- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH Commands
- 11-SSL Commands
- 12-SSL VPN Commands
- 13-TCP Attack Protection Commands
- 14-ARP Attack Protection Commands
- 15-IPsec Commands
- 16-ALG Commands
- 17-Firewall Commands
- 18-Session Management Commands
- 19-Web Filtering Commands
- 20-User Isolation Commands
- 21-Source IP Address Verification Commands
- 22-FIPS Commands
- 23-Protocol Packet Rate Limit Commands
- 24-Attack detection and protection commands
| 19-Web Filtering Commands | 113.61 KB |
Web filtering configuration commands
display firewall http activex-blocking
display firewall http java-blocking
display firewall http url-filter host
display firewall http url-filter parameter
firewall http activex-blocking acl
firewall http activex-blocking enable
firewall http activex-blocking suffix
firewall http java-blocking acl
firewall http java-blocking enable
firewall http java-blocking suffix
firewall http url-filter host acl
firewall http url-filter host default
firewall http url-filter host enable
firewall http url-filter host ip-address
firewall http url-filter host url-address
firewall http url-filter parameter enable
Support for the commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
Use display firewall http activex-blocking to display information about ActiveX blocking.
display firewall http activex-blocking [ all | item keywords | verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
all: Specifies all ActiveX blocking suffix keywords.
item keywords: Specifies a blocking suffix keyword. It is a case-insensitive string of 1 to 9 characters. Its starting character must be a dot (.) and the subsequent characters must be digits or English letters.
verbose: Specifies detailed information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not specify any parameters, this command displays brief information about ActiveX blocking.
# Display brief information about ActiveX blocking.
<Sysname> display firewall http activex-blocking
ActiveX blocking is enabled.
# Display ActiveX blocking information for a specific suffix keyword.
<Sysname> display firewall http activex-blocking item .ocx
The HTTP request packet including ".ocx" had been matched for 5 times.
# Display ActiveX blocking information for all suffix keywords.
<Sysname> display firewall http activex-blocking all
SN Match-Times Keywords
1 5 .OCX
2 0 .vbs
SN |
Serial number. |
Match-Times |
Number of times that a suffix keyword is matched. |
Keywords |
ActiveX blocking suffix keyword. |
# Display detailed ActiveX blocking information.
<Sysname> display firewall http activex-blocking verbose
No ACL group has been configured.
There are 5 packet(s) being filtered.
There are 0 packet(s) being passed.
Use display firewall http java-blocking to display information about Java blocking.
display firewall http java-blocking [ all | item keywords | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all Java blocking suffix keywords.
If you do not specify any parameters, this command displays brief information about Java blocking.
# Display brief information about Java blocking.
<Sysname> display firewall http java-blocking
Java blocking is enabled.
# Display Java blocking information for a specific suffix keyword.
<Sysname> display firewall http java-blocking item .class
The HTTP request packet including ".class" had been matched for 10 times.
# Display Java blocking information for all suffix keywords.
<Sysname> display firewall http java-blocking all
1 10 .CLASS
2 0 .JAR
3 0 .java
SN |
Serial number. |
Match-Times |
Number of times that the suffix keyword has been matched. |
Keywords |
Java blocking suffix keyword. |
# Display detailed information about Java blocking.
<Sysname> display firewall http java-blocking verbose
There are 10 packet(s) being filtered.
Use display firewall http url-filter host to display information about URL address filtering.
display firewall http url-filter host [ all | item keywords | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all URL filtering keywords.
item keywords: Specifies a filtering keyword, The keywords argument is a case-insensitive string of 1 to 80 characters. Valid characters include 0 to 9, a to z, A to Z, dot (.), hyphen (-), underline (_), and wildcards caret (^), dollar sign ($), ampersand (&), and asterisk (*). For meanings and usage guidelines of the wildcards, see the relevant description for command firewall http url-filter host url-address.
If you do not specify any parameters, this command displays brief information about URL address filtering.
# Display brief information about URL address filtering.
<Sysname> display firewall http url-filter host
URL-filter host is enabled.
Default method: permit.
# Display URL address filtering information for a specific filtering entry.
<Sysname> display firewall http url-filter host item ^webfilter$
The HTTP request packet including "^webfilter$" had been matched for 10 times.
# Display URL address filtering information for all filtering entries.
<Sysname> display firewall http url-filter host all
1 10 ^webfilter$
SN |
Serial number. |
Match-Times |
Number of times that the keyword has been matched. |
Keywords |
URL address filtering keyword. |
# Display detailed information about URL address filtering.
<Sysname> display firewall http url-filter host verbose
The support for IP address: deny.
Default method |
Default URL address filtering action, which can be permit or deny. |
The support for IP address |
Support for website IP addresses, permit or deny. |
Use display firewall http url-filter parameter to display information about URL parameter filtering.
display firewall http url-filter parameter [ all | item keywords | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Specifies all filtering keywords.
item keywords: Specifies a filtering keyword. The keywords argument is a case-insensitive string of 1 to 80 characters. Valid characters include numerals, English letters, wildcards caret (^), dollar sign ($), ampersand (&), and asterisk (*), and other ASCII characters with values in the range of 31 to 127.
If you do not specify any parameters, this command displays brief information about URL parameter filtering.
# Display brief information about URL parameter filtering.
<Sysname> display firewall http url-filter parameter
URL-filter parameter is enabled.
# Display URL parameter filtering information for a specific keyword.
<Sysname> display firewall http url-filter parameter item ^select$
The HTTP request packet including "^select$" had been matched for 10 times.
# Display URL parameter filtering information for all keywords.
<Sysname> display firewall http url-filter parameter all
1 0 ^select$
2 0 ^insert$
3 0 ^update$
4 0 ^delete$
5 0 ^drop$
6 0 --
7 0 ‘
8 0 ^exec$
9 10 %27
10 0 qqqqq
Table 5 Command output
SN |
Serial number. |
Match-Times |
Keywords |
URL parameter filtering keyword. |
# Display detailed information about URL parameter filtering.
<Sysname> display firewall http url-filter parameter verbose
Use firewall http activex-blocking acl to specify an ACL for ActiveX blocking.
Use undo firewall http activex-blocking acl to cancel the configuration.
firewall http activex-blocking acl acl-number
No ACL is specified for ActiveX blocking.
2: System level
acl-number: Specifies an ACL number in the range of 2000 to 3999.
After the command takes effect, all Web requests containing any suffix keywords in the ActiveX blocking suffix list will be processed according to the ACL.
You can specify multiple ACLs for ActiveX blocking, but only the last one takes effect.
You can specify a non-existing ACL, but ActiveX blocking based on the ACL takes effect only after you create and configure the ACL correctly.
# Specify the ACL for ActiveX blocking as ACL 2003.
[Sysname] firewall http activex-blocking acl 2003
Use firewall http activex-blocking enable to enable the ActiveX blocking function and add the default blocking keyword .ocx to the ActiveX blocking suffix list.
Use undo firewall http activex-blocking enable to disable the ActiveX blocking function.
The ActiveX blocking function is disabled.
2: System level
# Enable the ActiveX blocking function.
[Sysname] firewall http activex-blocking enable
Use firewall http activex-blocking suffix to add an ActiveX blocking suffix keyword to the ActiveX blocking suffix list.
Use undo firewall http activex-blocking suffix to remove an ActiveX blocking suffix keyword from the ActiveX blocking suffix list.
firewall http activex-blocking suffix keywords
undo firewall http activex-blocking suffix keywords
2: System level
keywords: Specifies the blocking suffix keyword, a case-insensitive string of 1 to 9 characters. Its starting character must be a dot (.) and the subsequent characters must be digits or English letters.
You can add a maximum of 5 ActiveX blocking suffix keywords.
You cannot add or remove the default suffix keyword ".ocx" by these commands.
# Add .vbs to the ActiveX blocking suffix list.
[Sysname] firewall http activex-blocking suffix .vbs
Use firewall http java-blocking acl to specify an ACL for Java blocking.
Use undo firewall http java-blocking acl to cancel the configuration.
firewall http java-blocking acl acl-number
No ACL is specified for Java blocking.
2: System level
After the command takes effect, all Web requests containing any suffix keywords in the Java blocking suffix list will be processed according to the specified ACL.
You can specify multiple ACLs for Java blocking, but only the last one takes effect.
You can specify a non-existing ACL, but Java blocking based on the ACL takes effect only after you create and configure the ACL correctly.
# Specify the ACL for Java blocking as ACL 2002.
[Sysname] firewall http java-blocking acl 2002
Use firewall http java-blocking enable to enable the Java blocking function and add the default blocking keywords .class and .jar to the Java blocking suffix list.
Use undo firewall http java-blocking enable to disable the Java blocking function.
The Java blocking function is disabled.
2: System level
# Enable the Java blocking function.
[Sysname] firewall http java-blocking enable
Use firewall http java-blocking suffix to add a Java blocking suffix keyword to the Java blocking suffix list.
Use undo firewall http java-blocking suffix to remove a Java blocking suffix keyword from the Java blocking suffix list.
firewall http java-blocking suffix keywords
undo firewall http java-blocking suffix keywords
2: System level
You can add a maximum of five Java blocking suffix keywords.
You cannot remove the default block suffix keywords .class and .jar.
# Add .js to the Java blocking suffix list.
[Sysname] firewall http java-blocking suffix .js
Use firewall http url-filter host acl to specify an ACL for URL address filtering.
Use undo firewall http url-filter host acl to cancel the configuration.
firewall http url-filter host acl acl-number
No ACL is specified for URL address filtering.
2: System level
With the command configured, all Web requests using IP addresses will be processed according to the specified ACL.
If you specify multiple ACLs for URL address filtering, only the last one takes effect.
You can specify a non-existing ACL, but filtering based on the ACL takes effect only after you create and configure the ACL correctly.
# Specify URL address filtering to permit Web requests with website IP addresses permitted by ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule 0 permit source 3.3.3.3 0.0.0.0
[Sysname-acl-basic-2000] quit
[Sysname] firewall http url-filter host acl 2000
Use firewall http url-filter host default to specify the default action for URL address filtering, that is, action to be taken for Web requests whose URL addresses do not match the configured filtering entries.
firewall http url-filter host default { deny | permit }
The default filtering action is deny.
2: System level
deny: Denies Web requests.
permit: Permits Web requests.
# Specify the default filtering action as permit.
[Sysname] firewall http url-filter host default permit
Use firewall http url-filter host enable to enable the URL address filtering function.
Use undo firewall http url-filter host enable to disable the URL address filtering function.
The URL address filtering function is disabled.
2: System level
# Enable the URL address filtering function.
[Sysname] firewall http url-filter host enable
Use firewall http url-filter host ip-address to enable/disable support for IP address in URL address filtering, that is, to permit or deny Web requests using IP addresses for access to websites.
firewall http url-filter host ip-address { deny | permit }
The URL address filtering function denies Web requests using IP addresses for access to websites.
2: System level
deny: Specifies to deny a Web request whose destination URL is present in IP address.
permit: Specifies to permit a Web request whose destination URL is present in IP address.
This configuration takes effect only after the URL address filtering function is enabled.
# Configure to permit Web requests using IP addresses for access to websites.
[Sysname] firewall http url-filter host ip-address permit
· display firewall http url-filter host
· firewall http url-filter host enable
Use firewall http url-filter host url-address to add a URL address filtering entry and set the filtering action.
Use undo firewall http url-filter host url-address to remove one or all URL address filtering entries.
firewall http url-filter host url-address { deny | permit } url-address
undo firewall http url-filter host url-address [ url-address ]
2: System level
deny: Denies matched URL addresses.
permit: Permits matched URL addresses.
url-address: URL address filtering entry, a case-insensitive string of 1 to 80 characters. Valid characters include digits, English letters, dot (.), hyphen (-), underline (_), and wildcards caret (^), dollar sign ($), ampersand (&), and asterisk (*).
Wildcard |
Meaning |
Usage guidelines |
Matches website addresses starting with the keyword |
It can be present once at the beginning of a filtering entry. |
Matches website addresses ending with the keyword |
It can be present once at the end of a filtering entry. |
Stands for a valid character other than dot (.) |
It can be present multiple times at any position of a filtering entry, consecutively or inconsecutively, but cannot be used together with asterisk (*). |
Stands for any number of valid characters and spaces excluding dot (.) |
It can be present once at the beginning or in the middle of a filtering entry. It cannot be at the end and cannot be used next to caret (^) or dollar sign ($). |
When using the wildcards, follow these rules:
· A filtering entry with caret (^) at the beginning or dollar sign ($) at the end indicates an exact match. For example, filtering entry ^webfilter matches website addresses starting with webfilter (such as webfilter.com.cn) or containing webfilter at the beginning of a string after a dot (such as cmm.webfilter-any.com). Filtering entry ^webfilter$ matches website addresses containing standalone webfilter like www.webfilter.com; it does not match website addresses like www.webfilter-china.com.
· A filtering entry with neither caret (^) at the beginning nor dollar sign ($) at the end indicates a fuzzy match, and matches website addresses containing the keyword.
· If asterisk (*) is present at the beginning of a filtering entry, it must be present in the format like *.xxx, where xxx represents a keyword, for example, *.com or *.webfilter.com.
· A filtering entry with only numerals is invalid. To filter a website address like www.123.com, you can define a filtering entry like ^123$, www.123.com, or 123.com, instead of 123. In other words, you are recommended to use exact match to filter numeral website addresses.
The device supports a maximum of 256 URL address filtering entries.
You can change the filtering action for an existing filtering entry, for example, from deny to permit.
# Add filtering entry ^china& to the URL address filtering entry list and set the filtering action to permit.
[Sysname] firewall http url-filter host url-address permit ^china&
Use firewall http url-filter parameter to add URL parameter filtering entries to the URL parameter filtering entry list.
Use undo firewall http url-filter parameter to remove URL parameter filtering entries from the list.
firewall http url-filter parameter { default | keywords keywords }
undo firewall http url-filter parameter [ default | keywords keywords ]
2: System level
keywords keywords: Specifies to use a user-defined parameter filtering entry. The keywords argument is a case-insensitive string of 1 to 80 characters. Valid characters include numerals, English letters, wildcards caret (^), dollar sign ($), ampersand (&), and asterisk (*), and other ASCII characters with values in the range of 31 to 127. A filtering entry can be a string with spaces, but such an entry must be present in quotes, for example, "select all". One space in a filtering entry can match multiple consecutive spaces in a URL parameter of an HTTP request. For meanings of the wildcards, see Table 7.
Wildcard |
Meaning |
Usage guidelines |
Matches parameters starting with the keyword |
Matches parameters ending with the keyword |
Stands for one valid character |
It can be present multiple times at any position of a filtering entry, consecutively or inconsecutively, and cannot be used next to an asterisk (*). If it is present at the beginning or end of a filtering entry, it must be next to a caret (^) or a dollar sign ($). |
Stands for up to 4 valid characters including spaces |
It can be present once in the middle of a filtering entry. |
When using the wildcards, also follow the principles below:
· A filtering entry with a caret (^) at the beginning or a dollar sign ($) at the end indicates an exact match. For example, filtering entry ^webfilter$ matches website addresses containing standalone webfilter, like www.abc.com/webfilter any; it does not match website addresses like www.abc.com/webfilterany.
· A filtering entry with neither a caret (^) at the beginning nor a dollar sign ($) at the end indicates a fuzzy match, and matches website addresses containing the keyword.
If you do not specify any parameters, the undo firewall http url-filter parameter command will remove all URL parameter filtering entries in the list.
The device supports a maximum of 256 URL parameter filtering entries, including the default ones.
You cannot specify the same URL filtering entries as the default ones in command firewall http url-filter parameter keywords or undo firewall http url-filter parameter keywords.
# Add select to the parameter filtering entry list.
[Sysname] firewall http url-filter parameter keywords select
Use firewall http url-filter parameter enable to enable the URL parameter filtering function.
Use undo firewall http url-filter parameter enable to disable the URL parameter filtering function.
The URL parameter filtering function is disabled.
2: System level
# Enable the URL parameter filtering function.
[Sysname] firewall http url-filter parameter enable
reset firewall http
Use reset firewall http to clear Web filtering statistics.
reset firewall http { activex-blocking | java-blocking | url-filter host | url-filter parameter } counter
1: Monitor level
activex-blocking: Specifies ActiveX blocking statistics.
java-blocking: Specifies Java blocking statistics.
url-filter host: Specifies URL address filtering statistics.
url-filter parameter: Specifies URL parameter filtering statistics.
counter: Specifies to clear statistics.
# Clear URL address filtering statistics.
<Sysname> reset firewall http url-filter host counter
