07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
10-SSH Commands
10-SSH Commands 155.36 KB
SSH configuration commands
SSH server configuration commands
display ssh server
Use the display ssh server command on an SSH server to display the SSH server status or sessions.
display ssh server { session | status } [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
session: Displays the SSH server sessions.
status: Displays the SSH server status.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the SSH server status.
<Sysname> display ssh server status
 SSH Server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH Authentication retries : 3 time(s)
 SFTP Server: Disable
 SFTP Server Idle-Timeout: 10 minute(s)
SSH Server
Whether the SSH server is enabled.
SSH version
SSH protocol version.
When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.
Authentication timeout timer.
SSH server key pair update interval.
Maximum number of SSH authentication attempts.
SFTP Server
Whether the Secure FTP (SFTP) server is enabled.
SFTP connection idle timeout timer.
# Display the SSH server session information.
<Sysname> display ssh server session
 Conn   Ver   Encry    State         Retry    SerType  Username
 VTY 0  2.0   DES      Established   0        SFTP     client001
Conn
Connected VTY channel.
Ver
SSH server protocol version.
Encry
Encryption algorithm.
Status of the session:
·     Init—Initialization.
·     Ver-exchange—Version negotiation.
·     Keys-exchange—Keys exchange.
·     Auth-request—Authentication request.
·     Serv-request—Session service request.
·     Established—The session is established.
·     Disconnected—The session is disconnected.
Retry
Number of authentication failures.
SerType
Service type: SFTP, Secure Telnet (Stelnet), or secure copy (SCP).
Username
Name of a user for login.
·     ssh server authentication-retries
·     ssh server authentication-timeout
·     ssh server compatible-ssh1x enable
·     ssh server enable
·     ssh server rekey-interval
display ssh user-information
Use the display ssh user-information command on an SSH server to display information about SSH users.
display ssh user-information [ username ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
username: Specifies an SSH username, a string of 1 to 80 characters. If no SSH user is specified, this command displays information about all SSH users.
This command displays only information about SSH users configured by using the ssh user command on the SSH server.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users : 2
 Username    Authentication-type   User-public-key-name     Service-type
 yemx        password              null                     stelnet
 test        publickey             pubkey                   sftp
Username
Name of the user.
Authentication-type
Authentication method:
·     Password authentication.
·     Publickey authentication.
·     Password-publickey authentication.
·     Any authentication.
Public key of the user or name of the PKI domain which verifies the client certificate. If the authentication method is password, this field displays null.
Service-type
Service type: SFTP, Stelnet, SCP, or all. If all authentication methods are supported, this field displays all.
ssh user
sftp server enable
Use sftp server enable to enable the SFTP server.
Use undo sftp server enable to restore the default.
sftp server enable
The SFTP server is disabled.
3: Manage level
# Enable the SFTP server.
[Sysname] sftp server enable
display ssh server
sftp server idle-timeout
Use sftp server idle-timeout to set the idle timeout timer for SFTP user connections.
Use undo sftp server idle-timeout to restore the default.
The idle timeout timer is 10 minutes.
3: Manage level
time-out-value: Specifies a timeout timer in minutes, in the range of 1 to 35791.
If an SFTP connection is idle when the idle timeout timer expires, the system automatically terminates the connection. If many SFTP connections are established, you can set a smaller value so that the connection resources can be promptly released.
# Set the idle timeout timer for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
display ssh server
Use ssh server authentication-retries to set the maximum number of SSH connection authentication attempts.
Use undo ssh server authentication-retries to restore the default.
ssh server authentication-retries times
The maximum number of SSH connection authentication attempts is 3.
3: Manage level
times: Specifies the maximum number of authentication attempts, in the range of 1 to 5.
You can set this limit to prevent malicious hacking of usernames and passwords.
This configuration takes effect only on the users at next login.
Authentication fails if the number of authentication attempts (including both publickey and password authentication) exceeds the upper limit configured by this command.
If the authentication method is password-publickey, the server first uses publickey authentication, and then uses password authentication to authenticate SSH users. The process is considered as one authentication attempt.
# Set the maximum number of SSH connection authentication attempts to 4.
[Sysname] ssh server authentication-retries 4
display ssh server
Use ssh server authentication-timeout to set the SSH user authentication timeout timer on the SSH server.
Use undo ssh server authentication-timeout to restore the default.
The authentication timeout timer is 60 seconds.
3: Manage level
time-out-value: Specifies an authentication timeout timer in seconds, in the range of 1 to 120.
If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
You can set a small value for this timer to prevent malicious occupation of TCP connections.
# Set the SSH user authentication timeout timer to 10 seconds.
[Sysname] ssh server authentication-timeout 10
display ssh server
Use ssh server compatible-ssh1x enable to enable the SSH server to support SSH1 clients.
Use undo ssh server compatible-ssh1x to disable the SSH server from supporting SSH1 clients.
The SSH server supports SSH1 clients.
3: Manage level
The configuration takes effect only on the clients at next login.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
display ssh server
ssh server enable
Use ssh server enable to enable the SSH server.
Use undo ssh server enable to restore the default.
ssh server enable
The SSH server is disabled.
3: Manage level
# Enable the SSH server.
[Sysname] ssh server enable
display ssh server
Use ssh server rekey-interval to set the interval for updating the RSA server key pair.
Use undo ssh server rekey-interval to restore the default.
ssh server rekey-interval hours
The interval for updating the RSA server key pair is 0. The system does not update the RSA server key pair.
3: Manage level
hours: Specifies an interval for updating the server key pair, in the range of 1 to 24.
Periodically updating the RSA server key pair can prevent malicious hacking of the key and enhance security of the SSH connections.
This command is only available to SSH1 clients.
The system does not update the DSA key pair periodically.
# Set the RSA server key pair update interval to 3 hours.
[Sysname] ssh server rekey-interval 3
display ssh server
ssh user
Use ssh user to create an SSH user and specify the service type and authentication method.
Use undo ssh user to delete an SSH user.
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign { pki-domain pkiname | publickey keyname } }
ssh user username service-type { all | scp | sftp } authentication-type { password | { any | password-publickey | publickey } assign { pki-domain pkiname | publickey keyname } work-directory directory-name }
undo ssh user username
3: Manage level
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters.
service-type: Specifies the service type for an SSH user:
·     all: Specifies Stelnet, SFTP, and SCP.
·     scp: Specifies the service type as SCP.
·     sftp: Specifies the service type as SFTP.
·     stelnet: Specifies the service type of Stelnet.
authentication-type: Specifies the authentication method of an SSH user.
·     password: Specifies password authentication. This authentication method features easy and fast encryption, but it is vulnerable. It can work with AAA to implement user authentication, authorization, and accounting.
·     any: Specifies either password authentication or publickey authentication.
·     password-publickey: Specifies both password authentication and publickey authentication (featuring higher security) if the client runs SSH2, and specifies either type of authentication if the client runs SSH1.
·     publickey: Specifies publickey authentication. This authentication method has the complicated and slow encryption, but it provides strong authentication that can defend against brute-force attacks. This authentication method is easy to use. If this method is configured, the authentication process completes automatically without the need of entering any password.
assign: Specifies parameters that are used to verify the client.
·     pki-domain pkiname: Specifies the PKI domain that verifies the client certificate. The pkiname argument is a case-insensitive string of 1 to 15 characters. The server uses the CA certificate that is saved in the PKI domain to verify one or multiple client certificates without saving clients' public keys in advance.
·     publickey keyname: Specifies the public key of the SSH user. The keyname argument represents an existing public key to an SSH user, and is a case-sensitive string of 1 to 64 characters. The server checks the validity of the user through the user's public key that has been locally saved. If the public key file on the client changes, the server needs to update the local configuration properly.
work-directory directory-name: Specifies the working directory for an SFTP or SCP user. The directory-name argument is a string of 1 to 135 characters.
If the SSH server uses publickey authentication, you must create an SSH user account on the device. If the SSH server uses password authentication, you do not need to create the user account on the device, but you must configure the user account information on the device for local authentication, or on the remote authentication server (such as a RADIUS server) for remote authentication.
If you use the ssh user command to specify a public key or PKI domain for a user multiple times, the most recent configuration takes effect.
You can change parameters for an SSH user that has logged in, but your changes take effect only on the user at next login.
If an SFTP or SCP user has been assigned a public key or PKI domain, it is necessary to set a working folder for the user.
The working folder of an SFTP or SCP user depends on the user authentication method:
·     If the authentication method is password, the working folder is the AAA authorized one.
·     If the authentication method is publickey or password-publickey, the working folder is the one set by using the ssh user command.
# Create an SSH user named user1, setting the service type as sftp, the authentication method as publickey, assigning a public key named key1 to the client, and the work folder of the SFTP server as flash:
[Sysname] ssh user user1 service-type sftp authentication-type publickey assign publickey key1 work-directory flash:
·     display ssh user-information
·     pki domain
SSH client configuration commands
bye
Use bye to terminate the connection with the SFTP server and return to user view.
bye
SFTP client view
3: Manage level
This command functions as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp-client> bye
Bye
Connection closed.
<Sysname>
cd
Use cd to change the working path on an SFTP server.
cd [ remote-path ]
SFTP client view
3: Manage level
remote-path: Specifies the name of a path on the server. If this argument is not specified, this command displays the current working path.
You can use the cd .. command to return to the upper-level directory.
You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp-client> cd new1
Current Directory is:
/new1
cdup
Use cdup to return to the upper-level directory.
cdup
SFTP client view
3: Manage level
# Return to the upper-level directory.
sftp-client> cdup
delete
Use delete to delete files from a server.
delete remote-file&<1-10>
SFTP client view
3: Manage level
remote-file&<1-10>: Specifies the names of files on the server. &<1-10> means that you can provide up to 10 file names, which are separated by spaces.
This command functions as the remove command.
# Delete the file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation might take a long time. Please wait...
File successfully Removed
dir
Use dir to display information about the files and subdirectories under a directory.
SFTP client view
3: Manage level
-a: Displays the names of the files and subdirectories under the specified directory.
-l: Displays the detailed information about the files and subdirectories under the specified directory in the form of a list.
remote-path: Specifies the name of the directory to be queried.
If none of the –a and –l keywords are specified, the command displays detailed information about the files and subdirectories under the specified directory in the form of a list.
If the remote-path argument is not specified, the command displays information about the files and subdirectories under the current working directory.
This command functions as the ls command.
# Display detailed information about the files and subdirectories under the current working directory in the form of a list.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
display sftp client source
Use display sftp client source to display the source IP address or source interface set for the SFTP client.
display sftp client source [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If neither source IP address nor source interface is specified for the SFTP client, the system displays the message "Neither source IP address nor source interface was specified for the SFTP client."
# Display the source IP address set for the SFTP client.
<Sysname> display sftp client source
The source IP address you specified is 192.168.0.1
sftp client source
display ssh client source
Use display ssh client source to display the source IP address or source interface information set for the Stelnet client.
display ssh client source [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If neither source IP address nor source interface is specified for the Stelnet client, the system displays the message "Neither source IP address nor source interface was specified for the Stelnet client."
# Display the source IP address or source interface set for the Stelnet client.
<Sysname> display ssh client source
ssh client source
display ssh server-info
Use display ssh server-info on a client to display mappings between SSH servers and their host public keys on an SSH client.
display ssh server-info [ | { begin | exclude | include } regular-expression ]
1: Monitor level
This command is also available on an SFTP client.
When an SSH client needs to authenticate the SSH server, it uses the locally saved public key of the server for the authentication. If the authentication fails, you can use this command to check the public key of the server saved on the client.
# Display the mappings between SSH servers and their host public keys on the client.
<Sysname> display ssh server-info
Server Name(IP)                 Server public key name
______________________________________________________
192.168.0.1                      abc_key01
192.168.0.2                      abc_key02
Server Name(IP)
Name or IP address of the server.
Name of the host public key of the server.
ssh client authentication server
exit
Use exit to terminate the connection with the remote SFTP server and return to user view.
exit
SFTP client view
3: Manage level
This command functions as the bye and quit commands.
sftp-client> exit
Bye
Connection closed.
<Sysname>
get
Use get to download a file from the SFTP server and save it locally.
SFTP client view
3: Manage level
remote-file: Specifies the name of a file on the SFTP server.
local-file: Name for the local file. If this argument is not specified, the file will be saved locally with the same name as that on the SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote  file:/temp1.c --->  Local file: temp.c
Downloading file successfully ended
help
Use help to display all commands or the help information of an SFTP client command.
help [ all | command-name ]
SFTP client view
3: Manage level
all: Displays all commands.
command-name: Specifies a command.
If none of the keyword and the argument are specified, the command displays a list of all commands.
# Display the help information of the get command.
sftp-client> help get
get remote-path [local-path]  Download file.Default local-path is the same
                              as remote-path
ls
Use ls to display file and folder information under a directory.
SFTP client view
3: Manage level
-a: Displays the file names and folder names of the specified directory.
-l: Displays in a list form detailed information of the files and folders of the specified directory.
If none of the –a and –l keywords are specified, the command displays detailed information of files and folders under the specified directory in the form of a list.
If the remote-path argument are not specified, the command displays the file and folder information under the current working directory.
This command functions as the dir command.
# Display detailed information about files and folders under the current working directory in the form of a list.
sftp-client> ls
mkdir
Use mkdir to create a directory on the SFTP server.
mkdir remote-path
SFTP client view
3: Manage level
remote-path: Specified the name for the directory on the SFTP server.
# Create a directory named test on the SFTP server.
sftp-client> mkdir test
New directory created
put
Use put to upload a local file to an SFTP server.
SFTP client view
3: Manage level
local-file: Specifies the name of a local file.
remote-file: Specifies the name for the file on an SFTP server. If this argument is not specified, the file will be saved remotely with the same name as the local one.
# Upload local file temp.c to the SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c --->  Remote file: /temp1.c
Uploading file successfully ended
pwd
Use pwd to display the current working directory of an SFTP server.
pwd
SFTP client view
3: Manage level
# Display the current working directory of the SFTP server.
sftp-client> pwd
Use quit to terminate the connection with an SFTP server and return to user view.
SFTP client view
3: Manage level
This command functions as the bye and exit commands.
sftp-client> quit
Bye
Connection closed.
<Sysname>
remove
Use remove to delete files from a remote server.
remove remote-file&<1-10>
SFTP client view
3: Manage level
remote-file&<1-10>: Specifies the names of files on an SFTP server. &<1-10> means that you can provide up to 10 file names, which are separated by spaces.
This command functions as the delete command.
# Delete file temp.c from the server.
sftp-client> remove temp.c
/temp.c
This operation might take a long time.Please wait...
rename
Use rename to change the name of the specified file or directory on an SFTP server.
rename oldname newname
SFTP client view
3: Manage level
oldname: Specifies the name of an existing file or directory.
newname: Specifies a new name for the file or directory.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
rmdir
Use rmdir to delete the specified directories from an SFTP server.
rmdir remote-path&<1-10>
SFTP client view
3: Manage level
remote-path&<1-10>: Specifies the names of directories on the remote SFTP server. &<1-10> means that you can provide up to 10 directory names that are separated by spaces.
# On the SFTP server, delete directory temp1 in the current directory.
sftp-client> rmdir temp1
Directory successfully removed
scp
Use scp to transfer files with an SCP server.
In non-FIPS mode:
scp [ ipv6 ] server [ port-number ] { get | put } source-file-path [ destination-file-path ] [ identity-key { dsa | rsa } | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
In FIPS mode:
scp [ ipv6 ] server [ port-number ] { get | put } source-file-path [ destination-file-path ] [ identity-key rsa | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] *
3: Manage level
ipv6: Specifies the type of the server as IPv6. If this keyword is not specified, the server is an IPv4 server.
server: Specifies a server by its IPv4 or IPv6 address or host name, a case-insensitive string of 1 to 255 characters.
port-number: Specifies the port number of the server, in the range of 0 to 65535. The default is 22.
get: Downloads the file.
put: Uploads the file.
source-file-path: Specifies the directory of the source file.
destination-file-path: Specifies the directory of the target file. If this argument is not specified, the directory names of the source and target files are same.
identity-key: Specifies the public key algorithm for the client, either dsa or rsa.
·     dsa: Specifies the public key algorithm dsa. This keyword is not supported in FIPS mode.
·     rsa: Specifies the public key algorithm rsa.
prefer-compress: Specifies the preferred compression algorithm. By default, the compression algorithm is not used.
·     zlib: Specifies the compression algorithm zlib.
·     zlib-openssh: Specifies the compression algorithm [email protected].
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm. The default is aes128.
·     3des: Specifies the encryption algorithm 3des-cbc. This keyword is not supported in FIPS mode.
·     aes128: Specifies the encryption algorithm aes128-cbc.
·     aes256: Specifies the encryption algorithm aes256-cbc. This keyword is only supported in FIPS mode.
·     des: Specifies the encryption algorithm des-cbc. This keyword is not supported in FIPS mode.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm. The default is sha1-96.
·     md5: Specifies the HMAC algorithm hmac-md5. This keyword is not supported in FIPS mode.
·     md5-96: Specifies the HMAC algorithm hmac-md5-96. This keyword is not supported in FIPS mode.
·     sha1: Specifies the HMAC algorithm hmac-sha1.
·     sha1-96: Specifies the HMAC algorithm hmac-sha1-96.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange.
·     dh-group-exchange: Specifies the key exchange algorithm diffie-hellman-group-exchange-sha1. This keyword is not supported in FIPS mode.
·     dh-group1: Specifies the key exchange algorithm diffie-hellman-group1-sha1. This keyword is not supported in FIPS mode.
·     dh-group14: Specifies the key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Specifies the preferred server-to-client encryption algorithm. The default is aes128.
prefer-stoc-hmac: Specifies the preferred server-to-client HMAC algorithm. The default is sha1-96.
When the client's authentication method is publickey, the client must get the local private key for digital signature. In non-FIPS mode, because the publickey authentication uses either RSA or DSA algorithm, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key.
The following table shows the default algorithms used in FIPS and non-FIPS modes:
Preferred algorithm
In non-FIPS mode
In FIPS mode
Public key algorithm
dsa
rsa
Preferred client-to-server encryption algorithm
aes128
aes128
Preferred client-to-server HMAC algorithm
sha1-96
sha1-96
Preferred key exchange algorithm
dh-group-exchange
dh-group14
Preferred server-to-client encryption algorithm
aes128
aes128
Preferred server-to-client HMAC algorithm
sha1-96
sha1-96
# Connect to the SCP server 192.168.0.1, download the file remote.bin from the server, and save it locally to the file local.bin
<Sysname> scp 192.168.0.1 get remote.bin local.bin
sftp
Use sftp to establish a connection to an IPv4 SFTP server and enter SFTP client view.
In non-FIPS mode:
sftp server [ port-number ] [ identity-key { dsa | rsa } | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
In FIPS mode:
sftp server [ port-number ] [ identity-key rsa | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] *
3: Manage level
server: Specifies a server by its IPv4 address or host name, a case-insensitive string of 1 to 20 characters.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange in non-FIPS mode and dh-group14 in FIPS mode.
Preferred algorithm
In non-FIPS mode
In FIPS mode
dsa
rsa
aes128
aes128
sha1-96
sha1-96
dh-group-exchange
dh-group14
aes128
aes128
sha1-96
sha1-96
# Connect to SFTP server 10.1.1.2, using the following connection scheme:
·     Preferred key exchange algorithm: dh-group1.
·     Preferred server-to-client encryption algorithm: aes128.
·     Preferred client-to-server HMAC algorithm: md5.
·     Preferred server-to-client HMAC algorithm: sha1-96.
<Sysname> sftp 10.1.1.2 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
sftp client ipv6 source
Use sftp client ipv6 source to specify the source IPv6 address or source interface for the SFTP client.
Use undo sftp client ipv6 source to remove the configuration.
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
An SFTP client uses the IPv6 address of the interface specified by the route of the device to access the SFTP server.
3: Manage level
interface interface-type interface-number: Specifies a source interface by its type and number.
ipv6 ipv6-address: Specifies a source IPv6 address.
To make sure the SFTP client and the SFTP server can communicate with each other, and to improve the manageability of SFTP clients in the authentication service, H3C recommends that you specify a loopback interface or dialer interface as the source interface.
# Specify the source IPv6 address of the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
Use sftp client source to specify the source IPv4 address or interface of an SFTP client.
Use undo sftp client source to remove the configuration.
sftp client source { interface interface-type interface-number | ip ip-address }
An SFTP client uses the IP address of the interface specified by the route of the device to access the SFTP server.
3: Manage level
ip ip-address: Specifies a source IPv4 address.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
Use sftp ipv6 to establish a connection to an IPv6 SFTP server and enter SFTP client view.
In non-FIPS mode:
sftp ipv6 server [ port-number ] [ identity-key { dsa | rsa } | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
In FIPS mode:
sftp ipv6 server [ port-number ] [ identity-key rsa | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] *
3: Manage level
server: Specifies a server by its IPv6 address or host name, a case-insensitive string of 1 to 46 characters.
·     md5-96: HMAC algorithm hmac-md5-96. This keyword is not supported in FIPS mode.
Preferred algorithm
In non-FIPS mode
In FIPS mode
dsa
rsa
aes128
aes128
sha1-96
sha1-96
dh-group-exchange
dh-group14
aes128
aes128
sha1-96
sha1-96
# Connect to server 2:5::8:9, using the following connection scheme:
<Sysname> sftp ipv6 2:5::8:9 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
Use ssh client authentication server on the client to configure the host public key of a server so that the client can determine whether the server is trustworthy.
Use undo ssh client authentication server to remove the configuration.
ssh client authentication server server assign publickey keyname
undo ssh client authentication server server assign publickey
No host public key of a server is configured. When the client logs into a server, it uses the IP address or host name of the server as the public key name.
2: System level
server: Specifies a server by IP address or host name, a string of 1 to 80 characters.
assign publickey keyname: Specifies the name of the host public key of the server, a string of 1 to 64 characters.
If the client does not support first-time authentication, it will reject unauthenticated servers. In this case, you need to configure the public keys of the servers and specify the mappings between public keys and servers on the client, so that the client uses the correct public key of a server to authenticate the server.
The specified host public key of the server must already exist.
# Configure the public key of the server at 192.168.0.1 to be key1.
[Sysname] ssh client authentication server 192.168.0.1 assign publickey key1
ssh client first-time enable
Use ssh client first-time enable to enable the first-time authentication function.
Use undo ssh client first-time to disable the function.
The function is enabled.
2: System level
Without first-time authentication, a client not configured with the server's host public key does not access the server. To access the server, a user must configure in advance the server's host public key locally and specify the public key name for authentication.
With first-time authentication, when an SSH client not configured with the server's host public key accesses the server for the first time, the user can continue accessing the server and save the server's host public key on the client. When accessing the server again, the client uses the saved server host public key to authenticate the server.
Because the server might update its key pairs periodically, a client must obtain the most recent host public key of the server for successful authentication of the server.
# Enable the first-time authentication function.
[Sysname] ssh client first-time enable
ssh client ipv6 source
Use ssh client ipv6 source to specify the source IPv6 address or source interface for the Stelnet client.
Use undo ssh client ipv6 source to remove the configuration.
An Stelnet client uses the IPv6 address of the interface specified by the route of the device to access the Stelnet server.
3: Manage level
To make sure the Stelnet client and the Stelnet server can communicate with each other, and to improve the manageability of Stelnet clients in the authentication service, H3C recommends that you specify a loopback interface or dialer interface as the source interface.
# Specify the source IPv6 address as 2:2::2:2 for the Stelnet client.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source
Use ssh client source to specify the source IPv4 address or source interface of the Stelnet client.
Use undo ssh client source to remove the configuration.
An Stelnet client uses the IP address of the interface specified by the route of the device to access the Stelnet server.
3: Manage level
# Specify the source IPv4 address of the Stelnet client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh2
Use ssh2 to establish a connection to an IPv4 Stelnet server and specify the public key algorithm, the preferred key exchange algorithm, and the preferred encryption algorithms and preferred HMAC algorithms between the client and server.
In non-FIPS mode:
ssh2 server [ port-number ] [ identity-key { dsa | rsa } | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
In FIPS mode:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key rsa | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] *
0: Visit level
Preferred algorithm
In non-FIPS mode
In FIPS mode
dsa
rsa
aes128
aes128
sha1-96
sha1-96
dh-group-exchange
dh-group14
aes128
aes128
sha1-96
sha1-96
# Log in to Stelnet server 10.214.50.51, using the following connection scheme:
<Sysname> ssh2 10.214.50.51 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
ssh2 ipv6
Use ssh2 ipv6 to establish a connection to an IPv6 Stelnet server and specify public key algorithm, the preferred key exchange algorithm, and the preferred encryption algorithms and preferred HMAC algorithms between the client and server.
In non-FIPS mode:
ssh2 ipv6 server [ port-number ] [ identity-key { dsa | rsa } | prefer-compress { zlib | zlib-openssh } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
In FIPS mode:
ssh2 ipv6 server [ port-number ] [ identity-key rsa | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] *
0: Visit level
Preferred algorithm
In non-FIPS mode
In FIPS mode
dsa
rsa
aes128
aes128
sha1-96
sha1-96
dh-group-exchange
dh-group14
aes128
aes128
sha1-96
sha1-96
# Log in to Stelnet server 2000::1, using the following connection scheme:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
