H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
34-DNS Command
34-DNS Command 58 KB
Chapter 1  DNS Configuration Commands
1.1  DNS Configuration Commands
1.1.1  display dns domain
display dns domain [ dynamic ]
View
Parameter
dynamic: Display the DNS suffixes dynamically configured by DHCP or other protocols.
Use the display dns domain command to display the DNS suffixes.
Related command: dns domain.
Example
# Display DNS suffixes
<H3C> display dns domain
No         Domain-name
0          aaa.com
Table 1-1 Description on the fields of the display dns domain command
No
Domain-name
Domain name suffix
1.1.2  display dns dynamic-host
View
Parameter
None
Use the display dns dynamic-host command to display the dynamic domain name resolution cache information.
The dynamic domain name resolution caches resent mappings between names and IP addresses. For the same domain name query, the DNS Client would not send to the DNS Server if it is stored in the cache.
Example
# Display the information in the dynamic domain name resolution cache.
<H3C> display dns dynamic-host
No  Domain-name           IpAddress            TTL      Alias
0   www.baidu.com         202.108.249.134      63000
1   www.yahoo.akadns.net  66.94.230.39         24
2   www.hotmail.com       207.68.172.239       3585
3   www.eyou.com          61.136.62.70         3591
Table 1-2 Description on the field of the display dns dynamic-host command
No
Domain-name
IpAddress
IP address for the corresponding domain name
TTL
Time for storing in the cache memory (s).
Alias
Alias for the domain name, maximum 4
1.1.3  display dns server
display dns server [ dynamic ]
View
Parameter
Dynamic: Display the DNS Server information configured by DHCP or other protocols
Use the display dns server command to display the DNS Server information.
Related command: dns server.
Example
# Display the DNS Server information.
<H3C> display dns server
Domain-server        IpAddress
     0               169.254.65.125
     1               169.254.66.15
Table 1-3 Description on fields of the display dns server command
Domain-server
Number of the DNS Server. Configured automatically by the device, starts from 0.
Servers with IPv4 or IPv6 addresses are numbered respectively.
IpAddress
IPv4 address of the DNS Server
Ipv6Address
IPv6 address of the DNS Server
Interface Name
Only available when the DNS Server is configured with an IPv6 address.
1.1.4  display ip host
display ip host
View
Parameter
None
Use the display ip host command to display the host names and corresponding IP addresses in the static domain name resolution resolving list.
Example
# Display the host names and corresponding IP addresses in the static domain name resolution resolving list.
<H3C> display ip host
Host         Age     Flags       Address
My           0       static      1.1.1.1
Aa           0       static      2.2.2.4
Table 1-4 Description on fields of the display ip host command
Host
Host name
Age
Time to live. 0 means the static list is never outdated.
You can only manually remove the mappings between host names and IP addresses.
Flags
Mapping types between host names and IP addresses.
Static is the type for static domain name resolution
Address
Host IP addresses
1.1.5  dns domain
dns domain domain-name
undo dns domain [ domain-name ]
View
Parameter
domain-name: DNS suffixes, comprises 1 to 60 characters, including letters, numbers, hyphens (-), underscores (_), and dots (.).
Use the dns domain command to configure the DNS suffixes.
Use the undo dns domain command to delete the DNS suffixes.
No DNS suffixes are configured by default.
You can configure maximum 10 DNS suffixes. You must input the suffix name to delete it, otherwise, all the statically configured suffixes are deleted.
Related command: display dns domain.
&  Note:
The domain name resolution function supported by S3100-52P switch should be used together with a domain name server. Different domain name server may have differences in DNS implementation. For example, the S3100-52P supports a domain name which includes “_”, while a Windows 2000 Server may not able to resolve the “_”.
Example
# Configure com as a DNS suffix.
<H3C> system-view
[H3C] dns domain com
1.1.6  dns resolve
dns resolve
undo dns resolve
View
Parameter
None
Use the dns resolve command to enable dynamic domain name resolution.
Use the undo dns resolve command to disable dynamic domain name resolution.
Dynamic domain name resolution is disabled by default.
Example
# Enable dynamic domain name resolution.
<H3C> system-view
[H3C] dns resolve
1.1.7  dns server
dns server ip-address
undo dns server [ ip-address ]
View
Parameter
ip-address: IP address of the DNS Server.
Use the dns server command to configure an IP address to the DNS Server.
Use the undo dns server to remove IP addresses.
No IP address is configured to the DNS Server by default.
You can configure maximum 6 DNS Servers.
Related command: display dns server.
Example
# Configure a DNS Server address to 172.16.1.1.
<H3C> system-view
[H3C] dns server 172.16.1.1
1.1.8  ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Parameter
Hostname: Host name, comprises 1 to 20 characters, including letters, numbers, hyphens (-), or dots (.). The host name must include at least one letter.
ip-address: IP address of the specified host in dotted decimal notation.
Use the ip host command to create a mapping between host name and IP address in the static resolving list.
Use the undo ip host command to remove the mapping.
No mappings are created by default.
You can configure only one mapping between IP address to host name. For example, a new mapping configured will overwrite the old one if there is any.
Related command: display ip host.
Example
# Configure IP address 10.110.0.1 to a host named aaa.
<H3C> system-view
[H3C] ip host aaa 10.110.0.1
1.1.9  nslookup type
nslookup type { ptr ip-address | a domain-name }
View
Parameter
ptr ip-address: Resolves the corresponding DNS domain name for an IP address.
a domain-name: Resolves the corresponding IP address for a DNS domain name. The domain name which is a string up to 30 characters supports automatic domain name completing.
Use the nslookup type command to display the results of DNS resolution. It can resolve the corresponding IP address for a specified domain name or resolve the corresponding domain name for a specified IP address.
Example
# Display the corresponding domain name for 192.168.3.2.
<H3C> nslookup type ptr 192.168.3.2
Trying DNS server (10.72.66.36)
Address:  192.168.3.2
# Display the corresponding IP address for www.h3c.com.
<H3C> nslookup type a www.h3c.com
1.1.10  reset dns dynamic-host
View
Parameter
None
Use the reset dns dynamic-host command to clear the cache.
Related command: display dns dynamic-host.
Example
# Clear the cache.
<H3C> reset dns dynamic-host
