- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH Commands
- 11-SSL Commands
- 12-SSL VPN Commands
- 13-TCP Attack Protection Commands
- 14-ARP Attack Protection Commands
- 15-IPsec Commands
- 16-ALG Commands
- 17-Firewall Commands
- 18-Session Management Commands
- 19-Web Filtering Commands
- 20-User Isolation Commands
- 21-Source IP Address Verification Commands
- 22-FIPS Commands
- 23-Protocol Packet Rate Limit Commands
- 24-Attack detection and protection commands
| 17-Firewall Commands | 83.14 KB |
Firewall configuration commands
Packet-filter firewall configuration commands
display firewall ipv6 statistics
firewall packet-filter (interface view)
firewall packet-filter (user-profile view)
reset firewall ipv6 statistics
firewall aspf (user-profile view)
Support for the packet-filter firewall commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
Use display firewall ipv6 statistics to view the packet filtering statistics of the IPv6 firewall.
display firewall ipv6 statistics { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
all: Displays the packet filtering statistics of all interfaces of the IPv6 firewall.
interface interface-type interface-number: Displays the packet filtering statistics of the specified interface of the IPv6 firewall.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the packet filtering statistics of the IPv6 firewall.
<Sysname> display firewall ipv6 statistics interface Vlan-interface 100
Interface: Vlan-interface100
In-bound Policy: acl6 2000
From 2013-06-04 10:25:21 to 2013-06-04 10:35:57
0 packets, 0 bytes, 0% permitted
0 packets, 0 bytes, 0% denied
0 packets, 0 bytes, 0% permitted default
0 packets, 0 bytes, 0% denied default
Totally 0 packets, 0 bytes, 0% permitted
Totally 0 packets, 0 bytes, 0% denied
Interface configured with the IPv6 packet filtering function. |
In-bound Policy |
IPv6 ACL configured in the inbound direction of the interface. |
Out-bound Policy |
IPv6 ACL configured in the outbound direction of the interface. |
acl6 |
IPv6 ACL number. |
0 packets, 0 bytes, 0% permitted |
Counts for packets permitted by IPv6 ACL rules: the number of packets and bytes, and the percentage of the permitted to the total. |
0 packets, 0 bytes, 0% denied |
Counts for packets denied by IPv6 ACL rules: the number of packets and bytes, and the percentage of the denied to the total. |
0 packets, 0 bytes, 0% permitted default |
Counts for packets that matched no IPv6 ACL rule and were permitted by the default filtering rule: number of packets and bytes, and the percentage of the permitted to the total. |
0 packets, 0 bytes, 0% denied default |
Counts for packets that matched no IPv6 ACL rule and were denied by the default filtering rule: number of packets and bytes, and the percentage of the denied to the total. |
Totally 0 packets, 0 bytes, 0% permitted |
Counts for all permitted packets: the number of packets and bytes, and the percentage of all the permitted to the total. |
Totally 0 packets, 0 bytes, 0% denied |
All denied packets: the number of packets and bytes, and the percentage of all the denied to the total. |
display firewall-statistics
Use display firewall-statistics to view the packet filtering statistics of the IPv4 firewall.
display firewall-statistics { all | interface interface-type interface-number | user-profile user-profile-name } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays all packet filtering statistics of the IPv4 firewall.
interface interface-type interface-number: Displays the packet filtering statistics on the specified interface of the IPv4 firewall.
user-profile user-profile-name: Displays packet filtering statistics about the user profile specified by its name, a case-sensitive string of 1 to 31 characters. For more information about user profiles, see Security Configuration Guide.
# Display all packet filtering statistics of the firewall.
<Sysname> display firewall-statistics all
Firewall is enable, default filtering method is 'permit'.
Interface: Vlan-interface3
In-bound Policy: acl 3001
From 2012-11-11 14:03:44 to 2012-11-11 14:07:41
0 packets, 0 bytes, 0% permitted,
0 packets, 0 bytes, 0% denied,
0 packets, 0 bytes, 0% permitted default,
0 packets, 0 bytes, 0% denied default,
Totally 0 packets, 0 bytes, 0% permitted,
Totally 0 packets, 0 bytes, 0% denied.
firewall default
Use firewall default to specify the default firewall filtering action of the IPv4 firewall.
firewall default { deny | permit }
The default filtering action of the IPv4 firewall is permitting packets to pass (permit).
2: System level
deny: Denies packets to pass the firewall.
permit: Permits packets to pass the firewall.
# Specify the default filtering action of the IPv4 firewall as denying packets to pass.
[Sysname] firewall default deny
firewall enable
Use firewall enable to enable the IPv4 firewall function.
Use undo firewall enable to disable the IPv4 firewall function.
firewall enable
The IPv4 firewall function is disabled.
2: System level
# Enable the IPv4 firewall function.
[Sysname] firewall enable
firewall ipv6 default
Use firewall ipv6 default to specify the default firewall filtering action of the IPv6 firewall.
firewall ipv6 default { deny | permit }
The default filtering action of IPv6 firewall is permitting packets to pass (permit).
2: System level
# Specify the default filtering action of the IPv6 firewall as denying packets to pass.
[Sysname] firewall ipv6 default deny
firewall ipv6 enable
Use firewall ipv6 enable to enable the IPv6 firewall function.
Use undo firewall ipv6 enable to disable the IPv6 firewall function.
The IPv6 firewall function is disabled.
2: System level
# Enable the IPv6 firewall function.
[Sysname] firewall ipv6 enable
Use firewall packet-filter to apply an IPv4 ACL to an interface to filter packets.
Use undo firewall packet-filter to cancel the configuration.
firewall packet-filter { acl-number | name acl-name } { inbound | outbound }
undo firewall packet-filter { acl-number | name acl-name } { inbound | outbound }
An interface does not filter packets.
Interface view
2: System level
acl-number: Specifies a basic ACL number in the range of 2000 to 2999, or an advanced ACL number in the range of 3000 to 3999.
name acl-name: Specifies a basic or an advanced IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters that must start with an alphabetical character. To avoid confusion, the word all cannot be used as the ACL name.
inbound: Filters incoming packets of the interface.
outbound: Filters outgoing packets of the interface.
You can apply only one IPv4 ACL in one direction of an interface to filter packets.
# Apply ACL 2001 to interface WLAN-ESS 1 to filter outbound packets.
[Sysname] interface wlan-ess 1
[Sysname-WLAN-ESS1] firewall packet-filter 2001 outbound
Use firewall packet-filter to apply an IPv4 ACL to a user profile to filter packets.
No ACL is applied to filter packets of any user.
User profile view
2: System level
name acl-name: Specifies a basic or an advanced IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters. It must start with an alphabetical character. To avoid confusion, the word all cannot be used as the ACL name.
inbound: Filters packets received from a user.
outbound: Filters packets sent to a user.
After a user passes authentication and is authorized with a user profile configured with an ACL packet-filter firewall, the packets received or sent by the user are filtered by the firewall.
In user profile view, you can apply only one ACL to filter packets in one direction.
# Apply ACL 2001 to user profile aaa to filter packets received from a user.
[Sysname] user-profile aaa
[Sysname-user-profile-aaa] firewall packet-filter 2001 inbound
firewall packet-filter ipv6
Use firewall packet-filter ipv6 to configure IPv6 packet filtering on the interface.
Use undo firewall packet-filter ipv6 to remove the IPv6 packet filtering setting on the interface.
firewall packet-filter ipv6 { acl6-number | name acl6-name } { inbound | outbound }
undo firewall packet-filter ipv6 [ { acl6-number | name acl6-name } ] { inbound | outbound }
IPv6 packets are not filtered on the interface.
Interface view
2: System level
acl6-number: Specifies a basic IPv6 ACL number in the range of 2000 to 2999, or an advanced IPv6 ACL number in the range of 3000 to 3999.
name acl6-name: Specifies a basic or an advanced IPv6 ACL by its name, a case-insensitive string of 1 to 32 characters that must start with an alphabetical character. To avoid confusion, the word all cannot be used as the ACL name.
You can apply only one IPv6 ACL in one direction of an interface.
# Apply IPv6 ACL 2500 to VLAN-interface 100 to filter outbound IPv6 packets.
[Sysname] interface Vlan-interface 100
[Sysname-Vlan-interface100] firewall packet-filter ipv6 2500 outbound
Use reset firewall ipv6 statistics to clear the packet filtering statistics of the IPv6 firewall.
reset firewall ipv6 statistics { all | interface interface-type interface-number }
1: Monitor level
all: Clears the packet filtering statistics on all interfaces of the IPv6 firewall.
interface interface-type interface-number: Clears the packet filtering statistics on the specified interface of the IPv6 firewall.
# Clear the packet filtering statistics on VLAN-interface 100 of the IPv6 firewall.
<Sysname> reset firewall ipv6 statistics interface Vlan-interface 100
reset firewall-statistics
Use reset firewall-statistics to clear packet filtering statistics of the IPv4 firewall.
reset firewall-statistics { all | interface interface-type interface-number | user-profile user-profile-name }
1: Monitor level
all: Clears all packet filtering statistics of the IPv4 firewall.
interface interface-type interface-number: Clears packet filtering statistics on the specified interface of the IPv4 firewall.
user-profile user-profile-name: Clears packet filtering statistics about the user profile specified by its name, a case-sensitive string of 1 to 31 characters. For more information about user profiles, see Security Configuration Guide.
# Clear packet filtering statistics of IPv4 firewall on interface WLAN-DBSS 1:4.
<Sysname> reset firewall-statistics interface WLAN-DBSS 1:4
ASPF configuration commands
aspf-policy
Use aspf-policy to create an ASPF policy and enter its view.
Use undo aspf-policy to remove an ASPF policy.
aspf-policy aspf-policy-number
undo aspf-policy aspf-policy-number
2: System level
aspf-policy-number: ASPF policy number, in the range of 1 to 99
A defined ASPF policy can be applied through its policy number.
# Create an ASPF policy and enter the corresponding ASPF policy view.
[Sysname] aspf-policy 1
[Sysname-aspf-policy-1]
display aspf all
Use display aspf all to view the information of all the ASPF policies and sessions.
display aspf all [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about all ASPF policies.
<Sysname> display aspf all
[ASPF Policy Configuration]
Policy Number 1:
icmp-error drop
tcp syn-check
Policy Number 2:
undo icmp-error drop
undo tcp syn-check
[Interface Configuration]
Interface InboundPolicy OutboundPolicy
WLAN-ESS1 1 2
[ASPF Policy Configuration] |
ASPF policy configuration information. |
Policy Number |
ASPF policy number. |
icmp-error drop |
Drop ICMP error messages. |
tcp syn-check |
Drop any non-SYN packet that is the first packet over a TCP connection. |
undo icmp-error drop |
Do not drop ICMP error messages. |
undo tcp syn-check |
Do not drop a non-SYN packet that is the first packet over a TCP connection. |
[Interface Configuration] |
ASPF policy application information of interface. |
Type and number of the interface. |
InboundPolicy |
Inbound ASPF policy. |
OutboundPolicy |
Outbound ASPF policy. |
display aspf interface
Use display aspf interface to view the ASPF policy configuration applied on interfaces.
display aspf interface [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the ASPF policies on interfaces.
<Sysname> display aspf interface
WLAN-ESS1 1 0
InboundPolicy |
OutboundPolicy |
display aspf policy
Use display aspf policy to view the information of an ASPF policy.
display aspf policy aspf-policy-number [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display ASPF policy 1
<Sysname> display aspf policy 1
Policy Number 1:
icmp-error drop
tcp syn-check
Policy Number |
icmp-error drop |
tcp syn-check |
Drop non-SYN packet that is the first packet over a TCP connection. |
display port-mapping
Use display port-mapping to view port mapping information.
display port-mapping [ application-name | port port-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
application-name: Name of the application to be used for port mapping. Available applications include FTP, GPRS Tunneling Protocol Control (GTP-C), GPRS Tunneling Protocol User (GTP-U), GPRS Tunneling Protocol V0 (GTP-V0), H323, HTTP, RTSP, SCCP, SIP, SMTP, and SQLNET.
port port-number: Specifies to display port mapping information on the specified port. The port number is in the range of 0 to 65535.
# Display all the information about port mapping.
<Sysname> display port-mapping
SERVICE PORT ACL TYPE
ftp 21 system defined
gtp-c 2123 system defined
gtp-u 2152 system defined
gtp-v0 3386 system defined
h323 1720 system defined
http 80 system defined
rtsp 554 system defined
sccp 2000 system defined
sip 5060 system defined
smtp 25 system defined
sqlnet 1521 system defined
Table 5 Command output
SERVICE |
Application layer protocol that is mapped to a port. |
PORT |
Number of the port for the application layer protocol. |
ACL |
Number of the ACL specifying the host range. |
TYPE |
Port mapping type, system predefined or user customized. |
port-mapping
firewall aspf (interface)
Use firewall aspf to apply an ASPF policy to the interface.
Use undo firewall aspf to remove an ASPF policy from the interface.
firewall aspf aspf-policy-number { inbound | outbound }
undo firewall aspf aspf-policy-number { inbound | outbound }
No ASPF policy is applied to an interface.
Interface view
2: System level
aspf-policy-number: Number of the ASPF policy, in the range of 1 to 99.
inbound: Applies ASPF policy to packets received from a user.
outbound: Applies ASPF policy to packets sent to a user.
# Apply ASPF policy 1 to the outbound direction of interface WLAN-ESS 1.
[Sysname-WLAN-ESS1] firewall aspf 1 outbound
Use firewall aspf to apply an ASPF policy to a user profile.
Use undo firewall aspf to cancel the application.
No ASPF policy is applied to a user profile.
User profile view
2: System level
inbound: Applies ASPF policy to inbound packets.
outbound: Applies ASPF policy to outbound packets.
After a user passes authentication and is authorized with a user profile configured with an ASPF policy, the packets received or sent by the user are inspected according to the ASPF policy.
Usually, authenticated users to be protected by the firewall reside in the internal network. Therefore, to inspect and filter packets from the internal network to the external network, apply an ASPF policy to the inbound direction, and to inspect and filter packets from the external network to the internal network, apply an ASPF policy to the outbound direction.
# Apply ASPF policy 1 to user profile aaa to filter packets sent to a user.
[Sysname-user-profile-aaa] firewall aspf 1 outbound
icmp-error drop
Use icmp-error drop to specify to drop ICMP error messages.
Use undo icmp-error drop to restore the default.
icmp-error drop
ICMP error messages are not dropped.
ASPF policy view
2: System level
# Configure ASPF policy 1 to drop ICMP error messages.
[Sysname-aspf-policy-1] icmp-error drop
aspf-policy
port-mapping
Use port-mapping to map a port to an application layer protocol.
Use undo port-mapping to remove a port mapping entry.
port-mapping application-name port port-number [ acl acl-number ]
undo port-mapping [ application-name port port-number [ acl acl-number ] ]
There is no mapping between the port and the application layer.
2: System level
application-name: Name of the application for port mapping. Available applications include FTP, GTP-C, GTP-U, GTP-V0, H323, HTTP, RTSP, SCCP, SIP, SMTP, and SQLNET.
port port-number: Specifies the port that the application layer protocol is mapped to. The port number is in the range of 0 to 65535.
acl acl-number: Specifies the IPv4 ACL for indicating the host range. The ACL number is in the range of 2000 to 2999.
# Map port 3456 to the FTP protocol.
[Sysname] port-mapping ftp port 3456
tcp syn-check
Use tcp syn-check to configure ASPF to drop any non-SYN packet that is the first packet over a TCP connection.
Use undo tcp syn-check to restore the default.
tcp syn-check
undo tcp syn-check
A non-SYN packet that is the first packet over a TCP connection is not dropped.
ASPF policy view
2: System level
# Configure ASPF policy 1 to drop any non-SYN packet which is the first packet over a TCP connection.
[Sysname-aspf-policy-1] tcp syn-check
aspf-policy
