07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
03-MAC Authentication Commands
03-MAC Authentication Commands 91.72 KB
MAC authentication configuration commands
display mac-authentication
Use display mac-authentication to display MAC authentication settings and statistics, including global settings, and port-specific settings and MAC authentication and online user statistics.
display mac-authentication [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
Default command level
2: System level
interface interface-list: Specifies a port list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges. The start port and end port of a port range must be of the same type and the end port number must be greater than the start port number. A port range defined without the to interface-type interface-number portion comprises only one port.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you specify a list of ports, the command displays port-specific settings and statistics only for the specified ports.
If you do not specify any port, the command displays port-specific settings and statistics for all ports.
# Display all MAC authentication settings and statistics.
MAC address authentication is enabled.
 User name format is MAC address in lowercase, like xxxxxxxxxxxx
 Fixed username:mac
 Fixed password:not configured
          Offline detect period is 300s
          Quiet period is 60s.
          Server response timeout value is 100s
          The max allowed user number is 1024 per slot
          Current user number amounts to 0
          Current domain: not configured, use default domain
Silent Mac User info:
         MAC Addr         From Port           Port Index
GigabitEthernet1/0/1 is link-up
  Authenticate success: 0, failed: 0
 Max number of on-line users is 128
  Current online user number is 0
MAC Addr         Authenticate state           AuthIndex
Whether MAC authentication is enabled.
Type of user account, which can be MAC-based or shared.
·     If MAC-based accounts are used, this field displays "User name format is MAC address…" and the format settings for usernames and passwords. For example, MAC addresses without hyphens in lower case.
·     If a shared account is used, this field displays "User name format is fixed account."
Fixed username:
Username of the shared account for MAC authentication users. If MAC-based accounts are used, this field displays mac.
Fixed password:
Password of the shared account for MAC authentication users.
·     If MAC-based accounts are used or if a shared account is used but no password is configured, this field displays not configured.
·     If a shared account is used and a password is configured, this field displays ******.
Setting of the offline detect timer.
Quiet period
Setting of the quiet timer.
Setting of the server timeout timer.
Maximum number of users the device supports. The value depends on the device model. For more information, see About the H3C Access Controllers Command References.
Number of online users.
Authentication domain that is currently used.
Information about silent MAC addresses. A MAC address is marked silent when it fails a MAC authentication, and at the same time, a quiet timer starts. Before the timer expires, the device drops any packet from the MAC address and does not perform MAC authentication for the MAC address.
Status of the link on port GigabitEthernet 1/0/1. In this example, the link is up.
Whether MAC authentication is enabled on port GigabitEthernet 1/0/1.
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts.
Maximum number of concurrent online users allowed on the port.
If MAC authentication is not enabled on the port, the field displays 0.
Number of online users on the port.
MAC Addr
MAC address of the online user.
Authenticate state
User status. Possible values include the following:
·     MAC_AUTHENTICATOR_CONNECT—The user is logging in.
·     MAC_AUTHENTICATOR_SUCCESS—The user has passed the authentication.
·     MAC_AUTHENTICATOR_FAIL—The user failed the authentication.
·     MAC_AUTHENTICATOR_LOGOFF—The user has logged off.
AuthIndex
Authenticator index.
mac-authentication accounting-delay
Use mac-authentication accounting-delay to enable accounting delay for MAC authentication users on an interface.
Use undo mac-authentication accounting-delay to restore the default.
mac-authentication accounting-delay [ logoff | time time ] *
The accounting delay feature is disabled. When a user passes MAC authentication, the device immediately sends an accounting request to the accounting server, regardless of whether it has obtained the user's IP address.
Interface view
2: System level
logoff: Cancels the accounting procedure for a MAC authentication user if the device fails to get the user's IP address within the delay time. As a result, the user cannot come online. If this option is not specified, the device sends an accounting request once the delay time is reached.
time time: Specifies a delay time in seconds. The value range for the time argument is 1 to 600. If no delay time is specified, a 10-second delay applies.
The accounting delay feature enables the device to delay sending the accounting request for an authenticated MAC authentication user. If the device gets the user's IP address within the delay period, it includes the IP address in the accounting request and starts the accounting process for the user. If the device fails to get the user's IP address, it starts the accounting process or logs off the user depending on your configuration.
H3C recommends that you enable the accounting delay feature when the following conditions exist:
·     MAC authentication users obtain IP addresses through DHCP.
·     The accounting server requires user IP addresses for accounting management.
Set the delay depending on how long it takes for users to obtain an IP address on your network.
# On interface WLAN-ESS 1, configure a 15-second accounting delay for MAC authentication users and enable the device to perform the logoff action when the delay expires.
[Sysname] interface wlan-ess 1
[Sysname-WLAN-ESS1] mac-authentication accounting-delay logoff time 15
mac-authentication
Use mac-authentication in system view to enable MAC authentication globally.
Use mac-authentication interface interface-list in system view to enable MAC authentication on a list of ports, or use mac-authentication in interface view to enable MAC authentication on a port.
Use undo mac-authentication in system view to disable MAC authentication globally.
Use undo mac-authentication interface interface-list in system view to disable MAC authentication on a list of ports, or use undo mac-authentication in interface view to disable MAC authentication on a port.
In system view:
undo mac-authentication [ interface interface-list ]
In Ethernet interface view:
mac-authentication
MAC authentication is not enabled globally or on any port.
System view, Ethernet interface view
2: System level
interface interface-list: Specifies an Ethernet port list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges. The start port and end port of a port range must be of the same type and the end port number must be greater than the start port number. A port range defined without the to interface-type interface-number portion comprises only one port.
To use MAC authentication on a port, you must enable the function both globally and on the port.
# Enable MAC authentication globally.
[Sysname] mac-authentication
Mac-auth is enabled globally.
# Enable MAC authentication on port GigabitEthernet 1/0/1.
[Sysname] mac-authentication interface gigabitethernet 1/0/1
Mac-auth is enabled on port GigabitEthernet1/0/1.
Or
[Sysname-GigabitEthernet1/0/1] mac-authentication
mac-authentication bypass-portal enable
Use mac-authentication bypass-portal enable to enable portal authentication bypass for MAC-authenticated users.
Use undo mac-authentication bypass-portal enable to restore the default.
Portal authentication bypass for MAC-authenticated users is disabled.
WLAN-ESS interface view
2: System view
# Enable portal authentication bypass for MAC-authenticated users.
[Sysname-WLAN-ESS1] mac-authentication bypass-portal enable
mac-authentication domain
Use mac-authentication domain to specify a global or port specific authentication domain.
Use undo mac-authentication domain to restore the default.
The default authentication domain is used for MAC authentication users. For more information about the default authentication domain, see the domain default enable command in "AAA configuration commands."
System view, Layer 2 Ethernet interface view, WLAN-ESS interface view
2: System level
domain-name: Specifies an authentication domain name, a case-insensitive string of 1 to 24 characters. The domain name cannot contain any forward slash (/), colon (:), asterisk (*), question mark (?), less-than sign (<), greater-than sign (>), or at sign (@).
The global authentication domain is applicable to all MAC authentication enabled ports. A port specific authentication domain is applicable only to the port. You can specify different authentication domains on different ports.
A port chooses an authentication domain for MAC authentication users in this order:
1.     Authentication domain specified on the port.
2.     Global authentication domain specified in system view.
3.     Default authentication domain.
# Specify the domain1 domain as the global authentication domain for MAC authentication users.
# Specify the aabbcc domain as the authentication domain for MAC authentication users on port WLAN-ESS 1.
[Sysname-WLAN-ESS1] mac-authentication domain aabbcc
mac-authentication guest-vlan
Use mac-authentication guest-vlan to specify a MAC authentication guest VLAN on a port. Any users that have failed MAC authentication on the port are assigned to this VLAN, so they can access a limited set of network resources, such as a software server, to download anti-virus software, and system patches. After a user in the guest VLAN passes MAC authentication, the user is removed from the guest VLAN and can access all authorized network resources.
Use undo mac-authentication guest-vlan to remove the MAC authentication guest VLAN from the port.
No MAC authentication guest VLAN is configured on a port.
2: System level
guest-vlan-id: Specifies a VLAN as the MAC authentication guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2 Configuration Guide.
To use the MAC authentication guest VLAN function on a port, you must enable MAC-based VLAN on the port, in addition to enabling MAC authentication both globally and on the port.
To delete a VLAN that has been set as a MAC authentication guest VLAN, remove the guest VLAN configuration first.
# Configure VLAN 5 as the MAC authentication guest VLAN on port WLAN-ESS 1.
[Sysname-WLAN-ESS1] mac-authentication guest-vlan 5
·     mac-authentication
·     mac-vlan enable (Layer 2 Command Reference)
mac-authentication max-user
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication users on a port.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user user-number
2: System level
user-number: Specifies a maximum number of concurrent MAC authentication users on the port. The value range varies with devices. For more information, see About the H3C Access Controllers Command References.
The default maximum number of concurrent MAC authentication users on a port depends on the device model (see About the H3C Access Controllers Command References).
# Configure port WLAN-ESS 1 to support up to 32 concurrent MAC authentication users.
[Sysname-WLAN-ESS1] mac-authentication max-user 32
mac-authentication timer
Use mac-authentication timer to set the MAC authentication timers.
Use undo mac-authentication timer to restore the default settings.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
undo mac-authentication timer { offline-detect | quiet | server-timeout }
The offline detect timer is 300 seconds, the quiet timer is 60 seconds, and the server timeout timer is 100 seconds.
2: System level
offline-detect offline-detect-value: Sets the offline detect timer in the range of 60 to 65535 seconds. This timer sets the interval that the device waits for traffic from a user before it regards the user as idle. If a user connection has been idle within the interval, the device logs the user out and stops accounting for the user.
quiet quiet-value: Sets the quiet timer in the range of 1 to 3600 seconds. This timer sets the interval that the device must wait before it can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
server-timeout server-timeout-value: Sets the server timeout timer in the range of 100 to 300 seconds. This timer sets the interval that the access device waits for a response from a RADIUS server before it regards the RADIUS server unavailable. If the timer expires during MAC authentication, the user cannot access the network.
# Set the server timeout timer to 150 seconds.
mac-authentication trigger after-portal
Use mac-authentication trigger after-portal to enable the MAC-after-portal feature.
Use undo mac-authentication trigger to restore the default.
mac-authentication trigger after-portal [ wait-time wait-time-value ]
This feature is disabled.
2: System level
wait-time wait-time-value: Sets the period of time for which the device waits before the MAC authentication is triggered for portal-authenticated users. The value range for the wait-time-value argument is 1 to 30 seconds.
The MAC-after-portal feature triggers MAC authentication for only portal-authenticated users. The AC allows only these users to pass MAC authentication and assigns them to VLANs that perform local forwarding on an AP. For more information about local forwarding, see WLAN Configuration Guide.
# Enable the MAC-after-portal feature on WLAN-ESS 1.
[Sysname-wlan-ess1] mac-authentication trigger after-portal
mac-authentication user-name-format
Use mac-authentication user-name-format to configure the type of user accounts for MAC authentication users.
Use undo mac-authentication user-name-format to restore the default.
mac-authentication user-name-format { fixed [ account name ] [ password { cipher | simple } password ] | mac-address [ { with-hyphen | without-hyphen } [ lowercase | uppercase ] ] }
Each user's MAC address is used as the username and password for MAC authentication. MAC addresses must use lower case without hyphens.
2: System level
fixed: Uses a shared account for all MAC authentication users.
account name: Specifies the username for the shared account. The name takes a case-insensitive string of 1 to 55 characters. If no username is specified, the default name mac applies.
password: Specifies the password for the shared user account:
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password. This argument is case sensitive. If simple is specified, it must be a string of 1 to 63 characters. If cipher is specified, it must be a ciphertext string of 1 to 117 characters.
mac-address: Uses MAC-based user accounts for MAC authentication users. If this option is specified, you must create one user account for each user, and use the MAC address of the user as both the username and password for the account. You can also specify the format of username and password:
·     with-hyphen—Hyphenates the MAC address, for example xx-xx-xx-xx-xx-xx.
·     without-hyphen—Excludes hyphens from the MAC address, for example, xxxxxxxxxxxx.
·     lowercase—Enters letters in lower case.
·     uppercase—Capitalizes letters.
MAC authentication supports the following types of user account:
·     One MAC-based user account for each user. A user can pass MAC authentication only when its MAC address matches a MAC-based user account. This approach is suitable for an insecure environment.
·     One shared user account for all users. Any user can pass MAC authentication on any MAC authentication enabled port. You can use this approach in a secure environment to limit network resources accessible to MAC authentication users, for example, by assigning an authorized ACL or VLAN for the shared account.
For secrecy, all passwords, including passwords configured in plaintext, are saved in cipher text.
# Configure a shared account for MAC authentication users: set the username as abc and password as a plaintext string of xyz.
# Configure a shared account for MAC authentication users: set the username as abc and password as a ciphertext string of $c$3$Uu9Dh4xRKWa8RHW3TFnNTafBbhdPAg.
[Sysname] mac-authentication user-name-format fixed account abc password cipher $c$3$Uu9Dh4xRKWa8RHW3TFnNTafBbhdPAg
# Use MAC-based user accounts for MAC authentication users, and each MAC address must be hyphenated and in upper case.
[Sysname] mac-authentication user-name-format mac-address with-hyphen uppercase
reset mac-authentication statistics
Use reset mac-authentication statistics to clear MAC authentication statistics.
reset mac-authentication statistics [ interface interface-list ]
2: System level
If no port list is specified, the command clears all global and port-specific MAC authentication statistics.
If a port list is specified, the command clears the MAC authentication statistics on the specified ports.
# Clear MAC authentication statistics on port WLAN-ESS 1.
<Sysname> reset mac-authentication statistics interface wlan-ess 1
