H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
21-ACL Command
21-ACL Command 139 KB
Chapter 1  ACL Configuration Commands
1.1  ACL Configuration Commands
1.1.1  acl
acl number acl-number [ match-order { config | auto } ]
undo acl { number acl-number | all }
View
Parameter
number acl-number: Specifies the number of an existing access control list (ACL) or an ACL to be defined. ACL number identifies the type of an ACL as follows.
l           An ACL number in the range 2000 to 2999 identifies a basic ACL.
l           An ACL number in the range 3000 to 3999 identifies an advanced ACL.
l           An ACL number in the range 4000 to 4999 identifies a layer 2 ACL.
l           An ACL number in the range 5000 to 5999 identifies a user-defined ACL.
match-order: Specifies the match order for the ACL rules of the ACL. This keyword is not available to Layer 2 ACLs or user-defined ACLs. Following two match orders exist.
l           config: Specifies to match ACL rules in the order they are defined.
l           auto: Specifies to match ACL rules according to the depth-first rule.
all: Specifies to remove all the ACLs.
Use the acl command to define an ACL and enter the corresponding ACL view.
Use the undo acl command to remove all the rules of an ACL or all the ACLs.
By default, ACL rules are matched in the order they are defined.
In ACL view, you can use the rule command to add rules to the ACL.
Rules of an ACL can be matched in one of the following orders.
l           Configured order: ACL rules are matched in the order they are defined.
l           Automatic order: ACL rules are matched according to the “depth-first” rule.
The “depth-first” order is described as follows:
l           The “depth-first” ordering of rules in IP ACLs (including basic ACLs and advanced ACLs) is implemented based on the lengths of the source IP address/mask and the destination IP address/mask. The rule with the longest masks is first matched, and then comes the rule with the second longest masks, and so on. In the ordering, the lengths of the source IP addresses/masks are compared first; if the source IP address masks have the same length, the lengths of the destination IP address masks are compared. For example, the rule with the source IP address mask being 255.255.255.0 precedes the rule with the source IP address mask being 255.255.0.0 in the match order.
You can use the match-order keyword to specify whether to use the configured order or “depth-first” order (rules with smaller ranges are matched first) to match rules. If neither match orders are specified, the configured match order will be adopted.
You cannot modify the match order for an ACL once you have specified it, unless you remove all the rules of the ACL and define new rules in the desired order.
The rules of an ACL are matched in a specific order only when the ACL is referenced by software for data filtering and traffic classification.
Related command: rule.
Example
# Define ACL 2000 and specify “depth-first” order as the rule match order.
<H3C> system-view
[H3C] acl number 2000 match-order auto
[H3C-acl-basic-2000]
1.1.2  description
View
Basic ACL view, advanced ACL view, Layer 2 ACL view, user-defined ACL view
Parameter
text: Description string to be assigned to an ACL, a string of up to 127 characters.
Use the description command to assign a description string to an ACL.
Use the undo description to remove the description string of an ACL.
Example
# Assign a description string to ACL 3100.
<H3C> system-view
[H3C] acl number 3100
[H3C-acl-adv-3100] description This acl is used in eth 0
# Remove the description string of ACL 3100.
[H3C-acl-adv-3100] undo description
1.1.3  display acl
display acl { all | acl-number }
View
Parameter
all: Displays all the ACLs.
acl-number: Number of the ACL to be displayed, in the range of 2000 to 5999.
Use the display acl command to display the configuration of an ACL or all the ACL, including ACL type, ACL number, number of the rules of an ACL, description string (if configured), ACL rule number step, and ACL content.
Example
# Display the information about all the ACLs.
<H3C>display acl all
Total ACL Number: 2
Basic ACL  2000, 1 rule
Acl's step is 1
 rule 0 permit
Advanced ACL  3000, 0 rule
Acl's step is 1
1.1.4  display time-range
display time-range { all | time-name }
View
Parameter
all: Displays all the time ranges.
time-name: Name of a time range, a string that starts with [a-z, A-Z] and can contain up to 32 characters.
Use the display time-range command to display the configuration and status of a time range or all the time ranges. For active time ranges, this command displays “active”; for inactive time ranges, this command displays “inactive”.
Related command: time-range.
Example
# Display all the time ranges.
<H3C> display time-range all
Current time is 14:36:36 Apr/3/2003 Thursday
Time-range : hhy ( Inactive )
 from 08:30 2/5/2005 to 18:00 2/19/2005
Time-range : hhy1 ( Inactive )
 from 08:30 2/5/2003 to 18:00 2/19/2003
Table 1-1 Description on the fields of the display time-range command
System time
 from 08:30 2/5/2005 to 18:00 2-19-2005
The information about the time range named hhy:
l      Inactive: This time range is currently in the inactive state (while “Active” indicates that the time range is in the active state)
l      The time range is from 8:30 February 5, 2005 to 18:00 February 19, 2005.
# Display the information about the time range named “tm1”.
<H3C> display time-range tm1
Current time is 14:37:31 Apr/3/2003 Thursday
Time-range : tm1 ( Inactive )
Table 1-2 Description on the fields of the display time-range command
System time
The information about the time range named tm1:
l      Inactive: This time range is currently in the inactive state (while “Active” indicates that the time range is in the active state).
1.1.5  rule (for Basic ACLs)
rule [ rule-id ] { permit | deny } [ fragment | source { sour-addr sour-wildcard | any } | time-range time-name ]*
undo rule rule-id [ fragment | source | time-range ]*
View
Basic ACL view
Parameter
I. Parameters of the rule command
rule-id: ACL rule ID, in the range of 0 to 65534.
deny: Drops the matched packets.
permit: Permits the matched packets.
fragment: Specifies that the rule only applies to the packets that are not the first fragments.
source { sour-addr sour-wildcard | any }: Specifies the source address for the rule. The sour-addr argument is the source IP address in dotted decimal notation. The sour-wildcard argument is the wildcard mask for the source subnet mask of the packet, expressed in dotted decimal notation. For example, you need to input 0.0.255.255 for the subnet mask 255.255.0.0. You can set sour-wildcard to 0 to represent the host IP address. any is used to represent any arbitrary IP address.
time-range time-name: Specifies a time range within which the rule is valid.
II. Parameters of the undo rule command
rule-id: Rule ID, which must the ID of an existing ACL rule. If no other arguments are specified, the entire ACL rule is removed. Otherwise, only the specified information of the ACL rule is removed.
fragment: Specifies that the ACL rule applies to other types of packets besides those that are not the first fragments.
source: Removes the settings concerning the source address in the ACL rule.
time-range: Deletes the settings concerning time range in the ACL rule.
Use the rule command to define an ACL rule.
Use the undo rule command to remove an ACL rule or specified settings of an ACL rule.
To remove an ACL rule using the undo rule command, you need to provide the ID of the ACL rule. You can obtain the ID of an ACL rule by using the display acl command.
When you define an ACL rule using the rule command with the rule-id argument provided,
l           If the ACL rule identified by the rule-id argument already exists, the settings specified in the rule command overwrite the corresponding settings of the existing rule. And the existing settings remain unchanged if the corresponding settings are not specified in the command.
l           If the ACL rule identified by the rule-id argument does not exist, you will create a new ACL rule.
l           The content of a modified or created ACL rule cannot be identical with the content of any existing ACL rules; otherwise the ACL rule modification or creation will fail, and the system prompts that the rule already exists.
If you do not specify the rule-id argument when creating an ACL rule, the ACL rule will be numbered automatically.
Example
# Create an ACL rule to deny the packets whose source IP addresses are 1.1.1.1.
<H3C> system-view
[H3C-acl-basic-2000] rule deny source 1.1.1.1 0
1.1.6  rule (for Advanced ACLs)
rule [ rule-id ] { permit | deny } rule-string
undo rule rule-id [ destination | destination-port | dscp | fragment | icmp-type | precedence | source | source-port | time-range | tos ]*
View
Advanced ACL view
Parameter
rule-string: ACL rule information, which can be a combination of the parameters described in Table 1-3. Note that this argument must begin with the protocol argument.
Table 1-3 Arguments/keywords available to the rule-string argument
Arguments/Keywords
Function
protocol
Protocol type
Type of the protocols carried by IP
When expressed in numerals, this argument ranges from 1 to 255.
When expressed with a name, the value can be GRE, ICMP, IGMP, IP, IPinIP, OSPF, TCP, and UDP.
Source address
Specifies the source address information for the ACL rule
The sour-addr sour-wildcard arguments specify the source address of the packets, expressed in dotted decimal notation. You can specify the IP address of a host as the source address by providing 0 for the sour-wildcard argument.
The any keyword specifies any source address.
destination { dest-addr dest-wildcard | any }
Destination address
Specifies the destination address information for the ACL rule
The dest-addr dest-wildcard arguments specify the destination address of the packets, expressed in dotted decimal notation. You can specify the IP address of a host as the destination address by providing 0 for the dest-wildcard argument.
The any keyword specifies any destination address.
precedence precedence
Packet priority
Packet precedence
The precedence argument ranges from 0 to 7.
tos tos
Packet priority
ToS
The tos argument ranges from 0 to 15.
dscp dscp
Packet priority
DSCP
The dscp argument ranges from 0 to 63.
fragment
Fragment information
Specifies that the rule is effective for the packets  that are not the first fragments.
Time range information
Specifies the time range in which the ACL rule is active.
&  Note:
The sour-wildcard/dest-wildcard argument is the complement of the wildcard mask of the source/destination subnet mask. For example, you need to input 0.0.255.255 to specify the subnet mask 255.255.0.0. The arguments can be set as 0 to represent a host IP address.
If you specify the dscp keyword, you can directly input a value ranging from 0 to 63 or input one of the keywords listed in Table 1-4 as the DSCP.
Table 1-4 DSCP values and the corresponding keywords
Keyword
DSCP value in decimal
DSCP value in binary
ef
46
101110
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
be (default)
0
000000
If you specify the precedence keyword, you can directly input a value ranging from 0 to 7 or input one of the keywords listed in Table 1-5 as the IP precedence.
Table 1-5 IP precedence values and the corresponding keywords
Keyword
IP Precedence in decimal
IP Precedence in binary
routine
0
000
priority
1
001
immediate
2
010
flash
3
011
flash-override
4
100
critical
5
101
internet
6
110
network
7
111
If you specify the tos keyword, you can directly input a value ranging from 0 to 15 or input one of the keywords listed in Table 1-6 as the ToS value.
Table 1-6 ToS value and the corresponding keywords
Keyword
ToS in decimal
ToS in binary
normal
0
0000
min-monetary-cost
1
0001
max-reliability
2
0010
max-throughput
4
0100
min-delay
8
1000
If the protocol type is TCP or UDP, you can also define the information listed in Table 1-7.
Table 1-7 TCP/UDP-specific ACL rule information
Parameter
Function
source-port operator port1 [ port2 ]
Source port
Defines the source port information of UDP/TCP packets
The value of operator can be lt (less than), gt (greater than), eq (equal to), neq (not equal to) or range (within the range of). Only the range operator requires two port numbers as the operands. Other operators require only one port number as the operand.
port1 and port2: TCP/UDP port number(s), expressed as port names or port numbers. When expressed as numerals, the value range is 0 to 65535.
destination-port operator port1 [ port2 ]
Destination port
Defines the destination port information of UDP/TCP packets
established
TCP connection flag
Specifies that the rule applies to TCP packets with the ack or rst flag (Packets of this type are TCP connection packets.)
TCP-specific argument
If the protocol type is ICMP, you can also define the information listed in Table 1-8.
Table 1-8 ICMP-specific ACL rule information
Parameter
Function
icmp-type icmp-type icmp-code
Type and message code information of ICMP packets
Specifies the type and message code information of ICMP packets in the ACL rule
icmp-type: ICMP message type, ranging from 0 to 255
icmp-code: ICMP message code, ranging from 0 to 255
If the protocol type is ICMP, you can also just input the ICMP message name after the icmp-type keyword. Table 1-9 lists some common ICMP messages.
Table 1-9 ICMP messages
Name
ICMP type
ICMP code
echo
Type=8
Code=0
echo-reply
Type=0
Code=0
fragmentneed-DFset
Type=3
Code=4
host-redirect
Type=5
Code=1
host-tos-redirect
Type=5
Code=3
host-unreachable
Type=3
Code=1
information-reply
Type=16
Code=0
information-request
Type=15
Code=0
net-redirect
Type=5
Code=0
net-tos-redirect
Type=5
Code=2
net-unreachable
Type=3
Code=0
parameter-problem
Type=12
Code=0
port-unreachable
Type=3
Code=3
protocol-unreachable
Type=3
Code=2
reassembly-timeout
Type=11
Code=1
source-quench
Type=4
Code=0
source-route-failed
Type=3
Code=5
timestamp-reply
Type=14
Code=0
timestamp-request
Type=13
Code=0
ttl-exceeded
Type=11
Code=0
rule-id: ID of an existing ACL rule. If no other arguments are specified, the entire ACL rule is removed. Otherwise, only the specified information of the ACL rule is removed.
source-port: Removes the settings concerning the source port in the ACL rule. This keyword is only available to the ACL rules with their protocol types set to TCP or UDP.
destination: Removes the settings concerning the destination address in the ACL rule.
destination-port: Removes the settings concerning the destination port in the ACL rule. This keyword is only available to the ACL rules with their protocol types set to TCP or UDP.
icmp-type: Removes the settings concerning the ICMP type and message code in the ACL rule. This keyword is only available to the ACL rules with their protocol type set to ICMP.
precedence: Removes the precedence-related settings in the ACL rule.
tos: Removes the ToS-related settings in the ACL rule.
dscp: Removes the DSCP-related settings in the ACL rule.
time-range: Removes the time range settings in the ACL rule.
Example
# Define an ACL rule to permit packets sourced from hosts in the network segment of 129.9.0.0 and destined for hosts in the network segment of 202.38.160.0 and with the destination port number of 80.
<H3C> system-view
[H3C] acl number 3101
[H3C-acl-adv-3101] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
1.1.7  rule (for Layer 2 ACLs)
rule [ rule-id ] { permit | deny } [ rule-string ]
undo rule rule-id
View
Layer 2 ACL view
Parameter
rule-string: ACL rule information, which can be a combination of the arguments/keywords described in Table 1-10.
Table 1-10 Layer 2 ACL rule information
Parameter
Function
format-type
Link layer encapsulation type
Specifies the link layer encapsulation type in the rule
This argument can be 802.3/802.2, 802.3, ether_ii, or snap.
lsap lsap-code lsap-wildcard
lsap field
Specifies the lsap field for the ACL rule
lsap-code: Encapsulation format of data frames, a 16-bit hexadecimal number.
lsap-wildcard: Mask of the lsap value, a 16-bit hexadecimal number used to specify the mask bits.
source { source-addr source-mask | vlan-id }*
Source MAC address information
Specifies the source MAC address range for the ACL rule
source-addr: Source MAC address, in the format of H-H-H.
source-mask: Mask of the source MAC address, in the format of H-H-H.
vlan-id: Source VLAN ID, in the range of 1 to 4,094.
dest dest-addr dest-mask
Destination MAC address information
Specifies the destination MAC address range for the ACL rule
dest-addr: Destination MAC address, in the format of H-H-H.
dest- mask: Mask of the destination MAC address, in the format of H-H-H.
cos vlan-pri
Priority
Specifies the 802.1p priority of the rule
vlan-pri: VLAN priority, in the range of 0 to 7.
time-name: specifies the name of the time range in which the rule is active; a string comprising 1 to 32 characters.
type protocol-type protocol-mask
Protocol type of Ethernet frames
Specifies the protocol type of Ethernet frames for the ACL rule
protocol-type: Protocol type.
protocol-mask: Protocol type mask.
If you specify the cos keyword, you can directly input a value ranging from 0 to 7 or input one of the keywords listed in Table 1-11 as the CoS precedence.
Table 1-11 CoS values and the corresponding keywords
Keyword
CoS in decimal
CoS in binary
best-effort
0
000
background
1
001
spare
2
010
excellent-effort
3
011
controlled-load
4
100
video
5
101
voice
6
110
network-management
7
111
Use the undo rule command to remove an ACL rule.
Example
# Define a rule to deny the packets sourced from the MAC address 000d-88f5-97ed, destined for the MAC address 011-4301-991e, and with their 802.1p priorities set to 3.
<H3C> system-view
[H3C] acl number 4000
[H3C-acl-ethernetframe-4000] rule deny cos 3 source 000d-88f5-97ed ffff-ffff-ffff dest 0011-4301-991e ffff-ffff-ffff
1.1.8  rule (for user-defined ACLs)
rule [ rule-id ] { permit | deny } [ rule-string rule-mask offset ] &<1-8> [ time-range time-name ]
undo rule rule-id
View
User-defined ACL view
Parameter
rule-id: ID of an ACL rule.
rule-string: User-defined ACL rule string. It must be an even hexadecimal number comprising 2 to 160 characters.
rule-mask: User-defined mask of the ACL rule. It must be an even hexadecimal number containing 2 to 160 hexadecimal characters and be of the same length as that of the rule-string argument. This argument is used to perform the logical AND operations with packets.
offset: Mask offset of the rule. It specifies a position in packets, from which the logical AND operation is to be performed. It ranges from 0 to 79 (in bytes). Note that the maximum value becomes one byte less when the rule-string (and rule-mask) argument has two more characters. For example, when rule-string and rule-mask contains two characters respectively, the maximum value of offset is 79 bytes; when the former contains four characters respectively, the maximum value of offset is 78 bytes, and so on.
&<1-8>: At most eight rules can be defined at one time.
time-range time-name: Specifies a time range within which the ACL rule is valid.
&  Note:
Note the following when setting the offset argument.
l      All the packets processed internally in a switch carry VLAN tags with them. A VLAN tag occupies four bytes of space.
l      With the VLAN VPN function not enabled, a packet processed internally in a switch carries only one VLAN tag.
l      With the VLAN VPN function enabled, a switch inserts another VLAN tag to the packets it processed, making the packets traveling across the network with two VLAN tags carried.
&  Note:
When setting the offset for a user-defined ACL, remember that you need to count two VLAN tags in no matter whether or not the packet is a tagged packet or an untagged packet. To filter 0800 packets using a user-defined ACL, you need to set the offset to 20.
Example
# Define a user-defined ACL rule to deny all TCP packets.
<H3C> system-view
[H3C] time-range t1 18:00 to 23:00 sat
[H3C] acl number 5001
[H3C-acl-user-5001] rule 25 deny 06 ff 35 time-range t1
1.1.9  rule comment
rule rule-id comment text
undo rule rule-id comment
View
Advanced ACL view, Layer 2 ACL view, user-defined ACL view
Parameter
comment text: Specifies the description string, a string comprising up to 127 characters.
Use the rule comment command to assign a description string to an ACL rule.
Use the undo rule comment command to remove the description string assigned to an ACL rule.
Before assigning a description string to an ACL rule, make sure that the ACL rule exists.
Example
# Assign the string “test” to rule 0 of ACL 3000 as the description string.
<H3C> system-view
[H3C] acl number 3000
[H3C-acl-adv-3000] rule 0 comment test
1.1.10  time-range
time-range time-name { start-time to end-time days-of-the-week [ from start-time start-date ] [ to end-time end-date ] | from start-time start-date [ to end-time end-date ] | to end-time end-date }
undo time-range { time-name [ start-time to end-time days-of-the-week [ from start-time start-date ] [ to end-time end-date ] | from start-time start-date [ to end-time end-date ] | to end-time end-date ] | all }
View
Parameter
time-name: Name of a time range, used as the identifier of a time range.
start-time: Start time of a time range, in the form of hh:mm.
end-time: End time of a time range, in the form of hh:mm.
days-of-the-week: Day of the week when the time range is active. You can provide this argument in one of the following forms.
l           Numeral (0 to 6)
l           Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday
l           Working days (Monday through Friday)
l           Off days (Saturday and Sunday)
l           Daily, namely everyday of the week
from start-time start-date: Specifies the start date of a time range, in the form of hh:mm MM/DD/ YYYY. The start-time start-date and end-time end-date argument jointly define a period in which the special time range takes effect.
to end-time end-date: Specifies the end date of a time range, in the form of hh:mm MM/DD/ YYYY. The start-time start-date and end-time end-date argument jointly define a period in which the special time range takes effect.
all: Removes all the time ranges.
Use the time-range command to define a time range.
Use the undo time-range command to remove a time range.
The time range defined by using the time-range command can include absolute time sections and periodic time sections. The start-time and end-time days-of-the-week argument jointly define a periodic time section, while the start-time start-date and end-time end-date argument jointly define an absolute time section.
If only a periodic time section is defined in a time range, the time range is active only when the system time is within the defined periodic time section.
If only an absolute time section is defined in a time range, the time range is active only when the system time is within the defined absolute time section.
If both a periodic time section and an absolute time section are defined in a time range, the time range is active only when the periodic time range and the absolute time range are both matched. Assume that a time range defines an absolute time section from 00:00 January 1, 2004 to 23:59 December 31, 2004, and a periodic time section from 12:00 to 14:00 every Wednesday. This time range is active only when the system time is within 12:00 to 14:00 every Wednesday in 2004.
If you include any argument undo time-range command, the system will removes only the content specified by the argument from the time range.
Example
# Define a time range that is active from 12:00 January 1, 2000 to 12:00 January 1, 2001.
<H3C> system-view
[H3C] time-range test from 12:00 1/1/2000 to 12:00 1/1/2001
