06-三层技术-IP业务命令参考
05-快速转发命令
本章节下载: 05-快速转发命令  (117.06 KB)
05-快速转发命令
1 快速转发配置命令··························································································································· 1-1
1.1 快速转发配置命令···················································································································· 1-1
1.1.1 display ip fast-forwarding cache····················································································· 1-1
1.1.2 ip fast-forwarding·········································································································· 1-2
1.1.3 reset ip fast-forwarding cache························································································ 1-3
1 快速转发配置命令
1.1  快速转发配置命令
display ip fast-forwarding cache [ ip-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ip-address:显示指定IP地址的快速转发表信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display ip fast-forwarding cache命令用来显示快速转发表信息。
·              如果不指定ip-address,将显示所有快速转发表信息;
·              如果指定ip-address,将显示指定IP地址的快速转发表信息。
# 显示所有快速转发表信息。
<Sysname> display ip fast-forwarding cache
Fast-Forwarding cache:  total 3 items
Index  SIP            SPort    DIP       DPort Pro Input_If   Output_If   Flg
412 :0 7.0.0.13       68    8.0.0.1      67   17  Eth1/3   Eth1/1       7
484 :0 8.0.0.1        67    7.0.0.13     68   17  Eth1/1   Eth1/3       7
819 :0 8.0.0.1        8     7.0.0.13     0    1   Eth1/2   Eth1/3       7
表1-1 display ip fast-forwarding cache命令显示信息描述表
Index
表项索引,唯一
SIP
源IP地址
SPort
源端口号
DIP
目的IP地址
DPort
目的端口号
Pro
协议号
Input_If
输入接口号
Output_If
输出接口号
Flg
内部标记,主要是标记分片等内部操作信息
ip fast-forwarding [ inbound | outbound ]
undo ip fast-forwarding [ inbound | outbound ]
【缺省级别】
2:系统级
inbound:允许或禁止接口在入方向进行快速转发。
outbound:允许或禁止接口在出方向进行快速转发。
不加任何参数时,表示允许或禁止接口在出入两个方向都进行快速转发。
【描述】
ip fast-forwarding命令用来允许接口在入方向和/或出方向进行快速转发。undo ip fast-forwarding命令用来禁止接口在入方向和/或出方向进行快速转发。
缺省情况下,允许接口在出入两个方向都进行快速转发。
快速转发适用于高速链路接口(如以太网、帧中继等),因为低速链路本身传输率低,使用快速转发也没有实际意义。
系统支持在设备的各个高速链路接口上提供快速转发,包括以太网、同步PPP、帧中继、HDLC等;支持在配置了防火墙、NAT、GRE特性下的快速转发功能;支持在PPP MP链路上提供快速转发的功能,支持在配置了IPHC压缩或VJ压缩等业务的PPP链路上提供快速转发的功能。
·       如果要对报文转发使用基于报文的负载分担,必须在相应方向上禁止接口进行快速转发。
·       在接口上配置了快速转发后,该接口将不再发送ICMP重定向报文。
·       在接口上配置了快速转发后,该接口上的IP报文的调试信息将不再输出,也就是说debugging ip packet不起作用了。
·       对一个数据流而言,只有在该数据流进路由器的接口上使能入方向的快速转发,在出路由器的接口上使能出方向的快速转发,才能实现该数据流的快速转发功能。
·       当路由接口和物理接口不相同时(如MP、PPPoE等链路),物理接口上是否配置快速转发不会影响路由接口的快速转发功能。
# 允许接口Ethernet1/2在入方向上进行快速转发。
[Sysname] interface ethernet 1/2
[Sysname-Ethernet1/2] ip fast-forwarding inbound
# 禁止接口Ethernet1/1在出和入方向进行快速转发。
[Sysname] interface ethernet 1/1
[Sysname-Ethernet1/1] undo ip fast-forwarding
【缺省级别】
2:系统级
无
【描述】
reset ip fast-forwarding cache命令用来清除快速转发表中的内容,清除后的快速转发表不再有任何快速转发表项。
# 清除快速转发表中的内容。
<Sysname> reset ip fast-forwarding cache
