- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
18-T11-FC-ZONE-SERVER-MIB | 78.36 KB |
About this MIB
Use this MIB to implement the functions supported by RFC 4936. A switch does not support this MIB when it is operating is NPV mode.
MIB file name
rfc4936-t11-fc-zone-server.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11ZoneServerMIB(160)
Tabular objects
t11ZsActiveTable
About this table
This table obtains information about the active zone set in a VSAN.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, and t11ZsServerFabricIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11ZsActiveZoneSetName (1.3.6.1.2.1.160.1.1.10.1.1) |
read-only |
T11ZoningName |
OCTET STRING (1..64) |
Active zone set name. |
As per the MIB. |
t11ZsActiveActivateTime (1.3.6.1.2.1.160.1.1.10.1.2) |
read-only |
TimeStamp |
TimeTicks (0.. 4294967295) |
Time when the zone set is most recently activated since the last system reboot. |
As per the MIB. |
t11ZsActiveZoneTable
About this table
This table obtains information about zones in the active zone set in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11ZsServerFabricIndex, and t11ZsActiveZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11ZsActiveZoneIndex (1.3.6.1.2.1.160.1.1.11.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Zone index. |
As per the MIB. |
t11ZsActiveZoneName (1.3.6.1.2.1.160.1.1.11.1.2) |
read-only |
T11ZoningName |
Zone name. |
As per the MIB. |
t11ZsActiveZoneBroadcastZoning (1.3.6.1.2.1.160.1.1.11.1.3) |
read-only |
TruthValue |
true(1) |
Indicates whether broadcast zoning is enabled. |
When read, this object always returns.false(2). |
t11ZsActiveZoneHardZoning (1.3.6.1.2.1.160.1.1.11.1.4) |
read-only |
TruthValue |
true(1) |
Indicates whether hardware zoning is enabled. |
When read, this object always returns true(1). |
t11ZsActiveZoneMemberTable
About this table
This table obtains information about members of a zone in the active zone set in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11ZsServerFabricIndex, t11ZsActiveZoneIndex, and t11ZsActiveZoneMemberIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11ZsActiveZoneMemberIndex (1.3.6.1.2.1.160.1.1.12.1.1) |
not-accessible |
Unsigned32 |
Member index. |
As per the MIB. |
t11ZsActiveZoneMemberFormat (1.3.6.1.2.1.160.1.1.12.1.2) |
read-only |
T11ZsZoneMemberType |
Unsigned32 (0..255) |
Member type. |
As per the MIB. |
t11ZsActiveZoneMemberID (1.3.6.1.2.1.160.1.1.12.1.3) |
read-only |
OCTET STRING |
OCTET STRING |
Member ID. |
As per the MIB. |
