H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
22-QoS Command
22-QoS Command 96 KB
Chapter 1  QoS Commands
1.1  QoS Commands
1.1.1  display protocol-priority
View
Parameter
None
Use the display protocol-priority command to display the priority of the protocol packet.
Example
# Display the priority of the protocol packet.
<H3C> display protocol-priority
Protocol: telnet
  DSCP: be(0)
1.1.2  display qos cos-local-precedence-map
View
Parameter
None
Use the display qos cos-local-precedence-map command to display the “COS-to-local-precedence” mapping table.
Example
# Display the “COS-to-local-precedence” mapping table.
<H3C> display qos cos-local-precedence-map
cos-local-precedence-map:
              cos(802.1p) :    0    1    2     3     4     5     6     7
 local precedence(queue) :     0    1    2     3     4     5     6     7
1.1.3  display qos-interface all
display qos-interface { interface-type interface-number | unit-id } all
View
Parameter
interface-type interface-number: Port index.
unit-id: Unit ID of the switch.
Use the display qos-interface all command to display all the QoS configuration of the ports. If you do not input port parameters, this command will display the QoS parameter configuration of all the ports of the switch, including priority remark, queue scheduling, rate limit, etc; if you input port parameters, this command will display QoS parameter configuration of the port, including priority remark, queue scheduling, rate limit, etc.
When the IRF feature is enabled, the interface-type interface-number argument or the unit-id argument must be input.
Example
# Display all the QoS parameter configuration on Ethernet1/0/1.
<H3C> display qos-interface Ethernet 1/0/1 all
Ethernet1/0/1: line-rate
   Inbound: 128 kbps
   Outbound: 1024 kbps
Ethernet1/0/1:
 Queue scheduling mode: strict-priority
1.1.4  display qos-interface line-rate
display qos-interface { interface-type interface-number | unit-id } line-rate
View
Parameter
Use the display qos-interface line-rate command to display the rate limit configuration of a port or all the ports of a switch. If you do not specify the interface-type interface-number argument, this command will display the rate limit configuration of all the ports of a switch; if you specify that argument, this command will display the rate limit configuration of a specific port.
Example
# Display the rate limit configuration of a specific port.
<H3C> display qos-interface 1 line-rate
   Inbound: 128 kbps
1.1.5  display queue-scheduler
View
Parameter
None
Use the display queue-scheduler command to display global queue scheduling mode and corresponding configuration.
Related command: queue-scheduler.
Example
# Display the global queue scheduling mode.
<H3C> display queue-scheduler
1.1.6  line-rate
line-rate { inbound | outbound } target-rate
undo line-rate{ inbound | outbound }
View
Ethernet port view
Parameter
inbound: Limits the rate of inbound packets.
outbound: Limits the rate of outbound packets.
target-rate: Total rate (in Kbps) to limit both the inbound and outbound packets on the port, with the granularity of rate limit being 64 Kbps. If the number you input is in the range of N*64 to (N+1)*64 (N is a natural number), the switch will set the value to (N+1)*64 Kbps automatically. The target rate range for fast Ethernet ports and Gigabit Ethernet ports respectively is:
l           Fast Ethernet port: 64 to 99,968
l           Gigabit Ethernet port: 64 to 1,000,000
Use the line-rate command to limit the rate of the packets on the port.
Use the undo line-rate command to cancel the rate limit configuration on the port.
The granularity of rate limit is 64 Kbps.
Example
# Limit the rate of inbound packets on Ethernet1/0/1 to 128 Kbps.
<H3C> system-view
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] line-rate inbound 128
1.1.7  priority
priority priority-level
undo priority
View
Ethernet port view
Parameter
priority-level: Priority level of the port, ranging from 0 to 7.
Use the priority command to configure the priority of Ethernet port.
Use the undo priority command to restore the default port priority.
By default, the switch uses the port priority instead of the 802.1p priority carried by a packet.
After this command is configured, the switch will replace the packet 802.1p priority with the priority of the receiving port, according to which the packet will be put into the corresponding egress queue.
Example
# Set the priority of Ethernet1/0/1 port to 6.
<H3C> system-view
[H3C-Ethernet1/0/1] priority 6
1.1.8  priority trust
priority trust
undo priority
View
Ethernet port view
Parameter
None
Use the priority trust command to configure the system to use the packet 802.1p priority instead of the port priority.
Use the undo priority command to configure the system not to use packet 802.1p priority.
By default, the system replaces the priority carried by a packet with the port priority.
Example
# Configure the system to use the packet priority on Ethernet1/0/1.
<H3C> system-view
[H3C-Ethernet1/0/1] priority trust
1.1.9  protocol-priority protocol-type
protocol-priority protocol-type protocol-type { ip-precedence ip-precedence | dscp dscp-value }
undo protocol-priority protocol-type protocol-type
View
Parameter
protocol-type protocol-type: Specifies the protocol type. Only TELNET, SNMP, ICMP and OSPF are supported currently.
ip-precedence ip-precedence: Specifies the IP precedence, in the range of 0 to 7. You can enter the keywords as shown in Table 1-1 .
Table 1-1 Description on IP precedence values
Keyword
IP precedence value (decimal)
IP precedence value (binary)
routine
0
000
priority
1
001
immediate
2
010
flash
3
011
flash-override
4
100
critical
5
101
internet
6
110
network
7
111
dscp dscp-value: Specifies the DSCP priority, in the range of 0 to 63. You can also enter the keywords listed in Table 1-2.
Table 1-2 Description on DSCP values
Keyword
DSCP value (decimal)
DSCP value (binary)
ef
46
101110
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
be (default)
0
000000
Use the protocol-priority command to set the global traffic priority for a specific protocol type.
Use the undo protocol-priority command to cancel the settings.
Example
# Set the IP precedence of SNMP protocol packets to 3.
<H3C> system-view
[H3C] protocol-priority protocol-type snmp ip-precedence 3
1.1.10  qos cos-local-precedence-map
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
undo qos cos-local-precedence-map
View
Parameter
cos0-map-local-prec: Local precedence to which CoS 0 is to be mapped, in the range of 0 to 7.
cos1-map-local-prec: Local precedence to which CoS 1 is to be mapped, in the range of 0 to 7.
cos2-map-local-prec: Local precedence to which CoS 2 is to be mapped, in the range of 0 to 7.
cos3-map-local-prec: Local precedence to which CoS 3 is to be mapped, in the range of 0 to 7.
cos4-map-local-prec: Local precedence to which CoS 4 is to be mapped, in the range of 0 to 7.
cos5-map-local-prec: Local precedence to which CoS 5 is to be mapped, in the range of 0 to 7.
cos6-map-local-prec: Local precedence to which CoS 6 is to be mapped, in the range of 0 to 7.
cos7-map-local-prec: Local precedence to which CoS 7 is to be mapped, in the range of 0 to 7.
Use the qos cos-local-precedence-map command to configure the “CoS-to-local-precedence” mapping table.
Use the undo qos cos-local-precedence-map command to restore the default values.
The following is the default “CoS-to-local-precedence” mapping table.
Table 1-3 Default “CoS-to-local-precedence” mapping table
CoS value
Local precedence
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Example
# Configure the “CoS-to-local-precedence” mapping table.
<H3C> system-view
[H3C] qos cos-local-precedence-map 0 1 2 3 4 5 6 7
The following is the configured "CoS-to-local-precedence” mapping table.
Table 1-4 “CoS-to-local-precedence” mapping table
CoS value
Local precedence
0
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
1.1.11  queue-scheduler
I. In system view
queue-scheduler { strict-priority | wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight }
undo queue-scheduler
II. In Ethernet port view
queue-scheduler wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight
View
System view/Ethernet port view
Parameter
strict-priority: Indicates that the queue uses strict priority (SP) scheduling algorithm.
wrr: Indicates that the queue uses weighted round robin (WRR) scheduling.
queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight: Indicates that the queue uses the WRR scheduling. The value ranges from 0 to 15. A value of 0 means the corresponding queue uses the SP scheduling.
Use the queue-scheduler command to configure the queue scheduling mode.
Use the undo queue-scheduler command to restore the default value.
The queue scheduling algorithm defined by executing the queue-scheduler command in system view takes effect on all the ports of the switch. The queue scheduling algorithm defined by executing the queue-scheduler command in Ethernet port view takes effect on the current port only. If the weight of the WRR queue scheduling algorithm defined globally cannot satisfy the requirement of a port, you can modify the weight of the queue scheduling algorithm for this port in Ethernet port view of this port. On this port, the newly defined queue weight will replace the globally defined one. You cannot use the display queue-scheduler command to display the queue weight defined in Ethernet port view.
A port of the switch supports eight egress queues and you can configure a queue scheduling mode, which can be  SP, WRR, as needed to achieve the implementation of WRR+SP. For example, with WRR, if you set the weight of one or more queues to 0, the SP applies to the queue(s) and WRR apply to other queues.
By default, the WRR algorithm is selected for all outbound queues on a port, and their weight values are 1, 2, 3, 4, 5, 9, 13, and 15.
Related command: display queue-scheduler.
Example
# Set WRR as the queue scheduling mode, and set the weight value of each queue to 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
<H3C> system-view
[H3C-Ethernet1/0/1] queue-scheduler wrr 1 2 3 4 5 6 7 8
