H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
01-Login Configuration Guide
01-Login Configuration Guide 86.1 KB
Unless otherwise specified, all the switches used in the following configuration examples and configuration procedures are S3600 series switches (release 1510).
Logging In from the Console Port
You can log in locally from the console port to configure and maintain your switch, including configuring other login modes. The default login mode on the S3600 series is local console login.
Network Diagram
Figure 1-1 Logging in from the console port to configure Telnet login
Networking and Configuration Requirements
As shown in Figure 1-1, use a console cable to connect the serial port of your PC/terminal to the console port of the switch. Log into the switch from the AUX user interface on the console port to configure Telnet login. The current user level is manage level (level 3).
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
l          Configure common attributes for Telnet login
# Set the level of commands accessible to the VTY 0 user to 2.
[Sysname] user-interface vty 0
[Sysname-ui-vty0] user privilege level 2
# Enable the Telnet service on VTY 0.
[Sysname-ui-vty0] protocol inbound telnet
# Set the number of lines that can be viewed on the screen of the VTY 0 user to 30.
[Sysname-ui-vty0] screen-length 30
# Set the history command buffer size to 20 for VTY 0.
[Sysname-ui-vty0] history-command max-size 20
# Set the idle-timeout time of VTY 0 to 6 minutes.
[Sysname-ui-vty0] idle-timeout 6
l          Configure an authentication mode for Telnet login
The following three authentication modes are available for Telnet login: none, password, and scheme.
The configuration procedures for the three authentication modes are described below:
1)        Configure not to authenticate Telnet users on VTY 0.
[Sysname-ui-vty0] authentication-mode none
2)        Configure password authentication for Telnet login on VTY 0, and set the password to 123456 in plain text.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password simple 123456
3)        Configure local authentication in scheme mode for login users.
# Create a local user named guest and enter local user view.
[Sysname] local-user guest
# Set the authentication password to 123456 in plain text.
[Sysname-luser-guest] password simple 123456
# Set the service type to Telnet and the user level to 2 for the user guest.
[Sysname-luser-guest] service-type telnet level 2
[Sysname-luser-guest] quit
# Enter VTY 0 user interface view.
# Set the authentication mode to scheme for Telnet login on VTY 0.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
# Specify the domain system as the default domain, and configure the domain to adopt local authentication in scheme mode.
[Sysname] domain default enable system
[Sysname] domain system
[Sysname-isp-system] scheme local
Complete Configuration
l          Telnet login configuration with the authentication mode being none
 idle-timeout 6 0
 screen-length 30
l          Telnet login configuration with the authentication mode being password
 idle-timeout 6 0
 screen-length 30
l          Telnet login configuration with the authentication mode being scheme
domain system
local-user guest
 level 2
 idle-timeout 6 0
 screen-length 30
Precautions
None
Logging In Through Telnet
You can telnet to your switch to manage and maintain it remotely.
Network Diagram
Figure 1-2 Telneting to the switch to configure console login
As shown in Figure 1-2, telnet to the switch to configure console login. The current user level is manage level (level 3).
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
l          Common configuration for console login
# Specify the level of commands accessible to the AUX 0 user interface to 2.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] user privilege level 2
# Set the baud rate of the console port to 19200 bps.
[Sysname-ui-aux0] speed 19200
# Set the number of lines that can be viewed on the screen of the AUX 0 user to 30.
[Sysname-ui-aux0] screen-length 30
# Set the history command buffer size to 20 for AUX 0.
[Sysname-ui-aux0] history-command max-size 20
# Set the idle-timeout time of AUX 0 to 6 minutes.
[Sysname-ui-aux0] idle-timeout 6
l          Configure the authentication mode for console login
The following three authentication modes are available for console login: none, password, and scheme. The configuration procedures for the three authentication modes are described below:
1)        Configure not to authenticate console login users.
[Sysname-ui-aux0] authentication-mode none
2)        Configure password authentication for console login, and set the password to 123456 in plain text.
[Sysname-ui-aux0] authentication-mode password
[Sysname-ui-aux0] set authentication password simple 123456
3)        Configure local authentication in scheme mode for console login.
# Set the service type to Terminal and the user level to 2 for the user guest.
[Sysname-luser-guest] service-type terminal level 2
# Enter AUX 0 user interface view.
# Set the authentication mode to scheme for console login.
[Sysname-ui-aux0] authentication-mode scheme
l          Console login configuration with the authentication mode being none
 idle-timeout 6 0
 speed 19200
 screen-length 30
l          Console login configuration with the authentication mode being password
 idle-timeout 6 0
 speed 19200
 screen-length 30
l          Console login configuration with the authentication mode being scheme
local-user guest
 level 2
 idle-timeout 6 0
 speed 19200
 screen-length 30
Precautions
None
Configuring Login Access Control
Network Diagram
Figure 1-3 Network diagram for login access control
As shown in Figure 1-3, configure the switch to allow only Telnet/SNMP/WEB users at 10.110.100.52 and 10.110.100.46 to log in.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
# Create basic ACL 2000 and enter basic ACL view.
[Sysname] acl number 2000 match-order config
[Sysname-acl-basic-2000]
# Define ACL rules to allow only Telnet/SNMP/WEB users at 10.110.100.52 and 10.110.100.46 to log into the switch.
[Sysname-acl-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-basic-2000] rule 2 permit source 10.110.100.46 0
[Sysname-acl-basic-2000] rule 3 deny source any
[Sysname-acl-basic-2000] quit
# Reference ACL 2000 to control Telnet login by source IP address.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 2000 inbound
# Reference ACL 2000 to control SNMP login by source IP address.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
# Reference ACL 2000 to control WEB login by source IP address.
[Sysname] ip http acl 2000
l          Configuration for Telnet login control by source IP address
acl number 2000
 rule 3 deny
 acl 2000 inbound
l          Configuration for SNMP login control by source IP address
acl number 2000
 rule 3 deny
l          Configuration for WEB login control by source IP address
 ip http acl 2000
acl number 2000
 rule 3 deny
Precautions
None
