07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
15-IPsec Commands
15-IPsec Commands 224.47 KB
IPsec configuration commands· 1
ah authentication-algorithm·· 1
connection-name· 1
display ipsec policy· 2
display ipsec policy-template· 4
display ipsec sa· 6
display ipsec statistics· 9
display ipsec transform-set 11
display ipsec tunnel 12
encapsulation-mode· 14
esp authentication-algorithm·· 14
esp encryption-algorithm·· 15
ike-peer (IPsec policy view/IPsec policy template view) 16
ipsec anti-replay check· 16
ipsec anti-replay window·· 17
ipsec invalid-spi-recovery enable· 17
ipsec policy (interface view) 18
ipsec policy (system view) 19
ipsec policy isakmp template· 20
ipsec policy-template· 20
ipsec sa global-duration· 21
ipsec transform-set 22
ipsec synchronization enable· 23
policy enable· 23
reset ipsec sa· 24
reset ipsec statistics· 25
sa duration· 25
security acl 26
synchronization anti-replay-interval 28
transform·· 29
transform-set 29
IKE configuration commands· 31
authentication-algorithm·· 31
authentication-method· 31
certificate domain· 32
dh· 32
display ike dpd· 33
display ike peer 34
display ike proposal 35
display ike sa· 36
dpd· 40
encryption-algorithm·· 40
exchange-mode· 41
id-type· 42
ike dpd· 43
ike local-name· 44
ike next-payload check disabled· 44
ike peer (system view) 45
ike proposal 45
ike sa keepalive-timer interval 46
ike sa keepalive-timer timeout 47
ike sa nat-keepalive-timer interval 47
interval-time· 48
local 48
local-address· 49
local-name· 50
nat traversal 50
peer 51
pre-shared-key· 51
proposal 52
remote-address· 53
remote-name· 54
reset ike sa· 55
sa duration· 56
time-out 57
All ACs support IPsec between ACs and APs. Only the WAC360 series, WX2540E, and the WX3000E series support IPsec between ACs.
Use ah authentication-algorithm to specify authentication algorithms for the AH protocol.
Use undo ah authentication-algorithm to restore the default.
ah authentication-algorithm { md5 | sha1 } *
In FIPS mode, AH uses SHA-1 for authentication.
In non-FIPS mode, AH uses MD5 for authentication.
IPsec transform set view
Default command level
2: System level
md5: Uses MD5.
sha1: Uses SHA1.
In FIPS mode, AH does not support MD5 authentication.
You must use the transform command to specify the AH security protocol or both AH and ESP before you specify authentication algorithms for AH.
# Configure IPsec transform set prop1 to use AH and SHA1.
[Sysname] ipsec transform-set prop1
[Sysname-ipsec-transform-set-prop1] transform ah
[Sysname-ipsec-transform-set-prop1] ah authentication-algorithm sha1
·     ipsec transform-set
·     transform
connection-name
Use connection-name to configure an IPsec connection name. This name functions only as a description of the IPsec policy.
Use undo connection-name to restore the default.
connection-name name
No IPsec connection name is configured.
IPsec policy view, IPsec policy template view
2: System level
name: Specifies an IPsec connection name, a case-insensitive string of 1 to 32 characters.
Example
# Set IPsec connection name to CenterToA.
[Sysname] ipsec policy policy1 1 isakmp
[Sysname-ipsec-policy-isakmp-policy1-1] connection-name CenterToA
Use display ipsec policy to display information about IPsec policies.
display ipsec policy [ brief | name policy-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays brief information about all IPsec policies.
name: Displays detailed information about a specific IPsec policy or IPsec policy group.
policy-name: Specifies the name of the IPsec policy, a string of 1 to 15 characters.
seq-number: Specifies the sequence number of the IPsec policy, in the range of 1 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not specify any parameters, the command displays detailed information about all IPsec policies.
If you specify the name policy-name option but leave the seq-number argument, the command displays detailed information about the specified IPsec policy group.
# Display brief information about all IPsec policies.
<Sysname> display ipsec policy brief
IPsec-Policy-Name     Mode    acl    ike-peer name    Mapped Template
bbbbbbbbbbbbbbb-1     template                        aaaaaaaaaaaaaaa
map-1                 isakmp  3000   peer
nat-1                 isakmp  3500   nat
test-1                isakmp  3200   test
toccccc-1             isakmp  3003   tocccc
IPsec-Policy-Name     Mode    acl          Local-Address  Remote-Address
IPsec-Policy-Name
Name and sequence number of the IPsec policy separated by hyphen.
Mode
Negotiation mode of the IPsec policy:
·     manual—Manual mode. The H3C access controllers do not support the manual mode.
·     isakmp—IKE negotiation mode.
·     template—IPsec policy template mode.
acl
ACL referenced by the IPsec policy.
ike-peer name
IKE peer name.
Mapped Template
Referenced IPsec policy template.
Local-Address
IP address of the local end.
Remote-Address
IP address of the remote end.
# Display detailed information about all IPsec policies.
IPsec Policy Group: "policy_isakmp"
Interface: Vlan-interface2
  IPsec policy name: "policy_isakmp"
  sequence number: 10
  acl version: IPv4
  mode: isakmp
    security data flow : 3000
    selector mode: standard
    ike-peer name:  per
    perfect forward secrecy:
    transform-set name: prop1
    synchronization inbound anti-replay-interval: 1000 packets
    synchronization outbound anti-replay-interval: 10000 packets
    IPsec sa local duration(time based): 3600 seconds
    IPsec sa local duration(traffic based): 1843200 kilobytes
    policy enable: True
    tfc enable: False
security data flow
Interface to which the IPsec policy is applied.
sequence number
Sequence number of the IPsec policy.
acl version
ACL version. The H3C access controllers support only IPv4 ACL.
If no ACL is referenced, this field displays None.
mode
selector mode
Data flow protection mode of the IPsec policy: standard, aggregation, or per-host.
ike-peer name
IKE peer referenced by the IPsec policy.
Whether PFS is enabled.
transform-set name
Transform set referenced by the IPsec policy.
policy enable
Whether the IPsec policy is enabled or not.
tfc enable
Whether TFC padding is enabled.
Interval for synchronizing anti-replay windows in inbound direction, expressed in the number of received packets.
Interval for synchronizing anti-replay sequence numbers in outbound direction, expressed in the number of sent packets.
inbound/outbound AH/ESP setting
AH/ESP settings in the inbound/outbound direction, including the SPI and keys.
Use display ipsec policy-template to display information about IPsec policy templates.
display ipsec policy-template [ brief | name template-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays brief information about all IPsec policy templates.
name: Displays detailed information about a specific IPsec policy template or IPsec policy template group.
template-name: Specifies the name of the IPsec policy template, a string of 1 to 15 characters.
seq-number: Specifies the sequence number of the IPsec policy template, in the range of 1 to 65535.
If you do not specify any parameters, the command displays detailed information about all IPsec policy templates.
If you specify the name template-name option but leave the seq-number argument, the command displays information about the specified IPsec policy template group.
# Display brief information about all IPsec policy templates.
<Sysname> display ipsec policy-template brief
Policy-Template-Name     acl            Remote-Address
test-300                 2200
Name and sequence number of the IPsec policy template separated by hyphen.
acl
ACL referenced by the IPsec policy template.
Remote Address
Remote IP address.
# Display detailed information about all IPsec policy templates.
IPsec Policy Template Group: "test"
  Policy template name: "test"
  sequence number: 1
    ACL's Version:  acl4
    ike-peer name:  per
    perfect forward secrecy:  DH group 5
    transform-set name:  testprop
security data flow
ACL's Version
ike-peer name
IKE peer referenced by the IPsec policy template.
DH group
DH group used: 1, 2, 5, or 14.
transport-set name
IPsec transform set referenced by the IPsec policy template.
Time-based lifetime of the IPsec SAs at the local end.
Traffic-based lifetime of the IPsec SAs at the local end.
display ipsec sa
Use display ipsec sa to display information about IPsec SAs.
display ipsec sa [ active | brief | policy policy-name [ seq-number ] | remote ip-address standby ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
active: Displays detailed information about the active IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
brief: Displays brief information about all IPsec SAs.
policy: Displays detailed information about IPsec SAs created by using a specific IPsec policy.
policy-name: Specifies the name of the IPsec policy, a string 1 to 15 characters.
remote ip-address: Displays detailed information about the IPsec SA with a specific remote address.
standby: Displays detailed information about the standby IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
If you do not specify any parameters, the command displays information about all IPsec SAs.
# Display brief information about all IPsec SAs.
<Sysname> display ipsec sa brief
total phase-2 IPv4 SAs: 2
Src Address  Dst Address  SPI    Protocol     Algorithm
10.1.1.1     10.1.1.2     300    ESP          E:DES;
                                         A:HMAC-MD5-96
10.1.1.2     10.1.1.1     400    ESP          E:DES;
                                              A:HMAC-MD5-96
total phase-2 IPv6 SAs: 0
Table 5 Command output
Src Address
Local IP address.
Dst Address
Remote IP address.
SPI
Security parameter index.
Protocol
Security protocol used by IPsec.
Algorithm
Authentication algorithm and encryption algorithm used by the security protocol, where E indicates the encryption algorithm and A indicates the authentication algorithm. A value of NULL means that type of algorithm is not specified.
# Display detailed information about all IPsec SAs.
    path MTU: 1500
  IPsec policy name: "r2"
  sequence number: 1
  acl version: ACL4
  mode: isakmp
    connection id: 3
    encapsulation mode: tunnel
    tunnel:
        local  address: 2.2.2.2
        remote address: 1.1.1.2
    flow:
        sour addr: 192.168.2.0/255.255.255.0  port: 0  protocol: IP
        dest addr: 192.168.1.0/255.255.255.0  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 3564837569 (0xd47b1ac1)
      transform-set: ESP-ENCRYPT-DES ESP-AUTH-MD5
      sa duration (kilobytes/sec): 4294967295/604800
      sa remaining duration (kilobytes/sec): 1843200/2686
      max received sequence-number: 5
      anti-replay check enable: Y
      anti-replay window size: 32
      udp encapsulation used for nat traversal: N
      status: active
    [outbound ESP SAs]
      spi: 801701189 (0x2fc8fd45)
      max sent sequence-number: 6
Table 6 Command output
Interface referencing the IPsec policy.
path MTU
Maximum IP packet length supported by the interface.
IPsec policy  name
Name of IPsec policy used.
sequence number
acl version
mode
IPsec negotiation mode.
connection id
IPsec tunnel identifier.
encapsulation mode
Encapsulation mode, transport or tunnel.
tunnel
IPsec tunnel.
local address
Local IP address of the IPsec tunnel.
remote address
Remote IP address of the IPsec tunnel.
flow
Data flow.
sour addr
Source IP address of the data flow.
dest addr
Destination IP address of the data flow.
port
Port number.
protocol
Protocol type.
inbound
Information of the inbound SA.
spi
transform-set
Security protocol and algorithms used by the IPsec transform set.
sa duration
Lifetime of the IPsec SA.
sa remaining key duration
Remaining lifetime of the SA.
Maximum sequence number of the received packets (relevant to the anti-replay function provided by the security protocol).
Whether NAT traversal is enabled for the SA.
outbound
Information of the outbound SA.
Maximum sequence number of the sent packets (relevant to the anti-replay function provided by the security protocol).
Whether IPsec anti-replay checking is enabled.
Size of the anti-replay window.
·     reset ipsec sa
·     ipsec sa global-duration
Use display ipsec statistics to display IPsec packet statistics.
display ipsec statistics [ tunnel-id integer ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
tunnel-id integer: Specifies an IPsec tunnel by its ID in the range of 1 to 2000000000.
If you do not specify any parameters, the command displays the statistics for all IPsec packets.
# Display statistics on all IPsec packets.
<Sysname> display ipsec statistics
  the security packet statistics:
    input/output security packets: 47/62
    input/output security bytes: 3948/5208
    input/output dropped security packets: 0/45
    dropped security packet detail:
      not enough memory: 0
      can't find SA: 45
      queue is full: 0
      authentication has failed: 0
      wrong length: 0
      replay packet: 0
      packet too long: 0
      wrong SA: 0
# Display IPsec packet statistics for Tunnel 3.
<Sysname> display ipsec statistics tunnel-id 3
  Connection ID : 3
    input/output security packets: 5124/8231
    input/output security bytes: 52348/64356
    input/output dropped security packets: 0/0
      queue is full: 0
      wrong length: 0
      replay packet: 0
      packet too long: 0
      wrong SA: 0
Table 7 Command output
Connection ID
ID of the tunnel.
Counts of inbound and outbound IPsec protected packets.
Counts of inbound and outbound IPsec protected bytes.
Counts of inbound and outbound IPsec protected packets that are discarded by the device.
Detailed information about inbound/outbound packets that get dropped.
not enough memory
Number of packets dropped due to lack of memory.
can't find SA
Number of packets dropped due to finding no security association.
queue is full
Number of packets dropped due to full queues.
Number of packets dropped due to authentication failure.
wrong length
Number of packets dropped due to wrong packet length.
replay packet
Number of packets replayed.
packet too long
Number of packets dropped due to excessive packet length.
wrong SA
Number of packets dropped due to improper SA.
Use display ipsec transform-set to display information about IPsec transform sets.
display ipsec transform-set [ transform-set-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
transform-set-name: Specifies the name of an IPsec transform set, a string of 1 to 32 characters. If you do not specify an IPsec transform set, the command displays information about all IPsec transform sets.
If you do not specify any parameters, the command displays information about all IPsec transform sets.
# Display information about all IPsec transform sets.
<Sysname> display ipsec transform-set
  IPsec transform-set name: tran1
    ESN : disable
    ESN scheme: NO
    transform: esp-new
    ESP protocol:
      Integrity: md5-hmac-96
      Encryption: des
  IPsec transform-set name: tran2
    encapsulation mode: transport
    ESN : disable
    ESN scheme: NO
    transform: esp-new
    ESP protocol:
      Encryption: des
Table 8 Command output
Name of the IPsec transform set.
encapsulation mode
Encapsulation mode used by the IPsec transform set, transport or tunnel.
ESN
Whether the ESN function is enabled.
ESN scheme
·     NO—Supports the ESN function.
·     YES—Does not support the ESN function.
transform
Security protocols used by the IPsec transform set: AH, ESP, or both. If both protocols are configured, IPsec uses ESP before AH.
AH protocol
Authentication algorithm used by AH.
ESP protocol
Authentication algorithm and encryption algorithm used by ESP.
ipsec transform-set
Use display ipsec tunnel to display information about IPsec tunnels.
display ipsec tunnel [ active | standby ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
active: Displays information about the active IPsec tunnels in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
standby: Displays information about the standby IPsec tunnels in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
If you do not specify any parameters, the command displays information about all IPsec tunnels.
# Display information about IPsec tunnels.
<Sysname> display ipsec tunnel
    total tunnel : 2
    connection id: 3
    SA's SPI:
        inbound:  187199087 (0xb286e6f) [ESP]
        outbound: 3562274487 (0xd453feb7) [ESP]
    tunnel:
        local  address:  44.44.44.44
        remote address : 44.44.44.55
    flow:
        sour addr : 44.44.44.0/255.255.255.0  port: 0  protocol : IP
        dest addr : 44.44.44.0/255.255.255.0  port: 0  protocol : IP
# Display information about IPsec tunnels in aggregation mode.
    total tunnel: 2
    connection id: 4
    SA's SPI:
        inbound :  2454606993 (0x924e5491) [ESP]
        outbound : 675720232 (0x2846ac28) [ESP]
    tunnel :
        remote address : 44.44.44.45
    flow :
        as defined in acl 3001
Table 9 Command output
connection id
Connection ID, used to uniquely identify an IPsec Tunnel.
SA's SPI
SPIs of the inbound and outbound SAs.
tunnel
Local and remote addresses of the tunnel.
flow
Data flow protected by the IPsec tunnel, including source IP address, destination IP address, source port, destination port and protocol.
The IPsec tunnel protects all data flows defined by ACL 3001.
encapsulation-mode
Use encapsulation-mode to set the encapsulation mode that the security protocol uses to encapsulate IP packets.
Use undo encapsulation-mode to restore the default.
encapsulation-mode { transport | tunnel }
A security protocol encapsulates IP packets in tunnel mode.
2: System level
transport: Uses transport mode.
tunnel: Uses tunnel mode.
# Configure IPsec transform set tran1 to use the transport encapsulation mode.
[Sysname] ipsec transform-set tran1
[Sysname-ipsec-transform-set-tran1] encapsulation-mode transport
ipsec transform-set
Use esp authentication-algorithm to specify authentication algorithms for ESP.
Use undo esp authentication-algorithm to restore the default.
esp authentication-algorithm { md5 | sha1 } *
In FIPS mode, ESP uses SHA-1 for authentication.
In non-FIPS mode, ESP uses MD5 for authentication.
2: System level
md5: Uses the MD5 algorithm, which uses a 128-bit key.
sha1: Uses the SHA1 algorithm, which uses a 160-bit key.
Compared with SHA1, MD5 is faster but less secure. MD5 is sufficient for most networks. To deploy a highly secure network, use SHA1.
In FIPS mode, ESP does not support MD5 authentication.
In FIPS mode, you must specify both an encryption algorithm and an authentication algorithm.
# Configure IPsec transform set prop1 to use ESP and specify SHA1 as the authentication algorithm for ESP.
[Sysname-ipsec-transform-set-prop1] transform esp
[Sysname-ipsec-transform-set-prop1] esp authentication-algorithm sha1
·     esp encryption-algorithm
Use esp encryption-algorithm to specify encryption algorithms for ESP.
Use undo esp encryption-algorithm to restore the default.
esp encryption-algorithm { 3des | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | des } *
In non-FIPS mode, ESP uses AES-128 for encryption.
In non-FIPS mode, ESP uses DES for encryption.
2: System level
3des: Uses the triple Data Encryption Standard (3DES) in CBC mode, which uses a 168-bit key.
aes-cbc-128: Uses the Advanced Encryption Standard (AES) in CBC mode that uses a 128-bit key.
aes-cbc-192: Uses AES in CBC mode that uses a 192-bit key.
aes-cbc-256: Uses AES in CBC mode that uses a 256-bit key.
des: Uses the DES in cipher block chaining (CBC) mode, which uses a 56-bit key.
In non-FIPS mode, ESP supports three IP packet protection schemes: encryption only, authentication only, or both encryption and authentication.
In FIPS mode, ESP must encrypt and authenticate packets.
In FIPS mode, ESP does not support DES or 3DES.
# Configure IPsec transform set prop1 to use ESP and specify 3DES as the encryption algorithm for ESP.
[Sysname-ipsec-transform-set-prop1] esp encryption-algorithm 3des
·     display ipsec transform-set
·     esp authentication-algorithm
Use ike-peer to reference an IKE peer in an IPsec policy or IPsec policy template configured through IKE negotiation.
Use undo ike peer to remove the reference.
ike-peer peer-name
undo ike-peer peer-name
2: System level
peer-name: Specifies the IKE peer name, a string of 1 to 32 characters.
# Configure a reference to an IKE peer in an IPsec policy.
[Sysname] ipsec policy policy1 10 isakmp
[Sysname-ipsec-policy-isakmp-policy1-10] ike-peer peer1
ipsec policy
Use ipsec anti-replay check to enable IPsec anti-replay checking.
Use undo ipsec anti-replay check to disable IPsec anti-replay checking.
2: System level
# Enable IPsec anti-replay checking.
[Sysname] ipsec anti-replay check
Use ipsec anti-replay window to set the size of the anti-replay window.
Use undo ipsec anti-replay window to restore the default.
ipsec anti-replay window width
The size of the anti-replay window is 32.
2: System level
width: Size of the anti-replay window. It can be 32, 64, 128, 256, 512, or 1024.
Your configuration affects only IPsec SAs negotiated later.
# Set the size of the anti-replay window to 64.
[Sysname] ipsec anti-replay window 64
Use ipsec invalid-spi-recovery enable to enable invalid security parameter index (SPI) recovery.
Use undo ipsec invalid-spi-recovery enable to restore the default.
The invalid SPI recovery is disabled. The receiver discards IPsec packets with invalid SPIs.
2: System level
Invalid SPI recovery enables an IPsec security gateway to send an INVALID SPI NOTIFY message to its peer when it receives an IPsec packet but cannot find any SA with the specified SPI. When the peer receives the message, it deletes the SAs on its side. Then, subsequent traffic triggers the two peers to establish new SAs.
# Enable invalid SPI recovery.
[Sysname] ipsec invalid-spi-recovery enable
Use ipsec policy to apply an IPsec policy group to an interface.
Use undo ipsec policy to remove the application.
ipsec policy policy-name
undo ipsec policy [ policy-name ]
Interface view
2: System level
policy-name: Specifies the name of the existing IPsec policy group to be applied to the interface, a string of 1 to 15 characters.
Only one IPsec policy group can be applied to an interface. To apply another IPsec policy group to the interface, remove the original application first. An IPsec policy group can be applied to more than one interface.
With an IPsec policy group applied to an interface, the system uses each IPsec policy in the group to protect certain data flows.
For each packet to be sent out an IPsec protected interface, the system checks the IPsec policies of the IPsec policy group in the ascending order of sequence numbers. If it finds an IPsec policy whose ACL matches the packet, it uses the IPsec policy to protect the packet. If it finds no ACL of the IPsec policies matches the packet, it does not provide IPsec protection for the packet and sends the packet out directly.
# Apply IPsec policy group pg1 to interface VLAN-interface 3.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] ipsec policy pg1
Use ipsec policy to create an IPsec policy and enter its view.
Use undo ipsec policy to delete the specified IPsec policies.
ipsec policy policy-name seq-number isakmp
undo ipsec policy policy-name [ seq-number ]
No IPsec policy exists.
2: System level
policy-name: Specifies the name for the IPsec policy, a case-insensitive string of 1 to 15 characters. No hyphen (-) can be included.
seq-number: Specifies the sequence number for the IPsec policy, in the range of 1 to 65535.
isakmp: Sets up SAs through IKE negotiation.
When creating an IPsec policy, you must specify the generation mode.
You cannot change the generation mode of an existing IPsec policy; you can only delete the policy and then re-create it with the new mode.
IPsec policies with the same name constitute an IPsec policy group. An IPsec policy is identified uniquely by its name and sequence number. In an IPsec policy group, an IPsec policy with a smaller sequence number has a higher priority.
The undo ipsec policy command without the seq-number argument deletes an IPsec policy group.
# Create an IPsec policy with the name policy1 and sequence number 100, and specify to set up SAs through IKE negotiation.
[Sysname] ipsec policy policy1 100 isakmp
[Sysname-ipsec-policy-isakmp-policy1-100]
·     ipsec policy (interface view)
·     display ipsec policy
Use ipsec policy isakmp template to create an IPsec policy by referencing an existing IPsec policy template, so that IKE can use the IPsec policy for SA negotiation.
Use undo ipsec policy with the seq-number argument to delete an IPsec policy.
Use undo ipsec policy without the seq-number argument to delete an IPsec policy group.
ipsec policy policy-name seq-number isakmp template template-name
2: System level
isakmp template template-name: Name of the IPsec policy template to be referenced.
After you create an IPsec policy by referencing an IPsec policy template, to modify the configuration for the IPsec policy, you must enter the IPsec policy template view instead of the IPsec policy view.
You cannot change the negotiation mode of an IPsec policy. To do so, you must delete the IPsec policy and then re-create it.
# Create an IPsec policy with the name policy2 and sequence number 200 by referencing IPsec policy template temp1.
[Sysname] ipsec policy policy2 200 isakmp template temp1
·     ipsec policy (system view)
·     ipsec policy-template
Use ipsec policy-template to create an IPsec policy template and enter the IPsec policy template view.
Use undo ipsec policy-template to delete the specified IPsec policy templates.
ipsec policy-template template-name seq-number
undo ipsec policy-template template-name [ seq-number ]
No IPsec policy template exists.
2: System level
template-name: Specifies the name for the IPsec policy template, a case-insensitive string of 1 to 41 characters. No hyphen (-) can be included.
seq-number: Specifies the sequence number for the IPsec policy template, in the range of 1 to 65535.
Using the undo command without the seq-number argument deletes an IPsec policy template group.
In an IPsec policy template group, an IPsec policy template with a smaller sequence number has a higher priority.
# Create an IPsec policy template with the name template1 and the sequence number 100.
[Sysname] ipsec policy-template template1 100
[Sysname-ipsec-policy-template-template1-100]
display ipsec policy template
Use ipsec sa global-duration to configure the global SA lifetime.
Use undo ipsec sa global-duration to restore the default.
ipsec sa global-duration { time-based seconds | traffic-based kilobytes }
undo ipsec sa global-duration { time-based | traffic-based }
The time-based global SA lifetime is 3600 seconds, and the traffic-based global SA lifetime is 1843200 kilobytes.
2: System level
seconds: Specifies the time-based global SA lifetime in seconds, in the range of 180 to 604800.
kilobytes: Specifies the traffic-based global SA lifetime in kilobytes, in the range of 2560 to 4294967295.
When negotiating to set up an SA, IKE prefers the lifetime of the IPsec policy that it uses. If the IPsec policy is not configured with its own lifetime, IKE uses the global SA lifetime.
When negotiating to set up an SA, IKE prefers the shorter one of the local lifetime and that proposed by the remote.
You can configure both a time-based and a traffic-based global SA lifetime. An SA is aged out when it has existed for the specified time period or has processed the specified volume of traffic.
# Set the time-based global SA lifetime to 7200 seconds (2 hours).
[Sysname] ipsec sa global-duration time-based 7200
# Set the traffic-based global SA lifetime to 10240 kilobytes (10 Mbytes).
[Sysname] ipsec sa global-duration traffic-based 10240
·     sa duration
·     display ipsec sa duration
ipsec transform-set
Use ipsec transform-set to create an IPsec transform set and enter IPsec transform set view.
Use undo ipsec transform-set to delete an IPsec transform set.
ipsec transform-set transform-set-name
undo ipsec transform-set transform-set-name
No IPsec transform set exists.
2: System level
transform-set-name: Specifies the name of an IPsec transform set, a case-insensitive string of 1 to 32 characters.
# Create an IPsec transform set named tran1 and enter its view.
Use ipsec synchronization enable to enable IPsec stateful failover.
Use undo ipsec synchronization enable to disable IPsec stateful failover.
IPsec stateful failover is enabled.
2: System level
You enable IPsec stateful failover typically on two redundant gateways in active/standby mode to ensure instant IPsec tunnel failover for nonstop services.
Disabling IPsec stateful failover will delete all active or standby IPsec SAs and IKE SAs.
Support for this command depends on the device model. For more information, see About the H3C Access Controllers Command References.
# Enable IPsec stateful failover.
[Sysname] ipsec synchronization enable
policy enable
Use policy enable to enable the IPsec policy.
Use undo policy enable to disable the IPsec policy.
policy enable
undo policy enable
The IPsec policy is enabled.
2: System level
If the IPsec policy is not enabled for the IKE peer, the peer cannot take part in the IKE negotiation.
# Enable the IPsec policy with the name policy1 and sequence number 100.
[Sysname-ipsec-policy-isakmp-policy1-100] policy enable
reset ipsec sa
Use reset ipsec sa to clear IPsec SAs.
reset ipsec sa [ active | parameters dest-address protocol spi | policy policy-name [ seq-number ] | remote ip-address | standby ]
2: System level
active: Specifies all active IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
parameters: Specifies IPsec SAs that use the specified destination address, security protocol, and SPI.
dest-address: Specifies the destination address, in dotted decimal notation.
protocol: Specifies the security protocol, which can be keyword ah or esp, case insensitive.
spi: Specifies the security parameter index in the range of 256 to 4294967295.
policy: Specifies IPsec SAs that use an IPsec policy.
policy-name: Specifies the name of the IPsec policy, a case-sensitive string of 1 to 15 alphanumeric characters.
seq-number: Specifies the sequence number of the IPsec policy, in the range of 1 to 65535. If no seq-number is specified, all the policies in the IPsec policy group named policy-name are specified.
remote ip-address: Specifies SAs to or from a remote address, in dotted decimal notation.
standby: Specifies all standby IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
After IKE negotiated SAs are cleared, the system sets up new SAs when IKE negotiation is triggered by interesting packets.
IPsec SAs appear in pairs. If you specify the parameters keyword to clear an IPsec SA, the IPsec SA in the other direction is also automatically cleared.
If you do not specify any parameter, the command clears all IPsec SAs.
If you specify neither active nor standby, the command clears both active and standby IPsec SAs.
When you clear the active IPsec SAs on the active device, the active device automatically notifies the standby device to clear the standby IPsec SAs.
When you clear the standby IPsec SAs on the standby device, the standby device re-synchronizes the IPsec service data with the active device to set up new standby IPsec SAs.
# Clear all IPsec SAs.
<Sysname> reset ipsec sa
# Clear the IPsec SA with a remote IP address of 10.1.1.2.
<Sysname> reset ipsec sa remote 10.1.1.2
# Clear all IPsec SAs of IPsec policy template policy1.
<Sysname> reset ipsec sa policy policy1
# Clear the IPsec SA of the IPsec policy with the name of policy1 and sequence number of 10.
<Sysname> reset ipsec sa policy policy1 10
# Clear the IPsec SA with a remote IP address of 10.1.1.2, security protocol of AH, and SPI of 10000.
<Sysname> reset ipsec sa parameters 10.1.1.2 ah 10000
display ipsec sa
Use reset ipsec statistics to clear IPsec packet statistics.
1: Monitor level
# Clear IPsec packet statistics.
<Sysname> reset ipsec statistics
sa duration
Use sa duration to set an SA lifetime for the IPsec policy.
Use undo sa duration to restore the default.
sa duration { time-based seconds | traffic-based kilobytes }
undo sa duration { time-based | traffic-based }
The SA lifetime of an IPsec policy equals the current global SA lifetime.
The time-based global SA lifetime is 3600 seconds, and traffic-based SA lifetime is 1843200 kilobytes.
2: System level
seconds: Specifies the time-based SA lifetime in seconds, in the range of 180 to 604800.
kilobytes: Specifies the traffic-based SA lifetime in kilobytes, in the range of 2560 to 4294967295.
When negotiating to set up an SA, IKE prefers the lifetime settings of the IPsec policy that it uses. If the IPsec policy or IPsec transform set is not configured with its own lifetime settings, IKE uses the global SA lifetime settings, which are configured with the ipsec sa global-duration command.
When negotiating to set up an SA, IKE prefers the shorter ones of the local lifetime settings and those proposed by the remote.
# Set the SA lifetime for IPsec policy1 to 7200 seconds (2 hours).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration time-based 7200
# Set the SA lifetime for IPsec policy policy1 to 20480 kilobytes (20 Mbytes).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration traffic-based 20480
security acl
Use security acl to specify the ACL for the IPsec policy to reference.
Use undo security acl to remove the configuration.
security acl acl-number [ aggregation | per-host ]
undo security acl
An IPsec policy references no ACL.
2: System level
acl-number: Specifies the number of the ACL for the IPsec policy to reference, in the range of 3000 to 3999.
aggregation: Specifies the data flow protection mode as aggregation. This protection mode is not applicable to IPv6 data flows. This mode is configurable only in IPsec policies that use IKE negotiation.
per-host: Specifies the data flow protection mode as per-host. This protection mode is not applicable to IPv6 data flows. This mode is configurable only in IPsec policies that use IKE negotiation.
With an IKE-dependent IPsec policy configured, data flows can be protected in the following modes:
·     Standard mode—One tunnel protects one data flow. The data flow permitted by an ACL rule is protected by one tunnel that is established solely for it.
·     Aggregation mode—One tunnel protects all data flows permitted by all the rules of an ACL.
·     Per-host mode—One tunnel protects one host-to-host data flow. One host-to-host data flow is identified by one ACL rule and protected by one tunnel established solely for it.
If you specify neither the aggregation nor the per-host mode, the standard mode is used.
To use the per-host mode, you only need to specify an ACL in per-host mode in the IPsec policy of the IPsec initiator. You do not need to specify the per-host keyword in the IPsec policy of the responder.
Use the per-host mode with caution. If the number of hosts to be protected is large, IPsec using the per-host mode will establish a large number of SAs, exhausting the system resources quickly.
When your device works with an old-version device, use the aggregation mode on both devices.
An IPsec policy references only one ACL. If you specify more than one ACL for an IPsec policy, the IPsec policy references the one last specified.
# Configure IPsec policy policy2 to reference ACL 3002, and set the data flow protection mode to aggregation.
[Sysname] acl number 3002
[Sysname-acl-adv-3002] rule 0 permit ip source 10.1.2.1 0.0.0.255 destination 10.1.2.2 0.0.0.255
[Sysname-acl-adv-3002] rule 1 permit ip source 10.1.3.1 0.0.0.255 destination 10.1.3.2 0.0.0.255
[Sysname] ipsec policy policy2 1 isakmp
[Sysname-ipsec-policy-isakmp-policy2-1] security acl 3002 aggregation
# Configure IPsec policy policy3 to reference ACL 3003, and set the data flow protection mode to per-host.
[Sysname] acl number 3003
[Sysname-acl-adv-3003] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-adv-3003] quit
[Sysname] ipsec policy policy3 10 isakmp
[Sysname-ipsec-policy-isakmp-policy3-10] security acl 3003 per-host
Use synchronization anti-replay-interval to set the inbound anti-replay window synchronization interval and the outbound anti-replay sequence number synchronization interval.
Use undo synchronization anti-replay-interval to restore the defaults.
synchronization anti-replay-interval inbound inbound-number outbound outbound-number
The inbound anti-replay window synchronization interval is 1000, and the outbound anti-replay sequence number synchronization interval is 100000.
2: System level
inbound-number: Interval at which the device, when functioning as the active device, synchronizes the inbound anti-replay window to the standby device. It is expressed in the number of received packets and in the range of 0 to 1000. If you set the argument to 0, inbound anti-replay window synchronization is disabled.
outbound-number: Interval at which the device, when functioning as the active device, synchronizes the outbound anti-replay sequence number to the standby device. It is expressed in the number of sent packets and in the range of 1000 to 100000.
In an IPsec stateful failover scenario, the active device regularly synchronizes anti-replay information to the standby device. When the active device fails, the standby device continues to provide the anti-replay service based on the synchronized anti-replay information.
A short interval improves the anti-replay information consistency between the active device and the standby device, but also increases the anti-replay information synchronization frequency and the impact on the performance of the devices.
# Set the inbound anti-replay window synchronization interval to 800 and the outbound anti-replay sequence number synchronization interval to 50000.
[Sysname] ipsec policy test 10 isakmp
[Sysname-ipsec-policy-isakmp-test-10] synchronization anti-replay-interval inbound 800 outbound 50000
·     display ipsec policy-template
transform
Use transform to specify a security protocol for an IPsec transform set.
Use undo transform to restore the default.
transform { ah | ah-esp | esp }
undo transform
The ESP protocol is used.
2: System level
ah: Uses the AH protocol.
ah-esp: Uses ESP first and then AH.
esp: Uses the ESP protocol.
The IPsec transform sets at the two ends of an IPsec tunnel must use the same security protocol.
# Configure IPsec transform set prop1 to use AH.
ipsec transform-set
transform-set
Use transform-set to specify an IPsec transform set for the IPsec policy to reference.
Use undo transform-set to remove an IPsec transform set referenced by the IPsec policy.
transform-set transform-set-name&<1-6>
undo transform-set [ transform-set-name ]
An IPsec policy references no IPsec transform set.
2: System level
transform-set-name&<1-6>: Specifies the name of the IPsec transform set, a string of 1 to 32 characters. &<1-6> means that you can specify up to six transform sets, which are separated by space.
The specified IPsec transform sets must already exist.
An IKE negotiated IPsec policy can reference up to six IPsec transform sets. The IKE negotiation process will search for and use the exactly matched transform set.
# Configure IPsec policy policy1 to reference IPsec transform set tran1.
[Sysname-ipsec-transform-set-tran1] quit
[Sysname-ipsec-policy-isakmp-policy1-100] transform-set tran1
Use authentication-algorithm to specify an authentication algorithm for an IKE proposal.
Use undo authentication-algorithm to restore the default.
authentication-algorithm { md5 | sha | sha256 }
An IKE proposal uses the SHA1 authentication algorithm in non-FIPS mode and the SHA256 authentication algorithm in FIPS mode.
IKE proposal view
2: System level
md5: Uses HMAC-MD5.
sha: Uses HMAC-SHA1.
sha256: Uses HMAC-SHA256.
In FIPS mode, MD5 is not supported.
# Set MD5 as the authentication algorithm for IKE proposal 10.
[Sysname] ike proposal 10
[Sysname-ike-proposal-10] authentication-algorithm md5
·     ike proposal
·     display ike proposal
Use authentication-method to specify an authentication method for an IKE proposal.
Use undo authentication-method to restore the default.
authentication-method { pre-share | rsa-signature }
An IKE proposal uses the pre-shared key authentication method.
IKE proposal view
2: System level
pre-share: Uses the pre-shared key method.
rsa-signature: Uses the RSA digital signature method.
# Specify that IKE proposal 10 uses the pre-shared key authentication method.
[Sysname-ike-proposal-10] authentication-method pre-share
·     ike proposal
certificate domain
Use certificate domain to configure the PKI domain of the certificate when IKE uses digital signature as the authentication mode.
Use undo certificate domain to remove the configuration.
certificate domain domain-name
IKE peer view
2: System level
domain-name: Name of the PKI domain, a string of 1 to 15 characters.
# Configure the PKI domain as abcde for IKE negotiation.
[Sysname] ike peer peer1
[Sysname-ike-peer-peer1] certificate domain abcde
·     authentication-method
·     pki domain
dh
Use dh to specify the DH group to be used in key negotiation phase 1 for an IKE proposal.
Use undo dh to restore the default.
In non-FIPS mode:
dh { group1 | group2 | group5 | group14 }
undo dh
In FIPS mode:
dh group14
undo dh
In non-FIPS node, group1, the 768-bit Diffie-Hellman group, is used. In FIPS node, group14, the 2048-bit Diffie-Hellman group, is used.
IKE proposal view
2: System level
group1: Uses the 768-bit Diffie-Hellman group for key negotiation in phase 1
group2: Uses the 1024-bit Diffie-Hellman group for key negotiation in phase 1.
group5: Uses the 1536-bit Diffie-Hellman group for key negotiation in phase 1.
group14: Uses the 2048-bit Diffie-Hellman group for key negotiation in phase 1.
# Specify 768-bit Diffie-Hellman for IKE proposal 10.
[Sysname-ike-proposal-10] dh group1
·     ike proposal
display ike dpd
Use display ike dpd to display information about Dead Peer Detection (DPD) detectors.
display ike dpd [ dpd-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
dpd-name: Specifies the DPD name, a string of 1 to 32 characters.
If you do not specify any parameters, the command displays information about all DPD detectors.
# Display information about all DPD detectors.
<Sysname> display ike dpd
 IKE dpd: dpd1
   references: 1
   interval-time: 10
   time_out: 5
Table 10 Command output
references
Number of IKE peers that use the DPD detector.
Interval-time
DPD query trigging interval in seconds.
time_out
DPD packet retransmission interval in seconds.
ike dpd
display ike peer
Use display ike peer to display information about IKE peers.
display ike peer [ peer-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
peer-name: Specifies the name of the IKE peer, a string of 1 to 32 characters.
If you do not specify any parameters, the command displays information about all IKE peers.
# Display information about all IKE peers.
<Sysname> display ike peer
 IKE Peer: rtb4tunn
   exchange mode: main on phase 1
   pre-shared-key ******
   peer id type: ip
   peer ip address: 44.44.44.55
   local ip address:
   peer name:
   nat traversal: disable
   dpd: dpd1
Table 11 Command output
exchange mode
IKE negotiation mode in phase 1.
pre-shared-key
Pre-shared key used in phase 1, displayed as ******.
peer id type
ID type used in phase 1.
peer ip address
IP address of the remote security gateway.
local ip address
IP address of the local security gateway.
peer name
Name of the remote security gateway.
nat traversal
Whether NAT traversal is enabled.
dpd
Name of the peer DPD detector.
ike peer
Use display ike proposal to view the settings of all IKE proposals.
display ike proposal [ | { begin | exclude | include } regular-expression ]
1: Monitor level
This command displays the configuration information of all IKE proposals in the descending order of proposal priorities.
# Display the settings of all IKE proposals.
<Sysname> display ike proposal
priority authentication authentication encryption Diffie-Hellman duration
              method       algorithm    algorithm     group       (seconds)
 10       PRE_SHARED     SHA            DES_CBC    MODP_1024      5000
 11       PRE_SHARED     MD5            DES_CBC    MODP_768       50000
 default  PRE_SHARED     SHA            DES_CBC    MODP_768       86400
Table 12 Command output
priority
Priority of the IKE proposal.
Authentication method used by the IKE proposal.
Authentication algorithm used by the IKE proposal.
Encryption algorithm used by the IKE proposal.
DH group used in IKE negotiation phase 1.
duration (seconds)
ISAKMP SA lifetime (in seconds) of the IKE proposal.
·     ike proposal
·     encryption-algorithm
·     authentication-algorithm
·     dh
·     sa duration
display ike sa
Use display ike sa to display information about the current IKE SAs.
display ike sa [ active | standby | verbose [ connection-id connection-id | remote-address remote-address ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
active: Displays the summary of active IKE SAs and IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
standby: Displays the summary of standby IKE SAs and IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
verbose: Displays detailed information.
connection-id connection-id: Displays detailed information about IKE SAs by connection ID in the range of 1 to 2000000000.
remote ip-address: Displays detailed information about IKE SAs with a specific remote address.
If you do not specify any parameters or keywords, the command displays brief information about the current IKE SAs.
# Display brief information about the current IKE SAs.
<Sysname> display ike sa
    total phase-1 SAs:  1
    connection-id  peer            flag        phase   doi
      1            202.38.0.2      RD|ST        1      IPSEC
      2            202.38.0.2      RD|ST        2      IPSEC
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO—TIMEOUT
Table 13 Command output
total phase-1 SAs
Total number of SAs for phase 1.
connection-id
Identifier of the ISAKMP SA.
peer
Remote IP address of the SA.
flag
Status of the SA:
·     RD (READY)—The SA has been established.
·     ST (STAYALIVE)—This end is the initiator of the tunnel negotiation.
·     RL (REPLACED)—The tunnel has been replaced by a new one and will be deleted later.
·     FD (FADING)—The soft lifetime is over but the tunnel is still in use. The tunnel will be deleted when the hard lifetime is over.
·     TO (TIMEOUT)—The SA has received no keepalive packets after the last keepalive timeout. If no keepalive packets are received before the next keepalive timeout, the SA will be deleted.
phase
The phase the SA belongs to:
·     Phase 1—The phase for establishing the ISAKMP SA.
·     Phase 2—The phase for negotiating the security service. IPsec SAs are established in this phase.
doi
Interpretation domain the SA belongs to.
# Display detailed information about the current IKE SAs.
<Sysname> display ike sa verbose
    connection id: 2
    transmitting entity: initiator
    local ip: 4.4.4.4
    local id type: IPV4_ADDR
    local id: 4.4.4.4
    remote ip: 4.4.4.5
    remote id type: IPV4_ADDR
    remote id: 4.4.4.5
    authentication-method: PRE-SHARED-KEY
    authentication-algorithm: HASH-SHA1
    encryption-algorithm: DES-CBC
    life duration(sec): 86400
    remaining key duration(sec): 86379
    exchange-mode: MAIN
# Display detailed information about the IKE SA with the connection ID of 2.
<Sysname> display ike sa verbose connection-id 2
    connection id: 2
    status: active
    local ip: 4.4.4.4
    local id: 4.4.4.4
    remote ip: 4.4.4.5
    remote id: 4.4.4.5
    remaining key duration(sec): 82480
    exchange-mode: MAIN
# Display detailed information about the IKE SA with the remote address of 4.4.4.5.
<Sysname> display ike sa verbose remote-address 4.4.4.5
    connection id: 2
    status: active
    local ip: 4.4.4.4
    local id: 4.4.4.4
    remote ip: 4.4.4.5
    remote id: 4.4.4.5
    remaining key duration(sec): 82236
    exchange-mode: MAIN
    nat traversal: NO
Table 14 Command output
connection id
transmitting entity
Entity in the IKE negotiation.
local ip
IP address of the local gateway.
local id type
Identifier type of the local gateway.
local id
Identifier of the local gateway.
remote ip
IP address of the remote gateway.
remote id type
Identifier type of the remote gateway.
remote id
Identifier of the remote security gateway.
life duration(sec)
Lifetime of the ISAKMP SA in seconds.
Remaining lifetime of the ISAKMP SA in seconds.
exchange-mode
nat traversal
Whether NAT traversal is enabled or not.
·     ike proposal
·     ike peer
dpd
Use dpd to apply a DPD detector to an IKE peer.
Use undo dpd to remove the application.
dpd dpd-name
undo dpd
No DPD detector is applied to an IKE peer.
IKE peer view
2: System level
dpd-name: Specifies the DPD detector name, a string of 1 to 32 characters.
# Apply dpd1 to IKE peer peer1.
[Sysname-ike-peer-peer1] dpd dpd1
Use encryption-algorithm to specify an encryption algorithm for an IKE proposal.
Use undo encryption-algorithm to restore the default.
encryption-algorithm { 3des-cbc | aes-cbc [ key-length ] | des-cbc }
In FIPS mode, an IKE proposal uses 128-bit AES-CBC for encryption.
In non-FIPS mode, an IKE proposal uses the 56-bit DES encryption algorithm in CBC mode.
IKE proposal view
2: System level
3des-cbc: Uses the 3DES algorithm in CBC mode as the encryption algorithm. The 3DES algorithm uses 168-bit keys for encryption. In FIPS mode, 3DES-CBC is not supported.
aes-cbc: Uses the AES algorithm in CBC mode as the encryption algorithm. The AES algorithm uses 128-bit, 192-bit, or 256-bit keys for encryption.
key-length: Key length for the AES algorithm, which can be 128, 192 or 256 bits and is defaulted to 128 bits.
des-cbc: Uses the DES algorithm in CBC mode as the encryption algorithm. The DES algorithm uses 56-bit keys for encryption. In FIPS mode, DES-CBC is not supported.
# Use 56-bit DES in CBC mode as the encryption algorithm for IKE proposal 10.
[Sysname-ike-proposal-10] encryption-algorithm des-cbc
·     ike proposal
exchange-mode
Use exchange-mode to select an IKE negotiation mode.
Use undo exchange-mode to restore the default.
exchange-mode { aggressive | main }
undo exchange-mode
Main mode is used.
IKE peer view
2: System level
aggressive: Specifies the aggressive mode.
main: Specifies the main mode.
When the user (for example, a dial-up user) at the remote end of an IPsec tunnel obtains an IP address automatically and pre-shared key authentication is used, H3C recommends setting the IKE negotiation mode to aggressive at the local end.
In FIPS mode, the aggressive mode is not supported.
# Specify that IKE negotiation operates in main mode.
[Sysname-ike-peer-peer1] exchange-mode main
id-type
id-type
Use id-type to select the type of the ID for IKE negotiation.
Use undo id-type to restore the default.
id-type { ip | name | user-fqdn }
undo id-type
The ID type is IP address.
IKE peer view
2: System level
ip: Uses an IP address as the ID during IKE negotiation.
name: Uses a name of the Fully Qualified Domain Name (FQDN) type as the ID during IKE negotiation.
user-fqdn: Uses a name of the user FQDN type as the ID during IKE negotiation.
In main mode, only the ID type of IP address can be used in IKE negotiation and SA creation. In aggressive mode, either type can be used.
If the ID type of FQDN is used, configure a name without any at sign (@) for the local security gateway, for example, foo.bar.com. If the ID type of user FQDN is used, configure a name with an at sign (@) for the local security gateway, for example, [email protected].
# Use the ID type of name during IKE negotiation.
[Sysname-ike-peer-peer1] id-type name
·     local-name
·     ike local-name
·     remote-name
·     remote-address
·     local-address
·     exchange-mode
ike dpd
Use ike dpd to create a DPD detector and enter IKE DPD view.
Use undo ike dpd to remove a DPD detector.
ike dpd dpd-name
undo ike dpd dpd-name
2: System level
dpd-name: Specifies the name for the DPD detector, a string of 1 to 32 characters.
DPD irregularly detects dead IKE peers. It works as follows:
1.     When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer.
2.     If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
3.     If the local end receives no DPD acknowledgement within the DPD packet retransmission interval, it retransmits the DPD hello.
4.     If the local end still receives no DPD acknowledgement after having made the maximum number of retransmission attempts (two by default), it considers the peer already dead, and clears the IKE SA and the IPsec SAs based on the IKE SA.
DPD enables an IKE entity to check the liveliness of its peer only when necessary. It generates less traffic than the keepalive mechanism, which exchanges messages periodically.
# Create a DPD detector named dpd2.
[Sysname] ike dpd dpd2
·     display ike dpd
·     interval-time
·     time-out
ike local-name
Use ike local-name to configure a name for the local security gateway.
Use undo ike local-name to restore the default.
ike local-name name
undo ike local-name
The device name is used as the name of the local security gateway.
2: System level
name: Specifies the name of the local security gateway for IKE negotiation, a case-sensitive string of 1 to 32 characters.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation peer uses the security gateway name as its ID to initiate IKE negotiation, and you must configure the ike local-name command in system view or the local-name command in IKE peer view on the local device. If you configure both the ike local-name command and the local-name command, the name configured by the local-name command is used.
The IKE negotiation initiator sends its security gateway name as its ID to the peer, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
# Configure the local security gateway name as app.
[Sysname] ike local-name app
·     remote-name
·     id-type
Use ike next-payload check disabled to disable the checking of the Next payload field in the last payload of an IKE message during IKE negotiation, gaining interoperation with products assigning the field a value other than zero.
Use undo ike next-payload check disabled to restore the default.
The Next payload field is checked.
2: System level
# Disable Next payload field checking for the last payload of an IKE message.
[Sysname] ike next-payload check disabled
Use ike peer to create an IKE peer and enter IKE peer view.
Use undo ike peer to delete an IKE peer.
ike peer peer-name
undo ike peer peer-name
2: System level
# Create an IKE peer named peer1 and enter IKE peer view.
ike proposal
Use ike proposal to create an IKE proposal and enter IKE proposal view.
Use undo ike proposal to delete an IKE proposal.
ike proposal proposal-number
undo ike proposal proposal-number
2: System level
proposal-number: Specifies the IKE proposal number in the range of 1 to 65535. A lower number represents a higher the priority of the IKE proposal. During IKE negotiation, a high priority IKE proposal is matched before a low priority IKE proposal.
The system provides a default IKE proposal, which has the lowest priority and uses the settings as shown in Table 15:
Table 15 Default values in non-FIPS mode and FIPS mode
Default parameter
Default value in non-FIPS mode
Default value in FIPS mode
DES-CBC
AES_CBC_128
HMAC-SHA1
SHA
Pre-shared key
Pre-shared key
DH group
MODP_768
MODP_1024
SA lifetime
86400 seconds
86400 seconds
# Create IKE proposal 10 and enter IKE proposal view.
Use ike sa keepalive-timer interval to set the ISAKMP SA keepalive interval.
Use undo ike sa keepalive-timer interval to disable the ISAKMP SA keepalive transmission function.
ike sa keepalive-timer interval seconds
No keepalive packet is sent.
2: System level
seconds: Specifies the transmission interval of ISAKMP SA keepalives in seconds, in the range of 20 to 28800.
The keepalive interval configured at the local end must be shorter than the keepalive timeout configured at the remote end.
# Set the keepalive interval to 200 seconds.
[Sysname] ike sa keepalive-timer interval 200
Use ike sa keepalive-timer timeout to set the ISAKMP SA keepalive timeout.
Use undo ike sa keepalive-timer timeout to disable the function.
ike sa keepalive-timer timeout seconds
2: System level
seconds: Specifies the ISAKMP SA keepalive timeout in seconds, in the range of 20 to 28800.
The keepalive timeout configured at the local end must be longer than the keepalive interval configured at the remote end. Since it seldom occurs that more than three consecutive packets are lost on a network, the keepalive timeout can be configured to be three times of the keepalive interval.
# Set the keepalive timeout to 20 seconds.
[Sysname] ike sa keepalive-timer timeout 20
Use ike sa nat-keepalive-timer interval to set the NAT keepalive interval.
Use undo ike sa nat-keepalive-timer interval to disable the function.
ike sa nat-keepalive-timer interval seconds
The NAT keepalive interval is 20 seconds.
2: System level
seconds: Specifies the NAT keepalive interval in seconds, in the range of 5 to 300.
# Set the NAT keepalive interval to 5 seconds.
[Sysname] ike sa nat-keepalive-timer interval 5
interval-time
Use interval-time to set the DPD query triggering interval for a DPD detector.
Use undo interval-time to restore the default.
interval-time interval-time
undo interval-time
The default DPD interval is 10 seconds.
IKE DPD view
2: System level
interval-time: Sets DPD interval in the range of 1 to 300 seconds. When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer. If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
# Set the DPD interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] interval-time 1
local
Use local to set the subnet type of the local security gateway for IKE negotiation.
Use undo local to restore the default.
local { multi-subnet | single-subnet }
undo local
The subnet is a single one.
IKE peer view
Default command level
2: System level
multi-subnet: Sets the subnet type to multiple.
single-subnet: Sets the subnet type to single.
Use this command to enable interoperability with a NetScreen device.
# Set the subnet type of the local security gateway to multiple.
[Sysname] ike peer xhy
[Sysname-ike-peer-xhy] local multi-subnet
local-address
Use local-address to configure the IP address of the local security gateway in IKE negotiation.
Use undo local-address to remove the configuration.
local-address ip-address
undo local-address
The primary address of the interface referencing the IPsec policy is used as the local security gateway IP address for IKE negotiation. Use this command if you want to specify a different address for the local security gateway.
IKE peer view
2: System level
ip-address: Specifies the IP address of the local security gateway to be used in IKE negotiation.
# Set the IP address of the local security gateway to 1.1.1.1.
[Sysname-ike-peer-xhy] local-address 1.1.1.1
local-name
Use local-name to configure a name for the local security gateway to be used in IKE negation.
Use undo local-name to restore the default.
local-name name
undo local-name
The device name is used as the name of the local security gateway view.
IKE peer view
2: System level
name: Specifies the name for the local security gateway to be used in IKE negotiation, a case-sensitive string of 1 to 32 characters.
# Set the name of the local security gateway to localgw in IKE peer view of peer1.
[Sysname-ike-peer-peer1] local-name localgw
·     remote-name
·     id-type
nat traversal
Use nat traversal to enable the NAT traversal function of IKE/IPsec.
Use undo nat traversal to disable the NAT traversal function of IKE/IPsec.
nat traversal
undo nat traversal
The NAT traversal function is disabled.
IKE peer view
2: System level
# Enable the NAT traversal function for IKE peer peer1.
[Sysname-ike-peer-peer1] nat traversal
peer
Use peer to set the subnet type of the peer security gateway for IKE negotiation.
Use undo peer to restore the default.
peer { multi-subnet | single-subnet }
undo peer
IKE peer view
2: System level
# Set the subnet type of the peer security gateway to multiple.
[Sysname-ike-peer-xhy] peer multi-subnet
pre-shared-key
Use pre-shared-key to configure the pre-shared key to be used in IKE negotiation.
Use undo pre-shared-key to remove the configuration.
pre-shared-key [ [ cipher | simple ] key ]
undo pre-shared-key
IKE peer view
2: System level
cipher: Sets a ciphertext pre-shared key.
simple: Sets a plaintext pre-shared key.
key: Specifies the key string. This argument is case sensitive. If cipher is specified, it must be a ciphertext string of 1 to 201 characters. If simple is specified, it must be a string of 1 to 128 characters. If neither cipher nor simple is specified, you configure a plaintext pre-shared key.
If you do not specify any of the parameters, you configure a plaintext pre-shared key in interactive mode. The interactive mode requires you to enter the same plaintext string twice to set the pre-shared key.
In FIPS mode, the simple keyword is not supported. You can configure a ciphertext pre-shared key by using the cipher key option or a plaintext pre-shared key in interactive mode. The key must contain at least eight characters comprising digits, uppercase and lowercase letters, and special characters.
In non-FIPS mode, the interactive mode is not supported. You can configure a ciphertext pre-shared key by using the cipher key option or a plaintext pre-shared key by using the simple key option. You can also directly specify a plaintext pre-shared key without the simple and cipher keywords.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
# Set the pre-shared key used in IKE negotiation to plaintext string abcde.
[Sysname-ike-peer-peer1] pre-shared-key simple abcde
# Set the pre-shared key used in IKE negotiation to 123Abc!@# in interactive mode.
Enter pre-share-key: *********
Re-enter pre-share-key: *********
proposal
Use proposal to specify the IKE proposals for the IKE peer to reference.
Use undo proposal to remove one or all IKE proposals referenced by the IKE peer.
proposal proposal-number&<1-6>
undo proposal [ proposal-number ]
An IKE peer references no IKE proposals and, when initiating IKE negotiation, it uses the IKE proposals configured in system view.
IKE peer view
2: System level
proposal-number&<1-6>: Specifies the sequence number of the IKE proposal for the IKE peer to reference, in the range of 1 to 65535. &<1-6> means that you can specify the proposal-number argument for up to six times. An IKE proposal with a smaller sequence number has a higher priority.
In the IKE negotiation phase 1, the local end uses the IKE proposals specified for it, if any.
An IKE peer can reference up to six IKE proposals.
The responder uses the IKE proposals configured in system view for negotiation.
# Configure IKE peer peer1 to reference IKE proposal 10.
[Sysname-ike-peer-peer1] proposal 10
·     ike proposal
·     ike peer (system view)
remote-address
Use remote-address to configure the IP address of the IPsec remote security gateway.
Use undo remote-address to remove the configuration.
remote-address { hostname [ dynamic ] | low-ip-address [ high-ip-address ] }
undo remote-address
IKE peer view
2: System level
hostname: Specifies the host name of the IPsec remote security gateway, a case-insensitive string of 1 to 255 characters. The host name uniquely identifies the remote IPsec peer and can be resolved to an IP address by the DNS server.
dynamic: Specifies to use dynamic address resolution for the IPsec remote peer name. If you do not provide this keyword, the local end has the remote host name resolved only once after you configure the remote host name.
low-ip-address: Specifies the IP address of the IPsec remote security gateway. It is the lowest address in the address range if you want to specify a range of addresses.
high-ip-address: Specifies the highest address in the address range if you want to specify a range of addresses.
The IP address configured with the remote-address command must match the local security gateway IP address that the remote security gateway uses for IKE negotiation, which is the IP address configured with the local-address command or, if the local-address command is not configured, the primary IP address of the interface to which the policy is applied.
The local end can be the initiator of IKE negotiation if the remote address is a host IP address or a host name. The local end can only be the responder of IKE negotiation if the remote address is an address range that the local end can respond to.
If the IP address of the remote address changes frequently, configure the host name of the remote gateway with the dynamic keyword so that the local end can use the up-to-date remote IP address to initiate IKE negotiation.
# Configure the IP address of the remote security gateway as 10.0.0.1.
[Sysname-ike-peer-peer1] remote-address 10.0.0.1
# Configure the host name of the remote gateway as test.com, and specify the local end to dynamically update the remote IP address.
[Sysname] ike peer peer2
[Sysname-ike-peer-peer2] remote-address test.com dynamic
·     id-type ip
·     local-address
remote-name
Use remote-name to configure the name of the remote gateway.
Use undo remote-name to remove the configuration.
remote-name name
undo remote-name
IKE peer view
2: System level
name: Specifies the name of the peer security gateway for IKE negotiation, a string of 1 to 32 characters.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation initiator sends its security gateway name as its ID for IKE negotiation, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
# Configure the remote security gateway name as apple for IKE peer peer1.
[Sysname-ike-peer-peer1] remote-name apple
·     id-type
·     local-name
·     ike local-name
reset ike sa
Use reset ike sa to clear IKE SAs.
reset ike sa [ connection-id | active | standby ]
2: System level
connection-id: Specifies the connection ID of the IKE SA to be cleared, in the range of 1 to 2000000000.
active: Clears all active IKE SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
standby: Clears all standby IKE SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
If you do not specify any parameter, the command clears all ISAKMP SAs.
When you clear a local IPsec SA, its ISAKMP SA can transmit the Delete message to notify the remote end to delete the paired IPsec SA. If the ISAKMP SA has been cleared, the local end cannot notify the remote end to clear the paired IPsec SA, and you must manually clear the remote IPsec SA.
# Clear the IKE SA that uses connection ID 2.
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO--TIMEOUT
<Sysname> reset ike sa 2
flag meaning
display ike sa
sa duration
Use sa duration to set the ISAKMP SA lifetime for an IKE proposal.
sa duration seconds
undo sa duration
The ISAKMP SA lifetime is 86400 seconds.
IKE proposal view
2: System level
seconds: Specifies the ISAKMP SA lifetime in seconds, in the range of 60 to 604800.
Before an SA expires, IKE negotiates a new SA. The new SA takes effect immediately after being set up, and the old one will be cleared automatically when it expires.
# Specify the ISAKMP SA lifetime for IKE proposal 10 as 600 seconds (10 minutes).
[Sysname-ike-proposal-10] sa duration 600
·     ike proposal
time-out
Use time-out to set the DPD packet retransmission interval for a DPD detector.
Use undo time-out to restore the default.
time-out time-out
undo time-out
IKE DPD view
2: System level
time-out: Specifies the DPD packet retransmission interval in seconds, in the range of 1 to 60.
The default DPD packet retransmission interval is 5 seconds.
# Set the DPD packet retransmission interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] time-out 1
