- H3C S6820 Switch Series Configuration Examples-Release 630x-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-FCoE Configuration Examples
- 54-OpenFlow Configuration Examples
- 55-MAC Address Table Configuration Examples
- 56-Static Multicast MAC Address Entry Configuration Examples
- 57-IP Unnumbered Configuration Examples
- 58-MVRP Configuration Examples
- 59-MCE Configuration Examples
- 60-Congestion Avoidance and Queue Scheduling Configuration Examples
- 61-Attack Protection Configuration Examples
- 62-Smart Link Configuration Examples
- 63-RRPP Configuration Examples
- 64-BGP Route Selection Configuration Examples
- 65-IS-IS Route Summarization Configuration Examples
- 66-IRF Configuration Examples
- 67-MPLS OAM Configuration Examples
- 68-MPLS TE Configuration Examples
- 69-NetStream Configuration Examples
- 70-VXLAN Configuration Examples
- 71-DRNI Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 73-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 74-S-MLAG Configuration Examples
- 75-MPLS SR Configuration Examples
- 76-Puppet Configuration Examples
| 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples | 103.95 KB |
H3C S6820 Switches |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring an ISATAP tunnel and a 6to4 tunnel.
This document assumes that you have basic knowledge of ISATAP tunneling and 6to4 tunneling.
Example: Configuring an ISATAP tunnel and a 6to4 tunnel
As shown in Figure 1, configure a 6to4 tunnel between Device A and Device B to allow communications between the headquarters and the branches over the IPv4 network.
Configure an ISATAP tunnel between Device A and the ISATAP host to allow the host in the IPv4 network to access the headquarters.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int10 |
2.1.1.1/24 |
Device B |
Vlan-int10 |
3.1.1.1/24 |
Vlan-int20 |
2002:0201:0101:1::1/64 |
Vlan-int20 |
2002:0301:0101:1::1/64 |
Vlan-int30 |
2002:0201:0101:2::1/64 |
Vlan-int30 |
2002:0301:0101:2::1/64 |
Tunnel 1 |
3001::1/64 |
Tunnel 1 |
3001::2/64 |
Tunnel 2 |
2001::5EFE:0201:0101/64 |
Software versions used
This configuration example was created and verified on R6301.
When you configure an ISATAP tunnel and a 6to4 tunnel, follow these restrictions and guidelines:
· You do not need to configure a destination address for a 6to4 tunnel, because the destination IPv4 address is embedded in the 6to4 IPv6 address whose format is 2002:IPv4-destination-address::/64.
· You do not need to configure a destination address for an ISATAP tunnel, because the destination IPv4 address is embedded in the ISATAP address whose format is Prefix:0:5EFE:IPv4-destination-address.
· Disable RA suppression on Device A and Device B to allow hosts to acquire address prefixes automatically. This configuration ensures that hosts in the same network use the same address prefix.
After RA suppression is disabled, the ISATAP host and hosts in the headquarters acquire address prefixes from RA messages advertised by Device A. Hosts in the branches acquire address prefixes from RA messages advertised by Device B.
· A tunneled packet cannot be directly routed based on its destination address. The packet is sent to a tunnel-type service loopback group, which then delivers the packet to the forwarding module for Layer 3 forwarding. Therefore, you must configure a tunnel-type service loopback group. Otherwise, the tunnel interface will fail to forward and receive packets.
Procedures
Make sure Device A and Device B can reach each other through IPv4.
Configuring Device A
# Configure an IP address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port hundredgige 1/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 2.1.1.1 24
# Configure IP addresses for other interfaces as shown in Table 1. (Details not shown.)
# Create service loopback group 1 and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add HundredGigE 1/0/4 to service loopback group 1.
[DeviceA] interface hundredgige 1/0/4
[DeviceA-HundredGigE1/0/4] port service-loopback group 1
[DeviceA-HundredGigE1/0/4] quit
# Create a 6to4 tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4 6to4
# Specify an IPv6 address for the tunnel interface.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Specify the source interface as VLAN-interface 10 for the tunnel interface.
[DeviceA-Tunnel1] source vlan-interface 10
[DeviceA-Tunnel1] quit
# Configure a static route destined for 2002:0301:0101::/48 through the tunnel interface.
[DeviceA] ipv6 route-static 2002:0301:0101:: 48 tunnel 1
# Create an ISATAP tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4 isatap
[DeviceA-Tunnel2] ipv6 address 2001::5EFE:0201:0101 64
[DeviceA-Tunnel2] source vlan-interface 10
[DeviceA-Tunnel2] quit
# Configure a static route destined for 2001::/16 through the tunnel interface.
[DeviceA] ipv6 route-static 2001:: 16 tunnel 2
# Disable RA suppression.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] undo ipv6 nd ra halt
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] undo ipv6 nd ra halt
[DeviceA-Vlan-interface20] quit
[DeviceA] interface vlan-interface 30
[DeviceA-Vlan-interface30] undo ipv6 nd ra halt
[DeviceA-Vlan-interface30] quit
Configuring Device B
[DeviceB] vlan 10
[DeviceB-vlan10] port hundredgige 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 3.1.1.1 24
[DeviceB-Vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface hundredgige 1/0/4
[DeviceB-HundredGigE1/0/4] port service-loopback group 1
[DeviceB-HundredGigE1/0/4] quit
[DeviceB] interface tunnel 1 mode ipv6-ipv4 6to4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
[DeviceB-Tunnel1] source vlan-interface 10
[DeviceB-Tunnel1] quit
# Configure a static route destined for 2002:0201:0101::/48 through the tunnel interface.
[DeviceB] ipv6 route-static 2002:0201:0101:: 48 tunnel 1
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] undo ipv6 nd ra halt
[DeviceB-Vlan-interface20] quit
[DeviceB] interface vlan-interface 30
[DeviceB-Vlan-interface30] undo ipv6 nd ra halt
[DeviceB-Vlan-interface30] quit
Configuring the ISATAP host
Configurations on the ISATAP host vary by operating system. The following example is performed on Windows XP.
# Install IPv6.
C:\>ipv6 install
# Configure an ISATAP tunnel.
C:\>netsh interface ipv6 isatap set router 2.1.1.1
# Display information about the ISATAP tunnel interface.
C:\>ipv6 if 2
Interface 2: Automatic Tunneling Pseudo-Interface
Guid {48FCE3FC-EC30-E50E-F1A7-71172AEEE3AE}
does not use Neighbor Discovery
uses Router Discovery
routing preference 1
EUI-64 embedded IPv4 address: 1.1.1.2
router link-layer address: 2.1.1.1
preferred global 2001::5efe:1.1.1.2, life 29d23h59m46s/6d23h59m46s (public)
preferred link-local fe80::5efe:1.1.1.2, life infinite
link MTU 1500 (true link MTU 65515)
current hop limit 255
reachable time 42500ms (base 30000ms)
retransmission interval 1000ms
DAD transmits 0
default site prefix length 48
The host has acquired the prefix 2001::/64 and has automatically generated the global unicast address 2001::5efe:1.1.1.2. The message "uses Router Discovery" indicates that the router discovery function is enabled on the host.
# Display information about IPv6 routes on the host.
C:\>ipv6 rt
2001::/64 -> 2 pref 1if+8=9 life 29d23h59m43s (autoconf)
::/0 -> 2/fe80::5efe:1.1.1.1 pref 1if+256=257 life 29m43s (autoconf)
# Verify that Host A and Host B can ping each other.
D:\>ping6 -s 2002:0201:0101:1::2 2002:0301:0101:1::2
Pinging 2002:0301:0101:1::2
from 2002:0201:0101:1::2 with 32 bytes of data:
Reply from 2002:0301:0101:1::2: bytes=32 time=13ms
Reply from 2002:0301:0101:1::2: bytes=32 time=1ms
Reply from 2002:0301:0101:1::2: bytes=32 time<1ms
Ping statistics for 2002:0301:0101:1::2:
Minimum = 0ms, Maximum = 13ms, Average = 3ms
# Verify that the ISATAP host can ping Host A.
C:\Documents and Settings\Administrator>pingv6 2002:0201:0101:1::2
Pinging 2002:0201:0101:1::2 with 32 bytes of data:
Reply from 2002:0201:0101:1::2: time=33ms
Reply from 2002:0201:0101:1::2: time=32ms
Ping statistics for 2002:0201:0101:1::2:
Minimum = 32ms, Maximum = 33ms, Average = 32ms
Configuration files
· Device A:
vlan 10
vlan 20
vlan 30
interface Vlan-interface10
ip address 2.1.1.1 255.255.255.0
interface Vlan-interface20
ipv6 address 2002:201:101:1::1/64
interface Vlan-interface30
ipv6 address 2002:201:101:2::1/64
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 10
interface HundredGigE1/0/2
port access vlan 20
interface HundredGigE1/0/3
port access vlan 30
interface HundredGigE1/0/4
interface Tunnel1 mode ipv6-ipv4 6to4
source Vlan-interface10
interface Tunnel2 mode ipv6-ipv4 isatap
ipv6 address 2001::5EFE:201:101/64
ipv6 route-static 2001:: 16 Tunnel2
ipv6 route-static 2002:301:101:: 48 Tunnel1
· Device B:
vlan 10
vlan 20
vlan 30
ip address 3.1.1.1 255.255.255.0
ipv6 address 2002:301:101:1::1/64
ipv6 address 2002:301:101:2::1/64
port access vlan 10
port access vlan 20
port access vlan 30
ipv6 route-static 2002:201:101:: 48 Tunnel1
Related documentation
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Services Configuration Guide
· H3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Layer 3—IP Services Command Reference
