06-三层技术-IP业务命令参考
11-UDP Helper命令
本章节下载: 11-UDP Helper命令  (95.7 KB)
11-UDP Helper命令
1 UDP Helper配置命令······················································································································ 1-1
1.1 UDP Helper配置命令··············································································································· 1-1
1.1.1 display udp-helper server······························································································· 1-1
1.1.2 reset udp-helper packet·································································································· 1-1
1.1.3 udp-helper enable·········································································································· 1-2
1.1.4 udp-helper port·············································································································· 1-2
1.1.5 udp-helper server··········································································································· 1-3
1 UDP Helper配置命令
1.1  UDP Helper配置命令
display udp-helper server [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
interface interface-type interface-number:显示指定接口的UDP中继转发相关信息。interface-type interface-number为接口类型和接口编号。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display udp-helper server命令用来显示UDP中继转发的相关信息。
如果不选择参数,则显示所有接口的UDP中继转发相关信息。
# 显示Ethernet1/1接口的UDP中继转发相关信息。
<Sysname> display udp-helper server interface ethernet 1/1
Interface name     Server address       Packets sent
Ethernet1/1            192.1.1.2            0
以上显示信息表示Ethernet1/1接口对应的中继转发目的服务器的IP地址为192.1.1.2,中继转发到该目的服务器的报文数为0。
【缺省级别】
2:系统级
无
【描述】
reset udp-helper packet命令用来清除UDP中继转发的报文统计数目。
相关配置可参考命令display udp-helper server。
# 清除UDP中继转发的报文统计数目。
<Sysname> reset udp-helper packet
udp-helper enable
undo udp-helper enable
【缺省级别】
2:系统级
无
【描述】
udp-helper enable命令用来使能UDP Helper功能,设备会将指定UDP端口的广播报文转换为单播报文发送给指定的目的服务器,起到中继的作用。undo udp-helper enable命令用来关闭UDP Helper功能。
缺省情况下,UDP Helper功能处于关闭状态。
# 使能UDP Helper功能。
[Sysname] udp-helper enable
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
【缺省级别】
2:系统级
port-number:需要中继转发的UDP端口号,取值范围为1~65535(不支持67和68)。
dns:对DNS的数据报文进行中继转发,对应的UDP端口号为53。
netbios-ds:对NetBIOS数据报服务的数据报文进行中继转发,对应的UDP端口号为138。
netbios-ns:对NetBIOS名字服务的数据报文进行中继转发,对应的UDP端口号为137。
tacacs:对终端访问控制器访问控制系统的数据报文进行中继转发,对应的UDP端口号为49。
tftp:对简单文件传输协议的数据报文进行中继转发,对应的UDP端口号为69。
time:对时间服务的数据报文进行中继转发,对应的UDP端口号为37。
【描述】
udp-helper port命令用来配置需要中继转发的UDP端口。undo udp-helper port命令用来取消对需要中继转发的UDP端口的配置。
缺省情况下,没有配置中继转发的UDP端口。
·              设备上最多可以配置256个需要中继转发的UDP端口。
·              关闭UDP Helper功能后,所有已配置的UDP端口都被取消。
# 配置对目的UDP端口号为100的广播报文进行中继转发。
[Sysname] udp-helper port 100
udp-helper server ip-address
undo udp-helper server [ ip-address ]
【缺省级别】
2:系统级
ip-address:目的服务器的IP地址,为点分十进制形式。
【描述】
udp-helper server命令用来配置中继转发的目的服务器。undo udp-helper server命令用来删除配置的中继转发的目的服务器。
缺省情况下,没有配置中继转发的目的服务器。
·              一个接口上最多可以配置20个中继转发的目的服务器。
·              undo udp-helper server命令后不加参数时,将会删除该接口下配置的所有目的服务器。
# 在接口Ethernet1/1上配置中继转发的目的服务器为192.1.1.2。
[Sysname] interface ethernet 1/1
[Sysname-Ethernet1/1] udp-helper server 192.1.1.2
