- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH Commands
- 11-SSL Commands
- 12-SSL VPN Commands
- 13-TCP Attack Protection Commands
- 14-ARP Attack Protection Commands
- 15-IPsec Commands
- 16-ALG Commands
- 17-Firewall Commands
- 18-Session Management Commands
- 19-Web Filtering Commands
- 20-User Isolation Commands
- 21-Source IP Address Verification Commands
- 22-FIPS Commands
- 23-Protocol Packet Rate Limit Commands
- 24-Attack detection and protection commands
| 18-Session Management Commands | 103.20 KB |
Session management commands
Support for session management commands depends on your device model. For more information, see About the H3C Access Controllers Command References.
application aging-time
Use application aging-time to set the aging timer for the sessions of an application layer protocol.
Use undo application aging-time to restore the default.
application aging-time { dns | ftp | msn | qq | sip } time-value
undo application aging-time [ dns | ftp | msn | qq | sip ]
The default session aging times for the application layer protocols are as follows:
· DNS: 60 seconds.
· FTP: 3600 seconds.
· MSN: 3600 seconds.
· QQ: 60 seconds.
· SIP: 300 seconds.
Default command level
2: System level
dns: Specifies the aging time for DNS sessions.
ftp: Specifies the aging time for FTP sessions.
msn: Specifies the aging time for MSN sessions.
qq: Specifies the aging time for QQ sessions.
sip: Specifies the aging time for SIP sessions.
time-value: Aging time in seconds, in the range of 5 to 100000.
If no application layer protocol type is specified, the command restores the session aging timers for all the application layer protocols to the defaults.
# Set the aging timer for FTP sessions to 1800 seconds.
[Sysname] application aging-time ftp 1800
display application aging-time
Use display application aging-time to display the session aging timers for the application layer protocols.
display application aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
You can use this command to display the default session aging timers for the application layer protocols before these session aging timers are adjusted.
# Display the current session aging timers for the application layer protocols.
<Sysname> display application aging-time
Protocol Aging-time(s)
ftp 3600
dns 60
sip 300
msn 3600
qq 60
Protocol |
Application layer protocol. |
Aging-time(s) |
Session aging timer in seconds. |
display session aging-time
Use display session aging-time to display the session aging timers in different protocol states.
display session aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
You can use this command to display the default session aging timers in different protocol states before these session aging timers are adjusted.
# Display the current session aging timers in different protocol states.
<Sysname> display session aging-time
syn 30
tcp-est 3600
fin 30
udp-open 30
udp-ready 60
icmp-open 60
icmp-closed 30
rawip-open 30
rawip-ready 60
accelerate 10
Protocol |
Protocol status. |
Aging-time(s) |
Session aging time in seconds. |
session aging-time
display session relation-table
Use display session relation-table to display relationship table entries.
display session relation-table [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Displays all relationship table entries.
<Sysname> display session relation-table
Local IP/Port Global IP/Port MatchMode
192.168.1.22/99 10.153.2.22/99 Local
APP:QQ Pro:UDP TTL:2000s AllowConn:10
192.168.1.100/99 10.153.2.100/99 Local
APP:FTP Pro:TCP TTL:2000s AllowConn:10
Total find: 2
Local IP/Port |
IP address/port number of the inside network. |
Global IP/Port |
IP address/ port number of the outside network. |
MatchMode |
Match mode from session table to relationship table: · Local—The source IP address/source port of a new session are matched against Local IP/Port in the relation table. · Global—The destination IP address and destination port of a new session are matched against Global IP/Port in the relation table. · Either—The IP/port of a new session are matched against Local IP/Port or Global IP/Port in the relation table. |
App |
Application layer protocol, FTP, MSN, or QQ. |
Pro |
Transport layer protocol, TCP or UDP. |
TTL |
Remaining lifetime of the relationship table entry, in seconds. |
AllowConn |
Number of sessions allowed by the relationship table entry. |
Total find |
Total number of found relationship table entries. |
display session statistics
Use display session statistics to display statistics for the sessions.
display session statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If no keyword is specified, the command displays statistics for all sessions.
# Display statistics for all sessions.
<Sysname> display session statistics
Current session(s):593951
Current TCP session(s): 0
Half-Open: 0 Half-Close: 0
Current UDP session(s): 593951
Current ICMP session(s): 0
Current RAWIP session(s): 0
Current relation table(s): 50000
Session establishment rate: 184503/s
TCP Session establishment rate: 0/s
UDP Session establishment rate: 184503/s
ICMP Session establishment rate: 0/s
RAWIP Session establishment rate: 0/s
Received TCP: 1538 packet(s) 337567 byte(s)
Received UDP: 86810494849 packet(s) 4340524910260 byte(s)
Received ICMP: 307232 packet(s) 17206268 byte(s)
Received RAWIP: 0 packet(s) 0 byte(s)
Dropped TCP: 0 packet(s) 0 byte(s)
Dropped UDP: 0 packet(s) 0 byte(s)
Dropped ICMP: 0 packet(s) 0 byte(s)
Dropped RAWIP: 0 packet(s) 0 byte(s)
Current session(s) |
Total number of sessions. |
Current TCP session(s) |
Number of TCP sessions. |
Half-Open |
Number of TCP sessions in the half-open state. |
Half-Close |
Number of TCP sessions in the half-close state. |
Current UDP session(s) |
Number of UDP sessions. |
Current ICMP session(s) |
Number of ICMP sessions. |
Current RAWIP session(s) |
Number of Raw IP sessions. |
Current relation table(s) |
Total number of relationship table entries. |
Session establishment rate |
Session establishment rate. |
TCP Session establishment rate |
Establishment rate of TCP sessions. |
UDP Session establishment rate |
Establishment rate of UDP sessions. |
ICMP Session establishment rate |
Establishment rate of ICMP sessions . |
RAWIP Session establishment rate |
Establishment rate of Raw IP sessions. |
Received TCP |
Counts of received TCP packets and bytes. |
Received UDP |
Counts of received UDP packets and bytes. |
Received ICMP |
Counts of received ICMP packets and bytes. |
Received RAWIP |
Counts of received Raw IP packets and bytes. |
Dropped TCP |
Counts of dropped TCP packets and bytes. |
Dropped UDP |
Counts of dropped UDP packets and bytes. |
Dropped ICMP |
Counts of dropped ICMP packets and bytes. |
Dropped RAWIP |
Counts of dropped Raw IP packets and bytes. |
display session table
Use display session table to display information about session table entries.
display session table [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol-type { icmp | raw-ip | tcp | udp } ] [ source-port source-port ] [ destination-port destination-port ] [ count | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
source-ip source-ip: Displays the session table entries with the specified source IP address.
destination-ip destination-ip: Displays session table entries with the specified destination IP address.
protocol-type { icmp | raw-ip | tcp | udp }: Display the session table entries for the specified protocol, including ICMP, RawIP, TCP, and UDP.
source-port source-port: Displays the session table entries with the specified source port. The source-port argument is in the range of 0 to 65535.
destination-port destination-port: Displays the session table entries with the specified destination port. The destination-port argument is in the range of 0 to 65535.
count: Displays the number of session table entries.
verbose: Displays detailed information about session table entries. Without this keyword, the command displays brief information about the specified session table entries.
If no argument is specified, the command displays all session table entries.
If multiple keywords like source-ip, destination-ip, protocol-type, source-port, and destination-port are specified, the command displays the session table entries that match all these criteria.
# Display brief information about all session table entries.
<Sysname> display session table
Initiator:
Source IP/Port : 192.168.1.18/2048
Dest IP/Port : 192.168.1.55/768
Pro : ICMP(ICMP(1))
VPN-Instance/VLAN ID/VLL ID:
Initiator:
Source IP/Port : 192.168.1.18/1212
Dest IP/Port : 192.168.1.55/23
Pro : TCP(TCP(6))
Total find: 2
# Display detailed information about all session table entries.
<Sysname> display session table verbose
Initiator:
Source IP/Port : 192.168.1.19/137
Dest IP/Port : 192.168.1.255/137
Responder:
Source IP/Port : 192.168.1.255/137
Dest IP/Port : 192.168.1.19/137
Pro: UDP(17) App: NBT-name State: UDP-OPEN
Start time: 2014-03-17 10:39:43 TTL: 2s
Received packet(s)(Init): 6 packet(s) 468 byte(s)
Received packet(s)(Reply): 0 packet(s) 0 byte(s)
Initiator:
Responder:
Source IP/Port : 192.168.1.55/23
Dest IP/Port : 192.168.1.18/1212
Pro: TCP(6) App: TELNET State: TCP-EST
Start time: 2014-03-17 09:30:33 TTL: 3600s
Received packet(s)(Init): 1173 packet(s) 47458 byte(s)
Received packet(s)(Reply): 1168 packet(s) 61845 byte(s)
Total find: 2
# Display the number of session table entries with the source IP address of 1.1.1.1.
<Sysname> display session table source-ip 1.1.1.1 count
Matching session count: 100
Table 5 Command output
Initiator: |
Initiator's session information. |
Responder: |
Responder's session information. |
Pro |
Transport layer protocol, TCP, UDP, ICMP, or Raw IP. |
VPN-Instance/VLAN ID/VLL ID |
VPN instance to which the session belongs. This field is reserved for future support. VLAN and INLINE that the session belongs to during Layer 2 forwarding. |
App |
Application layer protocol, FTP, DNS, MSN or QQ. Unknown indicates protocol type of a non-well-known port. |
State |
Session status. Possible values are: · Accelerate. · SYN. · TCP-EST. · FIN. · UDP-OPEN. · UDP-READY. · ICMP-OPEN. · ICMP-CLOSED. · RAWIP-OPEN. · RAWIP-READY. |
Start Time |
Session establishment time. |
TTL |
Remaining lifetime of the session, in seconds. |
Received packet(s)(Init) |
Counts of packets and bytes from the initiator to the responder. |
Received packet(s)(Reply) |
Counts of packets and bytes from the responder to the initiator. |
Total find |
Total number of found sessions. |
reset session
Use reset session to clear session table entries.
reset session [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol-type { icmp | raw-ip | tcp | udp } ] [ source-port source-port ] [ destination-port destination-port ]
2: System level
source-ip source-ip: Clears the session table entries with the specified source IP address of the initiator.
destination-ip destination-ip: Clears the session table entries with the specified destination IP address of the initiator.
protocol-type { icmp | raw-ip | tcp | udp }: Clears the session table entries of the specified protocol type. The protocol types include ICMP, Raw IP, TCP, and UDP.
source-port source-port: Clears the session table entries with the specified source port of the initiator.
destination-port destination-port: Clears the session table entries with the specified destination port of the initiator.
If no parameter is specified, the command clears all session table entries.
# Clear all session table entries.
<Sysname> reset session
# Clear all sessions with the source IP address as 10.10.10.10 of the initiator.
<Sysname> reset session source-ip 10.10.10.10
reset session statistics
Use reset session statistics to clear session statistics.
2: System level
# Clear all session statistics.
<Sysname> reset session statistics
session aging-time
Use session aging-time to set the aging timer for sessions of a specified protocol that are in a specified state.
Use undo session aging-time to restore the default. If no keyword is specified, the command restores the session aging timers for all protocol states to the defaults.
session aging-time { accelerate | fin | icmp-closed | icmp-open | rawip-open | rawip-ready | syn | tcp-est | udp-open | udp-ready } time-value
undo session aging-time [ accelerate | fin | icmp-closed | icmp-open | rawip-open | rawip-ready | syn | tcp-est | udp-open | udp-ready ]
The default values are as follows:
· ACCELERATE state: 10 seconds.
· TCP FIN_WAIT state: 30 seconds.
· ICMP CLOSED state: 30 seconds.
· ICMP OPEN state: 60 seconds.
· RAWIP_OPEN state: 30 seconds.
· RAWIP_READY state: 60 seconds.
· TCP SYN_SENT and SYN_RCV state: 30 seconds.
· TCP ESTABLISHED state: 3600 seconds.
· UDP OPEN state: 30 seconds.
· UDP READY state: 60 seconds.
2: System level
accelerate: Specifies the aging timer for the sessions in the accelerate queue.
fin: Specifies the aging timer for the TCP sessions in the FIN_WAIT state.
icmp-closed: Specifies the aging timer for the ICMP sessions in the CLOSED state.
icmp-open: Specifies the aging timer for the ICMP sessions in the OPEN state.
rawip-open: Specifies the aging timer for the sessions in the RAWIP_OPEN state.
rawip-ready: Specifies the aging timer for the sessions in the RAWIP_READY state.
syn: Specifies the aging timer for the TCP sessions in the SYN_SENT or SYN_RCV state.
tcp-est: Specifies the aging timer for the TCP sessions in the ESTABLISHED state.
udp-open: Specifies the aging timer for the UDP sessions in the OPEN state.
udp-ready: Specifies the aging timer for the UDP sessions in the READY state.
time-value: Aging timer in seconds. The value range is 5 to 100000 seconds.
To display the session aging timers in different protocol states, use the display session aging-time command.
# Set the aging time for TCP sessions in the SYN_SENT or SYN_RCV state to 60 seconds.
[Sysname] session aging-time syn 60
session checksum
Use session checksum to enable checksum verification for protocol packets.
Use undo session checksum to disable checksum verification.
session checksum { all | { icmp | tcp | udp } * }
undo session checksum { all | { icmp | tcp | udp } * }
Checksum verification is disabled.
2: System level
all: Enables checksum verification for TCP, UDP, and ICMP packets.
icmp: Enables checksum verification for ICMP packets.
tcp: Enables checksum verification for TCP packets.
udp: Enables checksum verification for UDP packets.
# Enable checksum verification for UDP packets.
[Sysname] session checksum udp
session log bytes-active
Use session log bytes-active to set the byte-based threshold for traffic-based logging.
Use undo session log bytes-active to restore the default.
session log bytes-active bytes-value
The device does not output session logs.
2: System level
bytes-value: Sets the byte-based threshold in the range of 1 to 1000 MB.
# Configure the device to output session logs on a per-10-MB basis.
[Sysname] session log byte-active 10
session log enable (interface view)
Use session log enable to enable session logging.
Use undo session log enable to disable session logging.
session log enable [ acl acl-number ] { inbound | outbound }
undo session log enable [ acl acl-number ] { inbound | outbound }
Session logging is disabled.
Interface view
2: System level
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If you do not specify an ACL, this command enables session logging for all sessions on the interface.
If neither inbound nor outbound keyword is specified, you enable session logging on both directions.
In each direction, you can use only one ACL for session logging. If you execute the command by using multiple ACLs in one direction, the most recent configuration takes effect.
# Enable session logging on interface VLAN-interface 1 for all sessions in the inbound direction.
[Sysname-Vlan-interface1] session log enable inbound
# Enable session logging on interface VLAN-interface 2 for sessions that match ACL 2050 in the outbound direction.
[Sysname-Vlan-interface2] session log enable acl 2050 outbound
session log packets-active
Use session log packets-active to set the packet-based threshold for traffic-based logging.
Use undo session log packets-active to restore the default.
session log packets-active packets-value
2: System level
packets-value: Sets the packet-based threshold in the range of 1 to 1000 mega-packets.
# Configure the device to output session logs on a per-10-mega-packet basis.
[Sysname] session log packets-active 10
session log time-active
Use session log time-active to set the time-based session logging.
Use undo session log time-active to restore the default.
session log time-active time-value
2: System level
time-value: Sets the interval in minutes. The value range for the time-value argument is 10 to 120 and the value must be integer times of 10.
# Configure the device to output session logs at 50-minute intervals.
<Sysname> system
[Sysname] session log time-active 50
session mode hybrid
Use session mode hybrid to set the hybrid mode for session management. In this mode, session management can process both bidirectional sessions and unidirectional sessions.
Use undo session mode to set the bidirectional mode for session management.
session mode hybrid
undo session mode
The session management feature operates in bidirectional mode, and it can process only bidirectional sessions.
2: System level
In a bidirectional session, all packets in any direction pass the device.
In a unidirectional session, only the packets in one direction pass the device, and the packets in the opposite direction do not pass the device.
# Set the hybrid mode for session management.
[Sysname] session mode unidirection
session persist acl
Use session persist acl to specify persistent sessions. Sessions that match the permit statements in the specified ACL are persistent sessions.
Use undo session persist to remove the configuration.
session persist acl acl-number [ aging-time time-value ]
No persistent session rule is specified.
2: System level
aging-time time-value: Sets the aging time for persistent sessions, in hours. The value range is 0 to 360 and defaults to 24. To disable the aging for persistent sessions, set the value to 0.
Persistent sessions will not be removed because they are not matched with any packets within the aging time. You can manually remove such sessions when necessary.
A persistent session rule can reference only one ACL.
# Configure all sessions matching ACL 2000 as persistent sessions, setting the aging time of the sessions to 72 hours.
[Sysname] session persist acl 2000 aging-time 72
reset session
