H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
28-File System Management Configuration
28-File System Management Configuration 186 KB
Chapter 1  File System Management Configuration
When configuring the file system management, go to these sections for information you are interested in:
l           File System Management
l           Configuration File Management
l           Displaying and Maintaining Device Configuration
&  Note:
Throughout this document, a filename can be entered as either of the following:
l      A fully qualified filename with the path included to indicate a file under a specific path. The filename can be 1 to 135 characters in length.
l      A short filename with the path excluded to indicate a file in the current path. The filename can be 1 to 91 characters in length.
1.1  File System Management
This section covers these topics:
l           File System Overview
l           Directory Operations
l           File Operations
l           Storage Device Operations
l           File System Prompt Mode Setting
l           File System Operations
1.1.1  File System Overview
A major function of the file system is to manage storage devices. It allows you to perform operations such as directory create and delete, and file copy and display. If an operation, delete or overwrite for example, may cause problems such as data loss or corruption, the file system will ask you to confirm the operation by default.
Depending on the managed object, file system operations fall into Directory Operations, File Operations, Storage Device Operations, and File System Prompt Mode Setting.
1.1.2  Directory Operations
Directory operations include create, delete, display the current path, display specified directory or file information as shown in the following table:
To do…
Use the command…
Remarks
Create a directory
mkdir directory
Optional
Available in user view
Remove a directory
rmdir directory
Optional
Display the current path
pwd
Optional
Display files or directories
dir [ /all ] [ file-url ]
Optional
Change the current path
cd directory
Optional
&  Note:
l      The directory to be removed must be empty, meaning before you remove a directory, you must delete all the files and the subdirectory under this directory. For file deletion, refer to the delete command and for subdirectory deletion, refer to the rmdir command.
l      After the execution of the rmdir command, the files in this directory will be automatically deleted for ever.
1.1.3  File Operations
File operations include delete (removing files into the recycle bin), restore the deleted, permanently delete (deleting files from the recycle bin), display, rename, copy, and move files, and display specified directory or file information as shown in the following table:
To do…
Use the command…
Remarks
Remove a file to the recycle bin or delete it permanently
delete [ /unreserved ] file-url
Optional
Restore a file from the recycle bin
undelete file-url
Optional
Empty the recycle bin
reset recycle-bin [ /force ]
Optional
Display the contents of a file
more file-url
Optional
Currently only a .txt file can be displayed.
Rename a file
rename fileurl-source fileurl-dest
Optional
Copy a file
copy fileurl-source fileurl-dest
Optional
Move a file
move fileurl-source fileurl-dest
Optional
Optional
Enter system view
Execute the batch file
execute filename
Optional
&  Note:
You can create a file by copying or downloading or using the save command.
  Caution:
l      Empty the recycle bin timely with the reset recycle-bin command to save memory space.
l      As the delete /unreserved file-url command deletes a file permanently and the action cannot be undone, use it with caution.
l      The execute command cannot ensure the execution of each command. For example, if a certain command is not correctly configured, the system will omit this command and go to the next one. Therefore, each configuration command in a batch file must be a standard configuration command, meaning the valid configuration information which can be displayed with the display current-configuration command after this command is configured successfully; otherwise, this command may not be executed correctly.
1.1.4  Storage Device Operations
I. Naming rules
Naming rules of the storage devices are as follows:
l           If there is only one storage device of the same type on the device, the physical device name of the storage device is the storage device name. For example, for a device with only one CF card, the physical device name of the CF card is cf.
l           If there are multiple storage devices with the same type on the device, the physical device name of the storage device is composed of the storage device type and the serial number of the storage device. The serial number is displayed in English letters such as a, b or c. For example, for a device with multiple CF cards, the physical device name of the first CF card is cfa, and that of the second is cfb, and so on.
l           If storage device partitioning is supported on the device, the name of the partition device is composed of the physical device name and partition number. The serial numbers of partitions are displayed in numbers such as 0, 1 or 2. For a device with only one CF card for example, the second partition of the CF card is cf1; for a device with multiple CF cards, the third partition of the second CF card is cfb2. If there is only one partition on the CF card, the partition name is the physical device name followed by 0.
II. Memory space management
You can use the fixdisk command to restore the space of a storage device or the format command to format a specified storage device as shown in the following table:
To do…
Use the command…
Remarks
Restore the space of a storage device
fixdisk device
Optional
Format a storage device
format device
Optional
You may use the two commands when some space of a storage device becomes inaccessible due to abnormal operations for example.
  Caution:
When you format a storage device, all the files stored on it are erased and cannot be restored. In particular, if there is a startup configuration file on the storage device, formatting the storage device results in loss of the startup configuration file.
1.1.5  File System Prompt Mode Setting
The file system provides the following two prompt modes:
l           alert: where the system warns you about operations that may bring undesirable consequence such as file corruption or data loss.
l           quiet: where the system does not do that in any cases.
To prevent undesirable consequence resulted from misoperations, the alert mode is preferred.
To do…
Use the command…
Remarks
Enter system view
Set the operation prompt mode of the file system
file prompt { alert | quiet }
Optional
The default is alert.
1.1.6  File System Operations Example
# Display the files and the subdirectory under the current directory.
<Sysname> dir
Directory of flash:/
   0   drw-         -  Feb 16 2006 11:45:36   logfile
   1   -rw-      1218  Feb 16 2006 11:46:19   config.cfg
   2   drw-         -  Feb 16 2006 15:20:27   test
   3   -rw-    184108  Feb 16 2006 15:30:20   aaa.bin
14605 KB total (6890 KB free)
# Create a new folder called mytest under the test directory.
<Sysname> cd test
<Sysname> mkdir mytest
%Created dir flash:/test/mytest.
# Display the current working directory.
<Sysname> pwd
flash:/test
# Display the files and the subdirectory under the test directory.
<Sysname> dir
Directory of flash:/test/
   0   drw-         -  Feb 16 2006 15:28:14   mytest
2540 KB total (2519 KB free)
# Return to the upper directory.
<Sysname> cd ..
<Sysname> pwd
flash:/
1.2  Configuration File Management
The device provides the configuration file management function with a user-friendly operating interface for you to manage the configuration files conveniently.
l           Configuration File Overview
l           Saving the Current Configuration
l           Erasing the Startup Configuration File
l           Specifying a Configuration File for Next Startup
l           Backing up/Restoring the Configuration File for Next Startup
1.2.1  Configuration File Overview
A configuration file saves the device configurations in command lines in text format. You can view configuration information conveniently through the configuration files.
I. Types of configuration
The configuration of a device falls into two types:
l           Saved configuration, a configuration file used for initialization. If this file does not exist, the default parameters are used.
l           Current configuration, which refers to the user’s configuration during the operation of a device. This configuration is stored in the flash. It is removed when the device is rebooting.
II. Format of configuration file
Configuration files are saved as text files. They:
l           Save configuration in the form of commands.
l           Save only non-default configuration settings.
l           List commands in sections by view in this view order: system, interface, routing protocol, and so on. Sections are separated with one or multiple blank lines or comment lines that start with a pound sign (#).
l           End with a return.
III. Startup with the configuration file
The following steps are taken during system startup:
1)         If you specify a configuration file and this file exists, the device will initialize its configuration based on this file.
2)         If you specify a configuration file but this file does not exist, the device will:
l           Initialize with the default configuration file if it exists;
l           Or initialize with empty configuration if the default configuration file does not exist.
1.2.2  Saving the Current Configuration
You can modify the configuration on your device at the command line interface (CLI). To use the modified configuration for your subsequent startups, you must save it (using the save command) as a configuration file.
I. Modes in saving the configuration
l           Fast saving mode. This is the mode when you use the save command without the safely keyword. The mode saves the file quicker but is likely to lose the original configuration file if the device reboots or the power fails during the process.
l           Safe mode. This is the mode when you use the save command with the safely keyword. The mode saves the file slower but can retain the configuration file in the device even if the device reboots or the power fails during the process.
  Caution:
Device reboot or the power failure during configuration file saving may result in loss of the configuration file for next startup. In this case, the device should be started with empty configuration and after the device starts, you need to re-specify a configuration file for next startup. Refer to Specifying a Configuration File for Next Startup for details.
Follow the step below to save the current configuration:
To do…
Use the command…
Remarks
Save the current configuration
save [ file-name | safely ]
Required
Available in any view
&  Note:
l      Fast saving mode is suitable for environments where power supply is stable. The safe mode, however, is preferred where stable power supply is unavailable or remote maintenance is involved.
l      The extension name of the configuration file must be .cfg.
l      If you press <Enter> after entering the save command, you can save the configuration file in an interactive way. In this way, you can use the default path or enter a filename to specify a new path, but the suffix of the filename must be “.cfg” and the path must be the path of the storage device on the AMB (active main board).
1.2.3  Erasing the Startup Configuration File
With the configuration file erased, your device will boot up with the default configuration next time it is powered on.
You may need to erase the configuration file for one of these reasons:
l           After you upgrade software, the original configuration file does not match the new software.
l           The startup configuration file is corrupted or not the one you need.
Follow the step below to erase the configuration file:
To do…
Use the command…
Remarks
Erase the startup configuration file from the storage device
reset saved-configuration
Required
  Caution:
This command will permanently delete the configuration file from the device. Use it with caution.
1.2.4  Specifying a Configuration File for Next Startup
Follow the step below to specify a configuration file for next startup:
To do…
Use the command…
Remarks
Specify a configuration file for next startup
startup saved-configuration cfgfile
Required
  Caution:
The configuration file must use “.cfg” as its extension name and the startup configuration file must be saved under the root directory of the device.
1.2.5  Backing up/Restoring the Configuration File for Next Startup
I. Backup/restore function overview
The backup/restore function allows you to backup or restore a configuration file for next startup through operations at the CLI. TFTP is used for intercommunication between the device and the server. The backup function enables you to backup a configuration file to the TFTP server, while the restore function enables you to download the configuration file from the TFTP server for next startup.
II. Backing up the configuration file for next startup
To do…
Use the command…
Remarks
Back up the configuration file for next startup
backup startup-configuration to dest-addr [ filename ]
Required
&  Note:
Before backup, you should:
l      Ensure that the server is reachable, the server is enabled with TFTP service, and the client has permission to read and write.
l      Use the display startup command (in user view) to verify if you have set the startup configuration file, and use the dir command to verify if this file exists. If the file is set as NULL or does not exist, the backup will be unsuccessful.
III. Restoring the startup configuration file
To do…
Use the command…
Remarks
Restore the startup configuration file
restore startup-configuration from src-addr filename
Required
&  Note:
l      Before restoring a configuration file, you should ensure that the server is reachable, the server is enabled with TFTP service, and the client has permission to read and write.
l      After the command is successfully executed, you can use the display startup command (in user view) to verify if the filename of the startup configuration file is the same with the filename argument, and use the dir command to verify if the restored file exists.
1.3  Displaying and Maintaining Device Configuration
To do…
Use the command…
Remarks
Display the configuration file saved in the storage device
display saved-configuration [ by-linenum ]
Display the configuration file used for this and next startup
display startup
Display the validated configuration in current view
display this [ by-linenum ]
Display current configuration
display current-configuration [ [ configuration [ configuration ] | controller | interface [ interface-type ] [ interface-number ] ] [ by-linenum ] [ | { begin | include | exclude } text ] ]
&  Note:
For detailed description of the display this and display current-configuration commands, refer to the System Maintaining and Debugging Configuration part of the manual.
Chapter 2  FTP Configuration
When configuring FTP, go to these sections for information you are interested in:
l           FTP Overview
l           Configuring the FTP Client
l           Configuring the FTP Server
l           Displaying and Maintaining FTP
2.1  FTP Overview
2.1.1  Introduction to FTP
The File Transfer Protocol (FTP) is an application layer protocol for sharing files between server and client over a TCP/IP network.
FTP uses TCP ports 20 and 21 for file transfer. Port 20 is used to transmit data, and port 21 to transmit control commands. Refer to RFC 959 for details of FTP basic operation.
FTP transmits files in two modes:
l           Binary mode for program file transmission
l           ASCII mode for text file transmission
2.1.2  Implementation of FTP
FTP adopts the server/client model. Your switch can function either as client or as server (as shown in Figure 2-1). They work in the following way:
l           When the switch serves as the FTP client, a PC user first telnets or connects to the switch through an emulation program, then executes the ftp command to establish the connection to the remote FTP server, and gain access to the files on the server. If the remote FTP server supports anonymous FTP, the device can log onto it directly; if not, the device must obtain FTP username and password first to log onto the remote FTP server.
l           When the switch serves as the FTP server, it must be configured with an IP address so that a user running FTP client program can access it. For the sake of security, the switch does not support anonymous FTP. Therefore, you must use an authenticated username and password. By default, authenticated users can access the root directory of the switch.
Figure 2-1 Network diagram for FTP
  Caution:
l      The FTP function is available when a route exists between the FTP server and the FTP client.
l      When a device serving as the FTP server logs onto the device using IE, some IE functions are not supported because multiple user connections are established, and the device supports only one connection currently.
2.2  Configuring the FTP Client
2.2.1  Establishing an FTP Connection
To access an FTP server, the FTP client must connect with it. Two ways are available for the connection: using the ftp command to establish the connection directly; using the open command in FTP client view.
Multiple routes may exist for the FTP client to successfully access the FTP server. You can specify one by configuring the source address of the packets of the FTP client to meet the requirement of the security policy of the FTP client. You can configure the source address by configuring the source interface or source IP address. The primary IP address configured on the source interface is the source address of the transmitted packets. The source address of the transmitted packets is selected following these rules:
l           If no source address of the FTP client is specified, a device uses the IP address of the interface determined by the routing protocol as the source IP address to communicate with an FTP server.
l           If the source address is specified with the ftp client source or ftp command, this source address is used to communicate with an FTP server.
l           If the source address is specified with the ftp client source command and then with the ftp command, the address specified with the latter one is used to communicate with an FTP server.
The source address specified with the ftp client source command is valid for all ftp connections and the source address specified with the ftp command is valid only for the current FTP connection.
Follow these steps to establish an FTP connection (In IPv4 networking):
To do…
Use the command…
Remarks
Enter system view
Configure the source address of the FTP client
Optional
A device uses the IP address of the interface determined by the routing protocol as the source IP address to communicate with the FTP server by default.
Exit to system view
Log onto the remote FTP server directly in user view
ftp [ server-address [ service-port ] [ source { interface interface-type interface-number | ip source-ip-address } ] ]
Use either approach.
Log onto the remote FTP server indirectly in FTP client view
ftp
open server-address [ service-port ]
&  Note:
l      If no primary IP address is configured on the source interface, the FTP connection fails.
l      If you use the ftp client source command to first configure the source interface and then the source IP address of the transmitted packets, the new source IP address will overwrite the current one, and vice versa.
Follow these steps to establish an FTP connection (In IPv6 networking):
To do…
Use the command…
Remarks
ftp ipv6 [ server-address [ service-port ] [ source ipv6 source-ipv6-address ] [ -i interface-type interface-number ] ]
ftp ipv6
open ipv6 server-address [ service-port ] [ -i interface-type interface-number ]
2.2.2  Configuring the FTP Client
After a device serving as the FTP client has established a connection with the FTP server (For establishing FTP connection, refer to Establishing an FTP Connection.), the device can perform the following operations for the authorized directory:
To do…
Use the command…
Remarks
Display help information of FTP-related commands supported by the remote FTP server
remotehelp [ protocol-command ]
Optional
Enable information display in a detailed manner
verbose
Optional
Enabled by default
Use other username to relog after logging onto the FTP server successfully
user username [ password ]
Optional
Set the file transfer mode to ASCII
ascii
Optional
ASCII by default
Set the file transfer mode to binary
binary
Optional
ASCII by default
Change the working path on the remote FTP server
cd pathname
Optional
Exit the current directory and enter the upper level directory
cdup
Optional
Display files/directories information on the FTP server
dir [ remotefile [ localfile ] ]
Optional
Check files/directories on the FTP server
ls [ remotefile [ localfile ] ]
Optional
Download a file from the FTP server
get remotefile [ localfile ]
Optional
Upload a file to the FTP server
put localfile [ remotefile ]
Optional
View the working directory of the remote FTP server
pwd
Optional
Find the working path of the FTP client
lcd
Optional
Create a directory on the FTP server
mkdir directory
Optional
Set the data transfer mode to passive
passive
Optional
Passive by default
Delete specified file on the FTP server
delete remotefile
Optional
Delete specified directory on the FTP server
rmdir directory
Optional
Disconnect with the FTP server without exiting the FTP client view
disconnect
Optional
Equal to the close command
close
Optional
Equal to the disconnect command
Disconnect with the FTP server and exit to user view
bye
Optional
Terminate the connection with the remote FTP server, and exit to user view
Optional
Available in FTP client view, equal to the bye command
&  Note:
l      FTP uses two modes for file transfer: ASCII mode and binary mode.
l      The Is command can only display the file/directory name, while the dir command can display more information, such as the size and date of creation of files or directories.
2.2.3  FTP Client Configuration Example
I. Network requirements
l           Use your device as an FTP client to download a startup file from the FTP server.
l           The IP address of the FTP server is 10.1.1.1/16.
l           On the FTP server, an FTP user account has been created for the FTP client, with the username being abc and the password being pwd.
l           The PC performs operations on the device through Console port.
II. Network diagram
Figure 2-2 Network diagram for FTPing an image file from an FTP server
III. Configuration procedure
# Check files on your device. Remove those redundant to ensure adequate space for the startup file to be downloaded.
<Sysname> dir
   0   drw-         -  Dec 07 2005 10:00:57   filename
   1   drw-         -  Jan 02 2006 14:27:51   logfile
   2   -rw-      1216  Jan 02 2006 14:28:59   config.cfg
   3   -rw-      1216  Jan 02 2006 16:27:26   backup.cfg
<Sysname> delete /unreserved flash:/backup.cfg
# Download the startup file from the server.
<Sysname> ftp 10.1.1.1
Trying 10.1.1.1.
Press CTRL+K to abort
Connected to 10.1.1.1
220 FTP service ready
User(10.1.1.1:(none)):abc
Password:
331 Password required for abc.
Password:
230 User logged in.
[ftp] binary
200 Type set to I.
[ftp] get aaa.bin bbb.bin
227 Entering Passive Mode (10.1.1.1,4,1).
125 BINARY mode data connection already open, transfer starting for aaa.bin.
.....226 Transfer complete.
FTP: 5805100 byte(s) received in 19.898 second(s) 291.74Kbyte(s)/sec.
[ftp] bye
# Specify the startup file for next startup with the boot-loader command.
<Sysname> boot-loader file bbb.bin
<Sysname> reboot
  Caution:
Startup files for next startup must be saved under the root directory. You can copy or move a file to change the path of it to the root directory. For description of the corresponding command, refer to the System Maintaining and Debugging part of the manual.
2.3  Configuring the FTP Server
2.3.1  Configuring FTP Server Operating Parameters
The FTP server uses two modes to update files when you upload files (use the put command) to the FTP server:
l           In fast mode, the FTP server starts writing data to the Flash after file transfer completes. This protects the files intended to be overwritten on the device from being corrupted in the event that anomalies, power failure for example, occur during a file transfer.
l           In normal mode, the FTP server writes data to the Flash during file transfer. This means that any anomaly, power failure for example, during file transfer might result in file corruption on the router. This mode, however, consumes less memory space than the fast mode.
Follow these steps to configure the FTP server:
To do…
Use the command…
Remarks
Enter system view
Enable the FTP server
ftp server enable
Required
Disabled by default.
Configure the idle-timeout timer
ftp timeout minutes
Optional
30 minutes by default.
In idle-timeout time, if there is no information interaction between the FTP server and client, the connection between them is terminated.
Set the file update mode in FTP
ftp update { fast | normal }
Optional
Normal update is used by default.
2.3.2  Configuring Authentication and Authorization for Accessing FTP Server
To allow an FTP user to access certain directories on the FTP server, you need to create an account for the user, authorizing access to the directories and associating the username and password with the account.
Follow these steps to configure authentication and authorization for FTP server:
To do…
Use the command…
Remarks
Enter system view
Create a local user and enter its view
local-user user-name
Required
No local user exists by default, and the system does not support FTP anonymous user access.
Assign a password to the user
password { simple | cipher } password
Required
Assign the FTP service to the user
service-type ftp [ ftp-directory directory ]
Required
By default, the system does not support anonymous FTP access, and does not assign any service. If the FTP service is assigned, the root directory of the device is used by default.
Specify the directory an FTP user can access
work-directory directory-name
Optional
By default, the FTP/SFTP users can access the root directory of the device.
&  Note:
If FTP server performs authentication, authorization and accounting (AAA) policy on FTP client, AAA related parameters should be configured on the FTP server. For more information about the local-user, password, service-type ftp, and work-directory commands and the AAA related configuration, refer to the AAA-RADIUS-HWTACACS Configuration part of the manual.
2.3.3  FTP Server Configuration Example
l           Use your device as an FTP server. Create a user account for an FTP user on it, setting the username to abc and the password to pwd.
l           The IP address of the VLAN interface is 1.1.1.1/16.
l           The PC serves as the FTP client.
II. Network diagram
Figure 2-3 Smooth upgrading using the FTP server
1)         Configure Device (FTP Server)
# Create an FTP user account abc, setting its password to pwd.
[Sysname] local-user abc
[Sysname-luser-abc] password simple pwd
# Specify abc to use FTP, and authorize its access to certain directory.
[Sysname-luser-abc] service-type ftp
[Sysname-luser-abc] work-directory flash:/
[Sysname-luser-abc] quit
# Enable FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Check files on your device. Remove those redundant to ensure adequate space for the startup file to be uploaded.
<Sysname> dir
   3   -rw-      1216  Jan 02 2006 16:27:26   back.cfg
   4   drw-         -  Jan 02 2006 15:20:21   ftp
2540 KB total (2511 KB free)
<Sysname> delete /unreserved flash:/back.cfg
2)         Configure the PC (FTP Client)
# Upload the startup file to the FTP server and save it under the root directory of the FTP server.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User(1.1.1.1:(none)):abc
Password:
230 User logged in.
ftp> put aaa.bin bbb.bin
&  Note:
l      When upgrading the configuration file with FTP, put the new file under the root directory.
l      After you finish upgrading the Boot ROM program through FTP, you must execute the bootrom upgrade command to refresh the system configuration.
<Sysname> reboot
  Caution:
2.4  Displaying and Maintaining FTP
To do…
Use the command…
Remarks
Display the configuration of the FTP client
display ftp client configuration
Display the configuration of the FTP server
display ftp-server
Display detailed information about logged-in FTP users
display ftp-user
Chapter 3  TFTP Configuration
When configuring TFTP, go to these sections for information you are interested in:
l           TFTP Overview
l           Configuring the TFTP Client
l           Displaying and Maintaining the TFTP Client
l           TFTP Client Configuration Example
3.1  TFTP Overview
3.1.1  Introduction to TFTP
The Trivial File Transfer Protocol (TFTP) provides functions similar to those provided by FTP, but it is not as complex as FTP in interactive access interface and authentication. Therefore, it is more suitable where complex interaction is not needed between client and server.
TFTP uses the UDP port 69 for data transmission. For TFTP basic operation, refer to RFC 1350.
In TFTP, file transfer is initiated by the client.
l           In a normal file downloading process, the client sends a read request to the TFTP server, receives data from the server, and then sends the acknowledgement to the server.
l           In a normal file uploading process, the client sends a write request to the TFTP server, sends data to the server, and receives the acknowledgement from the server.
TFTP transfers files in two modes:
l           Binary for program files
l           ASCII for text files.
3.1.2  Implementation of TFTP
&  Note:
Only the TFTP client service is available with your device at present.
Figure 3-1 TFTP configuration diagram
Before using TFTP, the administrator needs to configure IP addresses for the TFTP client and server, and make sure that there is a route between the TFTP client and server.
3.2  Configuring the TFTP Client
When a device acts as a TFTP client, you can upload files on the device to a TFTP server and download files from the TFTP server to the local device. You can use either of the following ways to download files:
l           Normal download: The device writes the obtained files to the storage device directly. In this way, the original system file will be overwritten and if file download fails (for example, due to network disconnection), the device cannot start up normally because the original system file has been deleted.
l           Secure download: The device saves the obtained files to its memory and does not write them to the storage device until all user files are obtained. In this way, if file download fails (for example, due to network disconnection), the device can still start up because the original system file is not overwritten. This mode is securer but consumes more memory.
 You are recommended to use the latter mode or use a filename not existing in the current directory as the target filename when downloading startup file or configuration file.
Multiple routes may exist for a TFTP client to successfully access the TFTP server. You can specify one by configuring the source address of the packets from the TFTP client to meet the requirement of the security policy of the TFTP client. You can configure the source address by configuring the source interface or source IP address. The primary IP address configured on the source interface is the source address of the transmitted packets. The source address of the transmitted packets is selected following these rules:
l           If no source address of the TFTP client is specified, a device uses the IP address of the interface determined by the routing protocol as the source IP address to communicate with a TFTP server.
l           If the source address is specified with the tftp client source or tftp command, this source address is adopted.
l           If the source address is specified with the tftp client source command and then with the tftp command, the source address configured with the latter one is used to communicate with a TFTP server.
The source address specified with the tftp client source command is valid for all tftp connections and the source address specified with the tftp command is valid only for the current tftp connection.
Follow these steps to configure the TFTP client:
To do…
Use the command…
Remarks
Enter system view
Reference an access control list (ACL) to the TFTP server
tftp-server [ ipv6 ] acl acl-number
Optional
Configure the source address of the TFTP client
Optional
A device uses the source address determined by the routing protocol to communicate with the TFTP server by default.
Return to user view
Download or upload a file in IPv4 network
tftp server-address { get | put | sget } source-filename [ destination-filename ] [ source { interface interface-type interface-number | ip source-ip-address } ]
Optional
Download or upload a file in IPv6 network
tftp ipv6 tftp-ipv6-server [ -i interface-type interface-number ] { get | put } source-file [ destination-file ]
Optional
&  Note:
l      If no primary IP address is configured on the source interface, TFTP connection fails.
l      If you use the ftp client source command to first configure the source interface and then the source IP address of the packets of the TFTP client, the new source IP address will overwrite the current one, and vice versa.
3.3  Displaying and Maintaining the TFTP Client
To do…
Use the command…
Remarks
Display the configuration of the TFTP client
display tftp client configuration
3.4  TFTP Client Configuration Example
l           Use a PC as the TFTP server and your device as the TFTP client.
l           PC uses IP address 1.2.1.1./16 and a TFTP working directory has been defined for the client.
l           On your device, VLAN-interface 1 is assigned an IP address 1.1.1.1/16. Make sure that the port connected to PC belongs to the same VLAN.
l           TFTP a startup file from PC for upgrading and a configuration file config.cfg to PC for backup.
II. Network diagram
Figure 3-2 Smooth upgrading using the TFTP client function
1)         Configure PC (TFTP Server), the configuration procedure omitted.
l           On the PC, enable TFTP server
l           Configure a TFTP working directory
2)         Configure the device (TFTP Client)
  Caution:
If the free memory space of the device is not big enough, you should delete the existing programs before downloading new ones.
# Enter system view.
# Assign VLAN-interface 1 an IP address 1.1.1.1/16, making sure that the port connected to PC belongs to the same VLAN.
[Sysname-Vlan-interface1] ip address 1.1.1.1 255.255.0.0
[Sysname-Vlan-interface1] return
# Download an application file aaa.bin from the TFTP server. (Before that, make sure that adequate memory is available.)
<Sysname> tftp 1.2.1.1 get aaa.bin bbb.bin
# Upload a configuration file config.cfg to the TFTP server.
<Sysname> tftp 1.2.1.1 put config.cfg configback.cfg
# Specify the main startup file for next startup with the boot-loader command (Suppose the device in this example supports the main and backup attribute of the startup file.).
<Sysname> reboot
  Caution:
