H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
29-FTP and TFTP Command
29-FTP and TFTP Command 188 KB
Chapter 1  FTP and TFTP
1.1  FTP Server Configuration Commands
1.1.1  display ftp-server
display ftp-server
View
Parameter
None
Use the display ftp-server command to display the FTP server-related settings of a switch when it operates as an FTP server.
You can use this command to verify FTP server-related configurations.
Example
# Display the FTP server-related settings of the switch (assuming that the switch is operating as an FTP server).
<H3C> display ftp-server
   FTP server is running
   Max user number       1
   User count            0
   Timeout value(in minute)       30
Table 1-1 Description on the fields of the display ftp-server command
The FTP server is started
Max user number       1
The FTP server can accommodate up to one user.
User count                 0
The current login user number is 0.
Timeout value (in minute)       30
The connection idle time is 30 minutes.
1.1.2  display ftp-server source-ip
View
Parameter
None
Use the display ftp-server source-ip command to display the source IP address set for an FTP server. If a source interface is specified for the FTP server, the IP address of the source interface will be displayed. If neither source interface nor source IP address is specified, 0.0.0.0 will be displayed.
Example
# Display the source IP address set for the FTP server.
<H3C> display ftp-server source-ip
The source IP you specified is 192.168.0.1
1.1.3  display ftp-user
display ftp-user
View
Parameter
None
Use the display ftp-user command to display the settings of the current FTP user, including the user name, host IP address, port number, connection idle time, and authorized directory.
Example
# Display FTP user settings.
<H3C> display ftp-user
Username     Host IP     Port        Idle        Homedir
H3C          10.110.3.5  1074        2       flash:
# If the user name exceeds ten characters, characters behind the tenth will be displayed in the second line with a left-aligning mode. Take username username@test for example, the result is:
username@t   10.110.3.5  1074        2       flash:
est
1.1.4  ftp disconnect
ftp disconnect user-name
View
Parameter
user-name: Name of the user to be disconnected from the FTP server.
Use the ftp disconnect command to terminate the connection between a specified user and the FTP server.
&  Note:
If you attempt to disconnect a user that is uploading/downloading data to/from the FTP server that is acted by an S3100-52P Ethernet switch, the S3100-52P Ethernet switch will disconnect the user after the data transmission is completed.
Example
# Display the current online FTP users.
  UserName             HostIP    Port    Idle              HomeDir
test              192.168.0.3    1229       0              flash:
# Disconnect the user named “test” from the FTP server.
<H3C> system-view
[H3C] ftp disconnect test
% The user connection will be disconnected after the data transfer finished
1.1.5  ftp server enable
ftp sever enable
undo ftp sever
View
Parameter
None
Use the ftp server enable command to enable the FTP server for users to log in.
Use the undo ftp server command to disable the FTP server.
By default, the FTP server is disabled to avoid potential security risks.
Example
# Enable the FTP server.
<H3C> system-view
[H3C] ftp server enable
% Start FTP server
1.1.6  ftp timeout
ftp timeout minutes
undo ftp timeout
View
Parameter
minutes: Connection idle time (in minutes) ranging from 1 to 35,791. The default connection idle time is 30 minutes.
Use the ftp timeout command to set the connection idle time.
Use the undo ftp timeout command to restore the default connection idle time.
If a FTP connection between an FTP server and an FTP client breaks down abnormally, the FTP server is not acknowledged with this and will keep this connection as usual.
You can set a connection idle time, so that the FTP server considers a FTP connection to be invalid and terminate it if no data exchange occurs on it in a specific period known as connection idle time.
Example
# Set the connection idle time to 36 minutes.
<H3C> system-view
[H3C] ftp timeout 36
1.1.7  ftp-server source-interface
ftp-server source-interface interface-type interface-number
undo ftp-server source-interface
View
Parameter
interface-type: Type of the source interface.
interface-number: Number of the source interface.
Use the ftp-server source-interface command to specify the source interface for an FTP server. If the specified interface does not exist, a prompt appears to show the configuration fails.
Use the undo ftp-server source-interface command to cancel the source interface setting. After you execute this command, the FTP server system decides which interface  will be used for being accessed by FTP clients.
Example
# Specify VLAN-interface2 as the source interface of the FTP server.
<H3C> system-view
[H3C] ftp-server source-interface Vlan-interface 2
1.1.8  ftp-server source-ip
ftp-server source-ip ip-address
undo ftp-server source-ip
View
Parameter
ip-address: IP address that is to be specified as the source IP address.
Use the ftp-server source-ip command to specify the source IP address for an FTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo ftp-server source-ip command to cancel the source IP address setting. After you execute this command, the FTP server system decides which IP address on it will be used for being accessed by FTP clients.
Example
# Specify 192.168.1.1 as the source IP address of the FTP server.
<H3C> system-view
[H3C] ftp-server source-ip 192.168.1.1
1.2  FTP Client Configuration Commands
1.2.1  ascii
ascii
View
FTP client view
Parameter
None
Use the ascii command to specify that files be transferred in ASCII mode. That is, data is transferred in ASCII characters.
By default, files are transferred in ASCII mode.
Example
# Enter FTP client view.
<H3C> ftp 2.2.2.2
Trying ...
Press CTRL+K to abort
Connected.
User(none):switch
Password:
230 Logged in successfully
[ftp]
# Specify to transfer text files in ASCII mode.
[ftp] ascii
200 Type is ASCII
1.2.2  binary
binary
View
FTP Client view
Parameter
None
Use the binary command to specify that program files be transferred in binary mode.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Specify to transfer files in binary mode.
[ftp] binary
200 Type is Image (Binary)
1.2.3  bye
bye
View
FTP client view
Parameter
None
Use the bye command to terminate the control connection and data connection with the remote FTP server and quit to user view.
This command has the same effect as that of the quit command.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the connections with the remote FTP server and quit to user view.
[ftp] bye
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye.
<H3C>
1.2.4  cd
cd pathname
View
FTP client view
Parameter
pathname: Path name
Use the cd command to change the work directory on the remote FTP server.
Note that you can use this command to enter only authorized directories.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Change the work directory to flash:/temp.
[ftp] cd flash:/temp
# Display the current work directory.
[ftp] pwd
257 "flash:/temp" is current directory.
1.2.5  cdup
cdup
View
FTP client view
Parameter
None
Use the cdup command to exit the current work directory and enter the parent directory.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Change the work directory to the parent directory.
[ftp] cdup
# Display the current directory.
[ftp] pwd
257 "flash:" is current directory.
1.2.6  close
close
View
FTP client view
Parameter
None
Use the close command to terminate an FTP connection without quitting FTP client view.
This command has the same effect as that of the disconnect command.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the FTP connection without quitting FTP client view.
[ftp] close
[ftp]
1.2.7  debugging
debugging
undo debugging
View
FTP client view
Parameter
None
Use the debugging command to enable system debugging.
Use the undo debugging command to disable system debugging.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Enable system debugging.
[ftp] debugging
% Debug is on.
1.2.8  delete
delete remotefile
View
FTP client view
Parameter
remotefile: File name
Use the delete command to delete a specified remote file.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Delete the file named temp.c.
[ftp] delete temp.c
250 File deleted from remote host.
1.2.9  dir
dir [ filename [ localfile ] ]
View
FTP client view
Parameter
filename: Name of the file to be queried.
localfile: Name of the local file where the query result is to be saved.
Use the dir command to query specified files on a remote FTP server, or to display file information in the current directory. The output information, which includes the name, size and creation time of files, will be saved in a local file.
If you do not specify the filename argument, the information about all the files in the current directory is displayed.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the information about all the files in the current directory on the remote FTP server.
[ftp] dir
200 PORT command okay
150 File Listing Follows in ASCII mode
-rwxrwxrwx   1 noone    nogroup   430585 Dec 21  2004 4.app
-rwxrwxrwx   1 noone    nogroup   430585 Dec 21  2004 5.app
-rwxrwxrwx   1 noone    nogroup   430585 Dec 23  2004 6. app
-rwxrwxrwx   1 noone    nogroup   430585 Dec 21  2004 6. app.bak
-rwxrwxrwx   1 noone    nogroup   638912 Nov 15  2004 abc.BTM
drwxrwxrwx   1 noone    nogroup        0 Dec 15  2004 TEST
-rwxrwxrwx   1 noone    nogroup  3212176 Jul 14  2004 21.bin
226 Transfer finished successfully.
FTP: 5346 byte(s) received in 6.782 second(s) 788.00 byte(s)/sec.
# Display the information about the file named 4.app and save the output information in the file named temp1.
[ftp] dir 4.app temp1
-rwxrwxrwx   1 noone    nogroup   430585 Dec 21  2004 4. app
FTP: 70 byte(s) received in 0.122 second(s) 573.00 byte(s)/sec.
1.2.10  disconnect
disconnect
View
FTP client view
Parameter
None
Use the disconnect command to terminate a FTP connection without quitting FTP client view.
This command has the same effect as that of the close command.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the FTP connection without quitting FTP Client view.
[ftp] disconnect
[ftp]
1.2.11  display ftp source-ip
View
Parameter
None
Use the display ftp source-ip command to display the source IP address that the FTP client uses every time it connects to an FTP server. If a source interface is specified for the FTP client, the IP address of the source interface will be displayed. If neither a source IP address nor source interface is specified for the FTP client, 0.0.0.0 will be displayed.
Example
# Display the source IP address that the FTP client uses every time it connects to an FTP server.
<H3C> display ftp source-ip
1.2.12  ftp
ftp [ cluster | remote-server [ port-number ] ]
View
Parameter
ip-address: Host name or the IP address of an FTP server. Note that the host name can be a string comprising 1 to 20 characters.
port-number: Port number of the FTP server, ranging from 0 to 65535. The default is 21.
Use the ftp command to establish a control connection with an FTP server and enter FTP client view.
Example
# Connect to the FTP server whose IP address is 2.2.2.2.
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
1.2.13  ftp { cluster | remote-server } source-interface
ftp { cluster | remote-server } source-interface interface-type interface-number
View
Parameter
cluster: Specifies to connect to a cluster FTP server.
remote-server: IP address or host name of the FTP server.
Use the ftp { cluster | remote-server } source-interface command to connect to an FTP server through the specified source interface. This command will fail to be executed if the specified interface does not exist.
Example
# Connect to the FTP server whose IP address is 192.168.8.8 through the source interface VLAN-interface1.
<H3C> ftp 192.168.8.8 source-interface Vlan-interface 1
1.2.14  ftp { cluster | remote-server } source-ip
ftp { cluster | remote-server } source-ip ip-address
View
Parameter
ip-address: Source IP address.
Use the ftp { cluster | remote-server } source-ip command to connect to an FTP server through the specified source IP address. This command will fail to be executed if the specified source IP address does not exist.
Example
#  Connect to the FTP server whose IP address is 192.168.8.8 through the source IP address 192.168.0.1.
<H3C> ftp 192.168.8.8 source-ip 192.168.0.1
1.2.15  ftp source-interface
ftp source-interface interface-type interface-number
undo ftp source-interface
View
Parameter
Use the ftp source-interface command to specify a source interface as the fixed source interface the FTP client uses every time it connects to an FTP server. This command will fail to be executed if the specified interface does not exist.
Use the undo ftp source-interface command to cancel the source interface setting. After you execute this command, the FTP client system decides which interface will be used for accessing FTP servers.
Example
# Specify VLAN-interface1 as the fixed source interface to be used in each connection between the FTP client and an FTP server.
<H3C> system-view
[H3C] ftp source-interface Vlan-interface 1
1.2.16  ftp source-ip
ftp source-ip ip-address
undo ftp source-ip
View
Parameter
Use the ftp source-ip command to specify the source IP address of an FTP client that the FTP client uses every time it connects to an FTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo ftp source-ip command to cancel the source IP address setting. After you execute this command, the FTP client system decides which IP address on it will be used for accessing FTP servers.
Example
# Specify 192.168.0.1 as the source IP address that the FTP client uses every time it connects to an FTP server.
<H3C> system-view
[H3C] ftp source-ip 192.168.0.1
1.2.17  get
get remotefile [ localfile ]
View
FTP client view
Parameter
remotefile: Name of a file on an FTP server.
localfile: Name of a local file.
Use the get command to download a remote file and save it as a local file.
If you do not specify the localfile argument, the downloaded file is saved with its original name.
  Caution:
When using the get command to download files from a remote FTP server, note to limit the lengths of file path and file name within the following ranges regulated for an S3100-52P Ethernet switch.
l      A directory name should be no more than 91 characters.
l      A file name plus its local path name should be no more than 127 characters.
l      A device name should be no more than 14 characters.
l      A file name plus its complete path name should be no more than 142 characters.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Download the file named temp.c.
[ftp] get temp.c
200 Port command okay.
150 Opening ASCII mode data connection for temp.c.
...............226 Transfer complete.
FTP: 749881 byte(s) received in 17.186 second(s) 43.00K byte(s)/sec.
1.2.18  lcd
lcd
View
FTP client view
Parameter
None
Use the lcd command to display the local work directory on the FTP client.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the local work directory.
[ftp] lcd
% Local directory now flash:/temp
1.2.19  ls
ls [ remotefile [ localfile ] ]
View
FTP client view
Parameter
remotefile: Name of the remote file to be queried.
Localfile: Name of the local file where the querying result is to be saved.
Use the ls command to display the information about a specified file on a remote FTP server.
If you do not specify the remotefile argument, names of all the files in the current remote directory are displayed.
  Caution:
The ls command only displays file names, while the dir command displays file information in more detail, including file size, creation date and so on.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the names of all the files in the current directory on the remote FTP server.
[ftp] ls
4.app
5.app
6.app
6.app.bak
abc.BTM
TEST
21.bin
FTP: 1235 byte(s) received in 1.595 second(s) 774.00byte(s)/sec.
1.2.20  mkdir
mkdir pathname
View
FTP client view
Parameter
pathname: Path name.
Use the mkdir command to create a directory on an FTP server.
This command is available only to the FTP clients that are assigned the permission to create directories on FTP servers.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Create the directory flash:/lanswitch on the FTP server.
[ftp] mkdir flash:/lanswitch
257 "flash:/ lanswitch" directory created.
1.2.21  open
open { ip-address | server-name } [ port ]
View
FTP client view
Parameter
ip-address: IP address of an FTP server.
server-name: Host name of the FTP server, a string comprising 1 to 20 characters.
port: Port number on the remote FTP server, ranging from 0 to 65535. The default value is 21.
Use the open command to establish a control connection with an FTP server.
Related command: close.
Example
<H3C> ftp
[ftp]
# Establish a control connection with the FTP server whose IP address is 1.1.1.1.
[ftp]open 1.1.1.1
Trying ...
Connected.
User(none):abc
Password:
1.2.22  passive
passive
undo passive
View
FTP client view
Parameter
None
Use the passive command to set the data transfer mode to the passive mode.
Use the undo passive command to set the data transfer mode to the active mode.
By default, the passive mode is adopted.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Set the data transfer mode to the passive mode.
[ftp] passive
% Passive is on
1.2.23  put
put localfile [ remotefile ]
View
FTP client view
Parameter
remotefile: File name which the local file is to be saved as on the remote FTP server.
Use the put command to upload a local file to an FTP server.
If you do not specify the remotefile argument, the local file is saved on the FTP server with its original name.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Upload the local file named temp.c to the FTP server.
[ftp] put temp.c
FTP: 749881 byte(s) sent in 17.691 second(s) 42.00Kbyte(s)/sec.
1.2.24  pwd
pwd
View
FTP Client view
Parameter
None
Use the pwd command to display the work directory on an FTP server.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the work directory on the FTP server.
[ftp] pwd
1.2.25  quit
View
FTP client view
Parameter
None
Use the quit command to terminate FTP control connection and FTP data connection and quit to user view.
This command has the same effect as that of the bye command.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Terminate the FTP control connection and FTP data connection and quit to user view.
[ftp] quit
<H3C>
1.2.26  remotehelp
remotehelp [ protocol-command ]
View
FTP client view
Parameter
protocol-command: FTP protocol command.
Use the remotehelp command to display the help information about an FTP protocol command.
This command works only when the FTP server provides the help information about FTP protocol commands.
  Caution:
l      This command is always valid when a H3C series switch operates as the FTP server.
l      If you use other FTP server software, refer to related instructions to know whether the FTP server provides help information about FTP protocol commands.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Display the syntax of the user command.
[ftp] remotehelp user
214 Syntax: USER <sp> <username>
1.2.27  rename
rename remote-source remote-dest
View
FTP client view
Parameter
remote-source: Name of a file on a remote host.
remote-dest: Destination file name.
Use the rename command to rename a file on a remote FTP server.
If the destination file name conflicts with the name of an existing file or directory, you will fail to rename the file.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Rename the file named temp.c as forever.c.
[ftp] rename temp.c forever.c
350 Enter the name to rename it to...
250 File renamed successfully
1.2.28  rmdir
rmdir pathname
View
FTP client view
Parameter
pathname: Name of a directory on an FTP server.
Use the rmdir command to remove a specified directory on an FTP server.
Note that you can only use this command to remove directories that are empty.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Remove the directory flash:/temp1 on the FTP server. (Assume that the directory is empty.)
[ftp] rmdir flash:/temp1
200 Directory flash:/temp1 removed.
1.2.29  user
user username [ password ]
View
FTP client view
Parameter
username: User name used to log into an FTP server.
password: Password used to log into an FTP server.
Use the user command to log into an FTP server with the specified user name and password.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Log into the FTP server using the user account with the user name being tom and the password being 111.
[ftp] user tom 111
1.2.30  verbose
verbose
undo verbose
View
FTP client view
Parameter
None
Use the verbose command to enable the verbose function, which displays execution and response information of other related commands.
Use the undo verbose command to disable the verbose function.
The verbose function is enabled by default.
Example
<H3C> ftp 2.2.2.2
Trying ...
Connected.
User(none):switch
Password:
[ftp]
# Enable the verbose function.
[ftp] verbose
1.3  TFTP Configuration Commands
1.3.1  display tftp source-ip
View
Parameter
None
Use the display tftp source-ip display the source IP address that the TFTP client uses every time it connects to a TFTP server. If a source interface is specified for the TFTP client, the IP address of the source interface will be displayed. If neither source IP address nor source interface is specified for the TFTP client, 0.0.0.0 will be displayed.
Example
# Display the source IP address that the TFTP client uses every time it connects to a TFTP server.
<H3C> display tftp source-ip
1.3.2  tftp
tftp { ascii | binary }
View
Parameter
ascii: Transfers data in the ASCII mode.
binary: Transfers data in the binary mode.
Use the tftp { ascii | binary } command to set the TFTP data transfer mode.
By default, the binary mode is adopted.
Example
# Specify to adopt the ASCII mode.
<H3C> system-view
[H3C] tftp ascii
TFTP transfer mode changed to ASCII.
1.3.3  tftp get
tftp tftp-server get source-file [ dest-file ]
View
Parameter
tftp-server: IP address or the host name of a TFTP server.
source-file: Name of the file to be downloaded from the TFTP server.
dest-file: File name which the downloaded file is to be saved as.
Use the tftp get command to download a file from a TFTP server to the local switch.
Related command: tftp put.
Example
# Download the file named abc.txt from the TFTP server whose IP address is 1.1.1.1 and save it as efg.txt.
<H3C>tftp 1.1.1.1 get abc.txt efg.txt
  File will be transferred in binary mode.
  Downloading file from remote tftp server, please wait......
  TFTP:       35 bytes received in 0 second(s).
  File downloaded successfully.
1.3.4  tftp put
tftp tftp-server put source-file [ dest-file ]
View
Parameter
source-file: Name of the file to be uploaded to the TFTP server.
dest-file: File name which the uploaded file is to be saved as.
Use the tftp put command to upload a file to a specified directory on a TFTP server.
Related command: tftp get.
Example
# Upload the file named config.cfg to the TFTP server whose IP address is 1.1.1.1 and save it as temp.cfg.
<H3C> tftp 1.1.1.1 put config.cfg temp.cfg
  Copying file to remote tftp server. Please wait... /
  TFTP:      962 bytes sent in 0 second(s).
  File uploaded successfully.
1.3.5  tftp tftp-server source-interface
tftp tftp-server source-interface interface-type interface-number { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
View
Parameter
tftp-server: IP address or host name of the TFTP server to be connected to.
get: Specifies to download a file from the TFTP server.
source-file: Name of the file to be downloaded.
dest-file: Name of the downloaded file to be saved locally.
put:  Specifies to upload a file to the TFTP server.
source-file-url: Path and name of the file to be uploaded.
dest-file: Name of the uploaded file to be saved on the TFTP server.
Use the tftp tftp-server source-interface command to connect to a TFTP server through the specified source interface, and perform download or upload operations. If the specified source interface does not exist, a prompt appears to show the command fails to be executed.
Example
# Connect to the remote TFTP server whose IP address is 192.168.8.8 through the source interface VLAN-interface1, and download the file named switch.bin from it.
<H3C> tftp 192.168.8.8 source-interface Vlan-interface 1 get switch.bin
1.3.6  tftp tftp-server source-ip
tftp tftp-server source-ip ip-address { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
View
Parameter
ip-address: IP address to be set as the source IP address.
Use the tftp tftp-server source-ip command to connect to a TFTP server through the specified source IP address, and perform download or upload operations. If the specified source IP address does not exist, a prompt appears to show the command fails to be executed.
Example
# Connect to the remote TFTP server whose IP address is 192.168.8.8 through the source IP address 192.168.0.1, and download the file named switch.bin from it.
<H3C> tftp 192.168.8.8 source-ip 192.168.0.1 get switch.bin
1.3.7  tftp source-interface
tftp source-interface interface-type interface-number
undo tftp source-interface
View
Parameter
Use the tftp source-interface command to specify the source interface of a TFTP client that the TFTP client uses every time it connects to a TFTP server. This command will fail to be executed if the specified interface does not exist.
Use the undo tftp source-interface command to cancel the source interface setting. After you execute this command, the TFTP client system decides which interface will be used for accessing TFTP servers.
Example
# Specify VLAN-interface1 as the source interface that the TFTP client uses every time it connects to a TFTP server.
<H3C> system-view
[H3C] tftp source-interface Vlan-interface 1
1.3.8  tftp source-ip
tftp source-ip ip-address
undo tftp source-ip
View
Parameter
Use the tftp source-ip command to specify the source IP address of a TFTP client that the TFTP client uses every time it connects with a TFTP server. The value of argument ip-address must be an IP address on the device where the configuration is performed. Otherwise, a prompt appears to show the configuration fails.
Use the undo tftp source-ip command to cancel the source IP address setting. After you execute this command, the TFTP client system decides which IP address on it will be used for accessing TFTP servers.
Example
# Specify 192.168.0.1 as the source IP address that the TFTP client uses every time it connects to a TFTP server.
<H3C> system-view
[H3C] tftp source-ip 192.168.0.1
1.3.9  tftp-server acl
tftp-server acl acl-number
undo tftp-server acl
View
Parameter
acl-number: Basic ACL number ranging from 2000 to 2999.
Use the tftp-server acl command to specify the ACL adopted for the connection between a TFTP client and a TFTP server.
Use the undo tftp-server acl command to cancel all ACLs adopted.
Example
# Specify to adopt ACL 2000 on the TFTP client.
<H3C> system-view
[H3C] tftp-server acl 2000
