07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
12-SSL VPN Commands
12-SSL VPN Commands 30.88 KB
SSL VPN configuration commands
Support for SSL VPN commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
ssl-vpn enable
Use ssl-vpn enable to enable the SSL VPN service.
Use undo ssl-vpn enable to disable the SSL VPN service.
ssl-vpn enable
undo ssl-vpn enable
The SSL VPN service is disabled.
Default command level
2: System level
Before executing this command, make sure that an SSL server policy has been specified for the SSL VPN service by using the ssl-vpn server-policy command.
# Specify the SSL server policy svpn and port 3001 for the SSL VPN service, and then enable the SSL VPN service.
[Sysname] ssl server-policy svpn
[Sysname-ssl-server-policy-svpn] pki-domain domain1
[Sysname-ssl-server-policy-svpn] quit
[Sysname] ssl-vpn server-policy svpn port 3001
[Sysname] ssl-vpn enable
Use ssl-vpn server-policy to specify the SSL server policy and port to be used by the SSL VPN service.
Use undo ssl-vpn server-policy to restore the default.
ssl-vpn server-policy server-policy-name [ port port-number ]
No SSL server policy is specified for the SSL VPN service.
2: System level
server-policy-name: Name of the SSL server policy, a case-insensitive string of 1 to 16 characters.
port port-number: Specifies the port number to be used by the SSL VPN service. The port-number argument is in the range of 1 to 65535 and defaults to 443.
The specified SSL server policy must have been created.
# Specify the SSL server policy svpn and port 3001 for the SSL VPN service.
