H3C S9500 Operation Manual-Release1648[v1.24]-01 Access Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-01 Access Volume
01-Ethernet Port Configuration
01-Ethernet Port Configuration 113.21 KB
Table of Contents
Chapter 1 Ethernet Port Configuration. 1-1
1.1 Ethernet Port Overview. 1-1
1.2 Ethernet Port Configuration. 1-1
1.2.1 Entering Ethernet Port View. 1-2
1.2.2 Enabling/Disabling an Ethernet Port 1-2
1.2.3 Setting Ethernet Port Description. 1-2
1.2.4 Setting the Duplex Attribute of an Ethernet Port 1-2
1.2.5 Setting Speed on the Ethernet Port 1-3
1.2.6 Setting the Cable Type for the Ethernet Port 1-4
1.2.7 Enabling/Disabling Flow Control for the Ethernet Port 1-5
1.2.8 Setting the Interval for Performing Statistics on the Port 1-5
1.2.9 Permitting/Denying Jumbo Frames. 1-6
1.2.10 Setting Broadcast/Multicast Suppression on an Ethernet Port 1-6
1.2.11 Setting the Network Mode of an Ethernet Port 1-7
1.2.12 Setting the Link Type for the Ethernet Port 1-8
1.2.13 Adding the Ethernet Port to Specified VLANs. 1-9
1.2.14 Setting the Default VLAN ID for the Ethernet Port 1-9
1.2.15 Setting the VLAN VPN Feature on a Port 1-10
1.2.16 Enabling/Disabling the VLAN Filtering Function on an Ethernet Port 1-11
1.2.17 Copying Port Configurations to Other Ports. 1-11
1.2.18 Setting the Link-State Hold Time. 1-13
1.2.19 Setting the Ethernet Port in Loopback Mode. 1-14
1.3 Displaying and Maintaining Ethernet Port Configuration. 1-14
1.4 Ethernet Port Configuration Example. 1-15
1.5 Troubleshooting Ethernet Ports. 1-16
When configuring an Ethernet port, go to these sections for information you are interested in:
l           Ethernet Port Overview
l           Ethernet Port Configuration
l           Displaying and Maintaining Ethernet Port Configuration
l           Ethernet Port Configuration Example
l           Troubleshooting Ethernet Ports
The S9500 series can provide conventional Ethernet ports, fast Ethernet ports, 1,000 Mbps Ethernet ports and 10 Gbps Ethernet ports. The configurations of these Ethernet ports are basically the same, which will be described in the following sections.
Complete the following tasks to configure an Ethernet port:
l           Entering Ethernet Port View
l           Enabling/Disabling an Ethernet Port
l           Setting Ethernet Port Description
l           Setting the Duplex Attribute of an Ethernet Port
l           Setting Speed on the Ethernet Port
l           Setting the Cable Type for the Ethernet Port
l           Enabling/Disabling Flow Control for the Ethernet Port
l           Setting the Interval for Performing Statistics on the Port
l           Permitting/Denying Jumbo Frames
l           Setting Broadcast/Multicast Suppression on an Ethernet Port
l           Setting the Network Mode of an Ethernet Port
l           Setting the Link Type for the Ethernet Port
l           Adding the Ethernet Port to Specified VLANs
l           Setting the Default VLAN ID for the Ethernet Port
l           Setting the VLAN VPN Feature on a Port
l           Enabling/Disabling the VLAN Filtering Function on an Ethernet Port
l           Copying Port Configurations to Other Ports
l           Setting the Link-State Hold Time
l           Setting the Ethernet Port in Loopback Mode
Before configuring an Ethernet port, enter Ethernet port view first.
Perform the following configuration in system view.
To do …
Use the command …
Enter Ethernet port view
After configuring the related parameters and protocol of the port, you can use undo shutdown command to enable the port. If you do not want a port to forward data any more, use shutdown command to disable it.
Perform the following configuration in Ethernet port view.
To do ...
Use the command …
Disable an Ethernet port
shutdown
Enable an Ethernet port
By default, the port is enabled.
To distinguish Ethernet ports, you can use the following command to make some necessary descriptions.
To do …
Use the command …
Configure an Ethernet port description
Delete the Ethernet port description
By default, an Ethernet port has no description.
To configure a port to send and receive data packets at the same time, set it to full-duplex. To configure a port to either send or receive data packets at a time, set it to half-duplex. If the port has been set to auto-negotiation mode, the local and peer ports will automatically negotiate the duplex mode.
To do …
Use the command …
Set duplex attribute for the Ethernet port
duplex { auto | full | half }
Restore the default duplex attribute of the Ethernet port
undo duplex
10/100 Mbps electrical Ethernet ports can operate in full-duplex, half-duplex or auto-negotiation mode, so can a 10/100/1,000 Mbps electrical Ethernet port. However, when the port rate is set to 1,000 Mbps or auto, the duplex mode of the port can only be set to full (full duplex) or auto (auto-negotiation). A 100 Mbps/1,000 Mbps optical Ethernet port operates in full duplex mode even if it is configured to operate in the auto-negotiation mode. A 10 Gbps optical Ethernet port can only operate in full duplex mode.
The duplex mode of Ethernet ports defaults to auto (auto-negotiation).
  Caution:
l      For ports coupled with photoelectric transducers, set the duplex mode to auto-negotiation mode. Otherwise, the status check for the port may be abnormal.
l      Only the GP48 interface board offers 100/1000 Mbps optical ports. By default, such an optical port operates at 1000 Mbps in full-duplex mode. If its rate is configured as 100 Mbps, you are recommended to configure it to operate in full-duplex mode. Otherwise, the auto-negotiation information of the port will be wrong.
l      Only the GP48 interface board supports speed (10/100/1000 Mbps) and duplex mode auto-negotiation for photoelectric transceiver modules. For the function to work, you must ensure that the modules are 1000_BASE_T photoelectric transceiver modules certified by H3C.
You can use the following command to set the speed on the Ethernet port. If the speed is set to auto-negotiation mode, the local and peer ports will automatically negotiate the port speed.
To do …
Use the command …
Set Ethernet port speed
speed { 10 | 100 | 1000 | 10000 | auto }
Restore the default speed on the Ethernet port
undo speed
The speed options in the command are available depending on the type and duplex mode of the port. For example, for 10/100/1,000 Mbps electrical ports, 10 Mbps, 100 Mbps, and 1,000 Mbps are available. You can select a proper port speed as needed. However, when the duplex mode is changed to half duplex, the port speed cannot be set to 1,000 Mbps or auto.
The 10/100 Mbps electrical Ethernet port can operate at 10 Mbps, 100 Mbps and in auto mode. You can set it accordingly.
The 10/100/1,000 Mbps electrical Ethernet port can operate at 10 Mbps, 100 Mbps, or 1,000 Mbps. However in half duplex mode, the port cannot operate at 1,000 Mbps or in auto mode. The 100 Mbps optical Ethernet port supports 100 Mbps; the 1,000 Mbps optical Ethernet port supports 1,000 Mbps; a 10 Gbps optical Ethernet port only supports 10 Gbps.
By default, the speed of the port is in auto mode.
  Caution:
The Ethernet port supports straight-through and cross-over network cables. The following command can be used for configuring the cable type.
To do …
Use the command …
Set the type of the cable connected to the Ethernet port
mdi { across | auto | normal }
Restore the default type of the cable connected to the Ethernet port
undo mdi
&  Note:
l      The settings only take effect on 10/100 Mbps and 10/100/1000 Mbps electrical ports.
l      10Gbps Ethernet ports support optical fiber only.
By default, the cable type is auto (auto-recognized). That is, the system can automatically recognize the type of the cable connecting to the port.
After enabling flow control in both the local and the peer switch, if congestion occurs in the local switch, the switch will inform its peer to pause packet sending. Once the peer switch receives this message, it will pause sending packets to the local switch, and vice versa. In this way, packet loss is reduced effectively. The flow control function of the Ethernet port can be enabled or disabled through the following command.
To do …
Use the command …
Enable Ethernet port flow control
flow-control
Disable Ethernet port flow control
undo flow-control
By default, Ethernet port flow control is disabled.
Follow these steps to set the interval for performing statistics on the port:
To do …
Use the command …
Remarks
Enter system view
Enter Ethernet port view/POS port view
Required
The interface-type argument is the Ethernet or POS port type.
Set the interval for performing statistics on the port
flow-interval interval
Required
300 seconds by default
During large throughput data switching, like in file transmission, a card may encounter jumbo frames larger than the standard Ethernet frame length. You may configure the device to permit them to pass the card or deny them.
To do …
Use the command …
Enable Jumbo frames to pass the card on a specified slot, and set the maximum length of Jumbo frames allowed to pass the card
jumboframe enable [ jumboframe-value ] slot slot-number
Disable Jumbo frames from passing the card on a specified slot
jumboframe disable slot slot-number
By default, jumbo frames are allowed to pass.
&  Note:
l      The system supports discrete Jumbo frame sizes ranging from 1,552 to 10,240. However, effective Jumbo frame values fall into several sections: the effective Jumbo frame sizes for the 1,552-9,022 section are 1,552 and 9,022, that for the 9,023-9,192 section is 9,192, and that for the 9,193-10,240 section is 10,240.
l      For XP4 LPUs that are not of wire speed, only the jumbo frame value 10,236 is supported, while all the other GE LPUs and 10GE LPUs support the jumbo frame value 10,240. LSB1GV48 LPUs support only the jumbo frame value 10,236, and LSB2FT48C0 LPUs support only the jumbo frame value 1,552.
To prevent port congestion resulting from broadcast/multicast packet flooding, the switch supports broadcast/multicast suppression. You can enable broadcast/multicast suppression by setting a suppression triggering speed percentage or bandwidth threshold.
To do …
Use the command …
Configure broadcast suppression on the Ethernet port
broadcast-suppression { ratio | bandwidth bandwidth }
Restore the default setting of broadcast suppression on the Ethernet port
undo broadcast-suppression
Configure multicast suppression on the Ethernet port
multicast-suppression { ratio | bandwidth bandwidth }
Restore the default setting of multicast suppression on the Ethernet port
undo multicast-suppression
  Caution:
l      You cannot enable both broadcast suppression and multicast suppression simultaneously on the same card. Namely, once you have enabled broadcast suppression on some ports of a card, you cannot enable multicast suppression on the other ports of the card, and vice versa.
l      To modify the broadcast/multicast suppression triggering threshold in the percentage form on a port, make sure all the ports on a board adopt the default suppression triggering threshold in the percentage form.
l      When broadcast/multicast suppression is enabled on an LPU, you can set different broadcast/multicast suppression triggering percentage values for different ports on the LPU.
l      While broadcast suppression does not work on multicasts, multicast suppression can suppress broadcasts.
l      No distinction is made between known multicast and unknown multicast for multicast suppression.
l      Broadcast suppression is implemented in a multiple of 64 bytes.
By default, the threshold for broadcast suppression is 50%, while that for multicast suppression is 100%.
A port in WAN mode is used for connecting to an SDH network, while a port in LAN mode is used for connecting to Ethernet.
To do …
Use the command …
Set the network mode of the Ethernet port
port-mode { wan | lan }
Restore the default network mode
undo port-mode
By default, Ethernet ports work in LAN mode. 10-GE Ethernet ports support WAN mode.
&  Note:
Ports on the XP4CA and XP4B boards do not support the WAN mode.
The link type of an Ethernet port can be access, hybrid, or trunk. The access port carries one VLAN only and is used for connecting to the user’s computer. The trunk port can belong to more than one VLAN to receive/send packets for them and is used for connection between switches. The hybrid port can also carry more than one VLAN to receive/send packets for them and is used for connecting both switches and user computers. The difference between the hybrid port and the trunk port is that the hybrid port allows the packets from multiple VLANs to be sent without tags, but the trunk port only allows the packets from the default VLAN to be sent without tags.
To do …
Use the command …
Configure the port as access port
port link-type access
Configure the port as hybrid port
port link-type hybrid
Configure the port as trunk port
port link-type trunk
Restore the default link type, that is, the access port
undo port link-type
You can configure three types of ports concurrently on the same switch, but you cannot switch the link type of a port directly between trunk and hybrid. To change the link type of a port from trunk to hybrid or vice versa, you must first set it to access.
The default port type is access.
The following commands are used for adding an Ethernet port to a specified VLAN. The access port can only be added to one VLAN, while the hybrid and trunk ports can be added to multiple VLANs.
To do …
Use the command …
Add the current access port to a specified VLAN
port access vlan vlan-id
Add the current hybrid port to specified VLANs
Add the current trunk port to specified VLANs
Remove the current access port from to a specified VLAN
undo port access vlan
Remove the current hybrid port from to specified VLANs
undo port hybrid vlan vlan-id-list
Remove the current trunk port from specified VLANs
undo port trunk permit vlan { vlan-id-list | all }
  Caution:
The access port shall be added to an existing VLAN other than VLAN 1. The VLAN to which a Hybrid port is added must be an existing VLAN.
After adding the Ethernet port to specified VLANs, the local port can forward packets of these VLANs. The hybrid and trunk ports can be added to multiple VLANs, thereby implementing the VLAN intercommunication between peers. On a hybrid port, you can configure to tag some VLAN packets so that they can be processed differently.
Since the access port can only be included in one VLAN, its default VLAN is the one to which it belongs. As the hybrid port and the trunk port can be included in multiple VLANs, it is necessary to assign them a default VLAN ID. Configured with a default VLAN ID, the hybrid or trunk port forwards the packets received without VLAN tags to the default VLAN. If the port receives a packet with the default VLAN tag, it will remove the tag before forwarding the packet.
To do …
Use the command …
Set the default VLAN ID for the hybrid port
port hybrid pvid vlan vlan-id
Set the default VLAN ID for the trunk port
port trunk pvid vlan vlan-id
Restore the default VLAN ID of the hybrid port to the default value
undo port hybrid pvid
Restore the default VLAN ID of the trunk port to the default value
undo port trunk pvid
  Caution:
To guarantee the proper packet transmission, the default VLAN ID of the local hybrid port or Trunk port should be identical with that of the hybrid port or Trunk port on the peer switch.
The default VLAN on the hybrid or trunk port is VLAN 1 and that on the access port is the VLAN to which it belongs.
A VLAN Tag consists of 12 bits (defined by IEEE802.1Q), so Ethernet Switches can support up to 4 K VLANs. Yet, this is far from enough for a network like MAN (metropolitan area network), where a large number of VLANs are required to isolate users.
The port VLAN VPN feature allows your switch to tag an originally tagged packet, namely, to mark the packet with another VLAN Tag besides the original one, thus providing VLANs as many as 4 K x 4 K. In addition, the use of dual tags allows you to use the original VLAN Tag for differentiating users and services and the new VLAN Tag for carrying services and VPNs, making VPN configuration simple and practicable. Through VLAN VPN configuration, Ethernet Switches can better meet the requirement in MAN.
If VLAN VPN is enabled on a port, every packet received on the port (no matter whether the packet carries a VLAN Tag or not) will be given a new Tag that specifies the default VLAN of this port. Thus, a tagged packet received on the port will be sent out with dual tags and an untagged one will be sent out with only the default VLAN tag of the port.
To do …
Use the command …
Enable the port VLAN VPN feature
vlan-vpn enable
Disable the port VLAN VPN feature
undo vlan-vpn
Note that if GVRP, STP, or 802.1x has been enabled on the port, you will be unable to enable the VLAN VPN feature.
By default, the port VLAN VPN feature is disabled.
To do …
Use the command …
Enable the VLAN filtering function
vlan filter enable
Disable the VLAN filtering function
vlan filter disable
By default, the VLAN filtering function is enabled on Ethernet ports.
With the VLAN filtering function enabled, the port permits only the packets of the VLAN where it resides. With the VLAN filtering function disabled, the port forwards all the packets it received.
To keep the configurations of some ports consistent with a specified port, you can use the copy configuration command to copy the configurations of that specified port to the other ports. Such configurations may involve STP, QoS, LACP, and port settings as follows:
Table 1-1 Configurations that can be copied
Attribute
Detailed Setting
STP settings
Enable/disable STP
Port priority
Path cost
Link attributes(point-to-point or not)
Port mCheck
Max transmission speed
Enable/disable root protection
Enable/disable loop protection
Edge or non-edge port
Reset ARP or not
QoS settings
Define/apply flow template
Traffic reshaping
Traffic redirection
Packet filtering
Priority re-assignment
Traffic statistics
Traffic mirroring
Rate limiting
Port settings
Permitted VLAN ID
Default VLAN ID
Add ports to VLAN
Default 802.1p priority
Port speed, duplex mode
Port link type
LACP
Enable/disable LACP on the port
&  Note:
l      Using the copy configuration command will clear protocol VLAN attributes of the destination port, but it will not copy the protocol VLAN attributes of the source port to the destination port.
l      With the copy configuration command, you can only copy the configurations of Ethernet ports, Gigabit Ethernet ports and aggregation groups.
l      You cannot copy the configuration of a port to ports of XP4B and XP4CA LPUs.
l      The uplink port of an isolation group cannot be configured as the source port or destination port in the copy configuration command.
To do …
Use the command …
Copy port configurations to other ports
copy configuration source { interface-type interface-number | aggregation-group agg-id } destination { interface-list [ aggregation-group agg-id ] | aggregation-group agg-id }
  Caution:
If the copy source is an aggregation group, the selected port with the least port number is taken as the source; if the copy destination is an aggregation group, the configurations of all ports in the group are updated to the configurations of the source. You cannot specify a dynamic aggregation group as the destination port in the copy command.
Frequent port up/down may affect the performance of the switch. To avoid the situation, you may configure the link-state hold time.
The system can record and report port changes to the user in one of the following two ways.
l           Interruption report: The switch does not suppress port state change reporting and reports the changes immediately.
l           Polling report: The switch suppresses port state change reporting. You can use the link-status hold command to set the link-state hold time.
With the link-state hold time set to zero seconds, the switch always prefers the interruption report mode to the polling report mode, so long as the former is supported.
With the link-state hold time set to a non-zero value, the port adopts the polling report mode, whether the interruption report mode is supported or not.
Therefore, you can switch the port state change reporting mode by setting the link-state hold time.
To do …
Use the command …
Set the link-state hold time
link-status hold hold-time
Restore the default value
undo link-status hold
The default link-state hold time is 3 seconds.
To do …
Use the command …
Set the Ethernet port in loopback mode
Remove loopback configuration on the port
undo loopback
&  Note:
At present, the Ethernet ports of the S9500 series switches do not support the external loopback mode.
By default, the Ethernet port is not in loopback mode.
To do …
Use the command …
Remarks
Display information for specified port(s)
display interface [ interface-type | interface-type interface-number [ packets ] ]
Available in any view
Display hybrid or trunk ports
Display the statistics information for the specified port(s)
display counters [ rate ] { inbound | outbound } interface [ interface-type ]
Clear the statistics of the specified port(s)
reset counters interface [ interface-type | interface-type interface-number ]
Available in user view
Display Jumbo frame configuration on all cards
display jumboframe configuration
Display the current alarm information of the optical transceiver module plugged in the specified port or all optical transceiver modules
Display the currently measured values of the diagnosis parameters for the pluggable optical transceiver in the specified port or all transceivers
Display the major parameters of the optical transceiver plugged in the specified port or all optical transceivers
Display the radio frequency identification (RFID) information of the pluggable optical transceiver in the specified port or all optical transceivers
&  Note:
l      When 802.1x is enabled on a port, the statistics information of the port cannot be cleared.
l      By default, the display counters command displays the traffic statistic information of all ports in position.
l      The supported Jumbo frame length range and default value may vary by card.
I. Network requirements
l           Switch A is connected to Switch B through GigabitEthernet 2/1/1.
l           Configure GigabitEthernet 2/1/1 as a trunk port permitting packets of VLAN 2, VLAN 6 through VLAN 50, and VLAN 100. Set VLAN 100 as the default VLAN on GigabitEthernet 2/1/1.
II. Network diagram
Figure 1-1 Network diagram for Ethernet port configuration
III. Configuration procedure
&  Note:
The following configuration is made on Switch A. Please configure Switch B in the similar way.
# Enter the Ethernet port view of GigabitEthernet 2/1/1.
<H3C> system-view
[H3C] interface GigabitEthernet2/1/1
# Configure GigabitEthernet 2/1/1 as a trunk port permitting packets of VLAN 2, VLAN 6 through VLAN 50, and VLAN 100.
[H3C-GigabitEthernet2/1/1] port link-type trunk
[H3C-GigabitEthernet2/1/1] port trunk permit vlan 2 6 to 50 100
[H3C-GigabitEthernet2/1/1] quit
# Create VLAN 100.
[H3C] vlan 100
[H3C-vlan100] quit
# Configure VLAN 100 as the default VLAN on GigabitEthernet 2/1/1.
[H3C-GigabitEthernet2/1/1] port trunk pvid vlan 100
Symptom 1: Default VLAN ID configuration fails.
Solution: Take the following steps:
l           Execute the display interface or display port command to check whether the port is a trunk port or a hybrid port. If it is neither, configure it as a trunk or hybrid port.
l           Configure the default VLAN ID.
Symptom 2: The port is in down status.
Solution: Check that
l           The cable connection is correct and the optical fibers are correctly connected.
l           The port has not been administratively shut down.
l           The correct optical module is used.
