H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
07-GVRP Command
07-GVRP Command 58 KB
Chapter 1  GVRP Configuration Commands
1.1  GARP Configuration Commands
1.1.1  display garp statistics
display garp statistics [ interface interface-list ]
View
Parameter
interface-list: List of Ethernet ports. You can specify multiple Ethernet ports by providing this argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] } &<1-10>, where &<1-10> means that you can provide up to 10 port indexes/port index lists for this argument.
Use the display garp statistics command to display the GARP statistics of specified ports or all ports.
This command displays the following information:
l           Number of the GVRP packets received
l           Number of the GVRP packets transmitted
l           Number of the packets discarded
Example
# Display the GARP statistics of Ethernet1/0/1.
<H3C> display garp statistics interface Ethernet1/0/1
GARP statistics on port Ethernet1/0/1
         Number Of GVRP Frames Received          : 0
         Number Of GVRP Frames Transmitted       : 0
         Number Of Frames Discarded              : 0
1.1.2  display garp timer
display garp timer [ interface interface-list ]
View
Parameter
Use the display garp timer command to display the settings of the GARP timers on specified ports or all ports.
This command displays the settings of the following timers:
l           Join timer
l           Leave timer
l           LeaveAll timer
l           Hold timer
Related command: garp timer, garp timer leaveall.
Example
# Display the settings of the GARP timers on port Ethernet1/0/1.
<H3C> display garp timer interface Ethernet1/0/1
                 Garp Join Time          : 20 centiseconds
                 Garp Leave Time         : 60 centiseconds
                 Garp LeaveAll Time      : 1000 centiseconds
                 Garp Hold Time          : 10 centiseconds
1.1.3  garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
Ethernet port view
Parameter
hold: Sets the GARP Hold timer. When a GARP entity receives a piece of registration information, it does not send out a Join message immediately. Instead, to save the bandwidth resources, it starts the Hold timer, puts all registration information it receives before the timer times out into one Join message and sends out the message after the timer times out.
join: Sets the GARP Join timer. To transmit the Join messages reliably to other entities, a GARP entity sends each Join message two times. The Join timer is used to define the interval for sending each Join message.
leave: Sets the GARP Leave timer. When a GARP entity expects to deregister a piece of attribute information, it sends out a Leave message. Any GARP entity receiving this message starts its Leave timer, and deregisters the attribute information if it does not receives a Join message again before the timer times out.
timer-value: Timeout time (in centiseconds) of the GARP timer (Hold, Join or Leave) to be set. This argument needs to be a multiple of 5. By default, it is 10, 20, and 60 for Hold, Join and Leave timers respectively.
Use the garp timer command to set a GARP timer (that is, the Hold timer, the Join timer, or the Leaver timer) for an Ethernet port.
Use the undo garp timer command to restore the default setting of a GARP timer.
The timeout ranges of the timers vary depending on the timeout values you set for other timers. If you want to set the timeout time of a timer to a value out of the current range, you can set the timeout time of the associated timer to another value to change the timeout range of this timer.
The following table describes the relations between the timers:
Table 1-1 Relations between the timers
Timer
Lower threshold
Upper threshold
Hold
10 centiseconds
This upper threshold is less than or equal to one-half of the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
Join
This lower threshold is greater than or equal to twice the timeout time of the Hold timer. You can change the threshold by changing the timeout time of the Hold timer.
This upper threshold is less than one-half of the timeout time of the Leave timer. You can change the threshold by changing the timeout time of the Leave timer.
Leave
This lower threshold is greater than twice the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
This upper threshold is less than the timeout time of the LeaveAll timer. You can change the threshold by changing the timeout time of the LeaveAll timer.
LeaveAll
This lower threshold is greater than the timeout time of the Leave timer. You can change threshold by changing the timeout time of the Leave timer.
32,765 centiseconds
Related command: display garp timer.
Example
# Set the GARP Join timer to 20 centiseconds for Ethernet1/0/1.
<H3C> system-view
[H3C] interface Ethernet1/0/1
[H3C-Ethernet1/0/1] garp timer join 20
1.1.4  garp timer leaveall
garp timer leaveall timer-value
undo garp timer leaveall
View
Parameter
timer-value: Setting (in centiseconds) of the GARP LeaveAll timer. You need to set this argument with the Leave timer settings of other Ethernet ports as references. That is, this argument needs to be larger than the Leave timer settings of any Ethernet ports. Also note that this argument needs to be a multiple of 5 and cannot be larger than 32,765.
By default, the LeaveAll timer is set to 1,000 centiseconds (that is, 10 seconds).
Use the garp timer leaveall command to set the GARP LeaveAll timer.
Use the undo garp timer leaveall command to restore the default setting of the GARP LeaveAll timer.
Once a GARP entity starts up, it starts the LeaveAll timer, and sends out a LeaveALL message after the timer times out, so that other GARP entities can re-register all the attribute information on this entity. After that, the entity restarts the LeaveAll timer to begin a new cycle.
Example
# Set the GARP LeaveAll timer to 100 centiseconds.
<H3C> system-view
[H3C] garp timer leaveall 100
1.1.5  reset garp statistics
reset garp statistics [ interface interface-list ]
View
Parameter
Use the reset garp statistics command to clear the GARP statistics (such as the information about the packets received/sent/discarded by GVRP/GMRP) on specified or all ports.
Executing the reset garp statistics command without any parameter clears the GARP statistics of all ports.
Related command: display garp statistics.
Example
# Clear GARP statistics of all ports.
<H3C> reset garp statistics
1.2  GVRP Configuration Commands
1.2.1  display gvrp statistics
display gvrp statistics [ interface interface-list ]
View
Parameter
Use the display gvrp statistics command to display the GVRP statistics of all trunk ports.
l           GVRP status
l           Number of the GVRP entries that fail to be registered
l           Source MAC address of the previous GVRP PDU
l           GVRP registration type of a port
Example
# Display the GVRP statistics of Ethernet1/0/1, assuming that the port is a trunk port.
<H3C> display gvrp statistics interface Ethernet 1/0/1
        GVRP statistics on port Ethernet1/0/1
                GVRP Status                     : Enabled
                GVRP Failed Registrations       : 0
                GVRP Last Pdu Origin            : 0000-0000-0000
                GVRP Registration Type          : Normal
1.2.2  display gvrp status
display gvrp status
View
Parameter
None
Use the display gvrp status command to display the global GVRP status (enabled or disabled).
Example
# Display the global GVRP status.
<H3C> display gvrp status
GVRP is enabled
The above information indicates that GVRP is enabled globally.
1.2.3  gvrp
gvrp
undo gvrp
View
System view, Ethernet port view
Parameter
None
Use the gvrp command to enable GVRP globally (in system view) or for a port (in Ethernet port view).
Use the undo gvrp command to disable GVRP globally (in system view) or on a port (in Ethernet port view).
By default, GVRP is disabled both globally and on ports.
Note that:
l           To enable GVRP for a port, you need to enable GVRP globally first.
l           GVRP is disabled on any port if GVRP is disabled globally. In this case, you cannot enable GVRP for a port.
l           You can enable/disable GVRP only on trunk ports.
l           After you enable GVRP on a trunk port, you cannot change the port to other types.
Related command: display gvrp status.
Example
# Enable GVRP globally.
<H3C> system-view
[H3C] gvrp
1.2.4  gvrp registration
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Ethernet port view
Parameter
fixed: Allows the manual creation and registration of VLANs on the current port, and inhibits the dynamic registration and deregistration of VLANs on the current port.
forbidden: Deregisters all the VLANs except VLAN 1 on the current port, and inhibits the creation and registration of any other VLAN on the current port.
normal: Allows both manual and dynamic creation, registration, and deregistration of VLANs on the current port.
Use the gvrp registration command to configure the GVRP registration type on a port.
Use the undo gvrp registration command to restore the default GVRP registration type on a port.
By default, the registration type is normal.
Note that these commands can be operated only on trunk ports.
Related command: display gvrp statistics
Example
# Configure the GVRP registration type on the port Ethernet1/0/1 to fixed.
<H3C> system-view
[H3C-Ethernet1/0/1] gvrp registration fixed
