H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
23-Mirroring Command
23-Mirroring Command 53 KB
Chapter 1  Mirroring Commands
1.1  Mirroring Commands
1.1.1  display mirroring-group
display mirroring-group { group-id | all | local | remote-destination | remote-source }
View
Parameter
group-id: Group number of a port mirroring group, in the range of 1 to 20.
local: Specifies to display the parameter settings of local port mirroring groups.
remote-destination: Specifies to display the parameter settings of the destination groups for remote mirroring.
remote-source: Specifies to display the parameter settings of the source groups for remote mirroring.
all: Specifies to display the parameter settings of all mirroring groups.
Use the display mirroring-group command to display the parameter settings of a port mirroring group.
Local mirroring group information includes:
l           Group number
l           Group type: local
l           Group status
l           Information of the source port
l           Information of the destination port
Information of the destination mirroring group for remote mirroring includes:
l           Group number
l           Group type: remote-destination
l           Group status
l           Remote-probe VLAN information
Information of the source mirroring group for remote mirroring includes:
l           Group number
l           Group type: remote-source
l           Group status
l           Information of the reflector port
Example
# Display the parameter settings of a port mirroring group.
<H3C> display mirroring-group all
mirroring-group 2:
    type: local
    status: active
    mirroring port:
        GigabitEthernet1/1/1  both
    monitor port: GigabitEthernet1/1/4
1.1.2  mirroring-group
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
View
Parameter
group-id: The number of a port mirroring group, in the range 1 to 20.
local: Specifies the mirroring group as a local port mirroring group.
remote-destination: Specifies the mirroring group as the destination mirroring group for remote port mirroring.
remote-source: Specifies the mirroring group as the source mirroring group for remote mirroring.
all: Specifies to remove all mirroring groups.
Use the mirroring-group command to configure a port mirroring group.
Use the undo mirroring-group command to remove a port mirroring group.
Example
# Configure a port mirroring group on the local switch.
<H3C> system-view
[H3C] mirroring-group 1 local
1.1.3  mirroring-group mirroring-port
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port mirroring-port-list
View
System view/Ethernet port view
Parameter
mirroring-port mirroring-port-list: Specifies a list of source ports. mirroring-port-list is available in system view only, instead of in Ethernet port view.
both: Specifies to mirror the packets received and sent by the port.
inbound: Specifies to mirror the packets received by the port.
outbound: Specifies to mirror the packets sent by the port.
Use the mirroring-group mirroring-port command to configure the source port.
Use the undo mirroring-group mirroring-port command to remove the configuration of the source port.
Example
# Configure GigabitEthernet1/1/1 as the source port and mirror all packets received by this port.
<H3C> system-view
[H3C] mirroring-group 1 mirroring-port Gigabitethernet1/1/1 inbound
1.1.4  mirroring-group monitor-port
mirroring-group group-id monitor-port monitor-port
undo mirroring-group group-id monitor-port monitor-port
View
Parameter
monitor-port monitor-port: Specifies the destination port for port mirroring. monitor-port is available in system view only, instead of in Ethernet port view.
Use the mirroring-group monitor-port command to configure the destination port.
Use the undo mirroring-group monitor-port to remove the configuration of the destination port.
Note the following when you configure the destination port:
l           LACP and STP must be disabled on the destination port.
l           The destination port for remote mirroring must be an Access port.
l           After a port is configured as a reflector port, the switch does not allow you to change the port type or its default VLAN ID.
Example
# Configure GigabitEthernet1/1/4 as the source port
<H3C> system-view
[H3C] mirroring-group 1 monitor-port Gigabitethernet1/1/4
1.1.5  mirroring-group reflector-port
mirroring-group group-id reflector-port reflector-port
undo mirroring-group group-id reflector-port reflector-port
View
Parameter
reflector-port reflector-port: Specifies the reflector port. reflector-port is available in system view only, instead of in Ethernet port view.
Use the mirroring-group reflector-port command to specify the reflector port.
Use the undo mirroring-group reflector-port command to remove the configuration of the reflector port.
Note the following when you configure the reflector port:
l           The reflector port must be an Access port.
l           LACP and STP must be disabled on the reflector port.
l           After a port is configured as a reflector port, the switch does not allow you to change the port type or its default VLAN ID, or to add it to another VLAN.
l           To mirror tagged packets, you need to configure VLAN VPN on the reflector port.
Example
# Configure GigabitEthernet1/1/2 as the reflector port.
<H3C> system-view
[H3C] mirroring-group 1 reflector-port GigabitEthernet1/1/2
1.1.6  mirroring-group remote-probe vlan
mirroring-group group-id remote-probe vlan remote-probe-vlan-id
undo mirroring-group group-id remote-probe vlan remote-probe-vlan-id
View
Parameter
remote-probe vlan remote-probe-vlan-id: Specifies the remote-probe VLAN for the mirroring group.
Use the mirroring-group remote-probe vlan command to specify the remote-probe VLAN for a mirroring group.
Use the undo mirroring-group remote-probe vlan command to remove the configuration of remote-probe VLAN for a mirroring group.
Example
# Configure VLAN 100 as the remote-probe VLAN.
<H3C> system-view
[H3C] mirroring-group 1 remote-probe vlan 100
1.1.7  mirroring-port
mirroring-port { inbound | outbound | both }
undo mirroring-port
View
Ethernet port view
Parameter
inbound | outbound | both: Direction of mirrored packets. inbound means only to mirror the packets received by the port; outbound means only to mirror the packets sent by the port; both means only to mirror all packets received and sent by the port.
Use the mirroring-port command to configure the source port.
Use the undo mirroring-port command to remove the configuration of the source port.
Related command: display mirroring-group
Example
# Configure GigabitEthernet1/1/1 as the source port and mirror all packets received and sent by this port.
<H3C> system-view
[H3C] interface GigabitEthernet1/1/1
[H3C-GigabitEthernet1/1/1] mirroring-port both
1.1.8  monitor-port
monitor-port
undo monitor-port
View
Ethernet port view
Parameter
None
Use the monitor-port command to configure the destination port.
Use the undo monitor-port command to remove the configuration of the destination port.
You can only configure one destination port on a switch, and all mirrored packets will be sent to the destination port.
Example
# Configure GigabitEthernet1/1/4 as the destination port.
<H3C> system-view
[H3C] interface GigabitEthernet1/1/4
[H3C-GigabitEthernet1/1/4] monitor-port
1.1.9  remote-probe vlan
remote-probe vlan enable
undo remote-probe vlan enable
View
VLAN view
Parameter
None
Use the remote-probe vlan enable command to configure the current VLAN as the remote-probe VLAN.
After this command is executed, the system first checks whether the current VLAN is a dynamic VLAN. If yes, the command will fail, and the system prompts “Can not set dynamic VLAN as remote-probe VLAN!”.
Use the undo remote-probe vlan enable command to configure the remote-probe VLAN as a normal VLAN.
Before defining the remote-probe VLAN, make sure that no Access or Hybrid port belongs to this VLAN. If any Trunk port exists in this VLAN, the port PVID cannot be the ID of remote-probe VLAN. After setting a VLAN as remote-probe VLAN, it is recommended not to add Access or Hybrid port to the VLAN.
Example
# Configure VLAN 5 as remote-probe vlan.
<H3C> system-view
[H3C] vlan 5
[H3C-vlan5] remote-probe vlan enable
