12-语音命令参考
02-语音用户线命令
本章节下载: 02-语音用户线命令  (584.76 KB)
02-语音用户线命令
1 语音用户线配置命令
1.1 模拟语音用户线配置命令
1.1.1 area
1.1.2 audio-input-gain
1.1.3 audio-mute
1.1.4 audio-output-gain
1.1.5 busytone-hookon timer
1.1.6 busytone-t-th
1.1.7 calling-name
1.1.8 cid display
1.1.9 cid receive
1.1.10 cid ring
1.1.11 cid send
1.1.12 cid type
1.1.13 cng-on
1.1.14 cptone country-type
1.1.15 cptone tone-type
1.1.16 default
1.1.17 default subscriber-line
1.1.18 delay hold
1.1.19 delay rising
1.1.20 delay send-dtmf
1.1.21 delay send-wink
1.1.22 delay wink-hold
1.1.23 delay wink-rising
1.1.24 delay start-dial
1.1.25 description (Voice subscriber-line view)
1.1.26 disconnect lcfo
1.1.27 display voice subscriber-line
1.1.28 dtmf amplitude
1.1.29 dtmf sensitivity-level
1.1.30 dtmf time
1.1.31 dtmf threshold
1.1.32 echo-canceller
1.1.33 echo-canceller parameter
1.1.34 em-phy-parm
1.1.35 em-signal
1.1.36 em-passthrough
1.1.37 hookoff-mode
1.1.38 hookoff-mode delay bind
1.1.39 hookoff-time
1.1.40 impedance
1.1.41 nlp-on
1.1.42 open-trunk
1.1.43 plc-mode
1.1.44 receive gain
1.1.45 reset voice cmc statistic
1.1.46 reset voice ipp statistic
1.1.47 reset voice iva statistic
1.1.48 ring-detect debounce
1.1.49 ring-detect frequency
1.1.50 send-busytone
1.1.51 shutdown (Voice subscriber-line view)
1.1.52 silence-th-span
1.1.53 slic-gain
1.1.54 subscriber-line
1.1.55 timer dial-interval
1.1.56 timer disconnect-pulse
1.1.57 timer first-dial
1.1.58 timer hookflash-detect
1.1.59 timer hookoff-interval
1.1.60 timer ring-back
1.1.61 timer wait-digit
1.1.62 transmit gain
1.1.63 type
1.1.64 vi-card cptone-custom
1.1.65 vi-card busy-tone-detect
1.1.66 vi-card reboot
1.1.67 mirror(模拟语音用户线视图)
1.1.68 amd enable
1.1.69 amd parameter
1.1.70 ani
1.1.71 ani-offset
1.1.72 answer enable
1.1.73 callmode
1.1.74 cas
1.1.75 clear-forward-ack enable
1.1.76 display voice subscriber-line
1.1.77 dl-bits
1.1.78 dtmf enable
1.1.79 dtmf threshold digital
1.1.80 enable snmp trap updown
1.1.81 final-callednum enable
1.1.82 force-metering enable
1.1.83 group-b enable
1.1.84 link-delay
1.1.85 line
1.1.86 mode
1.1.87 pcm
1.1.88 posa called-length
1.1.89 pri-set
1.1.90 qsig-tunnel enable
1.1.91 re-answer enable
1.1.92 register-value
1.1.93 renew
1.1.94 reverse
1.1.95 seizure-ack enable
1.1.96 select-mode
1.1.97 sendring ringbusy enable
1.1.98 signal-value
1.1.99 special-character
1.1.100 subscriber-line
1.1.101 tdm-clock
1.1.102 timer dl
1.1.103 timer dtmf
1.1.104 timer hold
1.1.105 timer register-pulse persistence
1.1.106 timer register-complete group-b
1.1.107 timer ring
1.1.108 timeslot-set
1.1.109 trunk-direction
1.1.110 ts
1.1.111 mirror(数字语音用户线视图)
1 语音用户线配置命令
1.1  模拟语音用户线配置命令
在本章中,语音用户线视图表示数字用户线和模拟用户线。
1.1.1  area
area { custom | europe | north-america }
undo area
语音视图
【缺省级别】
2:系统级
custom:用户自定义的忙音类型。
europe:符合欧洲标准的忙音类型。
north-america:符合北美标准的忙音类型。
【描述】
area命令用来配置FXO语音用户线检测忙音的类型。undo area命令用来恢复缺省情况。
缺省情况下,使用欧洲标准的忙音类型。
此条命令只用于二线环路中继接口FXO,此命令一旦配置,对设备上的所有模拟FXO类型语音单板都起作用。
当FXO语音单板接程控交换机的普通用户线时,如果交换机一侧的用户首先挂机,路由器需要检测忙音才能得知用户的挂机操作,由于不同的交换机执行不同的提示音方案,因此存在不同的频谱特性,使用此命令可以配置路由器使用何种频谱特性来检测忙音的存在。
# 配置符合北美标准的忙音类型。
[Sysname] voice-setup
[Sysname-voice] area north-america
audio-input-gain value
undo audio-input-gain
MOH语音用户线视图
【缺省级别】
2:系统级
value:音频输入增益,取值范围为19.5~41.5,步长为2,单位为dB。
【描述】
audio-input-gain命令用来配置接口输入增益值。undo audio-input-gain命令用来恢复情况。
缺省情况下,接口输入端的增益值为27.5dB。
调整增益大小可能会导致输入的音频质量下降。建议不要随意调整增益大小,如果确实有需要,请在技术人员指导下进行。
# 在MOH语音用户线1/1上,配置音频输入增益为23.5dB。
[Sysname] subscriber-line 1/1
[Sysname-subscriber-line1/1] audio-input-gain 23.5
1.1.3  audio-mute
audio-mute
undo audio-mute
MOH/PAGE语音用户线视图
【缺省级别】
2:系统级
无
【描述】
audio-mute命令用来将指定音频接口配置为静音状态。undo audio-mute命令用来恢复缺省情况。
缺省情况下,音频接口处于工作状态。
配置audio-mute命令后会使音频接口处于静音状态,将导致音频接口无法进行数据传输。
# 在PAGE语音用户线1/0上,配置音频接口为静音状态。
[Sysname] subscriber-line 1/0
[Sysname-subscriber-line1/0] audio-mute
audio-output-gain value
undo audio-output-gain
PAGE语音用户线视图
【缺省级别】
2:系统级
value:音频输出增益,取值范围为-24.0~12.0,步长为1,单位为dB。
【描述】
audio-output-gain命令用来配置接口输出增益值。undo audio-output-gain命令用来恢复缺省情况。
缺省情况下,接口输出端的增益值为-10.0dB。
当输出线路上音频信号功率较小时,可以使用本命令适当增大音频输出增益值以适应输出线路信号要求。
调整增益大小可能会导致输出的音频质量下降。建议不要随意调整增益大小,如果确实有需要,请在技术人员指导下进行。
# 在PAGE语音用户线2/0上,配置音频输出增益为-6.0dB。
[Sysname] subscriber-line 2/0
[Sysname-subscriber-line2/0] audio-output-gain -6.0
busytone-hookon timer seconds
undo busytone-hookon timer
模拟FXO语音用户线视图
【缺省级别】
2:系统级
seconds:忙音检测挂机延迟时间,取值范围为0~30,单位为秒。
【描述】
busytone-hookon timer命令配置FXO检测到忙音后,到挂机的延迟时间。
undo busytone-hookon timer命令用来恢复缺省情况。
缺省情况下,忙音检测挂机延迟时间为0秒。
通常FXO接口检测到线路忙音后,会自动挂机,完成线路拆除。在作为VOIP接入端口与IPPhone配合使用时,由于IPPhone拆线后不对本地放提示音,当FXO检测到忙音挂机拆线较快时,IPPhone用户容易忽略忙音,误认为线路出现异常。通过配置忙音检测挂机延迟时间,FXO检测到忙音后延迟一段时间后再挂机拆线,此时输入FXO的忙音会继续传到IPPhone,IPPhone用户容易对忙音信息进行确认。
# 配置忙音检测挂机延迟时间为5秒。
[Sysname] subscriber-line 5/0
[Sysname-subscriber-line5/0] busytone-hookon timer 5
1.1.6  busytone-t-th
busytone-t-th time-threshold
undo busytone-t-th
模拟FXO语音用户线视图
【缺省级别】
2:系统级
time-threshold:忙音检测的时间阈值,即忙音检测的周期数,周期数越多检测时间越长。取值范围为2~12。
【描述】
busytone-t-th命令配置忙音检测的时间阈值。undo busytone-t-th命令用来恢复缺省情况。
缺省情况下,忙音检测的时间阈值为2。
在某些特定情况下,由于实际的忙音数据与系统配置的忙音参数不能完全匹配,如果差距较大可能导致忙音检测不准确,会产生挂不断或误挂机等问题,通过调整DSP忙音检测的时间,从而达到更准确的检测忙音的目的。
通过调整忙音检测时间阈值,增加系统进行忙音检测的时间,可以增加忙音检测的准确性,这对由于忙音数据不准确导致误挂机能够一定程度上进行改善,但可能会使挂不断的情形加剧。
使用该命令改变忙音检测时间阈值时一定要多次长时间测试后,确认能够正常挂机后方可采用。
# 设置忙音检测的时间阈值为3。
[Sysname-subscriber-line1/0] busytone-t-th 3
1.1.7  calling-name
calling-name text
undo calling-name
模拟FXS语音用户线视图
【缺省级别】
2:系统级
text:该FXS用户线关联的主叫用户名,为1~50个字符、区分大小写。字符串中可以包括空格 、0-9,a-z,A-Z、_、-、.、!、%、*、+、`、'及~。
【描述】
calling-name命令用来配置主叫用户名。undo calling-name命令用来删除主叫用户名。
缺省模式下没有配置主叫用户名。
# 在FXS语音用户线1/0上配置主叫用户名为tony。
[Sysname-subscriber-line1/0] calling-name tony
1.1.8  cid display
cid display
undo cid display
模拟FXS语音用户线视图
【缺省级别】
2:系统级
无
【描述】
cid display命令用来启动模拟FXS语音用户线主叫信息(包括主叫号码和主叫用户名)显示功能。undo cid display命令用来取消主叫信息显示功能。
缺省情况下,模拟FXS语音用户线启动显示主叫信息功能。
# 在语音用户线1/0上显示主叫信息功能。
[Sysname-subscriber-line1/0] cid display
1.1.9  cid receive
cid receive
undo cid receive
模拟FXO语音用户线视图
【缺省级别】
2:系统级
无
【描述】
cid receive命令用来启动主叫信息识别(CID)功能。undo cid receive命令用来禁止主叫信息识别功能。
缺省情况下,主叫信息识别功能处于开启状态。
需要注意的是,当配置了undo cid receive后,如果主叫方发送了主叫号码并且本地的FXO口对应的实体上也配置了号码,就以此号码代替主叫侧发送的号码作为主叫号码发送到被叫侧。如果FXO口对应语音实体的号码匹配模板配置的是通配符“.”,则以“0”代替,如“1…”转换为“1000”。
# 在语音用户线1/0上启动主叫信息识别功能。
[Sysname-subscriber-line1/0] cid receive
1.1.10  cid ring
cid ring { 0 | 1 | 2 } [ times ]
undo cid ring
模拟FXO语音用户线视图
【缺省级别】
2:系统级
0:表示振铃前进行CID检测。
1:表示第一声和第二声振铃间进行CID检测。
2:表示第二声和第三声振铃间进行CID检测。
times:CID检测完毕后到摘机前的振铃次数,取值范围为0~5,缺省值为0。取值越大,FXO摘机应答时间越长。
【描述】
cid ring命令用来配置检测CID的时间和CID检测完毕后的振铃次数。undo cid ring命令用来恢复缺省情况。
缺省配置下,在第一声和第二声振铃间进行检测CID,CID检测完毕后FXO会立即摘机应答,即cid ring 1 0。
# 在语音用户线1/0上配置振铃前进行CID检测。
[Sysname-subscriber-line1/0] cid ring 0
1.1.11  cid send
cid send
undo cid send
模拟FXS/FXO语音用户线视图
【缺省级别】
2:系统级
无
【描述】
cid send命令用来启动FXS/FXO语音用户线向远端发送主叫信息。undo cid send命令用来禁止向远端发送主叫信息。
缺省情况下,FXS/FXO语音用户线启动向远端发送主叫信息。
需要注意的是,在FXO语音用户线下配置了undo cid send命令后,则不论主叫侧是否发送了主叫号码,以及本地的FXO语音用户线对应的语音实体上是否配置了号码,FXO语音用户线都不会把主叫号码信息发送到被叫侧。
# 在语音用户线1/0上禁止向IP侧发送主叫信息功能。
[Sysname-subscriber-line1/0] undo cid send
1.1.12  cid type
cid type { complex | simple }
undo cid type
模拟FXS语音用户线视图
【缺省级别】
2:系统级
complex:主叫信息采用复合格式。
simple:主叫信息采用简单格式。
【描述】
cid type命令用来配置模拟FXS语音用户线发送主叫信息时所采用的消息格式。undo cid type命令用来恢复缺省情况。
缺省情况下,模拟FXS语音用户线发送主叫信息时采用复合格式。
·              当对端设备只能支持两种格式中一种的时候,就需要调整本端用户线的格式,保证两端设备采用一致的格式。
·              主叫信息中的主叫用户名只能通过复合格式发送。
# 在语音用户线1/0上发送主叫信息使用简单格式。
[Sysname-subscriber-line1/0] cid type simple
1.1.13  cng-on
cng-on
undo cng-on
FXS/FXO/E&M/BSV语音用户线视图
【缺省级别】
2:系统级
无
【描述】
cng-on命令用来启用舒适噪音功能。undo cng-on命令用来禁止舒适噪音功能。
缺省情况下,舒适噪音处于开启状态。
命令cng-on用于使能舒适噪音配置。使用该命令可以产生适当的背景噪音以填充通话过程中的静音间隙。如果不产生舒适噪音,那么通话中的静音间隙将会使通话者感到不安。
相关配置可参考命令line和vad-on。
# 在语音用户线1/0上禁止舒适噪音功能。
[Sysname-subscriber-line1/0] undo cng-on
cptone country-type locale
undo cptone country-type
语音视图
【缺省级别】
2:系统级
country-type locale:将提示音设置为指定的国家或地区模式。目前支持65种提示音。
表1-1 提示音对应的国家模式
提示音模式
国家名(包括自定义方式)
AR
Argentina 阿根廷
AU
Australia 澳大利亚
AT
Austria 奥地利
BE
Belgium 比利时
BR
Brazil 巴西
BG
Bulgaria 保加利亚
CA
Canada 加拿大
CL
Chile 智利
CN
China 中国
HR
Croatia 克罗地亚
CU
Cuba 古巴
CS
Custom 自定义
CY
Cyprus 塞浦路斯
CZ
Czech Republic 捷克
DK
Denmark 丹麦
EG
Egypt 埃及
FI
Finland 芬兰
FR
France 法国
DE
Germany 德国
GH
Ghana 加纳
GR
Greece 希腊
HK
Hong Kong China 中国香港
HU
Hungary 匈牙利
IS
Iceland 冰岛
IN
India 印度
ID
Indonesia 印度尼西亚
IR
Iran 伊朗
IE
Ireland 爱尔兰
IEU
Ireland(UK style) 爱尔兰(英国模式)
IL
Israel 以色列
IT
Italy 意大利
JP
Japan 日本
JO
Jordan 约旦
KE
Kenya 肯尼亚
KR
Korea Republic 韩国
LB
Lebanon 黎巴嫩
LU
Luxembourg 卢森堡
MO
Macau 澳门
MY
Malaysia 马来西亚
MX
Mexico 墨西哥
NP
Nepal 尼泊尔
NL
Netherlands 荷兰
NZ
New Zealand 新西兰
NG
Nigeria 尼日利亚
NO
Norway 挪威
PK
Pakistan 巴基斯坦
PA
Panama 巴拿马
PH
Philippines 菲律宾
PL
Poland 波兰
PT
Portugal 葡萄牙
RU
Russian Federation 俄罗斯
SA
Saudi Arabia 沙特阿拉伯
SG
Singapore 新加坡
SK
Slovakia 斯洛伐克
SI
Slovenia 斯洛文尼亚
ZA
South Africa 南非
ES
Spain 西班牙
SE
Sweden 瑞典
CH
Switzerland 瑞士
TH
Thailand 泰国
TR
Turkey 土耳其
GB
United Kingdom 英国
US
United States 美国
UY
Uruguay 乌拉圭
ZW
Zimbabwe 津巴布韦
【描述】
cptone country-type命令用来将当前设备播放的呼叫提示音设置为指定的国家模式或自定义模式。undo cptone country-type命令用来恢复缺省情况。
缺省情况下,提示音的国家模式为中国。
cptone country-type CS命令代表自定义提示音模式(不是国家模式),该命令是和自定义提示音参数命令配合起来使用的。使用vi-card cptone-custom命令配置了提示音参数后,这些参数并未立即生效,需要在语音视图下运行cptone country-type CS命令,手动配置的呼叫提示音参数才能生效。
相关配置可参考命令vi-card cptone-custom。
配置此命令时将对设备上所有单板的所有语音接口生效。
# 配置呼叫提示音模式为美国模式。
<sysname> system-view
[sysname] voice-setup
[sysname-voice] cptone country-type us
cptone tone-type { all | busy-tone | congestion-tone | dial-tone | ringback-tone | special-dial-tone | waiting-tone } amplitude value
undo cptone tone-type { all | busy-tone | congestion-tone | dial-tone | ringback-tone | special-dial-tone | waiting-tone } amplitude
语音视图
【缺省级别】
2:系统级
all:所有类型的提示音。
busy-tone:忙音。
congestion-tone:拥塞音。
dial-tone:拨号音。
ringback-tone:回铃音。
special-dial-tone:特殊拨号音。
waiting-tone:呼叫等待音。
amplitude value:配置提示音幅度,取值范围为200~1500。
【描述】
cptone tone-type命令用来配置指定提示音的幅度值。undo cptone tone-type命令用来恢复缺省情况。
缺省情况下,忙音和拥塞音类型的幅度值为1000,拨号音和特殊拨号音类型的幅度值为400,回铃音和呼叫等待音类型的幅度值为600。
# 配置忙音的电平幅度为1200。
[sysname-voice] cptone tone-type busy-tone amplitude 1200
1.1.16  default
default
语音用户线视图
【缺省级别】
2:系统级
无
【描述】
default命令用来恢复语音用户线的缺省配置。
# 将语音用户5/0恢复为缺省配置。
[Sysname-subscriber-line5/0] default
This command will restore the default settings. Continue? [Y/N]:y
default subscriber-line { receive | transmit } gain value
undo default subscriber-line { receive | transmit } gain
语音视图
【缺省级别】
2:系统级
receive gain:配置所有语音用户线输入增益的缺省值。
transmit gain:配置所有语音用户线输出增益的缺省值。
value:表示语音用户线输入/输出增益值,取值范围是-14.0~13.9(取值时小数点后仅保留1位),单位是dB,缺省值为0。
【描述】
default subscriber-line命令用来配置所有语音用户线输入/输出增益的缺省值。undo default subscriber-line命令用来恢复所有语音用户线输入/输出增益的缺省值。
当输入/输出线路上需要的语音信号功率较小时,可以使用该命令适当增大语音输入/输出增益值以适应输入/输出线路信号要求。
相关配置可参考命令transmit gain和receive gain。
# 配置所有语音用户线输入增益值为9.0。
[Sysname-voice] default subscriber-line receive gain 9.0
1.1.18  delay hold
delay hold milliseconds
undo delay hold
E&M语音用户线视图
【缺省级别】
2:系统级
hold milliseconds:延时启动方式时,延时占用信号的持续时间,取值范围为100~5000,单位为毫秒。
【描述】
delay hold命令用来配置延时启动时,延时占用信号的持续时间。undo delay hold命令用来恢复缺省情况。
缺省情况下,延时占用信号的持续时间为400毫秒。
相关配置可参考命令em-signal。
# 配置在延时启动方式时,延时占用信号的持续时间为500毫秒。
[Sysname-subscriber-line5/0] em-signal delay
[Sysname-subscriber-line5/0] delay hold 500
1.1.19  delay rising
delay rising milliseconds
undo delay rising
E&M语音用户线视图
【缺省级别】
2:系统级
rising milliseconds:延时启动方式时,被叫端检测到占用信号到发送延时占用信号前的延时时间,取值范围为20~2000,单位为毫秒。
【描述】
delay rising命令用来配置延时启动时,被叫端检测到占用信号到发送延时占用信号前的延时时间。undo delay rising命令用来恢复缺省情况。
缺省情况下,被叫端检测到占用信号到发送延时占用信号前的延时时间为300毫秒。
相关配置可参考命令em-signal。
# 配置在延时启动方式时,被叫端检测到占用信号到发送延时占用信号前的延时时间为700毫秒。
[Sysname-subscriber-line5/0] delay rising 700
delay send-dtmf milliseconds
undo delay send-dtmf
E&M语音用户线视图
【缺省级别】
2:系统级
send-dtmf milliseconds:立即启动方式时,主叫端发送DTMF号码前的延迟时间,取值范围为50~5000,单位为毫秒。
【描述】
delay send-dtmf命令用来配置在立即启动方式时,主叫端发送DTMF号码前的延迟时间。undo delay send-dtmf命令用来恢复缺省情况。
缺省情况下,主叫端发送DTMF号码前的延迟时间为300毫秒。
相关配置可参考命令em-signal。
# 配置在立即启动方式下,主叫端发送DTMF号码前的延迟时间为3000毫秒。
[Sysname-subscriber-line5/0] delay send-dtmf 3000
delay send-wink milliseconds
undo delay send-wink
E&M语音用户线视图
【缺省级别】
2:系统级
send-wink milliseconds:闪断启动方式时,被叫端收到占用信号到发送闪断(wink)信号的延迟时间,取值范围为100~5000,单位为毫秒。
【描述】
delay send-wink命令用来配置闪断启动时,配置被叫端收到占用信号到发送闪断(wink)信号的延迟时间。undo delay send-wink命令用来恢复缺省情况。
缺省情况下,被叫端收到占用信号到发送闪断(wink)信号的延迟时间为200毫秒。
相关配置可参考命令em-signal。
# 配置在闪断启动方式时,被叫端收到占用信号到发送闪断(wink)信号的延迟时间为700毫秒。
[Sysname-subscriber-line5/0] em-signal wink
[Sysname-subscriber-line5/0] delay send-wink 700
delay wink-hold milliseconds
undo delay wink-hold
E&M语音用户线视图
【缺省级别】
2:系统级
wink-hold milliseconds:闪断启动方式时,被叫端发送闪断信号的持续时间,取值范围为100~3000,单位为毫秒。
【描述】
delay wink-hold命令用来配置闪断启动方式时,被叫端发送闪断信号的持续时间。undo delay wink-hold命令用来恢复缺省情况。
缺省情况下,被叫端发送闪断信号的持续时间为500毫秒。
# 配置在闪断启动方式时,被叫端发送闪断信号的持续时间为700毫秒。
[Sysname-subscriber-line5/0] delay wink-hold 700
delay wink-rising milliseconds
undo delay wink-rising
E&M语音用户线视图
【缺省级别】
2:系统级
wink-rising milliseconds:闪断启动方式时,主叫端发送占用信号后等待闪断(wink)信号的最大持续时间,取值范围为100~5000,单位为毫秒。
【描述】
delay wink-rising命令用来配置闪断启动时,主叫端发送占用信号后等待闪断(wink)信号的最大持续时间。undo delay wink-rising命令用来恢复缺省情况。
缺省情况下,主叫端发送占用信号后等待闪断(wink)信号的最大持续时间为2000毫秒。
# 配置在闪断启动方式时,主叫端发送占用信号后等待闪断(wink)信号的最大持续时间为2000毫秒。
[Sysname-subscriber-line5/0] delay wink-rising 2000
delay start-dial seconds
undo delay start-dial
FXS/FXO语音用户线视图
【缺省级别】
2:系统级
seconds:延时拨号的时间,取值范围为0~10,单位为秒。
【描述】
delay start-dial命令用来配置延时拨号的时间。undo delay start-dial命令用来恢复缺省情况。
缺省情况下,延时拨号的时间为1秒。
# 配置FXS语音用户线line1/0上的延时拨号时间为5秒。
[Sysname-subscriber-line1/0] delay start-dial 5
description string
语音用户线视图
【缺省级别】
2:系统级
string:语音用户线描述字符串,取值范围为1~80个字符。
【描述】
description命令用来配置语音用户线描述字符串。undo description命令用来删除语音用户线描述字符串。
缺省情况下,语音用户线的描述字符串为“该接口的接口名 Interface”。
通过description命令对语音用户线进行描述性说明。这一操作不会对语音实体的运行造成任何影响,只有在执行display命令时才会看到配置的信息。
# 标识语音用户线1/0为lab_1。
[Sysname-subscriber-line1/0] description lab_1
disconnect lcfo
undo disconnect lcfo
FXS语音用户线视图
【缺省级别】
2:系统级
无
【描述】
disconnect lcfo命令用来使能FXS语音用户线挂机脉冲信号发送功能。undo disconnect lcfo命令用来禁止FXS语音用户线挂机脉冲信号发送功能。
缺省情况下,禁止FXS语音用户线发送挂机脉冲信号,即直接播放忙音。
# 在FXS语音用户线5/1上,配置使能 FXS语音用户线发送挂机脉冲信号。
[Sysname] subscriber-line 5/1
[Sysname-subscriber-line5/1] disconnect lcfo
display voice subscriber-line line-number [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
line-number:语音用户线号。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display voice subscriber-line命令用来显示语音用户线的配置信息,包括语音用户线的类型、状态、编解码方式、以及输入和输出增益等信息。
相关配置可参考命令subscriber-line。
具体的显示信息与实际使用的板卡类型有关,请以设备实际情况为准。
# 显示E&M语音用户线5/0的配置信息。
<Sysname> display voice subscriber-line 5/0
  Current information  -----  subscriber-line5/0
    Type                        = Analog E&M Immediate-Start
    Status                      = UP
    Call Status                 = BUSYTONE
    Description                 = subscriber-line5/0 Interface
    Private Line                = None
    Cng                         = Enable
    Echo Canceller              = Enable
    Echo Canceller Tail-Length  = 32
    Nlp On                      = Enable
    Receive Gain                = 0.0
    Transmit Gain               = 0.0
    DTMF Threshold Analogue :
        Index  0                = 1400
        Index  1                = 458
        Index  2                = -9
        Index  3                = -9
        Index  4                = -9
        Index  5                = -9
        Index  6                = -3
        Index  7                = -12
        Index  8                = -12
        Index  9                = 30
        Index 10                = 300
        Index 11                = 3200
        Index 12                = 375
    Timer Dial-Interval         = 10
    Timer Wait-Digit            = 5
    Timer Ring-Back             = 60
    Delay Send-dtmf             = 300
    E&M Physical Wire           = 4-Wire
    E&M Type                    = V
    Slic-Gain                   = 0.8 db
    Physical Information :
        Card Type               = E&M
        Physical State          = 1
        Logical State           = 1
        Voice State             = Uninstall
        ResetCount              = 0
        InPkts                  = 0
        OutPkts                 = 0
        InBytes                 = 0
        OutBytes                = 0
        LastRcvPacketLen        = 0
        LastSndPacketLen        = 0
        CmdInBuff               = 0
        CmdInTotalBuff          = 0
        DataInBuff              = 0
        DataInTotalBuff         = 0
        AbortCmdCount           = 0
        AbortPktsCount          = 0
        G723R53ToR63Packet      = 0
        G723R63ToR53Packet      = 0
        ClearDspBuffCount       = 0
表1-2 display voice subscriber-line命令显示信息描述表
语音用户线的类型
Status
语音用户线的状态
Call Status
语音用户线呼叫状态
语音用户线描述
Private-line
语音用户线的专线拨号号码
CNG
语音用户线的舒适噪音配置
EchoCancel
语音用户线的回波持续时间配置
Nlp-on
语音用户线的回波抵消非线性处理配置
Receive gain
语音用户线的输入增益配置
Transmit gain
语音用户线的输出增益配置
模拟语音用户线的DTMF信号参数
Timer Dial-Interval
语音用户线等待号码的时间间隔
Timer Wait-Digit
语音用户线等待号码的超时时间
Timer Ring-Back
语音用户线发送回铃音的超时时间
Delay Send-dtmf
语音用户线预拨号延时时间
E&M Physical Wire
模拟E&M类型语音接口的线缆类型
E&M Type
模拟E&M类型语音接口的线路类型
Slic-Gain
模拟E&M类型语音接口的slic芯片增益配置
物理统计信息
Card Type
语音板卡类型
Physical State
语音接口物理状态
Logical State
语音接口逻辑状态
Voice State
语音接口语音呼叫状态
ResetCount
语音接口单板复位计数
InPkts
语音接口接收语音包数
OutPkts
语音接口发送语音包数
InBytes
语音接口接收语音包字节数
OutBytes
语音接口发送语音包字节数
LastRcvPacketLen
语音接口最后接收语音包包长
LastSndPacketLen
语音接口最后发送语音包包长
CmdInBuff
语音接口命令缓冲区命令计数
CmdInTotalBuff
语音接口所在单板命令缓冲区中总的命令计数
AbortCmdCount
语音接口丢弃命令包计数
AbortPktsCount
语音接口丢弃数据包计数
G723R53ToR63Packet
语音接口G723R53编解码到R63转换包数
G723R63ToR53Packet
语音接口G723R63编解码到R53转换包数
ClearDspBuffCount
语音接口清除DSP解码缓冲区计数
dtmf amplitude value
undo dtmf amplitude
语音视图
【缺省级别】
2:系统级
value:用来指定DTMF拨号音的幅值,取值范围为-9.0~-7.0,单位为dBm。
【描述】
dtmf amplitude命令用来配置DTMF拨号音的幅值。undo dtmf amplitude命令用来恢复缺省情况。
缺省情况下,DTMF拨号音的幅值为-9.0dBm。
需要注意的是,该命令一旦配置,对整个设备都起作用。
# 配置DTMF拨号音的幅值为-8.0dBm。
[Sysname-voice] dtmf amplitude -8.0
dtmf sensitivity-level { high | low | medium [ frequency-tolerance value ] }
undo dtmf sensitivity-level
模拟FXS/FXO语音用户线视图
【缺省级别】
2:系统级
high:DTMF拨号音检测灵敏度为高级,可靠性较低,此模式可能出现DTMF拨号音误检的情况。
low:DTMF拨号音检测灵敏度为低级,可靠性较高,此模式可能出现DTMF拨号音漏检的情况。
medium:DTMF拨号音检测灵敏度为中级。本参数的支持情况与实际使用的板卡有关。
frequency-tolerance value:中级检测灵敏度时允许的绝对频率偏差,取值范围为1.0~5.0,单位百分比,缺省值为2。取值越大,误检概率越大。
【描述】
dtmf sensitivity-level命令用来配置DTMF拨号音检测灵敏度等级。undo dtmf sensitivity-level命令用来恢复缺省情况。
缺省情况下,DTMF拨号音检测灵敏度为低级。
ICG系列信息通信网关各款型对于本节所描述的命令及参数的支持情况有所不同,详细差异信息如下:
参数
ICG 2000B
ICG 2000
ICG 2200
ICG 3000B
ICG 3000S
ICG 3000
ICG 5000B
ICG 5000
medium
支持该参数的语音模块包括:
·       SIC-2FXS1FXO
·       MIM-8FXS8FXO
·       MIM-16FXS
·       FIC-24FXS
·       DFIC-24FXO24FXS
# 配置语音用户线1/0的DTMF拨号音检测灵敏度为高级。
[Sysname-subscriber-line1/0] dtmf sensitivity-level high
1.1.30  dtmf time
dtmf time { interval | persist } milliseconds
undo dtmf time { interval | persist }
语音视图
【缺省级别】
2:系统级
persist:发送DTMF拨号音的持续时间。
interval:发送DTMF拨号音的间隔时间。
milliseconds:指定时间参数值,取值范围为50~500,单位为毫秒。
【描述】
dtmf time命令用来配置发送DTMF拨号音的相关时间参数。undo dtmf time命令用来恢复缺省情况。
缺省情况下,发送DTMF拨号音的持续时间和发送间隔时间都为120毫秒。
# 配置DTMF拨号音的持续时间为200毫秒,发送间隔为300毫秒。
[Sysname-voice] dtmf time persist 200
[Sysname-voice] dtmf time interval 300
dtmf threshold analog index value
undo dtmf threshold analog index
模拟FXS/FXO/E&M语音用户线视图
【缺省级别】
2:系统级
analog:模拟语音用户线。
index:对应于阈值的索引号,取值范围为0~12间的整数。
value:表示相应索引下的具体阈值,取值范围与索引号index的取值有关,具体请参见表1-3索引号的含义介绍。
DTMF拨号音检测根据输入的语音信号在4个行频率和4个列频率上的能量,以及它们的二倍频上的能量来判断输入的DTMF号码是否是一个有效的DTMF拨号音。
记输入信号在行频组上的最大能量值为ROWMAX,其对应的二倍频能量为ROW2nd,在列频率组上的能量最大值为COLMAX,其对应的二倍频能量为COL2nd。
表1-3 配置DTMF拨号音检测
索引号
含义
取值范围
0
与检测输入的DTMF号码强度有关。输入信号要被识别为DTMF号码必须满足(ROWMAX+COLMAX)>0,否则视为信号强度不足
取值范围为1~4999,缺省值为1400
取值越大检测可靠性越高,但灵敏度会下降
1
与检测输入的DTMF号码之间的停顿有关。一个DTMF号码在被检测到之后,只有满足max(ROWMAX,COLMAX)<1时,才能认为这个号码已经停止
取值范围为1~4999,缺省值为458
取值越小检测可靠性越高,但灵敏度会下降
2
当COLMAX<ROWMAX时,输入信号要被识别为DTMF号码,必须满足10×(COLMAX/ROWMAX)>2
取值范围为-18~-3,单位为dB,缺省值为-9
取值越大检测可靠性越高,但灵敏度会下降
3
功能基本与上一个参数相同,当COLMAX>=ROWMAX时,必须满足10×(ROWMAX/COLMAX)>2
取值越小检测可靠性越高,但灵敏度会下降
4
行频率组里的能量次大者与ROWMAX的比值的上限。输入信号要被识别为DTMF号码,其对应的比值必须小于此门限
取值越小检测可靠性越高,但灵敏度会下降
5
列频率组里的能量次大者与COLMAX的比值的上限。输入信号要被识别为DTMF号码,其对应的比值必须小于此门限
取值越小检测可靠性越高,但灵敏度会下降
6
(ROW2nd/ROWMAX)比值的上限。输入信号要被识别为DTMF号码,必须满足(ROW2nd/ROWMAX)<6
取值范围为-18~-3,单位为dB,缺省值为-3
取值越小检测可靠性越高,但灵敏度会下降
7
(COL2nd/COLMAX)比值的上限。输入信号要被识别为DTMF号码,其对应的比值必须小于此门限
取值范围为-18~-3,单位为dB,缺省值为-12
取值越小检测可靠性越高,但灵敏度会下降
8
两个额外指定的频点上的能量最大者与max(ROWMAX,COLMAX)的比值的上限。输入信号要被识别为DTMF号码,其对应的比值必须小于此门限
取值越小检测可靠性越高,但灵敏度会下降
9
DTMF信号持续时间的下限。输入信号要被识别为DTMF号码,其DTMF按键音持续的时间必须大于此门限
取值范围为30~150,单位为毫秒,缺省值为30毫秒
取值越大检测可靠性越高,但灵敏度会下降
10
额外指定的第一个检测频点的频率。这个频率需要选择为距离行、列频率组100Hz之外的频率值。
取值范围为300~3400,单位为Hz,缺省值为300Hz
11
额外指定的第二个检测频点的频率。这个频率需要选择为距离行、列频率组100Hz之外的频率值。
取值范围为300~3400,单位为Hz,缺省值为3200Hz
12
输入信号幅度的下限。输入信号要被识别为DTMF号码,其平均幅度必须大于此值
取值范围为0~700,缺省值为375
取值越大检测可靠性越高,但灵敏度会下降
【描述】
dtmf threshold命令用来配置检测DTMF码的敏感度。undo dtmf threshold命令用来恢复检测DTMF码的敏感度为缺省值。
dtmf threshold命令的功能是向底层DSP下发检测双音多频(DTMF)拨号音时的阈值参数。目的是精确调整设备对DTMF拨号音检测的灵敏度和可靠性。在DSP内部已经配置了一组通用的缺省值,按照序号从0到12的顺序,阈值参数分别为{1400,458,-9,-9,-9,-9,-3,-12,-12,30,300,3200,375}。
该命令主要供专业人员在DTMF拨号音检测功能失效时对设备进行调整,一般情况下使用缺省值即可。
# 在语音用户线1/0下配置DTMF索引为9的阈值。
[Sysname-subscriber-line1/0] dtmf threshold analog 9 40
echo-canceller { enable | tail-length milliseconds }
undo echo-canceller { enable | tail-length }
【缺省级别】
2:系统级
enable:使能回波抵消功能。
tail-length milliseconds:回波延时时间,即用户从发出原声到听到回声的时间间隔,取值范围为0~64,单位为毫秒,缺省值为0毫秒。
【描述】
echo-canceller命令用来使能回波抵消功能和配置回波延时时间。undo echo-canceller命令用来取消回波抵消的功能和参数设定。
缺省情况下,回波抵消功能处于开启状态。
echo-canceller tail-length命令只有在配置了echo-canceller enable命令之后才可用。
相关配置可参考命令subscriber-line和echo-canceller parameter。
# 配置语音用户线1/0的回波延时时间为24毫秒。
[Sysname-subscriber-line1/0] echo-canceller enable
[Sysname-subscriber-line1/0] echo-canceller tail-length 24
echo-canceller parameter { convergence-rate value | max-amplitude value | mix-proportion-ratio value | talk-threshold value }
undo echo-canceller parameter { convergence-rate | max-amplitude | mix-proportion-ratio | talk-threshold }
语音视图
【缺省级别】
2:系统级
convergence-rate value:舒适噪声幅度的收敛速度,取值范围为0~511。取值越大,噪声的收敛速度越快。
max-amplitude value:舒适噪声的最大幅度,取值范围为0~2048。取值越大,噪声的最大幅度越大。取值为0表示系统只做非线性处理而不加舒适噪声。
mix-proportion-ratio value:噪声的混合比例控制因子,取值范围为0~3000。取值越大,噪声与语音混合时噪声的比例越大。
talk-threshold value:双向通话判断阈值,取值范围为0~2。
【描述】
echo-canceller parameter命令用来配置回波抵消的参数。undo echo-canceller parameter命令用来恢复缺省情况。
缺省情况下,舒适噪声幅度的收敛速度的值为0,舒适噪声的最大幅度的值为256,噪声的混合比例控制因子的值为100,双向通话判断阈值的值为1。
相关配置可参考命令echo-canceller。
# 配置舒适噪声幅度的收敛速度为50。
[Sysname-voice] echo-canceller parameter convergence-rate 50
1.1.34  em-phy-parm
em-phy-parm { 2-wire | 4-wire }
undo em-phy-parm
模拟E&M语音用户线视图
【缺省级别】
2:系统级
2-wire:表示选择二线模拟E&M线缆类型。
4-wire:表示选择四线模拟E&M线缆类型。
【描述】
em-phy-parm命令用来为模拟E&M语音用户线的线缆类型,undo em-phy-parm命令用来恢复缺省情况。
缺省情况下,模拟E&M语音用户线的线缆类型为4线。
此命令仅适用于模拟E&M接口。该命令一旦配置,对该槽位上的所有E&M端口均有效。
# 配置模拟E&M语音用户线的线缆类型为2线。
[Sysname-subscriber-line5/0] em-phy-parm 2-wire
1.1.35  em-signal
em-signal { delay | immediate | wink }
undo em-signal
模拟E&M语音用户线视图
【缺省级别】
2:系统级
delay:延时启动方式。主叫端摘机占用中继线路,对端(如PBX)将响应主叫的摘机而进入摘机状态。对端将一直处于摘机状态直到准备好接收地址信息。
immediate:立即启动方式。主叫端通过E线摘机占线,并发送被叫号码。使用立即启动方式的前提是:对端设备在识别摘机信号后马上侦听拨号信号。
wink:闪断启动方式。主叫端通过E线摘机占线,在发送被叫号码之前必须等待对端的一个闪断信号。
【描述】
em-signal命令用来配置模拟E&M语音用户线的启动方式。undo em-signal命令用来恢复缺省情况。
缺省情况下,模拟E&M语音用户线采用立即启动方式。
# 配置delay方式。
em-passthrough
undo em-passthrough
模拟E&M语音用户线视图
【缺省级别】
2:系统级
无
【描述】
em-passthrough命令用来开启E&M透传模拟控制信号功能。undo em-passthrough命令用来关闭此功能。
缺省情况下,E&M透传模拟控制信号功能处于关闭状态。
# 配置E&M透传模拟控制信号。
[Sysname] subscriber-line 6/0
[Sysname-subscriber-line6/0] em-passthrough
1.1.37  hookoff-mode
hookoff-mode { delay | immediate }
undo hookoff-mode
模拟FXO语音用户线视图
【缺省级别】
2:系统级
delay:用于指示FXO语音用户线使用延时摘机方式摘机。
immediate:用于指示FXO语音用户线使用立即摘机方式摘机。
【描述】
hookoff-mode命令用来配置FXO语音用户线的摘机方式。undo hookoff-mode命令用来恢复缺省情况。
缺省情况下,FXO语音用户线使用立即摘机方式摘机。
# 配置FXO口的摘机模式为延时摘机。
[Sysname-subscriber-line 1/0] hookoff-mode delay
hookoff-mode delay bind fxs_subscriber_line [ ring-immediately ]
undo hookoff-mode delay bind
模拟FXO语音用户线视图
【缺省级别】
2:系统级
fxs_subscriber_line:同该FXO语音用户线绑定的FXS语音用户线号。
ring-immediately:采用立即振铃方式。
【描述】
hookoff-mode delay bind命令用来配置同该FXO语音用户线绑定的FXS语音用户线。undo hookoff-mode delay bind用来取消FXO语音用户线同FXS语音用户线的绑定关系。
缺省情况下,没有绑定FXS语音用户线。
FXO语音用户线同FXS语音用户线绑定后,两者的摘挂机状态保持一致。
·       为保证本FXO语音用户线与绑定的FXS语音用户线的摘挂机状态一致,hookoff-mode delay bind fxs_subscriber_line命令需要与private-line命令和caller-permit命令配合使用,fxs_subscriber_line应该为专线号码所指向的FXS用户线,同时通过主叫限制,只允许绑定的FXS用户线呼叫此FXO语音用户线。关于private-line和caller-permit命令的详细介绍请参见“语音命令参考”中的“拨号策略”。
·       hookoff-mode delay bind fxs_subscriber_line命令所绑定的FXS语音用户线必须与本FXO语音用户线在同一台设备上。
·       配置ring-immediately参数可提高FXO与绑定FXS语音用户线的振铃同步速度,但对于有来电显的话机,主叫号码将在第二声振铃后显示。
# 配置FXO语音用户线的摘机模式为延时摘机,并同FXS语音用户线3/0绑定。
[Sysname-subscriber-line1/0] hookoff-mode delay bind 3/0
1.1.39  hookoff-time
hookoff-time time
undo hookoff-time
模拟FXO语音用户线视图
【缺省级别】
2:系统级
time:强制挂机的时间,取值范围为60~36000,单位为秒。
【描述】
hookoff-time命令用来配置强制挂机的时间。undo hookoff-time命令用来取消强制挂机功能。
缺省情况下,强制挂机功能处于关闭状态。
# 配置强制挂机的时间为500秒。
[Sysname-subscriber-line1/0] hookoff-time 500
1.1.40  impedance
impedance { country-name | r550 | r600 | r650 | r700 | r750 | r800 | r850 | r900 | r950 }
undo impedance
模拟FXS/FXO语音用户线视图
【缺省级别】
2:系统级
country-name:国家名称,索引相应国家的阻抗匹配值。不同的国家有自己的阻抗匹配值。
australia:澳大利亚。
austria:奥地利。
belgium-long:比利时(长)。
belgium-short:比利时(短)。
brazil:巴西。
china:中华人民共和国。
czech-republic:捷克斯洛伐克。
denmark:丹麦。
etsi-harmanized:欧洲电信标准化协会。
finland:芬兰。
france:法国。
german-swiss:德国及瑞士。
greece:希腊。
hungary:匈牙利。
india:印度。
italy:意大利。
japan:日本。
korea:韩国。
mexico:墨西哥。
netherlands:荷兰。
norway:挪威。
portugal:葡萄牙。
slovakia:斯洛伐克。
spain:西班牙。
sweden:瑞典。
u.k.:英国。
us-loaded-line:美国标准1。
us-non-loaded:美国标准2。
us-special-service:美国标准3。
r550:550欧姆实(real)阻抗。
r600:600欧姆实(real)阻抗。
r650:650欧姆实(real)阻抗。
r700:700欧姆实(real)阻抗。
r750:750欧姆实(real)阻抗。
r800:800欧姆实(real)阻抗。
r850:850欧姆实(real)阻抗。
r900:900欧姆实(real)阻抗。
r950:950欧姆实(real)阻抗。
【描述】
impedance命令用来配置电气阻抗。undo impedance命令用来恢复缺省情况。
缺省情况下,电气阻抗是中国的阻抗匹配值。
用户通过输入国家名称就可以匹配此国家的阻抗值。配置的时候,可以不必输入完整的国家名称,只要输入的国家名称字符串在阻抗匹配索引表中唯一即可。
# 配置当前语音用户线1/0的电气阻抗为600欧姆实阻抗。
[Sysnamee] subscriber-line 1/0
[Sysname-subscriber-line1/0] impedance r600
1.1.41  nlp-on
nlp-on
undo nlp-on
语音用户线视图
【缺省级别】
2:系统级
无
【描述】
nlp-on命令用来使能回波抵消的非线性功能。undo nlp-on命令用来关闭回波抵消的非线性功能。
缺省情况下,回波抵消的非线性功能处于开启状态。
ICG 2000
ICG 2200
ICG 3000B
ICG 3000S
ICG 3000
ICG 5000B
ICG 5000
nlp-on
支持该命令的语音模块包括:
·       SIC-2FXS1FXO
·       MIM-8FXS8FXO
·       MIM-16FXS
·       FIC-24FXS
·       DFIC-24FXO24FXS
·       MIM-2BSV/MIM-4BSV
·       SIC-1VE1
·       MIM-1VE1
·       MIM-2VE1
·       FIC-1VE1
·       FIC-2VE1
该命令只有在配置了echo-canceller enable后才生效。
# 关闭语音接口的回波抵消的非线性功能。
[Sysname-subscriber-line 1/0] undo nlp-on
1.1.42  open-trunk
open-trunk { caller monitor interval | called }
undo open-trunk
E&M语音用户线视图
【缺省级别】
2:系统级
caller monitor interval:表示语音网关作为主叫时,使能E&M无信令模式,并同时启动监控时间,取值范围为60~600,单位为秒。
called:表示语音网关作为被叫时,使能E&M无信令模式。
【描述】
open-trunk命令用来使能E&M无信令模式。undo open-trunk命令用来取消E&M无信令模式。
缺省情况下,E&M无信令模式处于关闭状态。
# 在主叫语音网关侧使能E&M无信令模式,专线号码为100,监控时间为120秒。
[Sysname-subscriber-line5/0] private-line 100
[Sysname-subscriber-line5/0] open-trunk caller monitor 120
1.1.43  plc-mode
plc-mode { general | specific }
undo plc-mode
模拟FXS/FXO语音用户线视图
【缺省级别】
2:系统级
general:使用通用的frame erasure算法进行丢包补偿。
specific:使用语音网关特有方式进行丢包补偿。
【描述】
plc-mode命令用来配置模拟FXS/FXO语音用户线的丢包补偿方式。undo plc-mode命令用来恢复缺省情况。
缺省情况下,模拟FXS/FXO语音用户线使用语音网关特有方式进行丢包补偿。
# 配置语音网关使用通用的丢包补偿算法。
[Sysname-subscriber-line1/0] plc-mode general
1.1.44  receive gain
receive gain value
undo receive gain
【缺省级别】
2:系统级
value:语音输入增益,取值范围为-14.0~13.9,单位为dB。
【描述】
receive gain命令用来配置语音接口输入端的增益值。undo receive gain命令用来恢复将语音接口输入端的增益为缺省值。
缺省情况下,语音接口输入端的增益值为0。
此命令适用于FXO、FXS、模拟E&M接口、BSV和E1/T1语音接口。
当线路上语音信号衰减较大,可以使用该命令适当增大语音输入增益。
调整增益大小可能会导致语音呼叫失败。建议不要随意调整增益大小,如果确实有需要,请在技术人员指导下进行。
相关配置可参考命令transmit gain和subscriber-line。
# 在语音用户线1/0上,配置语音输入增益为3.5dB。
[Sysname-subscriber-line1/0] receive gain 3.5
【缺省级别】
2:系统级
无
【描述】
reset voice cmc statistic命令用来清除CMC模块的呼叫统计信息。
相关命令请参考display voice cmc。
# 清除CMC模块的呼叫统计信息。
<Sysname> reset voice cmc statistic
【缺省级别】
2:系统级
无
【描述】
reset voice ipp statistic命令用来清除IPP统计信息。
相关命令请参考display voice ipp statistic。
# 清除IPP统计信息。
<Sysname> reset voice ipp statistic
【缺省级别】
2:系统级
无
【描述】
reset voice iva statistic命令用来清除IVA统计信息。
相关命令请参考display voice iva statistic。
# 清除IVA统计信息。
<Sysname> reset voice iva statistic
ring-detect debounce value
undo ring-detect debounce
模拟FXO语音用户线视图
【缺省级别】
2:系统级
value:FXO振铃检测防抖动时间,取值范围为4~15,单位为毫秒。
【描述】
ring-detect debounce命令用来配置FXO振铃检测防抖动时间,通过调整debounce时间,可以检测不同频率和波形的振铃信号。undo ring-detect debounce命令用来恢复缺省情况。
缺省情况下,FXO振铃检测防抖动时间为10毫秒。
ICG 2000
ICG 2200
ICG 3000B
ICG 3000S
ICG 3000
ICG 5000B
ICG 5000
支持该命令的语音模块包括:
·       SIC-2FXO
·       SIC-1FXO
·       MIM-4FXO
·       MIM-2FXO
·       FIC-4FXO
·       FIC-2FXO
·       请不要在通话中修改振铃检测的防抖时间。
·       建议不要把防抖动时间参数设置的过小,因为在线路有工频干扰时,可能出现振铃误检。
·       在某一单板上的某个FXO语音用户线下配置该命令,则对该单板上所有FXO语音用户线均生效。
# 配置FXO语音用户线的振铃检测防抖动时间为15毫秒。
[sysname] subscriber-line 1/0
[sysname-subscriber-line1/0] ring-detect debounce 15
ring-detect frequency value
undo ring-detect frequency
模拟FXO语音用户线视图
【缺省级别】
2:系统级
value:FXO振铃检测的频率参数,取值范围为30~100,步长为10,单位为Hz。
【描述】
ring-detect frequency命令用来配置FXO振铃检测的频率参数。undo ring-detect frequency命令用来恢复缺省情况。
缺省情况下,FXO振铃检测的频率参数为40Hz。
ICG 2000
ICG 2200
ICG 3000B
ICG 3000S
ICG 3000
ICG 5000B
ICG 5000
支持该命令的语音模块包括:
·       SIC-2FXS1FXO
·       MIM-8FXS8FXO
·       DFIC-24FXO24FXS
# 配置FXO振铃检测的频率参数为100Hz。
[sysname-subscriber-line1/0] ring-detect frequency 100
send-busytone { enable | time seconds }
undo send-busytone { enable | time }
模拟FXO语音用户线视图
【缺省级别】
2:系统级
enable:启用FXO端口忙音发送功能。
time seconds:忙音发送时长,取值范围为2~15,单位为秒,缺省值为3秒。此参数只有在使用send-busytone enable命令启用FXO端口忙音发送功能后才可见。
【描述】
send-busytone命令用来启用FXO端口忙音发送功能。undo send-busytone命令用来停用FXO口忙音发送功能。
缺省情况下,忙音发送功能处于关闭状态。
# 启用FXO端口发送忙音功能,发送忙音的时长为5秒。
[Sysname-subscriber-line1/0] send-busytone enable
[Sysname-subscriber-line1/0] send-busytone time 5
shutdown
【缺省级别】
2:系统级
无
【描述】
shutdown命令用来关闭语音用户线。undo shutdown命令用来使语音用户线恢复到开启状态。
缺省情况下,语音用户线处于开启状态。
需要注意的是,如果执行shutdown命令,在语音接口卡上指定的POTS口将被禁用,连接的电话将听不到任何声音。而使用undo shutdown命令将使能语音卡上指定的语音用户线。
# 使语音用户线1/0离线。
[Sysname-subscriber-line1/0] shutdown
silence-th-span threshold time-length
undo silence-th-span
模拟FXO语音用户线视图
【缺省级别】
2:系统级
threshold:静音检测阈值,当交换机发来的语音信号小于此值时,系统将判定为静音,取值范围为0~200。通常情况下,没有任何通话发生的情况线路上的语音信号幅度为2到5之间。
time-length:静音检测挂机时长,当静音检测时长超过用户的设定值时,系统自动挂机,取值范围为2~7200,单位为秒。
【描述】
silence-th-span命令用来设置静音检测自动挂机的参数。undo silence-th-span命令用来恢复缺省情况。
缺省情况下,静音检测阈值为20,静音检测挂机时长为7200秒(即2个小时)。
# 设置静音检测阈值为20,静音检测时长为10秒。
[Sysname-subscriber-line1/0] silence-th-span 20 10
1.1.53  slic-gain
slic-gain { 0 | 1 }
undo slic-gain
模拟E&M语音用户线视图
【缺省级别】
2:系统级
0:使slic芯片的输出增益设置为0.8db。
1:使slic芯片的输出增益设置为2.1db。
【描述】
slic-gain命令用来配置slic芯片的输出增益,底层通过slic芯片对信号增益进行调整。undo slic-gain命令用来恢复缺省情况。
缺省情况下,slic芯片的输出增益为0。
# 在模拟E&M语音用户线视图下配置slic芯片的输出增益为1。
[Sysname-subscriber-line5/0] slic-gain 1
【缺省级别】
2:系统级
line-number:语音用户线号。
【描述】
subscriber-line命令用来进入语音用户线视图。例如,line-number为FXS语音用户线,则进入FXS语音用户线视图;line-number为模拟E&M语音用户线则进入模拟E&M语音用户线视图。
# 系统视图下进入语音用户线1/0的配置。
timer dial-interval seconds
undo timer dial-interval
FXS/FXO/E&M语音用户线视图
【缺省级别】
2:系统级
seconds:两个号码间的时间间隔,取值范围为1~300,单位为秒。
【描述】
timer dial-interval命令用来配置等待用户拨下一位号码的时间间隔。undo timer dial-interval命令用来恢复该时间为缺省值情况。
缺省情况下,超时时间为10秒。
用户每拨一位号码,此定时器就会重启,直到拨够所需的位数。如果在拨号没结束时定时器超时,用户将被提示挂机,呼叫终止。
# 配置语音用户线1/0上的拨下一位号码的最大等待时长为5秒。
[Sysname-subscriber-line1/0] timer dial-interval 5
timer disconnect-pulse milliseconds
undo timer disconnect-pulse
FXS语音用户线视图
【缺省级别】
2:系统级
milliseconds:挂机脉冲时长。取值范围为0~1500,缺省值为750,单位为毫秒。
【描述】
timer disconnect-pulse命令用来配置挂机脉冲信号时长。undo timer disconnect-pulse命令用来恢复挂机脉冲信号时长的缺省值。
# 在FXS语音用户线5/1上,配置FXS挂机脉冲时长为1秒。
[Sysname-subscriber-line5/1] timer disconnect-pulse 1000
timer first-dial seconds
undo timer first-dial
FXS/FXO语音用户线视图
【缺省级别】
2:系统级
seconds:用户从摘机到拨第一位号码的时间间隔,取值范围为1~300,单位为秒。
【描述】
timer first-dial命令用来配置用户从摘机到拨第一位号码的时间间隔。undo timer first-dial命令用来恢复缺省情况。
缺省情况下,从摘机到拨第一位号码的等待时间为10秒。
如果用户在摘机后的该时间内没有开始拨号,则将被提示挂机,呼叫终止。
# 配置用户从摘机到拨第一位号码的时间间隔为15秒。
[Sysname-subscriber-line1/0] timer first-dial 15
timer hookflash-detect hookflash-range
undo timer hookflash-detect
模拟FXS用户线视图
【缺省级别】
2:系统级
hookflash-range:检测拍叉的有效时间,单位为毫秒,取值范围为50~1200。
【描述】
timer hookflash-detect命令用来配置检测拍叉的有效时间。undo timer hookflash-detect命令用来恢复缺省情况。
缺省情况下,检测拍叉的有效时间为50~180毫秒,即检测到大于50毫秒小于180毫秒的挂机时间会被判定为拍叉。
# 在语音用户线1/0上配置检测拍叉的有效时间为100~200毫秒。
[Sysname-subscriber-line1/0] timer hookflash-detect 100-200
timer hookoff-interval milliseconds
undo timer hookoff-interval
模拟FXO语音用户线视图
【缺省级别】
2:系统级
milliseconds:挂机同摘机间隔时长。取值范围为500~4000,单位为毫秒。
【描述】
timer hookoff-interval命令用来配置挂机同摘机间隔时长。undo timer hookoff-interval命令用来恢复缺省情况。
缺省情况下,挂机同摘机间隔时长为500毫秒。
FXO接口在延时摘机绑定模式下,FXO语音用户线同FXS语音用户线摘挂机状态一致。FXS语音用户线摘机,同其绑定的FXO口语音用户线会同时摘机。当FXS语音用户线摘机,并需要接通FXO语音用户线,应用PSTN发起呼叫时,FXO语音用户线必须先进行挂机操作,然后再次进行摘机来发送被叫号码。参数milliseconds配置的间隔时长为挂机与再次摘机的间隔时间。
相关配置可参考命令hookoff-mode。
# 配置FXO用户线1/0上的摘机间隔时长为600毫秒。
[Sysname-subscriber-line1/0] timer hookoff-interval 600
timer ring-back seconds
undo timer ring-back
FXS/FXO/E&M语音用户线视图
【缺省级别】
2:系统级
seconds:送回铃音的最大时长,取值范围为5~120秒。
【描述】
timer ring-back命令用来配置送回铃音的最大时长。undo timer ring-back命令用来恢复缺省情况。
缺省情况下,送回铃音的最大时长为60秒。
# 在语音用户线1/0上配置系统送回铃音的最大时长为8秒。
[Sysname-subscriber-line1/0] timer ring-back 8
timer wait-digit { seconds | infinity }
undo timer wait-digit
E&M语音用户线视图
【缺省级别】
2:系统级
seconds:等待号码的最大时长,取值范围为3~600秒。
infinity:无限长时间。
【描述】
timer wait-digit命令用来配置等待号码拨号间隔的最大时长。undo timer wait-digit命令用来恢复缺省情况。
缺省情况下,等待号码拨号间隔的最大时长为5秒。
# 在语音用户线5/0上配置系统等待号码拨号间隔的最大时长为5秒。
[Sysname-subscriber-line5/0] timer wait-digit 5
transmit gain value
undo transmit gain
【缺省级别】
2:系统级
value:语音输出增益,取值范围为-14.0~13.9,单位是dB。
【描述】
transmit gain命令用来配置语音接口输出端的增益值。undo transmit gain命令用来将语音输出端增益恢复为缺省情况。
缺省情况下,语音接口输出端的增益值为0。
此命令适用于FXO、FXS、E&M接口、BSV和E1/T1语音接口。
当输出线路上需要的语音信号功率较小,可以使用本命令适当增大语音输出增益值以适应输出线路信号要求。
相关配置可参考命令receive gain和subscriber-line。
# 在语音用户线1/0上,配置语音输出增益为-6.7dB。
[Sysname-subscriber-line1/0] transmit gain -6.7
1.1.63  type
type { 1 | 2 | 3 | 5 }
undo type
模拟E&M语音用户线视图
【缺省级别】
2:系统级
1、2、3、5:分别对应模拟E&M语音用户线的四种信号类型,即类型1、2、3、5。
【描述】
type命令用来配置模拟E&M语音用户线的信号类型。undo type命令用来取消已有的配置。
缺省情况下,模拟E&M语音用户线的信号类型为类型5。
此命令仅适用于模拟E&M语音用户线。该命令一旦配置,对该槽位上的所有E&M语音用户线均有效。
# 配置模拟E&M语音用户线的信号类型为类型3。
[Sysname-subscriber-line5/0] type 3
vi-card cptone-custom { busy-tone | congestion-tone | dial-tone | ringback-tone | special-dial-tone | waiting-tone } comb freq1 freq2 time1 time2 time3 time4
undo vi-card cptone-custom { all | busy-tone | congestion-tone | dial-tone | ringback-tone | special-dial-tone | waiting-tone }
语音视图
【缺省级别】
2:系统级
busy-tone:忙音。
dial-tone:拨号音。
ringback-tone:回铃音。
waiting-tone:呼叫等待音。
comb:组合方式,取值范围为0~2。0表示两个频率的叠加,1表示两个频率的调制,2表示两个频率的交替。
freq1 freq2:两个单频音的频率值,单位为Hz。频率的取值范围与选择的组合方式相关,如果为叠加方式或交替方式,则两个频率的取值范围为300~3400;如果为调制方式,则两个频率的取值范围为0~3400,并且调制取值(两个频率的和与差的绝对值)必须在300~3400范围之间。
time1:第一个通断比的通时间的长度,取值范围为30~8192,单位为毫秒。如果是持续播放,设为8192。
time2:第一个通断比的断时间的长度,取值范围为30~8191,单位为毫秒。
time3:第二个通断比的通时间的长度,取值范围为30~8191,单位为毫秒。
time4:第二个通断比的断时间的长度,取值范围为30~8191,单位为毫秒。
【描述】
vi-card cptone-custom命令用来配置自定义模式的提示音参数。undo vi-card cptone-custom命令用来取消自定义模式的提示音参数。
缺省情况下,没有配置自定义模式的提示音参数。
需要注意的是,本命令将呼叫提示音参数输入到系统中后这些参数并未立即生效。需要在语音视图下运行cptone country-type CS命令后,手动配置的呼叫提示音参数才能生效。
# 定制忙音参数,双频425,通断时间分别为350毫秒。
[sysname-voice] vi-card cptone-custom busy-tone 0 425 425 350 350 350 350
vi-card busy-tone-detect { auto index line-number | custom area-number index argu f1 f2 p1 p2 p3 p4 p5 p6 p7 }
undo vi-card busy-tone-detect { auto | custom } index
语音视图
【缺省级别】
2:系统级
index:记录忙音特性的编号。取值范围为0~3。
line-number:语音用户线号,取值范围由路由器型号和所插单板情况而定。
area-number:区域号,目前为保留参数,规定设置为2。
argu:目前为保留参数,取值范围为0~32767。
f1:频率参数1,取值范围为50~3600,单位是Hz。
f2:频率参数2,取值范围为50~3600,单位是Hz。
p1:信号振幅参数1,取值范围为50~32767。
p2:信号振幅参数2,取值范围为50~32767。
p3:单音持续时间长度,取值范围为10~1000,单位是毫秒。
p4:单音持续时间长度的误差范围,取值范围为0~500,单位是毫秒。
p5:静音持续时间长度,取值范围为10~1000,单位是毫秒。
p6:静音持续时间长度的误差范围,取值范围为0~500,单位是毫秒。
p7:单频音和静音持续时间长度的差值区间,取值范围为0~500,单位是毫秒,即p3和p5差的绝对值。
【描述】
vi-card busy-tone-detect命令用来配置FXO接口忙音检测的参数。undo vi-card busy-tone-detect命令用来恢复FXO接口忙音检测的参数的缺省值。
vi-card busy-tone-detect命令只对FXO接口有效。系统可以记录4种忙音特性,由index参数来标记。
当使用vi-card busy-tone-detect auto命令成功检测到FXO接口的忙音后,系统会自动计算出忙音检测的相关参数,使用display current-configuration命令能够显示vi-card busy-tone-detect custom命令的忙音参数取值,这组参数值将有助于人工配置和调整忙音检测参数。
使用vi-card busy-tone-detect custom命令将忙音参数输入到系统中后这些参数并未立即生效。语音视图下运行area custom命令后手动配置的忙音参数才能生效。相关配置可参考命令area custom。
# 在语音用户线2/0上启动自动忙音检测,忙音编号为0。
[Sysname-voice] vi-card busy-tone-detect auto 0 2/0
# 手动配置1号忙音参数,高/低电平持续时间底限、高/低电平持续时间误差区间、高/低电平时间差值区间等值。
[Sysname-voice] vi-card busy-tone-detect custom 2 1 99 450 450 8000 8000 800 300 500 500 500
vi-card reboot slot-number
语音视图
【缺省级别】
2:系统级
slot-number:语音单板的槽位编号。
【描述】
vi-card reboot命令用来复位语音单板。
首先使用display version或display device命令显示路由器中语音单板的分布槽位,语音单板的正确槽位是语音单板实际插入的槽位。
相关配置可参考“基础配置命令参考/设备管理”中的命令display version和display device。
·       所有的模拟语音板卡(包括FXS、FXO、E&M)、SIC-AUDIO、BSV都可以通过vi-card reboot命令进行复位;所有的VE1和VT1语音板卡不能通过vi-card reboot命令进行复位。
·       SIC数字语音板卡不能进行单板复位操作。
·       FIC模拟语音板卡也可以通过reboot slot slot-number命令进行复位。关于reboot slot命令的详细介绍请参见“基础配置命令参考”中的“设备管理”。
# 复位3号槽位的语音单板。
[Sysname-voice] vi-card reboot 3
mirror number number { pcm | { in | out | all } { command | data } } to { local-interface interface-type interface-number [ mac H-H-H ] | remote-ip ip-address [ port port ] }
undo mirror [ number number ]
模拟语音用户线视图
【缺省级别】
2:系统级
number number:镜像编号,取值范围为1~64。
pcm:镜像PCM数据。
in:入方向语音RTP或命令数据镜像。
out:出方向语音RTP或命令数据镜像。
all:双方向语音RTP或命令数据镜像。
data:镜像语音RTP数据。
command:镜像语音命令数据。
to:输出镜像数据到指定接口或IP地址。
local-interface interface-type interface-number:将镜像数据输出到指定接口,interface-type interface-number为接口类型和接口编号。该接口必须为二层或三层以太网接口。
mac:镜像数据发出时使用的目的MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
remote-ip ip-address:将镜像数据输出到指定的IP地址。
port port:将镜像数据输出到指定的端口号,缺省值为60000。
【描述】
mirror命令用来镜像模拟语音用户线的PCM、语音RTP或命令数据。undo mirror命令用来取消一条或所有镜像配置。
缺省情况下,不镜像任何数据。
需要注意的是,在路由器全局配置环境下,只允许存在一条PCM数据镜像配置。
本命令仅适用于FXS、FXO和E&M模拟语音用户线。
# 镜像FXS 1/0接口的PCM数据到以太网接口Ethernet1/1。
[Sysname-subscriber-line1/0] mirror number 1 pcm to local-interface ethernet 1/1
数字语音用户线配置命令
1.1.68  amd enable
amd enable
undo amd enable
数字语音用户线视图
【缺省级别】
2:系统级
无
【描述】
amd enable命令用来使能自动应答机检测功能。undo amd enable命令用来关闭AMD功能。
缺省情况下,AMD功能处于关闭状态。
# 在语音用户线1/0:1上打开AMD功能。
[Sysname] subscriber-line 1/0:1
[Sysname-subscriber-line1/0:1] amd enable
amd parameter { machine-time value | max-analyze-time value | min-silence-time value | valid-voice-time value | voice-energy-threshold value }
undo amd parameter { machine-time | max-analyze-time | min-silence-time | valid-voice-time | voice-energy-threshold }
语音视图
【缺省级别】
2:系统级
machine-time value:设置自动应答机识别时间。如果接听者的问候语时间超过该参数值,即被判定为自动应答机。取值范围为10~60000,单位为毫秒,必须是10的倍数。
max-analyze-time value:设置AMD最大分析时间,从被叫摘机时开始计算。取值范围为10~60000,单位为毫秒,必须是10的倍数。
min-silence-time value:设置有效语音后的最短静音时间,取值范围为10~60000,单位为毫秒,必须是10的倍数。
valid-voice-time value:设置检测到有效语音的最短时间,取值范围为10~60000,单位为毫秒,必须是10的倍数。
voice-energy-threshold value:设置语音能量阈值,取值范围为10~5000。
【描述】
amd parameter命令用来配置AMD检测参数。undo amd parameter命令用来恢复缺省情况。
缺省情况下,machine-time(被识别为自动应答机的时间)为2600毫秒,max-analyze-time(AMD最大分析时间)为4000毫秒,min-silence-time(有效语音后的最短静音时间)为800毫秒,valid-voice-time(有效语音的最短时间)为120毫秒,voice-energy-threshold(语音能量阈值)为100。
AMD检测有四种结果:voice、automatic、silence和unknown。
# 配置AMD最大分析时间为5秒。
[Sysname-voice] amd parameter max-analyze-time 5000
1.1.70  ani
ani { all | ka }
undo ani
R2信令视图
【缺省级别】
2:系统级
all:对端发送主叫业务类别信息与主叫号码。
ka:对端只发送主叫业务类别信息。
【描述】
ani命令用来配置在呼叫接续过程中入局端向出局端请求主叫组号码信息(业务类别和主叫号码信息)。undo ani命令用来恢复缺省情况。
缺省情况下,在呼叫接续过程中不向出局端请求主叫组号码信息。
·       当本端需要支持号码自动识别功能时可以配置此命令;
·       此命令仅用于R2信令;
·       参数ka需要和对端交换机配置配合使用,否则可能导致电话无法接通。一般情况使用参数all。
相关配置可参考命令cas和ani-offset。
# 配置在接续过程中本局要求对局发送主叫用户类别信息和主叫号码。
[Sysname] controller e1 1/0
[Sysname-e1 1/0] timeslot-set 0 timeslot-list 1-31 signal r2
[Sysname-e1 1/0] cas 0
[Sysname-cas1/0:0] ani all
1.1.71  ani-offset
ani-offset number
undo ani-offset
R2信令视图
【缺省级别】
2:系统级
number:为收集的号码位数,取值范围为1~10,缺省值为1。
【描述】
ani-offset命令用来配置请求主叫组信息之前需要收集的被叫号位数,当收集的号码个数小于该值时,系统将等待接收下一个号码直到超时,在等待过程中不会向对端请求主叫号码信息;当收集的号码个数等于或超过该值,则向对端请求主叫号码或主叫标识。undo ani-offset命令用来恢复缺省情况。
缺省情况下,接收主叫标识之前所需收集的号码数量为1。
此命令仅用于R2信令。
相关配置可参考命令cas、timer、reverse和renew。
只有配置了ani命令后,才可以配置该命令。
# 配置收到3位号码后开始向对端请求主叫号码或主叫标识。
[Sysname-cas1/0:0] ani-offset 3
answer enable
undo answer enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
answer enable命令用来配置出局端要求入局端必须发送应答信号。只有接收到应答信号,双方才能进入通话状态。undo answer enable命令用来恢复缺省情况。
缺省情况下,出局端要求入局端发送应答信号。
此命令仅用于R2信令。
一些国家的R2线路信令编码方案中不发送应答信号,在这种情况下可使用answer enable命令来适配这种信令编码方案。若出局端不要求应答信号,则入局端在规定时间超时后就默认通话可以建立。
相关配置可参考命令re-answer enable和timer dl re-answer。
# 禁止入局端发送应答信号。
[Sysname-cas1/0:0] undo answer enable
1.1.73  callmode
callmode { segment | terminal }
undo callmode
R2信令视图
【缺省级别】
2:系统级
segment:用于指示R2呼叫的中继接续模式采用段到段方式。
terminal:用于指示R2呼叫的中继接续模式采用端到端方式。
【描述】
callmode命令用来配置使用R2信令的呼叫接续模式。undo callmode命令用来恢复缺省情况。
缺省情况下,R2信令的呼叫接续模式为端到端方式。
# 配置R2中继的接续方式使用段到段方式。
[Sysname-cas 1/0:0] callmode segment
1.1.74  cas
cas ts-set-number
E1/T1接口视图
【缺省级别】
2:系统级
ts-set-number:为预先定义的时隙(TS)组的编号,E1接口的取值范围为0~30,T1接口的取值范围为0~23。
【描述】
cas命令用来进入R2信令视图、数字E&M信令视图或数字LGS信令视图。
可以根据需要配置E1/T1接口上各种信令的各参数,如果想配置相应的信令参数,必须使得cas命令中的参数ts-set-number和timeslot-set命令中的参数ts-set-number保持一致。
相关配置可参考命令timeslot-set、ani-offset、reverse、select-mode、timer、runk-direction和renew。
# 进入5号时隙(TS)组的R2信令视图。
[Sysname-e1 1/0] timeslot-set 5 timeslot-list 1-31 signal r2
[Sysname-e1 1/0] cas 5
undo clear-forward-ack enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
clear-forward-ack enable命令用来配置出局端(主叫方)主动拆线时,入局端设备必须发送后向拆线信号给予回应。undo clear-forward-ack enable用来配置出局端(主叫方)主动拆线时,入局端设备不发送后向拆线信号给予回应。
缺省情况下,禁止入局端发送后向拆线信号对前拆线信号给予回应。
此命令仅用于R2信令。
一些国家R2线路信令交互过程中,如果出局端和入局端设备对于中继电路的复原控制是由被叫侧(入局端)控制时,当主叫方主动拆线,出局端向入局端发送前向拆线信号后,入局端会发送后向拆线信号作为确认信号,接着再发送释放监护信号以示入局端线路已完全释放。
相关配置可参考命令mode。
# 配置入局端发送后向拆线信号,来应答接收到的前向拆线信号。
[Sysname-cas1/0:0] clear-forward-ack enable
display voice subscriber-line slot-number:{ { ts-set-number | ts-set-number.sub-timeslot } | 15 | 23 } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
slot-number:表示创建时隙(TS)组或ISDN PRI组时生成的语音用户线编号。
ts-set-number:表示成功建立的时隙(TS)组编号。
ts-set-number.sub-timeslot:表示成功建立的时隙(TS)组编号。其中ts-set-number为时隙(TS)组的标识号;sub-timeslot为选择的时隙。
15:表示语音用户线是在E1接口上创建ISDN PRI组时生成的。
23:表示语音用户线是在T1接口上创建ISDN PRI组时生成的。
【描述】
display voice subscriber-line命令用来显示语音用户线的配置信息,如是否采用专线连接及连接号码,语音用户线描述,是否启动回波抵消功能及回波抵消采样时间长度,是否启动舒适噪音功能。
# 显示语音用户线配置。
<Sysname> display voice subscriber-line 5/0:0
  Current information  -----  subscriber-line5/0:0
    Type                        = R2
    Status                      = PhysicalDown
    Call Status :
        TS  1                   = IDLE
        TS  2                   = IDLE
        TS  3                   = IDLE
        TS  4                   = IDLE
        TS  5                   = IDLE
        TS  6                   = IDLE
        TS  7                   = IDLE
        TS  8                   = IDLE
        TS  9                   = IDLE
        TS 10                   = IDLE
        TS 11                   = IDLE
        TS 12                   = IDLE
        TS 13                   = IDLE
        TS 14                   = IDLE
        TS 15                   = IDLE
        TS 17                   = IDLE
        TS 18                   = IDLE
    Description                 = subscriber-line5/0:0 Interface
    Private Line                = None
    Cng                         = Enable
    Nlp On                      = Enable
    Receive Gain                = 0.0
    Transmit Gain               = 0.0
    DTMF Threshold Digital      = Insensitivty
    PCM Type                    = A-Law
表1-4 display voice subscriber-line命令显示信息描述表
Current information
当前语音用户线的信息
语音用户线的信令类型
Status
语音用户线的状态
Call Status
语音协议的呼叫状态
语音用户线信息
Private Line
语音用户线的专线拨号模式
Cng
语音用户线的舒适背景声配置
Echo Canceller
语音用户线的回波抵消功能配置
语音用户线的回波持续时间配置
Nlp on
语音用户线的回波抵消非线性处理配置
Receive Gain
语音用户线的输入增益配置
Transmit Gain
语音用户线的输出增益配置
数字语音用户线DTMF参数配置
PCM Type
语音用户线的PCM压扩方式
1.1.77  dl-bits
dl-bits { answer | blocking | clear-back | clear-forward | idle | seize | seizure-ack | release-guard } { received | transmit } ABCD
undo dl-bits { answer | blocking | clear-back | clear-forward | idle | seize | seizure-ack | release-guard } { received | transmit }
R2信令视图
【缺省级别】
2:系统级
answer:R2线路信令中的应答信号。
blocking:R2线路信令中的闭塞信号。
clear-back:R2线路信令中的后向拆线信号。
clear-forward:R2线路信令中的前向拆线信号。
idle:R2线路信令中的空闲信号。
seize:R2线路信令中的占用信号。
seizure-ack:R2线路信令中的占用确认信号。
release-guard:R2线路信令中的后向释放监护信号。
received:接收R2线路信令的信号。
transmit:发送R2线路信令的信号。
ABCD:接收/发送R2线路信令的信号位取值,各位取值为0或1。
表1-5 R2线路信令各信号缺省值
信号
rx-bits ABCD缺省值
tx-bits ABCD缺省值
Answer(应答)
0101
0101
Blocking(闭塞)
1101
1101
Clear-back(后向拆线)
1101
1101
Clear-forward(前向拆线)
1001
1001
Idle(空闲)
1001
1001
Seize(占用)
0001
0001
Seizure-ack(占用确认)
1101
1101
Release-guard(释放监护)
1001
1001
【描述】
dl-bits命令用来配置R2信令各线路信号的比特值。undo dl-bits命令用来恢复R2信令各线路信号比特值为缺省值。
此命令仅用于R2信令。
由于有些国家对于R2信令各线路信号ABCD比特值有着不同的编码方案,因而可使用此dl-bits命令设置发送和接收线路信号ABCD位的比特值。
相关配置可参考命令seizure-ack enable和answer enable。
# 配置接收R2信令空闲信号ABCD取值为1101,发送R2信令空闲信号取值为1011。
[Sysname-cas1/0:0] dl-bits idle received 1101
[Sysname-cas1/0:0] dl-bits idle transmit 1011
1.1.78  dtmf enable
dtmf enable
undo dtmf enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
dtmf enable命令用来配置采用DTMF方式收发R2信令。undo dtmf enable用来恢复缺省情况。
缺省情况下,采用MFC方式收发R2信令。
此命令仅用于R2信令。
相关配置可参考命令timer dtmf。
# 配置采用DTMF方式收发R2信令。
[Sysname-cas1/0:0] dtmf enable
dtmf threshold digital value
undo dtmf threshold digital
BSV语音用户线视图
【缺省级别】
2:系统级
digital:对数字语音用户线进行设置。
value:取值为0或者1,0表示检测DTMF码的灵敏度为不敏感,1表示检测DTMF码的灵敏度为敏感。
【描述】
dtmf threshold digital命令用来配置检测DTMF码的敏感度。undo dtmf threshold digital命令用来恢复检测DTMF码的敏感度为缺省值。
缺省情况下,检测DTMF码的敏感度为不敏感。
使用dtmf threshold digital命令配置检测DTMF码的敏感度,越敏感则表示DTMF码收号容限越大,误检号码的可能性相对变大,漏检的可能性越小。
# 配置检测DTMF码的敏感度为敏感。
[Sysname] subscirber-line1/0:0
[Sysname-subscriber-line1/0:0] dtmf threshold digital 1
undo enable snmp trap updown
BSV BRI接口视图
【缺省级别】
2:系统级
无
【描述】
enable snmp trap updown命令用来配置BSV BRI接口允许发送端口Link up和Link down的SNMP Trap报文。undo enable snmp trap updown命令用来配置BSV BRI接口禁止发送端口Link up和Link down的SNMP Trap报文。
缺省情况下,BSV BRI接口允许发送端口Link up和Link down的SNMP Trap报文。
# 设置BSV BRI2/0接口禁止发送端口Link up和Link down的SNMP Trap报文。
[Sysname] interface bri 2/0
[Sysname-Bri2/0] undo enable snmp trap updown
undo final-callednum enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
final-callednum enable命令用来配置当被叫号码发送完后,必须给入局端发送号码终结信号。undo final-callednum enable命令用来配置当被叫号码发送完后,禁止给入局端发送号码终结信号。
缺省情况下,禁止回送被叫号码终结信号。
此命令仅用于R2信令。
一些国家的R2记发器信令,可以在被叫号码发送完后再发送号码终结信号,以示被叫号码已经发送完毕,在这种情况下可使用final-callednum命令来适配这种信令交互方式。当入局端收到被叫号码终结信号后,将不再请求被叫号码。
相关配置可参考命令register-value digital-end。
# 使能发送被叫号码终结信号。
[Sysname-cas1/0:0] final-callednum enable
undo force-metering enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
force-metering enable命令用来配置使能R2信令的计次信号处理功能。undo force-metering enable命令用来关闭R2信令的计次信号处理功能。
缺省情况下,R2信令的计次信号处理功能处于关闭状态。
此命令仅用于R2信令。
对端局支持计次信号时,为了避免计次信号冲突,当路由器作为入局端主动结束呼叫时会发送强拆信号(forced-release)替代后向拆线信号(clear-back)表明被叫方已主动拆线结束呼叫。
# 使能R2信令的记次信号功能。
[Sysname-cas1/0:0] force-metering enable
group-b enable
undo group-b enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
group-b enable命令用来配置R2信令采用B组阶段信号完成记发器交互过程。undo group-b enable命令用来取消R2信令采用B组阶段信号完成记发器交互过程。
缺省情况下,使用B组阶段信号完成记发器交互过程。
此命令仅用于R2信令。
由于一些国家R2记发器信令不支持B组阶段信号交互过程,或不能正确解释B组信号值,因而可使用group-b命令来配置是否交互B组信号。
相关配置可参考命令register-value req-switch-groupb。
# 采用B组信号进行记发器交互过程。
[Sysname-cas1/0:0] group-b enable
1.1.84  link-delay
link-delay delay-time
undo link-delay
VE1/VT1接口视图
【缺省级别】
2:系统级
delay-time:接口物理连接状态抑制时间值,取值范围为0~10,单位为秒。取值为0时,表示关闭VE1/VT1接口物理连接状态抑制功能,与undo link-delay命令等效。
【描述】
link-delay命令用来设置VE1/VT1接口物理连接状态抑制时间。undo link-delay命令用来恢复缺省情况。
缺省情况下,VE1/VT1接口没有开启状态抑制功能。系统每5秒检测一次接口物理连接状态,当连接状态发生变化后,系统会在0~5秒内检测并上报连接状态的变化。
当配置delay-time参数值为1~10时,例如取值为2,则接口连接状态发生变化后,系统会在2~7秒内检测并上报连接状态的变化。
本命令需要配置在controller视图下。
本命令对自然关闭状态(down)下的端口有效,对手工关闭状态(使用shutdown命令)下的端口无效。
# 设置VE1/VT1接口物理连接状态抑制时间值为2,即系统会在2~7秒内检测并上报接口连接状态的变化:
[Sysname] controller e1 2/0
[Sysname-E1 2/0] link-delay 2
1.1.85  line
line slot-number:{ ts-set-number | 15 | 23 }
undo line
POTS语音实体视图
【缺省级别】
2:系统级
slot-number:表示该语音用户线所属的E1/T1接口的编号。
ts-set-number:表示采用E1/T1语音时成功建立的时隙(TS)组编号。
15:表示POTS语音实体与E1语音ISDN PRI接口对应。
23:表示POTS语音实体与T1语音ISDN PRI接口对应。
【描述】
line命令用来配置POTS语音实体与逻辑语音用户线的绑定关系。undo line命令用来取消POTS语音实体与逻辑语音用户线之间的绑定。
缺省情况下,POTS语音实体与逻辑语音用户线的没有绑定关系。
当使用match-template命令配置了语音实体的被叫号码模板后,需要使用line命令配置POTS语音实体与逻辑接口之间的对应关系,也即指定去往该目标应该从哪个接口进行路由。
相关配置可参考命令timeslots-set和pri-set,“语音命令参考/语音实体”中的命令entity。
# 配置POTS语音实体与E1接口的时隙(TS)组对应。
[Sysname-voice] dial-program
[Sysname-voice-dial] entity 10 pots
[Sysname-voice-dial-entity10] line 1/0:1
1.1.86  mode
mode zone-name [ default-standard ]
undo mode
R2信令视图
【缺省级别】
2:系统级
zone-name:国家或地区名称。取值如下:
·              argentina:使用阿根廷R2信令标准。
·              australia:使用澳大利亚R2信令标准。
·              bengal:使用孟加拉国R2信令标准。
·              brazil:使用巴西R2信令标准。
·              china:使用中国R2信令标准。
·              custom:使用用户自定义的R2信令模式。
·              hongkong:使用香港R2信令标准。
·              india:使用印度R2信令标准。
·              indonesia:使用印度尼西亚R2信令标准。
·              itu-t:使用ITU-T的R2信令标准。
·              korea:使用韩国R2信令标准。
·              malaysia:使用马来西亚R2信令标准。
·              mexico:使用墨西哥R2信令标准。
·              newzealand:使用新西兰R2信令标准。
·              singapore:使用新加坡R2信令标准。
·              thailand:使用泰国R2信令标准。
default-standard:按照当前配置的国家模式初始化R2信令相关参数,即初始化命令force-metering等命令的取值。
【描述】
mode命令用来配置国家或地区的R2信令模式,由于不同国家和地区可能有各自的R2信令规范,为了能和不同国家或地区的设备进行R2信令互通,需要适配国家和地区模式。undo mode命令用来恢复缺省情况。
缺省情况下,R2信令模式为ITU-T模式。
此命令仅用于R2信令。
不同国家R2信令的具体实现和参数取值不尽相同,因此为了路由器能和不同国家或地区的交换设备进行R2信令互通,需要适配国家和地区模式。系统根据配置的模式,自动选择相匹配的用户线状态、业务类别、计次信号和C、D信号位的信号值等。设备目前支持巴西、墨西哥、阿根廷、印度、新西兰、泰国、孟加拉、韩国、香港、印度尼西亚以及符合ITU-T建议规范的国家和地区。
如果配置了default-standard参数,则系统会按照该国家或地区的默认的国标来对用户线状态、业务类别、计次信号和C、D信号位等取值来初始化相关的参数。
如果采用用户自定义模式(custom)用户自定义模式,用户可以自行设定R2信令中的特定信令交互流程和信号值,以达到灵活适配各国R2信令的目的。
相关配置可参考命令register-value和force-metering enable。
# 配置采用香港地区的缺省R2信令模式。
[Sysname-cas1/0:0] mode hongkong default-standard
1.1.87  pcm
pcm { a-law | µ-law }
undo pcm
语音用户线视图
【缺省级别】
2:系统级
a-law:对数压扩律A律,中国、欧洲、非洲和南美等国家使用。
µ-law:对数压扩律µ律,美国使用。
【描述】
pcm命令用来配置信号量化时使用的对数压扩律。undo pcm命令用来恢复缺省的对数压扩律。
为了减少噪声,提高信噪比,保证语音质量,实际应用中一般使用对数压扩律对信号进行非均匀量化。使用压扩法减少噪音依据了语音信号的统计性质,即小功率信号出现的概率远大于大功率信号出现的概率。
根据CCITT规定,使用µ律压扩的国家负责将信号转换为A律。
VE1板卡该命令的缺省值为A律,VT1板卡该命令的缺省值为μ律。
# 配置信号量化时使用µ律进行压扩。
[Sysname-subscriber-line1/0:0] pcm u-law
posa called-length called-length
undo posa called-length
R2信令视图
【缺省级别】
系统级
called-length:E1POS卡接收被叫号码的长度,取值范围为1~31。
【描述】
posa called-length命令用来配置E1POS卡接收被叫号码的长度。undo posa called-length命令用来恢复缺省情况。
缺省情况下,E1POS卡能够接收被叫号码的长度为31位,即最大长度。
# 使用R2信令接入POS终端,配置E1POS卡接收被叫号码的长度为8位。
[Sysname] controller e1 5/0
[Sysname-e1 5/0] timeslot-set 0 timeslot-list 1-31 signal r2
[Sysname-e1 5/0] cas 0
[Sysname-cas5/0:0] posa called-length 8
1.1.89  pri-set
pri-set [ timeslot-list range ]
undo pri-set
E1/T1接口视图
【缺省级别】
2:系统级
range:被捆绑的时隙编号,E1接口取值范围为1~31,T1接口取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
【描述】
pri-set命令用来将E1接口或T1接口的时隙捆绑为PRI组,undo pri-set命令用来取消已有的捆绑。
缺省情况下,未创建任何PRI组。
·              将E1接口时隙捆绑为PRI组时,0时隙被用作传输同步信息,16时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时可以将除0时隙之外的时隙捆绑为一个PRI组(16时隙作为D信道会被自动捆绑),形成一个类似30B+D的ISDN PRI接口,其逻辑特性与ISDN PRI接口相同。E1接口在时隙捆绑以后将自动创建一个Serial接口,接口编号是serial number:15。
·              将T1接口时隙捆绑为PRI组时,24时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时24时隙作为D信道会被自动捆绑,形成一个类似23B+D的ISDN PRI接口,其逻辑特性与ISDN PRI接口相同。T1接口在时隙捆绑以后将自动创建一个Serial接口,接口的编号是serial number:23。
# 将E1接口的1、2、8~12时隙捆绑为PRI组。
[Sysname-e1 1/0] pri-set timeslot-list 1,2,8-12
qsig-tunnel enable
undo qsig-tunnel enable
数字语音用户线视图
【缺省级别】
2:系统级
无
【描述】
qsig-tunnel enable命令用来使能QSIG tunnel功能。undo qsig-tunnel enable命令用来关闭该功能。
缺省情况下,QSIG tunnel功能处于关闭状态。
# 使能QSIG tunnel功能。
[Sysname] subscriber-line 1/0:15
[Sysname-subscriber-line1/1:15] qsig-tunnel enable
re-answer enable
undo re-answer enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
re-answer enable命令用来配置出局端支持再应答信号的处理。undo re-answer enable命令用来恢复缺省情况。
缺省情况下,出局端不支持再应答信号的处理。
此命令仅用于R2信令。
一些国家的R2信令的由于业务需要存在再应答业务流程。当入局端主动发出后向拆线信号后,出局端不立即拆线,而是继续保持呼叫状态。如果在规定的时间内收到入局端发送的应答线路信号,则继续呼叫通话过程,否则超时后拆除呼叫。
相关配置可参考命令answer enable和timer dl re-answer。
# 启用出局端支持再应答信号的处理。
[Sysname-cas 1/0:0] re-answer enable
register-value { billingcategory | callcreate-in-groupa | callingcategory | congestion | demand-refused | digit-end | nullnum | req-billingcategory | req-callednum-and-switchgroupa | req-callingcategory | req- currentcallednum-in-groupc | req-currentdigit | req- firstcallednum-in-groupc | req-firstcallingnum | req-firstdigit | req-lastfirstdigit | req-lastseconddigit | req-lastthirddigit | req-nextcallednum | req-nextcallingnum | req-switch-groupb | subscriber-abnormal |subscriber-busy | subscriber-charge |subscriber-idle } value
undo register-value { billingcategory | callcreate-in-groupa | callingcategory | congestion | demand-refused | digit-end | nullnum | req-billingcategory | req-callednum-and-switchgroupa | req-callingcategory | req- currentcallednum-in-groupc | req-currentdigit | req- firstcallednum-in-groupc | req-firstcallingnum | req-firstdigit | req-nextcallednum | req-nextcallingnum | req-lastfirstdigit | req-lastseconddigit | req-lastthirddigit | req-nextcallednum | req- nextcallingnum | req-specialsignal | req-switch-groupb | subscriber-abnormal |subscriber-busy | subscriber-charge |subscriber-idle }
R2信令视图
【缺省级别】
2:系统级
billingcategory value:计费业务类别信号值,取值范围为1~16。用于配置R2信令的KA信号,即发端市话局向发端长话局或发端国际局前向发送的主叫用户类别信号,该信号提供本次接续的计费种类(定期、立即、免费等)和用户等级(普通、优先)两种信息。
callcreate-in-groupa value:直接建立呼叫信号,取值范围为1~16。
callingcategory value:主叫业务类别信号值,取值范围为1~16。用于配置R2信令中的KD信号,即发端呼叫业务类别,其作用是标识是否能插入或强拆市话,或能否被插入或强拆。
congestion value:拥塞信号值,取值范围为1~16。
demand-refused value:请求被拒绝信号值,取值范围为1~16。
digit-end value:号码结束信号值,取值范围为1~16。
nullnum value:空号信号值,取值范围为1~16。
req-billingcategory value:请求计费业务类别信号值,取值范围为1~16。
req-callednum-and-switchgroupa value:请求后一位被叫号码并且转到A组阶段,取值范围为1~16。
req-callingcategory value:请求主叫业务类别信号值,取值范围为1~16。
req-currentcallednum-in-groupc value:在C组状态下请求当前位被叫号码,取值范围为1~16。
req-currentdigit value:请求当前号码信号值,取值范围为1~16。
req-firstcallednum-in-groupc value:在C组状态下请求第一位被叫号码,取值范围为1~16。
req-firstcallingnum value:开始请求主叫号码信号值,取值范围为1~16。
req-firstdigit value:请求第一位号码发码位次信号值,取值范围为1~16。
req-lastfirstdigit value:请求前一位号码发码位次信号值,取值范围为1~16。
req-lastseconddigit value:请求前二位号码发码位次信号值,取值范围为1~16。
req-lastthirddigit value:请求前三位号码发码位次信号值,取值范围为1~16。
req-nextcallednum value:请求后一位被叫号码信号值,取值范围为1~16。
req-nextcallingnum value:请求后一位主叫号码信号值,取值范围为1~16。
req-switch-groupb value:请求切换到B组信号值,取值范围为1~16。
subscriber-abnormal value:表示用户线异常,取值范围为1~16。
subscriber-busy value:被叫用户线忙信号值,取值范围为1~16。
subscriber-charge value:表示用户线空闲,并且需要计费,取值范围为1~16。
subscriber-idle value:被叫用户线空闲信号值,取值范围为1~16。用于配置R2信令中的KB信号,表示被叫用户线状态(如空闲),起证实和控制接续的作用。实际应用时必须确保两端的KB值相同,否则即便被叫空闲,呼叫也可能无法正常建立。即如果两端都为路由器,则应使两端的KB值配置相同;如果一端为PBX交换机,而另一端为路由器,则调整路由器KB值,确保与PBX的KB值一致。
以上参数缺省值随R2信令所使用的国家模式的不同而不同。
【描述】
register-value命令用来配置R2信令中各记发器信号值。undo register-value命令恢复R2信令中各记发器信号值为缺省值。当配置信号值为16时,表明不存在相应信号功能。例如有些国家的国标规范中对于发码位次没有请求前一位信号功能,此时req-lastfirstdigit就为16。
配置register-value命令,主要是通过发送指定的请求信号,从而让对端发送相应的响应信号。例如对于register-value callingcategory命令,入局端发送指定信号来请求出局端发送主叫业务类别。
此命令仅用于R2信令。
有些国家记发器信号编码方案不一定都支持上述所有的记发器信号(例如ITU-T建议中只有callingcategory而没有billingcategory信号)因而如无特殊需要,请使用默认缺省值。
相关配置可参考命令group-b enable。
# 配置通过指定后向信号(信号值7)来请求出局端发送主叫业务类别。
[Sysname-cas1/0:0] register-value req-callingcategory 7
1.1.93  renew
renew ABCD
undo renew
R2信令视图
【缺省级别】
2:系统级
ABCD:表示各信号位在传输中的缺省值,取值为0或1。缺省值随着R2信令使用的国家模式的不同而不同。
【描述】
renew命令用来配置R2信令中c、d两信号位的信号值。undo renew命令用来恢复c、d两信号位的信号值为缺省值。缺省值随着R2信令使用的国家模式的不同而改变。
此命令仅用于R2信令。
在R2信令中,A和B用来传输有效信息,具体的传输信号和设定值无关;C和D不传输有效信息,通常采用设定的信号值作为传输信号。因此对于R2信令,此命令只对C和D有意义。
通过此命令可以使C、D两位的取值适配于各国的线路信令的编码规范,例如对于中国R2信令,其C、D两位是固定取值为1、1。但是对于其它大多数国家而言,其C、D位取值为0、1。
相关配置可参考命令cas和reverse。
# 配置R2线路信令的C位和D位信号值都为1。
[Sysname-cas1/0:0] renew 0011
1.1.94  reverse
reverse ABCD
undo reverse
R2信令视图
【缺省级别】
2:系统级
ABCD:表示各信号位是否进行反转变换,各bit位取值为0或1。缺省ABCD取值为0000,即不启动反转变换功能。
【描述】
reverse命令用来配置线路信号反转模式。undo reverse命令用来把当前线路信令值的ABCD位中对应于上次所执行的reverse命令参数中为1的位进行翻转。
此命令仅用于R2信令。
使用该命令可以在线路信令发送之前和接收之后对ABCD位进行反转变换,即0变为1,1变为0。当某位取值为1时表示该位需要被反转。
相关配置可参考命令cas和renew。
# 反转R2线路信令的B位和D位。
[Sysname-cas1/0:0] reverse 0101
seizure-ack enable
undo seizure-ack enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
seizure-ack enable命令用来配置在R2协议的线路信令交互过程中,出局端要求入局端必须发送占用确认信号。undo seizure-ack enable命令用来恢复缺省情况。
缺省情况下,出局端要求入局端发送占用确认信号功能。
此命令仅用于R2信令。
通常,入局端接收到对端(出局端)发来的占用信号后会发送占用确认信号。但是,目前一些国家的R2线路信令编码方案中允许不发送占用确认信号,在这种情况下可使用seizure-ack命令来适配这种信令编码方案。若出局端不要求占用确认信号,则入局端收到占用信号后也无需以占用确认信号回应。
相关配置可参考命令timer dl seizure。
# 禁止入局端发送占用确认信号。
[Sysname-cas1/0:0] undo seizure-ack enable
1.1.96  select-mode
select-mode { max | maxpoll | min | minpoll }
undo select-mode
R2信令视图
【缺省级别】
2:系统级
max:最大选路,从当前能用的时隙中选编号最大的使用。
maxpoll:最大循环选路,第一次使用时从当前能用的时隙中选编号最大的使用,下一次使用时,按从大到小的顺序依次选择比其小的能用的时隙,比如32个时隙中,TS31时隙和TS29时隙不可用,则第一次选路时选择TS30时隙,第二次选路时选择TS28时隙。
min:最小选路,从当前能用的时隙中选编号最小的使用。
minpoll:最小循环选路,第一次使用时从当前能用的时隙中选编号最小的使用,下一次使用时,按从小到大的顺序依次选择比其大的能用的时隙,比如32个时隙中,TS1时隙和TS3时隙不可用,则第一次选路时选择TS2时隙,第二次选路时选择TS4时隙。
【描述】
select-mode命令用来配置E1/T1中继选路模式。undo select-mode命令用来恢复缺省情况。
缺省情况下,E1/T1中继选路模式为最小选路方式。
相关配置可参考命令cas和trunk-direction。
# 为E1接口上的5号时隙(TS)组配置中继选路模式为max。
[Sysname-cas1/0:5] select-mode max
undo sendring ringbusy enable
R2信令视图
【缺省级别】
2:系统级
无
【描述】
sendring ringbusy enable命令用来配置被叫侧设备向主叫用户发送忙音信号。undo sendring ringbusy enable命令用来禁止被叫侧设备向主叫用户发送忙音信号。
缺省情况下,被叫侧设备向主叫用户发送忙音信号。
此命令仅用于R2信令。
相关配置可参考命令timer ring。
# 配置0号E1接口上5号时隙(TS)组作为入局端时使能向主叫侧发送忙音。
[Sysname-cas1/0:5] sendring ringbusy enable
1.1.98  signal-value
signal-value { received idle | received seize | transmit idle | transmit seize } ABCD
undo signal-value { received idle | received seize | transmit idle | transmit seize }
数字E&M语音用户线视图
【缺省级别】
2:系统级
received idle:表示数字E&M信令接收空闲信令。
received seize:表示数字E&M信令接收占用信令。
transmit idle:表示数字E&M信令发送空闲信令。
transmit seize:表示数字E&M信令发送占用信令。
【描述】
signal-value命令用来配置数字E&M信令接收空闲信令、接收占用信令、发送空闲信令、发送占用信令的ABCD比特值。undo signal-value命令用来恢复对应信令的比特值为缺省值。
缺省情况下,数字E&M信令接收空闲信令、发送空闲信令的ABCD比特值为1101,接收占用信令、发送占用信令的ABCD比特值为0101。
改变数字E&M信令的ABCD值的配置后,必须先使用shutdown命令使对应的数字E&M信令,然后再使用undo shutdown命令使其恢复服务。否则,此语音用户线将无法正常使用。
# 设置数字E&M接口发送占用信令的ABCD的比特值为1011。
[Sysname-subscriber-line1/0:0] signal-value transmit seize 1011
special-character character number
undo special-character character number
R2信令视图
【缺省级别】
2:系统级
character:特殊字符,取值范围为“#*ABCD”中的任意一个字符。
number:记发器信号的编码,取值范围为11~16。
【描述】
special-character命令用来配置记发器信号交互过程中支持的特殊字符。undo special-character命令用来取消已配置的特殊字符。
缺省情况下,没有配置特殊字符。
此命令仅用于R2信令。
由于一些国家R2信令的记发器前向I组信号除了可以表示数字号码信息外,还支持如“#”、“*”等特殊字符号码信息,为了编码这些特殊字符,需要使用special-character命令进行信号编码。
·       不允许使用special-character命令对同一个特殊字符重复配置不同信号编码。
·       不同的特殊字符请使用不同的信令值,否则可能会影响呼叫。
# 配置特殊字符“#”的记发器信号编码为11。
[Sysname-cas1/0:0] special-character # 11
subscriber-line slot-number:{ ts-set-number | 15 | 23 }
语音视图
【缺省级别】
2:系统级
slot-number:表示创建时隙(TS)组或ISDN PRI组时生成的语音用户线编号,由E1/T1端口号确定。
【描述】
subscriber-line命令用来进入E1/T1语音用户线视图。
在E1接口上,当成功地创建时隙(TS)组后,系统会根据当前E1接口号和时隙(TS)组的组号生成该时隙(TS)组对应的语音用户线,语音用户线号为“E1接口号:时隙(TS)组号”。当成功地配置ISDN PRI组后,系统会根据当前PRI接口所在E1接口的编号生成该PRI组对应的语音用户线,语音用户线号为“E1接口号:15”。
在T1接口上,当成功配置ISDN PRI组后,系统会根据当前PRI接口所在T1接口的编号生成该PRI组对应的语音用户线,语音用户线号为“T1接口号:23”。
相关配置可参考命令timeslot-set和pri-set。
# 进入语音用户线1/0:15的视图。
[Sysname-subscriber-line1/0:15]
1.1.101  tdm-clock
tdm-clock { internal | line [ primary ] }
undo tdm-clock
E1/T1接口视图
【缺省级别】
2:系统级
internal:设置E1/T1接口TDM交换时钟为设备内部晶振TDM时钟方式,此时E1/T1接口从设备主板上的晶振时钟源获取时钟;若无设备主板晶振时钟源,则从各自的E1/T1板卡上的晶振时钟源获取时钟(SIC卡上无晶振时钟源,只能从主板晶振时钟源获取时钟)。internal相当于master模式的时钟。
line:设置E1/T1接口TDM交换时钟为提取线路TDM时钟方式,即通过线路获取对端设备时钟。line相当于slave模式的时钟。
line primary:设置E1/T1接口TDM交换时钟为优先提取线路TDM时钟方式。
【描述】
tdm-clock命令用来将E1接口或T1接口的TDM交换时钟设置为相应模式。undo tdm-clock命令用来恢复缺省情况。
缺省情况下,E1POS接口的TDM交换时钟为line,其它E1接口或T1接口的TDM交换时钟为internal。
数字语音E1/T1接口之间进行TDM时隙交换时,需要保证不同E1/T1接口在进行TDM交换时时钟同步,否则会导致交换数据出现滑帧、误码等错误。
系统根据命令行接口时钟模式参数设置确定E1/T1接口时钟分配策略。主板VCPM扣卡存在时,时钟分配原则如下:
·              当所有接口参数均设为line时,系统采用接口号最小的接口时钟为标准进行TDM时隙交换;如果接口号最小的接口down掉,则采用接口号次小的接口时钟为标准进行TDM时隙交换,依此类推;
·              当有一个接口参数设置为line primary,而其他接口分别被设为line或internal时,则采用设置为line primary的接口时钟为标准进行TDM时隙交换;
·              如果一个接口设置为line,其余接口设置为internal,则采用设置为line的接口时钟进行TDM时隙交换;
·              一般情况下不允许系统内所有接口均设置为internal,否则会导致交换数据出现滑帧、误码等错误。但是如果对端设备E1/T1接口时钟设为slave模式,则本端设备上的所有E1/T1接口时钟可设为internal。
主板VCPM扣卡不存在时,各MIM/FIC卡时钟配置相互独立,但同一设备仅允许一个接口设置为line primary。
# 配置E1接口1/0的TDM时钟为line。
[Sysname-e1 1/0] tdm-clock line
1.1.102  timer dl
timer dl { answer | clear-back | clear-forward | seizure | re-answer | release-guard } time
undo timer dl { answer | clear-back | clear-forward | seizure | re-answer | release-guard }
R2信令视图
【缺省级别】
2:系统级
answer time:R2等待应答信号的超时时间间隔。当占用确认信号发送后,入局端应在该时间间隔内回送应答信号。如果入局端没有在该时间间隔内发送应答信号,出局端就拆线。取值范围是100~120000,单位是毫秒,缺省值为60000毫秒。出局端和入局端都要配置,出局端配置的是等待入局端线路应答信号的超时时间间隔,入局端配置的是等待模块内部函数调用的应答信号的超时时间间隔。
clear-back time:在入局端配置R2后向拆线信号的超时时间间隔。当入局端发送了后向拆线信号后,入局端应在该时间间隔内识别到出局端回应的前向信号。取值范围是100~60000,单位是毫秒,缺省值为10000毫秒。
clear-forward time:在出局端配置R2前向拆线信号的超时时间间隔。当出局端发送了前向拆线信号后,入局端应在该时间间隔内回送相应的线路信号(如后向拆线或释放监护信号)。取值范围是100~60000,单位是毫秒,缺省值为10000毫秒。
seizure time:在出局端配置R2占用信号的超时时间间隔。当出局端发送了占用信号后,入局端应当在该时间间隔内回应占用应答信号。取值范围是100~5000,单位是毫秒,缺省值为1000毫秒。
re-answer time:在出局端配置R2再应答信号的超时时间间隔。当出局端识别出后向拆线信号后,如果入局端没有在该时间间隔内再次发送应答信号,出局端将进行拆线处理。取值范围是100~60000,单位是毫秒,缺省值为1000毫秒。
release-guard time:在出局端配置R2后向释放信号的超时时间间隔。当出局端发送了前向拆线信号后,入局端回应了后向拆线信号后,应当在该时间间隔后发送释放监护信号。取值范围是100~60000,单位是毫秒,缺省值为10000毫秒。
【描述】
timer dl命令用来配置R2信令中各线路信号的超时时间间隔。undo timer dl命令用来恢复R2信令中各线路信号的超时时间为缺省值。
此命令仅用于R2信令。
# 配置R2线路信令中占用信号的超时时间间隔为300毫秒。
[Sysname-cas1/0:0] timer dl seize 300
1.1.103  timer dtmf
timer dtmf time
undo timer dtmf
R2信令视图
【缺省级别】
2:系统级
time:R2信令发送DTMF信号的延时时间,取值范围为50~10000,单位为毫秒。
【描述】
timer dtmf命令用来配置出局端收到占用确认信号到发送DTMF信号前的延时时间。undo timer dtmf命令用来恢复发送DTMF信号的时间间隔为缺省值。
缺省情况下,R2信令发送DTMF信号的延时时间为50毫秒。
此命令仅用于R2信令。
正常情况下,出局端接收到线路占用确认信号后,可以立刻进行DTMF发号过程。有时为了配合对端PBX交换机的收号过程,则在出局端设备上配置此命令,从而在规定时间间隔后才开始DTMF发号过程。
相关配置可参考命令dtmf enable。
只有在配置了dtmf enable命令后才可配置此命令。
# 配置R2信令接收到占用确认信号800毫秒后开始发送DTMF信号。
[Sysname-cas1/0:0] timer dtmf 800
1.1.104  timer hold
timer hold seconds
undo timer hold
BSV BRI接口视图
【缺省级别】
2:系统级
seconds:BSV BRI接口定时查询链路状态的时间间隔,取值范围为0~32767,单位为秒。
【描述】
timer hold命令用来配置BSV BRI接口定时查询链路状态的时间间隔。undo timer hold命令用来恢复缺省情况。
缺省情况下,BSV BRI接口定时查询链路状态的时间间隔为10秒。
# 设置BSV BRI2/0接口定时查询链路状态的时间间隔为100秒。
[Sysname-Bri2/0] timer hold 100
timer register-pulse persistence time
undo timer register-pulse persistence
R2信令视图
【缺省级别】
2:系统级
persistence time:R2信令记发器脉冲信号的持续时长,取值范围为50~3000,单位为毫秒,缺省值为150毫秒。
【描述】
timer register-pulse persistence命令用来配置R2信令记发器脉冲信号(A3、A4和A6等)的持续时长,undo timer register-pulse persistence命令用来恢复缺省情况。
缺省情况下,R2信令记发器脉冲信号持续时长为150毫秒。
此命令仅用于R2信令。
当入局端发送后向记发器脉冲信号(如信号A3)时,信号必须持续一定的时长。当出局端收到脉冲形式的信号A3时,必须发送前向II组信号。当出局端识别出脉冲信号A4、A6或A15时,不再发送任何前向信号,同时结束记发器信号交互过程。
相关配置可参考命令timer register-complete group-b。
# 配置R2信令记发器脉冲信号的持续时长为300毫秒。
[Sysname-cas1/0:0] timer register-pulse persistence 300
timer register-complete group-b time
undo timer register-complete group-b
R2信令视图
【缺省级别】
2:系统级
group-b time:出局端等待R2信令B组信号的超时时间间隔,取值范围为100~90000,单位为毫秒。
【描述】
timer register-complete group-b命令用来配置R2信令B组信号的超时时间间隔,当入局端转到B组交互过程后,应当在该时间间隔内发送B组信号。undo timer register-complete group-b命令用来恢复情况。
缺省情况下,出局端等待B组信号的超时时间为30000毫秒。
此命令仅用于R2信令。
相关配置可参考命令timer dl。
# 配置出局端等待R2信令B组信号的超时时间间隔为10000毫秒。
[Sysname-cas1/0:0] timer register-complete group-b 10000
1.1.107  timer ring
timer ring { ringback | ringbusy } time
undo timer ring { ringback | ringbusy }
R2信令视图
【缺省级别】
2:系统级
ringback time:播放回铃音的超时时间间隔,取值范围为1000~90000,单位是毫秒。
ringbusy time:播放忙音的超时时间间隔,取值范围是1000~90000,单位是毫秒。
【描述】
timer ring命令用来配置R2信令中播放信号音的超时时间间隔。undo timer ring命令用来恢复缺省情况。
缺省情况下,播放回铃音的超时时间间隔为60000毫秒,播放忙音的超时时间间隔为30000毫秒。
此命令仅用于R2信令。
相关配置可参考命令sendring。
# 配置R2信令播放回铃音的超时时间间隔为10000毫秒。
[Sysname-cas1/0:0] timer ring ringback 10000
1.1.108  timeslot-set
timeslot-set ts-set-number timeslot-list timeslots-list signal { e&m-delay | e&m-immediate | e&m-wink | fxo-ground | fxo-loop | fxs-ground | fxs-loop | r2 }
undo timeslot-set ts-set-number
E1/T1接口视图
【缺省级别】
2:系统级
ts-set-number:时隙(TS)组的标识号,E1的取值范围为0~30,T1的取值范围为0~23。
timeslots-list:时隙范围,表示方式包括单个数字、由逗号“,”分割开的两个数字、由连字号“-”分隔开的一对数字,或组合形式(如1-14,15,17-31)。E1接口下的取值范围为1~31,T1接口下的取值范围为1~24。在实际显示的时候,系统会自动去分别去除用于控制信令传输的16/24时隙。
signal:时隙(TS)组绑定的信令方式,一般用于配置中心局采用的信令方式,包括数字E&M信令、R2信令和数字LGS信令。
e&m-delay:指定采用数字E&M信令中的延时启动方式。
e&m-immediate:指定采用数字E&M信令中的立即启动方式。
e&m-wink:指定采用数字E&M信令中的闪断启动方式。
fxo-ground:指定采用数字LGS信令中的FXO地启动方式。
fxo-loop:指定采用数字LGS信令中的FXO回路启动方式。
fxs-ground:指定采用数字LGS信令中的FXS地启动方式。
fxs-loop:指定采用数字LGS信令中的FXS回路启动方式。
r2:指定信令方式采用ITU-T Q.421数字线路信令R2,该信令是最常用的配置信令。
【描述】
timeslot-set命令用来配置时隙(TS)组以便进行R2信令、数字E&M信令和数字LGS信令配置。undo timeslot-set 命令用来删除指定的时隙(TS)组。
缺省情况下,没有配置时隙组。
只有成功创建时隙(TS)组后,才能使用subscriber-line命令进入语音用户线,配置和语音相关的属性。
相关配置可参考命令subscriber-line和cas。
# 建立时隙(TS)组,组号为5,时隙包括TS1~TS31,信令为R2信令。
1.1.109  trunk-direction
trunk-direction timeslots timeslots-list { dual | in | out }
undo trunk-direction timeslots timeslots-list
R2信令视图
【缺省级别】
2:系统级
timeslots-list:指定了中继时隙的范围,表示方式包括单个数字、由逗号“,”分割开的两个数字、由连字号“-”分隔开的一对数字,或组合形式(如1-14,15,17-31)。其中E1接口下的取值范围是1~31,T1接口下的取值范围是1~24。
dual:双向中继。
in:入中继。
out:出中继。
【描述】
trunk-direction命令用来配置R2信令的中继方向。undo trunk-direction命令用来恢复缺省情况。
缺省情况下,中继方向为双向中继。
此命令仅用于R2信令。
当配置R2中继方向为入中继时,该中继将不会承载任何呼出呼叫。当配置R2中继方向为出中继时,该中继只能用于呼出而不能呼入。当配置为双向中继时,根据发起呼叫的主动性或被动性分别承载呼出和呼入呼叫。
为了使得R2信令通信正常,必须确保中继的两端一端为出一端为入,否则接续总是失败。如果R2中继两端都采用双向中继形式,则需要使用select-mode命令调整中继选路的策略,避免通信双方争抢时隙。
配置时应避免一端为双向中继,而另一端为出中继,否则配置双向中继的一端将总是呼出失败。
相关配置可参考命令cas和select-mode。
# 在E1接口1/0上,为5号时隙(TS)组配置中继方向为双向中继。
[Sysname-cas1/0:5] trunk-direction timeslots 1-31 dual
1.1.110  ts
ts { block | open | query | reset } timeslots timeslots-list
R2信令视图
【缺省级别】
2:系统级
block:闭塞指定时隙的中继电路,即人为的将电路设为不可用。
open:打开指定时隙的中继电路,闭塞操作的逆过程,可以重新将中继电路设为可用,并开始承载业务信息。
query:查询指定时隙的中继电路,实时显示电路的忙闲状态、打开或闭塞状态。
reset:复位指定时隙的中继电路,通常当进行人工闭塞或打开电路时,若电路的状态不能正常恢复,则需要执行复位操作。或者是由于其它原因导致电路不能自动正确复位时,往往也需要对电路进行人工复位。
timeslots timeslots-list:指定了一个时隙范围,表示方式包括单个数字、由逗号“,”分割开的两个数字、由连字号“-”分割开的一对数字,或组合形式(如1-14,15,17-31)。其中E1接口的取值范围为1~31,T1接口的取值范围为1~24。
【描述】
ts命令用来对指定时隙的中继电路进行维护操作。
相关配置可参考命令cas。
ts query命令不仅仅在R2类型的信令视图(cas)下存在,也存在于数字E&M或是数字LGS类型的信令视图(cas)下。
# 复位5号时隙(TS)组中的TS1~TS15时隙的电路,并查询TS1~TS31时隙电路的状态。
[Sysname-cas1/0:5] ts reset timeslots 1-15
[Sysname-cas1/0:5] ts query timeslots 1-31
1.1.111  mirror(数字语音用户线视图)
根据主叫号码镜像PCM或语音RTP数据:
mirror number number { pcm | { in | out | all } data } calling calling-number to { local-interface interface-type interface-number [ mac H-H-H ] | remote-ip ip-address [ port port ] }
根据接口时隙镜像PCM数据:
mirror number number pcm { bdsp | fdsp } channel-number to { local-interface interface-type interface-number [ mac H-H-H ] | remote-ip ip-address [ port port ] }
镜像所有时隙的语音RTP或命令数据:
mirror number number { in | out | all } { command | data } to { local-interface interface-type interface-number [ mac H-H-H ] | remote-ip ip-address [ port port ] }
数字语音用户线视图
【缺省级别】
2:系统级
pcm:镜像PCM数据。
in:入方向语音RTP或命令数据镜像。
data:镜像语音RTP数据。
calling calling-number:需要镜像数据的主叫号码,主叫号码必须精确匹配,最大长度为31个字符,字符串只能由0~9的数字组成。
bdsp:镜像指定时隙的后端DSP的PCM数据。
fdsp:镜像指定时隙的前端DSP的PCM数据。
command:镜像语音命令数据。
channel-number:需要镜像PCM数据的接口时隙编号,取值范围为0~29。
to:输出镜像报文到指定接口或IP地址。
【描述】
mirror命令用来镜像数字语音用户线的PCM、语音RTP或命令数据。可以根据主叫号码或接口时隙镜像,也可以镜像所有接口时隙的数据。undo mirror命令用来取消一条或所有镜像配置。
缺省情况下,不镜像任何数据。
本命令仅适用于VE1、VT1和BSV接口生成的数字语音用户线。
# 在VE1接口生成的subscriber-line 1/0:0语音用户线下,镜像主叫号码为55501234的PCM数据到以太网接口Ethernet1/1。
[Sysname] subscriber-line 1/0:0
[Sysname-subscriber-line1/0:0] mirror number 1 pcm calling 55501234 to local-interface ethernet 1/1
