19-FC and FCoE
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10019-FC and FCoE
15-T11-FC-NAME-SERVER-MIB
15-T11-FC-NAME-SERVER-MIB 132.36 KB
About this MIB
Use this MIB to implement the functions supported by RFC 4438. A switch does not support this MIB when it is operating is NPV mode.
MIB file name
rfc4438-t11-fc-name-server.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11FcNameServerMIB(135)
Tabular objects
t11NsInfoSubsetTable
About this table
This table contains one entry for each Name Server Information Subset within each Fibre Channel management instance.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Not supported
Columns
The table indexes are fcmInstanceIndex and t11NsInfoSubsetIndex.
Object (OID)
Access
Value range
Implementation
t11NsInfoSubsetIndex (1.3.6.1.2.1.135.1.1.1.1.1)
not-accessible
Unsigned32
Unsigned32
(1...4294967295)
An arbitrary integer value that uniquely identifies this Name Server Information Subset.
As per the MIB.
t11NsInfoSubsetSwitchIndex (1.3.6.1.2.1.135.1.1.1.1.2)
read-only
Unsigned32
Unsigned32
(0...4294967295)
Switch index.
As per the MIB.
t11NsInfoSubsetTableLastChange (1.3.6.1.2.1.135.1.1.1.1.3)
read-only
TimeStamp
Timeticks
(0.. 4294967295)
Last entry update time.
As per the MIB.
t11NsInfoSubsetNumRows (1.3.6.1.2.1.135.1.1.1.1.4)
read-only
Integer32
Integer32
(0..2147483647)
Number of Nx_Ports currently registered in this Name Server Information Subset.
As per the MIB.
t11NsInfoSubsetTotalRejects (1.3.6.1.2.1.135.1.1.1.1.5)
read-only
Counter32
Counter32
Total number of (CT_IU) Requests for Name Server functions that were rejected for inclusion in this Name Server Information Subset.
As per the MIB.
t11NsInfoSubsetRejReqNotfyEnable (1.3.6.1.2.1.135.1.1.1.1.6)
read-write
TruthValue
true(1),
false(2)
Indicates notifications are generated by rejections of requests to register information in this Name Server Information Subset.
As per the MIB.
t11NsRegTable
About this table
This table contains entries for all Nx_Ports registered in the identified Name Server Information Subsets across all Fabrics for which such subsets contain information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, t11NsInfoSubsetIndex, t11NsRegFabricIndex, and t11NsRegPortIdentifier.
Object (OID)
Access
Value range
Implementation
t11NsRegFabricIndex (1.3.6.1.2.1.135.1.1.2.1.1)
not-accessible
T11FabricIndex
Unsigned32 (0..4095)
VSAN ID.
As per the MIB.
t11NsRegPortIdentifier (1.3.6.1.2.1.135.1.1.2.1.2)
not-accessible
FcAddressIdOrZero
OCTET STRING (0 | 3)
FC ID of the Nx_Port.
As per the MIB.
t11NsRegPortName (1.3.6.1.2.1.135.1.1.2.1.3)
read-only
FcNameIdOrZero
OCTET STRING (0 | 8 | 16)
Port WWN of the Nx_Port.
As per the MIB.
t11NsRegNodeName (1.3.6.1.2.1.135.1.1.2.1.4)
read-only
FcNameIdOrZero
Node WWN of the Nx_Port.
As per the MIB.
t11NsRegClassOfSvc (1.3.6.1.2.1.135.1.1.2.1.5)
read-only
FcClasses
BITS {
classF(0),
class1(1),
class2(2),
class3(3),
class4(4),
class5(5),
class6(6)
Class of service indicator.
As per the MIB.
t11NsRegNodeIpAddress (1.3.6.1.2.1.135.1.1.2.1.6)
read-only
OCTET STRING
OCTET STRING (0 | 16)
IP address of the node of the Nx_Port.
As per the MIB.
t11NsRegProcAssoc (1.3.6.1.2.1.135.1.1.2.1.7)
read-only
OCTET STRING
OCTET STRING (0 | 8)
Fibre Channel Initial Process Associator.
As per the MIB.
Obsoleted in the FC-GS-6(09-153v1).
t11NsRegFc4Type (1.3.6.1.2.1.135.1.1.2.1.8)
read-only
OCTET STRING
OCTET STRING (0 | 32)
FC-4 protocol types supported by the Nx_Port.
As per the MIB.
t11NsRegPortType (1.3.6.1.2.1.135.1.1.2.1.9)
read-only
FcPortType
Unsigned32
Port type.
As per the MIB.
t11NsRegPortIpAddress (1.3.6.1.2.1.135.1.1.2.1.10)
read-only
OCTET STRING
IP address of the associated port.
As per the MIB.
t11NsRegFabricPortName (1.3.6.1.2.1.135.1.1.2.1.11)
read-only
FcNameIdOrZero
Fabric Port Name (WWN) of the Fx_Port to which the Nx_Port is attached.
As per the MIB.
t11NsRegHardAddress (1.3.6.1.2.1.135.1.1.2.1.12)
read-only
FcAddressIdOrZero
Hardware address.
As per the MIB.
t11NsRegSymbolicPortName (1.3.6.1.2.1.135.1.1.2.1.13)
read-only
SnmpAdminString
OCTET STRING
(0…255)
User-defined name of the port.
As per the MIB.
t11NsRegSymbolicNodeName (1.3.6.1.2.1.135.1.1.2.1.14)
read-only
SnmpAdminString
OCTET STRING
(0…255)
User-defined name of the node of this port.
As per the MIB.
t11NsRegFc4Features (1.3.6.1.2.1.135.1.1.2.1.15)
read-only
OCTET STRING
OCTET STRING (0 | 128)
FC-4 Features associated with FC-4 Types on this port.
As per the MIB.
t11NsRejectTable
About this table
This table contains information about the most recent Name Server Registration Request failures for various ports on various Fabrics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
t11NsRejectCtCommandString (1.3.6.1.2.1.135.1.1.4.1.1)
read-only
OCTET STRING
OCTET STRING
1:0..255
Binary content of the Registration Request.
As per the MIB.
t11NsRejectReasonCode (1.3.6.1.2.1.135.1.1.4.1.2)
read-only
T11NsGs4RejectReasonCode
none(1),
invalidCmdCode(2),
invalidVerLevel(3),
logicalError(4),
invalidIUSize(5),
logicalBusy(6),
protocolError(7),
unableToPerformCmdReq(8),
cmdNotSupported(9),
serverNotAvailable(10),
couldNotEstabSession(11),
vendorError(12)
Registration reject reason code.
As per the MIB.
t11NsRejReasonCodeExp (1.3.6.1.2.1.135.1.1.4.1.3)
read-only
T11NsRejReasonCodeExpl
noAdditionalExplanation(1),
portIdentifierNotRegistered(2),
portNameNotRegistered(3),
nodeNameNotRegistered(4),
classOfServiceNotRegistered(5),
nodeIpAddressNotRegistered(6),
ipaNotRegistered(7),
fc4TypeNotRegistered(8),
symbolicPortNameNotRegistered(9),
symbolicNodeNameNotRegistered(10),
portTypeNotRegistered(11),
portIpAddressNotRegistered(12),
fabricPortNameNotRegistered(13),
hardAddressNotRegistered(14),
fc4DescriptorNotRegistered(15),
fc4FeaturesNotRegistered(16),
accessDenied(17),
unacceptablePortIdentifier(18),
databaseEmpty(19),
noObjectRegInSpecifiedScope(20),
domainIdNotPresent(21),
portIdNotPresent(22),
noDeviceAttached(23),
authorizationException(24),
authenticationException(25),
databaseFull(26)
Registration reject reason code explanation.
As per the MIB.
t11NsRejReasonVendorCode (1.3.6.1.2.1.135.1.1.4.1.4)
read-only
OCTET STRING
OCTET STRING
(1)
Registration reject vendor-specific code.
As per the MIB.
t11NsStatsTable
About this table
This table contains per-Fabric state and statistics for operations upon the identified Name Server Information Subsets.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are fcmInstanceIndex, t11NsInfoSubsetIndex, and t11NsRegFabricIndex.
Object (OID)
Access
Value range
Implementation
t11NsInGetReqs (1.3.6.1.2.1.135.1.2.1.1.1)
read-only
Counter32
Counter32
Total number of (CT_IU) Get Requests received requesting information from this Name Server Information Subset on this Fabric.
As per the MIB.
t11NsOutGetReqs (1.3.6.1.2.1.135.1.2.1.1.2)
read-only
Counter32
Counter32
Total number of (CT_IU) Get Requests sent in order to obtain information needed in this Name Server Information Subset on this Fabric.
As per the MIB.
t11NsInRegReqs (1.3.6.1.2.1.135.1.2.1.1.3)
read-only
Counter32
Counter32
Total number of (CT_IU) Registration Requests received to register information in the Name Server Information Subset on this Fabric.
As per the MIB.
t11NsInDeRegReqs (1.3.6.1.2.1.135.1.2.1.1.4)
read-only
Counter32
Counter32
Total number of (CT_IU) De-registration Requests received to de-register information from this Name Server Information Subset on this Fabric.
As per the MIB.
t11NsInRscns (1.3.6.1.2.1.135.1.2.1.1.5)
read-only
Counter32
Counter32
Total number of received RSCNs, indicating Name Server-related changes relating to this Name Server Information Subset on this Fabric.
As per the MIB.
t11NsOutRscns (1.3.6.1.2.1.135.1.2.1.1.6)
read-only
Counter32
Counter32
Total number of transmitted RSCNs, indicating Name Server-related changes relating to this Name Server Information Subset on this Fabric.
As per the MIB.
t11NsRejects (1.3.6.1.2.1.135.1.2.1.1.7)
read-only
Counter32
Counter32
Total number of CT_IU Requests for Name Server functions on this Name Server Information Subset on this Fabric that were rejected.
As per the MIB.
t11NsDatabaseFull (1.3.6.1.2.1.135.1.2.1.1.8)
read-only
TruthValue
true(1)
false(2)
Indicates whether the database containing this Name Server Information Subset is full.
As per the MIB.
