- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH Commands
- 11-SSL Commands
- 12-SSL VPN Commands
- 13-TCP Attack Protection Commands
- 14-ARP Attack Protection Commands
- 15-IPsec Commands
- 16-ALG Commands
- 17-Firewall Commands
- 18-Session Management Commands
- 19-Web Filtering Commands
- 20-User Isolation Commands
- 21-Source IP Address Verification Commands
- 22-FIPS Commands
- 23-Protocol Packet Rate Limit Commands
- 24-Attack detection and protection commands
| 09-PKI Commands | 117.05 KB |
display pki certificate access-control-policy
display pki certificate attribute-group
pki request-certificate domain
PKI configuration commands
attribute
Use attribute to configure the attribute rules of the certificate issuer name, certificate subject name and alternative certificate subject name.
Use undo attribute to delete the attribute rules of one or all certificates.
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ} attribute-value
undo attribute { id | all }
No restrictions exist on the issuer name, subject name, and alternative subject name of a certificate.
Certificate attribute group view
Default command level
2: System level
id: Specifies a certificate attribute rule by its sequence number, in the range of 1 to 16.
alt-subject-name: Specifies the name of the alternative certificate subject.
fqdn: Specifies the FQDN of the entity.
ip: Specifies the IP address of the entity.
issuer-name: Specifies the name of the certificate issuer.
subject-name: Specifies the name of the certificate subject.
dn: Specifies the distinguished name of the entity.
ctn: Specifies the contain operation.
equ: Specifies the equal operation.
nctn: Specifies the not-contain operation.
nequ: Specifies the not-equal operation.
attribute-value: Specifies the value of the certificate attribute, a case-insensitive string of 1 to 128 characters.
all: Specifies all certificate attributes.
The attribute of the alternative certificate subject name does not appear as a distinguished name. Therefore, the dn keyword is not available for the attribute.
# Create a certificate attribute rule, specifying that the DN in the subject name includes the string of abc.
[Sysname] pki certificate attribute-group mygroup
[Sysname-pki-cert-attribute-group-mygroup] attribute 1 subject-name dn ctn abc
# Create a certificate attribute rule, specifying that the FQDN in the issuer name cannot be the string of abc.
[Sysname-pki-cert-attribute-group-mygroup] attribute 2 issuer-name fqdn nequ abc
# Create a certificate attribute rule, specifying that the IP address in the alternative subject name cannot be 10.0.0.1.
[Sysname-pki-cert-attribute-group-mygroup] attribute 3 alt-subject-name ip nequ 10.0.0.1
ca identifier
Use ca identifier to specify the trusted CA and bind the device with the CA.
Use undo ca identifier to remove the configuration.
ca identifier name
undo ca identifier
No trusted CA is specified for a PKI domain.
PKI domain view
2: System level
name: Specifies a trusted CA by its name, a case-sensitive string of 1 to 63 characters.
Certificate request, retrieval, revocation, and query depend on the trusted CA.
# Specify the trusted CA as new-ca.
[Sysname] pki domain 1
[Sysname-pki-domain-1] ca identifier new-ca
certificate request entity
Use certificate request entity to specify the entity for certificate request.
Use undo certificate request entity to remove the configuration.
certificate request entity entity-name
No entity is specified for certificate request.
PKI domain view
2: System level
entity-name: Specifies an entity for certificate request by the entity name, a case-insensitive string of 1 to 15 characters.
# Specify the entity for certificate request as entity1.
[Sysname-pki-domain-1] certificate request entity entity1
pki entity
certificate request from
Use certificate request from to specify the authority for certificate request.
Use undo certificate request from to remove the configuration.
certificate request from { ca | ra }
No authority is specified for certificate request.
PKI domain view
2: System level
ca: Indicates that the entity requests a certificate from a CA.
ra: Indicates that the entity requests a certificate from an RA.
# Specify that the entity requests a certificate from the CA.
[Sysname-pki-domain-1] certificate request from ca
certificate request mode
Use certificate request mode to set the certificate request mode.
Use undo certificate request mode to restore the default.
certificate request mode { auto [ key-length key-length | password { cipher | simple } password ] * | manual }
Manual mode is used.
PKI domain view
2: System level
auto: Requests a certificate in auto mode.
key-length: Specifies the length of the RSA keys in bits, in the range of 512 to 2048. It is 1024 bits by default.
cipher: Sets a ciphertext password for certificate revocation.
simple: Sets a plaintext password for certificate revocation.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 31 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters.
manual: Requests a certificate in manual mode.
In auto mode, an entity automatically requests a certificate from an RA or CA when it has no certificate. However, if the certificate will expire or has expired, the entity does not initiate a re-request automatically, in which case you need to request a new one manually. In manual mode, all operations associated with certificate request are performed manually.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
# Specify to request a certificate in auto mode.
[Sysname-pki-domain-1] certificate request mode auto
certificate request polling
Use certificate request polling to specify the certificate request polling interval and attempt limit.
Use undo certificate request polling to restore the defaults.
certificate request polling { count count | interval minutes }
undo certificate request polling { count | interval }
The polling is executed every 20 minutes for up to 50 times.
PKI domain view
2: System level
count count: Specifies the maximum number of attempts to poll the status of the certificate request, in the range of 1 to 100.
interval minutes: Specifies the polling interval in minutes, in the range of 5 to 168.
After an applicant makes a certificate request, the CA might need a long period of time if it verifies the certificate request manually. During this period, the applicant needs to query the status of the request periodically to get the certificate as soon as possible after the certificate is signed.
# Set the polling interval to 15 minutes and the maximum number of attempts as 40.
[Sysname-pki-domain-1] certificate request polling interval 15
[Sysname-pki-domain-1] certificate request polling count 40
certificate request url
Use certificate request url to specify the URL of the server for certificate request through SCEP.
Use undo certificate request url to remove the configuration.
certificate request url url-string
No URL is specified for a PKI domain.
PKI domain view
2: System level
url-string: Specifies the URL of the server for certificate request, a case-insensitive string of 1 to 127 characters. It comprises the location of the server and the location of CGI command interface script in the format of http://server_location/ca_script_location, where server_location must be an IP address and does not support domain name resolution.
# Specify the URL of the server for certificate request.
[Sysname-pki-domain-1] certificate request url http://169.254.0.100/certsrv/mscep/mscep.dll
common-name
Use common-name to configure the common name of an entity, which can be, for example, the user name.
Use undo common-name to remove the configuration.
common-name name
undo common-name
No common name is specified.
PKI entity view
2: System level
name: Specifies the common name for an entity, a case-insensitive string of 1 to 31 characters. Commas cannot be included.
# Configure the common name of an entity as test.
[Sysname] pki entity 1
[Sysname-pki-entity-1] common-name test
country
Use country to specify the code of the country to which an entity belongs. It is a standard 2-character code. For example, CN represents China.
Use undo country to remove the configuration.
country country-code-str
undo country
No country code is specified.
PKI entity view
2: System level
country-code-str: Specifies the country code for the entity, a case-insensitive string of two characters.
# Set the country code of an entity to CN.
[Sysname-pki-entity-1] country CN
crl check
Use crl check to enable or disable CRL checking.
crl check { disable | enable }
CRL checking is enabled.
PKI domain view
2: System level
disable: Disables CRL checking.
enable: Enables CRL checking.
CRLs are files issued by the CA to publish all certificates that have been revoked. Revocation of a certificate might occur before the certificate expires. CRL checking is intended for checking whether a certificate has been revoked. A revoked certificate is no longer trusted.
# Disable CRL checking.
[Sysname-pki-domain-1] crl check disable
crl update-period
Use crl update-period to set the CRL update period, that is, the interval at which a PKI entity with a certificate downloads the latest CRL from the LDAP server.
Use undo crl update-period to restore the default.
crl update-period hours
The CRL update period depends on the next update field in the CRL file.
PKI domain view
2: System level
hours: Specifies the CRL update period in hours, in the range of 1 to 720.
# Set the CRL update period to 20 hours.
[Sysname-pki-domain-1] crl update-period 20
crl url
Use crl url to specify the URL of the CRL distribution point.
Use undo crl url to remove the configuration.
crl url url-string
undo crl url
No CRL distribution point URL is specified.
PKI domain view
2: System level
url-string: Specifies the URL of the CRL distribution point, a case-insensitive string of 1 to 125 characters in the format of ldap://server_location or http://server_location, where server_location must be an IP address or a domain name.
When the URL of the CRL distribution point is not set, you should acquire the CA certificate and a local certificate, and then acquire a CRL through SCEP.
# Specify the URL of the CRL distribution point.
[Sysname-pki-domain-1] crl url ldap://169.254.0.30
Use display pki certificate to display the contents or request status of a certificate.
display pki certificate { { ca | local } domain domain-name | request-status } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ca: Displays the CA certificate.
local: Displays the local certificate.
domain-name: Specifies a PKI domain by its name, a string of 1 to 15 characters.
request-status: Displays the status of a certificate request.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the local certificate.
<Sysname> display pki certificate local domain 1
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
10B7D4E3 00010000 0086
Signature Algorithm: md5WithRSAEncryption
Issuer:
emailAddress=myca@aabbcc.net
C=CN
ST=Country A
L=City X
O=abc
OU=bjs
CN=new-ca
Validity
Not Before: Jan 13 08:57:21 2004 GMT
Not After : Jan 20 09:07:21 2005 GMT
Subject:
C=CN
ST=Country B
L=City Y
CN=pki test
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
RSA Public Key: (512 bit)
Modulus (512 bit):
00D41D1F …
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Subject Alternative Name:
DNS: hyf.xxyyzz.net
X509v3 CRL Distribution Points:
URI:http://1.1.1.1:447/myca.crl
A3A5A447 4D08387D …
Version |
Version of the certificate. |
Serial Number |
Serial number of the certificate. |
Signature Algorithm |
Signature algorithm. |
Issuer |
Issuer of the certificate. |
Validity |
Validity period of the certificate. |
Subject |
Entity holding the certificate. |
Subject Public Key Info |
Public key information of the entity. |
X509v3 extensions |
Extensions of the X.509 (version 3) certificate. |
X509v3 CRL Distribution Points |
Distribution points of X.509 (version 3) CRLs. |
· certificate request polling
· pki domain
· pki retrieval-certificate
Use display pki certificate access-control-policy to display information about one or all certificate access control policies.
display pki certificate access-control-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Specifies a certificate access control policy by its name, a string of 1 to 16 characters.
all: Specifies all certificate access control policies.
# Display information about the certificate access control policy named mypolicy.
<Sysname> display pki certificate access-control-policy mypolicy
access-control-policy name: mypolicy
rule 1 deny mygroup1
rule 2 permit mygroup2
access-control-policy |
Name of the certificate access control policy. |
rule number |
Number of the access control rule. |
Use display pki certificate attribute-group to display information about one or all certificate attribute groups.
display pki certificate attribute-group { group-name | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-name: Specifies a certificate attribute group by its name, a string of 1 to 16 characters.
all: Specifies all certificate attribute groups.
# Display information about the certificate attribute group mygroup.
<Sysname> display pki certificate attribute-group mygroup
attribute group name: mygroup
attribute 2 issuer-name fqdn nctn app
attribute group name |
Name of the certificate attribute group. |
attribute number |
Number of the attribute rule. |
subject-name |
Name of the certificate subject. |
dn |
DN of the entity. |
ctn |
Contain operations. |
abc |
Value of attribute 1. |
issuer-name |
Name of the certificate issuer. |
fqdn |
FQDN of the entity. |
nctn |
Not-contain operations. |
app |
Value of attribute 2. |
display pki crl domain
Use display pki crl domain to display the locally saved CRLs.
display pki crl domain domain-name [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the locally saved CRLs.
<Sysname> display pki crl domain 1
Certificate Revocation List (CRL):
Version 2 (0x1)
Signature Algorithm: sha1WithRSAEncryption
Issuer:
C=CN
O=abc
OU=soft
CN=A Test Root
Last Update: Jan 5 08:44:19 2004 GMT
Next Update: Jan 5 21:42:13 2004 GMT
CRL extensions:
X509v3 Authority Key Identifier:
keyid:0F71448E E075CAB8 ADDB3A12 0B747387 45D612EC
Revoked Certificates:
Serial Number: 05a234448E…
Revocation Date: Sep 6 12:33:22 2004 GMT
CRL entry extensions:…
Serial Number: 05a278445E…
Revocation Date: Sep 7 12:33:22 2004 GMT
Version |
Version of the CRL. |
Signature algorithm used by the CRLs. |
Issuer |
CA issuing the CRLs. |
Last Update |
Last update time. |
Next Update |
Next update time. |
CRL extensions |
Extensions of CRL. |
X509v3 Authority Key Identifier |
CA issuing the CRLs. The certificate version is X.509 v3. |
keyid |
ID of the public key. A CA might have multiple key pairs. This field indicates the key pair used by the CRL's signature. |
Revoked Certificates |
Revoked certificates. |
Serial Number |
Serial number of the revoked certificate. |
Revocation Date |
Revocation date of the certificate. |
· pki domain
· pki retrieval-crl
fqdn
Use fqdn to configure the FQDN of an entity.
Use undo fqdn to remove the configuration.
fqdn name-str
undo fqdn
No FQDN is specified for an entity.
PKI entity view
2: System level
name-str: Specifies the FQDN for an entity, a case-insensitive string of 1 to 127 characters.
An FQDN is the unique identifier of an entity on a network. It consists of a host name and a domain name and can be resolved into an IP address.
# Configure the FQDN of an entity as pki.domain-name.com.
[Sysname-pki-entity-1] fqdn pki.domain-name.com
ip (PKI entity view)
Use ip to configure the IP address of an entity.
Use undo ip to remove the configuration.
ip ip-address
undo ip
No IP address is specified for an entity.
PKI entity view
2: System level
ip-address: Specifies an IP address for the entity.
# Configure the IP address of an entity as 11.0.0.1.
[Sysname-pki-entity-1] ip 11.0.0.1
ldap-server
Use ldap-server to specify an LDAP server for a PKI domain.
Use undo ldap-server to remove the configuration.
ldap-server ip ip-address [ port port-number ] [ version version-number ]
undo ldap-server
No LDP server is specified for a PKI domain.
PKI domain view
2: System level
ip-address: Specifies an LDAP server by its IP address, in dotted decimal format.
port-number: Specifies the port number of the LDAP server, in the range of 1 to 65535. The default is 389.
version-number: Specifies the LDAP version number, either 2 or 3. The default is 2.
# Specify an LDAP server for PKI domain 1.
[Sysname-pki-domain-1] ldap-server ip 169.254.0.30
locality
Use locality to configure the geographical locality of an entity. For example, it can be a city name.
Use undo locality to remove the configuration.
locality locality-name
undo locality
No geographical locality is specified for an entity.
PKI entity view
2: System level
locality-name: Specifies the name for the geographical locality, a case-insensitive string of 1 to 31 characters. Commas cannot be included.
# Configure the locality of an entity as city.
[Sysname-pki-entity-1] locality city
organization
Use organization to configure the name of the organization to which the entity belongs.
Use undo organization to remove the configuration.
organization org-name
undo organization
No organization name is specified for an entity.
PKI entity view
2: System level
org-name: Specifies the organization name, a case-insensitive string of 1 to 31 characters. Commas cannot be included.
# Configure the name of the organization to which an entity belongs as test-lab.
[Sysname-pki-entity-1] organization test-lab
organization-unit
Use organization-unit to specify the name of the organization unit to which this entity belongs.
Use undo organization-unit to remove the configuration.
organization-unit org-unit-name
No organization unit name is specified for an entity.
PKI entity view
2: System level
org-unit-name: Specifies the organization unit name for distinguishing different units in an organization, a case-insensitive string of 1 to 31 characters. Commas cannot be included.
# Configure the name of the organization unit to which an entity belongs as group1.
[Sysname-pki-entity-1] organization-unit group1
Use pki certificate access-control-policy to create a certificate access control policy and enter its view.
Use undo pki certificate access-control-policy to remove one or all certificate access control policies.
pki certificate access-control-policy policy-name
undo pki certificate access-control-policy { policy-name | all }
No access control policy exists by default.
2: System level
policy-name: Specifies a name for the certificate access control policy, a case-insensitive string of 1 to 16 characters. It cannot be a, al, or all.
# Configure an access control policy named mypolicy and enter its view.
[Sysname] pki certificate access-control-policy mypolicy
[Sysname-pki-cert-acp-mypolicy]
Use pki certificate attribute-group to create a certificate attribute group and enter its view.
Use undo pki certificate attribute-group to delete one or all certificate attribute groups.
pki certificate attribute-group group-name
undo pki certificate attribute-group { group-name | all }
No certificate attribute group exists.
2: System level
group-name: Specifies a name for the certificate attribute group, a case-insensitive string of 1 to 16 characters. It cannot be a, al, or all.
# Create a certificate attribute group named mygroup and enter its view.
pki delete-certificate
Use pki delete-certificate to delete the certificate locally stored for a PKI domain.
pki delete-certificate { ca | local } domain domain-name
2: System level
ca: Deletes the locally stored CA certificate.
local: Deletes the locally stored local certificate.
# Delete the local certificate for PKI domain cer.
[Sysname] pki delete-certificate local domain cer
pki domain
Use pki domain to create a PKI domain and enter PKI domain view or enter the view of an existing PKI domain.
Use undo pki domain to remove a PKI domain.
pki domain domain-name
undo pki domain domain-name
No PKI domains exist.
2: System level
domain-name: Specifies a name for the PKI domain, a case-insensitive string of 1 to 15 characters.
The number of PKI domains supported by the device varies by device model. For more information, see About the WX Series Access Controllers Configuration Guides.
# Create a PKI domain and enter its view.
pki entity
Use pki entity to create a PKI entity and enter its view.
Use undo pki entity to remove a PKI entity.
pki entity entity-name
undo pki entity entity-name
No entities exist.
2: System level
entity-name: Specifies a name for the entity, a case-insensitive string of 1 to 15 characters.
You can configure a variety of attributes for an entity in PKI entity view. An entity is intended only for convenience of reference by other commands.
# Create a PKI entity named en and enter its view.
[Sysname] pki entity en
[Sysname-pki-entity-en]
pki import-certificate ca
Use pki import-certificate ca to import a CA certificate from a file and save it locally.
pki import-certificate ca domain domain-name { der | pem } [ filename filename ]
2: System level
ca: Specifies the CA certificate.
der: Specifies the certificate format of DER.
pem: Specifies the certificate format of PEM.
filename filename: Specifies the name of the certificate file to import, a case-insensitive string of 1 to 127 characters. If you do not specify a file name, the default file name that is used to save the retrieved certificate is used, which is domain-name_ca.cer.
In FIPS mode, you cannot import MD5 certificates or certificates that contain keys with a key modulus length of less than 2048 bits.
# Import the CA certificate for PKI domain cer in PEM format.
[Sysname] pki import-certificate ca domain cer pem
pki domain
pki import-certificate local
Use pki import-certificate local to import a local certificate from a file and save it locally.
pki import-certificate local domain domain-name { der | p12 | pem } [ filename filename ]
2: System level
local: Specifies the local certificate.
p12: Specifies the certificate format of p12.
filename filename: Specifies the name of the certificate file to import, a case-insensitive string of 1 to 127 characters. If you do not specify a file name, the default file name that is used to save the retrieved certificate is used, which is domain-name_local.cer.
# Import the local certificate for PKI domain cer in PEM format.
[Sysname] pki import-certificate local domain cer pem
pki domain
Use pki request-certificate domain to request a local certificate from a CA through SCEP. If SCEP fails, you can use the pkcs10 keyword to print the request information in BASE64 format, or use the pkcs10 filename filename option to save the request information to a local file and send the file to the CA by an out-of-band means.
pki request-certificate domain domain-name [ password ] [ pkcs10 [ filename filename ] ]
The retrieved certificate is stored in the root directory with the filename domain-name_ca.cer or domain-name_local.cer.
2: System level
password: Specifies the password for certificate revocation, a case-sensitive string of 1 to 31 characters.
pkcs10: Displays the BASE64-encoded PKCS#10 certificate request information, which can be used to request a certification by an out-of-band means, like phone, disk, or email.
filename filename: Specifies the name of the local file for saving the PKCS#10 certificate request, a case-insensitive string of 1 to 127 characters.
This operation will not be saved in the configuration file.
# Display the PKCS#10 certificate request information.
[Sysname] pki request-certificate domain 1 pkcs10
-----BEGIN CERTIFICATE REQUEST-----
MIIBTDCBtgIBADANMQswCQYDVQQDEwJqajCBnzANBgkqhkiG9w0BAQEFAAOBjQAw
gYkCgYEAw5Drj8ofs9THA4ezkDcQPBy8pvH1kumampPsJmx8sGG52NFtbrDTnTT5
ALx3LJijB3d/ndKpcHT/DfbJVDCn5gdw32tBZyCkEwMHZN3ol2z7Nvdu5TED6iN8
4m+hfp1QWoV6lty3o9pxAXuQl8peUDcfN6WV3LBXYyl1WCtkLkECAwEAAaAAMA0G
CSqGSIb3DQEBBAUAA4GBAA8E7BaIdmT6NVCZgv/I/1tqZH3TS4e4H9Qo5NiCKiEw
R8owVmA0XVtGMbyqBNcDTG0f5NbHrXZQT5+MbFJOnm5K/mn1ro5TJKMTKV46PlCZ
JUjsugaY02GBY0BVcylpC9iIXLuXNIqjh1MBIqVsa1lQOHS7YMvnop6hXAQlkM4c
-----END CERTIFICATE REQUEST-----
pki domain
Use pki retrieval-certificate to retrieve a certificate from the server for certificate distribution.
pki retrieval-certificate { ca | local } domain domain-name
2: System level
ca: Retrieves the CA certificate.
local: Retrieves the local certificate.
domain-name: Specifies the name of the PKI domain used for certificate request.
# Retrieve the CA certificate from the certificate issuing server.
[Sysname] pki retrieval-certificate ca domain 1
pki domain
pki retrieval-crl domain
Use pki retrieval-crl domain to retrieve the latest CRLs from the server for CRL distribution.
pki retrieval-crl domain domain-name
2: System level
CRLs help verify the validity of certificates.
# Retrieve CRLs.
[Sysname] pki retrieval-crl domain 1
pki domain
pki validate-certificate
Use pki validate-certificate to verify the validity of a certificate.
pki validate-certificate { ca | local } domain domain-name
2: System level
ca: Verifies the CA certificate.
local: Verifies the local certificate.
domain-name: Specifies the name of the PKI domain to which the certificate to be verified belongs, a string of 1 to 15 characters.
The focus of certificate validity verification will check that the certificate is signed by the CA and that the certificate has neither expired nor been revoked.
# Verify the validity of the local certificate.
[Sysname] pki validate-certificate local domain 1
pki domain
root-certificate fingerprint
Use root-certificate fingerprint to configure the fingerprint to be used for verifying the validity of the CA root certificate.
Use undo root-certificate fingerprint to remove the configuration.
root-certificate fingerprint { md5 | sha1 } string
No fingerprint is configured for verifying the validity of the CA root certificate.
PKI domain view
2: System level
md5: Uses an MD5 fingerprint.
sha1: Uses a SHA1 fingerprint.
string: Specifies the fingerprint to be used. An MD5 fingerprint must be a string of 32 characters in hexadecimal. A SHA1 fingerprint must be a string of 40 characters in hexadecimal.
# Configure an MD5 fingerprint for verifying the validity of the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint md5 12EF53FA355CD23E12EF53FA355CD23E
# Configure a SHA1 fingerprint for verifying the validity of the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint sha1 D1526110AAD7527FB093ED7FC037B0B3CDDDAD93
rule (PKI CERT ACP view)
Use rule to create a certificate attribute access control rule.
Use undo rule to delete one or all access control rules.
rule [ id ] { deny | permit } group-name
undo rule { id | all }
No access control rule exists.
PKI certificate access control policy view
2: System level
id: Specifies the number of the certificate attribute access control rule, in the range of 1 to 16. The default is the smallest unused number in this range.
deny: Indicates that a certificate whose attributes match an attribute rule in the specified attribute group is considered invalid and denied.
permit: Indicates that a certificate whose attributes match an attribute rule in the specified attribute group is considered valid and permitted.
group-name: Specifies the name of the certificate attribute group to be associated with the rule, a case-insensitive string of 1 to 16 characters. It cannot be a, al, or all.
all: Specifies all access control rules.
A certificate attribute group must exist to be associated with a rule.
# Create an access control rule, specifying that a certificate is considered valid when it matches an attribute rule in the certificate attribute group mygroup.
[Sysname-pki-cert-acp-mypolicy] rule 1 permit mygroup
state
Use state to specify the name of the state or province where an entity resides.
Use undo state to remove the configuration.
state state-name
undo state
No state or province is specified.
PKI entity view
2: System level
state-name: Specifies the state or province name, a case-insensitive string of 1 to 31 characters. Commas cannot be included.
# Specify the state where an entity resides.
[Sysname-pki-entity-1] state country
