- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
01-FC-MGMT-MIB | 147.50 KB |
FC-MGMT-MIB
About this MIB
Use this MIB to define management information specific to Fibre Channel-attached devices. A switch does not support this MIB when operating in NPV mode.
MIB file name
rfc4044-fc-mgmt.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).fcMgmtMIB(56)
Tabular objects
fcmPortTable
About this table
This table obtains information about Fibre Channel ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
fcmPortInstanceIndex (1.3.6.1.2.1.10.56.1.3.1.1) |
read-only |
Unsigned32 |
Unsigned32(1..4294967295) |
Port index. |
When read, this object always returns 1. |
fcmPortWwn (1.3.6.1.2.1.10.56.1.3.1.2) |
read-only |
FcNameIdOrZero |
OCTET STRING (0 | 8 | 16) |
Port name. |
As per the MIB. |
fcmPortNodeWwn (1.3.6.1.2.1.10.56.1.3.1.3) |
read-only |
FcNameIdOrZero |
Node name. |
When read, this object always returns a zero-length string. |
fcmPortAdminType (1.3.6.1.2.1.10.56.1.3.1.4) |
read-write |
FcPortType |
Administratively desired type of the port. |
The value is 6 for an F_Port, 8 for an E_Port, and 10 for a G_Port. A VFC interface cannot act as a G_Port. Only the read operation is supported for member ports of an FC aggregation group. |
fcmPortOperType (1.3.6.1.2.1.10.56.1.3.1.5) |
read-only |
FcPortType |
Current operational type of the port. |
As per the MIB. |
fcmPortFcCapClass (1.3.6.1.2.1.10.56.1.3.1.6) |
read-only |
FcClasses |
BITS { classF(0), class1(1), class2(2), class3(3), class4(4), class5(5), class6(6) } |
Classes of service capability of the port. |
As per the MIB. |
fcmPortFcOperClass (1.3.6.1.2.1.10.56.1.3.1.7) |
read-only |
FcClasses |
Classes of service that are currently operational on the port. |
As per the MIB. |
fcmPortTransmitterType (1.3.6.1.2.1.10.56.1.3.1.8) |
read-only |
INTEGER |
unknown(1), other(2), shortwave850nm(3), longwave1550nm(4), longwave1310nm(5), electrical(6) |
Technology of the port transceiver. |
When read, this object always returns Unknown. |
fcmPortConnectorType (1.3.6.1.2.1.10.56.1.3.1.9) |
read-only |
INTEGER |
unknown(1), other(2), gbic(3), embedded(4), glm(5), gbicSerialId(6), gbicNoSerialId(7), sfpSerialId(8), sfpNoSerialId(9) |
Module type of the port connector. |
fcmPortSerialNumber (1.3.6.1.2.1.10.56.1.3.1.10) |
read-only |
SnmpAdminString |
OCTET STRING( (0..79) |
Port serial number. |
fcmPortPhysicalNumber (1.3.6.1.2.1.10.56.1.3.1.11) |
read-only |
Unsigned32 |
Physical port number. |
As per the MIB. |
fcmPortAdminSpeed (1.3.6.1.2.1.10.56.1.3.1.12) |
read-write |
INTEGER |
auto(1), eighthGbs(2), quarterGbs(3), halfGbs(4), oneGbs(5), twoGbs(6), fourGbs(7), tenGbs(8) |
Configured port speed. |
If the configured port speed the out of range, this object, when read, returns a value close to it. The speeds of VFC interfaces and FC aggregate interface can only be auto and cannot be configured. |
fcmPortCapProtocols (1.3.6.1.2.1.10.56.1.3.1.13) |
read-only |
BITS |
unknown(0), loop(1), fabric(2), scsi(3), tcpIp(4), vi(5), ficon(6) |
Higher-level protocols that are capable of running on the port. |
fcmPortOperProtocols (1.3.6.1.2.1.10.56.1.3.1.14) |
read-only |
BITS |
Higher-level protocols that are currently operational on the port. |
fcmISPortTable
About this table
This table obtains additional information about Fibre Channel ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
fcmISPortClassFCredit (1.3.6.1.2.1.10.56.1.8.1.1) |
read-write |
FcBbCredit |
Maximum number of Class F data frames that can be transmitted by the inter-switch port without receipt of ACK or Link_Response frames. |
Supports only the read operation. When read, this object always returns 1. |
fcmISPortClassFDataFieldSize (1.3.6.1.2.1.10.56.1.8.1.2) |
read-only |
FcDataFieldSize |
Unsigned32 (1..4294967295) |
Negotiated MTU value. |
As per the MIB. |
fcmFLoginTable
About this table
This table obtains information about F_Ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex and fcmFLoginNxPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
fcmFLoginNxPortIndex (1.3.6.1.2.1.10.56.1.9.1.1) |
not-accessible |
Unsigned32 |
Index of an Nx_Port attached to the F_Port. |
As per the MIB. |
fcmFLoginPortWwn (1.3.6.1.2.1.10.56.1.9.1.2) |
read-only |
FcNameIdOrZero |
Nx_Port WWN. |
As per the MIB. |
fcmFLoginNodeWwn (1.3.6.1.2.1.10.56.1.9.1.3) |
read-only |
FcNameIdOrZero |
Node WWN of the Nx_Port. |
As per the MIB. |
fcmFLoginBbCreditModel (1.3.6.1.2.1.10.56.1.9.1.4) |
read-only |
FcBbCreditModel |
regular(1) alternate(2) |
Buffer-to-buffer credit model of the F_Port. |
As per the MIB. |
fcmFLoginBbCredit (1.3.6.1.2.1.10.56.1.9.1.5) |
read-only |
FcBbCredit |
integer32(1..15) |
Number of buffers available for holding frames to be transmitted to the attached Nx_Port. |
As per the MIB. |
fcmFLoginClassesAgreed (1.3.6.1.2.1.10.56.1.9.1.6) |
read-only |
FcClasses |
Classes of Service that the F_Port has agreed to support for the Nx_Port. |
When read, this object always returns Class3 (0x08). |
fcmFLoginClass2SeqDelivAgreed (1.3.6.1.2.1.10.56.1.9.1.7) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the F_Port has agreed to support Class 2 sequential delivery for the Nx_Port. |
When read, this object always returns false. |
fcmFLoginClass2DataFieldSize (1.3.6.1.2.1.10.56.1.9.1.8) |
read-only |
FcDataFieldSize |
Standard MIB values. |
MTU value for Class 2. |
When read, this object always returns 2112. |
fcmFLoginClass3SeqDelivAgreed (1.3.6.1.2.1.10.56.1.9.1.9) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the F_Port has agreed to support Class 3 sequential delivery for the Nx_Port. |
fcmFLoginClass3DataFieldSize (1.3.6.1.2.1.10.56.1.9.1.10) |
read-only |
FcDataFieldSize |
MTU value for Class 3. |
fcmLinkTable
About this table
This table obtains information about Fibre Channel links.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex and fcmLinkIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
fcmLinkIndex (1.3.6.1.2.1.10.56.1.10.1.1) |
not-accessible |
Unsigned32 |
Link index. |
As per the MIB. |
fcmLinkEnd1NodeWwn (1.3.6.1.2.1.10.56.1.10.1.2) |
read-only |
FcNameIdOrZero |
Local node WWN. |
fcmLinkEnd1PhysPortNumber (1.3.6.1.2.1.10.56.1.10.1.3) |
read-only |
Unsigned32 |
Local physical port number. |
As per the MIB. |
fcmLinkEnd1PortWwn (1.3.6.1.2.1.10.56.1.10.1.4) |
read-only |
FcNameIdOrZero |
Local port WWN. |
As per the MIB. |
fcmLinkEnd2NodeWwn (1.3.6.1.2.1.10.56.1.10.1.5) |
read-only |
FcNameIdOrZero |
Remote node WWN. |
As per the MIB. |
fcmLinkEnd2PhysPortNumber (1.3.6.1.2.1.10.56.1.10.1.6) |
read-only |
Unsigned32 |
Remote physical port number. |
As per the MIB. |
fcmLinkEnd2PortWwn (1.3.6.1.2.1.10.56.1.10.1.7) |
read-only |
FcNameIdOrZero |
Remote port WWN. |
As per the MIB. |
fcmLinkEnd2AgentAddress (1.3.6.1.2.1.10.56.1.10.1.8) |
read-only |
SnmpAdminString |
OCTET STRING (0..79) |
Remote agent address. |
fcmLinkEnd2PortType (1.3.6.1.2.1.10.56.1.10.1.9) |
read-only |
FcPortType |
Remote port type. |
As per the MIB. |
fcmLinkEnd2UnitType (1.3.6.1.2.1.10.56.1.10.1.10) |
read-only |
FcUnitFunctions |
BITS{ other(0), hub(1), switch(2), bridge(3), gateway(4), host(5), storageSubsys(6), storageAccessDev(7), nas(8), wdmux(9), storageDevice(10) } |
Remote device type. |
When read, this object always returns other. |
fcmLinkEnd2FcAddressId (1.3.6.1.2.1.10.56.1.10.1.11) |
read-only |
FcAddressIdOrZero |
OCTET STRING (0 | 3) |
Remote FC address. |
fcmSwitchTable
About this table
This table obtains information about Fibre Channel switches.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex and fcmSwitchIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
fcmSwitchIndex (1.3.6.1.2.1.10.56.1.2.1.1) |
not-accessible |
Unsigned32 |
Switch index. |
As per the MIB. |
fcmSwitchDomainId (1.3.6.1.2.1.10.56.1.2.1.2) |
read-write |
FcDomainIdOrZero |
Integer32 (0..5,2147483647) |
Domain ID in the default VSAN. |
Supports only the read operation. A value of zero indicates that a switch has not been assigned a Domain ID. |
fcmSwitchPrincipal (1.3.6.1.2.1.10.56.1.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the switch is the principal switch in the default VSAN. |
As per the MIB. |
fcmSwitchWWN (1.3.6.1.2.1.10.56.1.2.1.4) |
read-only |
FcNameIdOrZero |
Switch WWN. |
As per the MIB. |
