H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
28-File System Management Command
28-File System Management Command 130 KB
Chapter 1  File System Management Configuration Commands
1.1  File Attribute Configuration Commands
1.1.1  boot attribute-switch
boot attribute-switch { all | app | configuration | web }
View
Parameter
all: Specifies all the files, including app files, configuration files and Web files.
app: Specifies app files.
configuration: Specifies configuration files.
web: Specifies Web files.
Use the boot attribute-switch command to switch between the main and backup attribute for all the files or a specified type of files. That is, change a file with the main attribute to one with the backup attribute, or vice versa.
Example
# Switch the attributes of all the files.
<H3C> boot attribute-switch all
The boot, web and configuration file's backup-attribute and main-attribute will exchange.
 Are you sure? [Y/N] y
 The boot, web and configuration file's backup-attribute and main-attribute exchanged successfully on unit 1!
1.1.2  boot boot-loader
boot boot-loader file-url
View
Parameter
file-url: Path or the name of the app file in the Flash memory, a string comprising 1 to 64 characters.
Use the boot boot-loader command to configure an app file of a device to be with the main attribute. The app file specified by this command becomes the main startup file when the device starts up next time.
Example
# Configure the file named boot.bin to be the main startup file of the device.
<H3C> boot boot-loader boot.bin
 The specified file will be booted next time on unit 1!
1.1.3  boot boot-loader backup-attribute
boot boot-loader backup-attribute file-url
View
Parameter
Use the boot boot-loader backup-attribute command to configure an app file of a device to be with the backup attribute. The app file specified by this command becomes the backup startup file when the device starts up next time. When the main startup file is unavailable, the backup startup file is used to start the switch.
Example
# Configure the file named backup.bin to be the backup startup file of the device.
<H3C> boot boot-loader backup-attribute backup.bin
 Set boot file backup-attribute successfully on unit 1!
1.1.4  boot web-package
boot web-package webfile { backup | main }
View
Parameter
webfile: Name of a Web file, a string comprising 5 to 127 characters.
main: Specifies the file to be with the main attribute.
backup: Specifies the file to be with the backup attribute.
Use the boot web-package command to configure a Web file to be with the main or backup attribute.
  Caution:
l      The configuration of the main or backup attribute for a Web file takes effect immediately without restarting the device.
l      After you upgrade a Web file, you need to specify the new Web file in the Boot menu after restarting the switch. Otherwise, the Web server cannot function normally.
Example
# Configure the Web file named boot.web to be with the main attribute.
<H3C> boot web-package boot.web main
1.1.5  display boot-loader
display boot-loader [ unit unit-id ]
View
Parameter
unit unit-id: Specifies the unit ID of a switch, which must be 1.
Use the display boot-loader command to display the information about the app startup files of a specific device. Displayed information includes the current app startup file name, and the main and backup app startup files to be used when the switch starts up next time.
Example
# Display the information about the app startup files.
<H3C> display boot-loader
 Unit 1:
   The current boot app is: s3152p.bin
   The main boot app is:    s3152p.bin
   The backup boot app is:  s3152p.bin
1.1.6  startup bootrom-access enable
undo startup bootrom-access enable
View
Parameter
None
Use the startup bootrom-access enable command to specify a switch to prompt users to use customized password to enter the BOOT menu.
Use the undo startup bootrom-access enable command to disable the above function.
By default, users have to use customized passwords to enter the BOOT menu.
You can use the display startup command to view the execution results of these two commands.
Example
# Specify to prompt users to use customized passwords to enter the BOOT menu.
<H3C> startup bootrom-access enable
1.2  File System Configuration Commands
&  Note:
Note to limit the lengths of device name, directory name, file path and file name within the following ranges regulated for the switch.
l      A directory name should be no more than 91 characters.
l      A file name plus its local path name should be no more than 127 characters.
l      A device name should be no more than 14 characters.
l      A file name plus its complete path name should be no more than 142 characters.
1.2.1  cd
cd directory
View
Parameter
directory: Target directory.
Use the cd command to enter a specified directory on the Ethernet switch.
The default directory is the root directory of Flash memory.
Example
# Enter the directory named test.
<H3C> cd test
<H3C> pwd
unit1>flash:/test
1.2.2  copy
copy fileurl-source fileurl-dest
View
Parameter
fileurl-source: Path name or file name of the source file in the Flash memory.
fileurl-dest: Path name or file name of the target file in the Flash memory.
Use the copy command to copy a file.
If the fileurl-dest argument identifies an existing file, the system prompts you for the confirmation to overwrite the existing file.
Example
# Copy the file from flash:/config.cfg into flash:/test/1.cfg.
<H3C> copy flash:/config.cfg flash:/test/1.cfg
Copy unit1>flash:/config.cfg to unit1>flash:/test/1.cfg?[Y/N]:y
%Copy file unit1>flash:/config.cfg to unit1>flash:/test/1.cfg...Done.
1.2.3  delete
delete [ /unreserved ] file-url
delete { running-files | standby-files } [ /unreserved ]
View
Parameter
/unreserved: Specifies to delete a file completely.
file-url: Path name or file name of a file in the Flash memory. You can use the * character in this argument as a wildcard. For example, the delete *.txt command deletes all the files with txt as their extensions.
running-files: Specifies to delete all the files with the main attribute.
standby-files: Specifies to delete all the files with the backup attribute.
Use the delete command to delete a specified file from the Flash memory on a switch.
You can use the * character in the argument as a wildcard.
If you execute the delete command with the /unreserved keyword specified, the specified file is permanently deleted. That is, the file cannot be restored.
You can delete files based on file attribute. If you execute the delete running-files command, all the files with the main attribute will be deleted. If you execute the delete standby-files command, all the files with the backup attribute will be deleted.
For a file that has both the main and backup attributes, the delete running-files deletes its main attribute only instead of deleting the file itself, and the delete standby-files command deletes its backup attribute only instead of deleting the file itself.
Following are the notes concerning with the deleted files:
l           The deleted files are moved to the recycle bin.
l           The dir command cannot display the information about deleted files.
l           To display the information about deleted files, use the dir /all command.
l           To restore a deleted file, use the undelete command.
l           To restore the deleted files from the recycle bin, use the undelete command; to delete the files permanently from the recycle bin, use the reset recycle-bin command.
When you use the delete running-files or delete standby-files command, you will be prompted to confirm whether to delete all files with the main/backup attribute. If you choose yes, the corresponding files are deleted. If you choose no, the system will further to prompt you to confirm the following items orderly:
1)         Delete the image files with the main/backup attribute?
2)         Delete the configuration files with the main/backup attribute?
3)         Delete the Web files with the main/backup attribute?
The corresponding messages are displayed as follows:
Delete the running image file? [Y/N]:n
Delete the running config file? [Y/N]:n
Delete the running web file? [Y/N]:n
Delete the backup image file? [Y/N]:n
Delete the backup config file? [Y/N]:n
Delete the backup web file? [Y/N]:n
The corresponding files will be deleted after you choose yes.
  Caution:
For deleted files whose names are the same, only the latest deleted file is stored in the recycle bin and can be restored.
Example
# Delete the file test/test.txt.
<H3C> delete test/test.txt
Delete unit1>flash:/test/test.txt?[Y/N]:y
%Delete file unit1>flash:/test/test.txt...Done.
# Delete the files with the main attribute.
<H3C> delete running-files
Delete the running files ? [Y/N]:y
Start deleting ..........
Deleting ... done
1.2.4  dir
dir [ /all ] [ file-url ]
View
Parameter
/all: Specifies to display the information about all the files, including those in the recycle bin.
file-ur: Path name or the name of a file in the Flash memory. You can use the * character as a wildcard. For example, the dir *.txt command displays the information about all the files with the extension of txt in the current directory.
Use the dir command to display the information about the specified files or directories in the Flash memory on a switch.
In the output information, files with the main, backup or main/backup attribute are tagged.
&  Note:
In the output information of the dir /all command, deleted files (that is, those in the recycle bin) are embraced in brackets.
Example
# Display the information about all the ordinary files in the root directory of the file system.
<H3C> dir
Directory of unit1>flash:/
   1 (*b)  -rw-   3272557  Jul 24 2006 12:00:00   s3152p.bin
   2       -rw-    310368  Apr 01 2000 23:58:47   s3100-52p.btm
   3       -rw-      1890  Apr 02 2000 00:04:51   moni_pcs01_02.cfg
   4       -rw-      2059  Apr 02 2000 13:57:57   123.cfg
   5 (b)   -rw-      4428  Apr 02 2000 03:54:25   startup.cfg
   6       -rw-    728656  Apr 02 2000 15:19:35   default.diag
   7       -rw-        65  Apr 02 2000 16:23:19   temp1
   8       -rw-    310480  Apr 02 2000 16:36:40   s4e02_00c08.btm
   9       -rw-    100784  Apr 02 2000 17:16:00   cmdtree.txt
7239 KB total (2476 KB free)
(*) -with main attribute   (b) -with backup attribute
(*b) -with both main and backup attribute
# Display the information about all the files whose names begin with the character t (including those in the recycle bin) in the local directory flash:/test/.
<H3C> dir /all test/t*
Directory of unit1>flash:/test/
   0       -rw-    279296  Apr 04 2000 14:45:19   test.txt
15367 KB total (3720 KB free)
1.2.5  execute
execute filename
View
Parameter
filename: Batch file, with the extension .bat.
Use the execute command to execute the specified batch file.
This command executes command lines in the batch file in sequence. Note that the batch file cannot contain any invisible character. If any invisible character is found, the command will quit the current execution process and the executed operations are not cancelled automatically.
The batch execution command is the automation of executing commands in a batch file. However it
l           Does not guarantee that every command in the file is executed.
l           Does not perform hot backup.
l           Does not restrict the forms and contents of commands in the file.
Example
# Execute the batch file named test.bat under the directory flash:/.
<H3C> system-view
[H3C] execute test.bat
<H3C>
%Created dir unit1>flash:/test3.
1.2.6  file prompt
file prompt { alert | quiet }
View
Parameter
alert: Specifies to prompt for confirmation before performing file-related operations that have potential risks.
quiet: Specifies to disable prompts for file-related operations.
Use the file prompt command to configure the prompt mode for file-related operations.
By default, alert mode is used, by which a switch prompts for confirmation before performing file-related operations that have potential risks.
If you set the prompt mode of the file-related operations to quiet, the switch does not prompt for confirmation before performing file-related operations. In this case, the system is more likely to operate improperly if irretrievable file-related operations are performed. For example, if the prompt mode is set to alert, the following messages will be displayed when you delete a file:
<H3C> delete unit1>flash:/te.txt
Delete unit1>flash:/te.txt?[Y/N]:y
%Delete file unit1>flash:/te.txt...Done.
If the prompt mode is set to quiet, the following messages will be displayed when you delete a file:
Example
# Set the prompt mode to quiet for file-related operations.
<H3C> system-view
[H3C] file prompt quiet
1.2.7  fixdisk
fixdisk device
View
Parameter
device: Name of a device.
Use the fixdisk command to restore space on the Flash memory.
In case that space on the Flash memory may become unavailable for reasons such as abnormal operations, you can run this command to restore the space.
Example
# Restore space on the Flash memory.
<H3C> fixdisk flash:
Fixdisk flash: may take some time to complete.
%Fixdisk unit1>flash: completed.
1.2.8  format
format device
View
Parameter
Use the format command to format the Flash memory.
  Caution:
The format operation leads to the loss of all the files on the Flash memory, and the operation is irretrievable.
Example
# Format the Flash memory.
<H3C>format unit1>flash:
All data on unit1>flash: will be lost , proceed with format ? [Y/N]:y
%Format unit1>flash: completed.
1.2.9  mkdir
mkdir directory
View
Parameter
directory: Name of a directory.
Use the mkdir command to create a directory in the specified directory of a Flash memory.
Note that the names of the directories and files in the same directory must be unique.
Example
# Create a directory in the current directory, with the name being dd.
<H3C> mkdir dd
%Created dir unit1>flash:/dd.
1.2.10  more
more file-url
View
Parameter
Use the more command to display the contents of a specified file.
Currently, the contents of a file can only be displayed in text.
Example
# Display the content of the file named test.txt.
<H3C> more test.txt
AppWizard has created this test application for you.
This file contains a summary of what you will find in each of the files that make up your test application.
Test.dsp
This file (the project file) contains information at the project level and is used to build a single project or subproject. Other users can share the project (.dsp) file, but they should export the makefiles locally.
1.2.11  move
move fileurl-source fileurl-dest
View
Parameter
Use the move command to move a file to a specified directory.
If the target file name is the same as an existing file, the system prompts you for the confirmation to overwrite the existing file.
Example
# Move the file named 1.txt from flash:/ to flash:/a/, with the name unchanged.
<H3C>move unit1>flash:/1.txt unit1>flash:/a/
Move unit1>flash:/1.txt to unit1>flash:/a/1.txt?[Y/N]:y
%Moved file unit1>flash:/1.txt to unit1>flash:/a/1.txt.
1.2.12  pwd
pwd
View
Parameter
None
Use the pwd command to display the current path.
Example
# Display the current path.
<H3C> pwd
unit1>flash:
1.2.13  rename
rename fileurl-source fileurl-dest
View
Parameter
fileurl-source: Original path name or file name of a file in the Flash memory.
fileurl-dest: Target path name or file name.
Use the rename command to rename a file or a directory.
If the target file name or directory name is the same with any existing file name or directory name, you will fail to perform the rename operation.
Example
# Rename the file named config.txt to config.bak.
<H3C>rename config.txt config.bak
Rename unit1>flash:/config.txt to unit1>flash:/config.bak?[Y/N]:y
%Renamed file unit1>flash:/config.txt to unit1>flash:/config.bak.
1.2.14  reset recycle-bin
reset recycle-bin [ file-url ] [ /force ]
View
Parameter
file-url: Path name or file name of a file in the Flash memory. This argument supports the wildcard “*”.
/force: Specifies not to prompt for confirmation before deleting files.
Use the reset recycle-bin command to clear the recycle bin in the Flash memory.
The files deleted by the delete command are moved to the recycle bin. To delete them permanently, you can use the reset recycle-bin command.
Example
# Clear the recycle bin.
<H3C>reset recycle-bin unit1>flash:/
Clear unit1>flash:/te.txt ?[Y/N]:y
Clearing files from flash may take a long time. Please wait...
%Cleared file unit1>flash:/~/te.txt.
1.2.15  rmdir
rmdir directory
View
Parameter
Use the rmdir command to delete a directory.
As only empty directories can be deleted, you need to clear a directory before deleting it.
Example
# Delete the directory named dd.
<H3C> rmdir dd
Rmdir unit1>flash:/dd?[Y/N]:y
%Removed directory unit1>flash:/dd.
1.2.16  undelete
undelete file-url
View
Parameter
Use the undelete command to restore a deleted file from the recycle bin.
If the name of the file to be restored is the same as that of an existing file, the system prompts you for the confirmation to overwrite the latter.
Example
# Restore the deleted file named sample.bak.
<H3C> undelete sample.bak
Undelete unit1>flash:/sample.bak ?[Y/N]:y
% Undeleted file unit1>flash:/sample.bak.
Chapter 2  FTP/TFTP Lighting Configuration Commands
2.1  FTP Configuration Commands
2.1.1  ftp server enable
ftp server enable
undo ftp server
View
Parameter
None
Use the ftp server enable command to enable FTP server and allow FTP users to log in.
Use the undo ftp server command to disable FTP server and deny FTP users to log in.
By default, FTP server is disabled.
You can use the commands here to enable or disable FTP server. Disabling FTP server can ensure secure operating of the device.
Example
# Disable FTP server.
<H3C> system-view
[H3C] undo ftp server
% Close FTP server
2.1.2  local-user
local-user user-name
undo local-user { user-name | all [ service-type { telnet | ftp | lan-access | ssh | terminal } ] }
View
Parameter
user-name: Local user name, a character string of no more than 80 characters. This string cannot contain the following characters: /:*?<>. It can contain no more than one "@" character; the pure user name (the part before "@", that is, the user ID) cannot be longer than 55 characters. The user name is case-insensitive; that is, the system considers UserA and usera as the same user.
service-type: Specifies a user type. You can specify one of the following user types: telent, ftp, lan-access (this type of users are mainly Ethernet access users, for example, 802.1x users), ssh, and terminal (this type of users can use terminal service, that is, the users can log into the switch through Console port, AUX port, or Asynchronous serial port).
all: Specifies all users.
Use the local-user command to add a local user and enter local user view.
Use the undo local-user command to delete the specified local user(s).
Example
# Add a local user named hello1.
<H3C> system-view
[H3C] local-user hello1
New local user added.
[H3C-luser-hello1]
2.1.3  local-user password-display-mode
local-user password-display-mode { auto | cipher-force }
undo local-user password-display-mode
View
Parameter
auto: Specifies to display passwords in the modes adopted when the passwords are set. If a password is set in cipher mode, the password will be displayed in cipher text; or else, the password will be displayed in plain text.
cipher-force: Specifies to display passwords in cipher text forcibly.
Use the local-user password-display-mode command to set the password display mode when the switch displays the local users.
Use the undo local-user password-display-mode command to restore the default password display mode.
If the cipher-force mode is adopted, the passwords will be displayed in cipher text even though the password command is used to specify the password display mode to simple.
By default, the password display mode of local users is auto.
Example
# Set the password display mode when the switch displays local users to cipher-force.
<H3C>system-view
[H3C] local-user password-display-mode cipher-force
2.1.4  password
password { simple | cipher } password
undo password
View
Local user view
Parameter
simple: Specifies to display password in plain text.
cipher: Specifies to display password in cipher text.
password: Password to be set. In simple mode, it is a string of 1 to 63 characters; in cipher mode, it is a character string of 1 to 63 characters or fixed 88 characters.
Use the password command to set a password for the local user.
Use the undo password command to cancel the password setting.
Note that, after the local-user password-display-mode cipher-force command is used, the user password will be displayed in cipher text even though the password command is used to specify the password display mode to simple.
Example
# Set the password of user hello1 to 20030422 in plain text.
<H3C> system-view
[H3C-luser-hello1] password simple 20030422
2.1.5  ftp
ftp [ ipaddress [ port ] ]
View
Parameter
ipaddress: IP address of a remote FTP server.
port: Port number of the remote FTP server. If the port argument is not specified, the default port number will be used.
Use the ftp command to establish a control connection with a remote FTP server and enter FTP client view.
Example
# Connect to the remote FTP server whose IP address is 1.1.1.1.
<H3C> ftp 1.1.1.1
Trying ...
Press CTRL+K to abort
Connected.
220 FTP service ready.
User(none):hello
331 Password required for hello.
Password:
230 User logged in.
2.1.6  get
get remotefile [ localfile ]
View
FTP client command view
Parameter
localfile: Local file name.
remotefile: File name on the remote FTP server.
Use the get command to download a remote file and save the file to the local device.
If no local file name is specified, the switch will save the remote file locally with the same file name as that on the remote FTP server
Example
# Download the file temp1.c and save it as local file temp.c .
<H3C> ftp 1.1.1.1
Trying ...
Connected.
User(none):hello
Password:
230 User logged in.
[ftp] get temp1.c temp.c
200 Port command okay.
150 Opening ASCII mode data connection for temp1.c.
..226 Transfer complete.
FTP: 1709 byte(s) received in 2.176 second(s) 0.00 byte(s)/sec.
[ftp]
2.2  TFTP Configuration Commands
2.2.1  tftp get
tftp tftp-server get source-file [ dest-file ]
View
Parameter
tftp-server: IP address or host name of a TFTP server.
source-file: Name of the file which will be downloaded from the TFTP server.
dest-file: Name of the file to which the downloaded file will be saved on the switch.
Use the tftp get command to download a file from a TFTP server to this switch.
Example
# Download the file LANSwitch.bin from the TFTP server, whose IP address is 1.1.3.214, to this switch and save it to the file vs.bin.
<H3C> tftp 1.1.3.214 get LANSwitch.bin vs.bin
