08-IP组播命令参考
05-MSDP命令
本章节下载: 05-MSDP命令  (181.01 KB)
05-MSDP命令
1 MSDP配置命令······························································································································ 1-1
1.1 MSDP配置命令······················································································································· 1-1
1.1.1 cache-sa-enable············································································································ 1-1
1.1.2 display msdp brief········································································································ 1-1
1.1.3 display msdp peer-status······························································································· 1-3
1.1.4 display msdp sa-cache·································································································· 1-5
1.1.5 display msdp sa-count·································································································· 1-6
1.1.6 encap-data-enable········································································································· 1-8
1.1.7 import-source················································································································ 1-8
1.1.8 msdp···························································································································· 1-9
1.1.9 originating-rp··············································································································· 1-10
1.1.10 peer connect-interface································································································ 1-10
1.1.11 peer description········································································································· 1-11
1.1.12 peer mesh-group········································································································ 1-12
1.1.13 peer minimum-ttl········································································································ 1-12
1.1.14 peer request-sa-enable······························································································· 1-13
1.1.15 peer sa-cache-maximum····························································································· 1-14
1.1.16 peer sa-policy············································································································ 1-14
1.1.17 peer sa-request-policy································································································ 1-15
1.1.18 reset msdp peer········································································································· 1-16
1.1.19 reset msdp sa-cache·································································································· 1-17
1.1.20 reset msdp statistics·································································································· 1-17
1.1.21 shutdown (MSDP view)······························································································ 1-18
1.1.22 static-rpf-peer············································································································ 1-18
1.1.23 timer retry·················································································································· 1-19
1 MSDP配置命令
1.1  MSDP配置命令
cache-sa-enable
undo cache-sa-enable
公网实例MSDP视图/VPN实例MSDP视图
【缺省级别】
2:系统级
无
【描述】
cache-sa-enable命令用来使能SA消息缓存机制,即缓存SA消息中所包含的(S,G)表项。undo cache-sa-enable命令用来关闭SA消息缓存机制。
缺省情况下,SA消息缓存机制处于使能状态,即设备在收到SA消息后缓存其中包含的(S,G)表项。
# 在公网实例中使能SA消息缓存机制,使设备在收到SA消息后缓存其中包含的(S,G)表项。
[Sysname] msdp
[Sysname-msdp] cache-sa-enable
# 在VPN实例mvpn中使能SA消息缓存机制,使设备在收到SA消息后缓存其中包含的(S,G)表项。
[Sysname] msdp vpn-instance mvpn
[Sysname-msdp-mvpn] cache-sa-enable
display msdp [ all-instance | vpn-instance vpn-instance-name ] brief [ state { connect | down | listen | shutdown | up } ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all-instance:指定所有VPN实例。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
state:查看指定状态的MSDP对等体。
connect:查看处于连接状态的MSDP对等体。
down:查看处于连接失败状态的MSDP对等体。
listen:查看处于监听状态的MSDP对等体。
shutdown:查看处于手动关闭状态的MSDP对等体。
up:查看处于会话状态的MSDP对等体。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display msdp brief命令用来查看MSDP对等体的简要信息。
需要注意的是,如果未指定all-instance和vpn-instance参数,则只显示公网实例的相关信息。
# 查看公网实例中所有状态的MSDP对等体的简要信息。
<Sysname> display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
  Configured   Up           Listen       Connect      Shutdown     Down
  1            1            0            0            0            0
  Peer's Address    State    Up/Down time    AS     SA Count   Reset Count
  20.20.20.20       Up       00:00:13        100    0          0
表1-1 display msdp brief命令显示信息描述表
公网MSDP对等体的简要信息
Configured
已配置的MSDP对等体的数量
Up
处于up状态的MSDP对等体的数量
Listen
处于listen状态的MSDP对等体的数量
Connect
处于connect状态的MSDP对等体的数量
Shutdown
处于shutdown状态的MSDP对等体的数量
Down
处于down状态的MSDP对等体的数量
Peer's Address
MSDP对等体的地址
MSDP对等体的状态:
·       Up:连接建立,处于会话状态
·       Listen:连接建立,本地作为服务器端,处于监听状态
·       Connect:连接未建立,本地作为客户端,处于连接状态
·       Shutdown:关闭状态
·       Down:连接失败
Up/Down time
MSDP对等体连接已建立/失败的时长
AS
MSDP对等体所在自治系统的号码,“?”表示无法获得自治系统号码
SA Count
缓存中(S,G)表项的数量
Reset Count
MSDP对等体连接复位的次数
display msdp [ all-instance | vpn-instance vpn-instance-name ] peer-status [ peer-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
peer-address:查看指定MSDP对等体的详细状态信息。如果未指定本参数,将显示所有MSDP对等体的详细状态信息。
【描述】
display msdp peer-status命令用来查看MSDP对等体的详细状态信息。
相关配置可参考命令peer connect-interface、peer description、peer mesh-group、peer minimum-ttl、peer request-sa-enable、peer sa-cache-maximum、peer sa-policy和peer sa-request-policy。
# 查看公网实例MSDP对等体10.110.11.11的详细状态信息。
<Sysname> display msdp peer-status 10.110.11.11
MSDP Peer Information of VPN-Instance: public net
  MSDP Peer 20.20.20.20, AS 100
  Description:
  Information about connection status:
    State: Up
    Up/down time: 14:41:08
    Resets: 0
    Connection interface: LoopBack0 (20.20.20.30)
    Number of sent/received messages: 867/947
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 14:42:40
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
表1-2 display msdp peer-status命令显示信息描述表
公网MSDP对等体的信息
MSDP Peer
MSDP对等体的地址
AS
MSDP对等体的状态:
·       Up:连接建立,处于会话状态
·       Shutdown:关闭状态
·       Down:连接失败
Up/Down time
MSDP对等体连接已建立/失败的时长
Resets
MSDP对等体连接复位的次数
用于与对端对等体地址建立TCP连接的接口及其IP地址
MSDP通过该连接发送和接收的消息数目
丢弃的待发送信息
最近一次清除该MSDP对等体信息时刻距现在的时间
SA消息过滤列表信息:
·       Import policy:接收指定MSDP对等体的SA消息的过滤列表
·       Export policy:转发指定MSDP对等体的SA消息的过滤列表
SA请求消息信息:
·       Policy to accept SA-Request messages:接收或转发来自指定MSDP对等体SA消息的过滤规则
·       Sending SA-Requests status:是否使能在收到一个新的组加入消息时,向其指定的MSDP对等体发送SA请求消息
封装在SA消息中的组播数据包的最小TTL值
已缓存从指定MSDP对等体学到的(S,G)表项的数量
可缓存从指定MSDP对等体学到的(S,G)表项的最大数量
Input queue size
输入缓存中所缓存的数据长度
Output queue size
输出缓存中所缓存的数据长度
MSDP消息的统计数:
·       Count of RPF check failure:未通过RPF检查而被丢弃的SA消息的统计数
·       Incoming/outgoing SA messages:接收和发送的SA消息的统计数
·       Incoming/outgoing SA requests:接收和发送的SA请求消息的统计数
·       Incoming/outgoing SA responses:接收和发送的SA响应消息的统计数
·       Incoming/outgoing data packets:接收和发送的封装有组播数据的SA消息的统计数
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address | source-address | as-number ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-address:指定(S,G)表项中的组播组地址,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示所有组对应的(S,G)表项信息。
source-address:指定(S,G)表项中的组播源地址。如果未指定本参数,将显示所有源对应的(S,G)表项信息。
as-number:指定自治系统号码,取值范围为1~4294967295。如果未指定本参数,将显示所有自治系统的(S,G)表项信息。
【描述】
display msdp sa-cache命令用来查看SA缓存中的(S,G)表项信息。
·              如果未指定all-instance和vpn-instance参数,则只显示公网实例的相关信息。
·              如果未指定group-address和source-address参数,将显示所有(S,G)表项的信息。
·              只有配置了cache-sa-enable命令之后,执行本命令才会有相应的输出。
相关配置可参考命令cache-sa-enable。
# 查看公网实例SA缓存中的(S,G)表项信息。
<Sysname> display msdp sa-cache
MSDP Source-Active Cache Information of VPN-Instance: public net
 MSDP Total Source-Active Cache - 5 entries
 MSDP matched 5 entries
(Source, Group)              Origin RP       Pro  AS     Uptime   Expires
(10.10.1.2, 225.1.1.1)       10.10.10.10     BGP  100    00:00:11 00:05:49
(10.10.1.3, 225.1.1.1)       10.10.10.10     BGP  100    00:00:11 00:05:49
(10.10.1.2, 225.1.1.2)       10.10.10.10     BGP  100    00:00:11 00:05:49
(10.10.2.1, 225.1.1.2)       10.10.10.10     BGP  100    00:00:11 00:05:49
(10.10.1.2, 225.1.2.2)       10.10.10.10     BGP  100    00:00:11 00:05:49
表1-3 display msdp sa-cache命令显示信息描述表
公网SA缓存信息
SA缓存中(S,G)表项的总数
MSDP匹配的(S,G)表项总数
(Source, Group)
表示(S,G)表项:(源地址,组地址)
Origin RP
生成该(S,G)表项的源RP地址
Pro
源RP的自治系统号码来源于何种协议类型,“?”表示无法获得协议类型
AS
源RP的自治系统号码,“?”表示无法获得自治系统号码
Uptime
(S,G)表项缓存已存在的时间
Expires
(S,G)表项缓存超时剩余时间
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-count [ as-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display msdp sa-count命令用来查看SA缓存中(S,G)表项的数量。
# 查看公网实例SA缓存中(S,G)表项的数量。
<Sysname> display msdp sa-count
MSDP Source-Active Count Information of VPN-Instance: public net
  Number of cached Source-Active entries, counted by Peer
  Peer's Address     Number of SA
  10.10.10.10        5
  Number of source and group, counted by AS
  AS     Number of source    Number of group
  ?      3                   3
  Total 5 Source-Active entries
表1-4 display msdp sa-count命令显示信息描述表
公网缓存中的SA消息数量信息
按照对等体,统计缓存中(S,G)表项的数量
Peer's Address
发送SA消息的MSDP对等体地址
Number of SA
来自该对等体的(S,G)表项数量
按照源RP所属的自治系统,统计缓存中(S,G)表项的数量
AS
Number of source
来自该自治系统的组播源的统计数
Number of group
来自该自治系统的组播组的统计数
encap-data-enable
undo encap-data-enable
【缺省级别】
2:系统级
无
【描述】
encap-data-enable命令用来使能在SA消息中封装注册消息。undo encap-data-enable命令用来禁止在SA消息中封装注册消息。
缺省情况下,在SA消息中只包含(S,G)表项,不封装注册消息。
# 在公网实例中使能在SA消息中封装注册消息。
[Sysname] msdp
[Sysname-msdp] encap-data-enable
# 在VPN实例mvpn中使能在SA消息中封装注册消息。
[Sysname-msdp-mvpn] encap-data-enable
1.1.7  import-source
import-source [ acl acl-number ]
undo import-source
【缺省级别】
2:系统级
acl-number:指定基本或高级访问控制列表编号,取值范围为2000~3999。基本访问控制列表用来对源进行过滤,高级访问控制列表用来对源或组进行过滤。如果未指定本参数,将不通告任何组播源信息。
在规则匹配时,对于ACL规则中的协议号不作检查。
【描述】
import-source命令用来配置SA消息的创建规则。undo import-source命令用来取消SA消息的创建规则。
缺省情况下,在创建SA消息时,对其通告的(S,G)表项不作限制,即SA消息通告域内所有的(S,G)表项。
除了可以使用本命令控制SA消息的创建,还可以使用peer sa-policy命令控制SA消息的接收和转发。
相关配置可参考命令peer sa-policy。
# 在公网实例中配置MSDP对等体创建SA消息时,通告组播路由表中的特定的(S,G)表项:组播源在10.10.0.0/16网段,组播组地址为225.1.0.0/16。
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
# 在VPN实例mvpn中配置MSDP对等体创建SA消息时,通告组播路由表中的特定的(S,G)表项:组播源在10.10.0.0/16网段,组播组地址为225.1.0.0/16。
[Sysname-msdp-mvpn] import-source acl 3101
1.1.8  msdp
msdp [ vpn-instance vpn-instance-name ]
undo msdp [ vpn-instance vpn-instance-name ]
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则本配置只针对公网实例。
【描述】
msdp命令用来使能公网实例或VPN实例中的MSDP,并进入公网实例或VPN实例MSDP视图。undo msdp命令用来关闭公网实例或VPN实例中的MSDP,并清除公网实例或VPN实例MSDP视图下的所有配置,以释放MSDP占用的资源。
缺省情况下,MSDP处于关闭状态。
需要注意的是,只有在相应实例中先使能了IP组播路由,本命令才能生效。
相关配置可参考“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 使能公网实例中的IP组播路由,并使能公网实例中的MSDP、进入公网实例MSDP视图。
[Sysname] multicast routing-enable
[Sysname] msdp
[Sysname-msdp]
# 使能VPN实例mvpn中的IP组播路由,并使能公网实例中的MSDP、进入VPN实例mvpn的MSDP视图。
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn]route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname-msdp-mvpn]
originating-rp interface-type interface-number
undo originating-rp
【缺省级别】
2:系统级
【描述】
originating-rp命令用来配置接口地址为SA消息的RP地址。undo originating-rp命令用来取消将接口地址配置为SA消息的RP地址。
缺省情况下,SA消息的RP地址为PIM的RP地址。
# 在公网实例中配置接口Ethernet1/1的IP地址为SA消息的RP地址。
[Sysname] msdp
[Sysname-msdp] originating-rp ethernet 1/1
# 在VPN实例mvpn中配置接口Ethernet1/1的IP地址为SA消息的RP地址。
[Sysname-msdp-mvpn] originating-rp ethernet 1/1
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
【缺省级别】
2:系统级
peer-address:指定MSDP对等体的地址。
interface-type interface-number:指定接口类型和接口编号,本地路由器以该接口的主地址为源IP与远端MSDP对等体建立TCP连接。
【描述】
peer connect-interface命令用来创建MSDP对等体连接。undo peer connect-interface命令用来删除MSDP对等体。
缺省情况下,没有创建MSDP对等体连接。
执行其它peer命令之前必须先执行本命令,否则系统将提示peer不存在。
相关配置可参考命令static-rpf-peer。
# 在公网实例中把使用IP地址125.10.7.6的路由器配置成为本地路由器的MSDP对等体,接口Ethernet1/1为本地连接端口。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface ethernet 1/1
# 在VPN实例mvpn中把使用IP地址125.10.7.6的路由器配置成为本地路由器的MSDP对等体,接口Ethernet1/1为本地连接端口。
[Sysname-msdp-mvpn] peer 125.10.7.6 connect-interface ethernet 1/1
peer peer-address description text
undo peer peer-address description
【缺省级别】
2:系统级
text:描述性文本,为1~80个字符的字符串,可以包含空格,区分大小写。
【描述】
peer description命令用来配置MSDP对等体的描述信息。undo peer description命令用来删除MSDP对等体的描述信息。
缺省情况下,MSDP对等体没有描述信息。
相关配置可参考命令display msdp peer-status。
# 在公网实例中为IP地址为125.10.7.6的MSDP对等体添加描述信息“CustomerA”,以指明该路由器为客户A。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description CustomerA
# 在VPN实例mvpn中为IP地址为125.10.7.6的MSDP对等体添加描述信息“CustomerA”,以指明该路由器为客户A。
[Sysname-msdp-mvpn] peer 125.10.7.6 description CustomerA
peer peer-address mesh-group name
undo peer peer-address mesh-group
【缺省级别】
2:系统级
【描述】
peer mesh-group命令用来把MSDP对等体加入全连接组。undo peer mesh-group命令用来把MSDP对等体从全连接组中删除。
缺省情况下,MSDP对等体不属于任何全连接组。
# 在公网实例中把IP地址为125.10.7.6的MSDP对等体加入到全连接组“Group1”。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Group1
# 在VPN实例mvpn中把IP地址为125.10.7.6的MSDP对等体加入到全连接组“Group1”。
[Sysname-msdp-mvpn] peer 125.10.7.6 mesh-group Group1
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
【缺省级别】
2:系统级
ttl-value:指定最小TTL(Time to live,生存时间)值,取值范围为0~255。
【描述】
peer minimum-ttl命令用来配置封装在SA消息中组播数据报文的TTL阈值。undo peer minimum-ttl命令用来恢复缺省情况。
缺省情况下,封装在SA消息中组播数据报文的TTL阈值为0。
# 在公网实例中进行配置,使只有TTL值大于或等于10的组播数据报文才能被封装到SA消息中,并转发给MSDP对等体110.10.10.1。
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
# 在VPN实例mvpn中进行配置,使只有TTL值大于或等于10的组播数据报文才能被封装到SA消息中,并转发给MSDP对等体110.10.10.1。
[Sysname-msdp-mvpn] peer 110.10.10.1 minimum-ttl 10
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
【缺省级别】
2:系统级
【描述】
peer request-sa-enable命令用来使能发送SA请求消息,即当路由器收到新的组加入消息时,向其MSDP对等体发送SA请求消息。undo peer request-sa-enable命令用来禁止发送SA请求消息。
缺省情况下,路由器收到新的组加入消息时,不向其MSDP对等体发送SA请求消息,而是等待下一周期SA消息的到来。
需要注意的是,在使能发送SA请求消息功能之前,必须首先关闭SA消息缓存机制,否则设备不会向外发送SA请求消息。
# 在公网实例中关闭SA消息缓存机制,并配置当路由器收到新的组加入消息时,向其MSDP对等体125.10.7.6发送SA请求消息。
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
# 在VPN实例mvpn中关闭SA消息缓存机制,并配置当路由器收到新的组加入消息时,向其MSDP对等体125.10.7.6发送SA请求消息。
[Sysname-msdp-mvpn] undo cache-sa-enable
[Sysname-msdp-mvpn] peer 125.10.7.6 request-sa-enable
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
【缺省级别】
2:系统级
sa-limit:指定可缓存的(S,G)表项的最大数量,取值范围为1~8192。
【描述】
peer sa-cache-maximum命令用来配置可缓存从指定MSDP对等体学到的(S,G)表项的最大数量。undo peer sa-cache-maximum命令用来恢复缺省情况。
缺省情况下,可缓存从任一MSDP对等体学到的(S,G)表项的最大数量为8192。
相关配置可参考命令display msdp sa-count、display msdp peer-status和display msdp brief。
# 在公网实例中配置最多可缓存100条从MSDP对等体125.10.7.6学到的(S,G)表项。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
# 在VPN实例mvpn中配置最多可缓存100条从MSDP对等体125.10.7.6学到的(S,G)表项。
[Sysname-msdp-mvpn] peer 125.10.7.6 sa-cache-maximum 100
peer peer-address sa-policy { import | export } [ acl acl-number ]
undo peer peer-address sa-policy { import | export }
【缺省级别】
2:系统级
import:表示对来自指定MSDP对等体的SA消息进行过滤。
export:表示对转发给指定MSDP对等体的SA消息进行过滤。
acl-number:指定高级访问控制列表编号,取值范围为3000~3999。如果未指定本参数,将过滤掉所有携带(S,G)表项的SA消息。
【描述】
peer sa-policy命令用来配置接收或转发SA消息的过滤规则。undo peer sa-policy命令用来删除接收或转发SA消息的过滤规则。
缺省情况下,不对接收或转发的SA消息进行过滤,即接收或转发所有SA消息。
除了可以使用本命令控制SA消息的接收和转发,还可以使用import-source命令控制SA消息的创建。
相关配置可参考命令display msdp peer-status和import-source。
# 在公网实例中配置向MSDP对等体125.10.7.6只转发通过ACL 3100过滤的SA消息。
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
# 在VPN实例mvpn中配置向MSDP对等体125.10.7.6只转发通过ACL 3100过滤的SA消息。
[Sysname-msdp-mvpn] peer 125.10.7.6 sa-policy export acl 3100
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
【缺省级别】
2:系统级
acl-number:指定基本访问控制列表编号,取值范围为2000~2999。如果指定了本参数,只处理符合该列表的组播组的SA请求消息,其它的被忽略;如果未指定本参数,则忽略所有SA请求。
【描述】
peer sa-request-policy命令用来配置SA请求消息的过滤规则。undo peer sa-request-policy命令用来删除SA请求消息的过滤规则。
缺省情况下,不对SA请求消息进行过滤。
# 在公网实例中配置SA请求消息的过滤规则:在来自MSDP对等体175.58.6.5的SA请求消息中,除了来自组地址范围225.1.1.0/24的被接收外,其它的均被忽略。
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
# 在VPN实例mvpn中配置SA请求消息的过滤规则:在来自MSDP对等体175.58.6.5的SA请求消息中,除了来自组地址范围225.1.1.0/24的被接收外,其它的均被忽略。
[Sysname-msdp-mvpn] peer 175.58.6.5 sa-request-policy acl 2001
reset msdp [ all-instance | vpn-instance vpn-instance-name ] peer [ peer-address ]
【缺省级别】
2:系统级
peer-address:重置与指定MSDP对等体的TCP连接。如果未指定本参数,则重置与所有MSDP对等体的TCP连接。
【描述】
reset msdp peer命令用来重置与MSDP对等体的TCP连接,并清除MSDP对等体的所有统计信息。
需要注意的是,如果未指定all-instance和vpn-instance参数,则只清除公网实例的相关信息。
# 重置公网实例中与MSDP对等体125.10.7.6的TCP连接,并清除该MSDP对等体的所有统计信息。
<Sysname> reset msdp peer 125.10.7.6
reset msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address ]
【缺省级别】
2:系统级
group-address:从SA缓存中清除指定组播组所对应的(S,G)表项,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,则从SA缓存中清除所有的(S,G)表项。
【描述】
reset msdp sa-cache命令用来清除SA缓存中的(S,G)表项。
需要注意的是,如果未指定all-instance和vpn-instance参数,则只清除公网实例的相关表项。
相关配置可参考命令cache-sa-enable和display msdp sa-cache。
# 清除公网实例SA缓存中组播组225.5.4.3所对应的(S,G)表项。
<Sysname> reset msdp sa-cache 225.5.4.3
reset msdp [ all-instance | vpn-instance vpn-instance-name ] statistics [ peer-address ]
【缺省级别】
2:系统级
peer-address:清除指定MSDP对等体的统计信息。如果未指定本参数,则清除所有MSDP对等体的统计信息。
【描述】
reset msdp statistics命令用来在不重置MSDP对等体的情况下,清除MSDP对等体的统计信息。
# 清除公网实例MSDP对等体125.10.7.6的统计信息。
<Sysname> reset msdp statistics 125.10.7.6
shutdown peer-address
undo shutdown peer-address
【缺省级别】
2:系统级
【描述】
shutdown命令用来手工关闭MSDP对等体连接。undo shutdown命令用来重新打开MSDP对等体连接。
缺省情况下,MSDP对等体处于连接状态。
# 在公网实例中手工关闭MSDP对等体125.10.7.6的连接。
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
# 在VPN实例mvpn中手工关闭MSDP对等体125.10.7.6的连接。
[Sysname-msdp-mvpn] shutdown 125.10.7.6
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
【缺省级别】
2:系统级
rp-policy ip-prefix-name:指定基于SA消息中RP地址的过滤策略。ip-prefix-name表示过滤策略的名称,为1~19个字符的字符串,区分大小写。
【描述】
static-rpf-peer命令用来配置静态RPF对等体。undo static-rpf-peer命令用来删除静态RPF对等体。
缺省情况下,没有配置静态RPF对等体。
在同时配置多个静态RPF对等体时,必须遵守如下两种配置方法:
(1)      都使用rp-policy参数时:多个静态RPF对等体同时起作用,并按照所配置的前缀列表对SA消息进行过滤,只接收RP地址通过过滤的SA消息。如果多个静态RPF对等体同时使用相同的过滤策略,则从其中一个对等体收到的SA消息会向其它对等体转发。
(2)      都不使用rp-policy参数时:按照配置的先后顺序,只有第一个连接状态是up的静态RPF对等体是激活的,接收来自该对等体所有的SA消息,而来自其它静态RPF对等体的SA消息将被丢弃。如果这个激活的静态RPF对等体失效(如配置取消或连接断开),则仍然按照配置的先后顺序,重新选择第一个连接状态是up的静态RPF对等体作为激活的静态RPF对等体。
相关配置可参考命令display msdp peer-status和ip prefix-list。
# 在公网实例中配置静态RPF对等体。
[Sysname] ip ip-prefix list1 permit 130.10.0.0 16 great-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface ethernet 1/1
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
# 在VPN实例mvpn中配置静态RPF对等体。
[Sysname-msdp-mvpn] peer 130.10.7.6 connect-interface ethernet 1/1
[Sysname-msdp-mvpn] static-rpf-peer 130.10.7.6 rp-policy list1
1.1.23  timer retry
timer retry interval
undo timer retry
【缺省级别】
2:系统级
interval:表示建立MSDP对等体连接的重试周期,取值范围为1~60,单位为秒。
【描述】
timer retry命令用来配置建立MSDP对等体连接的重试周期。undo timer retry命令用来恢复缺省情况。
缺省情况下,建立MSDP对等体连接的重试周期为30秒。
# 在公网实例中配置建立MSDP对等体连接的重试周期为60秒。
[Sysname] msdp
[Sysname-msdp] timer retry 60
# 在VPN实例mvpn中配置建立MSDP对等体连接的重试周期为60秒。
[Sysname-msdp-mvpn] timer retry 60
