H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
33-HWPing Command
33-HWPing Command 64 KB
Chapter 1  HWPing Commands
1.1  HWPing Commands
1.1.1  count
count times
undo count
View
HWPing test group view
Parameter
times: Number of the test packets to be sent in each test. It is in the range 1 to 15 and defaults to 1.
Use the count command to configure the number of packets to be sent in each test.
Use the undo count command to restore the default.
If this parameter is set to a number greater than 1, the system sends the second test packet once it receives a response to the first one, or when the test timer times out if it receives no response after sending the first one, and so forth until the last test packet is sent out.
Related command: frequency.
Example
# Set the “administrator-icmp” test group to send 10 packets in each test.
<H3C> system-view
[H3C] hwping administrator icmp
[H3C-hwping-administrator-icmp] count 10
1.1.2  destination-ip
destination-ip ip-address
undo destination-ip
View
Parameter
ip-address: Destination IP address in a test.
Use the destination-ip command to configure the destination IP address in the test. Use the undo destination-ip command to remove the configured destination IP address.
By default, no destination IP address is configured for any test.
Example
# Set the destination IP address in the test of the “administrator-icmp” test group to 1.1.1.99.
<H3C> system-view
[H3C-hwping-administrator-icmp] destination-ip 1.1.1.99
1.1.3  display hwping
display hwping { results | history } [ administrator-name operation-tag ]
View
Parameter
results: Specifies to display the test results.
history: Specifies to display the test history.
administrator-name: Name of the administrator creating the test.
operation-tag: Test operation tag.
Use the display hwping command to view test result(s).
If a test group is specified using the arguments of administrator-name and test-operation-tag, the system displays only the test result of the group; if not, it displays the test results of all the test groups.
Related command: test-enable.
Example
# Use the display hwping results command to display the test result of the test group whose administrator name is “administrator” and operation tag is “icmp”.
<H3C> display hwping results administrator icmp
  HWPing entry(admin administrator, tag icmp) test result:
      Destination ip address:1.1.1.99
      Send operation times: 10              Receive response times: 10
      Min/Max/Average Round Trip Time: 2/5/2
      Square-Sum of Round Trip Time: 66
      Last complete test time: 2000-4-2 7:59:54.7
  Extend result:
      SD Maximal delay: 0                   DS Maximal delay: 0
      Packet lost in test: 0%
      Disconnect operation number: 0        Operation timeout number: 0
      System busy operation number: 0       Connection fail number: 0
      Operation sequence errors: 0          Drop operation number: 0
      Other operation errors: 0
Table 1-1 Description on the fields of the display hwping results command
Number of send operations
Number of successful test operations
Smallest/biggest/average round-trip time
The square sum of the round trip time
Time of the last successful test
SD Maximal delay
Maximal delay from the source to the destination
DS Maximal delay
Maximal delay from the destination to the source
Packet lost in test
Packet lost ratio in the test.
Number of forced disconnections by the opposite side
Number of timeout times in the test operation
Number of test failures because the system is busy
Number of connection failures
Number of received sequence error packets
Number of system resource allocation errors
Number of other errors
# Use the display hwping history command to display test results.
<H3C> display hwping history administrator icmp
  HWPing entry(admin administrator, tag icmp) history record:
    Index     Response    Status      LastRC       Time
        1            1         1           0    2004-11-25 16:28:55.0
        2            1         1           0    2004-11-25 16:28:55.0
        3            1         1           0    2004-11-25 16:28:55.0
        4            1         1           0    2004-11-25 16:28:55.0
        5            1         1           0    2004-11-25 16:28:55.0
        6            2         1           0    2004-11-25 16:28:55.0
        7            1         1           0    2004-11-25 16:28:55.0
        8            1         1           0    2004-11-25 16:28:55.0
        9            1         1           0    2004-11-25 16:28:55.9
       10            1         1           0    2004-11-25 16:28:55.9
Table 1-2 Description on the fields of the display hwping history command
Index
Index of the displayed information
Response
Round trip test time, in milliseconds, or the timeout time. 0 means the test fails.
Status
Value of the test result. See the following detailed description:
1: responceReceived. It means response is received.
2: unknown. It means unknown error.
3: internalError. It means system internal error.
4: requestTimeOut. It means timeout before response.
5: unknownDestinationAddress. It means the destination address is unknown.
6: noRouteToTarget. It means there is no route to the destination address.
7: interfaceInactiveToTarget. It means the interface of destination address is not activated.
8: arpFailure. It means ARP operation fails.
9: maxConcurrentLimitReached. It means the maximum limit of concurrent accesses is reached.
10: unableToResolveDnsName. It means it is unable to resolve the DNS name.
11: invalidHostAddress. It means the invalid host address.
LastRC
Receive the last response code based on the implementation ways. With ICMP echo enabled, if the system receives ICMP response which includes ICMP_ECHOREPLY(0), the probe has succeeds. ICMP response often defined in the file containing ip_icmp.
Time
Test time
1.1.4  frequency
frequency interval
undo frequency
View
Parameter
interval: Automatic test interval. It ranges from 0 to 65535 seconds and defaults to 0 seconds which means no automatic test.
Use the frequency command to configure an automatic test interval.
Use the undo frequency command to disable automatic test.
The system automatically tests at intervals specified by this command, where the argument interval is greater than 0.
Related command: count.
Example
# Set the automatic test interval of the “administrator-icmp” test group to 10 seconds.
<H3C> system-view
[H3C-hwping-administrator-icmp] frequency 10
1.1.5  hwping
hwping administrator-name operation-tag
undo hwping administrator-name operation-tag
View
Parameter
administrator-name: Name of the administrator creating an HWPing test group, a string of 1 to 32 characters.
operation-tag: Test operation tag, a string of 1 to 32 characters.
Use the hwping command to create an HWPing test group and enter HWPing test group view..
Use the undo hwping command to remove the HWPing test group.
Example
# Create an HWPing test group, where the administrator name is “administrator” and the test operation tag is “icmp”.
<H3C> system-view
1.1.6  hwping-agent enable
hwping-agent enable
undo hwping-agent enable
View
Parameter
None
Use the hwping-agent enable command to enable the HWPing client function.
Use the undo hwping-agent enable command to disable the HWPing client function.
Before you can perform a test, you must enable the HWPing client function.
Example
# Enable HWPing client.
<H3C> system-view
[H3C] hwping-agent enable
1.1.7  test-enable
test-enable
undo test-enable
View
Parameter
None
Use the test-enable command to execute an HWPing test.
Use the undo test-enable command to disable an HWPing test.
&  Note:
After you execute the test-enable command, the system does not display the test result. You may view the test result information by executing the display hwping command.
Related command: display hwping.
Example
# Execute the HWPing test defined by the test group “administrator-icmp”.
<H3C> system-view
[H3C-hwping-administrator-icmp] test-enable
1.1.8  test-type
test-type type
View
Parameter
type: Test type.
Use the test-type command to configure the type of the test.
Currently the system only supports ICMP test.
Example
# Set the test type of the “administrator-icmp” test group to ICMP.
<H3C> system-view
[H3C-hwping-administrator-icmp] test-type icmp
1.1.9  timeout
timeout time
undo timeout
View
Parameter
time: Timeout time. It ranges from 1 to 60 seconds and defaults to 3 seconds.
Use the timeout command to configure a timeout time for a test.
Use the undo timeout command to restore to the default timeout time.
Example
# Set the timeout time of the “administrator-icmp” test group to 10 seconds.
<H3C> system-view
[H3C-hwping-administrator-icmp] timeout 10
