H3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
HomeSupportSwitchesS3610[S5510] SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5301-(V1.03)
25-SNMP-RMON Configuration
25-SNMP-RMON Configuration 140 KB
Chapter 1  SNMP Configuration
When configuring SNMP, go to these sections for information you are interested in:
l           SNMP Overview
l           SNMP Configuration
l           Configuring SNMP Logging
l           Trap Configuration
l           Displaying and Maintaining SNMP
l           SNMP Configuration Example
l           SNMP Logging Configuration Example
1.1  SNMP Overview
Simple Network Management Protocol (SNMP) offers a framework to monitor network devices through TCP/IP protocol suite. It provides a set of basic operations in monitoring and maintaining the Internet and has the following characteristics:
l           Automatic network management: SNMP enables network administrators to search and modify information, find and diagnose network problems, plan for network growth, and generate reports on network nodes.
l           SNMP shields the physical differences between various devices and thus realizes automatic management of products from different manufacturers. Offering only the basic set of functions, SNMP makes the management tasks independent of both the physical features of the managed devices and the underlying networking technology. Thus, SNMP achieves effective management of devices from different manufacturers, especially so in small, fast and low cost network environments.
1.1.1  SNMP Mechanism
An SNMP enabled network comprises network management station (NMS) and Agent.
l           NMS is a station that runs the SNMP client software. It offers a user friendly interface, making it easier for network administrators to perform most network management tasks. Currently, the most commonly used NMSs include Quidview, Sun NetManager, and IBM NetView.
l           Agent is a program on the device. It receives and handles requests sent from the NMS. Only under certain circumstances, such as interface state change, will the Agent inform the NMS.
l           NMS manages an SNMP enabled network, whereas Agent is the managed network device. They exchange management information through the SNMP protocol.
SNMP provides the following four basic operations:
l           Get operation: NMS gets the value of a certain variable of Agent through this operation.
l           Set operation: NMS can reconfigure certain values in the Agent MIB (Management Information Base) to make the Agent perform certain tasks by means of this operation.
l           Trap operation: Agent sends Traps to the NMS through this operation.
l           Inform operation: NMS sends Traps to other NMSs through this operation.
1.1.2  SNMP Protocol Version
Currently, SNMP agents support SNMPv3 and are compatible with SNMPv1 and SNMPv2c.
SNMPv1 and SNMPv2c authenticate by means of community name, which defines the relationship between an SNMP NMS and an SNMP Agent. SNMP packets with community names that did not pass the authentication on the device will simply be discarded. A community name performs a similar role as a key word and can be used to regulate access from NMS to Agent.
SNMPv3 offers an authentication that is implemented with a User-Based Security Model (USM), which could be authentication with privacy, authentication without privacy, or no authentication no privacy. USM regulates the access from NMS to Agent in a more efficient way.
1.1.3  MIB Overview
Management Information Base (MIB) is a collection of all the objects managed by NMS. It defines a set of characteristics associated with the managed objects, such as the object identifier (OID), access right and data type of the objects.
MIB stores data using a tree structure. The node of the tree is the managed object and can be uniquely identified by a path starting from the root node. As illustrated in the following figure, the managed object B can be uniquely identified by a string of numbers {1.2.1.1}. This string of numbers is the OID of the managed object B.
Figure 1-1 MIB tree
1.2  SNMP Configuration
As configurations for SNMPv3 differ substantially from those of SNMPv1 and SNMPv2c, their SNMP functionalities will be introduced separately below.
Follow these steps to configure SNMPv3:
To do…
Use the command…
Remarks
Enter system view
Enable SNMP Agent
snmp-agent
Optional
Disabled by default
You can enable SNMP Agent through this command or any commands that begin with snmp-agent.
Configure SNMP Agent system information
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
Optional
The defaults are as follows:
Hangzhou H3C Technologies Co.,Ltd. for contact,
Hangzhou China for location, and SNMP v3 for the version.
Configure an SNMP agent group
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
Required
Add a new user to an SNMP agent group
snmp-agent usm-user v3 user-name group-name [ authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | des56 } priv-password ] ] [ acl acl-number ]
Required
Configure the maximum size of an SNMP packet that can be received or sent by an SNMP agent
Optional
1,500 bytes by default
Configure the engine ID for a local SNMP agent
Optional
Company ID and device ID by default
Create or update the MIB view content for an SNMP agent
Optional
MIB view name is ViewDefault and OID is 1 by default.
Follow these steps to configure SNMPv1 and SNMPv2c:
To do…
Use the command…
Remarks
Enter system view
Enable SNMP Agent
snmp-agent
Optional
Disabled by default
snmp-agent sys-info { contact sys-contact | location sys-location | version { { v1 | v2c | v3 }* | all } }
Required
Hangzhou China for location and SNMP v3 for the version.
Configure SNMP NMS access right
Configure directly
Configure a community name
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ]*
Use either approach.
Both commands can be used to configure SNMP NMS access rights. The second command was introduced to be compatible with SNMPv3.
The community name configured on NMS should be consistent with the username configured on the Agent.
Configure indirectly
Configure an SNMP group
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
Add a new user to an SNMP group
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
Optional
15,00 bytes by default
Optional
Create or update MIB view content for an SNMP agent
Optional
ViewDefault by default
  Caution:
The validity of a USM user depends on the engine ID of the SNMP agent. If the engine ID used for USM user creation is not identical to the current engine ID, the USM user is invalid.
1.3  Configuring SNMP Logging
1.3.1  Introduction to SNMP Logging
SNMP logs the GET and SET operations that NMS performs to SNMP Agent. When the GET operation is performed, Agent logs the IP address of NMS, node name of the GET operation and OID of the node. When the SET operation is performed, Agent logs the IP address of NMS, node name of the SET operation, OID of the node, the value set and the error code and index returned with the SET operation. These logs will be transferred to system information and sent to the information center to be checked and tracked.
SNMP logs GET request, SET request and SET response, but does not log GET response.
1.3.2  Enabling SNMP Logging
To do…
Use the command…
Remarks
Enter system view
Enable SNMP logging
snmp-agent log { all | get-operation | set-operation }
Required
Disabled by default.
&  Note:
l      Logs occupy storage space of the device, thus affecting the performance of the device. Therefore, you are recommended to disable SNMP logging.
l      When SNMP logging is enabled, SNMP logs will be output to the information center of the device.
l      The priority of SNMP log is informational, meaning it is a common prompt of the device. To check SNMP logs, enable the information center to output system information with the severity of informational.
l      The size of SNMP logs cannot exceed that allowed by the information center and the sum of the node and value field of each log information cannot exceed 1K bytes; otherwise, the exceeded part will be output.
l      For the detailed description of system information and the information center, refer to the Information Center Configuration part of the manual.
1.4  Trap Configuration
SNMP Agent sends Traps to NMS to alert the latter of critical and important events (such as restart of the managed device).
1.4.1  Configuration Prerequisites
Basic SNMP configurations have been completed. These configurations include version configuration: community name is needed when SNMPv1 and v2c are adopted; username and MIB view are needed if SNMPv3 is adopted.
1.4.2  Configuration Procedure
I. Enabling Trap transmission
Follow these steps to enable Trap transmission:
To do…
Use the command…
Remarks
Enter system view
Set to enable the device to send Traps globally
snmp-agent trap enable [ bfd | bgp | configuration | flash | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
Optional
All types of Traps are allowed by default.
Enter interface view
Set to enable the device to send Traps of interface state change
enable snmp trap updown
Optional
Enabled by default.
  Caution:
To enable an interface to send SNMP Traps when its state changes, you need to enable the Link up/down Trap packet transmission function on an interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
II. Configuring Trap transmission parameters
Follow these steps to configure Trap:
To do…
Use the command…
Remarks
Enter system view
Configure target host attribute for Traps
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
Required
The vpn-instance keyword is applicable in a network supporting IPv4.
Configure the source address for Traps
snmp-agent trap source interface-type { interface-number | interface-number.subnumber }
Optional
Extend the standard linkUp/linkDown Traps defined in RFC
snmp-agent trap if-mib link extended
Optional
Standard linkUp/linkDown Traps defined in RFC are used by default.
Configure the queue size for sending Traps
Optional
100 by default
Configure the lifetime for Traps
snmp-agent trap life seconds
Optional
120 seconds by default
&  Note:
The extended linkUp/linkDown Traps comprise the standard linkUp/linkDown Traps defined in RFC plus interface description and interface type. If the extended messages are not supported on NMS, you can disable this function and enable the device to send standard linkUp/linkDown Traps.
1.5  Displaying and Maintaining SNMP
To do…
Use the command…
Remarks
Display SNMP-agent system information, including the contact, location, and version of the SNMP
display snmp-agent sys-info [ contact | location | version ]*
Available in any view
Display SNMP agent statistics
display snmp-agent statistics
Display the SNMP agent engine ID
display snmp-agent local-engineid
Display SNMP agent group information
display snmp-agent group [ group-name ]
Display the modules that can send Traps and whether their Trap sending is enabled or not
display snmp-agent trap-list
Display SNMP v3 agent user information
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
Display SNMP v1 or v2c agent community information
Display MIB view information for an SNMP agent
display snmp-agent mib-view [ exclude | include | viewname view-name ]
1.6  SNMP Configuration Example
I. Network requirements
l           The NMS connects to the agent, a switch, through an Ethernet.
l           The IP address of the NMS is 1.1.1.2/24.
l           The IP address of VLAN interface on the switch is 1.1.1.1/24.
l           On the switch, configure the following: community name, access right, administrator ID, contact, location, enabling sending of Traps.
II. Network diagram
Figure 1-2 Network diagram for SNMP (on a switch)
III. Configuration procedure
1)         Configuring SNMP Agent
# Configure the community name, the SNMP agent group, and SNMP agent user.
[Sysname] snmp-agent community read public
[Sysname] snmp-agent community write private
[Sysname] snmp-agent mib-view included internet 1.3.6.1
[Sysname] snmp-agent group v3 managev3group write-view internet
[Sysname] snmp-agent usm-user v3 managev3user managev3group
# Configure VLAN-interface 2 (with the IP address of 1.1.1.1/24). Add the port Ethernet 1/0/1 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port ethernet 1/0/1
[Sysname-vlan2] interface vlan-interface 2
[Sysname-Vlan-interface2] ip address 1.1.1.1 255.255.255.0
[Sysname-Vlan-interface2] quit
# Configure the system information of the switch.
[Sysname] snmp-agent sys-info version all
[Sysname] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Sysname] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable the sending of Traps to the NMS with an IP address of 1.1.1.2/24, using public as the community name.
[Sysname] snmp-agent target-host trap address udp-domain 1.1.1.2 udp-port 5000 params securityname public
2)         Configuring SNMP NMS
SNMPv3 uses authentication and privacy security model. In NMS, the user needs to specify username and security level, and based on that level, configure the authentication mode, authentication password, privacy mode, privacy password. In addition, the time-out time and number of retries should also be configured. The user can inquire and configure the switch through NMS. For detailed information, refer to the NMS manuals.
&  Note:
The configurations on the agent and the NMS must match in order to perform the related operations.
1.7  SNMP Logging Configuration Example
l           NMS and Agent are connected through an Ethernet
l           The IP address of NMS is 1.1.1.2/24
l           The IP address of the VLAN interface on Agent is 1.1.1.1/24
l           Configure community name, access right and SNMP version on Agent
II. Network diagram
Figure 1-3 Network diagram for SNMP logging
&  Note:
The configurations for NMS and Agent are omitted.
# Enable logging display on the terminal (optional, enabled by default).
<Sysname> terminal monitor
<Sysname> terminal logging
# Enable the information center to output the system information with the severity of informational to the Console port.
[Sysname] info-center source snmp channel console log level informational
# Enable SNMP logging on Agent to log the GET and SET operations of NMS.
[Sysname] snmp-agent log get-operation
[Sysname] snmp-agent log set-operation
l           The following log information is displayed on the terminal when NMS performs the GET operation to Agent.
%Jan 1 02:49:40:566 2006 Sysname SNMP/6/GET:
seqNO = <10> srcIP = <1.1.1.2> op = <get> node = <sysName(1.3.6.1.2.1.1.5.0)> value=<>
l           The following log information is displayed on the terminal when NMS performs the SET operation to Agent.
%Jan 1 02:59:42:576 2006 Sysname SNMP/6/SET:
seqNO = <11> srcIP = <1.1.1.2> op = <set> errorIndex = <0> errorStatus =<noError> node = <sysName(1.3.6.1.2.1.1.5.0)> value = <Sysname>
Table 1-1 Descriptions on the output field of SNMP log
The time when SNMP log is generated
seqNO
Sequence number of the SNMP log ()
srcIP
IP address of NMS
op
SNMP operation type (GET or SET)
node
Node name of the SNMP operations and OID of the instance
erroIndex
Error index, with 0 meaning no error
errorstatus
Error status, with noError meaning no error
value
Value set when the SET operation is performed (This field is , meaning the value obtained with the GET operation is not logged.)
When the value is a string of characters and the string contains characters not in the range of ASCII 0 to 127 or invisible characters, the string is displayed in hexadecimal. For example, value = <81-43>[hex]
&  Note:
The system information of the information center can be output to the terminal or to the log buffer. In this example, SNMP log is output to the terminal. To set the SNMP log to be output to other directions, refer to the Information Center Configuration part of the manual.
Chapter 2  RMON Configuration
When configuring RMON, go to these sections for information you are interested in:
l           RMON Overview
l           Configuring RMON
l           Displaying and Maintaining RMON
l           RMON Configuration Example
2.1  RMON Overview
This section covers these topics:
l           Introduction
l           RMON Groups
2.1.1  Introduction
Remote Monitoring (RMON) is a type of IETF-defined MIB. It is the most important enhancement to the MIB II standard. It allows you to monitor traffic on network segments and even the entire network.
RMON is implemented based on the Simple Network Management Protocol (SNMP) and is fully compatible with the existing SNMP framework.
RMON provides an efficient means of monitoring subnets and allows SNMP to monitor remote network devices in a more proactive and effective way. It reduces traffic between network management station (NMS) and agent, facilitating large network management.
RMON comprises two parts: NMSs and agents running on network devices.
l           Each RMON NMS administers the agents within its administrative domain.
l           An RMON agent resides on a network monitor or probe for an interface. It monitors and gathers information about traffic over the network segment connected to the interface to provide statistics about packets over a specified period and good packets sent to a host for example.
2.1.2  Working Mechanism
RMON allows multiple monitors. A monitor provides two ways of data gathering:
l           Using RMON probes. NMSs can obtain management information from RMON probes directly and control network resources. In this approach, RMON NMSs can obtain all RMON MIB information.
l           Embedding RMON agents in network devices such as routers, switches, and hubs to provide the RMON probe function. RMON NMSs exchange data with RMON agents with basic SNMP commands to gather network management information, which, due to system resources limitation, may not cover all MIB information but four groups of information, alarm, event, history, and statistics, in most cases.
The device adopts the second way. By using RMON agents on network monitors, an NMS can obtain information about traffic size, error statistics, and performance statistics for network management.
2.1.3  RMON Groups
RMON categorizes objects into ten groups. This section describes only the major implemented five groups.
I. Event group
The event group defines event indexes and controls the generation and notifications of the events triggered by the alarms defined in the alarm group and the private alarm group. The events can be handled in one of the following ways:
l           Logging events in the event log table
l           Sending traps to NMSs
l           Both logging and sending traps
l           No action
II. Alarm group
The RMON alarm group monitors specified alarm variables, such as statistics on a port. If the sampled value of the monitored variable is bigger than or equal to the upper threshold, an upper event is triggered; if the sampled value of the monitored variable is lower than or equal to the lower threshold, a lower event is triggered The event is then handled as defined in the event group.
The following is how the system handles entries in the RMON alarm table:
1)         Samples the alarm variables at the specified interval.
2)         Compares the sampled values with the predefined threshold and triggers events if all triggering conditions are met.
&  Note:
If a sampled alarm variable overpasses the same threshold multiple times, only the first one can cause an alarm event. That is, the rising alarm and falling alarm are alternate.
III. Private alarm group
The private alarm group calculates the sampled values of alarm variables and compares the result with the defined threshold, thereby realizing a more comprehensive alarming function.
System handles the prialarm alarm table entry (as defined by the user) in the following ways:
l           Periodically samples the prialarm alarm variables defined in the prialarm formula.
l           Calculates the sampled values based on the prialarm formula.
l           Compares the result with the defined threshold and generates an appropriate event.
&  Note:
If the count result overpasses the same threshold multiple times, only the first one can cause an alarm event. That is, the rising alarm and falling alarm are alternate.
IV. History group
The history group controls the periodic statistical sampling of data, such as bandwidth utilization, number of errors, and total number of packets.
Note that each value provided by the group is a cumulative sum during a sampling period.
V. Ethernet statistics group
The statistics group monitors port utilization. It provides statistics about network collisions, CRC alignment errors, undersize/oversize packets, broadcasts, multicasts, bytes received, packets received, and so on.
After the creation of a valid event entry on a specified interface, the Ethernet statistics group counts the number of packets received on the current interface. The result of the statistics is a cumulative sum.
2.2   Configuring RMON
2.2.1  Configuration Prerequisites
Before configuring RMON, configure the SNMP agent as described in SNMP Configuration.
2.2.2  Configuration Procedure
Follow these steps to configure RMON:
To do…
Use the command…
Remarks
Enter system view
Create an event entry in the event table
rmon event entry-number [ description string ] { log | log-trap log-trapcommunity | none | trap trap-community } [ owner text ]
Optional
Enter Ethernet port view
Create an entry in the history table
rmon history entry-number buckets number interval sampling-interval [ owner text ]
Optional
Create an entry in the statistics table
rmon statistics entry-number [ owner text ]
Optional
Exit Ethernet port view
Create an entry in the alarm table
rmon alarm entry-number alarm-variable sampling-interval { absolute | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
Optional
Create an entry in the private alarm table
rmon prialarm entry-number prialarm-formula prialarm-des sampling-interval { absolute |  changeratio | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
Optional
&  Note:
l      Two entries with the same configuration cannot be created. If the parameters of a newly created entry are identical to the corresponding parameters of an existing entry, the system considers their configurations the same and the creation fails. Refer to Table 2-1 for the parameters to be compared for different entries.
l      The system limits the total number of all types of entries (Refer to Table 2-1 for the detailed numbers). When the total number of an entry reaches the maximum number of entries that can be created, the creation fails.
l      When you create an entry in the history table, if the specified buckets number argument exceeds the history table size supported by the device, the entry will be created. However, the validated value of the buckets number argument corresponding with the entry is the history table size supported by the device.
Table 2-1 Restrictions on the configuration of RMON
Entry
Parameters to be compared
Maximum number of entries that can be created
Event
Event description (description string), event type (log, trap, logtrap or none) and community name (trap-community or log-trapcommunity)
60
History
Sampling interval (interval sampling-interval)
100
Statistics
Only one statistics entry can be created on an interface.
100
Alarm
Alarm variable (alarm-variable), sampling interval (sampling-interval), sampling type (absolute or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2)
60
Pri-alarm
Alarm variable formula (alarm-variable), sampling interval (sampling-interval), sampling type (absolute, changeratio or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2)
50
2.3  Displaying and Maintaining RMON
To do…
Use the command…
Remarks
Display RMON statistics
display rmon statistics [ interface-type interface-number ]
Display RMON history information and the latest history sampling information
display rmon history [ interface-type interface-number ]
Display RMON alarm configuration information
display rmon alarm [ entry-number ]
Display RMON prialarm configuration information
display rmon prialarm [ entry-number ]
Display RMON events configuration information
display rmon event [ entry-number ]
Display RMON event log information
display rmon eventlog [ event-number ]
2.4  RMON Configuration Example
Agent is connected to a configuration terminal through its console port and to a remote NMS across the Internet.
Create an entry in the RMON Ethernet statistics table to gather statistics on port Ethernet 1/0/1, and logging is enabled after the received bytes on the port exceed the specified threshold.
II. Network diagram
Figure 2-1 Network diagram for RMON
# Configure RMON to gather statistics for Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] rmon statistics 1 owner user1-rmon
[Sysname-Ethernet1/0/1] quit
# Display RMON statistics on Ethernet 1/0/1.
<Sysname> display rmon statistics ethernet 1/0/1
Statistics entry 1 owned by user1-rmon is VALID.
  Gathers statistics of interface Ethernet1/0/1. Received:
  octets                : 270149  , packets            : 1954
  broadcast packets   :1570    , multicast packets :365
  undersized packets  :0         , oversized packets:0
  fragments packets   :0         , jabbers packets   :0
  CRC alignment errors:0         , collisions        :0
  Dropped packet events (due to lack of resources):0
  Packets received according to length (in octets):
  64     :644       ,  65-127  :518       ,  128-255  :688
  256-511:101      ,  512-1023:3         ,  1024-1518:0
# Create an event to start logging after the event is triggered.
[Sysname] rmon event 1 log owner 1-rmon
# Configure an alarm group to sample received bytes on Ethernet 1/0/1. When the received bytes exceed the upper or below the lower limit, logging is enabled.
[Sysname] rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 delta rising-threshold 1000 1 falling-threshold 100 1 owner 1-rmon
[Sysname] display rmon alarm 1
Alarm table 1 owned by 1-rmon is VALID.
  Samples type          : delta
  Variable formula      : 1.3.6.1.2.1.16.1.1.1.4.1<etherStatsOctets.1>
  Sampling interval     : 10(sec)
  Rising threshold      : 1000(linked with event 1)
  Falling threshold     : 100(linked with event 1)
  When startup enables  : risingOrFallingAlarm
  Latest value          : 2552
