
36 to 40 |
2003 |
Voice |
26 to 35 |
2002 |
Data |
15 to 25 |
2001 |
Figure 3 Required traffic pattern in the service provider network
Analysis
To support multiple SVLANs and send traffic to the customer networks with the SVLAN tag removed, perform the following tasks on the customer-side ports:
1. Configure the link type of the ports as hybrid.
2. Assign the ports to the SVLANs as untagged VLAN members.
For the SVLAN tag to use the same 802.1p priority as the CVLAN tag, configure the customer-side port to use the 802.1p priority in incoming packets for priority mapping.
When you configure ports on the forwarding path of double-tagged packets across the service provider network, follow these restrictions and guidelines:
· Set the MTU to a minimum of 1504 bytes for each port.
· Configure all ports to allow double-tagged packets to pass through without removing the SVLAN tag.
Procedures
Configuring PE A
1. Create CVLANs and SVLANs:
# Create CVLANs 10 to 40.
<PE_A> system-view
[PE_A] vlan 10 to 40
# Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A] vlan 1001 to 1003
[PE_A] vlan 2001 to 2003
2. Configure the customer-side port HundredGigE 1/0/1:
# Configure the port as a hybrid port.
[PE_A-HundredGigE1/0/1] port link-type hybrid
# Assign the port to CVLANs 10 through 40 as a tagged VLAN member.
[PE_A-HundredGigE1/0/1] port hybrid vlan 10 to 40 tagged
# Assign the port to SVLANs 1001 through 1003 as an untagged VLAN member.
[PE_A-HundredGigE1/0/1] port hybrid vlan 1001 to 1003 untagged
[PE_A-HundredGigE1/0/1] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 1001 to traffic from VLANs 10 through 20.
[PE_A-HundredGigE1/0/1] vlan mapping nest range 10 to 20 nested-vlan 1001
# Configure one-to-two VLAN mapping to add SVLAN tag 1002 to traffic from VLANs 21 through 30.
[PE_A-HundredGigE1/0/1] vlan mapping nest range 21 to 30 nested-vlan 1002
# Configure one-to-two VLAN mapping to add SVLAN tag 1003 to traffic from VLANs 31 through 40.
[PE_A-HundredGigE1/0/1] vlan mapping nest range 31 to 40 nested-vlan 1003
# Configure the port to use the 802.1p priority in incoming packets for priority mapping.
[PE_A-HundredGigE1/0/1] qos trust dot1p
3. Configure the customer-side port HundredGigE 1/0/2:
[PE_A-HundredGigE1/0/2] port link-type hybrid
# Assign the port to CVLANs 15 through 40 as a tagged VLAN member.
[PE_A-HundredGigE1/0/2] port hybrid vlan 15 to 40 tagged
# Assign the port to SVLANs 2001 through 2003 as an untagged VLAN member.
[PE_A-HundredGigE1/0/2] port hybrid vlan 2001 to 2003 untagged
[PE_A-HundredGigE1/0/2] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 2001 to traffic from VLANs 15 through 25.
[PE_A-HundredGigE1/0/2] vlan mapping nest range 15 to 25 nested-vlan 2001
# Configure one-to-two VLAN mapping to add SVLAN tag 2002 to traffic from VLANs 26 through 35.
[PE_A-HundredGigE1/0/2] vlan mapping nest range 26 to 35 nested-vlan 2002
# Configure one-to-two VLAN mapping to add SVLAN tag 2003 to traffic from VLANs 36 through 40.
[PE_A-HundredGigE1/0/2] vlan mapping nest range 36 to 40 nested-vlan 2003
[PE_A-HundredGigE1/0/2] qos trust dot1p
4. Configure the service provider-side port HundredGigE 1/0/3:
# Assign the port to SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A-HundredGigE1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
Configuring PE B
<PE_B> system-view
[PE_B] vlan 10 to 40
[PE_B] vlan 1001 to 1003
[PE_B] vlan 2001 to 2003
[PE_B-HundredGigE1/0/1] port link-type hybrid
[PE_B-HundredGigE1/0/1] port hybrid vlan 15 to 40 tagged
[PE_B-HundredGigE1/0/1] port hybrid vlan 2001 to 2003 untagged
[PE_B-HundredGigE1/0/1] undo port hybrid vlan 1
[PE_B-HundredGigE1/0/1] vlan mapping nest range 15 to 25 nested-vlan 2001
[PE_B-HundredGigE1/0/1] vlan mapping nest range 26 to 35 nested-vlan 2002
[PE_B-HundredGigE1/0/1] vlan mapping nest range 36 to 40 nested-vlan 2003
[PE_B-HundredGigE1/0/1] qos trust dot1p
[PE_B-HundredGigE1/0/2] port link-type hybrid
[PE_B-HundredGigE1/0/2] port hybrid vlan 10 to 40 tagged
[PE_B-HundredGigE1/0/2] port hybrid vlan 1001 to 1003 untagged
[PE_B-HundredGigE1/0/2] undo port hybrid vlan 1
[PE_B-HundredGigE1/0/2] vlan mapping nest range 10 to 20 nested-vlan 1001
[PE_B-HundredGigE1/0/2] vlan mapping nest range 21 to 30 nested-vlan 1002
[PE_B-HundredGigE1/0/2] vlan mapping nest range 31 to 40 nested-vlan 1003
[PE_B-HundredGigE1/0/2] qos trust dot1p
[PE_B-HundredGigE1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged packets. (Details not shown.)
# Configure all ports on the forwarding path to allow packets from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the SVLAN tag. (Details not shown.)
1. Verify VLAN mapping information:
# Verify VLAN mapping information on PE A.
[PE_A] display vlan mapping
Interface HundredGigE1/0/1:
Outer VLAN Inner VLAN Translated Outer VLAN Translated Inner VLAN
10-20 N/A 1001 10-20
21-30 N/A 1002 21-30
31-40 N/A 1003 31-40
Interface HundredGigE1/0/2:
15-25 N/A 2001 15-25
26-35 N/A 2002 26-35
36-40 N/A 2003 36-40
# Verify VLAN mapping information on PE B.
[PE_B] display vlan mapping
2. Verify that PCs of the same customer in a CVLAN can ping each other across the service provider network. (Details not shown.)
3. Verify that PCs of different customers in a CVLAN cannot communicate at Layer 2. The ARP tables on one customer's PCs do not contain entries for MAC addresses of the other customer's PCs. (Details not shown.)
Configuration files
· PE A:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
qos trust dot1p
qos trust dot1p
· PE B:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
qos trust dot1p
qos trust dot1p
As shown in Figure 4:
· Both customers have three types of traffic and require different transmission priorities for the three types of traffic.
Apply a QoS policy to each customer-side port on PE A and PE B to meet the following requirements:
· Separate the traffic by customer and traffic type.
· Assign different 802.1p priority values to the traffic flows.
Table 2 shows the VLAN and 802.1p priority assignment scheme. For each customer, the service provider assigns one SVLAN by traffic type. Figure 5 shows the expected traffic transmission pattern after the QoS policies are applied to customer-side ports.
Table 2 VLAN and traffic priority assignment
Traffic type |
CVLANs |
SVLAN |
Traffic priority |
Customer A: |
Video |
31 to 40 |
1003 |
High |
Voice |
21 to 30 |
1002 |
Medium |
Data |
10 to 20 |
1001 |
Low |
Customer B: |
Storage |
36 to 40 |
2003 |
High |
Voice |
26 to 35 |
2002 |
Medium |
Data |
15 to 25 |
2001 |
Low |
Figure 5 Expected traffic pattern in the service provider network
Analysis
For the customer-side ports to support multiple SVLANs and send traffic to the customer site with the SVLAN tag removed, you must perform the following tasks:
1. Configure the link type as hybrid on the customer-side ports.
To change the 802.1p priority for a class of traffic, use the remark dot1p action. By default, the 802.1p priority in the SVLAN tag added by a QinQ-enabled port depends on the priority trust mode on the port.
· If the 802.1p priority in frames is trusted, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
· If port priority is trusted, the port priority is used as the 802.1p priority in the SVLAN tag. For untagged incoming frames, the port encapsulates the port priority as the 802.1p priority in the SVLAN tag.
When you configure an SVLAN tagging QoS policy, follow these restrictions and guidelines:
· Use the nest action for SVLAN tagging. You can configure only one nest action in the traffic behavior for a traffic class.
· You must apply the QoS policy to the inbound direction of customer-side ports.
· For the nest action to take effect, you must enable QinQ on the customer-side ports.
· If an incoming frame does not match the QoS policy, the port adds the PVID tag to the frame as the SVLAN tag.
For QinQ frames to travel across the service provider network, follow these restrictions and guidelines:
· Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
· Configure all the ports on the forwarding path to allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1. Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
<PE_A> system-view
# Configure the port to trust the 802.1p priority of frames.
3. Configure the service provider-side port HundredGigE 1/0/3:
4. Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create the class customer_A_pc to match traffic from CVLANs 10 through 20 (data traffic) for Customer A.
[PE_A] traffic classifier customer_A_pc
[PE_A-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_A-classifier-customer_A_pc] quit
# Create the classes customer_A_voice and customer_A_video to match Customer A's voice traffic and video traffic, respectively.
[PE_A] traffic classifier customer_A_voice
[PE_A-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_A-classifier-customer_A_voice] quit
[PE_A] traffic classifier customer_A_video
[PE_A-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_A-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking actions for Customer A's three traffic types.
[PE_A] traffic behavior customer_A_pc
[PE_A-behavior-customer_A_pc] nest top-most vlan 1001
[PE_A-behavior-customer_A_pc] remark dot1p 3
[PE_A-behavior-customer_A_pc] quit
[PE_A] traffic behavior customer_A_voice
[PE_A-behavior-customer_A_voice] nest top-most vlan 1002
[PE_A-behavior-customer_A_voice] remark dot1p 5
[PE_A-behavior-customer_A_voice] quit
[PE_A] traffic behavior customer_A_video
[PE_A-behavior-customer_A_video] nest top-most vlan 1003
[PE_A-behavior-customer_A_video] remark dot1p 7
[PE_A-behavior-customer_A_video] quit
# Create the QoS policy customer_A for Customer A, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_A
[PE_A-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_A-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_A-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_A-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of HundredGigE 1/0/1.
[PE_A-HundredGigE1/0/1] qos apply policy customer_A inbound
# Create traffic classes for matching Customer B's three traffic types.
[PE_A] traffic classifier customer_B_pc
[PE_A-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_A-classifier-customer_B_pc] quit
[PE_A] traffic classifier customer_B_voice
[PE_A-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_A-classifier-customer_B_voice] quit
[PE_A] traffic classifier customer_B_storage
[PE_A-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_A-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's traffic types.
[PE_A] traffic behavior customer_B_pc
[PE_A-behavior-customer_B_pc] nest top-most vlan 2001
[PE_A-behavior-customer_B_pc] remark dot1p 3
[PE_A-behavior-customer_B_pc] quit
[PE_A] traffic behavior customer_B_voice
[PE_A-behavior-customer_B_voice] nest top-most vlan 2002
[PE_A-behavior-customer_B_voice] remark dot1p 5
[PE_A-behavior-customer_B_voice] quit
[PE_A] traffic behavior customer_B_storage
[PE_A-behavior-customer_B_storage] nest top-most vlan 2003
[PE_A-behavior-customer_B_storage] remark dot1p 7
[PE_A-behavior-customer_B_storage] quit
# Create the QoS policy customer_B for Customer B, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_B
[PE_A-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_A-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_A-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_A-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of HundredGigE 1/0/2.
[PE_A-HundredGigE1/0/2] qos apply policy customer_B inbound
Configuring PE B
<PE_B> system-view
5. Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create traffic classes for matching Customer A's traffic types.
[PE_B] traffic classifier customer_A_pc
[PE_B-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_B-classifier-customer_A_pc] quit
[PE_B] traffic classifier customer_A_voice
[PE_B-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_B-classifier-customer_A_voice] quit
[PE_B] traffic classifier customer_A_video
[PE_B-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_B-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer A's three traffic types.
[PE_B] traffic behavior customer_A_pc
[PE_B-behavior-customer_A_pc] nest top-most vlan 1001
[PE_B-behavior-customer_A_pc] remark dot1p 3
[PE_B-behavior-customer_A_pc] quit
[PE_B] traffic behavior customer_A_voice
[PE_B-behavior-customer_A_voice] nest top-most vlan 1002
[PE_B-behavior-customer_A_voice] remark dot1p 5
[PE_B-behavior-customer_A_voice] quit
[PE_B] traffic behavior customer_A_video
[PE_B-behavior-customer_A_video] nest top-most vlan 1003
[PE_B-behavior-customer_A_video] remark dot1p 7
[PE_B-behavior-customer_A_video] quit
[PE_B] qos policy customer_A
[PE_B-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_B-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_B-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_B-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of HundredGigE 1/0/2.
[PE_B-HundredGigE1/0/2] qos apply policy customer_A inbound
[PE_B] traffic classifier customer_B_pc
[PE_B-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_B-classifier-customer_B_pc] quit
[PE_B] traffic classifier customer_B_voice
[PE_B-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_B-classifier-customer_B_voice] quit
[PE_B] traffic classifier customer_B_storage
[PE_B-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_B-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's three traffic types.
[PE_B] traffic behavior customer_B_pc
[PE_B-behavior-customer_B_pc] nest top-most vlan 2001
[PE_B-behavior-customer_B_pc] remark dot1p 3
[PE_B-behavior-customer_B_pc] quit
[PE_B] traffic behavior customer_B_voice
[PE_B-behavior-customer_B_voice] nest top-most vlan 2002
[PE_B-behavior-customer_B_voice] remark dot1p 5
[PE_B-behavior-customer_B_voice] quit
[PE_B] traffic behavior customer_B_storage
[PE_B-behavior-customer_B_storage] nest top-most vlan 2003
[PE_B-behavior-customer_B_storage] remark dot1p 7
[PE_B-behavior-customer_B_storage] quit
[PE_B] qos policy customer_B
[PE_B-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_B-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_B-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_B-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of HundredGigE 1/0/1.
[PE_B-HundredGigE1/0/1] qos apply policy customer_B inbound
# Configure all ports on the path between PE A and PE B allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag. (Details not shown.)
# Verify the configuration on each port. This example uses HundredGigE 1/0/1 of PE A.
[PE_A-HundredGigE1/0/1] display this
qinq enable
qos trust dot1p
Return
# Verify the QoS configuration on each port. This example uses HundredGigE 1/0/1 of PE A.
[PE_A] display qos policy interface hundredgige 1/0/1
Interface: HundredGigE1/0/1
Direction: Inbound
Policy: customer_A
Classifier: customer_A_pc
Operator: AND
Rule(s) :
If-match customer-vlan-id 10 to 20
Behavior: customer_A_pc
Nesting:
Nest top-most vlan-id 1001
Marking:
Remark dot1p 3
Classifier: customer_A_voice
Operator: AND
Rule(s) :
If-match customer-vlan-id 21 to 30
Behavior: customer_A_voice
Nesting:
Nest top-most vlan-id 1002
Marking:
Remark dot1p 5
Classifier: customer_A_video
Operator: AND
Rule(s) :
If-match customer-vlan-id 31 to 40
Behavior: customer_A_video
Nesting:
Nest top-most vlan-id 1003
Marking:
Remark dot1p 7
Configuration files
· PE A:
vlan 1001 to 1003
vlan 2001 to 2003
traffic classifier customer_A_pc operator and
traffic classifier customer_A_voice operator and
traffic classifier customer_A_video operator and
traffic classifier customer_B_pc operator and
traffic classifier customer_B_voice operator and
traffic classifier customer_B_storage operator and
remark dot1p 3
remark dot1p 5
remark dot1p 7
remark dot1p 3
remark dot1p 5
remark dot1p 7
qinq enable
qos trust dot1p
qinq enable
qos trust dot1p
· PE B:
vlan 1001 to 1003
vlan 2001 to 2003
remark dot1p 3
remark dot1p 5
remark dot1p 7
remark dot1p 3
remark dot1p 5
remark dot1p 7
qinq enable
qos trust dot1p
qinq enable
qos trust dot1p
As shown in Figure 6:
· Each household subscribes to PC, VoD, and VoIP services, and obtains the IP address through DHCP.
· On the home gateways, PC, VoD, and VoIP service traffic is assigned to VLANs 1, 2, and 3, respectively.
To isolate traffic of the same service type from different households, configure one-to-one VLAN mapping on the wiring-closet switches. This feature assigns one VLAN to each type of traffic from each household.
To save VLAN resources, configure many-to-one VLAN mapping on the campus switch (Switch C). This feature transmits the same type of traffic from different households in one VLAN. Use VLANs 501, 502, and 503 for PC, VoD, and VoIP traffic, respectively.
Table 3 VLAN mapping scheme for each service
Service |
VLANs on home gateways |
VLANs on wiring-closet switches (Switch A and Switch B) |
VLANs on campus switch (Switch C) |
PC |
VLAN 1 |
VLANs 101, 102, 103, 104 |
VLAN 501 |
VoD |
VLAN 2 |
VLANs 201, 202, 203, 204 |
VLAN 502 |
VoIP |
VLAN 3 |
VLANs 301, 302, 303, 304 |
VLAN 503 |
Procedures
Configuring Switch A
# Create the original VLANs 2 and 3. (VLAN 1 is the system default VLAN and already exists.)
[SwitchA] vlan 2 to 3
# Create the translated VLANs 101 through 102, 201 through 202, and 301 through 302.
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
# Configure the customer-side port HundredGigE 1/0/1 as a trunk port.
[SwitchA] interface hundredgige 1/0/1
[SwitchA-HundredGigE1/0/1] port link-type trunk
# Assign HundredGigE 1/0/1 to the original VLANs and translated VLANs.
[SwitchA-HundredGigE1/0/1] port trunk permit vlan 1 2 3 101 201 301
# Configure one-to-one VLAN mapping on HundredGigE 1/0/1 to map VLANs 1, 2, and 3 to VLANs 101, 201, and 301, respectively.
[SwitchA-HundredGigE1/0/1] vlan mapping 1 translated-vlan 101
[SwitchA-HundredGigE1/0/1] vlan mapping 2 translated-vlan 201
[SwitchA-HundredGigE1/0/1] vlan mapping 3 translated-vlan 301
[SwitchA-HundredGigE1/0/1] quit
# Configure the customer-side port HundredGigE 1/0/2 as a trunk port.
[SwitchA] interface hundredgige 1/0/2
[SwitchA-HundredGigE1/0/2] port link-type trunk
# Assign HundredGigE 1/0/2 to the original VLANs and translated VLANs.
[SwitchA-HundredGigE1/0/2] port trunk permit vlan 1 2 3 102 202 302
# Configure one-to-one VLAN mapping on HundredGigE 1/0/2 to map VLANs 1, 2, and 3 to VLANs 102, 202, and 302, respectively.
[SwitchA-HundredGigE1/0/2] vlan mapping 1 translated-vlan 102
[SwitchA-HundredGigE1/0/2] vlan mapping 2 translated-vlan 202
[SwitchA-HundredGigE1/0/2] vlan mapping 3 translated-vlan 302
[SwitchA-HundredGigE1/0/2] quit
# Configure the network-side port HundredGigE 1/0/3 as a trunk port.
[SwitchA] interface hundredgige 1/0/3
[SwitchA-HundredGigE1/0/3] port link-type trunk
# Assign HundredGigE 1/0/3 to the translated VLANs.
[SwitchA-HundredGigE1/0/3] undo port trunk permit vlan 1
[SwitchA-HundredGigE1/0/3] port trunk permit vlan 101 201 301 102 202 302
[SwitchA-HundredGigE1/0/3] quit
Configuring Switch B
# Configure Switch B in the same way Switch A is configured. (Details not shown.)
Configuring Switch C
1. Configure basic settings required for many-to-one VLAN mapping:
# Enable DHCP snooping.
[SwitchC] dhcp snooping enable
# Create the original VLANs 101 through 104, 201 through 204, and 301 through 304, and enable ARP detection for these VLANs.
[SwitchC] vlan 101
[SwitchC-vlan101] arp detection enable
[SwitchC-vlan101] vlan 201
[SwitchC-vlan201] arp detection enable
[SwitchC-vlan201] vlan 301
[SwitchC-vlan301] arp detection enable
[SwitchC-vlan301] vlan 102
[SwitchC-vlan102] arp detection enable
[SwitchC-vlan102] vlan 202
[SwitchC-vlan202] arp detection enable
[SwitchC-vlan202] vlan 302
[SwitchC-vlan302] arp detection enable
[SwitchC-vlan302] vlan 103
[SwitchC-vlan103] arp detection enable
[SwitchC-vlan103] vlan 203
[SwitchC-vlan203] arp detection enable
[SwitchC-vlan203] vlan 303
[SwitchC-vlan303] arp detection enable
[SwitchC-vlan303] vlan 104
[SwitchC-vlan104] arp detection enable
[SwitchC-vlan104] vlan 204
[SwitchC-vlan204] arp detection enable
[SwitchC-vlan204] vlan 304
[SwitchC-vlan304] arp detection enable
# Create the translated VLANs 501 through 503, and enable ARP detection for these VLANs.
[SwitchC-vlan304] vlan 501
[SwitchC-vlan501] arp detection enable
[SwitchC-vlan501] vlan 502
[SwitchC-vlan502] arp detection enable
[SwitchC-vlan502] vlan 503
[SwitchC-vlan503] arp detection enable
[SwitchC-vlan503] quit
[SwitchC] interface hundredgige 1/0/1
[SwitchC-HundredGigE1/0/1] port link-type trunk
# Assign the port to the original VLANs and translated VLANs.
[SwitchC-HundredGigE1/0/1] undo port trunk permit vlan 1
[SwitchC-HundredGigE1/0/1] port trunk permit vlan 101 102 201 202 301 302 501 to 503
# Configure the user-side many-to-one VLAN mapping to map VLANs for PC, VoD, and VoIP traffic to VLANs 501, 502, and 503, respectively.
[SwitchC-HundredGigE1/0/1] vlan mapping uni range 101 to 102 translated-vlan 501
[SwitchC-HundredGigE1/0/1] vlan mapping uni range 201 to 202 translated-vlan 502
[SwitchC-HundredGigE1/0/1] vlan mapping uni range 301 to 302 translated-vlan 503
# Enable DHCP snooping entry recording.
[SwitchC-HundredGigE1/0/1] dhcp snooping binding record
[SwitchC-HundredGigE1/0/1] quit
[SwitchC] interface hundredgige 1/0/2
[SwitchC-HundredGigE1/0/2] port link-type trunk
[SwitchC-HundredGigE1/0/2] undo port trunk permit vlan 1
[SwitchC-HundredGigE1/0/2] port trunk permit vlan 103 104 203 204 303 304 501 to 503
[SwitchC-HundredGigE1/0/2] vlan mapping uni range 103 to 104 translated-vlan 501
[SwitchC-HundredGigE1/0/2] vlan mapping uni range 203 to 204 translated-vlan 502
[SwitchC-HundredGigE1/0/2] vlan mapping uni range 303 to 304 translated-vlan 503
[SwitchC-HundredGigE1/0/2] dhcp snooping binding record
[SwitchC-HundredGigE1/0/2] quit
4. Configure the network-side port HundredGigE 1/0/3:
# Enable the network-side VLAN mapping function on the port.
[SwitchC] interface hundredgige 1/0/3
[SwitchC-HundredGigE1/0/3] vlan mapping nni
[SwitchC-HundredGigE1/0/3] port link-type trunk
# Assign the port to the translated VLANs 501 through 503.
[SwitchC-HundredGigE1/0/3] undo port trunk permit vlan 1
[SwitchC-HundredGigE1/0/3] port trunk permit vlan 501 to 503
# Configure the port as a DHCP snooping trusted and ARP trusted port.
[SwitchC-HundredGigE1/0/3] dhcp snooping trust
[SwitchC-HundredGigE1/0/3] arp detection trust
[SwitchC-HundredGigE1/0/3] quit
Configuring Switch D
# Create the translated VLANs 501 through 503.
<SwitchD> system-view
[SwitchD] vlan 501 to 503
# Configure HundredGigE 1/0/1 as a trunk port.
[SwitchD] interface hundredgige 1/0/1
[SwitchD-HundredGigE1/0/1] port link-type trunk
# Assign HundredGigE 1/0/1 to the translated VLANs 501 through 503.
[SwitchD-HundredGigE1/0/1] port trunk permit vlan 501 to 503
[SwitchD-HundredGigE1/0/1] quit
# Verify VLAN mapping information on the wiring-closet switches, for example, Switch A.
[SwitchA] display vlan mapping
1 N/A 101 N/A
2 N/A 201 N/A
3 N/A 301 N/A
1 N/A 102 N/A
2 N/A 202 N/A
3 N/A 302 N/A
# Verify VLAN mapping information on Switch C.
[SwitchC] display vlan mapping
101-102 N/A 501 N/A
201-202 N/A 502 N/A
301-302 N/A 503 N/A
103-104 N/A 501 N/A
203-204 N/A 502 N/A
303-304 N/A 503 N/A
Configuration files
· Switch A:
vlan 1
vlan 2 to 3
vlan 101 to 102
vlan 201 to 202
vlan 301 to 302
port trunk permit vlan 1 to 3 101 201 301
port trunk permit vlan 1 to 3 102 202 302
port trunk permit vlan 1 101 to 102 201 to 202 301 to 302
· Switch B:
vlan 1
vlan 2 to 3
vlan 103 to 104
vlan 203 to 204
vlan 303 to 304
port trunk permit vlan 1 to 3 103 203 303
vlan mapping 1 translated-vlan 103
vlan mapping 2 translated-vlan 203
vlan mapping 3 translated-vlan 303
port trunk permit vlan 1 to 3 104 204 304
vlan mapping 1 translated-vlan 104
vlan mapping 2 translated-vlan 204
vlan mapping 3 translated-vlan 304
port trunk permit vlan 1 103 to 104 203 to 204 303 to 304
· Switch C:
vlan 101
vlan 102
vlan 103
vlan 104
vlan 201
vlan 202
vlan 203
vlan 204
vlan 301
vlan 302
vlan 303
vlan 304
vlan 501
vlan 502
vlan 503
port trunk permit vlan 101 to 102 201 to 202 301 to 302 501 to 503
port trunk permit vlan 103 to 104 203 to 204 303 to 304 501 to 503
vlan mapping nni
arp detection trust
dhcp snooping trust
· Switch D:
vlan 501 to 503
port trunk permit vlan 1 501 to 503
As shown in Figure 7:
· A company assigns its branch sites (Site 1 and Site 2) to VLAN 10, and the headquarters provides services in VLAN 30.
· Service provider A uses SVLAN 100 to transmit VLAN 10 traffic for the branch sites.
· Service provider B uses SVLAN 200 to transmit VLAN 30 traffic for the headquarters.
Configure two-to-two VLAN mapping to permit the two branch sites to access VLAN 30 of the headquarters without changing their VLAN assignment.
Configure two-to-two VLAN mapping on one of the edge devices between the two service provider networks. This example uses Switch C.
Procedures
# Create CVLAN 10 and SVLAN 100.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (HundredGigE 1/0/1) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchA-HundredGigE1/0/1] vlan mapping nest single 10 nested-vlan 100
# Configure HundredGigE 1/0/1 as a hybrid port.
[SwitchA-HundredGigE1/0/1] port link-type hybrid
# Assign HundredGigE 1/0/1 to VLAN 10 as a tagged member.
[SwitchA-HundredGigE1/0/1] port hybrid vlan 10 tagged
# Assign HundredGigE 1/0/1 to VLAN 100 as an untagged member.
[SwitchA-HundredGigE1/0/1] port hybrid vlan 100 untagged
# Remove HundredGigE 1/0/1 from VLAN 1.
[SwitchA-HundredGigE1/0/1] undo port hybrid vlan 1
# Configure the network-side port HundredGigE 1/0/2 as a trunk port.
# Assign HundredGigE 1/0/2 to VLAN 100.
[SwitchA-HundredGigE1/0/2] port trunk permit vlan 100
# Remove HundredGigE 1/0/2 from VLAN 1.
[SwitchA-HundredGigE1/0/2] undo port trunk permit vlan 1
[SwitchB] vlan 10
[SwitchB-vlan10] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (HundredGigE 1/0/3) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchB] interface hundredgige 1/0/3
[SwitchB-HundredGigE1/0/3] vlan mapping nest single 10 nested-vlan 100
# Configure HundredGigE 1/0/3 as a hybrid port.
[SwitchB-HundredGigE1/0/3] port link-type hybrid
# Assign HundredGigE 1/0/3 to VLAN 10 as a tagged member.
[SwitchB-HundredGigE1/0/3] port hybrid vlan 10 tagged
# Assign HundredGigE 1/0/3 to VLAN 100 as an untagged member.
[SwitchB-HundredGigE1/0/3] port hybrid vlan 100 untagged
# Remove HundredGigE 1/0/3 from VLAN 1.
[SwitchB-HundredGigE1/0/3] undo port hybrid vlan 1
[SwitchB-HundredGigE1/0/3] quit
[SwitchB] interface hundredgige 1/0/1
[SwitchB-HundredGigE1/0/1] port link-type trunk
# Assign HundredGigE 1/0/1 to VLAN 100.
[SwitchB-HundredGigE1/0/1] port trunk permit vlan 100
[SwitchB-HundredGigE1/0/1] undo port trunk permit vlan 1
[SwitchB-HundredGigE1/0/1] quit
# Configure HundredGigE 1/0/2 as a trunk port.
[SwitchB] interface hundredgige 1/0/2
[SwitchB-HundredGigE1/0/2] port link-type trunk
[SwitchB-HundredGigE1/0/2] port trunk permit vlan 100
[SwitchB-HundredGigE1/0/2] undo port trunk permit vlan 1
[SwitchB-HundredGigE1/0/2] quit
# Create SVLANs 100 and 200.
[SwitchC] vlan 100
[SwitchC-vlan100] quit
[SwitchC] vlan 200
[SwitchC-vlan200] quit
# Assign HundredGigE 1/0/1 to VLANs 100 to 200.
[SwitchC-HundredGigE1/0/1] port trunk permit vlan 100 200
# Configure a two-to-two VLAN mapping on HundredGigE 1/0/1 to map SVLAN 100 and CVLAN 10 to SVLAN 200 and CVLAN 30.
[SwitchC-HundredGigE1/0/1] vlan mapping tunnel 100 10 translated-vlan 200 30
# Assign HundredGigE 1/0/2 to VLAN 200.
[SwitchC-HundredGigE1/0/2] port trunk permit vlan 200
# Create CVLAN 30 and SVLAN 200.
[SwitchD] vlan 30
[SwitchD-vlan30] quit
[SwitchD] vlan 200
[SwitchD-vlan200] quit
# Configure the link type of HundredGigE 1/0/1 as trunk.
# Assign HundredGigE 1/0/1 to VLAN 200.
[SwitchD-HundredGigE1/0/1] port trunk permit vlan 200
[SwitchD-HundredGigE1/0/1] undo port trunk permit vlan 1
# Configure HundredGigE 1/0/2 as a hybrid port.
[SwitchD] interface hundredgige 1/0/2
[SwitchD-HundredGigE1/0/2] port link-type hybrid
# Assign HundredGigE 1/0/2 to VLAN 30 as a tagged member.
[SwitchD-HundredGigE1/0/2] port hybrid vlan 30 tagged
# Assign HundredGigE 1/0/2 to VLAN 200 as an untagged member.
[SwitchD-HundredGigE1/0/2] port hybrid vlan 200 untagged
[SwitchD-HundredGigE1/0/2] undo port hybrid vlan 1
[SwitchD-HundredGigE1/0/2] quit
# Configure a one-to-two VLAN mapping on the customer-side port (HundredGigE 1/0/2) to add SVLAN tag 200 to packets from VLAN 30.
[SwitchD-HundredGigE1/0/2] vlan mapping nest single 30 nested-vlan 200
100 10 200 30
Configuration files
· Switch A:
vlan 10
vlan 100
· Switch B:
vlan 10
vlan 100
vlan 100
vlan 200
· Switch D:
vlan 30
vlan 200
· Company A uses CVLANs 10 and 20 to transmit voice traffic and data traffic, respectively.
· Company B uses CVLANs 30 and 40 to transmit voice traffic and data traffic, respectively.
· The service provider uses SVLANs 100 and 200 to transmit these two companies' voice and data traffic, respectively.
To provide Layer 2 connectivity for the voice and data traffic between the two companies, configure QoS CVLAN marking on PE A and PE B.
Analysis
To meet the network requirements, you must perform the following tasks:
· To add different SVLAN tags to voice and data traffic, use the nest action for SVLAN tagging on the customer-side ports of PE A and PE B.
· To provide Layer 2 connectivity for the traffic from different CVLANs, configure QoS CVLAN marking on the service provider-side ports of PE A and PE B.
Procedures
Configuring PE A
1. Create the CVLANs and SVLANs.
<PE_A> system-view
[PE_A] vlan 10
[PE_A-vlan10] quit
[PE_A] vlan 20
[PE_A-vlan20] quit
[PE_A] vlan 100
[PE_A-vlan100] quit
[PE_A] vlan 200
[PE_A-vlan200] quit
[PE_A] vlan 30
[PE_A-vlan30] quit
[PE_A] vlan 40
[PE_A-vlan40] quit
2. Configure the customer-side port HundredGigE1/0/1:
# Configure the port as an untagged VLAN member of VLANs 100 and 200.
[PE_A-HundredGigE1/0/1] port hybrid vlan 100 200 untagged
# Create the class A10 to match frames with CVLAN 10.
[PE_A] traffic classifier A10
[PE_A-classifier-A10] if-match customer-vlan-id 10
[PE_A-classifier-A10] quit
# Configure the traffic behavior P100 to tag packets with SVLAN 100.
[PE_A] traffic behavior P100
[PE_A-behavior-P100] nest top-most vlan 100
[PE_A-behavior-P100] quit
# Create the class A20 to match frames with CVLAN 20.
[PE_A] traffic classifier A20
[PE_A-classifier-A20] if-match customer-vlan-id 20
[PE_A-classifier-A20] quit
# Configure the traffic behavior P200 to tag packets with SVLAN 200.
[PE_A] traffic behavior P200
[PE_A-behavior-P200] nest top-most vlan 200
[PE_A-behavior-P200] quit
# Create the QoS policy qinq to associate the traffic classes A10 and A20 with the traffic behaviors P100 and P200, respectively.
[PE_A] qos policy qinq
[PE_A-qospolicy-qinq] classifier A10 behavior P100
[PE_A-qospolicy-qinq] classifier A20 behavior P200
[PE_A-qospolicy-qinq] quit
# Enable QinQ in the port.
# Apply the QoS policy to the inbound direction of the port.
[PE_A-HundredGigE1/0/1] qos apply policy qinq inbound
3. Configure the service network-side port HundredGigE1/0/2:
[PE_A-HundredGigE1/0/2] port link-type trunk
# Assign the port to VLANs 100 and 200.
[PE_A-HundredGigE1/0/2] port trunk permit vlan 100 200
[PE_A-HundredGigE1/0/2] undo port trunk permit vlan 1
# Create the class A100 to match frames with CVLAN 10 and SVLAN 100.
[PE_A] traffic classifier A100
[PE_A-classifier-A100] if-match customer-vlan-id 10
[PE_A-classifier-A100] if-match service-vlan-id 100
[PE_A-classifier-A100] quit
# Configure the traffic behavior T100 to mark matching traffic with CVLAN 30.
[PE_A] traffic behavior T100
[PE_A-behavior-T100] remark customer-vlan-id 30
[PE_A-behavior-T100] quit
# Create the class A200 to match frames with CVLAN 20 and SVLAN 200.
[PE_A] traffic classifier A200
[PE_A-classifier-A200] if-match customer-vlan-id 20
[PE_A-classifier-A200] if-match service-vlan-id 200
[PE_A-classifier-A200] quit
# Configure the traffic behavior T200 to mark matching traffic with CVLAN 40.
[PE_A] traffic behavior T200
[PE_A-behavior-T200] remark customer-vlan-id 40
[PE_A-behavior-T200] quit
# Create the QoS policy vlanmapping to associate the traffic classes A100 and A200 with the traffic behaviors T100 and T200, respectively.
[PE_A] qos policy vlanmapping
[PE_A-qospolicy-vlanmapping] classifier A100 behavior T100
[PE_A-qospolicy-vlanmapping] classifier A200 behavior T200
[PE_A-qospolicy-vlanmapping] quit
# Apply the QoS policy to the outbound direction of the port.
[PE_A-HundredGigE1/0/2] qos apply policy vlanmapping outbound
Configuring PE B
<PE_B> system-view
[PE_B] vlan 30
[PE_B-vlan30] quit
[PE_B] vlan 40
[PE_B-vlan40] quit
[PE_B] vlan 100
[PE_B-vlan100] quit
[PE_B] vlan 200
[PE_B-vlan200] quit
[PE_B] vlan 10
[PE_B-vlan10] quit
[PE_B] vlan 20
[PE_B-vlan20] quit
# Assign the port to VLANs 100 and 200 as an untagged VLAN member.
[PE_B-HundredGigE1/0/1] port hybrid vlan 100 200 untagged
# Create the class A30 to match frames with CVLAN 30.
[PE_B] traffic classifier A30
[PE_B-classifier-A30] if-match customer-vlan-id 30
[PE_B-classifier-A30] quit
[PE_B] traffic behavior P100
[PE_B-behavior-P100] nest top-most vlan 100
[PE_B-behavior-P100] quit
# Create the class A40 to match frames with CVLAN 40.
[PE_B] traffic classifier A40
[PE_B-classifier-A40] if-match customer-vlan-id 40
[PE_B-classifier-A40] quit
[PE_B] traffic behavior P200
[PE_B-behavior-P200] nest top-most vlan 200
[PE_B-behavior-P200] quit
# Create the QoS policy qinq to associate the traffic classes A30 and A40 with the traffic behaviors P100 and P200, respectively.
[PE_B] qos policy qinq
[PE_B-qospolicy-qinq] classifier A30 behavior P100
[PE_B-qospolicy-qinq] classifier A40 behavior P200
[PE_B-qospolicy-qinq] quit
[PE_B-HundredGigE1/0/1] qos apply policy qinq inbound
3. Configure the service provider-side port HundredGigE 1/0/2:
[PE_B-HundredGigE1/0/2] port link-type trunk
[PE_B-HundredGigE1/0/2] port trunk permit vlan 100 200
[PE_B-HundredGigE1/0/2] undo port trunk permit vlan 1
# Create the class A100 to match frames with CVLAN 30 and SVLAN 100.
[PE_B] traffic classifier A100
[PE_B-classifier-A100] if-match customer-vlan-id 30
[PE_B-classifier-A100] if-match service-vlan-id 100
[PE_B-classifier-A100] quit
# Configure the traffic behavior T100 to mark matching traffic with CVLAN 10.
[PE_B] traffic behavior T100
[PE_B-behavior-T100] remark customer-vlan-id 10
[PE_B-behavior-T100] quit
# Create the class A200 to match frames with CVLAN 40 and SVLAN 200.
[PE_B] traffic classifier A200
[PE_B-classifier-A200] if-match customer-vlan-id 40
[PE_B-classifier-A200] if-match service-vlan-id 200
[PE_B-classifier-A200] quit
# Configure the traffic behavior T200 to mark matching traffic with CVLAN 20.
[PE_B] traffic behavior T200
[PE_B-behavior-T200] remark customer-vlan-id 20
[PE_B-behavior-T200] quit
[PE_B] qos policy vlanmapping
[PE_B-qospolicy-vlanmapping] classifier A100 behavior T100
[PE_B-qospolicy-vlanmapping] classifier A200 behavior T200
[PE_B-qospolicy-vlanmapping] quit
[PE_B-HundredGigE1/0/2] qos apply policy vlanmapping outbound
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged frames. (Details not shown.)
# Configure the ports between PE A and PE B to allow frames from VLANs 100 and 200 to pass through tagged. (Details not shown.)
# Verify configuration on the customer-side ports on PE A and PE B. This example uses HundredGigE 1/0/1 of PE A.
qinq enable
return
# Verify the QoS nesting configuration on the customer-side ports on PE A and PE B. This example uses HundredGigE 1/0/1 of PE A.
Direction: Inbound
Policy: qinq
Classifier: A10
Operator: AND
Rule(s) :
Behavior: P100
Nesting:
Classifier: A20
Operator: AND
Rule(s) :
If-match customer-vlan-id 20
Behavior: P200
Nesting:
Nest top-most vlan-id 200
# Verify the QoS marking configuration on the service provider-side ports on PE A and PE B. This example uses HundredGigE 1/0/2 of PE A.
[PE_A] display qos policy interface hundredgige 1/0/2
Interface: HundredGigE1/0/2
Direction: Outbound
Policy: vlanmapping
Classifier: A100
Operator: AND
Rule(s) :
If-match service-vlan-id 100
Behavior: T100
Marking:
Remark Customer VLAN ID 30
Classifier: A200
Operator: AND
Rule(s) :
If-match service-vlan-id 200
Behavior: T200
Marking:
Remark Customer VLAN ID 40
Configuration files
· PE A:
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
vlan 200
traffic classifier A10 operator and
traffic classifier A20 operator and
traffic classifier A100 operator and
traffic classifier A200 operator and
qos policy qinq
qinq enable
· PE B:
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
vlan 200
traffic classifier A30 operator and
traffic classifier A40 operator and
qos policy qinq
qinq enable
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 2—LAN Switching Command Reference
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series ACL and QoS Command Reference
