19-FC and FCoE
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10019-FC and FCoE
06-HH3C-FC-PSM-MIB
06-HH3C-FC-PSM-MIB 209.84 KB
HH3C-FC-PSM-MIB
About this MIB
Use this MIB to configure port security.
MIB file name
hh3c-fc-psm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcPsm(8)
Scalar objects
hh3cFcPsmNotifyEnable
Object (OID)
Access
Value range
Implementation
hh3cFcPsmNotifyEnable (1.3.6.1.4.1.25506.2.127.8.1.1.1)
read-write
TruthValue
true(1),
false(2)
Notifications state
The default value is false(2).
Tabular objects
hh3cFcPsmEnableTable
About this table
This table enables port security in a VSAN.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cFcPsmEnableVsanIndex.
Object (OID)
Access
Value range
Implementation
hh3cFcPsmEnableVsanIndex (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.1)
not-accessible
Unsigned32
Unsigned32(1..4095)
VSAN ID
As per the MIB.
hh3cFcPsmEnable (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.2)
read-write
INTEGER
enable(1),
enableWithAutoLearn(2),
disable(3),
noop(4)
Enable type.
As per the MIB.
hh3cFcPsmEnableState (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.3)
read-only
TruthValue
true(1),
false(2)
Enable status.
As per the MIB.
hh3cFcPsmConfigTable
About this table
This table configures port security settings.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Not supported
Columns
The table indexes are hh3cFcPsmEnableVsanIndex and hh3cFcPsmIndex.
Object (OID)
Access
Value range
Implementation
hh3cFcPsmIndex (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.1)
not-accessible
Unsigned32
Unsigned32(1..32768)
Index of the port bound to the VSAN.
As per the MIB.
hh3cFcPsmLoginDevType (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.2)
read-create
Hh3cFcPsmPortBindDevType
nWWN(1),
pWWN(2),
sWWN(3),
wildCard(4)
Device type.
As per the MIB.
hh3cFcPsmLoginDev (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.3)
read-create
Hh3cFcNameIdOrZero
OCTET STRING(0..255)
Device address.
As per the MIB.
hh3cFcPsmLoginPoint (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.4)
read-create
InterfaceIndexOrZero
Integer32(0..255)
Port address.
As per the MIB.
hh3cFcPsmRowStatus (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.5)
read-create
RowStatus
INTEGER (0..7)
Row status.
As per the MIB.
hh3cFcPsmEnfTable
About this table
This table obtains port security database information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cFcPsmEnableVsanIndex and hh3cFcPsmEnfIndex.
Object (OID)
Access
Value range
Implementation
hh3cFcPsmEnfIndex (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.1)
not-accessible
Unsigned32
Unsigned32 (1..32768)
As per the MIB.
hh3cFcPsmEnfLoginDevType (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.2)
read-only
nWWN(1),
pWWN(2),
sWWN(3),
wildCard(4)
Device type.
As per the MIB.
hh3cFcPsmEnfLoginDev (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.3)
read-only
Hh3cFcNameIdOrZero
OCTET STRING (0..255)
Device address.
As per the MIB.
hh3cFcPsmEnfLoginPoint (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.4)
read-only
Integer32(0..255)
Port address.
As per the MIB.
hh3cFcPsmEnfEntryType (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.5)
read-only
INTEGER
learning(1),
learned(2),
static(3)
Binding entry type.
As per the MIB.
hh3cFcPsmCopyToConfigTable
About this table
This table converts learned entries to static entries.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cFcPsmCopyToConfig (1.3.6.1.4.1.25506.2.127.8.1.2.4.1.1)
read-write
INTEGER
copy(1),
noop(2)
Converts learned entries to static entries.
As per the MIB.
hh3cFcPsmAutoLearnTable
About this table
This table enables auto learning.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cFcPsmAutoLearnEnable (1.3.6.1.4.1.25506.2.127.8.1.2.5.1.1)
read-write
TruthValue
true(1),
false(2)
Enables auto learning.
As per the MIB.
hh3cFcPsmClearTable
About this table
This table clears binding entries in the port security database and port security statistics for an interface.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cFcPsmClearType (1.3.6.1.4.1.25506.2.127.8.1.2.6.1.1)
read-write
Hh3cFcPsmClearEntryType
clearStatic(1),
clearAutolearn(2),
clearAll(3),
noop(4)
Binding entry type.
As per the MIB.
hh3cFcPsmClearIntf (1.3.6.1.4.1.25506.2.127.8.1.2.6.1.2)
read-write
Integer32 (0..2147483647)
Interface index.
As per the MIB.
hh3cFcPsmStatsTable
About this table
This table obtains port security statistics on the local device.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cFcPsmAllowedLogins (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.1)
read-only
Counter32
Standard MIB values.
Number of allowed logins.
As per the MIB.
hh3cFcPsmDeniedLogins (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.2)
read-only
Counter32
Number of denied logins.
As per the MIB.
hh3cFcPsmStatsClear (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.3)
read-write
INTEGER
clear(1),
noop(2)
Clears statistics of hh3cFcPsmStatsTable.
As per the MIB.
hh3cFcPsmViolationTable
About this table
This table obtains security violation entries. If a WWN logs in to an interface repeatedly, the system updates the login time and count.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cFcPsmEnableVsanIndex and hh3cFcPsmViolationIndex.
Object (OID)
Access
Value range
Implementation
hh3cFcPsmViolationIndex (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.1)
not-accessible
Unsigned32
Unsigned32(1..1024)
Violation index.
As per the MIB.
hh3cFcPsmLoginPWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.2)
read-only
Hh3cFcNameIdOrZero
OCTET STRING(0 | 8 | 16)
pWWN of a denied device.
As per the MIB.
hh3cFcPsmLoginNWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.3)
read-only
Hh3cFcNameIdOrZero
nWWN of a denied device.
As per the MIB.
hh3cFcPsmLoginSWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.4)
read-only
Hh3cFcNameIdOrZero
sWWN of a denied device.
As per the MIB.
hh3cFcPsmLoginIntf (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.5)
read-only
InterfaceIndex
Integer32(1..2147483647)
Port index of a denied device.
As per the MIB.
hh3cFcPsmLoginTime (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.6)
read-only
DateAndTime
OCTET STRING(1..255)
Violation time.
As per the MIB.
hh3cFcPsmLoginCount (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.7)
read-only
Counter32
Number of violations.
As per the MIB.
Notifications
hh3cFcPsmFPortDenyNotify
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.127.8.0.1
F_Port denied device login
Informational
Warning
OFF
Notification triggers
An F_Port denied device login.
System impact
Services on the F_Port are inaccessible.
Status control
ON
·     MIB: Set hh3cFcPsmNotifyEnable to true(1).
OFF
·     MIB: Set hh3cFcPsmNotifyEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.2
(ifDescr)
ifDescr name
ifIndex
STRING
OCTET STRING(0…255)
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.2 (hh3cFcPsmLoginPWWN)
Hh3cFcNameIdOrZero
OCTET STRING(0…255)
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.5 (hh3cFcPsmLoginIntf)
InterfaceIndex
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.6 (hh3cFcPsmLoginTime)
Violation time.
DateAndTime
OCTET STRING(0…255)
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFcPsmEPortDenyNotify
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.127.8.0.2
E_Port denied device login
Informational
Warning
N/A
OFF
An E_Port denied device login.
System impact
Services on the E_Port are inaccessible.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.2
(ifDescr)
ifDescr name
ifIndex
STRING
OCTET STRING(0…255)
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.4 (hh3cFcPsmLoginSWWN)
Hh3cFcNameIdOrZero
OCTET STRING(0…255)
InterfaceIndex
Violation time.
DateAndTime
OCTET STRING(0…255)
Recommended action
