H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
15-Routing Protocol Command
15-Routing Protocol Command 99 KB
Chapter 1  IP Routing Table Display Commands
&  Note:
When running a routing protocol, the Ethernet switch also functions as a router. The words “router” and the router icons covered in the following text represent routers in common sense and Ethernet switches running a routing protocol. To improve readability, this will not be mentioned again in this manual.
1.1  IP Routing Table Display Commands
1.1.1  display ip routing-table
View
Parameter
None
Use the display ip routing-table command to display the routing table summary.
This command displays the summary of the routing table. Each line represents one route, containing destination address/mask length, protocol, preference, cost, next hop, and output interface.
This command displays only the currently used routes, that is, the optimal routes.
Example
# Display the summary of the current routing table.
<H3C> display ip routing-table
Routing Table: public net
Destination/Mask   Protocol   Pre Cost  Nexthop     Interface
1.1.1.0/24         DIRECT        0   0       1.1.1.1     Vlan-interface1
1.1.1.1/32         DIRECT        0   0       127.0.0.1   InLoopBack0
2.2.2.0/24         DIRECT        0   0       2.2.2.1     Vlan-interface2
2.2.2.1/32         DIRECT        0   0       127.0.0.1   InLoopBack0
3.3.3.0/24         DIRECT        0   0       3.3.3.1     Vlan-interface3
3.3.3.1/32         DIRECT        0   0       127.0.0.1   InLoopBack0
4.4.4.0/24         DIRECT        0   0       4.4.4.1     Vlan-interface4
4.4.4.1/32         DIRECT        0   0       127.0.0.1   InLoopBack0
127.0.0.0/8        DIRECT        0   0       127.0.0.1   InLoopBack0
127.0.0.1/32       DIRECT    0  0        127.0.0.1  InLoopBack0
Table 1-1 Description on the fields of the display ip routing-table command
Destination/Mask
Destination address/mask length
Protocol
Routing protocol
Pre
Route preference
Cost
Route cost
Nexthop
Next hop address
Output interface, through which the data packets destined for the destination network segment are sent
1.1.2  display ip routing-table ip-address
display ip routing-table ip-address [ mask ] [ longer-match ] [ verbose ]
View
Parameter
ip-address: Destination IP address, in dotted decimal notation.
mask: IP address mask, length in dotted decimal notation or expressed as an integer. It ranges from 0 to 32 when expressed as an integer.
longer-match: Specifies all the routes that lead to the destination address and match the specified mask. If you do not specify the mask argument, those that match the natural mask are specified.
verbose: With the verbose argument specified, this command displays the verbose information of both the active and inactive routes. Without the argument specified, this command only displays the summary of active routes.
Use the display ip routing-table ip-address command to display the routing information of the specified destination address.
With different arguments provided, the command output is different. The following is the command output with different arguments provided:
l           display ip routing-table ip-address
If the destination address ip-address corresponds to a route in the natural mask range, this command displays the route that is the longest match of the destination address ip-address and is active.
l           display ip routing-table ip-address mask
This command only displays the routes exactly matching the specified destination address and mask.
l           display ip routing-table ip-address longer-match
This command displays all destination address routes matching the specified destination address in the natural mask range.
l           display ip routing-table ip-address mask longer-match
This command displays all destination address routes matching the specified destination address in the specified mask range.
Example
# There is a corresponding route in the natural mask range. Display the summary.
<H3C> display ip routing-table 169.0.0.0
169.0.0.0/16         Static  60  0       2.1.1.1     LoopBack1
For detailed description of the output information, see Table 1-1.
# There is no corresponding route (only the longest matching route is displayed) in the natural mask range. Display the summary.
<H3C> display ip routing-table 169.253.0.0
169.0.0.0/8          Static  60      0       2.1.1.1     LoopBack1
# There are corresponding routes in the natural mask range. Display detailed information.
<H3C> display ip routing-table 169.0.0.0 verbose
Routing tables:
  + = Active Route, - = Last Active, # = Both    * = Next hop in use
  Summary count: 1
**Destination: 169.0.0.0         Mask: 255.255.255.0
         Protocol: #STATIC       Preference: 60
         *NextHop: 2.1.1.1          Interface: 2.1.1.1(LoopBack1)
         Vlinkindex: 0
         State: <Int ActiveU Gateway Static Unicast>
         Age: 4:49       Cost: 0/0       Tag: 0
# There is no corresponding route in the natural mask range (only the longest matched route is displayed). Display the detailed information.
<H3C> display ip routing-table 169.253.0.0 verbose
Routing Tables:
  Summary count:1
**Destination: 169.0.0.0       Mask: 255.0.0.0
         Protocol: #Static     Preference: -60
         Vlinkindex: 0
         State: <Int ActiveU Static Unicast>
         Age: 3:47       Cost: 0/0       Tag: 0
For detailed description of the output information, see Table 1-2.
1.1.3  display ip routing-table ip-address1 ip-address2
display ip routing-table ip-address1 mask1 ip-address2 mask2 [ verbose ]
View
Parameter
ip-address1, ip-address2: Destination IP address in dotted decimal notation. ip-address1, mask1 and ip-address2, mask2 determine one address range together. ip-address1 ANDed with mask1 specifies the start of the range, while ip-address2 ANDed with mask2 specifies the end. This command displays the route in this address range.
mask1, mask2: IP address mask, length in dotted decimal notation or expressed as an integer. It ranges from 0 to 32 when expressed as an integer.
verbose: With the verbose argument provided, this command displays the verbose information of both active and inactive routes. Without this argument provided, this command displays the summary of active routes only.
Use the display ip routing-table ip-address1 ip-address2 command to display the route information in the specified destination address range.
Example
# Display the routing information of destination addresses ranging from 1.1.1.0 to 2.2.2.0.
<H3C>display ip routing-table 1.1.1.0 24 2.2.2.0 24
Routing tables:
  Summary count: 3
1.1.4  display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
Parameter
protocol: You can provide one of the following values for this argument.
l           direct: Displays direct-connect route information
l           static: Displays static route information.
inactive: With this argument provided, this command displays the inactive route information. Without this argument provided, this command displays both active and inactive route information.
verbose: With this argument provided, this command displays the verbose route information. Without this argument provided, this command displays route summary only.
Use the display ip routing-table protocol command to display the route information of a specific protocol.
Example
# Display the summary of all direct-connect routes.
<H3C> display ip routing-table protocol direct
DIRECT Routing tables:
Summary count: 4
DIRECT Routing tables status:<active>:
Summary count: 3
20.1.1.1/32          DIRECT          0   0       127.0.0.1   InLoopBack0
DIRECT Routing tables status:<inactive>:
Summary count: 1
210.0.0.1/32         DIRECT     0       0       127.0.0.1   InLoopBack0
# Display the static routing table.
<H3C> display ip routing-table protocol static
STATIC Routing tables:
  Summary count: 1
STATIC Routing tables status:<active>:
  Summary count: 0
STATIC Routing tables status:<inactive>:
  Summary count: 1
1.2.3.0/24          STATIC  60  0           1.2.4.5       Vlan-interface10
1.1.5  display ip routing-table radix
View
Parameter
None
Use the display ip routing-table radix command to display the route information in a tree structure.
Example
<H3C> display ip routing-table radix
Radix tree for INET (2) inodes 7 routes 5:
             +-32+--{210.0.0.1
         +--0+
          | | +--8+--{127.0.0.0
          | | | +-32+--{127.0.0.1
          | +--1+
          | +--8+--{20.0.0.0
          | +-32+--{20.1.1.1
Table 1-2 Description on the fields of the display ip routing-table radix command
INET
Address suite
inodes
Number of nodes
routes
Number of routes
1.1.6  display ip routing-table statistics
View
Parameter
None
Use the display ip routing-table statistics command to display the integrated routing information.
The integrated routing information includes the total number of routes, the number of active routes, the number of routes added by protocols, and the number of routes deleted.
Example
# Display the integrated route information.
<H3C> display ip routing-table statistics
Routing tables:
Proto      route       active      added       deleted
DIRECT     24          4           25          1
STATIC     4           1           4           0
RIP        0           0           0           0
OSPF       0           0           0           0
O_ASE      0           0           0           0
O_NSSA     0           0           0           0
Total      28          5           29          1
Table 1-3 Description on the fields of the display ip routing-table statistics command
Proto
Routing protocol. O_ASE stands for OSPF_ASE routes; O_NSSA stands for OSPF NSSA routes; AGGRE stands for aggregated routes.
route
Total number of routes
active
Number of active routes
added
Number of routes added after the router is rebooted or the routing table is cleared last time.
deleted
Number of routes deleted (Such routes will be freed in a period of time)
Total
Total number of the different kinds of routes
1.1.7  display ip routing-table verbose
View
Parameter
None
Use the display ip routing-table verbose command to display the verbose routing table information.
With the verbose argument provided, this command displays the verbose routing table information. The descriptor describing the route state will be displayed first. Then, the statistics of the entire routing table will be output. Finally, the verbose description of each route will be output.
The display ip routing-table verbose command can display all current routes, including inactive routes and invalid routes.
Example
# Display the verbose routing table information.
<H3C> display ip routing-table verbose
Routing Tables:
  Destinations: 3       Routes: 3
  Holddown: 0    Delete: 62      Hidden: 0
**Destination: 1.1.1.0           Mask: 255.255.255.0
         Protocol: #DIRECT       Preference: 0
         *NextHop: 1.1.1.1        Interface: 1.1.1.1(Vlan-interface1)
         State: <Int ActiveU Retain Unicast>
         Age: 20:17:41   Cost: 0/0
**Destination: 1.1.1.1           Mask: 255.255.255.255
         *NextHop: 127.0.0.1        Interface: 127.0.0.1(InLoopBack0)
         State: <NoAdvise Int ActiveU Retain Gateway Unicast>
         Age: 20:17:42   Cost: 0/0
**Destination: 2.2.2.0           Mask: 255.255.255.0
         *NextHop: 2.2.2.1          Interface: 2.2.2.1(Vlan-interface2)
         Age: 20:08:05   Cost: 0/0
First, display statistics of the whole routing table. Then, output detailed information of every route entry in turn. Table 1-2shows the meaning of route status. Table 1-4 shows routing table statistics.
Table 1-4 Description on the fields of the display ip routing-table verbose command
Holddown
Number of held-down routes
Delete
Number of deleted routes
Hidden
Number of hidden routes
Chapter 2  Static Route Configuration Commands
2.1  Static Route Configuration Commands
2.1.1  delete static-routes all
View
Parameter
None
Use the delete static-routes all command to delete all static routes.
The system will request your confirmation before it deletes all the configured static routes.
Related command: ip route-static and display ip routing-table.
Example
# Delete all the static routes in the router.
<H3C> system-view
[H3C] delete static-routes all
Are you sure to delete all the unicast static routes?[Y/N]y
2.1.2  reset ip routing-table
reset ip routing-table statistics protocol { all | protocol }
View
Parameter
statistics protocol: Clears routing table statistics.
all: All protocols.
protocol: Origin of routes.
Use the reset ip routing-table command to reset routing table statistics for the public network routing table.
Example
# Clear private routing information.
<Sysname> reset ip routing-table statistics protocol all
2.1.3  ip route-static
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] [ description text | detect-group group number ]*
undo ip route-static ip-address { mask | mask-length } [ interface-type interface-number | next-hop ] [ preference preference-value ] [ reject | blackhole ] [ description text | detect-group group number ]*
View
Parameter
mask: Mask.
mask-length: Mask length. Since 1s in a 32-bit mask must be consecutive, a mask in dotted decimal notation can be replaced by mask-length, which is the number of the consecutive 1s in the mask.
interface-type interface-number: Next-hop outgoing interface. The packets sent to a null interface, which is a virtual interface, will be discarded immediately. This can decrease the system load.
next-hop: Next hop IP address of the route, in dotted decimal notation.
preference-value: Preference level of the route, in the range from 1 to 255. The default preference is 60.
reject: Indicates an unreachable route. If a static route to a destination has the "reject" attribute, all the IP packets destined for this destination will be discarded, and the source host will be informed that the destination is unreachable.
blackhole: Indicates a blackhole route. If a static route to a destination has the “blackhole” attribute, the outgoing interface of this route is the Null 0 interface regardless of the next hop address, and all the IP packet addresses destined for this destination are dropped without the source host being notified.
description: Provides a description for the current route.
detect-group: Specifies a detect group.
Use the ip route-static command to configure a static route.
Use the undo ip route-static command to delete a manually configured static route.
By default, the system can obtain the subnet route directly connected to the router. When you configure a static route, if no preference is specified for the route, the preference defaults to 60, and if the route is not specified as reject or blackhole, the route will be reachable by default.
When configuring a static route, note the following points:
l           If the destination IP address and the mask are both 0.0.0.0, what you are configuring is a default route. All the packets that fail to find a routing entry will be forwarded through this default route.
l           You cannot configure an interface address of the local switch as the next hop address of a static route.
l           You can configure a different preference to implement flexible route management policy.
Related command: display ip routing-table.
Example
# Configure the next hop of the default route as 129.102.0.2.
<H3C> system-view
[H3C] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
