H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
00-1Cover
00-1Cover 329 KB
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08194N-20070410-C-1.01
Product Version: Release 1500
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3100-52P Ethernet Switch documentation set includes the following:
Manual
H3C S3100-52P Ethernet Switch  Installation Manual
It provides information for the system installation and setup.
H3C S3100-52P Ethernet Switch  Operation Manual-Release 1500
It is used for assisting the users in device configurations and typical applications.
Organization
H3C S3100-52P Ethernet Switch Command Manual is organized as follows:
Part
1 CLI
Introduces the commands used for switching between the command levels and command level setting.
2 Login
Introduces the commands used for logging into the Ethernet switch.
3 Configuration File Management
Introduces the commands used for manipulating the configuration files.
4 VLAN
Introduces the commands used for configuring VLANs.
5 IP Address and Performance Confiugration
Introduces the commands used for configuring IP addresses and IP performance.
6 Access Management
Introduces the commands used for access management.
7 GVRP
Introduces the GVRP-related commands.
8 Port Basic Configuration
Introduces the basic port configuration commands.
9 Link Aggregation
Introduces the commands used for link aggregation.
10 Port Isolation
Introduces the commands used for port isolation.
11 DLDP
Introduces the DLDP-related commands.
12 MAC Address Table
Introduces the commands used for MAC address forwarding table management.
13 MSTP
Introduces the STP-related commands.
14 Multicast
Introduces the commands used for multicast protocol configuration.
15 Routing Protocol
Introduces the commands used for routing protocol configuration.
16 802.1x
Introduces the 802.1x-related commands.
17 AAA-RADIUS-HWTACACS
Introduces the commands used for the configuration of AAA, RADIUS, and HWTACACS.
18 Centralized MAC Address Authentication
Introduces the commands used for centralized MAC address authentication.
19 DHCP
Introduces the commands used for DHCP-Snooping.
20 ARP
Introduces the ARP-related commands.
21 ACL
Introduces the ACL-related commands.
22 QoS
Introduces the QoS-related commands.
23 Mirroring
Introduces the commands used for port mirroring.
24 Cluster
Introduces the commands used for cluster management.
25 SNMP and RMON
Introduces the commands used for SNMP and RMON configuration.
26 NTP
Introduces the NTP-related commands.
27 SSH Terminal Service
Introduces the commands used for configuring SSH2.0.
28 File System Management
Introduces the commands used for file system management.
29 FTP and TFTP
Introduces the FTP /TFTP related commands.
30 Information Center
Introduces the commands used for configuring the information center.
31 System Maintenance and Debugging
Introduces the commands used for system maintenance and debugging.
32 VLAN VPN
Introduces the VLAN VPN-related commands.
33 HWPing
Introduces the HWPing-related commands.
34 DNS
Introduces the commands used for domain name resolution.
35 Appendix
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
