07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
14-ARP Attack Protection Commands
14-ARP Attack Protection Commands 91.93 KB
ARP attack protection configuration commands
IP flood protection configuration commands
arp resolving-route enable
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable ARP blackhole routing.
ARP blackhole routing is enabled.
Default command level
2: System level
Support for this command depends on the device model. For more information, see About the H3C Access Controllers Command References.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
arp source-suppression enable
Use arp source-suppression enable to enable the ARP source suppression feature.
Use undo arp source-suppression enable to disable the ARP source suppression feature.
The ARP source suppression feature is disabled.
2: System level
# Enable the ARP source suppression feature.
[Sysname] arp source-suppression enable
display arp source-suppression
arp source-suppression limit
Use arp source-suppression limit to set the maximum number of unresolvable IP packets that can be received from a device in 5 seconds. Unresolvable IP packets refer to packets that cannot be resolved by ARP.
Use undo arp source-suppression limit to restore the default value, which is 10.
2: System level
limit-value: Sets the maximum number of unresolvable packets that can be received from a host in 5 seconds. The value range is 2 to 1024.
If the number of unresolvable packets from a host within 5 seconds exceeds the specified threshold, the device stops resolving packets from the host until the 5 seconds elapse.
# Allow the device to receive a maximum of 100 unresolvable packets from a host in 5 seconds.
[Sysname] arp source-suppression limit 100
Use display arp source-suppression to display information about the current ARP source suppression configuration.
display arp source-suppression [ | { begin | exclude | include } regular-expression ]
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
 Current cache length: 16
Maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in 5 seconds.
Size of cache used to record source suppression information.
ARP packet rate limit configuration commands
arp rate-limit
Use arp rate-limit to configure or disable ARP packet rate limit on an interface.
Use undo arp rate-limit to restore the default.
arp rate-limit { disable | rate pps drop }
undo arp rate-limit
ARP packet rate limit is disabled.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, WLAN-ESS interface view
2: System level
disable: Disables ARP packet rate limit.
rate pps: Specifies the upper limit for ARP packet rate in pps, in the range of 5 to 3072.
drop: Discards the exceeded packets.
# Set the maximum ARP packet rate to 50 pps on GigabitEthernet 1/0/1, and configure the interface to discard exceeded packets.
[Sysname-GigabitEthernet1/0/1] arp rate-limit rate 50 drop
Source MAC-based ARP attack detection configuration commands
arp anti-attack source-mac
Use arp anti-attack source-mac to enable the source MAC-based ARP attack detection feature and specify a handling method.
Use undo arp anti-attack source-mac to restore the default.
arp anti-attack source-mac { filter | monitor }
undo arp anti-attack source-mac [ filter | monitor ]
Source MAC-based ARP attack detection is disabled.
2: System level
filter: Generates log messages and discards subsequent ARP packets from the MAC address.
monitor: Only generates log messages.
This feature enables the device to check the source MAC address of ARP packets received from the same MAC address within 5 seconds against a specific threshold. If the threshold is exceeded, the device takes the preconfigured method to handle the attack.
If neither the filter nor the monitor keyword is specified in the undo arp anti-attack source-mac command, both handling methods are disabled.
# Enable the source MAC-based ARP attack detection and specify the filter handling method.
[Sysname] arp anti-attack source-mac filter
arp anti-attack source-mac aging-time
Use arp anti-attack source-mac aging-time to set the aging time for source MAC-based ARP attack detection entries.
Use undo arp anti-attack source-mac aging-time to restore the default.
arp anti-attack source-mac aging-time time
The aging time for ARP attack entries is 300 seconds (5 minutes).
2: System level
time: Specifies the aging time for ARP attack entries, in the range of 60 to 6000 seconds.
# Set the aging time to 60 seconds for ARP attack entries.
[Sysname] arp anti-attack source-mac aging-time 60
arp anti-attack source-mac exclude-mac
Use arp anti-attack source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ARP attack detection.
Use undo arp anti-attack source-mac exclude-mac to remove the specified MAC addresses.
arp anti-attack source-mac exclude-mac mac-address&<1-10>
undo arp anti-attack source-mac exclude-mac [ mac-address&<1-10> ]
No MAC address is excluded from source MAC-based ARP attack detection.
2: System level
mac-address&<1-10>: Specifies the MAC address list. The mac-address argument indicates an excluded MAC address in the format H-H-H. &<1-10> indicates the number of MAC addresses that you can exclude.
If you do not specify any MAC address in the undo arp anti-attack source-mac exclude-mac command, this command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ARP attack detection.
[Sysname] arp anti-attack source-mac exclude-mac 2-2-2
arp anti-attack source-mac threshold
Use arp anti-attack source-mac threshold to set the threshold for source MAC-based ARP attack detection. If the number of ARP packets from a MAC address within 5 seconds exceeds this threshold, the device recognizes this as an attack.
Use undo arp anti-attack source-mac threshold to restore the default.
arp anti-attack source-mac threshold threshold-value
The threshold for source MAC-based ARP attack detection is 50.
2: System level
threshold-value: Specifies the threshold for source MAC-based ARP attack detection, in the range of 10 to 100.
# Set the threshold to 30 for source MAC-based ARP attack detection.
[Sysname] arp anti-attack source-mac threshold 30
display arp anti-attack source-mac
Use display arp anti-attack source-mac to display ARP attack entries detected by source MAC-based ARP attack detection.
display arp anti-attack source-mac [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays ARP attack entries detected on the interface.
If you do not specify any interface, the display arp anti-attack source-mac command displays ARP attack entries detected on all interfaces.
# Display ARP attack entries detected by source MAC-based ARP attack detection.
<Sysname> display arp anti-attack source-mac
Source-MAC          VLAN ID           Interface             Aging-time
23f3-1122-3344      4094              GE1/0/1               10
23f3-1122-3355      4094              GE1/0/2               30
ARP packet source MAC consistency check configuration commands
arp anti-attack valid-ack enable
Use arp anti-attack valid-check enable to enable ARP packet source MAC address consistency check on the gateway.
Use undo arp anti-attack valid-check enable to restore the default.
ARP packet source MAC address consistency check is disabled.
2: System level
After you execute the arp anti-attack valid-check enable command, the gateway device can filter out ARP packets with the source MAC address in the Ethernet header different from the sender MAC address in the ARP message.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp anti-attack valid-check enable
ARP active acknowledgement configuration commands
arp anti-attack active-ack enable
Use arp anti-attack active-ack enable to enable the ARP active acknowledgement feature.
Use undo arp anti-attack active-ack enable to restore the default.
The ARP active acknowledgement feature is disabled.
2: System level
This feature is configured on gateway devices to identify invalid ARP packets.
# Enable the ARP active acknowledgement feature.
[Sysname] arp anti-attack active-ack enable
Authorized ARP configuration commands
This feature is supported only on VLAN interfaces.
arp authorized enable
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to restore the default.
Authorized ARP is not enabled on the interface.
VLAN interface view
2: System level
# Enable authorized ARP on VLAN-interface 2.
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] arp authorized enable
ARP detection configuration commands
arp detection
Use arp detection to configure a user validity check rule.
Use undo arp detection to restore the default.
arp detection id-number { deny | permit } ip { any | ip-address [ ip-address-mask ] } mac { any | mac-address [ mac-address-mask ] } [ vlan vlan-id ]
undo arp detection id-number
No user validity check rule is specified.
2: System level
id-number: Specifies the sequence number of the user validity check rule, in the range of 0 to 511. The smaller the value, the higher the priority.
deny: Denies the matching ARP packets.
permit: Permits the matching ARP packets.
ip { any | ip-address [ ip-address-mask ] }: Specifies the sender IP address range.
·     any: Matches any sender IP address.
·     ip-address: Matches a sender IP address.
·     ip-address-mask: Specifies the mask for the sender IP address in dotted decimal format. If no mask is specified, the ip-address argument specifies a host IP address.
mac { any | mac-address [ mac-address-mask ] }: Specifies the sender MAC address range.
·     any: Matches any sender MAC address.
·     mac-address: Matches a sender MAC address, in the format of H-H-H.
·     mac-address-mask: Specifies the mask for the sender MAC address, in the format of H-H-H.
·     vlan vlan-id: Specifies the ID of a VLAN where this rule applies, in the range of 1 to 4094.
Upon receiving an ARP packet, user validity check first compares the sender IP and MAC addresses of the ARP packet against user validity check rules. If a matching rule is found, the ARP packet is processed according to the rule. If no matching rule is found, the device compares the ARP packet's sender IP and MAC addresses against the DHCP snooping entries and 802.1X security entries.
# Configure a user validity check rule, and enable user validity check.
[Sysname] arp detection 0 permit ip 10.1.1.1 255.255.0.0 mac 0001-0203-0607 ffff-ffff-0000
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
Use arp detection enable to enable ARP detection.
Use undo arp detection enable to restore the default.
ARP detection is disabled.
VLAN view
2: System level
# Enable ARP detection for VLAN 2.
[Sysname] vlan 2
[Sysname-Vlan2] arp detection enable
arp detection trust
Use arp detection trust to configure the port as an ARP trusted port.
Use undo arp detection trust to restore the default.
arp detection trust
The port is an ARP untrusted port.
2: System level
# Configure GigabitEthernet 1/0/1 as an ARP trusted port.
[Sysname-GigabitEthernet1/0/1] arp detection trust
arp detection validate
Use arp detection validate to enable ARP packet validity check. You can specify one or more objects to be checked in one command line.
Use undo arp detection validate to disable ARP packet validity check. If you do not specify any keyword, this command deletes all objects.
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP packet validity check is disabled.
2: System level
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the source and destination IP addresses of ARP packets. The all-zero, all-one, or multicast IP addresses are considered invalid and the corresponding packets are discarded. With this keyword specified, the source and destination IP addresses of ARP replies, and the source IP address of ARP requests are checked.
src-mac: Checks whether the sender MAC address of an ARP packet is identical to the source MAC address in the Ethernet header. If they are identical, the packet is considered valid. Otherwise, the packet is discarded.
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac src-mac ip
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
ARP restricted forwarding is disabled.
VLAN view
2: System level
# Enable ARP restricted forwarding in VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] arp restricted-forwarding enable
display arp detection
Use display arp detection to display the VLANs enabled with ARP detection.
display arp detection [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the VLANs enabled with ARP detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1, 2, 4-5
display arp detection statistics
Use display arp detection statistics to display statistics about ARP detection. This command only displays numbers of discarded packets. If you do not specify any interface, this command displays the statistics of all interfaces.
display arp detection statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays the ARP detection statistics of an interface.
# Display the ARP detection statistics of all interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted  T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State)          IP         Src-MAC    Dst-MAC    Inspect
GE1/0/1(U)                40         0          0          78
GE1/0/2(U)                0          0          0          0
Interface(State)
State T or U identifies a trusted or untrusted port.
IP
Number of ARP packets discarded due to invalid source and destination IP addresses.
Src-MAC
Number of ARP packets discarded due to invalid source MAC address.
Dst-MAC
Number of ARP packets discarded due to invalid destination MAC address.
Inspect
Number of ARP packets that failed to pass ARP detection (based on static DHCP snooping entries and 802.1X security entries).
reset arp detection statistics
Use reset arp detection statistics to clear ARP detection statistics of an interface. If you do not specify any interface, this command clears the statistics of all interfaces.
reset arp detection statistics [ interface interface-type interface-number ]
1: Monitor level
interface interface-type interface-number: Clears the ARP detection statistics of an interface.
# Clear the ARP detection statistics of all interfaces.
<Sysname> reset arp detection statistics
ARP gateway protection configuration commands
arp filter source
Use arp filter source to enable ARP gateway protection for a gateway.
Use undo arp filter source to disable ARP gateway protection for a gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
2: System level
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for up to eight gateways on a port.
You cannot configure both arp filter source and arp filter binding commands on a port.
# Enable ARP gateway protection for the gateway at 1.1.1.1.
[Sysname] interface wlan-ess 1
[Sysname-WLAN-ESS1] arp filter source 1.1.1.1
ARP filtering configuration commands
arp filter binding
Use arp filter binding to configure an ARP filtering entry. If the sender IP and MAC addresses of an ARP packet match an ARP filtering entry, the ARP packet is permitted. If not, it is discarded.
Use undo arp filter binding to remove an ARP filtering entry.
undo arp filter binding ip-address
No ARP filtering entry is configured.
2: System level
ip-address: Specifies a permitted sender IP address.
mac-address: Specifies a permitted sender MAC address.
You can configure up to eight ARP filtering entries on a port.
# Configure an ARP filtering entry with permitted sender IP address 1.1.1.1 and MAC address 2-2-2.
[Sysname-WLAN-ESS1] arp filter binding 1.1.1.1 2-2-2
