H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
35-Appendix
35-Appendix 279 KB
Appendix A  Command Index
The command index includes all the commands in the Comware Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
AAA-RADIUS-HWTACACS
1-1
accounting
AAA-RADIUS-HWTACACS
1-2
accounting optional
AAA-RADIUS-HWTACACS
1-3
accounting optional
AAA-RADIUS-HWTACACS
1-28
accounting-on enable
AAA-RADIUS-HWTACACS
1-29
acl
Login
2-1
acl
ACL
1-1
active region-configuration
MSTP
1-1
add-member
Cluster
1-15
administrator-address
Cluster
1-16
arp check enable
ARP
1-1
arp static
ARP
1-1
arp timer aging
ARP
1-2
ascii
FTP and TFTP
1-6
attribute
AAA-RADIUS-HWTACACS
1-4
authentication
AAA-RADIUS-HWTACACS
1-5
authentication-mode
Login
1-1
authorization
AAA-RADIUS-HWTACACS
1-6
auto-build
Cluster
1-17
auto-execute command
Login
1-2
B
binary
FTP and TFTP
1-7
boot attribute-switch
File System Management
1-1
boot boot-loader
1-1
boot boot-loader
System Maintenance and Debugging
3-1
boot boot-loader backup-attribute
1-2
boot bootrom
3-1
boot web-package
1-3
bpdu-drop any
MSTP
1-2
bpdu-tunnel
VLAN-VPN
2-1
bpdu-tunnel uplink
VLAN-VPN
2-2
broadcast-suppression
Port Basic Configuration
1-1
build
Cluster
1-18
bye
SSH Terminal Service
1-28
bye
FTP and TFTP
1-8
C
cd
1-28
cd
1-5
cd
FTP and TFTP
1-9
cdup
1-29
cdup
FTP and TFTP
1-9
check region-configuration
MSTP
1-2
clock datetime
1-1
clock summer-time
1-1
clock timezone
1-2
close
FTP and TFTP
1-10
cluster
Cluster
1-20
cluster enable
Cluster
1-20
cluster switch-to
Cluster
1-21
cluster-mac
Cluster
1-22
cluster-mac syn-interval
Cluster
1-23
command-privilege level
CLI
1-1
copy
1-5
copy configuration
1-2
count
HWPing
1-1
cut connection
AAA-RADIUS-HWTACACS
1-7
D
databits
Login
1-3
data-flow-format
AAA-RADIUS-HWTACACS
1-31
data-flow-format
AAA-RADIUS-HWTACACS
1-63
debugging
FTP and TFTP
1-11
debugging
1-10
debugging dhcp client
DHCP
2-1
debugging dhcp irf xha
DHCP
2-1
delete
1-29
delete
1-6
delete
FTP and TFTP
1-12
delete static-routes all
Routing Protocol
2-1
delete-member
Cluster
1-24
description
VLAN
1-1
description
1-4
description
ACL
1-2
destination-ip
HWPing
1-1
dhcp-snooping
DHCP
1-1
dhcp-snooping trust
DHCP
1-1
dir
1-30
dir
1-8
dir
FTP and TFTP
1-13
disconnect
FTP and TFTP
1-14
display acl
ACL
1-3
display arp
ARP
1-3
display arp |
ARP
1-4
display arp count
ARP
1-5
display arp timer aging
ARP
1-6
display boot-loader
1-3
display boot-loader
3-2
display bootp client
DHCP
2-4
display brief interface
1-5
display channel
Information Center
1-1
display clock
1-6
display cluster
Cluster
1-24
display cluster candidates
Cluster
1-26
display cluster members
Cluster
1-28
display connection
AAA-RADIUS-HWTACACS
1-9
display cpu
3-3
display current-configuration
Configuration File Management
1-1
display debugging
1-7
display device
3-4
display dhcp client
DHCP
2-2
display dhcp-snooping
DHCP
1-2
display dhcp-snooping trust
DHCP
1-3
display diagnostic-information
1-10
display dldp
DLDP
1-1
display dns domain
DNS
1-1
display dns dynamic-host
DNS
1-1
display dns server
DNS
1-2
display domain
AAA-RADIUS-HWTACACS
1-11
display dot1x
802.1x
1-1
display fan
3-4
display fib
IP Address and Performance Confiugration
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib ip-prefix
2-5
display fib statistics
2-6
display ftp source-ip
FTP and TFTP
1-15
display ftp-server
FTP and TFTP
1-1
display ftp-server source-ip
FTP and TFTP
1-2
display ftp-user
FTP and TFTP
1-2
display garp statistics
GVRP
1-1
display garp timer
GVRP
1-2
display gvrp statistics
GVRP
1-6
display gvrp status
GVRP
1-7
display habp
802.1x
2-1
display habp table
802.1x
2-2
display habp traffic
802.1x
2-2
display history-command
CLI
1-2
display hwping
HWPing
1-2
display hwtacacs
AAA-RADIUS-HWTACACS
1-63
display icmp statistics
2-6
display igmp-snooping configuration
Multicast
1-1
display igmp-snooping group
Multicast
1-2
display igmp-snooping statistics
Multicast
1-2
display info-center
Information Center
1-1
display interface
1-6
display interface Vlan-interface
VLAN
1-1
display ip host
DNS
1-3
display ip interface
1-1
display ip routing-table
Routing Protocol
1-1
display ip routing-table ip-address
Routing Protocol
1-2
display ip routing-table ip-address1 ip-address2
Routing Protocol
1-4
display ip routing-table protocol
Routing Protocol
1-5
display ip routing-table radix
Routing Protocol
1-6
display ip routing-table statistics
Routing Protocol
1-7
display ip routing-table verbose
Routing Protocol
1-8
display ip socket
2-8
display ip statistics
2-9
display isolate port
Port Isolation
1-1
display lacp system-id
Link Aggregation
1-5
display link-aggregation interface
Link Aggregation
1-1
display link-aggregation summary
Link Aggregation
1-2
display link-aggregation verbose
Link Aggregation
1-4
display local-server statistics
AAA-RADIUS-HWTACACS
1-31
display local-user
AAA-RADIUS-HWTACACS
1-12
display logbuffer
Information Center
1-3
display logbuffer summary
Information Center
1-5
display loopback-detection
1-9
display mac-address
MAC Address Table
1-2
display mac-address aging-time
MAC Address Table
1-1
display mac-address multicast static
Multicast
3-2
display mac-authentication
Centralized MAC Address Authentication
1-1
display memory
3-5
display mirroring-group
Mirroring
1-1
display multicast-source-deny
Multicast
2-1
display ndp
Cluster
1-1
display ntdp
Cluster
1-7
display ntdp device-list
Cluster
1-8
display ntp-service sessions
NTP
1-1
display ntp-service status
NTP
1-2
display ntp-service trace
NTP
1-4
display port
1-11
display port vlan-vpn
VLAN-VPN
1-1
display power
3-6
display protocol-priority
QoS
1-1
display qos cos-local-precedence-map
QoS
1-1
display qos-interface all
QoS
1-2
display qos-interface line-rate
QoS
1-3
display queue-scheduler
QoS
1-4
display radius scheme
AAA-RADIUS-HWTACACS
1-32
display radius statistics
AAA-RADIUS-HWTACACS
1-34
display rmon alarm
SNMP and RMON
2-1
display rmon event
SNMP and RMON
2-2
display rmon eventlog
SNMP and RMON
2-3
display rmon history
SNMP and RMON
2-4
display rmon prialarm
SNMP and RMON
2-6
display rmon statistics
SNMP and RMON
2-7
display rsa local-key-pair public
1-1
display rsa peer-public-key
1-2
display saved-configuration
1-7
display schedule reboot
3-6
display sftp source-ip
1-31
display snmp-agent
SNMP and RMON
1-1
display snmp-agent community
SNMP and RMON
1-1
display snmp-agent group
SNMP and RMON
1-2
display snmp-agent mib-view
SNMP and RMON
1-4
display snmp-agent statistics
SNMP and RMON
1-5
display snmp-agent sys-info
SNMP and RMON
1-6
display snmp-agent trap-list
SNMP and RMON
1-6
display snmp-agent usm-user
SNMP and RMON
1-7
display ssh server
1-3
display ssh server-info
1-18
display ssh user-information
1-4
display ssh2 source-ip
1-17
display ssh-server source-ip
1-5
display startup
1-10
display stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-36
AAA-RADIUS-HWTACACS
1-65
display stp
MSTP
1-4
display stp region-configuration
MSTP
1-6
display tcp statistics
2-11
display tcp status
2-13
display telnet source-ip
Login
1-4
display telnet-server source-ip
Login
1-4
display tftp source-ip
FTP and TFTP
1-31
display this
1-10
display time-range
ACL
1-4
display transceiver-information interface
1-10
display trapbuffer
Information Center
1-5
display udp statistics
2-14
display unit
1-12
display user-interface
Login
1-5
display users
Login
1-7
display users
1-8
display version
1-9
display vlan
VLAN
1-3
display web users
Login
1-8
dldp
DLDP
1-2
dldp authentication-mode
DLDP
1-3
dldp delaydown-timer
DLDP
1-7
dldp interval
DLDP
1-4
dldp reset
DLDP
1-5
dldp unidirectional-shutdown
DLDP
1-5
dldp work-mode
DLDP
1-6
dns domain
DNS
1-4
dns resolve
DNS
1-5
dns server
DNS
1-6
domain
AAA-RADIUS-HWTACACS
1-14
dot1x
802.1x
1-5
dot1x authentication-method
802.1x
1-7
dot1x dhcp-launch
802.1x
1-8
dot1x guest-vlan
802.1x
1-9
dot1x max-user
802.1x
1-10
dot1x port-control
802.1x
1-11
dot1x port-method
802.1x
1-13
dot1x quiet-period
802.1x
1-14
dot1x retry
802.1x
1-15
dot1x retry-version-max
802.1x
1-15
dot1x supp-proxy-check
802.1x
1-16
dot1x timer
802.1x
1-19
dot1x version-check
802.1x
1-21
duplex
1-13
E
enable snmp trap updown
SNMP and RMON
1-8
execute
1-9
exit
1-31
F
file prompt
1-10
fixdisk
1-11
flow interval
1-15
flow-control
1-14
format
1-12
free user-interface
Login
1-9
free web-users
Login
2-1
frequency
HWPing
1-5
ftp
2-4
ftp
FTP and TFTP
1-15
ftp { cluster | remote-server } source-interface
FTP and TFTP
1-16
ftp { cluster | remote-server } source-ip
FTP and TFTP
1-17
ftp cluster
Cluster
1-30
ftp disconnect
FTP and TFTP
1-3
ftp server enable
2-1
ftp server enable
FTP and TFTP
1-4
ftp source-interface
FTP and TFTP
1-17
ftp source-ip
FTP and TFTP
1-18
ftp timeout
FTP and TFTP
1-4
ftp-server
Cluster
1-31
ftp-server source-interface
FTP and TFTP
1-5
FTP and TFTP
1-6
G
garp timer
GVRP
1-2
garp timer leaveall
GVRP
1-4
get
1-32
get
2-5
get
FTP and TFTP
1-19
giant-frame statistics enable
1-16
gratuitous-arp-learning enable
ARP
1-7
gvrp
GVRP
1-7
gvrp registration
GVRP
1-8
H
habp enable
802.1x
2-3
habp server vlan
802.1x
2-4
habp timer
802.1x
2-5
header
Login
1-9
help
1-32
history-command max-size
Login
1-12
holdtime
Cluster
1-31
hwping
HWPing
1-6
hwping-agent enable
HWPing
1-7
hwtacacs nas-ip
AAA-RADIUS-HWTACACS
1-65
hwtacacs scheme
AAA-RADIUS-HWTACACS
1-66
I
idle-cut
AAA-RADIUS-HWTACACS
1-15
idle-timeout
Login
1-12
igmp-snooping
Multicast
1-3
igmp-snooping fast-leave
Multicast
1-4
igmp-snooping general-query source-ip
Multicast
1-5
igmp-snooping group-limit
Multicast
1-6
igmp-snooping group-policy
Multicast
1-7
igmp-snooping host-aging-time
Multicast
1-9
igmp-snooping max-response-time
Multicast
1-10
igmp-snooping querier
Multicast
1-11
igmp-snooping query-interval
Multicast
1-11
igmp-snooping router-aging-time
Multicast
1-12
info-center channel name
Information Center
1-6
info-center console channel
Information Center
1-7
info-center enable
Information Center
1-8
info-center logbuffer
Information Center
1-8
info-center loghost
Information Center
1-9
info-center loghost source
Information Center
1-10
info-center monitor channel
Information Center
1-11
info-center snmp channel
Information Center
1-12
info-center source
Information Center
1-13
info-center synchronous
Information Center
1-17
info-center timestamp
Information Center
1-18
info-center timestamp loghost
Information Center
1-19
info-center trapbuffer
Information Center
1-20
instance
MSTP
1-7
interface
1-16
VLAN
1-4
ip address
1-3
ip address bootp-alloc
DHCP
2-5
ip address dhcp-alloc
DHCP
2-3
ip forward-broadcast
2-16
ip host
DNS
1-6
ip http acl
Login
2-2
ip http shutdown
Login
1-13
ip route-static
Routing Protocol
2-2
ip-pool
Cluster
1-32
J
jumboframe enable
1-17
K
key
AAA-RADIUS-HWTACACS
1-37
key
AAA-RADIUS-HWTACACS
1-67
L
lacp enable
Link Aggregation
1-6
lacp port-priority
Link Aggregation
1-6
lacp system-priority
Link Aggregation
1-7
language-mode
1-3
lcd
FTP and TFTP
1-20
level
AAA-RADIUS-HWTACACS
1-15
line-rate
QoS
1-4
link-aggregation group agg-id description
Link Aggregation
1-8
link-aggregation group agg-id mode
Link Aggregation
1-8
local-server
AAA-RADIUS-HWTACACS
1-38
local-server nas-ip
AAA-RADIUS-HWTACACS
1-39
local-user
AAA-RADIUS-HWTACACS
1-16
local-user
2-1
local-user password-display-mode
AAA-RADIUS-HWTACACS
1-17
2-2
lock
Login
1-14
logging-host
Cluster
1-33
loopback
1-18
loopback-detection control enable
1-19
loopback-detection enable
1-20
loopback-detection interval-time
1-20
loopback-detection per-vlan enable
1-21
ls
1-33
ls
FTP and TFTP
1-21
M
mac-address
MAC Address Table
1-4
mac-address max-mac-count
MAC Address Table
1-6
mac-address multicast interface
Multicast
3-1
mac-address multicast vlan
Multicast
3-2
mac-address timer
MAC Address Table
1-7
mac-authentication
1-3
mac-authentication authmode usernameasmacaddress
1-5
mac-authentication authmode usernamefixed
1-6
mac-authentication authpassword
1-7
mac-authentication authusername
1-8
mac-authentication domain
1-8
mac-authentication interface
1-4
mac-authentication timer
1-9
management-vlan
Cluster
1-34
mdi
1-22
messenger
AAA-RADIUS-HWTACACS
1-18
mirroring-group
Mirroring
1-2
mirroring-group mirroring-port
Mirroring
1-3
mirroring-group monitor-port
Mirroring
1-3
mirroring-group reflector-port
Mirroring
1-4
mirroring-group remote-probe vlan
Mirroring
1-5
mirroring-port
Mirroring
1-6
mkdir
1-34
mkdir
1-12
mkdir
FTP and TFTP
1-22
monitor-port
Mirroring
1-6
more
1-13
move
1-13
Multicast
2-2
multicast-suppression
1-22
N
name
VLAN
1-5
name
AAA-RADIUS-HWTACACS
1-19
nas-ip
AAA-RADIUS-HWTACACS
1-40
nas-ip
AAA-RADIUS-HWTACACS
1-68
ndp enable
Cluster
1-3
ndp timer aging
Cluster
1-4
ndp timer hello
Cluster
1-5
nm-interface Vlan-interface
Cluster
1-35
nslookup type
DNS
1-7
ntdp enable
Cluster
1-10
ntdp explore
Cluster
1-11
ntdp hop
Cluster
1-11
ntdp timer
Cluster
1-12
ntdp timer hop-delay
Cluster
1-13
ntdp timer port-delay
Cluster
1-14
ntp-service access
NTP
1-4
ntp-service authentication enable
NTP
1-5
ntp-service authentication-keyid
NTP
1-6
ntp-service broadcast-client
NTP
1-7
ntp-service broadcast-server
NTP
1-7
ntp-service in-interface disable
NTP
1-8
ntp-service max-dynamic-sessions
NTP
1-9
ntp-service multicast-client
NTP
1-10
ntp-service multicast-server
NTP
1-10
ntp-service reliable authentication-keyid
NTP
1-11
ntp-service source-interface
NTP
1-12
ntp-service unicast-peer
NTP
1-13
ntp-service unicast-server
NTP
1-14
O
open
FTP and TFTP
1-23
P
parity
Login
1-15
passive
FTP and TFTP
1-23
password
AAA-RADIUS-HWTACACS
1-20
password
2-3
peer-public-key end
1-5
ping
2-1
port
VLAN
1-9
port access vlan
1-23
port hybrid pvid vlan
1-24
port hybrid vlan
1-25
port isolate
Port Isolation
1-1
port link-aggregation group
Link Aggregation
1-9
port link-type
1-26
port trunk permit vlan
1-27
port trunk pvid vlan
1-28
primary accounting
AAA-RADIUS-HWTACACS
1-41
primary accounting
AAA-RADIUS-HWTACACS
1-69
primary authentication
AAA-RADIUS-HWTACACS
1-42
AAA-RADIUS-HWTACACS
1-70
primary authorization
AAA-RADIUS-HWTACACS
1-71
priority
QoS
1-5
priority trust
QoS
1-6
protocol inbound
Login
1-16
protocol inbound
1-6
protocol-priority protocol-type
QoS
1-7
public-key-code begin
1-7
1-19
public-key-code end
1-7
public-key-code end
1-19
put
1-34
put
FTP and TFTP
1-24
pwd
1-35
pwd
1-14
pwd
FTP and TFTP
1-25
Q
QoS
1-9
queue-scheduler
QoS
1-11
1-20
1-35
FTP and TFTP
1-26
1-4
R
radius client
AAA-RADIUS-HWTACACS
1-44
radius nas-ip
AAA-RADIUS-HWTACACS
1-44
radius scheme
AAA-RADIUS-HWTACACS
1-45
radius trap
AAA-RADIUS-HWTACACS
1-46
radius-scheme
AAA-RADIUS-HWTACACS
1-21
reboot
3-7
reboot member
Cluster
1-35
region-name
MSTP
1-8
remotehelp
FTP and TFTP
1-27
remote-probe vlan
Mirroring
1-7
remove
1-36
rename
1-36
rename
1-15
rename
FTP and TFTP
1-28
reset arp
ARP
1-8
reset counters interface
1-29
reset dns dynamic-host
DNS
1-8
reset dot1x statistics
802.1x
1-22
reset garp statistics
GVRP
1-5
reset hwtacacs statistics
AAA-RADIUS-HWTACACS
1-72
reset igmp-snooping statistics
Multicast
1-13
reset ip routing-table
Routing Protocol
2-1
reset ip statistics
2-16
reset lacp statistics
Link Aggregation
1-10
reset logbuffer
Information Center
1-21
reset mac-authentication
1-10
reset ndp statistics
Cluster
1-6
reset radius statistics
AAA-RADIUS-HWTACACS
1-47
reset recycle-bin
1-15
reset saved-configuration
1-12
reset stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-48
AAA-RADIUS-HWTACACS
1-72
reset stp
MSTP
1-9
reset tcp statistics
2-17
reset trapbuffer
Information Center
1-21
reset udp statistics
2-17
retry
AAA-RADIUS-HWTACACS
1-49
retry realtime-accounting
AAA-RADIUS-HWTACACS
1-50
retry stop-accounting
AAA-RADIUS-HWTACACS
1-51
AAA-RADIUS-HWTACACS
1-73
return
1-4
revision-level
MSTP
1-9
rmdir
1-37
rmdir
1-16
rmdir
FTP and TFTP
1-29
rmon alarm
SNMP and RMON
2-9
rmon event
SNMP and RMON
2-11
rmon history
SNMP and RMON
2-12
rmon prialarm
SNMP and RMON
2-13
rmon statistics
SNMP and RMON
2-16
rsa local-key-pair create
1-8
rsa local-key-pair destroy
1-9
rsa peer-public-key
1-10
rsa peer-public-key
1-21
rsa peer-public-key import sshkey
1-10
rule (for Advanced ACLs)
ACL
1-7
rule (for Basic ACLs)
ACL
1-5
rule (for Layer 2 ACLs)
ACL
1-13
rule (for user-defined ACLs)
ACL
1-16
rule comment
ACL
1-18
S
save
1-13
schedule reboot at
3-8
schedule reboot delay
3-9
schedule reboot regularity
3-10
scheme
AAA-RADIUS-HWTACACS
1-22
screen-length
Login
1-17
secondary accounting
AAA-RADIUS-HWTACACS
1-52
AAA-RADIUS-HWTACACS
1-74
secondary authentication
AAA-RADIUS-HWTACACS
1-53
AAA-RADIUS-HWTACACS
1-75
secondary authorization
AAA-RADIUS-HWTACACS
1-76
self-service-url
AAA-RADIUS-HWTACACS
1-23
send
Login
1-17
server-type
AAA-RADIUS-HWTACACS
1-54
service-type
Login
1-18
service-type
AAA-RADIUS-HWTACACS
1-24
service-type multicast
Multicast
1-13
set authentication password
Login
1-20
sftp
1-37
sftp server enable
1-26
sftp source-interface
1-39
sftp source-ip
1-39
sftp timeout
1-27
shell
Login
1-21
shutdown
VLAN
1-6
shutdown
1-29
snmp-agent
SNMP and RMON
1-9
Login
2-3
SNMP and RMON
1-10
snmp-agent group
Login
2-3
snmp-agent group
SNMP and RMON
1-11
snmp-agent local-engineid
SNMP and RMON
1-12
snmp-agent log
SNMP and RMON
1-13
snmp-agent mib-view
SNMP and RMON
1-14
snmp-agent packet max-size
SNMP and RMON
1-14
snmp-agent sys-info
SNMP and RMON
1-15
snmp-agent target-host
SNMP and RMON
1-16
snmp-agent trap enable
SNMP and RMON
1-17
snmp-agent trap life
SNMP and RMON
1-19
snmp-agent trap queue-size
SNMP and RMON
1-19
snmp-agent trap source
SNMP and RMON
1-20
snmp-agent usm-user
Login
2-5
snmp-agent usm-user
SNMP and RMON
1-21
snmp-host
Cluster
1-36
speed
Login
1-22
speed
1-30
ssh authentication-type default
1-11
ssh client assign rsa-key
1-21
ssh client first-time enable
1-22
ssh server authentication-retries
1-12
ssh server timeout
1-13
ssh user assign rsa-key
1-14
ssh user authentication-type
1-15
ssh user service-type
1-26
ssh2
1-23
ssh2 source-interface
1-24
ssh2 source-ip
1-25
ssh-server source-interface
1-16
1-17
startup bootrom-access enable
1-4
startup saved-configuration
1-15
state
AAA-RADIUS-HWTACACS
1-25
state
AAA-RADIUS-HWTACACS
1-55
stop-accounting-buffer enable
AAA-RADIUS-HWTACACS
1-56
stopbits
Login
1-22
stp
MSTP
1-10
stp bpdu-protection
MSTP
1-11
stp bridge-diameter
MSTP
1-12
stp compliance
MSTP
1-13
stp config-digest-snooping
MSTP
1-14
stp cost
MSTP
1-16
stp edged-port
MSTP
1-17
stp interface
MSTP
1-18
stp interface config-digest-snooping
MSTP
1-19
stp interface cost
MSTP
1-21
stp interface edged-port
MSTP
1-22
stp interface loop-protection
MSTP
1-23
stp interface mcheck
MSTP
1-24
stp interface no-agreement-check
MSTP
1-25
stp interface point-to-point
MSTP
1-26
stp interface port priority
MSTP
1-27
stp interface root-protection
MSTP
1-28
stp interface transmit-limit
MSTP
1-29
stp loop-protection
MSTP
1-30
stp max-hops
MSTP
1-31
stp mcheck
MSTP
1-32
stp mode
MSTP
1-33
stp no-agreement-check
MSTP
1-34
stp pathcost-standard
MSTP
1-35
stp point-to-point
MSTP
1-37
stp port priority
MSTP
1-38
stp priority
MSTP
1-39
MSTP
1-40
stp root primary
MSTP
1-41
stp root secondary
MSTP
1-42
stp root-protection
MSTP
1-43
stp tc-protection
MSTP
1-44
stp timer forward-delay
MSTP
1-45
stp timer hello
MSTP
1-46
stp timer max-age
MSTP
1-47
stp timer-factor
MSTP
1-48
stp transmit-limit
MSTP
1-49
super
CLI
1-2
super password
CLI
1-3
sysname
Login
1-23
sysname
1-5
1-6
T
tcp timer fin-timeout
2-18
tcp timer syn-timeout
2-18
tcp window
2-19
telnet
Login
1-24
telnet source-interface
Login
1-26
telnet source-ip
Login
1-27
telnet-server source-interface
Login
1-25
Login
1-25
terminal debugging
Information Center
1-21
terminal debugging
1-12
terminal logging
Information Center
1-22
terminal monitor
Information Center
1-23
terminal trapping
Information Center
1-23
test-enable
HWPing
1-7
test-type
HWPing
1-8
tftp
FTP and TFTP
1-32
tftp cluster get
Cluster
1-37
tftp cluster put
Cluster
1-37
tftp get
2-5
tftp get
FTP and TFTP
1-32
tftp put
FTP and TFTP
1-33
tftp source-interface
FTP and TFTP
1-35
tftp source-ip
FTP and TFTP
1-36
tftp tftp-server source-interface
FTP and TFTP
1-34
tftp tftp-server source-ip
FTP and TFTP
1-34
tftp-server
Cluster
1-38
tftp-server acl
FTP and TFTP
1-37
timeout
HWPing
1-8
timer
AAA-RADIUS-HWTACACS
1-57
timer
Cluster
1-39
timer quiet
AAA-RADIUS-HWTACACS
1-58
timer quiet
AAA-RADIUS-HWTACACS
1-77
timer realtime-accounting
AAA-RADIUS-HWTACACS
1-59
AAA-RADIUS-HWTACACS
1-77
timer response-timeout
AAA-RADIUS-HWTACACS
1-60
AAA-RADIUS-HWTACACS
1-79
time-range
ACL
1-19
tracert
2-3
U
undelete
1-16
unicast-suppression
1-31
unknown-multicast drop enable
Multicast
4-1
user
FTP and TFTP
1-29
user privilege level
Login
1-28
user-interface
Login
1-27
user-name-format
AAA-RADIUS-HWTACACS
1-61
user-name-format
AAA-RADIUS-HWTACACS
1-79
V
verbose
FTP and TFTP
1-30
virtual-cable-test
1-32
vlan
VLAN
1-7
vlan to
VLAN
1-8
vlan-assignment-mode
AAA-RADIUS-HWTACACS
1-26
vlan-mapping modulo
MSTP
1-50
vlan-vpn enable
VLAN-VPN
1-2
vlan-vpn inner-cos-trust
VLAN-VPN
1-3
vlan-vpn tpid
VLAN-VPN
1-3
vlan-vpn tunnel
MSTP
2-1
W
X
Y
Z
