07-MPLS命令参考
08-MPLS L3VPN命令
本章节下载: 08-MPLS L3VPN命令  (532.21 KB)
08-MPLS L3VPN命令
1 MPLS L3VPN
1.1 MPLS L3VPN配置命令
1.1.1 address-family ipv4 (VPN instance view)
1.1.2 address-family vpnv4
1.1.3 advertise route-reoriginate
1.1.4 apply-label
1.1.5 dampening ibgp
1.1.6 description (VPN instance view)
1.1.7 display bgp routing-table ipv4 unicast inlabel
1.1.8 display bgp routing-table ipv4 unicast outlabel
1.1.9 display bgp routing-table vpnv4
1.1.10 display bgp routing-table vpnv4 inlabel
1.1.11 display bgp routing-table vpnv4 outlabel
1.1.12 display ip vpn-instance
1.1.13 display ospf sham-link
1.1.14 display vpn-peer
1.1.15 domain-id (OSPF view)
1.1.16 export route-policy
1.1.17 ext-community-type (OSPF view)
1.1.18 import route-policy
1.1.19 ip binding vpn-instance
1.1.20 ip public-instance
1.1.21 ip vpn-instance (System view)
1.1.22 l3vpn reflector
1.1.23 mpls per-vrf-label range
1.1.24 nesting-vpn
1.1.25 peer advertise vpn-reoriginate ibgp (BGP VPNv4 address family view)
1.1.26 peer next-hop-invariable (BGP VPNv4 address family view)
1.1.27 peer next-hop-vpn
1.1.28 peer upe
1.1.29 peer upe route-policy
1.1.30 policy vpn-target
1.1.31 route-distinguisher
1.1.32 route-replicate (Public instance IPv4 address family view)
1.1.33 route-replicate (VPN instance IPv4 address family view)
1.1.34 route-replicate enable
1.1.35 route-tag (OSPF view)
1.1.36 routing-table limit
1.1.37 rr-filter (BGP VPNv4 address family view)
1.1.38 sham-link (OSPF area view)
1.1.39 snmp context-name
1.1.40 snmp-agent trap enable l3vpn
1.1.41 tnl-policy
1.1.42 vpn popgo
1.1.43 vpn-id
1.1.44 vpn-peer
1.1.45 vpn-route cross multipath
1.1.46 vpn-target
1 MPLS L3VPN
1.1  MPLS L3VPN配置命令
address-family ipv4命令用来进入VPN实例IPv4地址族视图。
undo address-family ipv4命令用来删除VPN实例IPv4地址族视图下的所有配置。
address-family ipv4
VPN实例视图
在VPN实例IPv4地址族视图下可以配置IPv4 VPN的参数,如IPv4 VPN应用的出方向路由策略、入方向路由策略等。
# 进入VPN实例IPv4地址族视图。
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1]
·     address-family ipv6 (VPN instance view)
address-family vpnv4命令用来创建BGP VPNv4地址族或BGP-VPN VPNv4地址族,并进入相应地址族视图。如果BGP VPNv4地址族或BGP-VPN VPNv4地址族已经存在,则直接进入BGP VPNv4地址族或BGP-VPN VPNv4地址族视图。
undo address-family vpnv4命令用来删除BGP VPNv4地址族或BGP-VPN VPNv4地址族,及相应地址族视图下的所有配置。
不存在BGP VPNv4地址族和BGP-VPN VPNv4地址族。
BGP实例视图
BGP-VPN实例视图
VPNv4地址是指在IPv4地址前缀前增加RD后,形成的地址。VPNv4路由是指携带VPNv4地址的路由信息。
在PE设备上,进入BGP VPNv4地址族视图或BGP-VPN VPNv4地址族视图,在该视图下通过peer enable命令使能BGP对等体后,PE才能与该对等体交换BGP VPNv4路由。
在BGP VPNv4地址族视图下,还可以配置BGP-VPNv4路由的属性,例如为从对等体/对等体组接收的BGP-VPNv4路由分配的首选值、是否允许本地AS号在接收的BGP-VPNv4路由的AS_PATH属性中出现等。
BGP VPNv4地址族视图下的配置用来控制PE设备之间交互的VPNv4路由。
BGP-VPN VPNv4地址族视图下的配置用来控制嵌套VPN组网中,运营商PE和运营商CE之间交互的VPNv4路由。
# 在BGP实例视图下,创建BGP VPNv4地址族,并进入BGP VPNv4地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4]
advertise route-reoriginate命令用来配置在指定VPN实例的BGP单播路由表中重生成其他VPN实例下的BGP单播路由。
undo advertise route-reoriginate命令用来恢复缺省情况。
仅R5111及以上版本支持本命令。
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
在VPN实例下无法重生成其他VPN实例下的BGP单播路由。
BGP-VPN IPv4单播地址族视图
route-policy route-policy-name:仅重生成通过路由策略过滤的BGP路由。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则不对重生成的路由进行过滤。
replace-rt:将重生成路由的Route Target属性修改为当前VPN实例的Route Target属性值。如果不指定本参数,则重生成的路由保留原路由的Route Target属性。
缺省情况下,各个VPN实例之间的BGP路由均相互隔离。在某些组网场景下,需要实现跨VPN发布路由,即需要将其他VPN实例的路由发布到指定的VPN实例中。配置本命令后,如果其他VPN实例的Route Target属性与当前地址族视图所属的VPN实例匹配,则会在该VPN实例的BGP路由表中重生成其他VPN实例的所有BGP路由(不包括从本地引入的路由,如配置import-route命令后引入的IGP路由),并且可以通过replace-rt参数决定是否改变重生成路由的Route Target属性。
从IBGP对等体接收到的路由在重生成后,不会再发布给其他IBGP对等体,如需将该路由发布给IBGP对等体,则需要配置peer advertise vpn-reoriginate ibgp命令。
配置本命令后,重生成的是IPv4单播路由。
advertise route-reoriginate命令和route-replicate enable命令都可以实现VPN实例间的BGP路由相互引入,两条命令的区别如下:
·     advertise route-reoriginate命令仅能重生成VPN实例下的BGP路由。route-replicate enable命令可以实现将公网BGP路由引入到VPN实例的BGP路由表中。
·     通过route-replicate enable命令将从IBGP对等体接收到的路由引入到特定的VPN实例后,该路由无法发布给其他IBGP对等体。同时配置advertise route-reoriginate命令和peer advertise vpn-reoriginate ibgp命令可以实现将从IBGP对等体收到的BGP路由重生后发布给其他IBGP对等体。
advertise route-reoriginate命令和route-replicate enable命令可以相互配合,使公网BGP路由引入到VPN实例后再重生成到指定的VPN实例,并且可以发布给任何需要的BGP对等体。
# 配置在VPN实例vpn1的BGP单播路由表中,重生成其他VPN实例下的BGP单播路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise route-reoriginate
·     peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)(EVPN命令参考/EVPN概述)
·     peer advertise vpn-reoriginate ibgp (BGP VPNv4 address family view)
·     route-replicate enable
1.1.4  apply-label
apply-label命令用来配置MPLS标签分配方式。
undo apply-label命令用来恢复缺省情况。
apply-label { per-instance [ static static-label-value ] | per-route }
undo apply-label
采用每下一跳每标签的标签分配方式,即BGP为VPN路由中的每个下一跳分配一个标签。
VPN实例IPv4 VPN视图
per-instance:表示每实例每标签的标签分配方式,即当前VPN实例下所有发往对端PE的路由都使用同一个标签值。
static static-label-value:静态标签值,取值范围为16~250000。如果未指定本参数时,则随机分配一个标签值。
per-route:表示每路由每标签的标签分配方式,即当前VPN实例下每条路由使用单独的标签值。
执行本命令将改变标签的分配方式,导致VPN实例下的所有路由重分发。因此已经有业务在VPN实例中运行时,执行本命令会导致业务短暂中断,请慎重操作。
BGP为VPN实例路由分配标签的方式有三种:
·     每下一跳每标签:为每个下一跳分配一个标签。当按照每路由每标签的标签分配方式申请的标签数量大于设备支持的最大标签数目时,通过采用此方式,可以减少申请的标签数量。
·     每路由每标签:为每条路由分配一个标签。采用这种方式时,路由条目和标签一一对应。
·     每实例每标签:为每个VPN实例分配一个标签。在MPLS L3VPN组网环境中,当PE上的VPN路由数量很多导致MPLS标签资源不足时,配置本方式可以节省PE上的标签资源。
每下一跳每标签或者每路由每标签分配方式可以与vpn popgo命令配合使用,可以实现报文根据标签查找出接口转发报文。
每实例每标签分配方式不能与vpn popgo命令配合使用,采用该分配方式时,只能根据标签查找FIB转发报文,该VPN内vpn popgo命令不生效。
# 在VPN实例IPv4 VPN视图,为所有发往对端PE的路由分配静态标签10000。
[Sysname-vpn-ipv4-vpn1] apply-label per-instance static 10000
This configuration causes service interruption. Continue? [Y/N]:y
·     vpn popgo
dampening ibgp命令用来配置IBGP路由衰减。
undo dampening ibgp命令用来恢复缺省情况。
dampening ibgp [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
undo dampening ibgp
未配置IBGP路由衰减。
BGP VPNv4地址族视图
half-life-reachable:发生震荡的可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
half-life-unreachable:发生震荡的不可达路由的半衰期,取值范围为1~45,单位为分钟,缺省值为15分钟。
reuse:路由的再使用阈值,取值范围为1~20000,缺省值为750。当惩罚值降低到该值以下时,此路由变为可用路由,参与路由选择。路由的再使用阈值必须小于suppress。
suppress:路由的抑制阈值,取值范围为1~20000,缺省值为2000。当惩罚值超过该值时,此路由被抑制,不参与路由选择。
ceiling:惩罚值的上限,取值范围为1001~20000,缺省值为16000。惩罚值达到该值后,不再增加。惩罚值的上限必须大于suppress。
route-policy route-policy-name:通过路由策略指定对哪些路由进行路由衰减。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
配置本命令后,IBGP邻居down了之后,来自该邻居的路由不会被删除,而是进行路由衰减。
# 在BGP VPNv4地址族视图下,配置IBGP路由衰减,可达路由和不可达路由的半衰期均为10分钟,路由的再使用阈值为1000,抑制阈值为2000,惩罚值上限为10000。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] dampening ibgp 10 10 1000 2000 10000
·     display bgp dampening parameter(三层技术-IP路由命令参考/BGP)
description命令用来配置VPN实例的描述信息。
undo description命令用来恢复缺省情况。
未配置VPN实例的描述信息。
VPN实例视图
text:VPN实例的描述信息,为1~79个字符的字符串,区分大小写。
# 配置名为vpn1的VPN实例的描述信息为“This is vpn1”。
[Sysname-vpn-instance-vpn1] description This is vpn1
display bgp routing-table ipv4 unicast inlabel命令用来显示BGP IPv4单播路由的入标签信息。
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的入标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网BGP IPv4单播路由的入标签信息。
执行本命令时指定unicast参数和不指定unicast参数的效果相同。
# 显示公网内所有BGP IPv4单播路由的入标签信息。
<Sysname> display bgp routing-table ipv4 inlabel
 Total number of routes: 1
 BGP local router ID is 3.3.3.9
     Network            NextHop         OutLabel        InLabel
* >  2.2.2.9/32         1.1.1.2         1151            1279
表1-1 display bgp routing-table ipv4 unicast inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? – incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对等体为IPv4路由分配的标签
InLabel
入标签值,即本地为IPv4路由分配的标签
display bgp routing-table ipv4 unicast outlabel命令用来显示BGP IPv4单播路由的出标签信息。
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的出标签信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网BGP IPv4单播路由的出标签信息。
# 显示公网所有BGP IPv4单播路由的出标签信息。
<Sysname> display bgp routing-table ipv4 outlabel
表1-2 display bgp routing-table ipv4 unicast outlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
display bgp routing-table vpnv4命令用来显示BGP VPNv4路由信息。
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ mask-length | mask ] [ longest-match ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
route-distinguisher route-distinguisher:显示指定路由标识符的BGP VPNv4路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
ipv4-address:目的网段的IPv4地址。
mask-length:掩码长度,取值范围为0~32。
mask:网络掩码,为点分十进制格式。
longest-match:指定根据如下方法判断显示哪条BGP VPNv4路由信息:
(1)     将用户输入的网络地址和路由的掩码进行与操作;
(2)     根据是否指定掩码,决定显示的BGP VPNv4路由信息:
¡     指定掩码时,计算结果与路由的网段地址相同,且掩码小于等于用户输入子网掩码的路由中,子网掩码最长的路由的简要信息将被显示出来。
¡     未指定掩码时,计算结果与路由的网段地址相同的路由中,子网掩码最长的路由的详细信息将被显示出来。
advertise-info:显示BGP VPNv4路由的通告信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP VPNv4路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
as-path-acl as-path-acl-name:显示匹配指定AS路径过滤列表名的BGP VPNv4路由信息。as-path-acl-name为AS路径过滤列表名,为1~51个字符的字符串,区分大小写,不能全为数字。
communit-list:显示匹配指定BGP团体列表的BGP VPNv4路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表与指定的团体属性列表完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表中包含指定的团体属性列表,就显示该路由的信息。
adv-community-list-number:高级团体列表号,取值范围为100~199。
vpn-instance vpn-instance-name:显示向指定对等体发布或者从指定对等体收到的指定VPN实例内BGP VPNv4路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示向指定对等体发布或者从指定对等体收到的公网内BGP VPNv4路由信息。
peer:显示向指定对等体发布或者从指定对等体收到的BGP VPNv4路由信息。
ipv4-address:对等体的IPv4地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示BGP VPNv4路由的统计信息。
如果未指定任何参数,则显示所有BGP VPNv4路由的简要信息。
如果指定了ipv4-address mask或ipv4-address mask-length参数,则显示与指定目的网段IP地址和网络掩码(或掩码长度)精确匹配的BGP VPNv4路由的详细信息。
如果只指定了ipv4-address参数,未指定mask和mask-length参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的详细信息。
# 显示所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4
 BGP local router ID is 1.1.1.9
 Total number of routes from all PEs: 8
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 6
* >  10.1.1.0/24        10.1.1.2        0                     32768   ?
*  e                    10.1.1.1        0                     0       65410?
* >  10.1.1.2/32        127.0.0.1       0                     32768   ?
* >i 10.3.1.0/24        3.3.3.9         0          100        0       ?
* >e 192.168.1.0        10.1.1.1        0                     0       65410?
*  i                    3.3.3.9         0          100        0       65420?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i 192.168.1.0        3.3.3.9         0          100        0       65420?
# 显示路由标识符为100:1的所有BGP VPNv4路由的简要信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
# 显示匹配AS路径过滤列表1的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
# 显示匹配BGP团体列表100的BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 community-list 100
# 显示向对等体3.3.3.9发布的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  10.1.1.0/24        10.1.1.2        0                             ?
* >e 192.168.1.0        10.1.1.1        0                             65410?
# 显示从对等体3.3.3.9收到的所有公网BGP VPNv4路由信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
表1-3 display bgp routing-table vpnv4命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
Network
目的网络地址
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
# 显示网段10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Paths:   1 available, 1 best
 Rely nexthop    : 172.1.1.2
 Original nexthop: 3.3.3.9
 OutLabel        : 1279
 Ext-Community   : <RT: 111:1>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# 显示路由标识符为100:1、目的网络地址为10.3.1.0/24的BGP VPNv4路由的详细信息。
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
表1-4 display bgp routing-table vpnv4命令详细显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
Route distinguisher
路由标识符
路由总数
Paths
路由数信息
·     available:有效路由条数
·     best:最佳路由条数
到达目的网络10.3.1.0/24的BGP路由表项信息
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值,取值包括:
·     RT:表示Route Target属性
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     localredist:本地路由生成的VPNv4路由
·     remoteredist:远端路由生成的VPNv4路由
·     not preferred for reason:路由未被优选的原因,reason的具体内容请参见表1-5
·     not ECMP for reason:未形成等价路由的原因,reason的具体内容请参见表1-6
IP precedence
路由的IP优先级,取值范围是0~7,N/A表示无效值
QoS local ID
路由的QoS本地ID属性,取值范围是1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围是1~64,N/A表示无效值
表1-5 路由未被优选的原因
原因
preferred-value
优选首选值最大的路由
local-preference
优选本地优先级最高的路由
local-origin-route
依次选择network命令生成的路由、import-route命令引入的路由、聚合路由
aigp
优选携带AIGP属性的路由,AIGP属性值越小优先级越高
as-path
优选AS路径最短的路由
origin
依次选择ORIGIN类型为IGP、EGP、Incomplete的路由
med
优选MED值最低的路由
remote-route
依次选择从EBGP、联盟EBGP、联盟IBGP、IBGP学来的路由
igp-cost
优选IGP Metric值最小的路由
relydepth
优选迭代深度值小的路由
rfc5004
rfc5004规则:如果当前的最优路由为EBGP路由,则BGP路由器收到来自不同的EBGP邻居的路由后,不会改变最优路由
router-id
优选Router ID最小的路由器发布的路由。如果路由包含RR属性,那么在路由选择过程中,就用ORIGINATOR_ID来替代Router ID
cluster-list
优选CLUSTER_LIST长度最短的路由
peer-address
优选IP地址最小的对等体发布的路由
redist-route
优选本VPN的路由,然后选择其他VPN引入的路由
rpki
优选RPKI验证结果优先级最高的路由
received
优选最先学习到的路由
evpn-macip-mobile
优选携带MAC迁移团体属性的EVPN MAC/IP发布路由
evpn-macip-mobile-static
优选MAC迁移团体属性中携带静态MAC的EVPN MAC/IP发布路由
evpn-macip-mobile-seq
优选MAC迁移团体属性中携带序列号最大的EVPN MAC/IP发布路由
evpn-macip-mobile-routerid
优选MAC迁移团体属性中携带Router ID最小的EVPN MAC/IP发布路由
encap-type
优选SRv6封装的路由或者MPLS封装的路由
color-relay
优选通过Color属性迭代的路由
表1-6 未形成等价路由的原因
原因
preferred-value
首选值不同
local-preference
本地优先级不同
local-origin-route
路由的生成方式不同
aigp
携带的AIGP属性值不同或某条路由未携带AIGP属性
as-path
AS_PATH属性的长度不同
origin
ORIGIN属性不同
med
MED属性值不同
remote-route
路由来自不同的EBGP、联盟EBGP、联盟IBGP或IBGP邻居
igp-cost
IGP Metric值不同
local-redist-route
本地从其他VPN引入的路由不能形成等价
label-route
不同时为标签路由或非标签路由
samenexthop
路由具有相同的下一跳
evpn-macip-label
EVPN MAC/IP发布路由未同时携带L3VNI
evpn-other-type
EVPN路由中非MAC/IP发布路由不能形成等价
color-relay
路由未同时通过Color属性迭代
# 显示到达目的网段10.1.1.0/24的BGP VPNv4路由的通告信息。
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24:
    3.3.3.9
 Inlabel         : 1279
表1-7 display bgp routing-table vpnv4 advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
路由总数
Paths
到达指定目的网络的优选路由数目
到达目的网络10.1.1.0/24的BGP路由的通告信息
该路由已经向哪些VPNv4对等体发送,以及对等体的数目
Inlabel
路由的入标签
# 显示向对等体3.3.3.9发布的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体3.3.3.9收到的公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistics
 Received routes total: 2
表1-8 display bgp routing-table vpnv4 peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示公网BGP VPNv4路由的统计信息。
<Sysname> display bgp routing-table vpnv4 statistics
表1-9 display bgp routing-table vpnv4 statistics命令显示信息描述表
来自所有PE设备的VPNv4路由总数
Route distinguisher
路由标识符
路由标识符为指定值的VPNv4路由总数
·     ip as-path(三层技术-IP路由命令参考/路由策略)
display bgp routing-table vpnv4 inlabel命令用来显示所有BGP VPNv4路由的入标签信息。
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
# 显示所有BGP VPNv4路由的入标签信息。
<Sysname> display bgp routing-table vpnv4 inlabel
* >  10.1.1.0/24        10.1.1.2        NULL            1279
* >e 192.168.1.0        10.1.1.1        NULL            1278
表1-10 display bgp routing-table vpnv4 inlabel命令输出信息描述表
BGP路由总数
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为VPNv4路由分配的私网标签,取值为NULL表示空标签
InLabel
入标签值,即本地PE为VPNv4路由分配的私网标签
display bgp routing-table vpnv4 outlabel命令用来显示所有BGP VPNv4路由的出标签信息。
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
# 显示所有BGP VPNv4路由的出标签信息。
<Sysname> display bgp routing-table vpnv4 outlabel
 Total number of routes from all PEs: 4
* >i 10.3.1.0/24        3.3.3.9         1279
*  i 192.168.1.0        3.3.3.9         1278
* >i 192.168.1.0        3.3.3.9         1278
表1-11 display bgp routing-table vpnv4 outlabel命令输出信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
来自所有PE设备的路由数
Route distinguisher
路由标识符
路由标识符为指定值的路由总数
Network
目的网络地址
NextHop
下一跳IP地址
OutLabel
display ip vpn-instance命令用来显示VPN实例的信息。
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name:显示指定VPN实例的详细信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示创建的所有VPN实例的简要信息。
# 显示所有VPN实例的简要信息。
<Sysname> display ip vpn-instance
  Total IPv4 VPN-Instances configured : 1
  Total IPv6 VPN-Instances configured : 0
  VPN-Instance Name     RD              Address family      Create time
  abc                   1:1             IPv4                2011/05/18 10:48:17
表1-12 display ip vpn-instance命令显示信息描述表
VPN-Instance Name
VPN实例名称
RD
VPN实例的路由标识符
Address family
地址族名称,取值包括IPv4和IPv6
如果VPN实例下没有创建IPv4 VPN和IPv6 VPN,则本字段显示为N/A
Create time
VPN实例创建的时间
# 显示名为vpn1的VPN实例的详细信息。
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and Index : vpn1, 2
  Route Distinguisher : 100:1
  VPN ID : 1:1
  Description : vpn1
  Interfaces : HundredGigE1/0/2
  Address-family IPv4:
   Export VPN Targets :
       2:2
   Import VPN Targets :
       3:3
   Export Route Policy : outpolicy
   Import Route Policy : inpolicy
   Tunnel Policy : tunnel1
   Maximum Routes Limit : 500
   Threshold Value(%): 50
  Address-family IPv6:
       2:2
       3:3
   Maximum Routes Limit :500
表1-13 display ip vpn-instance instance-name命令显示信息描述表
VPN实例名称和索引
Route Distinguisher
VPN实例的路由标识符值
VPN ID
VPN实例的ID,即VPN实例的全局唯一标识
VPN实例的描述信息
Interfaces
关联该VPN实例的接口
Address-family IPv4
IPv4 VPN的信息
Address-family IPv6
IPv6 VPN的信息
Address-family IPv4 Flowspec
IPv4 Flowspec VPN的信息,详细介绍请参见“ACL和QoS配置指导”中的“Flowspec”
Export VPN Targets
出方向扩展团体属性
Import VPN Targets
入方向扩展团体属性
Export Route Policy
出方向路由策略
Import Route Policy
入方向路由策略
Tunnel Policy
隧道策略
路由最大条数
Threshold Value(%)
激活路由条数的告警门限值
display ospf sham-link命令用来显示OSPF伪连接信息。
display ospf [ process-id ] sham-link [ area area-id ]
process-id:显示指定OSPF进程内的伪连接信息。process-id为OSPF进程号,取值范围为1~65535。如果未指定本参数,则显示所有OSPF进程的伪连接信息。
area area-id:显示指定OSPF区域内的伪连接信息。area-id为OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。如果未指定本参数,则显示所有OSPF区域的伪连接信息。
如果未指定进程号和区域号,则显示所有的OSPF伪连接信息。
# 显示所有OSPF伪连接信息。
<Sysname> display ospf sham-link
          OSPF Process 1 with Router ID 125.1.1.1
                  Sham link
 Area            Neighbor ID     Source IP       Destination IP  State  Cost
 0.0.0.0         95.1.1.1        125.2.1.1       95.2.1.1        P-2-P  1
表1-14 display ospf sham-link命令显示信息描述表
Area
伪连接所属的OSPF区域
Neighbor ID
伪连接邻居的Router ID
Source IP
伪连接的源IP地址
Destination IP
伪连接的目的IP地址
伪连接的接口状态,取值包括Down和P-2-P
Cost
伪连接的开销
# 显示OSPF区域1内的OSPF伪连接信息。
<Sysname> display ospf sham-link area 1
          OSPF Process 100 with Router ID 100.1.1.2
 Sham link: 3.3.3.3 --> 5.5.5.5
 Neighbor ID: 120.1.1.2        State: Full
 Area: 0.0.0.1
 Cost: 1  State: P-2-P  Type: Sham
 Request list: 0  Retransmit list: 0
 GTSM: Enabled, maximum number of hops: 2
 Cryptographic authentication: Enabled, inherited
    The last key is 3.
    The rollover is in progress, 1 neighbor(s) left.
表1-15 display ospf sham-link area命令显示信息描述表
Sham link
伪连接,从源IP地址到目的IP地址
Neighbor ID
伪连接邻居的Router ID
伪连接的邻居状态,取值包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Area
伪连接所属的OSPF区域
Cost
伪连接的开销
伪连接的状态,取值包括Down和P-2-P
伪连接的类型,取值为Sham
Timers
伪连接的定时器,包括Hello,Dead,Retransmit和Transmit Delay定时器,单位为秒
Request list
请求列表个数
Retransmit list
重传列表个数
开启OSPF报文的GTSM安全检测功能,本例中允许接收到的报文所经过的路由器的最大跳数为2跳
如果未开启OSPF报文的GTSM安全检测功能,则显示为GTSM:Disabled
伪连接使用的验证模式,inherited表示伪连接继承的是所在区域下配置的验证模式,取值为:
·     Simple:表示简单验证模式
·     Cryptographic:表示加密验证模式,即MD5、HMAC-MD5或HMAC-SHA-256
The last key
最新的MD5/HMAC-MD5/HMAC-SHA-256验证密钥
正在进行MD5/HMAC-MD5/HMAC-SHA-256验证平滑迁移,尚未完成MD5/HMAC-MD5/HMAC-SHA-256验证平滑迁移的邻居个数为1
display vpn-peer命令用来显示VPN peer的信息。
display vpn-peer [ peer-id vpn-peer-id | peer-name vpn-peer-name | verbose ]
vpn-peer-id:显示指定ID的VPN peer的详细信息。vpn-peer-id表示VPN peer ID,取值范围为1~134217727。
vpn-peer-name:显示指定名称的VPN peer的详细信息。vpn-peer-name表示VPN peer名称,为1~31个字符的字符串,区分大小写。
verbose:显示所有VPN peer的详细信息。
如果未指定任何参数,则显示所有VPN peer的简要信息。
# 显示所有VPN peer的简要信息。
<Sysname> display vpn-peer
Total VPN peer count(s): 2
VPN peer name                   Peer-id   User-profile                    State
010-020                         1         up10M                           Online
030-040                         2         up20M                           Offline
表1-16 display vpn-peer命令显示信息描述表
VPN peer name
VPN peer名称
Peer-id
VPN peer标识符
User-profile
VPN peer使用的用户配置文件
VPN peer当前是否在线:
·     Offline:表示不在线
·     Online:表示在线
# 显示所有VPN peer的详细信息。
<Sysname> display vpn-peer verbose
VPN peer name: 010-020
Peer-id: 1
User-profile: up10M
State: Online
Outbound statistics:
  Pass packets: 12600
  Pass bytes  : 100
  Drop packets: 0
  Drop bytes  : 0
VPN peer name: 030-040
Peer-id: 2
User-profile: up20M
State: Offline
  Pass packets: 12600
  Pass bytes  : 100
  Drop packets: 0
  Drop bytes  : 0
表1-17 display vpn-peer verbose命令显示信息描述表
VPN peer name
VPN peer名称
Peer-id
VPN peer标识符
User-profile
VPN peer使用的用户配置文件
VPN peer当前是否在线:
·     Offline:表示不在线
·     Online:表示在线
Outbound statistics
该VPN peer出方向的报文转发统计信息,包括出方向发送的字节数、发送的报文数、丢弃的字节数和丢弃的报文数
domain-id命令用来配置OSPF域标识符。
undo domain-id命令用来删除OSPF域标识符。
undo domain-id [ domain-id ]
OSPF域标识符为0。
OSPF视图
domain-id:OSPF域标识符,可以采用以下三种形式。
·     整数形式,取值范围为0~4294967295,例如:1。
·     点分十进制形式,例如:0.0.0.1。
·     9~21个字符的字符串,格式为“点分十进制形式:16位用户自定义数”,16位用户自定义数取值范围0~65535,例如:0.0.0.1:512。
secondary:配置的域标识符作为从标识符。如果未指定本参数,表示配置主标识符。
如果通过domain-id命令配置了OSPF域标识符,则PE将OSPF路由引入到BGP时,主域标识符被附加到BGP VPNv4路由上,作为BGP的扩展团体属性传递给对端PE。对端PE接收到BGP路由后,将本地配置的OSPF主域标识符、从域标识符和路由中携带的OSPF域标识符进行比较:如果主域标识符或从域标识符与其相同,且为区域内或区域间路由,则将路由重新引入到OSPF时,该路由作为Network Summary LSA(即Type-3 LSA)发布给CE;否则,该路由将作为AS External LSA(即Type-5 LSA)或NSSA External LSA(即Type-7 LSA)发布给CE。
执行undo domain-id命令时,如果未指定任何参数,将恢复缺省情况。
# 配置OSPF域标识符为234。
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy命令用来配置出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
未应用出方向路由策略,不对发布的路由进行过滤。
VPN实例视图
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
route-policy:出方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的出方向路由策略,则该VPN实例在向其他VPN实例发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例之间路由的发布。
多次执行本命令,最后一次执行的命令生效。
VPN实例视图下的配置对所有地址族有效,地址族视图下的配置只能用于对应地址族。对于指定地址族,优先使用该地址族视图内的配置。只有该地址族视图内未配置时,才采用VPN实例视图下的配置。
# 对名为vpn1的VPN实例应用出方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] export route-policy poly-1
·     import route-policy
·     route-policy(三层技术-IP路由命令参考/路由策略)
ext-community-type命令用来配置OSPF扩展团体属性的类型编码。
undo ext-community-type命令用来将指定OSPF扩展团体属性的类型编码恢复为缺省值。
undo ext-community-type [ domain-id | router-id | route-type ]
OSPF扩展团体属性Domain ID的类型编码是0x0005,Router ID的类型编码是0x0107,Route Type的类型编码是0x0306。
OSPF视图
domain-id type-code1:指定OSPF扩展团体属性Domain ID的类型编码。type-code1取值可以为十六进制数值0005、0105、0205和8005。
router-id type-code2:指定OSPF扩展团体属性Router ID的类型编码。type-code2取值可以为十六进制数值0107和8001。
route-type type-code3:指定OSPF扩展团体属性Route Type的类型编码。type-code3取值可以为十六进制数值0306和8000。
# 为OSPF进程100配置OSPF扩展团体属性Domain ID的类型编码为0x8005,Router ID的类型编码为0x8001,Route Type的类型编码为0x8000。
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy命令用来配置入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
未应用入方向路由策略。如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
VPN实例视图
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
route-policy:入方向路由策略名,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了VPN实例应用的入方向路由策略,则该VPN实例在接收其他VPN实例的路由后,将利用指定的路由策略对接收的路由进行过滤、改变接收路由的属性等。使用本命令可以更加精确、灵活地控制VPN实例之间路由的接收。
# 对名为vpn1的VPN实例应用入方向路由策略poly-1。
[Sysname-vpn-instance-vpn1] import route-policy poly-1
·     export route-policy
ip binding vpn-instance命令用来配置接口与指定VPN实例关联。
undo ip binding vpn-instance命令用来恢复缺省情况。
接口未关联VPN实例,接口属于公网。
vpn-instance-name:接口关联的VPN实例名称,为1~31个字符的字符串,区分大小写。
配置或取消接口与VPN实例关联后,该接口上的IP地址、路由协议等配置将被删除。
本命令用于在PE设备上将连接CE的接口与该CE所属的VPN实例关联。
接口关联的VPN实例,必须已经通过系统视图下的ip vpn-instance命令创建。
不能通过重复执行本命令修改接口关联的VPN实例。如需修改接口关联的VPN实例,请先通过undo ip binding vpn-instance命令取消关联的VPN实例后,再执行ip binding vpn-instance命令关联新的VPN实例。
# 将接口HundredGigE1/0/1与名为vpn1的VPN实例关联。
[Sysname-HundredGigE1/0/1] ip binding vpn-instance vpn1
·     ip vpn-instance (System view)
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例可以看作是特殊的VPN实例,通过公网实例可以实现公网用户和私网用户互相访问。
# 创建公网实例,并进入公网实例视图。
[Sysname] ip public-instance
[Sysname-public-instance]
ip vpn-instance命令用来创建VPN实例,并进入VPN实例视图。如果指定的VPN实例已经存在,则直接进入VPN实例视图。
undo ip vpn-instance命令用来删除指定的VPN实例。
不存在VPN实例。
vpn-instance-name:VPN实例的名称,为1~31个字符的字符串,区分大小写。
# 创建一个名为vpn1的VPN实例,并进入VPN实例视图。
·     route-distinguisher
l3vpn reflector命令用来配置L3VPN的报文反射功能。
undo l3vpn reflector命令用来关闭L3VPN的报文反射功能。
l3vpn reflector vpn-instance vpn-instance-name ip ip-address [ source-port source-port ] [ destination-port destination-port ]
undo l3vpn reflector vpn-instance vpn-instance-name
L3VPN的报文反射功能处于关闭状态。
vpn-instance vpn-instance-name:指定需要反射报文的VPN实例,vpn-instance-name为接口关联的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:指定待反射报文的目的IP地址,为点分十进制格式,不能为本设备连接CE的接口IP地址。
source-port source-port:指定待反射报文的UDP源端口号,取值范围为1~65535,缺省值为49184。
destination-port destination-port:指定待反射报文的UDP目的端口号,取值范围为1~65535,缺省值为7。
配置L3VPN的报文反射功能后,可反射对指定VPN的检测报文。
每个VPN实例只能关联一个待反射报文的IP地址。多次执行本命令为同一个VPN实例关联不同的待反射报文IP地址时,最后一次执行的命令生效。
# 配置L3VPN的报文反射功能:VPN实例为vpn1,反射报文的目的IP地址为1.1.1.1。
[Sysname] l3vpn reflector vpn-instance vpn1 ip 1.1.1.1
mpls per-vrf-label range命令用来配置VPN实例的MPLS标签范围。
undo mpls per-vrf-label range命令用来恢复缺省情况。
mpls per-vrf-label range minimum maximum
未配置VPN实例的MPLS标签范围。
minimum:MPLS标签范围的最小值,取值范围为15000~249999。
maximum:MPLS标签范围的最大值,取值范围为15001~250000。
在MPLS L3VPN组网环境中,PE设备为VPN实例的私网路由分配MPLS标签时,使用本命令配置的标签范围内的标签。
# 配置VPN实例的MPLS标签范围为100000~104095。
[Sysname] mpls per-vrf-label range 100000 104095
1.1.24  nesting-vpn
nesting-vpn命令用来开启嵌套VPN功能。
undo nesting-vpn命令用来关闭嵌套VPN功能。
nesting-vpn
undo nesting-vpn
嵌套VPN功能处于关闭状态。
BGP VPNv4地址族视图
嵌套VPN是指在运营商通过MPLS L3VPN骨干网为用户提供一个大的VPN的基础上,用户可以根据实际需要管理和划分自己的内部VPN,而这些内部VPN的划分对于运营商骨干网来说是透明的。嵌套VPN为用户提供了多样化的VPN组网方式,实现了用户对内部VPN以及多层VPN之间的互访权限控制管理,可以满足多种用户网络的需求。
只有在BGP VPNv4地址族视图下使能了嵌套VPN功能后,BGP-VPN VPNv4地址族视图下通过peer enable命令激活的对等体之间才能成功协商VPNv4路由交换能力,才能接收和发布VPNv4路由。
# 在BGP VPNv4视图下,使能嵌套VPN功能。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] nesting-vpn
peer advertise vpn-reoriginate ibgp命令用来配置以VPNv4路由的形式向指定IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
undo peer advertise vpn-reoriginate ibgp命令用来取消该配置。
仅R5111及以上版本支持本命令。
peer { group-name | ipv4-address [ mask-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] } peer advertise vpn-reoriginate ibgp
不会向IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
BGP VPNv4地址族视图
ipv4-address:对等体的IP地址。指定的对等体组必须已经创建。
本命令的应用场景请参见advertise route-reoriginate命令。本命令必须配合advertise route-reoriginate命令使用。单独配置本命令时,本命令不生效。
配置本命令后,设备将会以VPNv4路由的形式向指定IBGP对等体发布配置了advertise route-reoriginate命令后VPN实例下重生成的路由。
# 在BGP VPNv4地址族视图下,配置以VPNv4路由的形式向IBGP对等体1.1.1.1发布VPN实例下重生成的BGP路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 advertise vpn-reoriginate ibgp
peer next-hop-invariable命令用来配置向指定对等体/对等体组发布路由时不改变下一跳。
undo peer next-hop-invariable命令用来配置向对等体/对等体组发布路由时会将下一跳改为自己的地址。
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
BGP VPNv4地址族视图
如果在跨域VPN OptionC组网中使用路由反射器RR(Route Reflector)通告VPNv4路由,则需要在路由反射器上通过本命令配置向BGP邻居和反射客户通告VPNv4路由时,不改变路由的下一跳,以保证私网路由下一跳不会被修改。
本命令与peer next-hop-local命令互斥。
# 在BGP VPNv4地址族视图下,配置向对等体1.1.1.1发布路由时不改变下一跳。
[Sysname] bgp 100
[Sysname-bgp-default-af-vpnv4] peer 1.1.1.1 next-hop-invariable
·     peer next-hop-local(三层技术-IP路由命令参考/BGP)
peer next-hop-vpn命令用来配置从对等体/对等体组接收到VPNv4路由时,将下一跳属性修改为VPN实例中的下一跳地址。
undo peer next-hop-vpn命令用来恢复缺省情况。
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
设备接收到VPNv4路由时不修改路由的下一跳属性。
BGP VPNv4地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
缺省情况下,设备接收到VPNv4路由时不修改路由的下一跳属性,即VPNv4路由的下一跳为公网地址。配置本命令后,设备接收到VPNv4路由时,将VPNv4路由的下一跳指向私网,并将出标签修改为无效值。例如,设备收到VPNv4路由的下一跳为公网地址10.1.1.1,配置本命令后,将VPNv4路由的下一跳指向私网10.1.1.1。
配置本命令后:
·     设备将删除并重新建立与指定对等体的BGP会话,会造成BGP会话短暂中断。
·     设备只接收RD与本地已存在的RD相同的VPNv4路由。
·     设备将从指定对等体/对等体组接收到的VPNv4路由发送给其对等体时,路由RT属性将保持原有属性,不使用所在VPN的RT属性进行替换。
·     本地删除VPN实例或VPN实例的RD时,从指定对等体/对等体组收到的属于该VPN实例的VPNv4路由将被删除。
# 在BGP VPNv4地址族视图下,配置将从对等体1.1.1.1收到的VPNv4路由的下一跳修改为对应VPN实例中的下一跳。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 next-hop-vpn
1.1.28  peer upe
peer upe命令用来指定BGP对等体或对等体组作为HoVPN的UPE。
undo peer upe命令用来取消指定BGP对等体或对等体组作为HoVPN的UPE。
peer { group-name | ip-address [ mask-length ] } upe
undo peer { group-name | ip-address [ mask-length ] } upe
BGP对等体或对等体组不是HoVPN的UPE。
BGP VPNv4地址族视图
ip-address:对等体的IP地址。指定的对等体必须已经创建。
UPE是一类特殊的VPNv4对等体,它可以接收SPE上每个相关VPN实例的一条缺省路由,也可以接收SPE上发送的通过路由策略过滤的路由信息。SPE是普通的VPN对等体。
# 在BGP VPNv4地址族视图下,指定对等体1.1.1.1作为UPE。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe
peer upe route-policy命令用来配置向指定的UPE发布经过路由策略过滤的路由信息。
undo peer upe route-policy命令用来取消该配置。
peer { group-name | ip-address [ mask-length ] } upe route-policy route-policy-name export
undo peer { group-name | ip-address [ mask-length ] } upe route-policy [ route-policy-name ] export
不向对等体发布路由。
BGP VPNv4地址族视图
route-policy-name:路由策略的名称,为1~63个字符的字符串,区分大小写。
export:对发布的路由应用过滤策略。
本命令必须和peer upe命令配合使用。
# 在BGP VPNv4地址族视图下,配置对等体1.1.1.1为UPE,并向1.1.1.1发送通过路由策略hope过滤的路由信息。
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe route-policy hope export
·     peer upe
policy vpn-target命令用来配置对接收到的VPNv4路由进行VPN-Target过滤,即只将Export Route Target属性与本地Import Route Target属性匹配的VPNv4路由加入到路由表。
undo policy vpn-target命令用来配置对接收到的VPNv4路由不进行VPN-Target过滤,即接收所有VPNv4路由。
policy vpn-target
对接收到的VPNv4路由进行VPN-Target过滤。
BGP VPNv4地址族视图
在跨域VPN OptionB组网中,ASBR需要保存所有VPNv4路由信息,以通告给对端ASBR。这种情况下,ASBR上需执行undo policy vpn-target命令接收所有的VPNv4路由信息,不对它们进行VPN-Target过滤。
# 在BGP VPNv4地址族视图下,配置对接收到的VPNv4路由不进行VPN-Target过滤。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo policy vpn-target
route-distinguisher命令用来配置RD(Route Distinguisher,路由标识)。
undo route-distinguisher命令用来恢复缺省情况。
未配置RD。
VPN实例视图
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
公网实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
RD用于解决不同VPN之间地址空间重叠的问题。将RD添加到一个IPv4前缀之前,使之成为全局唯一的VPN-IPv4地址前缀。
在VPN实例视图下配置RD后,如果VPN实例所有地址族视图下不存在RD配置,则该配置会同步到VPN实例所有地址族视图下。此时如果删除某一地址族视图下的RD配置,则会同时删除VPN实例视图下的RD配置。
当VPN实例视图下没有配置RD时,允许用户在VPN实例各个地址族视图下分别配置RD,RD可以不同。此时如果在VPN实例视图下配置RD,则必须保证VPN实例视图下和VPN实例各个地址族视图下的RD配置一致,否则配置失败。
为了保证VPN-IPv4地址全球唯一,建议不要将自治系统号/IP地址设置为私有AS号/私有IP地址。
不能通过重复执行route-distinguisher命令修改VPN实例的RD值。如需修改VPN实例的RD值,请先通过undo route-distinguisher命令删除VPN实例的RD值,再执行route-distinguisher命令配置新的RD值。
# 配置VPN实例vpn1的RD为22:1。
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
route-replicate命令用来将指定VPN实例的路由信息引入到公网中。
undo route-replicate命令用来取消该配置。
route-replicate from vpn-instance vpn-instance-name protocol bgp as-number [ route-policy route-policy-name ]
route-replicate from vpn-instance vpn-instance-name protocol { direct | static | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from vpn-instance vpn-instance-name protocol { direct | static | bgp as-number | { isis | ospf | rip } process-id }
VPN实例的路由信息不能引入到公网中。
公网实例IPv4地址族视图
vpn-instance vpn-instance-name:从指定的VPN引入路由。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
protocol:引入指定路由协议的路由。
bgp:BGP协议。
as-number:本地AS号,取值范围为1~4294967295。
direct:直连路由。
static:静态路由。
isis:IS-IS协议。
ospf:OSPF协议。
rip:RIP协议。
process-id:路由协议的进程号,取值范围为1~65535。
advertise:允许发布引入的路由。如果未指定本参数,则表示引入的路由不允许发布。
route-policy route-policy-name:对引入的路由应用路由策略。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。
通过配置本功能可以将指定VPN实例的路由信息引入到公网中,从而使公网获取指定VPN的路由,以便转发用户流量。
# 将VPN实例vpn1中OSPF的有效路由引入到公网中。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4] route-replicate from vpn-instance vpn1 protocol ospf 1
route-replicate命令用来将公网或其他VPN实例的路由信息引入到指定VPN实例中。
route-replicate from { public | vpn-instance vpn-instance-name } protocol bgp as-number [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol eigrp eigrp-as [ advertise ] [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | static | unr | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | eigrp eigrp-as | static | unr | bgp as-number | { isis | ospf | rip } process-id }
公网或其他VPN实例的路由信息不能引入到指定VPN实例中。
VPN实例IPv4地址族视图
public:从公网引入路由。
bgp:BGP协议。
direct:直连路由。
eigrp:EIGRP协议。
static:静态路由。
unr:用户网络路由。
isis:IS-IS协议。
ospf:OSPF协议。
rip:RIP协议。
在BGP/MPLS L3VPN组网中,只有Route Target属性匹配的VPN实例之间才可以通信。通过配置本功能可以将公网或其他VPN实例的路由信息引入到指定VPN实例中,从而使指定VPN用户可以获取访问公网或其他VPN的路由。
在流量智能调控场景中,不同租户的流量被划分到不同的VPN中。为了使租户流量可以流向公网,则需要配置本功能将公网的路由信息引入到指定VPN实例中。
# 引入公网OSPF的有效路由到VPN实例vpn1中。
[Sysname-vpn-ipv4-vpn1] route-replicate from public protocol ospf 1
route-replicate enable命令用来开启公网和VPN实例BGP路由互相引入功能。
undo route-replicate enable命令用来关闭公网和VPN实例BGP路由互相引入功能。
仅R5111及以上版本支持本命令。
公网和VPN实例BGP路由互相引入功能处于关闭状态。
BGP实例视图
在流量清洗的场景中,公私网之间通过防火墙对流量进行过滤,不同用户的流量被划分到不同的VPN中。为了使VPN用户和公网用户互访,在防火墙提供流量安全保障的前提下,需要公网和VPN实例的BGP路由互相引入。
配置本命令后,Route Target属性相匹配的VPN实例及公网实例之间会互相引入对方实例下的BGP路由,以实现公网和所有VPN实例内的用户都可以互相访问。但此配置会影响不同VPN用户之间的隔离,请仅在特定场景下使用本功能。
本功能引入BGP路由时,还会同时引入BGP路由属性,以便设备通过BGP路由属性选择合适的转发路径。
·     通过route-replicate enable命令将从IBGP对等体接收到的路由引入到特定的VPN实例后,该路由也无法发布给其他IBGP对等体。同时配置advertise route-reoriginate命令和peer advertise vpn-reoriginate ibgp命令可以实现将从IBGP对等体收到的BGP路由重生后发布给其他IBGP对等体。
# 在BGP实例视图下,开启公网和VPN实例的BGP路由互相引入功能。
[Sysname] bgp 100
[Sysname-bgp-default] route-replicate enable
route-tag命令用来配置VPN引入路由的外部路由标记值。
undo route-tag命令用来恢复缺省情况。
route-tag tag-value
undo route-tag
若MPLS骨干网上配置了BGP路由协议,并且BGP的AS号不大于65535,则外部路由标记值的前面两个字节固定为0xD000,后面的两个字节为本端BGP的AS号;否则,外部路由标记值为0。例如,本端BGP AS号为100时,外部路由标记的缺省值为十进制值3489661028,即0xD0000000对应的十进制值(3489660928)+100。
OSPF视图
tag-value:VPN引入路由的外部路由标记值,取值范围为0~4294967295。
在CE双归属(CE连接两个PE)、且PE和CE之间采用OSPF协议交互私网路由的组网中,外部路由标记可以用来避免路由环路。CE连接的一台PE将从对端PE接收到的BGP路由引入OSPF,并通过Type-5或Type-7 LSA发布给CE时,为该Type-5或Type-7 LSA添加本地的外部路由标记。另一台PE接收到CE发布的Type-5或Type-7 LSA后,将其中的外部路由标记值与本地的外部路由标记值进行比较。如果相同(包括接收路由的外部路由标记值和本地的值均为0),则在进行路由计算时忽略该LSA,从而避免路由环路。
外部路由标记值的配置方式及各种方式的优先级为:
(1)     import-route命令配置的tag值优先级最高;
(2)     route-tag、default tag命令配置的tag值优先级其次。其中,route-tag命令用于PE设备,default tag命令用于CE和MCE设备。
同一个区域的PE建议配置相同的外部路由标记值。
外部路由标记值不会在BGP的扩展团体属性中传递,它只在收到BGP路由并且产生OSPF Type-5或Type-7 LSA的PE路由器上起作用。
可以为不同的OSPF进程配置相同的外部路由标记值。
# 为OSPF进程100配置VPN引入路由的外部路由标记值为100。
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
·     import-route(三层技术-IP路由命令参考/OSPF)
·     default(三层技术-IP路由命令参考/OSPF)
routing-table limit命令用来限制VPN实例支持的最多激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
未限制VPN实例支持的最多激活路由前缀数。
VPN实例视图
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
number:指定一个VPN实例最多可以支持的激活路由前缀数,取值范围为1~2700000。
warn-threshold:告警门限值,取值范围为1~100,单位为百分比。当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到告警门限值时,产生一条日志信息,但仍然允许激活路由前缀。当VPN实例中的激活路由前缀数达到最多支持激活路由前缀数目时,不再激活新的路由前缀。
simply-alert:指定当VPN实例的激活路由前缀数超过最多支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
通过本命令可以避免PE路由器引入太多的VPN激活路由前缀。
VPN实例视图下的配置,既可以用于IPv4 VPN,也可以用于IPv6 VPN;VPN实例IPv4地址族视图下的配置只能用于IPv4 VPN;VPN实例IPv6地址族视图下的配置只能用于IPv6 VPN。
VPN实例IPv4地址族视图下的配置优先级高于VPN实例视图下的配置,即如果同时在VPN实例IPv4地址族视图和VPN实例视图下进行了配置,则IPv4 VPN采用VPN实例IPv4地址族视图下的配置。
VPN实例IPv6地址族视图下的配置优先级高于VPN实例视图下的配置,即如果同时在VPN实例IPv6地址族视图和VPN实例视图下进行了配置,则IPv6 VPN采用VPN实例IPv6地址族视图下的配置。
# 限制名为vpn1的VPN实例最多可支持1000条激活路由前缀,并且当激活路由前缀数超过最多支持激活路由前缀数时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
rr-filter命令用来创建路由反射器的反射策略。
undo rr-filter命令用来恢复缺省情况。
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
路由反射器不会对反射的路由进行过滤。
BGP VPNv4地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~65535。
ext-comm-list-name:扩展团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的VPNv4路由进行过滤:只有接收的VPNv4路由通过扩展团体属性列表过滤时,路由反射器才会反射该路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 在BGP VPNv4地址族视图下,配置路由反射器只反射通过扩展团体属性列表10过滤的VPNv4路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
sham-link命令用来创建一条OSPF伪连接。
undo sham-link命令用来删除一条已有的OSPF伪连接,或者将指定OSPF伪连接的参数恢复为缺省值。
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | { { hmac-md5 | hmac-sha-256 | md5 } key-id | keychain | simple } | retransmit | trans-delay | ttl-security ] *
不存在OSPF伪连接。
OSPF区域视图
source-ip-address:OSPF伪连接的源IP地址。
destination-ip-address:OSPF伪连接的目的IP地址。
cost cost-value:伪连接开销,取值范围为1~65535,缺省值为1。
dead dead-interval:失效间隔,取值范围为1~32768,单位为秒,缺省值为40。建立伪连接的两个路由器上需要配置相同的dead-interval,且至少为hello-interval的4倍。
hello hello-interval:接口上发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10。建立伪连接的两个路由器上需要配置相同的hello-interval。
hmac-md5:HMAC-MD5验证模式。
hmac-sha-256:HMAC-SHA-256验证模式。
md5:MD5验证模式。
simple:简单验证模式。
key-id:MD5/HMAC-MD5验证字标识符,取值范围为1~255。
cipher:以密文方式设置密钥。
plain:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。对于简单验证模式,明文密钥为1~8个字符的字符串;密文密钥为33~41个字符的字符串。对于MD5/HMAC-MD5验证模式,明文密钥为1~16个字符的字符串;密文密钥为33~53个字符的字符串。对于HMAC-SHA-256验证模式,明文密钥为1~255个字符的字符串;密文密钥为33~373个字符的字符串。
keychain:使用keychain验证方式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
retransmit retrans-interval:接口上重传LSA报文的时间间隔,取值范围是1~3600,单位为秒,缺省值为5。
trans-delay delay:接口上延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
ttl-security hops hop-count:开启OSPF报文的GTSM(Generalized TTL Security Mechanism,通用TTL安全保护机制)安全检测功能,并指定允许接收来自OSPF伪连接邻居的报文所经过的路由器的最大跳数。hop-count表示最大跳数,取值范围为1~254。如果未指定本参数,GTSM安全检测功能处于关闭状态。
属于同一个VPN的两个Site之间存在一条区域内OSPF链路(backdoor链路)时,为了避免VPN流量总是通过backdoor链路转发而不走骨干网,可以在PE路由器之间建立OSPF伪连接,使经过MPLS VPN骨干网的路由也成为OSPF区域内路由,确保VPN流量通过骨干网转发。
可以使用MD5/HMAC-MD5/HMAC-SHA-256验证方式、简单验证方式或keychain验证方式对OSPF伪连接进行验证,但不能同时使用多种验证方式。使用MD5/HMAC-MD5/HMAC-SHA-256验证方式时,可配置多条MD5/HMAC-MD5/HMAC-SHA-256验证命令,但同一key-id只能配置一个验证字。
修改伪连接的OSPF MD5/HMAC-MD5/HMAC-SHA-256验证字的步骤如下:
(1)     为伪连接配置新的MD5/HMAC-MD5/HMAC-SHA-256验证字。此时若邻居设备尚未配置新的MD5/HMAC-MD5/HMAC-SHA-256验证字,便会触发MD5/HMAC-MD5/HMAC-SHA-256验证平滑迁移过程。在这个过程中,OSPF会发送分别携带各个MD5/HMAC-MD5/HMAC-SHA-256验证字的多份报文,使得无论邻居设备上是否配置新验证字都能验证通过,保持邻居关系。
(2)     在邻居设备上也配置相同的新MD5/HMAC-MD5/HMAC-SHA-256验证字。当本设备上收到邻居的携带新验证字的报文后,便会退出MD5/HMAC-MD5/HMAC-SHA-256验证平滑迁移过程。
(3)     在本设备和邻居上都执行undo sham-link命令删除旧的MD5/HMAC-MD5/HMAC-SHA-256验证字。建议不要为伪连接保留多个MD5/HMAC-MD5/HMAC-SHA-256验证字,每次MD5/HMAC-MD5/HMAC-SHA-256验证字修改完毕后,应当及时删除旧的验证字,这样可以防止与持有旧验证字的系统继续通信、减少被攻击的可能,还可以减少验证迁移过程对系统、带宽的消耗。
在OSPF伪连接使用keychain验证方式时:
·     OSPF伪连接在发送报文前,会先从keychain获取当前的有效发送key,根据该key的key-id、认证算法和认证密钥进行报文验证,如果当前不存在有效发送key,或者该key的key-id大于255,OSPF伪连接不会发送报文。
·     OSPF伪连接在收到报文后,会根据报文携带的key-id从keychain获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验。如果报文校验失败,或者根据报文中携带的key-id无法从keychain中获取到有效接收key,则该报文将被丢弃。
·     OSPF支持MD5、HMAC-MD5和HMAC-SHA-256认证算法,仅支持标识符取值范围为0~255的key。
开启OSPF报文的GTSM安全检测功能后,当设备在伪连接上收到OSPF报文时,会判断报文的TTL是否在255-“hop-count”+1到255之间。如果在,则上送报文;如果不在,则直接丢弃报文。以使设备避免受到CPU利用(CPU-utilization)类型的攻击(如CPU过载),增强系统的安全性。执行本命令后,设备会将发送报文的初始TTL设置为255。
同一VPN实例的不同OSPF进程下,不能配置源地址、目的地址都相同的伪连接。
两端PE上配置的伪连接必须属于相同的OSPF区域,否则,无法建立OSPF邻居。
开启GTSM功能时,要求本设备和邻居设备上同时支持本特性,指定的hop-count值可以不同,只要能够通过安全检测即可。
# 创建一条OSPF伪连接,源地址为1.1.1.1,目的地址为2.2.2.2。
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] sham-link 1.1.1.1 2.2.2.2
·     display ospf sham-link
snmp context-name命令用来配置VPN实例的SNMP上下文。
未配置VPN实例的SNMP上下文。
VPN实例视图
context-name:SNMP上下文名称,为1~32个字符的字符串,区分大小写。
对于支持多VPN实例的功能(如AAA),通过MIB(Management Information Base,管理信息库)节点对这些功能进行管理时,这些功能无法获知被管理的节点属于哪个VPN实例。为不同的VPN实例配置不同的SNMP上下文可以解决上述问题。
·     对于SNMPv3报文:
¡     如果报文中不携带上下文,则功能模块对公网的MIB节点进行相应处理。
¡     如果报文中携带上下文,设备上存在对应的SNMP上下文(通过系统视图下的snmp-agent context命令创建),且该上下文与为某一个VPN实例配置的上下文相同,则功能模块对该VPN实例的MIB节点进行相应处理。
¡     其他情况下,不允许对任何MIB节点进行处理。
·     对于SNMPv1/v2c报文:
¡     如果设备上未通过系统视图下的snmp-agent community-map命令将报文中的团体名映射为SNMP上下文,则功能模块对公网的MIB节点进行相应处理。
¡     如果设备上将团体名映射为SNMP上下文,设备上存在对应的SNMP上下文,且该上下文与为某一个VPN实例配置的上下文相同,则功能模块对该VPN实例的MIB节点进行相应处理。
SNMP上下文和团体名的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
为不同VPN实例配置的SNMP上下文不能相同。
在同一个VPN实例下重复执行本命令,则新的配置将覆盖已有配置。
# 配置VPN实例vpna的SNMP上下文为vpna。
[Sysname] snmp-agent context vpna
[Sysname-vpn-instance-vpna] route-distinguisher 22:33
[Sysname-vpn-instance-vpna] snmp context-name vpna
·     snmp-agent community-map(网络管理和监控命令参考/SNMP)
·     snmp-agent context(网络管理和监控命令参考/SNMP)
snmp-agent trap enable l3vpn命令用来开启L3VPN模块的告警功能。
undo snmp-agent trap enable l3vpn命令用来关闭L3VPN模块的告警功能。
L3VPN模块的告警功能处于开启状态。
开启L3VPN模块的告警功能后,在VPN实例内的路由数达到告警门限等情况下,L3VPN模块会产生RFC 4382中规定的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启L3VPN模块的告警功能。
[Sysname] snmp-agent trap enable l3vpn
1.1.41  tnl-policy
tnl-policy命令用来配置VPN实例与指定的隧道策略关联。
undo tnl-policy命令用来恢复缺省情况。
tnl-policy tunnel-policy-name
undo tnl-policy
VPN实例未关联隧道策略。
VPN实例视图
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
tunnel-policy-name:VPN实例的隧道策略名称,为1~19个字符的字符串,区分大小写。
在设备上配置VPN实例与隧道策略关联后,设备将根据指定的隧道策略选择转发该VPN实例流量的隧道。
如果VPN实例未关联隧道策略或者关联的隧道策略尚未配置,则该VPN实例根据缺省选择策略来选择隧道。缺省选择策略为按照LSP隧道->CRLSP隧道->SRLSP隧道->SR-TE Policy隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
# 将名为vpn1的VPN实例和隧道策略po1关联起来。
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
·     tunnel-policy(MPLS命令参考/隧道策略)
1.1.42  vpn popgo
vpn popgo命令用来将Egress PE上私网路由的标签操作方式配置为根据标签查找出接口转发。
undo vpn popgo命令用来恢复缺省情况。
vpn popgo
undo vpn popgo
Egress PE上私网路由的标签操作方式为根据标签查找FIB转发。
BGP实例视图
配置vpn popgo命令后,Egress PE会自动断开并重建与私网内BGP邻居之间的会话,重新学习私网路由。
配置vpn popgo命令后,Egress PE将报文转发给私网时,不支持在多个私网BGP邻居之间进行BGP负载分担。
# 在BGP实例视图下,将Egress PE上私网路由的标签操作方式定制为根据标签查找出接口转发。
[Sysname] bgp 100
[Sysname-bgp-default] vpn popgo
1.1.43  vpn-id
vpn-id命令用来配置VPN实例的ID。
undo vpn-id命令用来恢复缺省情况。
vpn-id vpn-id
undo vpn-id
未配置VPN实例的ID。
VPN实例视图
vpn-id:VPN实例的ID,取值为3~15个字符的字符串,取值形式为OUI:Index。其中,OUI(Organizationally Unique Identifier,全球统一标识符)的取值范围为十六进制数0~FFFFFF;Index的取值范围为十六进制数0~FFFFFFFF。
VPN ID是VPN实例的唯一标识,不同VPN实例的VPN ID不能相同。
VPN ID的取值不能为0:0。
# 配置VPN实例vpn1的ID为20:1。
[Sysname-vpn-instance-vpn1] vpn-id 20:1
·     display ip vpn-instance
1.1.44  vpn-peer
vpn-peer命令用来创建一个VPN peer。
undo vpn-peer命令用来删除指定的VPN peer。
vpn-peer vpn-peer-name vpn-peer-id vpn-peer-id user-profile profile-name
undo vpn-peer vpn-peer-name
不存在VPN peer。
vpn-peer-name:VPN peer的名称,为1~31个字符的字符串,区分大小写。
vpn-peer-id:VPN peer ID值,取值范围为1~134217727。
profile-name:表示关联的User Profile的名称,为1~31个字符的字符串,只能包含英文字母[a-z,A-Z]、数字、下划线,支持以英文字母或数字开头,但不能为纯数字,区分大小写。
在虚拟化网络中,位于不同区域的VPC(Virtual Private Cloud,虚拟私有云)之间通过MPLS L3VPN进行互通,互通的每两个VPC称为一个VPN对(VPN Peer)。
通过路由策略对报文进行标记,给FIB下发的路由信息中携带关联User Profile的VPN peer ID,报文转发时根据User Profile进行处理。
有关路由策略的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
有关User Profile的详细介绍,请参见“安全配置指导”中的“User Profile”。
# 创建一个名为vpn-010-020的VPN peer,其VPN peer ID值为1,关联的User Profile名称为UP010-020。
[Sysname] vpn-peer vpn-010-020 vpn-peer-id 1 user-profile UP010-020
·     apply vpn-peer-id(三层技术-IP路由命令参考/路由策略)
·     user-profile(安全命令参考/User Profile)
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到VPN实例的路由表中。
BGP实例视图
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
开启VPN引入等价路由功能后,BGP可以把前缀和RD均相同的多条路由全部引入到VPN实例的路由表中,以便在这些路由之间进行负载分担或MPLS L3VPN快速重路由。
# 在BGP-VPN IPv4单播地址族视图下开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] vpn-route cross multipath
1.1.46  vpn-target
vpn-target命令用来配置VPN实例的Route Target。
undo vpn-target命令用来删除VPN实例的Route Target。
未配置VPN实例的Route Target。
VPN实例视图
VPN实例IPv4地址族视图
IPv4 Flowspec VPN视图
VPN实例IPv6地址族视图
公网实例视图
公网实例IPv4地址族视图
公网实例IPv6地址族视图
vpn-target&<1-8>:指定Route Target值。vpn-target为3~21个字符的字符串,取值为AS-number:nn或IP-address:nn。&<1-8>表示前面的参数最多可以输入8次。
Route Target有三种格式:
both:指定配置的Route Target值同时作为Import Target和Export Target。如果未指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
Route Target用来控制VPN路由的发布。PE在发布的VPN路由中添加Route Target扩展团体属性,该属性的值为配置的Export Target。对端PE接收到VPN路由后,将路由中携带的Route Target属性与本地配置的VPN实例的Import Target进行比较,如果二者中存在相同的值,则将该路由学习到该VPN实例的路由表中。
VPN实例/公网实例视图下的配置对所有地址族有效,地址族视图下的配置只能用于对应地址族。对于指定地址族,优先使用该地址族视图内的配置。只有该地址族视图内未配置时,才采用VPN实例/公网实例视图下的配置。
重复执行本命令,VPN实例的Route Target值为多次配置结果的集合。
# 为名为vpn1的VPN实例配置Route Target。
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
