H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
18-ARP Configuration
18-ARP Configuration 121 KB
Chapter 1  ARP Configuration
When configuring ARP, go to these sections for information you are interested in:
l           ARP Overview
l           Configuring ARP
l           Configuring Gratuitous ARP
l           Configuring ARP Source Suppression
l           Displaying and Maintaining ARP
1.1  ARP Overview
1.1.1  ARP Function
Address Resolution Protocol (ARP) is used to resolve an IP address into a data link layer address.
An IP address is the address of a host at the network layer. To send a network layer packet to a destination host, the device must know the data link layer address (such as the MAC address) of the destination host. To this end, the IP address must be resolved into the corresponding data link layer address.
&  Note:
Unless otherwise stated, the data link layer addresses that appear in this chapter refer to the 48-bit Ethernet MAC addresses.
1.1.2  ARP Message Format
Figure 1-1 ARP message format
The following explains the fields in Figure 1-1.
l           Hardware type: This field specifies the hardware address type. The value “1” represents Ethernet.
l           Protocol type: This field specifies the type of the protocol address to be mapped. The hexadecimal value “0x0800” represents IP.
l           Hardware address length and protocol address length: They respectively specify the length of a hardware address and a protocol address, in bytes. For an Ethernet address, the value of the hardware address length field is "6”. For an IP(v4) address, the value of the protocol address length field is “4”.
l           OP: Operation code. This field specifies the type of ARP message. The value “1” represents an ARP request and “2” represents an ARP reply.
l           Sender hardware address: This field specifies the hardware address of the device sending the message.
l           Sender protocol address: This field specifies the protocol address of the device sending the message.
l           Target hardware address: This field specifies the hardware address of the device the message is being sent to.
l           Target protocol address: This field specifies the protocol address of the device the message is being sent to.
1.1.3  ARP Address Resolution Process
Suppose that Host A and Host B are on the same subnet and that Host A sends a message to Host B, as show in Figure 1-2. The resolution process is as follows:
1)         Host A looks in its ARP mapping table to see whether there is an ARP entry for Host B. If Host A finds it, Host A uses the MAC address in the entry to encapsulate the IP packet into a data link layer frame and sends the frame to Host B.
2)         If Host A finds no entry for Host B, Host A buffers the packet and broadcasts an ARP request, in which the source IP address and source MAC address are respectively the IP address and MAC address of Host A and the destination IP address and MAC address are respectively the IP address of Host B and an all-zero MAC address. Because the ARP request is sent in broadcast mode, all hosts on this subnet can receive the request, but only the requested host (namely, Host B) will process the request.
3)         Host B compares its own IP address with the destination IP address in the ARP request. If they are the same, Host B saves the source IP address and source MAC address into its ARP mapping table, encapsulates its MAC address into an ARP reply, and unicasts the reply to Host A.
4)         After receiving the ARP reply, Host A adds the MAC address of Host B into its ARP mapping table for subsequent packet forwarding. Meanwhile, Host A encapsulates the IP packet and sends it out.
Figure 1-2 ARP address resolution process
When Host A and Host B are not on the same subnet, Host A first sends an ARP request to the gateway. The destination IP address in the ARP request is the IP address of the gateway. After obtaining the MAC address of the gateway from an ARP reply, Host A encapsulates the packet and sends it to the gateway. Subsequently, the gateway broadcasts the ARP request, in which the destination IP address is the one of Host B. After obtaining the MAC address of Host B from another ARP reply, the gateway sends the packet to Host B.
1.1.4  ARP Mapping Table
After obtaining the destination MAC address, the device adds the IP-to-MAC mapping into its own ARP mapping table. This mapping is used for forwarding packets with the same destination in future.
An ARP mapping table contains ARP entries, which fall into two categories: dynamic and static.
1)         A dynamic entry is automatically created and maintained by ARP. It can get aged, be updated by a new ARP packet, or be overwritten by a static ARP entry. When the aging timer expires or the port goes down, the corresponding dynamic ARP entry will be removed.
2)         A static ARP entry is manually configured and maintained. It cannot get aged or be overwritten by a dynamic ARP entry. It can be permanent or non-permanent.
l           A permanent static ARP entry can be directly used to forward packets. When configuring a permanent static ARP entry, you must configure a VLAN and outbound port for the entry besides the IP address and MAC address.
l           A non-permanent static ARP entry cannot be directly used for forwarding data. When configuring a non-permanent static ARP entry, you only need to configure the IP address and MAC address. When forwarding IP packets, the device sends an ARP request. If the source IP and MAC addresses in the received ARP reply are the same as the configured IP and MAC addresses, the device adds the port receiving the ARP reply into the static ARP entry. Now the entry can be used for forwarding IP packets.
&  Note:
Usually ARP dynamically implements and automatically seeks mappings from IP addresses to MAC addresses, without manual intervention.
1.2  Configuring ARP
1.2.1  Configuring a Static ARP Entry
A static ARP entry is effective when the device works normally. However, when a VLAN or VLAN interface to which a static ARP entry corresponds is deleted, the entry, if permanent, will be deleted, and if non-permanent and resolved, will become unresolved.
Follow these steps to configure a static ARP entry:
To do…
Use the command…
Remarks
Enter system view
Configure a permanent static ARP entry
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance-name ]
Required
No permanent static ARP entry is configured by default.
Configure a non-permanent static ARP entry
arp static ip-address mac-address [ vpn-instance vpn-instance-name ]
Required
No non-permanent static ARP entry is configured by default.
  Caution:
The vlan-id argument must be the ID of an existing VLAN which corresponds to the ARP entries. In addition, the Ethernet port following the argument must belong to that VLAN. A VLAN interface must be created for the VLAN.
1.2.2  Configuring the Maximum Number of ARP Entries for a VLAN Interface
Follow these steps to set the maximum number of dynamic ARP entries that a VLAN interface can learn:
To do…
Use the command…
Remarks
Enter system view
Enter VLAN interface view
interface Vlan-interface vlan-id
Set the maximum number of dynamic ARP entries that a VLAN interface can learn
arp max-learning-num number
Optional
It is 2560 by default.
1.2.3  Setting Aging Time for Dynamic ARP Entries
After dynamic ARP entries expire, the system will delete them from the ARP mapping table. You can adjust the aging time for dynamic ARP entries according to the actual network condition.
Follow these steps to set aging time for dynamic ARP entries:
To do…
Use the command…
Remarks
Enter system view
Set aging time for dynamic ARP entries
arp timer aging aging-time
Optional
20 minutes by default.
1.2.4  Enabling the ARP Entry Check
The ARP entry check can control the device to learn multicast MAC addresses. With the ARP entry check enabled, the device cannot learn any ARP entry with a multicast MAC address. Configuring such a static ARP entry is not allowed either; otherwise, the system prompts error information.
After the ARP entry check is disabled, the device can learn the ARP entry with a multicast MAC address, and you can also configure such a static ARP entry on the device.
Follow these steps to enable the ARP entry check:
To do…
Use the command…
Remarks
Enter system view
Enable the ARP entry check
arp check enable
Optional
Enabled by default.
1.2.5  ARP Configuration Example
I. Network requirements
l           Enable the ARP entry check.
l           Set the aging time for dynamic ARP entries to 10 minutes.
l           Set the maximum number of dynamic ARP entries that VLAN-interface 10 can learn to 1,000.
l           Add a static ARP entry, with the IP address being 192.168.1.1/24, the MAC address being 00e0-fc01-0000, and the outbound port being Ethernet 1/0/10 of VLAN 10.
II. Configuration procedure
[Sysname] arp check enable
[Sysname] arp timer aging 10
[Sysname] vlan 10
[Sysname-vlan10] port Ethernet 1/0/10
[Sysname-vlan10] quit
[Sysname-vlan-interface10] arp max-learning-num 1000
[Sysname-vlan-interface10] quit
[Sysname] arp static 192.168.1.1 00e0-fc01-0000 10 ethernet1/0/10
1.3  Configuring Gratuitous ARP
1.3.1  Introduction to Gratuitous ARP
A gratuitous ARP packet is a special ARP packet, in which the source IP address and destination IP address are both the IP address of the sender, the source MAC address is the MAC address of the sender, and the destination MAC address is a broadcast address.
A device can implement the following functions by sending gratuitous ARP packets:
l           Determining whether its IP address is already used by another device.
l           Informing other devices of its MAC address change so that they can update their ARP entries.
A device receiving a gratuitous ARP packet can add the information carried in the packet to its own dynamic ARP mapping table if it finds no corresponding ARP entry for the ARP packet in the cache.
1.3.2  Configuring Gratuitous ARP
Follow these steps to configure gratuitous ARP:
To do…
Use the command…
Remarks
Enter system view
Enable the device to send gratuitous ARP packets when receiving ARP requests from another network segment
gratuitous-arp-sending enable
Required
By default, an switch cannot send gratuitous ARP packets when receiving ARP requests from another network segment.
Enable the gratuitous ARP packet learning function
gratuitous-arp-learning enable
Required
Disabled by default.
1.4  Configuring ARP Source Suppression
1.4.1  Introduction to ARP Source Suppression
If a host attacks the device on a network by sending large amounts of IP packets whose IP addresses cannot be resolved:
l           The device sends large amounts of ARP request messages to the destination subnet, which increases the load of the destination subnet.
l           The device continuously resolves destination IP addresses, which increase the load of the CPU.
To protect the device against this kind of attack, you can enable the ARP source suppression function. With the function enabled, whenever the number of packets with unresolvable IP addresses that a host on the network sends to the device within five seconds exceeds the specified threshold, the device drops all subsequent packets with the same source IP address in another five coming seconds. This helps in protecting the device against the attack.
1.4.2  Configuring ARP Source Suppression
Follow these steps to configure ARP source suppression:
To do…
Use the command…
Remarks
Enter system view
Enable ARP source suppression
arp source-suppression enable
Required
Set the maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds
Optional
10 by default.
1.5  Displaying and Maintaining ARP
To do…
Use the command…
Remarks
Display the ARP entries in the ARP mapping table
display arp { { all | dynamic | static } | vlan vlan-id | interface interface-type interface-number } [ [ verbose ] [ | { begin | exclude | include } text ] | count ]
Available in any view
Display the ARP entries for a specified IP address
display arp ip-address [ verbose ] [ | { begin | exclude | include } text ]
Display the ARP entries for a specified VPN instance
display arp vpn-instance vpn-instance-name [ | { begin | exclude | include } text | count ]
Display the aging time for dynamic ARP entries
display arp timer aging
Display the configuration information of ARP source suppression
display arp source-suppression
Clear ARP entries from the ARP mapping table
reset arp { all | dynamic | static | interface interface-type interface-number }
Available in user view
Chapter 2  Proxy ARP Configuration
When configuring proxy ARP, go to these sections for information you are interested in:
l           Proxy ARP Overview
l           Enabling Proxy ARP
l           Displaying and Maintaining Proxy ARP
2.1  Proxy ARP Overview
For an ARP request of a host on a network to be forwarded to an interface that is on the same network but isolated at Layer 2 or a host on another network, the device connecting the two physical or virtual networks must be able to respond to the request. This is achieved by proxy ARP.
Proxy ARP implements Layer 3 communication between VLAN interfaces isolated at Layer 2 or located on different networks.
In one of the following cases, you need to enable the local proxy ARP:
l           Devices connected to different isolated layer 2 ports in the same VLAN need to implement layer 3 communication.
l           With the isolate-user-vlan function enabled on a device attached to an switch, devices in different second VLANs need to implement Layer 3 communication.
2.2  Enabling Proxy ARP
Follow these steps to enable proxy ARP or enable local proxy ARP in VLAN interface view:
To do…
Use the command…
Remarks
Enter system view
Required
Enable proxy ARP
proxy-arp enable
Required
Enable local proxy ARP
local-proxy-arp enable
Required
2.3  Displaying and Maintaining Proxy ARP
To do…
Use the command…
Remarks
Display whether proxy ARP is enabled
display proxy-arp [ interface Vlan-interface vlan-id ]
Display whether local proxy ARP is enabled
display local-proxy-arp [ interface Vlan-interface vlan-id ]
2.4  Proxy ARP Configuration Examples
2.4.1  Proxy ARP Configuration Example
Host A and Host D have IP addresses of the same network segment. Host A belongs to VLAN 1, and Host D belongs to VLAN 2. Configure proxy ARP on the device to enable the communication between the two hosts.
II. Network diagram
Figure 2-1 Network diagram for proxy ARP
III. Configuration procedure
# Configure Proxy ARP on the device to enable the communication between Host A and Host D.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
[Switch-Vlan-interface1] proxy-arp enable
[Switch-Vlan-interface1] quit
[Switch-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
[Switch-Vlan-interface2] proxy-arp enable
[Switch-Vlan-interface2] quit
2.4.2  Local Proxy ARP Configuration Example in Case of Port Isolation
l           Host A and Host B belong to the same VLAN, and are connected to Ethernet 1/0/2 and Ethernet 1/0/3 of the switch respectively.
l           Ethernet 1/0/2 and Ethernet 1/0/3 isolated at layer 2 can implement layer 3 communication.
II. Network diagram
Figure 2-2 Network diagram for local proxy ARP between isolated ports
# Add Ethernet 1/0/2 and Ethernet 1/0/3 to VLAN 2. Host A and Host B are isolated and unable to exchange Layer 2 packets.
[Switch] vlan 2
[Switch-vlan2] port ethernet 1/0/2
[Switch-vlan2] port ethernet 1/0/3
[Switch-vlan2] quit
[Switch] interface ethernet 1/0/2
[Switch-Ethernet1/0/2] port-isolate enable
[Switch-Ethernet1/0/2] quit
[Switch] interface ethernet 1/0/3
[Switch-Ethernet1/0/3] port-isolate enable
[Switch-Ethernet1/0/3] quit
# Configure an IP address of VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.10.100 255.255.0.0
Ping Host B on Host A to verify that the two hosts cannot be pinged through, which indicates they are isolated at Layer 2.
# Configure local proxy ARP to let Host A and Host B communicate at Layer 3.
[Switch-Vlan-interface2] local-proxy-arp enable
Ping Host B on Host A to verify that the two hosts can be pinged through, which indicates Layer 3 communication is implemented.
