10-ACL和QoS命令参考
04-MPLS QoS命令
本章节下载: 04-MPLS QoS命令  (87.15 KB)
04-MPLS QoS命令
1 MPLS QoS配置命令······················································································································· 1-1
1.1 MPLS QoS配置命令················································································································ 1-1
1.1.1 if-match mpls-exp·········································································································· 1-1
1.1.2 qos cql protocol mpls exp····························································································· 1-1
1.1.3 qos pql protocol mpls exp····························································································· 1-2
1.1.4 remark mpls-exp············································································································ 1-2
1 MPLS QoS配置命令
1.1  MPLS QoS配置命令
if-match [ not ] mpls-exp exp-value-list
undo if-match [ not ] mpls-exp exp-value-list
类视图
【缺省级别】
2:系统级
not:不匹配该规则。
exp-value-list:EXP值的列表,取值范围为0~7,最多可以配置8个EXP值。如果指定了多个相同的EXP值,系统默认为一个;多个不同的EXP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
【描述】
if-match mpls-exp命令用来定义匹配MPLS EXP优先级的规则。undo if-match mpls-exp命令用来删除匹配MPLS EXP优先级的规则。
# 定义匹配EXP优先级为3或4的报文的规则。
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
qos cql cql-index protocol mpls exp exp-value-list queue queue-number
undo qos cql cql-index protocol mpls exp exp-value-list
【缺省级别】
2:系统级
cql-index:定制列表的组号,取值范围为1~16。
queue queue-number:定制队列的队列号,取值范围为0~16。
exp-value-list:EXP值的列表,取值范围为0~7,用户可以重复输入8个EXP值。
【描述】
qos cql protocol mpls exp命令用来配置基于MPLS协议的定制队列分类规则。undo qos cql protocol mpls exp命令用来删除相应的定制分类规则。
·              对于同一个cql-index,本命令可以重复使用,从而为同一个优先列表配置多种分类规则。
·              当存在多个规则时,设备以规则的配置顺序来匹配数据包。
# 配置基于MPLS协议的定制列表10的分类规则,设置队列2对应EXP值1。
[Sysname] qos cql 10 protocol mpls exp 1 queue 2
qos pql pql-index protocol mpls exp exp-value-list queue { bottom | middle | normal | top }
undo qos pql pql-index protocol mpls exp exp-value-list
【缺省级别】
2:系统级
pql-index:优先列表的组号,取值范围为1~16。
top、middle、normal、bottom:对应PQ的四个队列,优先级依次降低。
【描述】
qos pql protocol mpls exp命令用来配置基于MPLS协议的优先列表分类规则。undo qos pql protocol mpls exp命令用来删除相应的优先列表分类规则。
·              对于同一个pql-index,本命令可以重复使用,从而为同一个优先列表配置多种分类规则。
相关配置可参考命令qos pql protocol。
# 配置基于MPLS协议的优先列表10分类规则,设置队列top对应的EXP值为5。
[Sysname] qos pql 10 protocol mpls exp 5 queue top
remark mpls-exp exp-value
undo remark mpls-exp
流行为视图
【缺省级别】
2:系统级
exp-value:MPLS报文的EXP值,取值范围为0~7。
【描述】
remark mpls-exp命令用来配置标记MPLS报文的EXP值。undo remark mpls-exp命令用来取消标记MPLS报文的EXP值。
# 配置标记MPLS报文的EXP值为0。
[Sysname-behavior-database] remark mpls-exp 0
