07-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Command Reference
11-SSL Commands
11-SSL Commands 93.24 KB
SSL configuration commands
ciphersuite
Use ciphersuite to specify the cipher suites supported by an SSL server policy.
In non-FIPS mode:
ciphersuite [ rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha ] *
In FIPS mode:
ciphersuite [ dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha ] *
An SSL server policy supports all cipher suites.
SSL server policy view
Default command level
2: System level
rsa_3des_ede_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 3DES_EDE_CBC, and the MAC algorithm of SHA.
rsa_aes_128_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit AES_CBC, and the MAC algorithm of SHA.
rsa_aes_256_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 256-bit AES_CBC, and the MAC algorithm of SHA.
rsa_des_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of DES_CBC, and the MAC algorithm of SHA.
rsa_rc4_128_md5: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of MD5.
rsa_rc4_128_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of SHA.
If you do not specify a cipher suite, the SSL server policy supports all cipher suites.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure SSL server policy policy1 to support cipher suites rsa_rc4_128_md5 and rsa_rc4_128_sha.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite rsa_rc4_128_md5 rsa_rc4_128_sha
display ssl server-policy
client-verify enable
Use client-verify enable to configure the SSL server to require the client to pass certificate-based authentication.
Use undo client-verify enable to restore the default.
The SSL server does not require certificate-based SSL client authentication.
2: System level
If you configure the client-verify enable command and enable the SSL client weak authentication function, whether the client must be authenticated is up to the client. If the client chooses to be authenticated, the client must pass authentication before accessing the SSL server. Otherwise, the client can access the SSL server without authentication.
If you configure the client-verify enable command but disable the SSL client weak authentication function, the SSL client must pass authentication before accessing the SSL server.
# Configure the SSL server to require certificate-based SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify enable
·     client-verify weaken
·     display ssl server-policy
Use client-verify weaken to enable SSL client weak authentication.
Use undo client-verify weaken to restore the default.
SSL client weak authentication is disabled.
2: System level
The client-verify weaken command takes effect only when the SSL server requires certificate-based client authentication.
If the SSL server requires certificate-based client authentication and the SSL client weak authentication function is enabled, whether the client must be authenticated is up to the client. If the client chooses to be authenticated, the client must pass authentication before accessing the SSL server. Otherwise, the client can access the SSL server without authentication.
If the SSL server requires certificate-based client authentication and SSL client weak authentication is disabled, the SSL client must pass authentication before accessing the SSL server.
# Enable SSL client weak authentication.
[Sysname-ssl-server-policy-policy1] client-verify weaken
·     client-verify enable
close-mode wait
Use close-mode wait to set the SSL connection close mode to wait mode. In this mode, after sending a close-notify alert message to a client, the server does not close the connection until it receives a close-notify alert message from the client.
Use undo close-mode wait to restore the default.
close-mode wait
An SSL server sends a close-notify alert message to the client and closes the connection without waiting for the close-notify alert message from the client.
2: System level
# Set the SSL connection close mode to wait.
[Sysname-ssl-server-policy-policy1] close-mode wait
display ssl client-policy
Use display ssl client-policy to view information about one or all SSL client policies.
display ssl client-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 16 characters.
all: Displays information about all SSL client policies.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL Client Policy: policy1
     SSL Version: SSL 3.0
     PKI Domain: 1
     Prefer Ciphersuite:
         RSA_RC4_128_SHA
     Server-verify: enabled
SSL Client Policy
SSL client policy name.
SSL Version
Version of the protocol used by the SSL client policy: SSL 3.0 or TLS 1.0.
PKI Domain
PKI domain of the SSL client policy.
Prefer Ciphersuite
Preferred cipher suite of the SSL client policy.
Server-verify
Whether server authentication is enabled for the SSL client policy.
Use display ssl server-policy to view information about one or all SSL server policies.
display ssl server-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 16 characters.
all: Displays information about all SSL server policies.
# Display information about SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL Server Policy: policy1
     PKI Domain: domain1
     Ciphersuite:
         RSA_RC4_128_MD5
         RSA_RC4_128_SHA
         RSA_DES_CBC_SHA
         RSA_3DES_EDE_CBC_SHA
         RSA_AES_128_CBC_SHA
         RSA_AES_256_CBC_SHA
     Handshake Timeout: 3600
     Close-mode: wait disabled
     Session Timeout: 3600
     Session Cachesize: 500
     Client-verify: disabled
     Client-verify weaken: disabled
SSL Server Policy
SSL server policy name.
PKI Domain
PKI domain used by the SSL server policy.
If no PKI domain is specified for the SSL server policy, nothing is displayed for this field, and the SSL server generates and signs a certificate for itself and does not obtain a certificate from a CA server.
Ciphersuite
Cipher suites supported by the SSL server policy.
Handshake Timeout
Handshake timeout time of the SSL server policy, in seconds.
Close-mode
Close mode of the SSL server policy:
·     wait disabled—In this mode, the server sends a close-notify alert message to the client and then closes the connection immediately without waiting for the close-notify alert message of the client.
·     wait enabled—In this mode, the server sends a close-notify alert message to the client and then waits for the close-notify alert message of the client. The server closes the connection only after receiving the expected message.
Session Timeout
Session timeout time of the SSL server policy, in seconds.
Session Cachesize
Maximum number of buffered sessions of the SSL server policy.
Client-verify
Whether the SSL server policy requires the client to be authenticated.
handshake timeout
Use handshake timeout to set the handshake timeout time for an SSL server policy.
Use undo handshake timeout to restore the default.
The handshake timeout time is 3600 seconds.
2: System level
time: Specifies the handshake timeout time in seconds. The range is 180 to 7200.
If the SSL server receives no packet from the SSL client before the handshake timeout time expires, the SSL server terminates the handshake process.
# Set the handshake timeout time to 3000 seconds for SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] handshake timeout 3000
pki-domain
Use pki-domain to specify a PKI domain for an SSL server policy or SSL client policy.
Use undo pki-domain to restore the default.
pki-domain domain-name
undo pki-domain
No PKI domain is configured for an SSL server policy or SSL client policy.
SSL server policy view, SSL client policy view
2: System level
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 15 characters.
If you do not specify a PKI domain for an SSL server policy, the SSL server generates and signs a certificate for itself rather than obtaining one from a CA server.
# Configure SSL server policy policy1 to use PKI domain server-domain.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
# Configure SSL client policy policy1 to use PKI domain client-domain.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
·     display ssl client-policy
prefer-cipher
Use prefer-cipher to specify the preferred cipher suite for an SSL client policy.
Use undo prefer-cipher to restore the default.
In non-FIPS mode:
prefer-cipher { rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
In FIPS mode:
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha }
undo prefer-cipher
The preferred cipher suite for an SSL client policy is rsa_rc4_128_md5.
2: System level
# Set the preferred cipher suite to rsa_aes_128_cbc_sha for SSL client policy policy1.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
server-verify enable
Use server-verify enable to enable certificate-based SSL server authentication so that the SSL client authenticates the server by the server’s certificate during the SSL handshake process.
Use undo server-verify enable to disable certificate-based SSL server authentication. When certificate-based SSL server authentication is disabled, it is assumed that the SSL server is valid.
Certificate-based SSL server authentication is enabled.
2: System level
# Enable certificate-based SSL server authentication.
[Sysname-ssl-client-policy-policy1] server-verify enable
session
Use session to set the maximum number of cached sessions and the caching timeout time.
Use undo session to restore the default.
undo session { cachesize | timeout } *
The maximum number of cached sessions is 500, and the caching timeout time is 3600 seconds.
2: System level
cachesize size: Specifies the maximum number of cached sessions. The range is 100 to 1000.
timeout time: Specifies the caching timeout time in seconds. The range is 1800 to 72000.
It is a complicated process to use the SSL handshake protocol to negotiate session parameters and establish sessions. To simplify the process, SSL allows reusing negotiated session parameters to establish sessions. This feature requires that the SSL server maintain information about existing sessions.
The number of cached sessions and the session information caching time are limited:
·     If the number of sessions in the cache reaches the maximum, SSL rejects the caching of new sessions.
·     If a session has been cached for a period equal to the caching timeout time, SSL removes the information of the session.
# Set the caching timeout time to 4000 seconds and the maximum number of cached sessions to 600.
[Sysname-ssl-server-policy-policy1] session timeout 4000 cachesize 600
ssl client-policy
Use ssl client-policy to create an SSL policy and enter its view.
Use undo ssl client-policy to delete a specified SSL client policy or all SSL client policies.
ssl client-policy policy-name
undo ssl client-policy { policy-name | all }
2: System level
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 16 characters, which cannot be a, al, or all.
all: Specifies all SSL client policies.
# Create SSL client policy policy1 and enter its view.
ssl server-policy
Use ssl server-policy to create an SSL server policy and enter its view.
Use undo ssl server-policy to delete a specified SSL server policy or all SSL server policies.
ssl server-policy policy-name
undo ssl server-policy { policy-name | all }
2: System level
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 16 characters, which cannot be a, al, or all.
all: Specifies all SSL server policies.
You cannot delete an SSL server policy that has been associated with one or more application layer protocols.
# Create SSL server policy policy1 and enter its view.
ssl version ssl3.0 disable
Use ssl version ssl3.0 disable to disable SSL 3.0 on the device.
Use undo ssl version ssl3.0 disable restore the default.
The device supports SSL 3.0.
2: System level
Use this command to disable SSL 3.0 on a device to enhance system security.
·     An SSL server supports only TLS 1.0 after SSL 3.0 is disabled.
·     An SSL client always uses SSL 3.0 if SSL 3.0 is specified for the client policy, whether you disable SSL 3.0 or not.
To ensure successful establishment of an SSL connection, do not disable SSL 3.0 on a device when the peer device only supports SSL 3.0. H3C recommends upgrading the peer device to support TLS 1.0 to improve security.
# Disable SSL 3.0 on the device.
[Sysname] ssl version ssl3.0 disable
version
Use version to specify the SSL protocol version for an SSL client policy.
Use undo version to restore the default.
In non-FIPS mode:
version { ssl3.0 | tls1.0 }
undo version
In FIPS mode:
version tls1.0
undo version
The SSL protocol version for an SSL client policy is TLS 1.0.
2: System level
ssl3.0: Specifies SSL 3.0.
tls1.0: Specifies TLS 1.0.
# Set the SSL protocol version to SSL 3.0 for SSL client policy policy1.
[Sysname-ssl-client-policy-policy1] version ssl3.0
