07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
23-Protocol Packet Rate Limit Commands
23-Protocol Packet Rate Limit Commands 38.77 KB
Protocol packet rate limit commands
anti-attack enable
Use anti-attack enable to enable protocol packet rate limit.
Use undo anti-attack enable to disable protocol packet rate limit.
Protocol packet rate limit is disabled.
anti-attack enable
Default command level
2: System level
# Enable protocol packet rate limit.
[Sysname] anti-attack enable
anti-attack protocol enable
Use anti-attack protocol enable to enable per-protocol bandwidth limit.
Use undo anti-attack protocol enable to disable per-protocol bandwidth limit.
anti-attack protocol { all | protocol } enable
undo anti-attack protocol { all | protocol } enable
Per-protocol bandwidth limit is disabled for packets of all protocols.
2: System level
all: Specifies all protocols.
protocol: Specifies a protocol by its type, a string of 1 to 31 characters.
# Enable per-protocol bandwidth limit for ARP frames.
[Sysname] anti-attack protocol arp enable
anti-attack protocol threshold
Use anti-attack protocol threshold to configure the threshold for per-protocol bandwidth limit.
Use undo anti-attack protocol threshold to restore the default.
anti-attack protocol protocol threshold limit-rate
undo anti-attack protocol protocol threshold
Each protocol has a default threshold.
2: System level
protocol: Specifies a protocol by its name, a string of 1 to 31 characters.
limit-rate: Specifies the threshold for per-protocol bandwidth limit, in the range of 0 to 102400 pps. When the maximum bandwidth is exceeded, the packets are discarded.
# Configure the threshold for per-protocol bandwidth limit for ARP frames as 1000 pps.
[Sysname] anti-attack protocol arp threshold 1000
anti-attack protocol flow-threshold
Use anti-attack protocol flow-threshold to enable per-flow bandwidth limit and configure the threshold.
Use undo anti-attack protocol flow-threshold to disable per-flow bandwidth limit.
anti-attack protocol protocol flow-threshold flow-limit-rate
undo anti-attack protocol protocol flow-threshold
Per-flow bandwidth limit is disabled for packets of all protocols.
2: System level
flow-limit-rate: Specifies the per-flow bandwidth limit threshold in the range of 0 to 102400 pps. When the maximum bandwidth is exceeded, the packets are discarded.
# Configure the per-flow bandwidth limit threshold for ARP frames as 50 pps.
[Sysname] anti-attack protocol arp flow-threshold 50
display anti-attack
Use display anti-attack to display protocol packet rate limit information.
display anti-attack { all | protocol [ protocol ] }
2: System level
protocol [ protocol ]: Specifies a protocol by its type, a string of 1 to 31 characters.
# Display states of the rate limit function for all protocols.
<Sysname> display anti-attack protocol
Enable Protocols: dhcp arp
 Disable Protocols: default udp tcp dot1x igmp ntp snmp telnet icmp lwapp
 loopback pppoe iactp acsei iec wlanex stp meshaction lwapp_data dot11_ctrl
 iactp_eapol svp ipc http ip ipv6 ethernet radius vrrp capwap_ctrl
 capwap_data dot11_auth dot11_assoc dot11_reassoc dot11_null
Enable Protocols
Protocols with rate limit enabled.
Disable Protocols
Protocols with rate limit disabled.
# Display rate limit information for all protocols.
<Sysname>display anti-attack all
                        Anti-attack statistics
Protocol       Priority  Limit(pps)       Rate(pps)      Passed     Dropped
default        2         256              0              3          0
udp            2         2048             0              0          0
tcp            2         1024             0              0          0
dot1x          1         1024             0              0          0
dhcp           2         2000             0              0          0
igmp           2         1024             0              0          0
ntp            2         256              0              0          0
arp            1         1024             0              1          0
snmp           0         1024             0              0          0
telnet         0         1024             0              0          0
icmp           0         1024             0              4          0
lwapp          1         2048             0              0          0
loopback       2         40               0              0          0
pppoe          1         1024             0              0          0
iactp          1         2560             0              0          0
acsei          2         128              0              0          0
iec            0         128              0              0          0
wlanex         2         2048             0              0          0
stp            2         2048             0              0          0
meshaction     2         1024             0              0          0
lwapp_data     1         2048             0              0          0
dot11_ctrl     1         512              0              0          0
iactp_eapol    1         2048             0              0          0
svp            2         40               0              0          0
ipc            2         40               0              0          0
http           1         1024             0              0          0
ip             2         2560             0              0          0
ipv6           2         128              0              0          0
ethernet       2         128              0              0          0
radius         1         2048             0              0          0
vrrp           1         2048             0              0          0
capwap_ctrl    1         2048             0              0          0
capwap_data    1         2048             0              0          0
dot11_auth     1         256              0              0          0
dot11_assoc    1         256              0              0          0
dot11_reassoc  1         256              0              0          0
dot11_null     1         1024             0              0          0
Protocol
Protocol name.
Priority
Processing priority value of the protocol, in the range of 0 to 4. A smaller value represents a higher priority.
Limit(pps)
Rate limit value. This field displays the default value if you have not configured it.
Rate(pps)
Current rate of the protocol packets.
Passed
Number of passed packets.
Dropped
Number of dropped packets.
# Display rate limit information for ICMP packets.
<Sysname> display anti-attack protocol icmp
icmp           0         1024             4              50         0
Flow-Source                               FlowRate(pps)  Passed     Dropped
1.1.1.10                                  2              40         0
1.1.1.20                                  1              10         0
Flow-Source
Source of the flow.
FlowRate(pps)
Current rate of the flow.
