H3C S9500 Operation Manual-Release1648[v1.24]-01 Access Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-01 Access Volume
11-Ethernet OAM Configuration
11-Ethernet OAM Configuration 171.54 KB
Chapter 1  Ethernet OAM Configuration
When configuring Ethernet OAM, go to these sections for information you are interested in:
l           Ethernet OAM Overview
l           Configuring OAM
l           Displaying and Maintaining OAM
l           OAM Configuration Example
1.1  Ethernet OAM Overview
Operations, administration and maintenance (OAM) is a Layer 2 protocol, used to monitor and solve network problems. OAM can report the network state at the data link layer so that a network administrator can manage the network effectively. Currently, OAM is used to solve OAM problems on Ethernet equipment in the last mile. It can monitor link performance, monitor faults and generate alarms, perform loopback test, and send remote MIB variable requests.
OAM serves as a universal mechanism of interoperation and inter-maintenance between Ethernet equipment. The basic operations include establishing OAM connection, monitoring links, diagnosing remote faults, performing a remote loopback, and sending remote MIB variable requests.
&  Note:
Table 1-1 lists the cards that support unidirectional link fault events and remote loopback defined by OAM.
Table 1-1 Cards supporting OAM features
Name
Support the link fault event or not (packet delivery ratio when a unidirectional link presents)
Support remote loopback or not
LSB1GP12
12-port Gigabit Ethernet optical interface card
Yes (1%)
No
LSB1GT12
12-port Gigabit Ethernet electrical interface card
No
Yes
LSB1GT24
24-port Gigabit Ethernet electrical interface card
No
Yes
LSB1GP24
24-port Gigabit Ethernet optical interface card
Yes (1%)
No
LSB1GV48
48-port Gigabit Ethernet electrical interface card-1:4-POE
No
Yes
LSB1GP48
48-port Gigabit Ethernet optical interface card-1:4
Yes (1%)
No
LSB1XK1
1-port 10GE optical interface card
Yes (100%)
No
LSB1XP2
2-port 10GE optical interface card
Yes (100%)
No
LSB1XP4L
4-port 10GE optical interface card
Yes (100%)
No
LSB1AHP4G
2-port OC-3-ATM + 2-port OC-3/12-ATM + 8-port Gigabit optical interface card
Yes (1%)
No
LSB1CLP4G
4-port channelized OC-3-POS + 4-port Gigabit interface card
Yes (1%)
No
LSB1ET32G
32-port channelized E1/T1 electrical interface + 4-port Gigabit optical interface card
Yes (1%)
No
LSB1F32G
32-port fast Ethernet electrical interface + 4-port Gigabit Ethernet optical interface card
Yes (1%)
No
LSB1P4G8
4-port OC-3c POS optical interface + 8-port Gigabit optical interface card
Yes (1%)
No
LSB1GT8P
8-port Gigabit electrical interface + 4-port Gigabit optical interface card (B)
Yes (1%)
Yes
LSB1FW8
Firewall card with eight Gigabit optical interfaces
Yes (1%)
No
LSB1IPSEC8
IPSec card with eight Gigabit optical interfaces
Yes (1%)
No
LSB1XP4
4-port 10 GE optical interface card-1:2
No
No
LSB1FP20
20-port 100 Mbps optical Ethernet interface board
Yes (100%)
No
1.1.1  Establishing OAM Connection
OAM connection is established in the OAM discovery phase. Through OAM connection, interconnected equipment can exchange OAM configuration information and announce the OAM capabilities supported by a local node.
The equipment can establish OAM connection in the active mode or in the passive mode. Table 1-2 compares the processing capabilities of data terminal entity (DTE) in the passive and active mode.
Table 1-2 Comparison between processing capabilities of active DTE and passive DTE
Processing capability
Active DTE
Passive DTE
Initialize OAM discovery
Yes
No
Respond to the initialization of OAM discovery
Yes
Yes
Send information OAM protocol data unit (OAMPDU)
Yes
Yes
Send event notification PDUs
Yes
Yes
Send loopback OAMPDUs
Yes
No
Send information OAMPDUs without TLV
Yes
Yes
Send variable request OAMPDUs
Yes
No
Send variable response OAMPDUs
Yes, but the peer DTE is required to be in the active mode.
Yes
Send loopback control OAMPDUs
Yes
No
Respond to loopback control OAMPDUs
Yes
Send organization specific OAMPDUs
Yes
Yes
If OAM configurations at both ends are consistent, OAM operation begins at the data link layer.
1.1.2  Link Monitor
Through link monitor, you can detect and find faults in various environments at the data link layer. Link monitor uses event notification PDUs. When a link fault occurs, the local link notifies the OAM entity of the fault after detecting the fault. The following table defines standard link events.
Table 1-3 Standard link events
Definition
Error signal event
The number of error signals within a fixed period of time exceeds the defined threshold.
Errored frame event
The number of errored frames within a fixed period of time exceeds the defined threshold.
Errored frame period event
The number of errored frames received within the period of N frames exceeds the defined threshold.
Errored frame seconds event
The number of error seconds within M seconds exceeds the defined threshold.
802.3ah does not guarantee that all OAMPDUs can be sent successfully. An event notification OAMPDU should be sent multiple times to handle the packet loss situation and a counting sequence number is used to identify each OAMPDU to be sent.
1.1.3  Diagnosing Remote Faults
Ethernet faults are difficult to diagnose, especially when physical communication is still maintained but network performance is decreasing gradually. OAMPDU defines a flag to allow an OAM entity to send information to the peer. The flag defines an emergency link event supported by OAM. Currently, OAM defines the link fault event, which occurs when the local end can send data, but cannot receive data. In this case, OAMPDUs are sent once every second.
1.1.4  Remote Loopback
A local OAM entity can send a remote loopback OAMPDU to the remote OAM entity, requesting the remote OAM entity to perform loopback. This function can provide necessary help for troubleshooting.
In the loopback mode, all packets except OAMPDUs and pause packets are returned along the way they are sent. Periodical loopback detection can guarantee that current links are smooth. Loopback detection in phases can help you locate specific areas where faults occur.
1.1.5  Remote MIB Variable Request
A local OAM entity can send a remote MIB request OAMPDU to the remote OAM entity, requesting the remote OAM entity to notify the local end of the current MIB variable. This function can be used to periodically monitor the link state of the remote port.
1.1.6  OAMPDU
The formats of OAMPDUs are as follows.
Figure 1-1 OAMPDU formats
This document involves the following packets:
I. Information OAMPDU
The information OAMPDU is used to send state information, such as local information, remote information, and user-defined information, to the remote OAM entity for maintaining OAM connection.
II. Event notification OAMPDU
The event notification OAMPDU is used for link monitoring and is used to notify the remote OAM entity that a fault has occurred to the link.
III. Var request OAMPDU
The Var request OAMPDU is used for variable request, primarily for MIB variables request.
IV. Var response OAMPDU
The Var response OAMPDU is used for responding to variable requests. This packet is used for returning MIB values.
V. Loopback control OAMPDU
The loopback control OAMPDU is used for remote loopback control. The device can determine whether to send the packet. To implement loopback control, the local DTE sends the loopback control command to the remote DTE. If loopback control is enabled on the remote DTE, the remote DTE returns the packet to the sending entity directly.
1.2  Configuring OAM
Complete the following tasks to configure OAM:
l           Setting OAM Mode
l           Enabling OAM
l           Configuring the Error Signal Detection Interval and Error Threshold
l           Configuring the Error Frame Detection Interval and Error Threshold
l           Configuring the Error Frame Period Detection Interval and Error Threshold
l           Configuring the Error Frame Second Detection Interval and Error Threshold
l           Enabling/Disabling OAM Remote Loopback
l           Setting the Interval for Sending OAM Hello PDUs
l           Setting the OAM Link Timeout Time
1.2.1  Setting OAM Mode
Follow these steps to configure the OAM mode for the current port:
To do …
Use the command …
Remarks
Enter system view
Enter Ethernet port view
Set OAM mode
oam ethernet mode { active | passive }
Optional
By default, OAM is set to the passive mode.
&  Note:
l      The OAM entity in the active mode can initiate an OAM connection, while the OAM entity in the passive mode can only wait for the connection request sent from the opposite OAM entity.
l      You cannot establish an OAM connection between two OAM entities in the passive mode.
l      After the OAM function is enabled by entering the oam ethernet enable command, you are not allowed to change the OAM mode. If needed, you can first disable the OAM, then change the OAM mode, and finally enable OAM again.
1.2.2  Enabling OAM
Follow these steps to enable OAM on an Ethernet port:
To do …
Use the command …
Remarks
Enter system view
Enable OAM on the current port
oam ethernet enable
Required
After OAM is enabled, the current Ethernet port starts to establish OAM connection with the peer entity in the preset mode.
OAM is disabled by default.
1.2.3  Configuring the Error Signal Detection Interval and Error Threshold
Follow these steps to configure the error signal detection interval and the error threshold for creating an error signal event:
To do …
Use the command …
Remarks
Enter system view
Configure the error signal detection interval
oam ethernet errored-symbol period period-value
Optional
The default is 1 second.
Configure the error threshold for creating an error signal event
oam ethernet errored-symbol threshold threshold-value
Optional
The default is 1.
Display the configuration information
display oam ethernet configuration
Available in any view
&  Note:
l      If the number of error signals detected on a port over a detection interval is equal to or greater than the error threshold, an error signal event is created.
l      After the OAM connection is established, the configured values take effect on all the Ethernet ports automatically.
1.2.4  Configuring the Error Frame Detection Interval and Error Threshold
Follow these steps to configure the error frame detection interval and the threshold for creating an error frame event:
To do …
Use the command …
Remarks
Enter system view
Configure the error frame detection interval
oam ethernet errored-frame period period-value
Optional
Configure the error threshold for creating an error frame event
oam ethernet errored-frame threshold threshold-value
Optional
The default is 1.
&  Note:
l      If the number of error frames detected on a port over a detection interval is equal to or greater than the error threshold, an error frame event is created.
1.2.5  Configuring the Error Frame Period Detection Interval and Error Threshold
Follow these steps to configure the error frame period detection interval and the error threshold for creating an error frame period event:
To do …
Use the command …
Remarks
Enter system view
Configure the error frame period detection interval
oam ethernet errored-frame-period period period-value
Optional
Configure the error threshold for creating an error frame period event
oam ethernet errored-frame-period threshold threshold-value
Optional
The default is 1.
&  Note:
l      The system converts the configured interval to the maximum number of packets that a port can send over this interval, that is, the maximum number of packets sent serves as the interval.
l      If the number of error frames detected on a port over a detection interval is equal to or greater than the error threshold, an error frame period event is created.
1.2.6  Configuring the Error Frame Second Detection Interval and Error Threshold
Follow these steps to configure the error frame second detection interval and the error threshold for creating an error frame second event:
To do …
Use the command …
Remarks
Enter system view
Configure the error frame second detection interval
oam ethernet errored-frame-seconds period period-value
Optional
The default is 60 seconds.
Configure the error threshold for creating an error frame second event
oam ethernet errored-frame-seconds threshold threshold-value
Optional
The default is 1.
&  Note:
l      Error frame seconds are the seconds within which error frames are detected.
l      The threshold value should not be greater than the corresponding interval; otherwise, no error frame second event can be created.
l      If the number of error frame seconds detected on a port over a detection interval is equal to or greater than the error threshold, an error frame second event is created.
1.2.7  Enabling/Disabling OAM Remote Loopback
Follow these steps to perform or remove an OAM remote loopback:
To do …
Use the command …
Remarks
Enter system view
Enable OAM remote loopback
oam ethernet loopback
Optional
OAM remote loopback is disabled by default.
Disable OAM remote loopback
undo oam ethernet loopback
Optional
display oam ethernet loopback status
&  Note:
l      The oam ethernet loopback command just triggers loopback, and buildrun is not performed.
l      You can perform remote loopback only after establishing the OAM connection; otherwise the system will give an error prompt.
l      Remote loopback needs the support of remote hardware. If the remote hardware does not support remote loopback, the system gives a prompt message.
l      OAM remote loopback is used to test a single link. It is not supported on aggregated ports. Ports in remote loopback are not allowed to join aggregation.
1.2.8  Setting the Interval for Sending OAM Hello PDUs
Follow these steps to set the interval for sending OAM hello PDUs:
To do …
Use the command …
Remarks
Enter system view
Set the interval for sending OAM hello PDUs
oam ethernet timer hello interval
Optional
By default, the interval for sending OAM hello PDUs is 1,000 ms.
display oam ethernet local
Available in any view.
1.2.9  Setting the OAM Link Timeout Time
Follow these steps to set the OAM link timeout time:
To do …
Use the command …
Remarks
Enter system view
Set the OAM link timeout time
oam ethernet timer keepalive interval
Optional
By default, the OAM link timeout time is 5000 ms.
&  Note:
After an OAM link times out, the local end of the Ethernet OAM will age out its connection to the remote OAM entity, resulting in disconnection of the OAM link. In normal conditions, you are recommended to set the timeout time to be longer than the interval for sending Ethernet OAM hello PDUs. Otherwise, a link may disconnect before Ethernet OAM hello PDUs are received, thus causing link instability.
1.3  Displaying and Maintaining OAM
To do …
Use the command …
Remarks
Display global configuration information of OAM
Display the statistics about the link events after an OAM sub-layer reset or clear of the statistics
display oam ethernet link-event { local | remote } [ interface interface-type interface-number ]
Display the statistics about link events after the establishment of the OAM connection
display oam ethernet critical-event [ interface interface-type interface-number ]
Display the information of the OAM connection
display oam ethernet { local | remote } [ interface interface-type interface-number ]
Clear the statistics about Ethernet OAMPDUs and link events
reset oam ethernet [ interface interface-type interface-number ]
Available in user view
Display the variable information on the peer entity
display oam ethernet remote variable interface interface-type interface-number
&  Note:
When specifying a port in any of the commands in this section, note that the interface-type argument must be Ethernet or GigabitEthernet and the interface-number argument must take the form of slot number/port number.
1.4  OAM Configuration Example
I. Network requirements
l           Enable the OAM protocol on switches to manage the data link layer.
l           Verify link performance by observing error frames received by the switches.
II. Network diagram
Figure 1-2 Network diagram for OAM configuration
III. Configuration procedure
1)         Configure Switch A
# Set Ethernet 1/1/1 in the Passive mode, and then enable OAM.
<H3C>system-view
[H3C] interface ethernet 1/1/1
[H3C-Ethernet1/1/1] oam ethernet mode passive
[H3C-Ethernet1/1/1] oam ethernet enable
[H3C-Ethernet1/1/1] quit
# Configure the error frame detection interval.
[H3C] oam ethernet errored-frame period 20
# Configure the error threshold for creating an error frame event.
[H3C] oam ethernet errored frame threshold 10
# Display the global configuration information of OAM
[H3C] display oam ethernet configuration
Configuration of the link event window/threshold : (s = seconds, f = frames, ms= milliseconds)
Errored-symbol Event period           :         1(s)
Errored-symbol Event threshold        :         1(f)
Errored-frame Event period            :         20(s)
Errored-frame Event threshold         :         10(f)
Errored-frame-period Event period     :      1000(ms)
Errored-frame-period Event threshold  :         1(f)
Errored-frame-seconds Event period    :        60(s)
Errored-frame-seconds Event threshold :         1(s)
2)         Configure Switch B
# Enable OAM on Ethernet 1/1/1. The default OAM mode is Active.
<H3C> system-view
# Display the statistics about link events.
[H3C] display oam ethernet link-event remote
Port        : Ethernet1/1/1
Link Status : Up
OAMRemoteErrFrameEvent : (s = seconds, f = frames, t = times)
Event Time Stamp        :       5619(s) Errored Frame Window :         20(s)
Errored Frame Threshold :         10(f) Errored Frame        :    1243635(f)
Error Running Total     :   85887789(f) Event Running Total  :         57(t)
