19-FC and FCoE
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10019-FC and FCoE
14-T11-FC-FABRIC-CONFIG-SERVER-MIB
14-T11-FC-FABRIC-CONFIG-SERVER-MIB 224.90 KB
About this MIB
Use this MIB to implement the functions supported by RFC 4935. The t11FcsPlatformTable and t11FcsNodeNameListTable tables are not supported.
MIB file name
rfc4935-t11-fc-fabric-config-server.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11FcFabricConfigServerMIB(162)
Scalar objects
t11FcsMgmtAddrChangeFabricIndex
Object (OID)
Access
Value range
Implementation
t11FcsMgmtAddrChangeFabricIndex (1.3.6.1.2.1.162.1.4.2)
accessible-for-notify
T11FabricIndex
Unsigned32 (0..4095)
ID of the VSAN in which a management address change has been detected..
Not supported
t11FcsMgmtAddrChangeIeName
Object (OID)
Access
Value range
Implementation
t11FcsMgmtAddrChangeIeName (1.3.6.1.2.1.162.1.4.3)
FcNameIdOrZero
OCTET STRING (0 | 8 | 16)
WWN of the IE for which a management address change has been detected.
Not supported
t11FamLocalSwitchWwn
Object (OID)
Access
Value range
Implementation
t11FamLocalSwitchWwn (1.3.6.1.2.1.137.1.1.1.1.8)
FcNameIdOrZero
Local switch WWN.
Not supported
Tabular objects
t11FcsFabricDiscoveryTable
About this table
This table contains control information for discovery of Fabric configuration by switches.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Not supported
Columns
The table indexes are fcmInstanceIndex and fcmSwitchIndex.
Object (OID)
Access
Value range
Implementation
t11FcsFabricDiscoveryRangeLow (1.3.6.1.2.1.162.1.1.1.1.1)
read-write
T11FabricIndex
Start VSAN of the VSAN range for discovery.
As per the MIB.
t11FcsFabricDiscoveryRangeHigh (1.3.6.1.2.1.162.1.1.1.1.2)
read-write
T11FabricIndex
End VSAN of the VSAN range for discovery.
As per the MIB.
t11FcsFabricDiscoveryStart (1.3.6.1.2.1.162.1.1.1.1.3)
read-write
INTEGER
INTEGER
1:start(1)
2:noOp(2)
Initiates a topology discovery.
As per the MIB.
t11FcsFabricDiscoveryTimeOut (1.3.6.1.2.1.162.1.1.1.1.4)
read-write
Unsigned32
Unsigned32
300..86400
Minimum interval of time for which the discovered Fabric information is cached.
As per the MIB.
t11FcsDiscoveryStateTable
About this table
This table contains the status of discovery.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, and t11FcsFabricIndex.
Object (OID)
Access
Value range
Implementation
t11FcsFabricIndex (1.3.6.1.2.1.162.1.1.2.1.1)
not-accessible
T11FabricIndex
VSAN index.
As per the MIB.
t11FcsDiscoveryStatus (1.3.6.1.2.1.162.1.1.2.1.2)
read-write
INTEGER
1:inProgress(1)
2:completed(2)
3:localOnly(3)
Status of the discovery.
As per the MIB.
t11FcsDiscoveryCompleteTime (1.3.6.1.2.1.162.1.1.2.1.3)
read-only
TimeTicks
TimeTicks
(0.. 4294967295)
Time when discovery was most recently completed.
As per the MIB.
t11FcsIeTable
About this table
This table contains information about Interconnect Elements (IEs).
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsFabricIndex, and t11FcsIeName.
Object (OID)
Access
Value range
Implementation
t11FcsIeName (1.3.6.1.2.1.162.1.2.1.1.1)
not-accessible
OCTET STRING
FcNameIdOrZero
IE WWN.
As per the MIB.
t11FcsIeType  (1.3.6.1.2.1.162.1.2.1.1.2)
read-only
INTEGER
T11FcIeType
IE type.
As per the MIB.
t11FcsIeDomainId (1.3.6.1.2.1.162.1.2.1.1.3)
read-only
Integer32
FcDomainIdOrZero
IE domain ID.
As per the MIB.
t11FcsIeMgmtId (1.3.6.1.2.1.162.1.2.1.1.4)
read-only
OCTET STRING
FcAddressIdOrZero
Domain controller address of the IE.
As per the MIB.
t11FcsIeFabricName (1.3.6.1.2.1.162.1.2.1.1.5)
read-only
OCTET STRING
FcNameIdOrZero
Fabric name (WWN) of the IE.
As per the MIB.
t11FcsIeLogicalName (1.3.6.1.2.1.162.1.2.1.1.6)
read-only
OCTET STRING
OCTET STRING
Logical name (WWN) of the IE.
As per the MIB.
t11FcsIeMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.1.1.7)
read-only
Unsigned32
T11FcListIndexPointerOrZero
Management address list index for the IE.
As per the MIB.
t11FcsIeInfoList (1.3.6.1.2.1.162.1.2.1.1.8)
read-only
OCTET STRING
OCTET STRING
Information list for the IE, including vendor name, model name/number, and release code/level, and vendor-specific information.
As per the MIB.
t11FcsMgmtAddrListTable
About this table
This table contains information about management address lists.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsMgmtAddrListIndex, and t11FcsMgmtAddrIndex.
Object (OID)
Access
Value range
Implementation
t11FcsMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.2.1.1)
not-accessible
Unsigned32
T11FcListIndex
Management address list index.
As per the MIB.
t11FcsMgmtAddrIndex (1.3.6.1.2.1.162.1.2.2.1.2)
not-accessible
Unsigned32
Unsigned32
1:1..4294967295
Management address index.
As per the MIB.
t11FcsMgmtAddr (1.3.6.1.2.1.162.1.2.2.1.3)
read-only
OCTET STRING
URLString
Management address.
As per the MIB.
t11FcsPortTable
About this table
This table contains information about the ports of IEs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsIeName, and t11FcsPortName.
Object (OID)
Access
Value range
Implementation
t11FcsPortName (1.3.6.1.2.1.162.1.2.4.1.1)
not-accessible
OCTET STRING
FcNameIdOrZero
Port name (WWN) of the port.
As per the MIB.
t11FcsPortType  (1.3.6.1.2.1.162.1.2.4.1.2)
read-only
Unsigned32
FcPortType
Port type.
As per the MIB.
t11FcsPortTxType (1.3.6.1.2.1.162.1.2.4.1.3)
read-only
INTEGER
T11FcPortTxType
Port Tx Type.
As per the MIB.
t11FcsPortModuleType (1.3.6.1.2.1.162.1.2.4.1.4)
read-only
Unsigned32
Unsigned32
Port module type.
As per the MIB.
t11FcsPortPhyPortNum (1.3.6.1.2.1.162.1.2.4.1.5)
read-only
Unsigned32
Unsigned32
Physical port number.
As per the MIB.
t11FcsPortAttachPortNameIndex (1.3.6.1.2.1.162.1.2.4.1.6)
read-only
Unsigned32
Attached port name list.
As per the MIB.
t11FcsPortState (1.3.6.1.2.1.162.1.2.4.1.7)
read-only
INTEGER
T11FcPortState
Port status.
As per the MIB.
t11FcsPortSpeedCapab (1.3.6.1.2.1.162.1.2.4.1.8)
read-only
OCTET STRING
OCTET STRING
SIZE (2)
Port speed capabilities.
As per the MIB.
t11FcsPortOperSpeed (1.3.6.1.2.1.162.1.2.4.1.9)
read-only
OCTET STRING
OCTET STRING
SIZE (2)
Operating port speed.
As per the MIB.
t11FcsPortZoningEnfStatus (1.3.6.1.2.1.162.1.2.4.1.10)
read-only
OCTET STRING
OCTET STRING
SIZE (12)
Zoning enforcement status.
As per the MIB.
t11FcsAttachPortNameListTable
About this table
This table contains all the lists of attached port names.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsAttachPortNameListIndex, and t11FcsAttachPortName.
Object (OID)
Access
Value range
Implementation
t11FcsAttachPortNameListIndex (1.3.6.1.2.1.162.1.2.5.1.1)
not-accessible
Unsigned32
T11FcListIndex
Attached port name list index.
As per the MIB.
t11FcsAttachPortName (1.3.6.1.2.1.162.1.2.5.1.2)
read-only
OCTET STRING
OCTET STRING
SIZE (12)
Attached port name, inlcuding port WWN, port flag, and port type.
As per the MIB.
t11FcsPlatformTable
About this table
This table contains information on platforms.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsFabricIndex, and t11FcsPlatformIndex.
Object (OID)
Access
Value range
Implementation
t11FcsPlatformIndex (1.3.6.1.2.1.162.1.2.6.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Platform index.
As per the MIB.
t11FcsPlatformName (1.3.6.1.2.1.162.1.2.6.1.2)
read-only
OCTET STRING
OCTET STRING
(1…255)
Platform name.
As per the MIB.
t11FcsPlatformType (1.3.6.1.2.1.162.1.2.6.1.3)
read-only
OCTET STRING
OCTET STRING
(1…4)
Platform type.
As per the MIB.
t11FcsPlatformNodeNameListIndex (1.3.6.1.2.1.162.1.2.6.1.4)
read-only
Unsigned32
List of nodes for this platform.
As per the MIB.
t11FcsPlatformMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.6.1.5)
read-only
Unsigned32
List of management addresses for this platform.
As per the MIB.
t11FcsPlatformVendorId (1.3.6.1.2.1.162.1.2.6.1.6)
read-only
SnmpAdminString
OCTET STRING (0 | 12)
Vendor of this platform.
As per the MIB.
t11FcsPlatformProductId (1.3.6.1.2.1.162.1.2.6.1.7)
read-only
SnmpAdminString
OCTET STRING (0 | 20)
Vendor's product and/or model identifier for this platform.
As per the MIB.
t11FcsPlatformProductRevLevel (1.3.6.1.2.1.162.1.2.6.1.8)
read-only
SnmpAdminString
OCTET STRING (0 | 4..32)
Product revision level for this platform.
As per the MIB.
t11FcsPlatformDescription (1.3.6.1.2.1.162.1.2.6.1.9)
read-only
SnmpAdminString
OCTET STRING (0 | 4..128)
Description of this platform.
As per the MIB.
t11FcsPlatformLabel (1.3.6.1.2.1.162.1.2.6.1.10)
read-only
SnmpAdminString
OCTET STRING (0 | 4..64)
Administratively assigned symbolic name for the platform.
As per the MIB.
t11FcsPlatformLocation (1.3.6.1.2.1.162.1.2.6.1.11)
read-only
SnmpAdminString
Physical location of the platform.
As per the MIB.
t11FcsPlatformSystemID (1.3.6.1.2.1.162.1.2.6.1.12)
read-only
SnmpAdminString
ID of the hosting system that this platform is associated with.
As per the MIB.
t11FcsPlatformSysMgmtAddr (1.3.6.1.2.1.162.1.2.6.1.13)
read-only
Unsigned32
List of management addresses for the platform.
As per the MIB.
t11FcsPlatformClusterId (1.3.6.1.2.1.162.1.2.6.1.14)
read-only
SnmpAdminString
ID of the cluster that this platform is associated with.
As per the MIB.
t11FcsPlatformClusterMgmtAddr (1.3.6.1.2.1.162.1.2.6.1.15)
read-only
Unsigned32
List of management addresses for the cluster.
As per the MIB.
t11FcsPlatformFC4Types (1.3.6.1.2.1.162.1.2.6.1.16)
read-only
OCTET STRING
OCTET STRING
FC-4 types supported by this platform.
As per the MIB.
About this table
This table contains all the lists of nodes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsNodeNameListIndex, and t11FcsNodeName.
Object (OID)
Access
Value range
Implementation
t11FcsNodeNameListIndex (1.3.6.1.2.1.162.1.2.7.1.1)
not-accessible
T11FcListIndex
Unsigned32 (1..4294967295)
Node name list index.
As per the MIB.
t11FcsNodeName (1.3.6.1.2.1.162.1.2.7.1.2)
read-only
OCTET STRING
FcNameIdOrZero
Node name.
As per the MIB.
t11FcsStatsTable
About this table
This table contains all the statistics related to the Fabric Configuration Server (FCS).
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
t11FcsInGetReqs (1.3.6.1.2.1.162.1.3.1.1.1)
read-only
Counter32
Counter32
Number of Get Requests received by the FCS.
As per the MIB.
t11FcsOutGetReqs (1.3.6.1.2.1.162.1.3.1.1.2)
read-only
Counter32
Counter32
Number of Get Requests sent by the FCS.
As per the MIB.
t11FcsInRegReqs (1.3.6.1.2.1.162.1.3.1.1.3)
read-only
Counter32
Counter32
Number of Registration Requests received by the FCS.
When read, this object always returns 0.
t11FcsOutRegReqs (1.3.6.1.2.1.162.1.3.1.1.4)
read-only
Counter32
Counter32
Number of Registration Requests sent by the FCS.
t11FcsInDeregReqs (1.3.6.1.2.1.162.1.3.1.1.5)
read-only
Counter32
Counter32
Number of Deregistration Requests received by the FCS.
t11FcsOutDeregReqs (1.3.6.1.2.1.162.1.3.1.1.6)
read-only
Counter32
Counter32
Number of Deregistration Requests sent by the FCS.
t11FcsRejects (1.3.6.1.2.1.162.1.3.1.1.7)
read-only
Counter32
Counter32
Total number of requests rejected by the FCS.
As per the MIB.
t11FcsNotifyControlTable
About this table
This table contains control information for notifications generated due to FCS events.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
t11FcsReqRejectNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.1)
read-write
INTEGER
TruthValue
true(1)
false(2)
Specifies if the FCS should generate t11FcsReqRejectNotifyEnable notifications.
As per the MIB.
t11FcsDiscoveryCompNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.2)
read-write
INTEGER
TruthValue
true(1)
false(2)
Specifies if the FCS should generate t11FcsDiscoveryCompNotifyEnable notifications.
As per the MIB.
t11FcsMgmtAddrChangeNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.3)
read-write
INTEGER
TruthValue
true(1)
false(2)
Specifies if the FCS should generate t11FcsMgmtAddrChangeNotifyEnable notifications.
As per the MIB.
t11FcsRejectCtCommandString (1.3.6.1.2.1.162.1.4.1.1.4)
read-only
OCTET STRING
OCTET STRING (SIZE (0..255))
Binary content of the FCS request.
As per the MIB.
t11FcsRejectRequestSource (1.3.6.1.2.1.162.1.4.1.1.5)
read-only
OCTET STRING
FcNameIdOrZero
WWN that was the source of the CT_IU contained in the corresponding instance of t11FcsRejectCtCommandString.
As per the MIB.
t11FcsRejectReasonCode (1.3.6.1.2.1.162.1.4.1.1.6)
read-only
T11NsGs4RejectReasonCode
none(1),
invalidCmdCode(2),
invalidVerLevel(3),
logicalError(4),
invalidIUSize(5),
logicalBusy(6),
protocolError(7),
unableToPerformCmdReq(8),
cmdNotSupported(9),
serverNotAvailable(10),
couldNotEstabSession(11),
vendorError(12)
Reason code corresponding to the latest FCS request rejected by the local system.
As per the MIB.
t11FcsRejectReasonCodeExp (1.3.6.1.2.1.162.1.4.1.1.7)
read-only
T11FcsRejectReasonExplanation
noAdditionalExplanation(1),
invNameIdForIEOrPort(2),
ieListNotAvailable(3),
ieTypeNotAvailable(4),
domainIdNotAvailable(5),
mgmtIdNotAvailable(6),
fabNameNotAvailable(7),
ielogNameNotAvailable(8),
mgmtAddrListNotAvailable(9),
ieInfoListNotAvailable(10),
portListNotAvailable(11),
portTypeNotAvailable(12),
phyPortNumNotAvailable(13),
attPortNameListNotAvailable(14),
portStateNotAvailable(15),
unableToRegIELogName(16),
platformNameNoExist(17),
platformNameAlreadyExists(18),
platformNodeNameNoExists(19),
platformNodeNameAlreadyExists(20),
resourceUnavailable(21),
noEntriesInLunMap(22),
invalidDeviceNameLength(23),
multipleAttributes(24),
invalidAttribBlockLength(25),
attributesMissing(26)
Corresponding reason code explanation when the corresponding instance of t11FcsRejectReasonCode has the value: 'unable to perform command request'.
As per the MIB.
t11FcsRejectReasonVendorCode (1.3.6.1.2.1.162.1.4.1.1.8)
read-only
OCTET STRING
OCTET STRING (SIZE(1))
Registration reject vendor-specific code.
As per the MIB.
Notifications
This document provides information about the SNMP notifications for T11-FC-FABRIC-CONFIG-SERVER-MIB. It also provides recommended actions to help you remove the error conditions reported through SNMP notifications.
t11FcsRqRejectNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.162.0.1
Informational
Major
N/A
OFF
Notification triggers
This notification is generated whenever the FCS on a switch rejects an FCS request.
System impact
The FCS-related services are affected.
Status control
ON
MIB: Set t11FcsReqRejectNotifyEnable to true(1).
OFF
MIB: Set t11FcsReqRejectNotifyEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.137.1.1.1.1.8 (t11FamLocalSwitchWwn)
Local switch WWN.
fcmInstanceIndex
fcmSwitchIndex
t11FcsFabricIndex
FcNameIdOrZero
 OCTET STRING (SIZE (0 | 8 | 16))
1.3.6.1.2.1.162.1.4.1.1.6 (t11FcsRejectReasonCode)
fcmInstanceIndex
fcmSwitchIndex
t11FcsFabricIndex
none(1)
invalidCmdCode(2)
invalidVerLevel(3)
logicalError(4)
invalidIUSize(5)
logicalBusy(6)
protocolError(7)
cmdNotSupported(9)
vendorError(12)
1.3.6.1.2.1.162.1.4.1.1.7 (t11FcsRejectReasonCodeExp)
fcmInstanceIndex
fcmSwitchIndex
t11FcsFabricIndex
 1.3.6.1.2.1.162.1.4.1.1.8(t11FcsRejectReasonVendorCode)
fcmInstanceIndex
fcmSwitchIndex
t11FcsFabricIndex
OCTET STRING
SIZE(1)
Recommended action
To resolve the issue:
1.     Verify that the FCS configuration is correct.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help..
t11FcsDiscoveryCompleteNotify
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.162.0.2
Discovery completed in VSANs
Informational
Warning
N/A
OFF
This notification is generated by the FCS on the completion of the discovery of Fabrics in the range that has t11FcsFabricDiscoveryRangeLow at its low end.
System impact
No negative impact on services.
Status control
ON
MIB: Set t11FcsDiscoveryCompNotifyEnable to true(1).
OFF
MIB: Set t11FcsDiscoveryCompNotifyEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.162.1.1.1.1.1 (t11FcsFabricDiscoveryRangeLow)
Start VSAN ID of the VSAN range.
fcmInstanceIndex
fcmSwitchIndex
T11FabricIndex
Unsigned32(0..4095)
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.162.0.3
Management address change
Informational
Warning
N/A
OFF
This notification is generated by the FCS whenever the management address of an IE changes, i.e., whenever an entry in the t11FcsMgmtAddrListTable changes.
System impact
Status control
ON
MIB: Set t11FcsMgmtAddrChangeNotifyEnable to true(1).
OFF
MIB: Set t11FcsMgmtAddrChangeNotifyEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.162.1.4.2 (t11FcsMgmtAddrChangeFabricIndex)
VSAN ID.
N/A
T11FabricIndex
Unsigned32(0..4095)
1.3.6.1.2.1.162.1.4.3 (t11FcsMgmtAddrChangeIeName)
Local switch WWN.
N/A
FcNameIdOrZero
Recommended action
