- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FDMI-MIB
- 03-HH3C-FC-FLOGIN-MIB
- 04-HH3C-FC-NAME-SERVER-MIB
- 05-HH3C-FC-PING-MIB
- 06-HH3C-FC-PSM-MIB
- 07-HH3C-NPV-MIB
- 08-HH3C-SAN-AGG-MIB
- 09-HH3C-VSAN-MIB
- 10-HH3C-FC-TRACE-ROUTE-MIB
- 11-HH3C-FC-ZONE-SERVER-MIB
- 12-HH3C-FCOE-MODE-MIB
- 13-HH3C-FCOE-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
04-HH3C-FC-NAME-SERVER-MIB | 90.32 KB |
About this MIB
Use this MIB to obtain name service information.
MIB file name
hh3c-fc-name-server.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcNameServer(10)
Scalar objects
hh3cFcNsPortLoginNotifyEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcNsPortLoginNotifyEnable (1.3.6.1.4.1.25506.2.127.10.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Trap for hh3cFcNsPortLoginNotify |
As per the MIB. |
hh3cFcNsPortLogoutNotifyEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcNsPortLogoutNotifyEnable (1.3.6.1.4.1.25506.2.127.10.1.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Trap for hh3cFcNsPortLogoutNotify |
As per the MIB. |
Tabular objects
hh3cFcNsObjsForNotification
About this table
This table contains FC name service information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
This table indexes are hh3cFcNsLocalSwitchWWN and hh3cFcNsFloginPortWWN.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcNsLocalSwitchWWN (1.3.6.1.4.1.25506.2.127.10.1.1.2.1) |
accessible-for-notify |
Hh3cFcNameId |
OCTET STRING(8) |
Local switch WWN. |
As per the MIB. |
hh3cFcNsFloginPortWWN (1.3.6.1.4.1.25506.2.127.10.1.1.2.2) |
Hh3cFcNameId |
OCTET STRING(8) |
WWN of the Nx_Port performing a Fabric Login to the local switch. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.10.1.1.0.1 |
Node online |
Informational |
Warning |
N/A |
OFF |
Notification triggers
An Nx_Port performs a Fabric Login.
System impact
No negative impact on services.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-name-service login command.
· MIB: Set hh3cFcNsPortLoginNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-name-service login command.
· MIB: Set hh3cFcNsPortLoginNotifyEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1 (hh3cVsanIndex) |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
1.3.6.1.4.1.25506.2.127.10.1.1.2.1 (hh3cFcNsLocalSwitchWWN) |
Local switch WWN. |
hh3cFcNsLocalSwitchWWN hh3cFcNsFloginPortWWN |
Hh3cFcNameId |
OCTET STRING (0 | 8) |
1.3.6.1.4.1.25506.2.127.10.1.1.2.2 (hh3cFcNsFloginPortWWN) |
Port WWN. |
Hh3cFcNameId |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.10.1.1.0.2 |
Node offline |
Informational |
Warning |
OFF |
An Nx_Port performs a Fabric Logout.
System impact
The number of logged-in nodes on the switch decreases.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-name-service logout command.
· MIB: Set hh3cFcNsPortLogoutNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-name-service logout command.
· MIB: Set hh3cFcNsPortLogoutNotifyEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VSAN ID. |
hh3cVsanIndex |
Hh3cFcVsanIndex |
Local switch WWN. |
Hh3cFcNameId |
Port WWN. |
Hh3cFcNameId |
Recommended action
